12-Network Management and Monitoring Configuration Guide
HomeSupportSwitchesS7500E-XS SeriesConfigure & DeployConfiguration GuidesH3C S7500E-XS Switch Series Configuration Guides-Release7178-6W10012-Network Management and Monitoring Configuration Guide
04-SNMP configuration
04-SNMP configuration 145.58 KB
Configuring SNMP
Overview
Simple Network Management Protocol (SNMP) is an Internet standard protocol widely used for a management station to access and operate the devices on a network, regardless of their vendors, physical characteristics, and interconnect technologies.
SNMP enables network administrators to read and set the variables on managed devices for state monitoring, troubleshooting, statistics collection, and other management purposes.
SNMP framework
The SNMP framework contains the following elements:
·     SNMP manager—Works on an NMS to monitor and manage the SNMP-capable devices in the network.
·     SNMP agent—Works on a managed device to receive and handle requests from the NMS, and sends notifications to the NMS when events, such as an interface state change, occur.
·     Management Information Base (MIB)—Specifies the variables (for example, interface status and CPU usage) maintained by the SNMP agent for the SNMP manager to read and set.
Figure 1 Relationship between NMS, agent, and MIB
MIB and view-based MIB access control
A MIB stores variables called "nodes" or "objects" in a tree hierarchy and identifies each node with a unique OID. An OID is a dotted numeric string that uniquely identifies the path from the root node to a leaf node. For example, object B in Figure 2 is uniquely identified by the OID {1.2.1.1}.
Figure 2 MIB tree
A MIB view represents a set of MIB objects (or MIB object hierarchies) with certain access privileges and is identified by a view name. The MIB objects included in the MIB view are accessible while those excluded from the MIB view are inaccessible.
A MIB view can have multiple view records each identified by a view-name oid-tree pair.
You control access to the MIB by assigning MIB views to SNMP groups or communities.
SNMP operations
SNMP provides the following basic operations:
·     Get—NMS retrieves the SNMP object nodes in an agent MIB.
·     Set—NMS modifies the value of an object node in an agent MIB.
·     Notification—SNMP agent sends traps or informs to report events to the NMS. The difference between these two types of notification is that informs require acknowledgment but traps do not. Traps are available in SNMPv1, SNMPv2c, and SNMPv3, but informs are available only in SNMPv2c and SNMPv3.
Protocol versions
SNMPv1, SNMPv2c, and SNMPv3 are supported for high encryption in non-FIPS mode. Only SNMPv3 is supported in FIPS mode. An NMS and an SNMP agent must use the same SNMP version to communicate with each other.
·     SNMPv1—Uses community names for authentication. To access an SNMP agent, an NMS must use the same community name as set on the SNMP agent. If the community name used by the NMS differs from the community name set on the agent, the NMS cannot establish an SNMP session to access the agent or receive traps from the agent.
·     SNMPv2c—Uses community names for authentication. SNMPv2c is compatible with SNMPv1, but supports more operation types, data types, and error codes.
·     SNMPv3—Uses a user-based security model (USM) to secure SNMP communication. You can configure authentication and privacy mechanisms to authenticate and encrypt SNMP packets for integrity, authenticity, and confidentiality.
Access control modes
SNMP uses the following modes to control access to MIB objects:
·     View-based Access Control ModelThe VACM mode controls access to MIB objects by assigning MIB views to SNMP communities or users.
·     Role based access controlThe RBAC mode controls access to MIB objects by assigning user roles to SNMP communities or users.
¡     An SNMP community or user with a predefined user role network-admin or level-15 has read and write access to all MIB objects.
¡     An SNMP community or user with a predefined user role network-operator has read-only access to all MIB objects.
¡     An SNMP community or user with a user role specified by the role command accesses MIB objects through the user role rules specified by the rule command.
If you create the same SNMP community or user with both modes multiple times, the most recent configuration takes effect. For more information about user roles and the rule command, see Fundamentals Command Reference.
For an NMS to access an agent:
·     The RBAC mode requires the user role bound to a community name or username to have the same access right to MIB objects as the NMS.
·     The VACM mode requires only the access right from the NMS to MIB objects.
The RBAC mode is more secure. As a best practice, use the RBAC mode to control NMS access to MIB objects.
FIPS compliance
Security strength
By default, the device provides low encryption. To obtain high encryption, you must install the Strong Cryptography feature license. This feature provides stronger cryptography, additional IPsec tunnels, and higher encryption performance. For more information about obtaining the Strong Cryptography feature license, see the release notes or contact your H3C sales representative.
Support for features, commands, and parameters differs with the cryptography capability.
Configuring SNMP basic parameters
SNMPv3 differs from SNMPv1 and SNMPv2c in many ways. Their configuration procedures are described in separate sections.
Configuring SNMPv1 or SNMPv2c basic parameters
SNMPv1 and SNMPv2c settings are supported only for high encryption in non-FIPS mode.
To configure SNMPv1 or SNMPv2c basic parameters:
Step
Remarks
N/A
2.     (Optional.) Enable the SNMP agent.
snmp-agent
By default, the SNMP agent is disabled.
The SNMP agent is enabled when you use any command that begins with snmp-agent except for the snmp-agent calculate-password command.
3.     (Optional.) Configure the system contact.
snmp-agent sys-info contact sys-contact
By default, the system contact is Hangzhou H3C Tech. Co., Ltd.
4.     (Optional.) Configure the system location.
snmp-agent sys-info location sys-location
By default, the system location is Hangzhou, China.
5.     Enable SNMPv1 or SNMPv2c.
snmp-agent sys-info version { all | { v1 | v2c } *}
By default, no SNMP version is enabled.
6.     (Optional.) Change the local engine ID.
By default, the local engine ID is the company ID plus the device ID.
7.     (Optional.) Create or update a MIB view.
By default, the MIB view ViewDefault is predefined. In this view, all the MIB objects in the iso subtree but the snmpUsmMIB, snmpVacmMIB, and snmpModules.18 subtrees are accessible.
Each view-name oid-tree pair represents a view record. If you specify the same record with different MIB sub-tree masks multiple times, the most recent configuration takes effect. Except for the four sub-trees in the default MIB view, you can create up to 16 unique MIB view records.
8.     Configure the SNMP access right.
·     (Method 1.) Create an SNMP community:
In VACM mode:
snmp-agent community { read | write } [ simple | cipher ] community-name [ mib-view view-name ] [ acl acl-number | acl ipv6 ipv6-acl-number ] *
In RBAC mode:
snmp-agent community [ simple | cipher ] community-name user-role role-name [ acl acl-number | acl ipv6 ipv6-acl-number ] *
·     (Method 2.) Create an SNMPv1/v2c group, and add users to the group:
a.     snmp-agent group { v1 | v2c } group-name [ read-view view-name ] [ write-view view-name ] [ notify-view view-name ] [ acl acl-number | acl ipv6 ipv6-acl-number ] *
b.     snmp-agent usm-user { v1 | v2c } user-name group-name [ acl acl-number | acl ipv6 ipv6-acl-number ] *
By default, no SNMP group or SNMP community exists.
The username in method 2 has the same purpose as the community name in method 1. Whichever method you use, make sure the configured name is the same as the community name on the NMS.
9.     (Optional.) Create an SNMP context.
snmp-agent context context-name
By default, no SNMP context is configured on the device.
10.     (Optional.) Map an SNMP community to an SNMP context.
snmp-agent community-map community-name context context-name
By default, no mapping between an SNMP community and an SNMP context exists on the device.
11.     (Optional.) Configure the maximum SNMP packet size (in bytes) that the SNMP agent can handle.
By default, the maximum SNMP packet size that the SNMP agent can handle is 1500 bytes.
12.     Specify the UDP port for receiving SNMP packets.
snmp-agent port port-num
By default, the device uses UDP port 161 for receiving SNMP packets.
Configuring SNMPv3 basic parameters
SNMPv3 users are managed in groups. All SNMPv3 users in a group share the same security model, but can use different authentication and privacy key settings. To implement a security model for a user and avoid SNMP communication failures, make sure the security model configuration for the group and the security key settings for the user are compliant with Table 1 and match the settings on the NMS.
Table 1 Basic security setting requirements for different security models
Security model
Security model keyword for the group
Security key settings for the user
Remarks
Authentication with privacy
privacy
Authentication key, privacy key
If the authentication key or the privacy key is not configured, SNMP communication will fail.
Authentication without privacy
authentication
Authentication key
If no authentication key is configured, SNMP communication will fail.
The privacy key (if any) for the user does not take effect.
No authentication, no privacy
Neither authentication nor privacy
None
The authentication and privacy keys, if configured, do not take effect.
To configure SNMPv3 basic parameters:
Step
Remarks
N/A
snmp-agent
5.     Enable SNMPv3.
snmp-agent sys-info version v3
* IMPORTANT:
After you change the local engine ID, the existing SNMPv3 users and encrypted keys become invalid, and you must reconfigure them.
7.     (Optional.) Configure a remote engine ID.
snmp-agent remote { ip-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ] engineid engineid
By default, no remote engine ID is configured.
To send informs to an SNMPv3 NMS, you must configure the SNMP engine ID of the NMS.
8.     (Optional.) Create or update a MIB view.
9.     (Optional.) Create an SNMPv3 group.
·     High encryption in non-FIPS mode:
snmp-agent
group v3 group-name [ authentication | privacy ] [ read-view view-name ] [ write-view view-name ] [ notify-view view-name ] [ acl acl-number | acl ipv6 ipv6-acl-number ] *
·     High encryption in FIPS mode:
snmp-agent group v3 group-name { authentication | privacy } [ read-view view-name ] [ write-view view-name ] [ notify-view view-name ] [ acl acl-number | acl ipv6 ipv6-acl-number ] *
By default, no SNMP group exists.
10.     (Optional.) Calculate a digest for the ciphertext key converted from a plaintext key.
snmp-agent calculate-password plain-password mode {
3desmd5 | 3dessha | md5 | sha } { local-engineid | specified-engineid engineid }
snmp-agent calculate-password plain-password mode sha { local-engineid | specified-engineid engineid }
N/A
11.     Create an SNMPv3 user.
·     High encryption in non-FIPS mode (in VACM mode):
snmp-agent usm-user v3 user-name group-name [ remote { ip-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ] ] [ { cipher | simple } authentication-mode { md5 | sha } auth-password [ privacy-mode { aes128 | 3des | des56 } priv-password ] ] [ acl acl-number | acl ipv6 ipv6-acl-number ] *
·     High encryption in non-FIPS mode (in RBAC mode):
snmp-agent usm-user v3 user-name user-role role-name [ remote { ip-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ] ] [ { cipher | simple } authentication-mode { md5 | sha } auth-password [ privacy-mode { aes128 | 3des | des56 } priv-password ] ] [ acl acl-number | acl ipv6 ipv6-acl-number ] *
·     High encryption in FIPS mode (in VACM mode):
snmp-agent usm-user v3 user-name group-name [ remote { ip-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ] ] { cipher | simple } authentication-mode sha auth-password [ privacy-mode aes128 priv-password ] [ acl acl-number | acl ipv6 ipv6-acl-number ] *
·     High encryption in FIPS mode (in RBAC mode):
snmp-agent usm-user v3 user-name user-role role-name [ remote { ip-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ] ] { cipher | simple } authentication-mode sha auth-password [ privacy-mode aes128 priv-password ] [ acl acl-number | acl ipv6 ipv6-acl-number ] *
·     Low encryption in VACM mode:
snmp-agent usm-user v3 user-name group-name [ remote { ip-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ] ] [ { cipher | simple } authentication-mode { md5 | sha } auth-password [ privacy-mode des56 priv-password ] ] [ acl acl-number | acl ipv6 ipv6-acl-number ] *
·     Low encryption in RBAC mode:
snmp-agent usm-user v3 user-name user-role role-name [ remote { ip-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ] ] [ { cipher | simple } authentication-mode { md5 | sha } auth-password [ privacy-mode des56 priv-password ] ] [ acl acl-number | acl ipv6 ipv6-acl-number ]
If the cipher keyword is specified, the arguments auth-password and priv-password are used as encrypted keys.
To send informs to an SNMPv3 NMS, you must configure the remote ip-address option to specify the IP address of the NMS.
12.     (Optional.) Assign a user role to an SNMPv3 user created in RBAC mode.
snmp-agent usm-user user-name v3 user-role role-name
By default, no SNMPv3 users are configured in RBAC mode.
13.     (Optional.) Create an SNMP context.
14.     (Optional.) Configure the maximum SNMP packet size (in bytes) that the SNMP agent can handle.
15.     (Optional.) Specify the UDP port for receiving SNMP packets.
Configuring SNMP logging
Enable SNMP logging only if necessary. SNMP logging is memory-intensive and might impact device performance.
The SNMP agent logs Get requests, Set requests, Set responses, and SNMP notifications, but does not log Get responses.
·     Get operation—The agent logs the IP address of the NMS, name of the accessed node, and node OID.
·     Set operation—The agent logs the NMS' IP address, name of accessed node, node OID, variable value, and error code and index for the Set operation.
·     Notification tracking—The agent logs the SNMP notifications after sending them to the NMS.
The SNMP module sends these logs to the information center as informational messages. You can configure the information center to output these messages to certain destinations, such as the console and the log buffer. The total output size for the node field (MIB node name) and the value field (value of the MIB node) in each log entry is 1024 bytes. If this limit is exceeded, the information center truncates the data in the fields. For more information about the information center, see "Configuring the information center."
To configure SNMP logging:
Step
Remarks
N/A
2.     (Optional.) Enable SNMP logging.
snmp-agent log { all | get-operation | set-operation | authfail }
By default, SNMP logging is disabled.
3.     (Optional.) Enable SNMP notification logging.
snmp-agent trap log
By default, SNMP notification logging is disabled.
Configuring SNMP notifications
The SNMP Agent sends notifications (traps and informs) to inform the NMS of significant events, such as link state changes and user logins or logouts. Unless otherwise stated, the trap keyword in the command line includes both traps and informs.
Enabling SNMP notifications
Enable an SNMP notification only if necessary. SNMP notifications are memory-intensive and might affect device performance.
To generate linkUp or linkDown notifications when the link state of an interface changes, you must perform the following tasks:
·     Enable linkUp or linkDown notification globally by using the snmp-agent trap enable standard [ linkdown | linkup ] * command.
·     Enable linkUp or linkDown notification on the interface by using the enable snmp trap updown command.
After you enable notifications for a module, whether the module generates notifications also depends on the configuration of the module. For more information, see the configuration guide for each module.
To enable SNMP notifications:
Step
Remarks
N/A
2.     Enable notifications globally.
snmp-agent trap enable [ configuration | protocol | standard [ authentication | coldstart | linkdown | linkup | warmstart ] * | system ]
By default, SNMP configuration notifications, standard notifications, and system notifications are enabled. Whether other SNMP notifications are enabled varies by modules.
3.     Enter interface view.
N/A
4.     Enable link state notifications.
By default, link state notifications are enabled.
Configuring the SNMP agent to send notifications to a host
You can configure the SNMP agent to send notifications as traps or informs to a host, typically an NMS, for analysis and management. Traps are less reliable and use fewer resources than informs, because an NMS does not send an acknowledgment when it receives a trap.
Configuration guidelines
When network congestion occurs or the destination is not reachable, the SNMP agent buffers notifications in a queue. You can configure the queue size and the notification lifetime (the maximum time that a notification can stay in the queue). A notification is deleted when its lifetime expires. When the notification queue is full, the oldest notifications are automatically deleted.
You can extend standard linkUp/linkDown notifications to include interface description and interface type, but must make sure the NMS supports the extended SNMP messages.
To send informs, make sure:
·     The SNMP agent and the NMS use SNMPv2c or SNMPv3.
·     If SNMPv3 is used, you must configure the SNMP engine ID of the NMS when you configure SNMPv3 basic settings. Also, specify the IP address of the SNMP engine when you create the SNMPv3 user.
Configuration prerequisites
Configure the SNMP agent with the same basic SNMP settings as the NMS. If SNMPv1 or SNMPv2c is used, you must configure a community name. If SNMPv3 is used, you must configure an SNMPv3 user, a MIB view, and a remote SNMP engine ID associated with the SNMPv3 user for notifications.
Make sure the SNMP agent and the NMS can reach each other.
Configuration procedure
To configure the SNMP agent to send notifications to a host:
Step
Remarks
N/A
2.     Configure a target host.
·     (High encryption in non-FIPS mode.) Send traps to the target host:
snmp-agent target-host trap address udp-domain { ip-address | ipv6 ipv6-address } [ udp-port port-number ] [ vpn-instance vpn-instance-name ] params securityname security-string [ v1 | v2c | v3 [ authentication | privacy ] ]
·     (High encryption in FIPS mode.) Send traps to the target host:
snmp-agent target-host trap address udp-domain { ip-address | ipv6 ipv6-address } [ udp-port port-number ] [ vpn-instance vpn-instance-name ] params securityname security-string v3 { authentication | privacy }
·     (High encryption in non-FIPS mode.) Send informs to the target host:
snmp-agent target-host inform address udp-domain { ip-address | ipv6 ipv6-address } [ udp-port port-number ] [ vpn-instance vpn-instance-name ] params securityname security-string { v2c | v3 [ authentication | privacy ] }
·     (High encryption in FIPS mode.) Send informs to the target host:
snmp-agent target-host inform address udp-domain { ip-address | ipv6 ipv6-address } [ udp-port port-number ] [ vpn-instance vpn-instance-name ] params securityname security-string v3 { authentication | privacy }
By default, no target host is configured.
3.     (Optional.) Configure a source address for notifications.
snmp-agent { inform | trap } source interface-type interface-number
By default, SNMP uses the IP address of the outgoing routed interface as the source IP address.
4.     (Optional.) Enable extended linkUp/linkDown notifications.
snmp-agent trap if-mib link extended
By default, the SNMP agent sends standard linkup/linkDown notifications.
5.     (Optional.) Configure the notification queue size.
By default, the notification queue can hold 100 notification messages.
6.     (Optional.) Configure the notification lifetime.
snmp-agent trap life seconds
The default notification lifetime is 120 seconds.
Displaying the SNMP settings
Display SNMP agent system information, including the contact, physical location, and SNMP version.
display snmp-agent sys-info [ contact | location | version ] *
Display SNMP agent statistics.
display snmp-agent statistics
Display the local engine ID.
display snmp-agent local-engineid
Display SNMP group information.
display snmp-agent group [ group-name ]
Display remote engine IDs.
display snmp-agent remote [ ip-address [ vpn-instance vpn-instance-name ] | ipv6 ipv6-address [ vpn-instance vpn-instance-name ] ]
Display basic information about the notification queue.
display snmp-agent trap queue
Display the modules that can generate notifications and their notification status (enable or disable).
display snmp-agent trap-list
Display SNMPv3 user information.
display snmp-agent usm-user [ engineid engineid | username user-name | group group-name ] *
Display SNMPv1 or SNMPv2c community information. (This command is supported only for high encryption in non-FIPS mode.)
Display MIB view information.
display snmp-agent mib-view [ exclude | include | viewname view-name ]
Display SNMP MIB node information.
display snmp-agent mib-node [ details | index-node | trap-node | verbose ]
Display an SNMP context.
display snmp-agent context [ context-name ]
SNMPv1/SNMPv2c configuration example
The SNMPv1 configuration procedure is the same as the SNMPv2c configuration procedure. This example uses SNMPv1, and is available only for high encryption in non-FIPS mode.
Network requirements
As shown in Figure 3, the NMS (1.1.1.2/24) uses SNMPv1 to manage the SNMP agent (1.1.1.1/24), and the agent automatically sends notifications to report events to the NMS.
Figure 3 Network diagram
1.     Configure the SNMP agent:
# Configure the IP address of the agent and make sure the agent and the NMS can reach each other. (Details not shown.)
# Specify SNMPv1, and create the read-only community public and the read and write community private.
<Agent> system-view
[Agent] snmp-agent sys-info version v1
[Agent] snmp-agent community read public
[Agent] snmp-agent community write private
# Configure contact and physical location information for the agent.
[Agent] snmp-agent sys-info contact Mr.Wang-Tel:3306
[Agent] snmp-agent sys-info location telephone-closet,3rd-floor
# Enable SNMP notifications, specify the NMS at 1.1.1.2 as an SNMP trap destination, and use public as the community name. (To make sure the NMS can receive traps, specify the same SNMP version in the snmp-agent target-host command as is configured on the NMS.)
[Agent] snmp-agent trap enable
[Agent] snmp-agent target-host trap address udp-domain 1.1.1.2 params securityname public v1
2.     Configure the SNMP NMS:
¡     Specify SNMPv1.
¡     Create the read-only community public, and create the read and write community private.
¡     Configure timeout time and maximum number of retries as needed.
For information about configuring the NMS, see the NMS manual.
The SNMP settings on the agent and the NMS must match.
# Try to get the MTU value of NULL0 interface from the agent. The attempt succeeds.
Send request to 1.1.1.1/161 ...
Protocol version: SNMPv1
Operation: Get
Request binding:
1: 1.3.6.1.2.1.2.2.1.4.135471
Response binding:
1: Oid=ifMtu.135471 Syntax=INT Value=1500
Get finished
# Use a wrong community name to get the value of a MIB node on the agent. You can see an authentication failure trap on the NMS.
1.1.1.1/2934 V1 Trap = authenticationFailure
SNMP Version = V1
Community = public
Command = Trap
Enterprise = 1.3.6.1.4.1.43.1.16.4.3.50
GenericID = 4
SpecificID = 0
Time Stamp = 8:35:25.68
SNMPv3 configuration example
As shown in Figure 4, the NMS (1.1.1.2/24) uses SNMPv3 to monitor and manage the interface status of the agent (1.1.1.1/24). The agent automatically sends notifications to report events to the NMS. The default UDP port 162 is used for SNMP notifications.
The NMS and the agent perform authentication when they establish an SNMP session. The authentication algorithm is SHA-1 and the authentication key is 123456TESTauth&!. The NMS and the agent also encrypt the SNMP packets between them by using the AES algorithm and the privacy key 123456TESTencr&!.
Figure 4 Network diagram
Configuring SNMPv3 in RBAC mode
1.     Configure the agent:
# Configure the IP address of the agent, and make sure the agent and the NMS can reach each other. (Details not shown.)
# Create the user role test, and permit test to have read and write access to the snmp node (OID 1.3.6.1.2.1.11).
<Agent> system-view
[Agent] role name test
[Agent-role-test] rule 1 permit read write oid 1.3.6.1.2.1.11
# Permit the user role test to have read-only access to the system node (OID 1.3.6.1.2.1.1) and hh3cUIMgt node (OID 1.3.6.1.4.1.25506.2.2).
[Agent-role-test] rule 2 permit read oid 1.3.6.1.4.1.25506.2.2
[Agent-role-test] rule 3 permit read oid 1.3.6.1.2.1.1
[Agent-role-test] quit
# Create the SNMPv3 user managev3user with the user role test, and enable the authentication with privacy security model for the user. Set the authentication algorithm to sha, authentication key to 123456TESTauth&!, encryption algorithm to aes128, and privacy key to 123456TESTencr&!.
[Agent] snmp-agent usm-user v3 managev3user user-role test simple authentication-mode sha 123456TESTauth&! privacy-mode aes128 123456TESTencr&!
# Enable notifications, specify the NMS at 1.1.1.2 as a notification destination, and set the username to managev3user for the notifications.
[Agent] snmp-agent target-host trap address udp-domain 1.1.1.2 params securityname managev3user v3 privacy
¡     Specify SNMPv3.
¡     Create the SNMPv3 user managev3user.
¡     Enable both authentication and privacy functions.
¡     Use SHA-1 for authentication and AES for encryption.
¡     Set the authentication key to 123456TESTauth&! and the privacy key to 123456TESTencr&!.
¡     Set the timeout time and maximum number of retries.
Configuring SNMPv3 in VACM mode
# Assign the NMS (SNMPv3 group managev3group) read and write access to the objects under the ifTable node (OID 1.3.6.1.2.1.2.2), and deny its access to any other MIB object.
<Agent> system-view
[Agent] undo snmp-agent mib-view ViewDefault
[Agent] snmp-agent mib-view included test ifTable
[Agent] snmp-agent group v3 managev3group privacy read-view test write-view test
# Assign the NMS (SNMPv3 group managev3group) read-only access to the objects under the system node (OID 1.3.6.1.2.1.1) and hh3cUIMgt node (OID 1.3.6.1.4.1.25506.2.2) in the test view.
[Agent] snmp-agent mib-view included test 1.3.6.1.2.1.1
[Agent] snmp-agent mib-view included test 1.3.6.1.4.1.25506.2.2
# Add the user managev3user to the SNMPv3 group managev3group, and set the authentication algorithm to sha, authentication key to 123456TESTauth&!, encryption algorithm to aes128, and privacy key to 123456TESTencr&!.
[Agent] snmp-agent usm-user v3 managev3user managev3group simple authentication-mode sha 123456TESTauth&! privacy-mode aes128 123456TESTencr&!
# Enable notifications, specify the NMS at 1.1.1.2 as a trap destination, and set the username to managev3user for the traps.
¡     Specify SNMPv3.
# Try to get the value of sysName from the agent. The get attempt succeeds.
Protocol version: SNMPv3
Operation: Get
Request binding:
1: 1.3.6.1.2.1.1.5.0
Response binding:
1: Oid=sysName.0 Syntax=OCTETS Value=Agent
Get finished
# Try to set the device name from the agent. The set attempt fails because the NMS has no access right to the node.
Operation: Set
Request binding:
Response binding:
Session failed ! SNMP: Cannot access variable, No Access, error index=11: Oid=sysName.0 Syntax=OCTETS Value=h3c Set finished
The following log appears only if the Set operation is performed by using RBAC mode.
%Aug 14 16:13:21:475 2013 Agent SNMP/5/SNMP_SETDENY: -IPAddr=1.1.1.2-SecurityName=managev3user-SecurityModel=SNMPv3-OP=SET-Node=sysName(1.3.6.1.2.1.1.5.0)-Value=h3c; Permission denied.
# Log in to the agent. You can see a notification on the NMS.
hh3cLogIn inform received from: 192.168.41.41 at 2013/8/14 17:36:16
  Time stamp: 0 days 08h:03m:43s.37th
  Agent address: 1.1.1.1 Port: 62861 Transport: IP/UDP Protocol: SNMPv2c Inform
  Manager address: 1.1.1.2 Port: 10005 Transport: IP/UDP
  Community: public
  Bindings (4)
    Binding #1: sysUpTime.0 *** (timeticks) 0 days 08h:03m:43s.37th
    Binding #2: snmpTrapOID.0 *** (oid) hh3cLogIn
    Binding #3: hh3cTerminalUserName.0 *** (octets) testuser [74.65.73.74.75.73.65.72 hex)]
    Binding #4: hh3cTerminalSource.0 *** (octets) VTY [56.54.59 (hex)]
