05-Layer 3 - IP Services Configuration Guide
HomeSupportSwitchesS7500E SeriesConfigure & DeployConfiguration GuidesH3C S7500E Switch Series Configuration Guides-Release7178-6W10005-Layer 3 - IP Services Configuration Guide
06-Adjacency table configuration
06-Adjacency table configuration 41.69 KB
Displaying the adjacency table
The adjacency table stores information about directly connected neighbors for IP forwarding. The neighbor information in the adjacency table in this chapter refers to non-Ethernet neighbor information.
This table is not user configurable. The neighbor information is generated, updated, and deleted by link layer protocols through negotiation. An adjacency entry contains the neighbor network layer address (next hop), output interface, link layer protocol type, and link layer address.
When forwarding an IP packet, the device does the following:
·     Searches the FIB to find the output interface and next hop.
·     Uses the output interface and next hop address to search the adjacency table for link layer forwarding information that is required for forwarding the packet.
The following table shows the items contained in an adjacency table output:
Item
IP address
IP address of the next hop in FIB table for packet forwarding. This address is used for adjacency table lookup.
Routing interface
Output interface in the matching route entry. This interface is used for adjacency table lookup, and it can be logical or physical.
Physical interface
Output physical interface that sends matching packets. If the routing interface is physical, the routing interface and physical interface are the same. If the routing interface is logical, the routing interface and physical interface are different.
Logical interface
Logical interface for sending packets, such as a Virtual-Template interface for MP.
Service type
Link layer protocol type, such as Tunnel.
Action type
Action to be taken on the matching packet: Forwarding or Drop.
Link media type
Related to the link layer protocol used by the routing interface. P2P indicates a point-to-point link, and NBMA indicates a non-broadcast multi-access link.
Link head information(IP)
Link layer header for IP forwarding.
Link head information(IPv6)
Link layer header for IPv6 forwarding.
Link head information(MPLS)
Link layer header for MPLS forwarding.
To display adjacency table entries, use one of the following commands in any view:
Display IPv4 adjacency table information (in standalone mode).
display adjacent-table { all | physical-interface interface-type interface-number | routing-interface interface-type interface-number | slot slot-number } [ count | verbose ]
Display IPv4 adjacency table information (in IRF mode).
display adjacent-table { all | physical-interface interface-type interface-number | routing-interface interface-type interface-number | chassis chassis-number slot slot-number } [ count | verbose ]
Display IPv6 adjacency table information (in standalone mode).
display ipv6 adjacent-table { all | physical-interface interface-type interface-number | routing-interface interface-type interface-number | slot slot-number } [ count | verbose ]
Display IPv6 adjacency table information (in IRF mode).
display ipv6 adjacent-table { all | physical-interface interface-type interface-number | routing-interface interface-type interface-number | chassis chassis-number slot slot-number } [ count | verbose ]
