12-Network Management and Monitoring Command Reference
HomeSupportSwitchesS7500E SeriesReference GuidesCommand ReferencesH3C S7500E Switch Series Command References-Release7178-6W10012-Network Management and Monitoring Command Reference
04-PoE commands
04-PoE commands 149.36 KB
PoE commands
apply poe-profile
Use apply poe-profile to apply a PoE profile to a power interface (PI).
Use undo apply poe-profile to remove application of a PoE profile from a PI.
apply poe-profile { index index | name profile-name }
undo apply poe-profile { index index | name profile-name }
No PoE profile is applied to PIs.
PI view
index index: Specifies a PoE profile by its index number in the range of 1 to 100.
name profile-name: Specifies a PoE profile by its name, a case-sensitive string of 1 to 15 characters.
# Apply the PoE profile named forIPphone to GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] apply poe-profile name forIPphone
·     apply poe-profile interface
·     display poe-profile
Use apply poe-profile interface to apply a PoE profile to PIs.
Use undo apply poe-profile interface to remove the application of a PoE profile from PIs.
apply poe-profile { index index | name profile-name } interface interface-range
undo apply poe-profile { index index | name profile-name } interface interface-range
No PoE profile is applied to a PI.
interface-range: Specifies a range of Ethernet interfaces in the form of interface-type interface-number [ to interface-type interface-number ], where interface-type interface-number represents the interface type and interface number. The start interface number must be smaller than the end interface number. If an interface in the specified range does not support PoE, it is ignored when the PoE profile is applied.
[Sysname] apply poe-profile name forIPphone interface gigabitethernet 1/0/1
# Apply the PoE profile with index number 1 to PIs GigabitEthernet 1/0/2 to GigabitEthernet 1/0/8.
[Sysname] apply poe-profile index 1 interface gigabitethernet 1/0/2 to gigabitethernet 1/0/8
·     apply poe-profile
·     display poe-profile interface
display poe device
Use display poe device to display general PSE information, including the ID, slot number, and status of PSEs.
In standalone mode:
display poe device [ slot slot-number ]
In IRF mode:
display poe device [ chassis chassis-number slot slot-number ]
slot slot-number: Specifies a card by its slot number. If you do not specify a card, the command displays information about all PSEs. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, the command displays information about all PSEs in the IRF fabric. (In IRF mode.)
This command is only available for the default MDC. For more information about MDCs, see Virtual Technologies Configuration Guide.
# (In standalone mode.) Display general PSE information.
<Sysname> display poe device
 PSE ID  Slot No. SSlot No. PortNum  MaxPower(W)  State  Model
 7        2         0           48        800.0          Off    LSQ1GV48SD0
 10       3         0           48        800.0          Off    LSQ1GV48SD0
# (In IRF mode.) Display general PSE information.
Chassis 1:
 4        1         0           48        800.0          Off    LSQ1GV48SD0
 7        1         0           48        800.0          Off    LSQ1GV48SD0
Chassis 2:
 43       2         0           48        800.0          Off    LSQ1GV48SD0
Chassis 1
Information for member device 1. (In IRF mode.)
PSE ID
ID of the PSE.
Slot No.
Slot number of the PSE.
SSlot No.
Sub-slot number of the PSE.
PortNum
Number of PIs on the PSE.
MaxPower(W)
Maximum power of the PSE.
PSE status:
·     On—The PSE is supplying power.
·     Off—The PSE is not supplying power.
·     Faulty—The PSE has failed.
Model
PSE model.
display poe interface
Use display poe interface to display power supplying information for PIs.
display poe interface [ interface-type interface-number ]
The interface-type interface-number argument is optional for the default MDC and is required for non-default MDCs. For the default MDC, if you do not specify an interface, this command displays power supplying information for all PIs.
# Display power supplying information for GigabitEthernet 1/0/1.
<Sysname> display poe interface gigabitethernet 1/0/1
 PoE Status                         : Enabled
 Power Priority                    : Critical
 Oper                                : On
 IEEE Class                         : 1
 Detection Status                  : Delivering power
 Power Mode                         : Signal
 Current Power                      : 11592    mW
 Average Power                      : 11610    mW
 Peak Power                          : 11684    mW
 Max Power                           : 15400    mW
 Electric Current                   : 244      mA
 Voltage                              : 51.7     V
 PD Description                      : IP Phone For Room 101
PoE status
PoE status:
·     Enabled.
·     Disabled.
Power Priority
Power supply priority of the PI:
·     Critical (highest).
·     High.
·     Low.
Oper
Operating status of a PI:
·     Off—PoE is disabled.
·     On—Power is being supplied to the PI correctly.
·     Power-lack—Remaining guaranteed power is insufficient for a critical PI.
·     Power-deny—The PSE refuses to supply power. The power required by the PD is higher than the configured power.
·     Power-itself—The PD is using another power supply.
·     Power-limit—The PSE is supplying power to the PD based on the configured power though the PD requires more power than the configured power.
IEEE Class
PD power class: 0, 1, 2, 3, or 4.
If the PSE does not support PD classification, this field displays a hyphen (-).
Detection Status
Power detection status of a PI:
·     Disabled—The PoE function is disabled.
·     Searching—The PI is searching for the PD.
·     Delivering power—The PI is supplying power to the PD.
·     Fault—A fault occurred during the test.
·     Test—The PI is undergoing a test.
·     Other fault—A fault has caused the PSE to enter the idle status.
·     PD disconnected—The PD is disconnected.
Power Mode
Power transmission mode of a PI:
·     Signal—Power is being supplied over signal cables.
·     Spare—Power is being supplied over spare cables. The switch does not support the spare mode.
Current Power
Current power of a PI, including PD consumption power and transmission loss.
Typical transmission loss is within 1 watt.
Average Power
Average power of a PI.
Peak Power
Peak power of a PI.
Max Power
Maximum power of a PI.
Electric Current
Current of a PI.
Voltage
Voltage of a PI.
PD Description
Type and location description for the PD connected to the PI.
# Display power supplying information for all PIs.
 Interface    PoE       Priority  CurPower  Oper      IEEE  Detection
                                      (W)                   Class Status
 GE1/0/1         Enabled   Low        4.4       On         1      Delivering Power
 GE1/0/2         Enabled   Critical  0.0       On         -      Disabled
 GE1/0/3         Enabled   Low        0.0       On         -      Disabled
 GE1/0/4         Enabled   Critical  0.0       On         -      Searching
 GE1/0/5         Enabled   Low        4.0       On         2      Delivering Power
 GE1/0/6         Enabled   Low        0.0       On         -      Disabled
 GE1/0/7         Disabled  Low        0.0       Off        -      Fault
   ---  On State Ports: 2; Used: 8.4(W); Remaining: 171.6(W)  ---
Interface name of a PI.
PoE
PoE status:
·     Enabled.
·     Disabled.
Priority
Power priority of a PI:
·     High.
·     Low.
CurPower
Current power of a PI.
Oper
IEEE Class
Detection Status
·     Disabled—PoE function is disabled.
·     Delivering Power—The PI is supplying power for the PD.
On State Ports
Number of PIs that are supplying power.
Used
Power consumed by the current PI.
Remaining
Total remaining power of the system.
display poe interface power
Use display poe interface power to display power information for PIs.
display poe interface power [ interface-type interface-number ]
The interface-type interface-number argument is optional for the default MDC and is required for non-default MDCs. For the default MDC, if you do not specify an interface, this command displays power information for all PIs.
# Display power information for GigabitEthernet 1/0/1.
<Sysname> display poe interface power gigabitethernet 1/0/1
Interface    Current   Peak      Max       PD Description
               (W)       (W)       (W)
 GE1/0/1        15.0      15.3      15.4      Access Point on Room 509 for Peter
# Display power information for all PIs.
               (W)       (W)       (W)
 GE1/0/25      4.4        4.5       4.6         IP Phone in Room 309 for Peter Smith
 GE1/0/26      4.4        4.5       15.4        IP Phone in Room 409 for Peter Pan
 GE1/0/27      15.0      15.3       15.4        Access Point in Room 509 for Peter
--- On State Ports: 3; Used: 23.8(W);  Remaining: 776.2(W) ---
CurPower
PeakPower
Peak power of a PI.
MaxPower
PD Description
Type and location description for the PD connected to a PI.
Ports On
Used
Power consumed by all PIs.
Remaining
display poe power-usage
Use display poe power-usage to display power usage statistics for PoE power supplies and PSEs.
In standalone mode:
In IRF mode:
display poe power-usage [ chassis chassis-number ]
chassis chassis-number: Specifies an IRF member device by its member ID. If you do not specify a member device, the command displays information about all PoE power supplies and PSEs in the IRF fabric. (In IRF mode.)
# (In standalone mode.) Display power usage statistics for the PoE power supply and all PSEs.
<Sysname> display poe power-usage
 PoE Current Power                    : 12    W
 PoE Max Power                         : 2000  W
 PoE Max Guaranteed Power            : 2000  W
 PoE Remaining Allocable Power      : 1800  W
 PoE Remaining Guaranteed Power     : 2000  W
 Powered PoE Ports                     : 1
 Statistics by PSE:
 PSE ID  Max     Current  Peak     Average  Remaining      Powered
         (W)     (W)       (W)      (W)        Guaranteed(W) Ports
 5       200     12        12        6          200             1
# (In IRF mode.) Display power usage statistics for all PoE power supplies and PSEs.
Chassis 1 :
 PoE Current Power                   : 600   W
 PoE Max Guaranteed Power           : 1000  W
 PoE Remaining Allocable Power      : 800   W
 PoE Remaining Guaranteed Power    : 600   W
 Powered PoE Ports                    : 60
 Statistics by PSE:
 4        300     200         230     205         100                 20
 7        400     300         345     290         200                 30
 10       500     100         120     110         300                 10
Chassis 2 :
 Statistics by PSE:
 35       300     200         230     205         100                 20
Table 5 Command output
Chassis 1
PoE power and PSE power information for member device 1. (In IRF mode.)
PoE Current Power
Total power that has been consumed by PSEs.
PoE Max Power
Maximum PoE power.
Maximum power that can be supplied to critical PSEs.
Remaining allocable PoE power = Maximum PoE power – Total maximum power of all PoE-enabled PSEs.
Remaining guaranteed PoE power = Maximum guaranteed PoE power – Total maximum power of all critical PSEs.
Typically, the maximum guaranteed PoE power is equal to the maximum PoE power.
Powered PoE Ports
PSE ID
ID of the PSE.
Max
Current
Current power of the PSE.
Peak
Peak power of the PSE.
Average
Average power of the PSE.
Remaining guaranteed power of the PSE = Maximum guaranteed power of the PSE – Total maximum power of all critical PIs of the PSE
Typically, the maximum guaranteed PSE power is equal to the maximum PSE power.
Powered Ports
Number of PIs that are receiving power from the PSE.
display poe pse
Use display poe pse to display detailed PSE information.
display poe pse [ pse-id ]
pse-id: Specifies a PSE by its ID. If you do not specify a PSE, this command displays information about all PSEs.
# (In standalone mode.) Display detailed information about PSE 7.
<Sysname> display poe pse 7
 PSE ID                                      : 7
 Slot No.                                    : 2
 PSE Model                                   : LSQ1GV48SD0
 PSE Status                                  : Enabled
 Power Priority                              : Low
 Current Power                               : 0.0 W
 Average Power                               : 0.0 W
 Peak Power                                   : 0.0 W
 Max Power                                      : 800.0 W
 Remaining Guaranteed Power                : 800.0 W
 PSE CPLD Version                            : -
 PSE Software Version                       : 390
 PSE Hardware Version                       : 57603
 Legacy  PD Detection                       : Disabled
 Power Utilization Threshold              : 80
 PD Power Policy                            : Disabled
 PD Disconnect-Detection Mode             : DC
# (In IRF mode.) Display detailed information about PSE 7.
 PSE ID                                       : 7
 Chassis                                      : 1
 Slot No.                                     : 2
 SSlot No.                                    : 0
 PSE Status                                   : Disabled
 Peak Power                                      : 0.0 W
 Max Power                                    : 800.0 W
 PD Disconnect Detection Mode              : DC
Table 6 Command output
PSE ID
ID of the PSE.
Slot No.
SSlot No.
Subslot number of the PSE.
Chassis
In IRF mode, member ID of the device where the PSE resides.
PSE Status
PoE status of the PSE:
·     Enabled.
·     Disabled.
Power Priority
Power priority of the PSE.
Current Power
Average Power
Peak Power
Max Power
Remaining guaranteed power of the PSE = Maximum guaranteed power of the PSE – Total maximum power of all critical PIs of the PSE.
PSE CPLD Version
PSE CPLD version number.
PSE software version number.
PSE hardware version number.
Legacy PD Detection
Nonstandard PD detection status:
·     Enabled.
·     Disabled.
PSE power alarm threshold.
PD Power Policy
PD power management policy mode.
PD disconnection detection mode. This field is not supported in the current software version.
display poe pse interface
Use display poe pse interface to display the PoE status of all PIs on a PSE.
display poe pse pse-id interface
pse pse-id: Specifies a PSE ID.
To display PSE ID and slot mappings, use the display poe device command.
# Display the status of all PIs connected to PSE 7.
<Sysname> display poe pse 7 interface
                                      (W)                             Class    Status
 GE1/0/2        Enabled   Critical  0.0        Power-lack          -        Disabled
 GE1/0/3        Enabled   Low        0.0        Power-deny          -        Disabled
 GE1/0/5        Enabled   Low        4.0        Power-limit        2         Delivering Power
 GE1/0/6        Enabled   Low        0.0        Power-itself       -         Disabled
   ---  On State Ports: 2; Used: 8.4(W); Remaining: 171.6 (W)  ---
Table 7 Command output
PoE
PoE status of a PI:
·     Enabled.
·     Disabled.
Priority
Priority of a PI:
·     High.
·     Low.
CurPower
Oper
IEEE Class
Detection Status
·     Delivering Power—The PI is supplying power to the PD.
·     Other Fault—A fault has caused the PSE to enter the idle status.
·     PD Disconnected—The PD is disconnected.
On State Ports
Used
Power consumed by PIs on the PSE.
Remaining
Remaining power on the PSE.
display poe pse interface power
Use display poe pse interface power to display power information for PIs on a PSE.
display poe pse pse-id interface power
pse pse-id: Specifies a PSE by its ID.
# Display power information for PIs on PSE 7.
<Sysname> display poe pse 7 interface power
            (W)        (W)        (W)
 GE1/0/25    4.4        4.5        4.6         IP Phone on Room 309 for Peter Smith
 GE1/0/26    4.4        4.5        15.4        IP Phone on Room 409 for Peter Pan
 GE1/0/27    15.0       15.3       15.4        Access Point on Room 509 for Peter
 GE1/0/28    0.0        0.0        5.0         IP Phone on Room 609 for Peter John
 GE1/0/29    0.0        0.0        4.0         IP Phone on Room 709 for Jack
 GE1/0/30    0.0        0.0        5.0         IP Phone on Room 809 for Alien
Table 8 Command output
Current
Peak
Peak power of a PI.
Max
PD Description
Type and location description for the PD connected with a PI.
Ports On
Used
Remaining
display poe-power
Use display poe-power to display PoE power information.
In standalone mode:
display poe-power
In IRF mode:
display poe-power [ chassis chassis-number ]
# (In standalone mode.) Display PoE power information.
<Sysname> display poe-power
 PoE Current Power                    : 1870     W
 PoE Average Power                    : 2100     W
 PoE Peak Power                        : 2350     W
 PoE Nominal Power                     : 2500     W
 PoE Current Electric Current        : 3.00     A
 PoE Current Voltage                   : 55.00    V
 PoE Lower Input Threshold            : 111.22   V
 PoE Upper Input Threshold            : 131.00   V
 PoE Lower Output Threshold           : 45.00    V
 PoE Upper Output Threshold           : 57.00    V
 PoE Hardware Version                  : 0002
 PoE Software Version                  : 0001
 PoE Power Supplies                     : 2
 PoE Power Supply 1:
 Manufacturer                          : Tyco Electronics Com
 Type                                    : PSE2500-A
 Status                                  : Normal
 PoE Power Supply 2:
 Type                                    : PSE2500-B
 Status                                  : Normal
# (In IRF mode.) Display PoE power information.
Chassis 1 :
 PoE Power Supply 1:
     Type                                 : PSE2500-A
     Status                              : Normal
 PoE Power Supply 2:
     Type                                : PSE2500-B
     Status                              : Normal
Chassis 2 :
 PoE Power Supply 1:
 Type                                       : PSE2500-A
 Status                                     : Normal
 PoE Power Supply 2:
 Type                                        : PSE2500-B
 Status                                      :Normal
Table 9 Command output
Chassis 1
PoE Current Power
Current PoE power.
PoE Average Power
Average PoE power.
PoE Peak Power
Peak PoE power.
PoE Max Power
Maximum PoE power.
PoE Nominal Power
Nominal PoE power.
Current PoE current.
PoE Current Voltage
Current PoE voltage.
AC input under-voltage threshold.
AC input over-voltage threshold.
DC output under-voltage threshold.
DC output over-voltage threshold.
PoE hardware version number.
PoE software version number.
PoE Power Supplies
Number of PoE power supply units.
Manufacturer
Manufacturer of the PoE power. This field displays NONE if the device cannot obtain manufacturer information.
Type of the PoE power. This field displays NONE if the device cannot obtain type information.
Status
PoE power status:
·     Normal—The PoE power supply is operating correctly.
·     Absent—The PoE power supply is not present.
display poe-profile
Use display poe-profile to display information about the PoE profile.
display poe-profile [ index index | name profile-name ]
If you do not specify a profile, the command displays information about all PoE profiles.
# Display information about all PoE profiles.
<Sysname> display poe-profile
 PoE Profile     Index   ApplyNum  Interfaces     Configuration
 forIPphone      1        6          GE1/0/5            poe enable
                                        GE1/0/6           poe priority critical
                                        GE1/0/7
                                        GE1/0/8
                                        GE1/0/9
                                        GE1/0/10
 forAP            2        2          GE1/0/11         poe enable
                                        GE1/0/12         poe max-power 14000
   ---  Total PoE profiles: 3, total ports: 0  ---
# Display information about the PoE profile with index number 1.
<Sysname> display poe-profile index 1
                                       GE1/0/7
                                       GE1/0/8
                                       GE1/0/9
                                       GE1/0/1
   ---  Total ports: 0  ---
Table 10 Command output
PoE Profile
Name of the PoE profile.
Index
Index number of the PoE profile.
ApplyNum
Number of PIs to which the PoE profile is applied.
Interfaces
Interface name of the PI to which the PoE configuration is applied.
Configuration
Configurations of the PoE profile.
Total PoE profiles
Number of PoE profiles.
Total ports
Number of PIs to which all PoE profiles are applied.
Use display poe-profile interface to display information about the PoE profile on a PI.
display poe-profile interface interface-type interface-number
# Display information about the PoE profile on GigabitEthernet 1/0/1.
<Sysname> display poe-profile interface gigabitethernet 1/0/1
 PoEProfile     Index   ApplyNum  Interface   Effective configuration
 forIPphone      1        6          GE1/0/1       poe enable
The Effective configuration field displays the configurations that have taken effect. For the descriptions of other fields, see Table 10.
poe enable
Use poe enable to enable PoE on a PI.
Use undo poe enable to disable PoE on a PI.
poe enable
undo poe enable
PoE is disabled on a PI.
PI view
PoE profile view
If a PoE profile has been applied to a PI, remove the application before configuring the PI in PoE profile view.
If a PI has been configured, remove the configuration before configuring the PI in PI view.
# Enable PoE on a PI in PI view.
[Sysname-GigabitEthernet1/0/1] poe enable
# Enable PoE on a PI in PoE profile view.
[Sysname] poe-profile abc
[Sysname-poe-profile-abc-1] poe enable
·     display poe interface
·     poe-profile
poe enable pse
Use poe enable pse to enable PoE for a PSE.
Use undo poe enable pse to disable PoE for the PSE.
poe enable pse pse-id
undo poe enable pse pse-id
PoE is disabled on PSEs.
# Enable PoE for PSE 7.
[Sysname] poe enable pse 7
display poe pse
poe legacy enable
Use poe legacy enable to enable a PSE to detect nonstandard PDs.
Use undo poe legacy enable to disable the PSE from detecting nonstandard PDs.
poe legacy enable pse pse-id
undo poe legacy enable pse pse-id
Nonstandard PD detection is disabled.
# Enable PSE 7 to detect nonstandard PDs.
[Sysname] poe legacy enable pse 7
display poe pse
poe max-power
Use poe max-power to configure the maximum power for a PI.
Use undo poe max-power to restore the default.
poe max-power max-power
undo poe max-power
The maximum power of a PI is 30000 milliwatts.
PI view
PoE profile view
max-power: Sets the maximum power to an integer in the range of 1000 to 30000, in milliwatts.
# Set the maximum power of a PI to 12000 milliwatts in PI view.
[Sysname-GigabitEthernet1/0/1] poe max-power 12000
# Set the maximum power of a PI to 12000 milliwatts in PoE profile view.
[Sysname-poe-profile-abc-1] poe max-power 12000
·     poe max-power(system view)
·     poe power max-value
poe max-power (system view)
Use poe max-power to set the maximum power for a PSE.
poe pse pse-id max-power max-power
undo poe pse pse-id max-power
The maximum power for a PSE is 800 watts.
max-power: Sets the maximum power to an integer in the range of 37 to 800, in watts.
To prevent power supply interruption, the maximum PSE power must be greater than the total maximum power of all critical PIs.
The total maximum power of PSEs must be smaller than the maximum PoE power.
On an IRF 3 system, the maximum PSE power configuration is not supported on a PEX. For more information about IRF 3 and PEXs, see Virtual Technologies Configuration Guide.
# Set the maximum power to 150 watts for PSE 7.
[Sysname] poe pse 7 max-power 150
poe priority pse
poe mode
Use poe mode to configure a PoE power transmission mode.
Use undo poe mode to restore the default.
poe mode { signal | spare }
undo poe mode
The PoE power transmission mode is signal (power over signal cables).
PI view
PoE profile view
signal: Specifies the PoE power transmission mode as power over signal cables. The system uses pairs 1, 2, 3, and 6 in the Category 3 or Category 5 twisted pair cable to supply DC power.
spare: Specifies the PoE power transmission mode as power over spare cables. The system uses pairs 4, 5, 7, and 8 in the Category 3 or Category 5 twisted pair cable to supply DC power. The switch does not support this keyword.
# Set the PoE power transmission mode to power over signal cables in PI view.
[Sysname-GigabitEthernet1/0/1] poe mode signal
# Set the PoE power transmission mode to power over signal cables in PoE profile view.
[Sysname-poe-profile-abc-1] poe mode signal
poe-profile
poe pd-description
Use poe pd-description to configure a description for the PD that connects to a PI.
Use undo poe pd-description to restore the default.
poe pd-description text
No description is available for the PD that connects to a PI.
PI view
text: Configures a description for the PD connected to the PI, a case-sensitive string of 1 to 80 characters.
# Configure the description for the PD as IP Phone for Room 101.
[Sysname] interface gigabitEthernet 1/0/1
[Sysname-GigabitEthernet1/0/1] poe pd-description IP Phone For Room 101
poe pd-policy priority
Use poe pd-policy priority to enable PI power management.
Use undo poe pd-policy priority to restore the default.
PI power management is disabled.
If PI power management is disabled, the PSE does not supply power to new PDs when PSE power overload occurs.
If PI power management is enabled, when a PSE is overloaded, the PSE allocates power to new PDs based on the priority of their PIs.
# Enable PI power management.
[Sysname] poe pd-policy priority
poe priority
poe power max-value
Use poe power max-value to set the maximum PoE power.
Use undo poe power max-value to restore the default.
In standalone mode:
poe power max-value max-power
In IRF mode:
poe power chassis chassis-number max-value max-power
undo poe power chassis chassis-number max-value
The maximum power of the power supply is the total maximum power of all operating PoE power modules in the PoE power frame.
max-power: Sets the maximum power to a positive integer that is smaller than the total maximum power of all operating PoE power modules in the PoE power frame. To accommodate transient peak power surges, the actual maximum power available is 5% higher than the configured maximum power.
chassis chassis-number: Specifies an IRF member device by its member ID. (In IRF mode.)
The configured maximum PoE power cannot exceed the rated PoE power.
# Set the maximum PoE power to 2000 watts.
[Sysname] poe power max-value 2000
poe priority
Use poe priority to configure a power supply priority for a PI.
Use undo poe priority to restore the default.
poe priority { critical | high | low }
undo poe priority
The power priority of a PI is low.
PI view
PoE profile view
critical: Sets the power supply priority to critical. The PI with critical power priority operates in guaranteed mode. Power is first supplied to the PD connected to the critical PI.
high: Sets the power supply priority to high.
low: Sets the power supply priority to low.
When the PoE power is insufficient, power is first supplied to PIs with higher priority.
For PIs with same power supply priority, the PI with the smallest ID is allocated with power first.
# Set the power supply priority of the PI to critical in PI view.
[Sysname-GigabitEthernet1/0/1] poe priority critical
# Set the power supply priority of the PI to critical in PoE profile view.
[Sysname-poe-profile-abc-1] poe priority critical
[Sysname-poe-profile-abc-1] quit
[Sysname-GigabitEthernet1/0/1] apply poe-profile name abc
poe priority (system view)
Use poe priority to set the power supply priority for a PSE.
poe priority { critical | high | low } pse pse-id
undo poe priority pse pse-id
The power priority of a PSE is low.
critical: Sets the power supply priority to critical. The PSE with critical power priority operates in guaranteed mode. Power is first supplied to the critical PSE.
If PSE power management is disabled, the system does not supply power to new PSEs when PoE power overload occurs.
If PSE power management is enabled, when PSE power overload occurs, the system supplies power to a PSE with higher priority. For multiple new PSEs with the same priority, the PSE with a smaller ID gets power supplied first.
For example, if PoE is enabled for a PSE, and the PSE has higher priority, the system performs the following operations:
·     Stops supplying power to a PSE with lower priority.
·     Supplies power to the PSE that has higher priority.
On an IRF 3 system, the power supply priority configuration for a PSE is not supported on a PEX. For more information about IRF 3 and PEXs, see Virtual Technologies Configuration Guide.
# Set the power supply priority to critical for PSE 7.
[Sysname] poe priority critical pse 7
poe pse-policy priority
Use poe pse-policy priority to enable PSE power management.
Use undo poe pse-policy priority to restore the default.
PSE power management is disabled.
If PSE power management is enabled, the system supplies power based on the PSE priority when a new PSE causes PoE power overload.
On an IRF 3 system, the PSE power management configuration is not supported on a PEX. For more information about IRF 3 and PEXs, see Virtual Technologies Configuration Guide.
# Enable PSE power management.
[Sysname] poe pse-policy priority
poe temperature-protection
Use poe temperature-protection enable to enable PoE over-temperature protection.
Use undo poe temperature-protection enable to disable the feature.
PoE over-temperature protection is enabled.
If PoE over-temperature protection is enabled, the device disables PoE on all PIs when the temperature exceeds the upper limit or drops below the lower limit.
# Disable PoE over-temperature protection.
[Sysname] undo poe temperature-protection enable
poe update
Use poe update to upgrade a PSE firmware when the device is operating.
poe update { full | refresh } filename [ pse pse-id ]
full: Upgrades the PSE firmware in full mode. You can use this mode if the firmware is unavailable, and execution of all PoE commands fails.
refresh: Upgrades the PSE firmware in refresh mode. You can use this mode if the firmware is available.
filename: Specifies the name of the upgrade file, a case-sensitive string of 1 to 64 characters. The specified file must be in the root directory of the file system of the device.
pse pse-id: Specifies a PSE by its ID. If you do not specify a PSE, all PSEs are upgraded.
# Upgrade the firmware of PSE 7 in service.
[Sysname] poe update refresh 0400_001.S19 pse 7
poe-profile
Use poe-profile to create a PoE profile and enter PoE profile view.
Use undo poe-profile to delete the specified PoE profile.
poe-profile profile-name [ index ]
undo poe-profile { index index | name profile-name }
No PoE profile is created.
profile-name: Specifies a PoE profile name, a case-sensitive string of 1 to 15 characters. A PoE configuration file name begins with a letter and must not contain reserved keywords including undo, all, name, interface, user, poe, disable, max-power, mode, priority, or enable.
index: Specifies the index number of a PoE profile, in the range of 1 to 100.
If you do not specify a profile index, the system automatically assigns an index (starting from 1) to the PoE profile.
If a PoE profile is applied, use the undo apply poe-profile command to remove the application before deleting the PoE profile.
# Create a PoE profile, name it abc, and specify the index number as 3.
[Sysname] poe-profile abc 3
[Sysname-poe-profile-abc-3]
# Create a PoE profile and name it def. Do not specify the index number.
[Sysname] poe-profile def
[Sysname-poe-profile-def-1]
·     apply poe-profile
·     poe enable
·     poe max-power
·     poe mode
·     poe priority
poe utilization-threshold
Use poe utilization-threshold to configure a power alarm threshold for a PSE.
Use undo poe utilization-threshold to restore the default power alarm threshold of a PSE.
poe utilization-threshold value pse pse-id
undo poe utilization-threshold pse pse-id
The power alarm threshold for the PSE is 80%.
value: Specifies alarm threshold as a percentage of 1 to 99.
If PSE power usage crosses the threshold multiple times in succession, the system sends notification messages only for the first crossing. For more information, see "Configuring SNMP."
# Set the power alarm threshold of PSE 7 to 90%.
[Sysname] poe utilization-threshold 90 pse 7
