15-EVI Command Reference
HomeSupportSwitchesS7500E SeriesReference GuidesCommand ReferencesH3C S7500E Switch Series Command References-Release7178-6W10015-EVI Command Reference
Table of Contents
Related Documents
01-EVI commands
01-EVI commands 193.64 KB
EVI commands
display evi arp-suppression
Use display evi arp-suppression to display ARP flood suppression entries.
In standalone mode:
display evi arp-suppression interface tunnel interface-number [ vlan vlan-id ] [ slot slot-number ] [ count ]
In IRF mode:
display evi arp-suppression interface tunnel interface-number [ vlan vlan-id ] [ chassis chassis-number slot slot-number ] [ count ]
interface tunnel interface-number: Specifies an EVI tunnel interface by its number.
vlan vlan-id: Specifies a VLAN ID in the range of 1 to 4094. If you do not specify a VLAN, this command displays entries for all VLANs.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays entries on the active MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays entries on the global active MPU. (In IRF mode.)
count: Displays the number of ARP flood suppression entries that match the command.
# Display ARP flood suppression entries on Tunnel 101.
<Sysname> display evi arp-suppression interface tunnel 101
IP Address      MAC Address    VLAN ID  Interface                Aging Status
1.1.1.2         000f-e201-0101 1        EVI-link1                14    Valid
1.1.1.3         000f-e201-0202 1        EVI-link1                18    Invalid
1.1.1.4         000f-e201-0203 1        EVI-link1                10    Collision
# Display the total number of ARP flood suppression entries on Tunnel 101.
<Sysname> display evi arp-suppression interface tunnel 101 count
Total entries: 3
EVI-Link interface where the entry has been learned.
Aging
Remaining lifetime (in minutes) of the EVI ARP flood suppression entry. When the timer expires, the entry is deleted.
Status
Entry status:
·     Valid—The edge device can use this entry to reply to ARP requests.
·     Invalid—No update packet has been received for this entry in the last 15 minutes. If the Invalid state lasts 10 minutes, the entry is deleted. An invalid entry cannot be used.
·     Collision—An ARP reply is received for the IP address in this entry, but the sender MAC address in the reply is different from the MAC address in this entry. This entry cannot be used and is removed 1 minute later after its state changes to Collision.
display evi isis brief
Use display evi isis brief to display brief information about EVI IS-IS processes.
display evi isis brief [ process-id ]
process-id: Specifies an EVI IS-IS process ID in the range of 0 to 65535. If you do not specify a process, this command displays brief information about all EVI IS-IS processes.
# Display brief information about an EVI IS-IS process.
<Sysname> display evi isis brief
Site ID: 1
Isolation Count: 0
Process ID: 1
Network-entity: 00.0000.fc00.2500.00
LSP-length receive: 1400
LSP-length originate: 1400
Timers:
  LSP-max-age: 1200s
  LSP-refresh: 900s
Site ID
Local site ID.
Isolation Count
Number of remote sites that have isolated the device because of site ID conflicts.
·     If the isolation count is 0, there is no conflict. The device can send hello packets.
·     If the isolation count is not 0, there are conflicts. The device cannot send hello packets. You must reconfigure the site ID.
Network-entity
Network entity name of the EVI IS-IS process.
LSP-length receive
Maximum length of incoming LSPs.
Maximum length of LSPs that the EVI IS-IS process can generate.
Timers
·     LSP-max-age—Maximum lifetime for the LSPs generated by the EVI IS-IS process.
·     LSP-refresh—Interval at which the EVI IS-IS process sends LSPs to refresh remote LSDBs.
display evi isis graceful-restart status
Use display evi isis graceful-restart status to display the GR state of EVI IS-IS processes.
display evi isis graceful-restart status [ process-id ]
process-id: Specifies an EVI IS-IS process ID in the range of 0 to 65535. If you do not specify a process, this command displays the GR state of all EVI IS-IS processes.
# Display the GR state of all EVI IS-IS processes.
<Sysname> display evi isis graceful-restart status
Process ID: 1
Restart status: RESTARTING
Restart phase: LSDB synchronization
Restart interval: 300s
T3 remaining time: 65531s
Total number of interfaces: 1
Number of waiting LSPs: 0
T2 remaining time: 56s
  Interface: EVI-Link0
    T1 remaining time: 2
    RA received: N
    CSNP received: N
    T1 expired number: 3
Restart status
Graceful Restart state:
·     COMPLETE—Restart has been completed.
·     STARTING—EVI IS-IS process begins to restart.
·     RESTARTING—EVI IS-IS process is restarting.
·     UNKNOWN—Unknown state.
Restart phase
Restart phase:
·     InitializationEVI IS-IS process is initializing.
·     LSDB synchronization—Peer EVI IS-IS processes are synchronizing LSDBs.
·     MAC receiving—EVI IS-IS process is receiving reported local MAC addresses.
·     LSP stable—EVI IS-IS process is generating LSPs.
·     LSP generation—EVI IS-IS process is refreshing and flooding LSPs to adjacent EVI neighbors.
·     Finish—Graceful Restart is complete.
·     Unknown—Unknown phase.
T3 remaining time
The remaining time (in seconds) of the T3 timer.
The GR process fails if it is not complete before this timer expires.
T2 remaining time
The remaining time (in seconds) of the T2 timer.
The T2 timer sets the LSDB synchronization interval.
T1 remaining time
The remaining time (in seconds) of the T1 timer.
The T1 timer sets the interval for the restarting device to retransmit hello messages with the RR bit set (restart request messages).
display evi isis local-mac
Use display evi isis local-mac to display local MAC reachability information maintained by EVI IS-IS.
display evi isis local-mac { dynamic | static } [ interface tunnel interface-number [ vlan vlan-id ] [ filtered | passed ] [ count ] ]
display evi isis local-mac nonadvertised [ interface tunnel interface-number [ vlan vlan-id ] [ count ] ]
dynamic: Displays the dynamic MAC addresses for the local site.
nonadvertised: Displays the MAC addresses that cannot be advertised to remote sites, including blackhole MAC addresses, multiport unicast MAC addresses, multicast MAC addresses, and MAC addresses that have been configured by using the evi selective-flooding mac-address command.
static: Displays the static MAC addresses for the local site.
interface tunnel interface-number: Specifies an EVI tunnel interface by its number. If you do not specify an EVI tunnel interface, this command displays local MAC reachability information that EVI IS-IS maintains for each EVI tunnel interface.
vlan vlan-id: Specifies a VLAN ID in the range of 1 to 4094. If you do not specify a VLAN, this command displays local MAC reachability information for all VLANs.
filtered: Specifies the local MAC addresses that are filtered by a routing policy. These MAC addresses cannot be advertised to remote sites.
passed: Specifies the local MAC addresses that are not filtered by a routing policy. These MAC addresses can be advertised to remote sites.
count: Displays the number of MAC addresses that match the command.
# Display local dynamic MAC reachability information for all EVI tunnel interfaces.
<Sysname> display evi isis local-mac dynamic
Process ID: 0
Tunnel interface: Tunnel1
  VLAN ID: 100
    MAC address: 00aa-00bb-00cc
    MAC address: 00aa-00cc-00bb (Filtered)
    MAC address: 00cc-00aa-00bb
  VLAN ID: 50
    MAC address: 00bb-00aa-00cc
    MAC address: 00bb-00cc-00aa
# Display advertisable local dynamic MAC addresses on the EVI tunnel interface Tunnel 1.
<Sysname> display evi isis local-mac dynamic interface tunnel 1 passed
Process ID: 0
  VLAN ID: 100
  VLAN ID: 50
# Display local non-advertisable MAC reachability information for all EVI tunnel interfaces.
<Sysname> display evi isis local-mac nonadvertised
MAC Flags: F-Flooding, B-Blackhole, P-Multiport, M-Multicast
Process ID: 3
  Tunnel interface: Tunnel3
  VLAN ID: 111
    MAC address: 0005-0005-0005
          Flags: F
# Display local static MAC reachability information for all EVI tunnel interfaces.
<Sysname> display evi isis local-mac static
Process ID: 0
  VLAN ID: 100
  VLAN ID: 50
# Display the local static MAC addresses that are filtered by the routing policy on Tunnel 1. These MAC addresses cannot be advertised.
<Sysname> display evi isis local-mac static interface tunnel 1 filtered
Process ID: 0
  VLAN ID: 100
  VLAN ID: 50
# Display the number of local dynamic MAC addresses on Tunnel 1.
<Sysname> display evi isis local-mac dynamic interface tunnel 1 count
5 MAC addresses found.
# Display the number of advertisable local dynamic MAC addresses on Tunnel 1.
<Sysname> display evi isis local-mac dynamic interface tunnel 1 passed count
4 MAC addresses found.
# Display the number of local static MAC addresses that are filtered by the routing policy on Tunnel 1.
<Sysname> display evi isis local-mac static interface tunnel 1 filtered count
1 MAC addresses found.
Process ID
EVI IS-IS process ID. The ID of an EVI IS-IS process is always the same as the EVI tunnel interface where the EVI IS-IS process is running.
Tunnel interface
VLAN ID
Active extended VLAN on the EVI tunnel interface.
MAC address
MAC addresses in the VLAN.
(Filtered)
The MAC address is filtered by a routing policy. It cannot be advertised to remote sites.
Flags
Flag of a local non-advertisable MAC address:
·     FMAC address that has been configured with the evi selective-flooding mac-address command.
·     BBlackhole MAC address.
·     PMultiport unicast MAC address.
·     MMulticast MAC address.
display evi isis lsdb
Use display evi isis lsdb to display the LSDBs of EVI IS-IS processes.
display evi isis lsdb [ local | lsp-id lspid | verbose ] * [ process-id ]
local: Displays locally generated LSPs.
lsp-id lspid: Specifies an LSP identifier in the SYSID.Pseudonode ID-fragment num format. The SYSID argument represents the originating node or pseudo node. The Pseudonode ID argument is separated by a dot from SYSID and by a hyphen from fragment num.
verbose: Displays detailed information about LSPs in the LSDB. If you do not specify this keyword, the command displays LSP summaries.
process-id: Specifies an EVI IS-IS process ID in the range of 0 to 65535. If you do not specify a process, this command displays LSP information for all EVI IS-IS processes.
# Display LSP summaries for all EVI IS-IS processes.
<Sysname> display evi isis lsdb
               Link state database information for EVI-ISIS(0)
LSP ID                 Seq num     Checksum  Holdtime  Length    Overload
0011.2200.0001.00-00*  0x000000f3  0xd95e    45        47        0
0011.2200.0101.00-00   0x00000017  0xbb6f    1139      85        0
0011.2200.0101.02-00   0x00000002  0x7973    805       54        0
Flags: *-Self LSP, +-Self LSP(Extended)
# Display detailed LSP information for all EVI IS-IS processes.
<Sysname> display evi isis lsdb verbose
                Link state database information for EVI-ISIS(1)
LSP ID: 3822.d69e.ee00.00-00*
Sequence number: 0x00000001
Checksum: 0xe0b5
Holdtime: 820s
Length: 47
Overload: 0
Source: 3822.d69e.ee00.00
Neighbour
    ID: 3ce5.a600.7600.02, Cost: 16777214
LSP ID: 3ce5.a600.7600.00-00
Sequence number: 0x00000007
Checksum: 0xc98a
Holdtime: 1163s
Length: 72
Overload: 0
Source: 3ce5.a600.7600.00
Neighbour
MAC addresses:
  VLAN ID: 10  Confidence: 1
    3822-d69e-ef68
    d485-64aa-7f23
    3408-0499-b44c
LSP ID: 3ce5.a600.7600.02-00
Checksum: 0xe16d
Holdtime: 819s
Length: 54
Overload: 0
Source: 3ce5.a600.7600.02
Neighbour
    ID: 3822.d69e.ee00.00, Cost: 0
    ID: 3ce5.a600.7600.00, Cost: 0
Table 5 Command output
LSP ID
LSP ID:
·     An asterisk mark (*) suffix indicates that the LSP segment is generated by the default EVI IS-IS system on the local device.
·     A plus sign (+) suffix indicates that the LSP segment is generated by an EVI IS-IS virtual system on the local device.
·     IDs of remote LSPs do not have a suffix.
Holdtime
LSP lifetime in seconds, which counts down over time.
Overload
Overload bit flag in the LSP:
·     1—The bit is set.
·     0—The bit is not set.
Source
System ID of the LSP generating device.
Neighbour
Neighbors of the LSP generating device.
ID
System ID of the neighbor.
Cost
Cost of the link between the LSP generating device and its neighbor.
MAC address
MAC addresses that can be reached through the LSP generating device.
VLAN ID
VLAN in which the MAC addresses are learned.
Confidence
LSP credibility.
display evi isis peer
Use display evi isis peer to display EVI IS-IS neighbor information.
display evi isis peer [ process-id ]
process-id: Specifies an EVI IS-IS process ID in the range of 0 to 65535. If you do not specify a process, this command displays neighbor information for all EVI IS-IS processes.
# Display neighbor information for EVI IS-IS process 0.
<Sysname> display evi isis peer 0
Process ID: 1
System ID: 5cdd.70bd.6ceb
Link interface: EVI-Link0
Circuit ID: 5cdd.70bd.6ceb.04
State: Up
Site ID: 0
Hold time: 7s
Neighbour DED priority: 64
Uptime: 01:01:14
Process ID: 1
System ID: 5cdd.70bd.6cf4
Link interface: EVI-Link1
Circuit ID: 5cdd.70bd.6cf4.04
State: Up
Site ID: 0
Hold time: 7s
Uptime: 01:01:14
Process ID: 1
System ID: 5cdd.70bd.6ce2
Link interface: EVI-Link64
Table 6 Command output
System ID
System ID of the EVI neighbor.
Link interface
·     Tunnel—Local tunnel interface.
·     EVI-link—Local EVI-Link interface.
Circuit ID
Link ID.
Adjacency state:
·     Init—Neighbor state is initializing.
·     Up—Adjacency has been set up.
·     Down—Adjacency is lost.
Site ID
Site ID of the EVI neighbor. (Conflict) indicates that the site ID of the neighbor conflicts with the local site ID.
A site ID conflict occurs if the edge devices at different sites use the same site ID.
Hold time
Adjacency hold timer in seconds, which counts down over time.
If no hello packet has been received from the neighbor before this timer expires, the device removes the adjacency with the neighbor. If a hello packet is received, the hold timer restarts.
Neighbour DED Priority
DED priority of the neighbor. The edge device with higher DED priority is more likely to be elected as the DED on an EVI link.
Uptime
The amount of time that the adjacency with the neighbor has lasted. This field uses the hours:minutes:seconds format.
display evi isis remote-mac
Use display evi isis remote-mac to display remote MAC reachability information maintained by EVI IS-IS.
display evi isis remote-mac [ interface tunnel interface-number [ vlan vlan-id ] [ count ] ]
interface tunnel interface-number: Specifies an EVI tunnel interface by its number. If you do not specify an EVI tunnel interface, this command displays remote MAC reachability information that EVI IS-IS maintains for each EVI tunnel interface.
vlan vlan-id: Specifies a VLAN ID in the range of 1 to 4094. If you do not specify a VLAN, this command displays remote MAC reachability information for all VLANs.
count: Displays the number of remote MAC addresses that match the command.
# Display remote MAC reachability information that EVI IS-IS has for all EVI tunnel interfaces.
<Sysname> display evi isis remote-mac
Process ID: 1
  VLAN ID: 106
    MAC address: 0000-0014-1414
      Interface: EVI-Link1
          Flags: 0x2
  VLAN ID: 109
          Flags: 0x2
  VLAN ID: 110
          Flags: 0x2
  VLAN ID: 112
          Flags: 0x2
  VLAN ID: 124
          Flags: 0x2
  VLAN ID: 130
# Display the number of remote MAC addresses that EVI IS-IS has on Tunnel 1.
<Sysname> display evi isis remote-mac interface tunnel 1 count
3 mac address(es) found.
Table 7 Command output
Process ID
Tunnel interface
VLAN ID
MAC address
EVI link index.
Flags
Remote MAC address flag:
·     0x1—The remote MAC address conflicts with a local dynamic MAC address.
·     0x2—The remote MAC address has been added to the MAC address table in the data plane.
·     0x4The remote MAC address conflicts with a local static MAC address or a MAC address that has been configured for selective flood.
display evi isis tunnel
Use display evi isis tunnel to display EVI IS-IS settings on EVI tunnel interfaces.
display evi isis tunnel [ tunnel-number ]
tunnel-number: Specifies an EVI tunnel interface by its number. If you do not specify an EVI tunnel interface, this command displays EVI IS-IS settings on all EVI tunnel interfaces.
# Display EVI IS-IS settings on Tunnel 101.
<Sysname> display evi isis tunnel 101
Tunnel101
MTU: 1400
DED: Yes
DED priority: 64
Hello timer: 10s
Hello multiplier: 3
CSNP timer: 10s
LSP timer: 100ms
LSP transmit-throttle count: 5
AEF: No
EVI-Link0    DED: No
LAV:
  1,50,100
Table 8 Command output
MTU
Link MTU of the tunnel.
DED
DED election result:
·     Yes—The device is a DED in the EVI network.
·     No—The device is not a DED in the EVI network.
DED priority
DED priority of the device on the EVI tunnel interface.
Hello timer
Interval (in seconds) at which EVI IS-IS sends hello packets to maintain the adjacencies with its neighbors.
Hello multiplier
Multiplier for calculating the EVI IS-IS adjacency hold time.
CSNP timer
Interval at which the edge device sends CSNP packets to advertise LSP summaries for LSDB synchronization. This timer takes effect only if the edge device is a DED.
LSP timer
Minimum LSP transmit interval in milliseconds. The device must wait for this timer to expire before sending LSPs.
Together with the maximum number of LSPs setting, this timer reduces the impact of LSP traffic on EVI network performance.
Maximum number of LSPs that can be sent at each interval.
AEF
Qualification of the device to be an appointed edge forwarder for extended VLANs at a multihomed site:
·     No.
·     Yes.
The current software version does not support multihoming. This field displays No.
EVI-link
EVI virtual link.
LAV
Active VLANs on the EVI tunnel interface. The interface extends only active VLANs to remote sites.
display evi link
Use display evi link to display information about EVI links on an EVI tunnel.
display evi link interface tunnel interface-number
# Display information about EVI links on Tunnel 1.
<Sysname> display evi link interface tunnel 1
Interface     Status Source          Destination
EVI-Link0     UP     1.1.1.1         1.1.2.1
EVI-Link1     UP     1.1.1.1         1.1.3.1
Table 9 Command output
EVI-Link interface name.
Status
EVI link status: UP or DOWN.
Source
Local address of the EVI link. All the EVI links use the source address of the EVI tunnel.
Destination
Remote address of the EVI link.
display evi mac-address
Use display evi mac-address to display remote MAC address entries.
In standalone mode:
display evi mac-address interface tunnel interface-number [ vlan vlan-id ] [ slot slot-number ] [ count ]
display evi mac-address interface tunnel interface-number mac-address mac-address vlan vlan-id [ slot slot-number ]
In IRF mode:
display evi mac-address interface tunnel interface-number [ vlan vlan-id ] [ chassis chassis-number slot slot-number ] [ count ]
display evi mac-address interface tunnel interface-number mac-address mac-address vlan vlan-id [ chassis chassis-number slot slot-number ]
mac-address mac-address: Specifies a remote MAC address.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays entries on the global active MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. (In IRF mode.)
count: Displays the number of remote MAC address entries that match the command.
# Display remote MAC address entries on Tunnel 101.
<Sysname> display evi mac-address interface tunnel 101
MAC Address      VLAN ID   Port
000f-e202-0101   2         EVI-link1, EVI-link2
# Display the total number of remote MAC address entries on Tunnel 101.
<Sysname> display evi mac-address interface tunnel 101 count
Total entries: 2
Table 10 Command output
MAC Address
Remote MAC address.
VLAN ID
VLAN that has the remote MAC address.
Port
Outgoing EVI-Link interface for reaching the MAC address.
N/A indicates that the EVI-Link interface where the MAC address was learned has been removed.
display evi neighbor-discovery client member
Use display evi neighbor-discovery client member to display information about EVI neighbors that ENDCs have learned.
display evi neighbor-discovery client member [ interface tunnel interface-number | [ local local-ip | remote client-ip | server server-ip ] [ vpn-instance vpn-instance-name ] ]
local local-ip: Specifies all EVI tunnel interfaces that use the IP address specified by the local-ip argument.
remote client-ip: Specifies the IPv4 address of an EVI neighbor.
server server-ip: Specifies the IPv4 address of an ENDS.
vpn-instance vpn-instance-name: Specifies a VPN instance by its name, a case-sensitive string of 1 to 31 characters. This option is not supported in the current software version.
Each EVI neighbor entry includes a neighbor's IP address, bridge MAC address, entry creation time, aging time, and EVI link status.
If you do not specify any parameters, this command displays IPv4 neighbor entries that all local ENDCs have learned.
# Display IPv4 neighbor entries that all local ENDCs have learned.
<Sysname> display evi neighbor-discovery client member
Interface: Tunnel1    Network ID: 1    Vpn-instance: [No Vrf]
Local Address: 1.1.1.1
Server Address: 4.4.4.4
Neighbor        System ID         Created Time           Expire    Status
2.2.2.2         5cdd-70bd-6ce2    2014/09/05 15:45:30    70        Up
3.3.3.3         5cdd-70bd-6ceb    2014/09/05 15:45:14    70        Up
4.4.4.4         5cdd-70bd-6cf4    2014/09/05 15:45:14    70        Up
Interface: Tunnel2    Network ID: 2    Vpn-instance: [No Vrf]
Interface: Tunnel3    Network ID: 3    Vpn-instance: [No Vrf]
Interface: Tunnel4    Network ID: 4    Vpn-instance: [No Vrf]
Interface: Tunnel5    Network ID: 5    Vpn-instance: [No Vrf]
Interface: Tunnel6    Network ID: 6    Vpn-instance: [No Vrf]
Table 11 Command output
Name of an ENDC-enabled EVI tunnel interface.
Network ID
EVI network ID.
Vpn-instance
VPN instance associated with the EVI tunnel. This field is not supported in the current software version.
Local Address
Source IP address of the EVI tunnel.
Server Address
IP address of the ENDS. This field displays NA if the ENDS is unknown.
Neighbor
IP address of the neighbor learned from the ENDS.
System ID
Bridge MAC address of the neighbor. This field displays NA if the bridge MAC address is unknown.
Created Time
Time when the neighbor entry was created.
Expire
Remaining lifetime (in seconds) of the neighbor entry.
Status
EVI link status:
·     Up—The EVI link is up.
·     Down—The EVI link is down.
·     NA—No EVI link has been set up with the neighbor.
display evi neighbor-discovery client statistics
Use display evi neighbor-discovery client statistics to display ENDP packet statistics for an ENDC-enabled EVI tunnel interface.
display evi neighbor-discovery client statistics interface tunnel interface-number
# Display ENDP packet statistics for ENDCs on IPv4 tunnel interface Tunnel 1.
<Sysname> display evi neighbor-discovery client statistics interface tunnel 1
Server Address: 10.0.0.1    Vpn-instance: [No Vrf]
Received packets:
  Reply:        170              Error:      1
Sent packets:
  Register:     170              Purge:      0
Server Address: 10.0.0.2    Vpn-instance: [No Vrf]
Received packets:
  Reply:        99               Error:      1
Sent packets:
  Register:     100              Purge:      0
Table 12 Command output
Server Address
Vpn-instance
Received packets
Packets received by the ENDC:
·     Reply—Registration replies received from the ENDS.
·     Error—ENDP error packets.
Sent packets
Packets sent by the ENDC:
·     RegisterRegistration packets sent to the ENDS.
·     Purge—Deregistration packets sent to the ENDS.
display evi neighbor-discovery client summary
Use display evi neighbor-discovery client summary to display ENDC settings and connectivity to ENDSs.
# Display ENDC settings and connectivity to IPv4 ENDSs.
<Sysname> display evi neighbor-discovery client summary
                         Status: I-Init  E-Establish  P-Probe
Interface    Local Address   Server Address  Network ID  Reg  Auth      Status VPN Instance
Tunnel1      10.1.1.1        10.1.1.1        1         15   disabled  E      [No Vrf]
Tunnel2      10.1.1.1        10.1.1.1        2         15   disabled  E      [No Vrf]
Table 13 Command output
Local Address
Source IP address of the EVI tunnel. This field displays NA if no source IP address has been assigned to the EVI tunnel.
Server Address
Network ID
This field displays NA if no network ID has been configured.
Reg
Registration update interval. The ENDC updates its registration with the ENDS at this interval.
Auth
ENDP authentication status:
·     enabled.
·     disabled.
Status
Status of the connection between the ENDC and the ENDS:
·     IThe connection is initializing.
·     EThe connection has been set up.
·     P—The ENDC is probing for the ENDS to set up a connection.
Vpn-instance
·     evi neighbor-discovery authentication
·     evi neighbor-discovery client enable
·     evi neighbor-discovery client register-interval
display evi neighbor-discovery server member
Use display evi neighbor-discovery server member to display information about EVI neighbors that have registered with an ENDS on the device.
display evi neighbor-discovery server member [ interface tunnel interface-number | [ local local-ip | remote client-ip ] [ vpn-instance vpn-instance-name ] ]
local local-ip: Specifies the IPv4 address of an ENDS on the device.
This command takes effect only if a minimum of one ENDS is configured on the device.
Each neighbor entry includes a neighbor's IP address, bridge MAC address, entry creation time, and aging time.
If you do not specify any parameters, this command displays all IPv4 EVI neighbors that have registered with each ENDS on the device.
# Display IPv4 EVI neighbor entries of all ENDSs on the device.
<Sysname> display evi neighbor-discovery server member
Interface: Tunnel1    Network ID: 2    Vpn-instance: [No Vrf]
IP Address: 11.0.1.2
Client Address  System ID         Expire    Created Time
11.0.1.3        000F-0001-0011    19        2014/09/05 00:19:31
11.0.1.4        000F-0001-0012    30        2014/09/05 02:00:43
11.0.1.5        000F-0001-0013    20        2014/09/05 01:02:13
Interface: Tunnel2    Network ID: 3    Vpn-instance: [No Vrf]
IP Address: 12.0.0.1
12.0.0.2        000F-0002-0001    30        2014/09/05 03:20:43
12.0.0.3        000F-0002-0002    37        2014/09/05 03:27:46
Table 14 Command output
Name of an ENDS-enabled EVI tunnel interface.
Network ID
EVI network ID.
Vpn-instance
IP Address
Client Address
IP address of the neighbor.
System ID
Expire
Remaining lifetime of the neighbor entry.
Created Time
display evi neighbor-discovery server statistics
Use display evi neighbor-discovery server statistics to display ENDP packet statistics for an ENDS-enabled EVI tunnel interface.
display evi neighbor-discovery server statistics interface tunnel interface-number
# Display ENDP packet statistics on the ENDS-enabled IPv4 EVI tunnel interface Tunnel 1.
<Sysname> display evi neighbor-discovery server statistics interface tunnel 1
Received packets:
  Register:     170              Purge:      13
Sent packets:
  Reply:        170              Error:      1
Table 15 Command output
Received packets
Packets received by the ENDS:
·     Register—Registration requests received from ENDCs.
·     Purge—Deregistration packets received from ENDCs.
Sent packets
Packets sent by the ENDS:
·     Reply—Registration replies sent to ENDCs.
display evi neighbor-discovery server summary
Use display evi neighbor-discovery server summary to display ENDS information.
ENDS information includes ENDP authentication status (enabled or disabled) and the total number of ENDCs that have registered with each ENDS.
# Display IPv4 ENDS information.
<Sysname> display evi neighbor-discovery server summary
Interface      Local Address   Network ID    Auth        Members   Vpn-instance
Tunnel1        10.1.1.1        1             disabled    2          [No Vrf]
Tunnel2        10.1.1.1        2             disabled    2          [No Vrf]
Table 16 Command output
Local Address
Network ID
Auth
·     enabled.
·     disabled.
Members
Total number of ENDCs that have registered with the ENDS.
Vpn-instance
·     evi neighbor-discovery server enable
display interface evi-link
Use display interface evi-link to display EVI-Link interface information.
display interface [ evi-link [ interface-number ] ] [ brief [ description | down ] ]
evi-link [ interface-number ]: Specifies EVI-Link interfaces. If you specify an EVI-Link interface number, this command displays information about the specified interface. If you specify only the evi-link keyword, this command displays information about all EVI-Link interfaces. If you do not specify the evi-link [ interface-number ] option, this command displays information about all interfaces.
description: Displays the complete interface description. If you do not specify this keyword, the command displays only the first 27 characters of the interface description string.
down: Displays interfaces that are physically down as well as the down reason. If you do not specify this keyword, the command does not filter output by physical interface state.
The command output includes the PVID, link type, tunnel source address, tunnel destination address, and EVI network ID.
# Display detailed information about EVI-Link 0.
<Sysname> display interface evi-link 0
EVI-Link0
Current state: UP
Bandwidth: 1000000kbps
Description: EVI-Link0 Interface
PVID: 1
Port link-type: trunk
 VLAN Passing:   101-130
 VLAN permitted: 101-130
 Trunk port encapsulation:  IEEE 802.1q
This evi-link belongs to Tunnel1
Source 1.1.1.1, Destination 1.1.2.1
Network ID 1
Table 17 Command output
Current state
EVI-Link interface state:
·     DOWNPhysical state of the interface is down.
·     UP—Physical state of the interface is up.
Interface description.
PVID
Port VLAN ID of the interface.
Interface link type, fixed at trunk.
VLAN Passing
VLANs that have been created and allowed to pass through the interface. For EVI-Link interfaces, this field always displays none.
VLAN permitted
VLANs to which the interface has been assigned. They do not necessarily have been created. For EVI interfaces, this field always displays none.
Link layer protocol of the interface.
EVI tunnel that conveys the EVI link.
Source
Local tunnel address of the EVI link.
Destination
Remote tunnel address of the EVI link.
Network ID
EVI network ID of the EVI link. This network ID is configurable on the EVI tunnel interface.
# Display brief information about EVI-Link 0.
<Sysname> display interface evi-link 0 brief
Brief information on interface(s) under bridge mode:
Speed or Duplex: (a)/A - auto; H - half; F - full
ELNK0                UP   --      --     T    1
# Display physically down EVI-Link interfaces and the down reason.
<Sysname> display interface evi-link brief down
ELNK0                DOWN Not connected
Table 18 Command output
Brief information about the physical Layer 2 interface for the EVI-Link interface.
Interface name abbreviation.
Link
Physical state of the interface:
·     DOWN—Physical state of the interface is down.
·     ADM—The interface has been administratively shut down. To bring it up, use the undo shutdown command.
·     Stby—The interface is in standby state.
Speed
Interface rate in bps.
Duplex
Duplex mode of the interface:
·     A—Autonegotiation mode. The duplex mode depends on the result of the negotiation with the remote end.
·     FFull duplex.
·     F(a)The result of the autonegotiation is full duplex.
·     HHalf duplex.
·     H(a)The result of the autonegotiation is half duplex.
Link type:
·     AAccess.
·     T—Trunk.
·     H—Hybrid.
PVID
Interface description set with the description command.
If you execute the display interface brief command without the description keyword, this field displays up to 27 characters.
If you execute the display interface brief command with the description keyword, this field displays the complete interface description.
Cause
Down reasons:
·     Administratively—The physical link has been shut down with the shutdown command. To bring it up, use the undo shutdown command.
·     Not connected—No physical link is present, for example, because no cable is connected to the port or because the cable is damaged.
evi arp-suppression enable
Use evi arp-suppression enable to enable EVI ARP flood suppression.
Use undo evi arp-suppression enable to restore the default.
EVI ARP flood suppression is disabled.
Tunnel interface view
Use ARP flood suppression to reduce ARP request broadcasts on the EVI network.
This feature snoops ARP replies on an EVI tunnel interface to populate the ARP flood suppression table with remote MAC addresses. If an ARP request has a matching entry, the edge device replies to the request on behalf of the remote-site host. If no match is found, the edge device floods the request to the EVI network.
You must enable or disable EVI ARP flood suppression on all EVI tunnel interfaces on the device.
# Enable EVI ARP flood suppression on the EVI tunnel interface Tunnel 101.
[Sysname] interface tunnel 101 mode evi
[Sysname-tunnel 101] evi arp-suppression enable
·     display evi arp-suppression
·     reset evi arp-suppression
evi enable
Use evi enable to enable EVI on a transport-facing physical interface.
Use undo evi enable to restore the default.
evi enable
undo evi enable
EVI is disabled on an interface.
Layer 2 Ethernet interface view, Layer 3 Ethernet interface view
Enable EVI on physical interfaces that provide transport network access.
# Enable EVI on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] evi enable
evi extend-vlan
Use evi extend-vlan to specify a list of VLANs that can be extended to remote sites over an EVI tunnel.
Use undo evi extend-vlan to remove the configuration.
evi extend-vlan vlan-list
undo evi extend-vlan vlan-list
No extended VLANs are configured.
vlan-list: Specifies a space-separated list of up to 10 VLAN items. Each item specifies a VLAN ID or a range of VLAN IDs in the format of start-vlan-id to end-vlan-id. The end VLAN ID must be greater than the start VLAN ID. The value range for VLAN IDs is 1 to 4094.
Do not specify VLAN 1 as an extended VLAN.
# Specify extended VLANs 2 to 10, 15, and 100 to 200 on the EVI tunnel interface Tunnel 101.
[Sysname-tunnel101] evi extend-vlan 2 to 10 15 100 to 200
evi flooding enable
Use evi flooding enable to enable EVI flooding for all destination-unknown frames.
Use undo evi flooding enable to disable EVI flooding.
evi flooding enable
EVI flooding is disabled. The device floods unknown unicast and multicast frames only to internal interfaces.
EVI flooding enables the device to flood all destination-unknown frames to an EVI tunnel interface.
If selective flood is also enabled for a MAC address in a list of VLANs, EVI flooding has higher priority than the selective flood setting. The device will flood frames destined for that MAC address, whether or not the frames are from a VLAN in the VLAN list for selective flood.
To ensure correct EVI flooding, do not configure both the evi flooding enable command and the evi selective-flooding mac-address command.
# Enable EVI flooding on Tunnel 101.
[Sysname-tunnel 101] evi flooding enable
evi isis ded-priority
Use evi isis ded-priority to change the DED priority of the edge device on an EVI tunnel interface.
Use undo evi isis ded-priority to restore the default DED priority.
evi isis ded-priority value
The DED priority value is 64.
value: Specifies a DED priority value in the range of 0 to 127.
The edge devices on an EVI link exchange their DED priority in EVI IS-IS hello packets to elect a DED for periodic LSDB synchronization.
The edge device with higher DED priority is more likely to be elected as the DED on an EVI link. If two edge devices have the same DED priority, the one with the highest MAC address is elected.
# Set the DED priority value of Tunnel 101 to 2.
[Sysname-tunnel101] evi isis ded-priority 2
evi isis timer csnp
Use evi isis timer csnp to set the CSNP packet transmit interval.
Use undo evi isis timer csnp to restore the default.
evi isis timer csnp seconds
The CSNP packet transmit interval is 10 seconds.
seconds: Specifies an interval in the range of 1 to 600 seconds.
The setting takes effect only if the edge device is the DED on an EVI link in the tunnel.
The DEDs in an EVI network regularly send CSNP packets to advertise LSP summaries to remote sites for LSDB synchronization.
# Set the CSNP transmit interval to 15 seconds.
[Sysname-tunnel101] evi isis timer csnp 15
evi isis timer hello
Use evi isis timer hello to set the EVI IS-IS hello interval.
Use undo evi isis timer hello to restore the default.
evi isis timer hello seconds
The EVI IS-IS hello interval is 10 seconds.
seconds: Specifies an interval in the range of 3 to 255 seconds.
Set the hello interval depending on the network convergence requirement and system resources.
·     To increase the speed of network convergence, decrease the hello interval.
·     To conserve resources, increase the hello interval.
If the edge device is a DED, its hello interval is one-third of the hello interval set by using this command.
# Set the EVI IS-IS hello interval to 6 seconds.
[Sysname-tunnel101] evi isis timer hello 6
evi isis timer holding-multiplier
Use evi isis timer holding-multiplier to configure the hello multiplier for calculating the EVI IS-IS adjacency hold time.
Use undo evi isis timer holding-multiplier to restore the default.
evi isis timer holding-multiplier value
The hello multiplier for calculating the EVI IS-IS adjacency hold time is 3.
value: Specifies a multiplier in the range of 3 to 1000.
Adjacency hold time is the amount of time that the remote edge devices can retain the adjacency with the local edge device before an adjacency update.
·     If Graceful Restart is disabled, the adjacency hold time equals the EVI IS-IS hello interval multiplied by the hello multiplier.
·     If Graceful Restart is enabled, the adjacency hold time equals the greater of the following values:
?     The restart interval.
?     The EVI IS-IS hello interval multiplied by the hello multiplier.
If an edge device is a DED, its hello interval is one-third of the hello interval set by using the evi isis timer hello command.
Edge devices send their adjacency hold time in hello packets to update the adjacencies with their neighbors. An edge device removes the adjacency with a neighbor if it does not receive a hello packet from the neighbor before the timer expires.
The maximum adjacency hold time is 65535 seconds. If this value is exceeded, the actual adjacency hold time is set to 65535 seconds.
# Set the hello multiplier to 6 for calculating EVI IS-IS adjacency hold time.
[Sysname-tunnel101] evi isis timer holding-multiplier 6
·     display evi isis tunnel
·     evi isis timer hello
evi isis timer lsp
Use evi isis timer lsp to configure the minimum LSP transmit interval and the maximum number of LSPs that can be sent at each interval.
Use undo evi isis timer lsp to restore the default.
evi isis timer lsp time [ count count ]
The minimum LSP transmit interval is 100 milliseconds. A maximum of five LSPs can be sent at each interval.
time: Specifies the minimum LSP transmit interval, a multiple of 100 in the range of 100 to 1000 milliseconds.
count count: Specifies the maximum number of LSP segments that can be sent at each interval. The value range is 1 to 1000.
The edge device generates an LSP update when any LSDB content changes. For example, an LSP update is generated when a MAC address is removed or added.
Use this command to control the number of LSP segments that the edge device sends out. To decrease the number of LSP segments, increase the interval and decrease the maximum number of LSP segments sent at each interval.
# Set the minimum LSP transmit interval to 500 ms.
[Sysname-tunnel101] evi isis timer lsp 500
evi isis track
Use evi isis track to associate an EVI tunnel interface with a track entry.
Use undo evi isis track to remove the track entry association for an EVI tunnel interface.
evi isis track track-entry-number
undo evi isis track
An EVI tunnel interface is not associated with any track entry.
track-entry-number: Specifies a track entry number in the range of 1 to 1024.
You can associate an EVI tunnel interface with only one track entry. If you execute this command multiple times, the most recent association takes effect.
EVI IS-IS uses a hello mechanism to monitor the connectivity of each EVI link on an EVI tunnel. To detect the connectivity of a particular EVI link more quickly, you can associate its tunnel interface with a track entry. The monitoring protocol used in this entry can only be BFD.
EVI IS-IS changes the state of an EVI-Link interface in response to the track entry state, as shown in Table 19.
Table 19 Action on the monitored EVI-Link in response to the track entry state change
Track entry state
State of the monitored EVI link
Action on the EVI-Link interface
Positive
The EVI link is operating correctly.
Places the EVI-Link interface in up state.
Negative
The EVI link has failed.
Places the EVI-Link interface in down state.
NotReady
The EVI link is not monitored.
This situation occurs when the Track module or the monitoring module is not ready, for example, because the Track module is restarting or the monitoring settings are incomplete. In this situation, EVI cannot obtain information about the EVI link from the Track module.
N/A
For more information about configuring a track entry, see Track configuration in High Availability Configuration Guide.
# Associate Tunnel 101 with track entry 1.
[Sysname-tunnel101] evi isis track 1
Use evi neighbor-discovery authentication to enable ENDP authentication.
Use undo evi neighbor-discovery authentication to disable ENDP authentication.
evi neighbor-discovery authentication { cipher | simple } string
ENDP authentication is disabled.
cipher: Specifies an authentication key in encrypted form.
simple: Specifies an authentication key in plaintext form.
string: Specifies the authentication key. Its plaintext form is a case-sensitive string of 1 to 24 characters in length. Its encrypted form is a case-sensitive string of 1 to 65 characters.
Configure ENDP authentication in an insecure network to prevent malicious registration with an ENDS.
Make sure all authentication-enabled ENDCs and ENDSs in an EVI network use the same authentication key.
If authentication is disabled on an ENDS, all ENDCs, including authentication-enabled ENDCs, can register with the ENDS without authentication.
If authentication is enabled on an ENDS, only authentication-enabled ENDCs that use the same authentication key as the ENDS can register with the ENDS.
For security purposes, all authentication keys, including keys set in plaintext form, are stored in encrypted form.
# Enable ENDP authentication on the EVI tunnel interface Tunnel 1 and specify web-evi as the authentication key.
<Sysname> system
[Sysname] interface tunnel 1 mode evi
[Sysname-Tunnel1] evi neighbor-discovery authentication simple web-evi
·     display evi neighbor-discovery client summary
·     display evi neighbor-discovery server summary
Use evi neighbor-discovery client enable to configure an EVI tunnel interface as the ENDC of an ENDS.
Use undo evi neighbor-discovery client enable to remove an ENDS from an EVI tunnel interface.
evi neighbor-discovery client enable server-ip
undo evi neighbor-discovery client enable server-ip
The ENDC feature is disabled.
server-ip: Specifies the IP address of a remote ENDS-enabled EVI tunnel interface.
For redundancy, you can configure up to two ENDS addresses on an EVI tunnel interface. These two ENDSs work independently. The failure of one ENDS does not affect the neighbor discovery and EVI link maintenance in the EVI network.
On an ENDS-enabled EVI tunnel interface, you can use the evi neighbor-discovery client enable command to add only one ENDS address. An ENDS is always an ENDC of itself. When you enable ENDS on an EVI tunnel interface, an ENDC is automatically enabled, with the source address of the EVI tunnel as the ENDS address.
To guarantee that each edge device can obtain the addresses of all its EVI neighbors, make sure the ENDSs are the same across the EVI network.
# Configure Tunnel 1 as an ENDC of the ENDS at 11.0.0.1.
<Sysname> system
[Sysname-Tunnel1] evi neighbor-discovery client enable 11.0.0.1
Use evi neighbor-discovery client register-interval to configure the interval at which the ENDCs on an EVI tunnel interface update their registration with their ENDSs.
Use undo evi neighbor-discovery client register-interval to restore the default.
evi neighbor-discovery client register-interval time-value
An ENDC updates its registration with its ENDS every 15 seconds.
time-value: Specifies a registration update interval in the range of 5 to 120 seconds.
ENDP uses an ENDS probe timer and a registration aging timer in addition to the ENDC register timer set with this command.
·     ENDS probe timer—Sets the interval for an ENDC to detect an ENDS. This timer is maintained on ENDCs and is not user configurable.
·     ENDC register timer—Sets the interval for an ENDC to update its registration with an ENDS. This timer is by default 15 seconds and can be changed with the evi neighbor-discovery client register-interval command on ENDCs.
·     Registration aging timer—This timer is five times the ENDC register timer. This timer is maintained on ENDSs. When the registration aging timer for an ENDC expires, ENDS removes the ENDC from its ENDC database.
When an ENDC sends a register request to join the EVI network, a 5-second ENDS probe timer starts. The ENDC sends a register request to the ENDS every 5 seconds until it receives a response from the ENDS.
When the ENDC receives a response from the ENDS, the ENDS probe timer stops and an ENDC register timer starts. The ENDC regularly sends register updates at the interval set by the register timer.
If the ENDC does not receive a response after sending five consecutive register packets, the ENDC clears its neighbor information database and starts the ENDS probe timer.
The ENDC adds the register timer setting to each register packet. The ENDS records this timer setting when it adds the ENDC to the ENDC database. If no register update is received from the ENDC before five times the timer is reached, ENDS removes the ENDC from the EVI network.
# Set the ENDC registration update interval to 30 seconds on the EVI tunnel interface Tunnel 1.
<Sysname> system
[Sysname-Tunnel1] evi neighbor-discovery client register-interval 30
Use evi neighbor-discovery server enable to enable ENDS on an EVI tunnel interface.
Use undo evi neighbor-discovery server enable to disable ENDS on an EVI tunnel interface.
ENDS is disabled.
When you enable ENDS on an EVI tunnel interface, an ENDC is automatically enabled, with the source address of the EVI tunnel as the ENDS address. You can use the evi neighbor-discovery client register-interval command to modify the interval at which the ENDC registers with the ENDS.
# Enable IPv4 ENDS.
<Sysname> system
[Sysname-Tunnel1] evi neighbor-discovery server enable
evi network-id
Use evi network-id to assign a network ID to an EVI tunnel interface.
Use undo evi network-id to remove the network ID.
evi network-id number
undo evi network-id
No network ID is assigned to any EVI tunnel interface.
number: Specifies a network ID in the range of 1 to 16777215.
An edge device can belong to multiple EVI networks. Each EVI network is uniquely identified by a network ID.
Each edge device has only one EVI tunnel in each EVI network. To assign an edge device to an EVI network, you must create an EVI tunnel interface and assign the network ID of the EVI network to the EVI tunnel interface.
Assign the same network ID to the EVI tunnel interfaces of all edge devices in an EVI network.
# Assign EVI network ID 123 to the EVI tunnel interface Tunnel 1.
[Sysname-Tunnel1] evi network-id 123
interface tunnel
Use evi selective-flooding mac-address to enable flooding specific destination-unknown frames to an EVI tunnel interface.
Use undo evi selective-flooding mac-address to disable flooding specific destination-unknown frames to an EVI tunnel interface.
evi selective-flooding mac-address mac-address vlan vlan-id-list
undo evi selective-flooding mac-address mac-address vlan vlan-id-list
Selective flood is disabled for all MAC addresses. The device floods unknown unicast and multicast frames only to internal interfaces.
mac-address: Specifies a MAC address, which cannot be all Fs.
vlan vlan-id-list: Specifies a space-separated list of up to 10 VLAN items. Each item specifies a VLAN ID or a range of VLAN IDs in the format of start-vlan-id to end-vlan-id. The end VLAN ID must be greater than the start VLAN ID. The value range for VLAN IDs is 1 to 4094.
CAUTION
CAUTION:
Do not configure selective flood for local unicast MAC addresses. The setting might cause remote devices to drop packets destined for the MAC address.
Enable selective flood for the following types of MAC addresses:
·     Unknown unicast addresses that require inter-site forwarding. By default, the device floods unknown unicast frames only to internal interfaces.
·     Known or unknown multicast addresses that require inter-site forwarding. EVI does not support multicast forwarding based on the multicast forwarding table.
# Configure selective flood for 000f-e201-0101 in VLANs 2 to 10 on the EVI tunnel interface Tunnel 101.
[Sysname-tunnel 101] evi selective-flooding mac-address 000f-e201-0101 vlan 2 to 10
evi site-id
Use evi site-id to configure a site ID for the device.
Use undo evi site-id to restore the default.
evi site-id site-id
undo evi site-id
The site ID of the device is 0.
site-id: Specifies a site ID in the range of 1 to 65535.
By default, all edge devices in an EVI network have a site ID of 0. To identify the site of each edge device, you can change their site IDs.
Manually assigned site IDs must be unique in the EVI network. If the edge devices at two sites are assigned the same site ID, EVI IS-IS isolates the device with the lower MAC address. The isolated device cannot exchange any EVI IS-IS packets with other neighbors except that it can receive EVI IS-IS hello packets. To identify isolated devices, use the display evi isis brief command or the display evi isis peer command.
EVI IS-IS does not perform isolation for edge devices that use the default site ID.
# Assign a site ID of 201 to the device.
[Sysname] evi site-id 201
·     display evi-isis brief
·     display evi isis peer
evi-isis
Use evi-isis to create an EVI IS-IS process or enter EVI IS-IS process view.
Use undo evi-isis to delete an EVI IS-IS process or clear the configuration that has made in EVI IS-IS process view.
evi-isis process-id
undo evi-isis process-id
No EVI IS-IS process exists.
Each EVI network has one EVI IS-IS process. Before you can configure settings in EVI IS-IS process view, you must create the process.
An EVI IS-IS process is created automatically when you perform a task that can trigger automatic EVI IS-IS process creation on a tunnel interface. The ID of an automatically created process is the same as the EVI tunnel interface number. For more information about automatic EVI IS-IS process creation, see EVI Configuration Guide.
Alternatively, you can use the evi-isis command to create an EVI IS-IS process manually.
To delete a manually created EVI IS-IS process, you must use the undo evi-isis command.
·     If EVI IS-IS settings exist on the EVI tunnel interface, the undo evi-isis command only deletes settings configured in EVI IS-IS process view.
·     If no EVI IS-IS settings exist on the EVI tunnel interface, the undo evi-isis command deletes both the EVI IS-IS process and all settings configured in EVI IS-IS process view.
An automatically created EVI IS-IS process is automatically deleted when you delete all EVI IS-IS settings from the EVI tunnel interface.
# Enter EVI IS-IS process view.
[Sysname] evi-isis 101
[Sysname-evi-isis-101]
filter-policy
Use filter-policy to specify a routing policy for an EVI IS-IS process.
Use undo filter-policy to remove the routing policy on an EVI IS-IS process.
filter-policy policy-name
undo filter-policy
No routing policy is assigned to any EVI IS-IS process.
policy-name: Specifies a routing policy name, a case-sensitive string of 1 to 63 characters.
You can configure a routing policy to match MAC reachability information that can be advertised to the remote EVI sites. The routing policy is also called a reachability information filtering policy.
The routing policy for EVI IS-IS can only contain the following filters:
·     MAC list.
·     VLAN list.
For more information about configuring routing policies, see Layer 3—IP Routing Configuration Guide.
# Specify the routing policy EVI-Filter for EVI IS-IS process 101.
[Sysname-evi-isis-101] filter-policy EVI-Filter
graceful-restart
Use graceful-restart to enable Graceful Restart for an EVI IS-IS process.
Use undo graceful-restart to disable Graceful Restart for an EVI IS-IS process.
graceful-restart
Graceful Restart is disabled.
To guarantee nonstop forwarding while the peer EVI IS-IS processes are re-establishing their adjacency after a process restart or active/standby switchover occurs, enable Graceful Restart for the peer EVI IS-IS processes at two ends of the EVI tunnel.
# Enable Graceful Restart for EVI IS-IS process 101.
[Sysname-evi-isis-101] graceful-restart
graceful-restart interval
Use graceful-restart interval to configure the GR restart interval for EVI IS-IS.
Use undo graceful-restart interval to restore the default.
graceful-restart interval interval-value
The GR restart interval is 300 seconds.
interval-value: Specifies the GR restart interval (the intended restart time), in the range of 30 to 1800 seconds.
# Set the GR restart interval to 120 seconds for EVI IS-IS process 1.
[Sysname-evi-isis-1] graceful-restart interval 120
gre key vlan-id
Use gre key vlan-id to enable an EVI tunnel interface to generate a GRE key for tunneled packets based on their VLAN IDs.
Use undo gre key to disable GRE key generation on an EVI tunnel interface.
gre key vlan-id
undo gre key
EVI tunneled packets do not contain a GRE key.
The GRE key setting must be the same across an EVI network.
Configure this command on an EVI tunnel interface if any remote edge devices generate VLAN ID-based GRE keys for EVI tunneled packets. The EVI tunnel interface accepts an incoming tunneled packet only if the GRE key in the packet matches one of the local GRE keys.
# Enable EVI tunnel interface 1 to generate VLAN ID-based GRE keys for tunneled packets.
[Sysname-Tunnel2] gre key vlan-id
keepalive
Use keepalive to configure the keepalive interval on an EVI tunnel interface and configure the maximum number of consecutive keepalive failures that are allowed before a remote end is declared unavailable.
Use undo keepalive to restore the default.
keepalive [ seconds [ times ] ]
undo keepalive
The EVI link keepalive interval is 5 seconds and the maximum number of consecutive keepalive failures is two.
seconds: Specifies a keepalive interval in the range of 1 to 32767 seconds.
times: Specifies the maximum number of consecutive keepalive failures in the range of 1 to 255.
The EVI-Link interfaces on an EVI tunnel regularly send keepalive packets to test the availability of their peer ends.
If no acknowledgment is received from the peer end before the timeout timer expires, an EVI-Link interface retransmits a keepalive packet. The timeout timer is the same as the keepalive interval.
When the maximum number of consecutive keepalive failures is reached, the EVI-Link interface state changes to Down. The EVI-Link interface state changes back to Up after the interface receives a keepalive acknowledgment or keepalive packet.
# Set the keepalive interval to 20 seconds and the maximum number of consecutive keepalive failures to 5.
[Sysname-Tunnel1] keepalive 20 5
interface tunnel
log-peer-change enable
Use log-peer-change enable to enable EVI IS-IS adjacency change logging.
Use undo log-peer-change enable to disable outputting EVI IS-IS adjacency change logging.
EVI IS-IS adjacency change logging is enabled.
Adjacency change logging enables an EVI IS-IS process to send a log message to the information center when an adjacency change occurs. With the information center, you can set log message filtering and output rules, including output destinations. For more information about using the information center, see Network Management and Monitoring Configuration Guide.
# Disable adjacency change logging for an EVI IS-IS process.
[Sysname-evi-isis-1] undo log-peer-change enable
Use reset evi arp-suppression to clear EVI ARP flood suppression entries.
reset evi arp-suppression interface tunnel interface-number [ vlan vlan-id ]
vlan vlan-id: Specifies a VLAN ID in the range of 1 to 4094. If you do not specify a VLAN, this command clears the flood suppression entries in every VLAN.
# Clear the EVI ARP flood suppression entries on Tunnel 101.
<Sysname> reset evi arp-suppression interface tunnel 101
This will delete all entries under the specified interface. Continue? [Y/N]:y
·     evi arp-suppression enable
reset evi isis all
Use reset evi isis all to clear dynamic EVI IS-IS data.
reset evi isis all [ process-id ]
process-id: Specify an EVI IS-IS process ID in the range of 1 to 65535. If you do not specify a process, this command clears all EVI IS-IS processes' dynamic data.
# Clear dynamic data on EVI IS-IS process 1.
<Sysname> reset evi isis all 1
snmp context-name
Use snmp context-name to configure an SNMP context for an EVI IS-IS process.
Use undo snmp context-name to restore the default.
No SNMP context is configured for an EVI IS-IS process.
context-name: Specifies a context name, a case-sensitive string of 1 to 32 characters.
In addition to the private EVI IS-IS MIB, EVI IS-IS shares the standard IS-IS MIB with IS-IS and other protocols that use IS-IS in the control plane. For SNMP to correctly identify a protocol's management information in the standard IS-IS MIB, you must configure a unique context for each of these protocols. If a protocol supports multiple processes, you must assign a unique context to each process.
The context names must be unique among all the protocols and their processes.
Context is a method introduced to SNMPv3 for multiple instance managements. For SNMPv1/v2c, you must specify a context name as a community name for protocol identification.
# Configure the SNMP context name as eviisis100 for EVI IS-IS process 100.
[Sysname] evi-isis 100
[Sysname-evi-isis-100] snmp context-name eviisis100
snmp-agent trap enable evi-isis
Use snmp-agent trap enable evi-isis to enable EVI IS-IS SNMP notifications.
Use undo snmp-agent trap enable evi-isis to disable EVI IS-IS SNMP notifications.
snmp-agent trap enable evi-isis [ adjacency-state-change | area-mismatch | buffsize-mismatch | id-length-mismatch | link-disconnect | lsp-parse-error | lsp-size-exceeded | max-seq-exceeded | maxarea-mismatch | new-ded | own-lsp-purge | protocol-support | rejected-adjacency | skip-sequence-number | topology-change | version-skew ] *
undo snmp-agent trap enable evi-isis [ adjacency-state-change | area-mismatch | buffsize-mismatch | id-length-mismatch | link-disconnect | lsp-parse-error | lsp-size-exceeded | max-seq-exceeded | maxarea-mismatch | new-ded | own-lsp-purge | protocol-support | rejected-adjacency | skip-sequence-number | topology-change | version-skew ] *
All EVI IS-IS SNMP notifications are enabled.
adjacency-state-change: Specifies notifications about EVI IS-IS adjacency status changes.
area-mismatch: Specifies notifications about area address mismatches between hello packets.
buffsize-mismatch: Specifies notifications about buffer size mismatches for LSPs.
id-length-mismatch: Specifies notifications about system ID length mismatches of EVI IS-IS packets.
link-disconnect: Specifies notifications about EVI link failures.
lsp-parse-error: Specifies notifications about LSP parse failures.
lsp-size-exceeded: Specifies notifications about propagation failures caused by oversized LSPs.
max-seq-exceeded: Specifies notifications about attempts to exceed the maximum LSP sequence number.
maxarea-mismatch: Specifies notifications about maximum area address mismatches of hello packets.
new-ded: Specifies notifications about the device's being elected as the DED.
own-lsp-purge: Specifies notifications about attempts to remove the local LSP.
protocol-support: Specifies notifications about supported-protocol mismatches for non-pseudo node LSPs.
rejected-adjacency: Specifies notifications about adjacency creation failures.
skip-sequence-number: Specifies notifications about LSP sequence number duplications.
topology-change: Specifies notifications about edge device topology changes at the local site. This notification will not be sent if a new-ded notification has been sent for the same event.
version-skew: Specifies notifications about hello packet version mismatches.
To report critical EVI IS-IS events to an NMS, enable SNMP notifications for EVI IS-IS.
If you do not specify a notification, this command enables all EVI IS-IS SNMP notifications.
For EVI IS-IS SNMP notifications to be sent correctly, you must also configure SNMP on the device. For more information about SNMP configuration, see the network management and monitoring configuration guide for the device.
# Enable EVI IS-IS adjacency status change notifications.
[Sysname] snmp-agent trap enable evi-isis adjacency-state-change
timer lsp-max-age
Use timer lsp-max-age to specify the maximum lifetime of LSPs.
Use undo timer lsp-max-age to restore the default.
timer lsp-max-age seconds
The maximum LSP lifetime is 1200 seconds.
seconds: Specifies the maximum LSP lifetime in the range of 3 to 65535 seconds.
This command specifies the maximum amount of time an LSP generated by the local EVI IS-IS process can be valid in an LSDB. When the timer decreases to zero, the LSP is removed from the LSDB.
# Set the maximum LSP lifetime to 25 minutes (1500 seconds) on EVI IS-IS process 101.
[Sysname-evi-isis-101] timer lsp-max-age 1500
timer lsp-refresh
Use timer lsp-refresh to specify the LSP refresh interval.
Use undo timer lsp-refresh to restore the default.
timer lsp-refresh seconds
The LSP update interval is 900 seconds.
seconds: Specifies an LSP refresh interval in the range of 1 to 65534 seconds.
Each edge device updates the LSPs that they generated at the LSP refresh interval to maintain LSDB consistency across the EVI network.
To avoid unnecessary LSP age-outs at remote edge devices, make sure the LSP refresh interval is shorter than the LSP lifetime.
# Set the LSP refresh interval to 1500 seconds.
[Sysname-evi-isis-101] timer lsp-refresh 1500
·     display evi isis brief
·     timer lsp-max-age
virtual-system
Use virtual-system to create an EVI IS-IS virtual system.
Use undo virtual-system to delete an EVI IS-IS virtual system.
virtual-system systemid
undo virtual-system systemid
No EVI IS-IS virtual system is created.
systemid: Specifies a virtual system ID in the XXXX.XXXX.XXXX format. Each X represents a hexadecimal digit.
The virtual system ID must be unique in the EVI network.
An EVI IS-IS process sends all local MAC reachability information in one LSP. By default, an LSP can convey up to 55 x 210 MAC address entries.
To increase this number to accommodate all local MAC address entries, create virtual systems. Each virtual system represents an increase of 55 x 210 MAC address entries.
# Create the virtual system 0001.0001.0001.
[Sysname-evi-isis-101] virtual-system 0001.0001.0001
