06-Layer 3 - IP Routing Command Reference
HomeSupportSwitchesH3C S7500E Switch SeriesReference GuidesCommand ReferencesH3C S7500E Switch Series Command References-Release7178-6W10006-Layer 3 - IP Routing Command Reference
09-RIPng commands
09-RIPng commands 99.61 KB
RIPng commands
checkzero
Use checkzero to enable zero field check on RIPng packets.
Use undo checkzero to disable zero field check.
checkzero
undo checkzero
Zero field check is enabled.
RIPng view
Some fields in RIPng packet headers must be zero. These fields are called zero fields. You can enable zero field check on incoming RIPng packets. If a zero field of a packet contains a non-zero value, RIPng does not process the packet.
# Disable zero field check on RIPng packets for RIPng 100.
[Sysname] ripng 100
[Sysname-ripng-100] undo checkzero
default cost
Use default cost to configure a default metric for redistributed routes.
Use undo default cost to restore the default.
default cost value
undo default cost
The default metric of redistributed routes is 0.
RIPng view
value: Specifies a default metric for redistributed routes, in the range of 0 to 16.
When you use the import-route command to redistribute routes from another routing protocol without specifying a metric, the metric specified by the default cost command applies.
# Configure a default metric of 2 for redistributed routes.
[Sysname] ripng 100
[Sysname-ripng-100] default cost 2
import-route
display ripng
Use display ripng to display state and configuration information for a RIPng process.
display ripng [ process-id ]
process-id: Specifies a RIPng process by its ID in the range of 1 to 65535. If you do not specify this argument, the command displays information about all RIPng processes.
# Display state and configuration information for all configured RIPng processes.
<Sysname> display ripng
  Public VPN-instance name:
RIPng process: 1
       Preference: 100
           Routing policy: abc
       Checkzero: Enabled
       Default cost: 0
       Maximum number of load balanced routes: 6
       Update time   :   30 secs  Timeout time         :  180 secs
       Suppress time :  120 secs  Garbage-collect time :  120 secs
       Number of periodic updates sent: 256
       Number of trigger updates sent: 1
Public VPN-instance name/Private VPN-instance name
Public network or VPN where the RIPng process runs.
RIPng process
RIPng process ID.
Preference
RIPng preference.
Checkzero
Indicates whether zero field check for RIPng packet headers is enabled.
Default Cost
Default metric of redistributed routes.
Maximum number of balanced paths
Maximum number of load-balanced routes.
Update time
RIPng update interval, in seconds.
Timeout time
RIPng timeout interval, in seconds.
Suppress time
RIPng suppress interval, in seconds.
Garbage-Collect time
RIPng garbage collection interval, in seconds.
display ripng database
Use display ripng database to display all active routes in the advertising database for a RIPng process. RIPng advertises active routes in RIPng routing updates.
display ripng process-id database [ ipv6-address prefix-length ]
ipv6-address prefix-length: Specifies an IPv6 address. The ipv6-address argument specifies an IPv6 address. The prefix-length argument specifies a prefix length in the range of 0 to 128.
# Display active routes for RIPng process 1.
<Sysname> display ripng 1 database
   1::/64,
        cost 0, RIPng-interface
   10::/32,
        cost 0, imported
   2::2/128,
       via FE80::20C:29FF:FE7A:E3E4, cost 1
cost
Route metric value.
imported
Indicates the route is redistributed from another routing protocol.
RIPng-interface
Route learned from the interface.
via
Next hop IPv6 address.
display ripng interface
Use display ripng interface to display interface information for a RIPng process.
display ripng process-id interface [ interface-type interface-number ]
interface-type interface-number: Specifies an interface by its type and number. If you do not specify this argument, the command displays information about all interfaces for the RIPng process.
# Display interface information for RIPng process 1.
<Sysname> display ripng 1 interface
         Link-local address: FE80::20C:29FF:FEC8:B4DD
         Split-horizon: On                Poison-reverse: Off
         MetricIn: 0                      MetricOut: 1
         Default route: Off
         Summary address:
                1::/16
Name of an interface running RIPng.
Link Local Address
Link-local address of an interface running RIPng.
Split-horizon
Indicates whether split horizon is enabled:
·     On—Enabled.
·     Off—Disabled.
Poison-reverse
Indicates whether poison reverse is enabled:
·     On—Enabled.
·     Off—Disabled.
MetricIn/MetricOut
Additional metric to incoming and outgoing routes.
Default route
·     OnlyThe interface advertises only a default route.
·     OriginateThe interface advertises a default route and other RIPng routes.
·     Off—In this state, the interface does not advertise a default route.
·     In garbage-collection statusIn this state, the interface advertises a default route with a metric of 16.
Default route cost
Cost of the default route.
display ripng route
Use display ripng route to display all RIPng routes for a RIPng process.
display ripng process-id route [ ipv6-address prefix-length [ verbose ] | peer ipv6-address | statistics ]
verbose: Displays all routing information for the specified destination IPv6 address. If you do not specify this keyword, the command displays only optimal RIPng routes with the specified destination IPv6 address.
peer ipv6-address: Specifies a neighbor by its IPv6 address.
statistics: Displays routing information statistics, including total number of routes and the number of routes learned from each neighbor.
# Display routing information for RIPng process 1.
<Sysname> display ripng 1 route
   Route Flags: A - Aging, S - Suppressed, G - Garbage-collect
                O - Optimal, F - Flush to RIB
 Peer FE80::20C:29FF:FED4:7171 on GigabitEthernet1/0/2
 Destination 4::4/128,
     via FE80::20C:29FF:FED4:7171, cost 1, tag 0, AOF, 5 secs
# Display information about routes with the specified destination IPv6 address for RIPng process 1.
<Sysname> display ripng 1 route 2::2 64 verbose
 Peer FE80::200:FCFF:FE00:5A9 on GigabitEthernet3/0/1
 Destination 2::/64,
     via FE80::200:FCFF:FE00:5A9, cost 1, tag 0, AOF, 26 secs
A–Aging
The route is in aging state.
S–Suppressed
The route is in suppressed state.
G–Garbage-collect
The route is in Garbage-collect state.
O - Optimal
The route is an optimal route.
F - Flush to RIB
The route has been flushed to the RIB.
Peer
Neighbor connected to the interface.
Destination
IPv6 destination address.
via
cost
Routing metric value.
tag
Route tag.
secs
Time a route entry has stayed in the current state.
# Display routing information statistics for RIPng process 1.
<Sysname> display ripng 1 route statistics
Peer                                            Optimal/Aging    Garbage
 FE80::20C:29FF:FED4:7171                        1/2              0
 total                                           1/2              0
Table 5 Command output
Peer
IPv6 address of the neighbor.
Optimal
Number of optimal routes.
Aging
Number of routes in aging state.
Garbage
Number of routes in Garbage-collection state.
total
Total number of routes learned from RIPng neighbors.
enable ipsec-profile
Use enable ipsec-profile to apply an IPsec profile to a RIPng process.
Use undo enable ipsec-profile to remove the IPsec profile from the RIPng process.
enable ipsec-profile profile-name
No IPsec profile is applied to the RIPng process.
RIPng view
profile-name: Specifies an IPsec profile by its name, a case-insensitive string of 1 to 63 characters.
This command must reference an IPsec profile. For more information about IPsec profiles, see Security Configuration Guide.
# Apply the IPsec profile profile001 to RIPng process 1.
[Sysname] ripng 1
[Sysname-ripng-1] enable ipsec-profile profile001
filter-policy export
Use filter-policy export to configure RIPng to filter redistributed routes. Only routes not filtered can be advertised in update messages.
Use undo filter-policy export to remove the configuration.
filter-policy { acl6-number | prefix-list prefix-list-name } export [ protocol [ process-id ] ]
RIPng does not filter redistributed routes.
RIPng view
acl6-number: Specifies an ACL by its number in the range of 2000 to 3999 to filter redistributed routes.
prefix-list prefix-list-name: Specifies an IPv6 prefix list by its name, a string of 1 to 63 characters, to filter redistributed routes.
protocol: Filters routes redistributed from a routing protocol, including bgp4+, direct, isisv6, ospfv3, ripng, and static.
process-id: Specifies the process ID of the specified routing protocol, in the range of 1 to 65535. This argument is available only when the routing protocol is ripng, ospfv3, or isisv6. The default is 1.
If the protocol argument is specified, RIPng filters only routes redistributed from the specified routing protocol. Otherwise, RIPng filters all redistributed routes.
To use an advanced ACL (with a number from 3000 to 3999) in the command, configure the ACL in one of the following ways:
·     To deny/permit a route with the specified destination, use the rule [ rule-id ] { deny | permit } ipv6 source sour sour-prefix command.
·     To deny/permit a route with the specified destination and prefix, use the rule [ rule-id ] { deny | permit } ipv6 source sour sour-prefix destination dest dest-prefix command.
The source keyword specifies the destination address of a route and the destination keyword specifies the prefix of the route. The specified prefix must be contiguous. Otherwise, the prefix configuration does not take effect.
# Use IPv6 prefix list to filter redistributed RIPng updates.
[Sysname] ipv6 prefix-list abc index 10 permit 100:1:: 32
[Sysname] ripng 100
[Sysname-ripng-100] filter-policy prefix-list abc export
# Configure IPv6 ACL 3000 to permit only route 2001::1/128 to pass. Use IPv6 ACL 3000 to filter redistributed routes.
[Sysname-acl6-adv-3000] rule 10 permit ipv6 source 2001::1 128 destination ffff:ffff:ffff:ffff:ffff:ffff:ffff:ffff 128
[Sysname-acl6-adv-3000] rule 100 deny ipv6
[Sysname-acl6-adv-3000] quit
[Sysname] ripng 100
[Sysname-ripng-100] filter-policy 3000 export
filter-policy import
Use filter-policy import to configure RIPng to filter received routes. Only routes not filtered can be received.
Use undo filter-policy import to remove the configuration.
filter-policy { acl6-number | prefix-list prefix-list-name } import
RIPng does not filter received routes.
RIPng view
acl6-number: Specifies an ACL by its number in the range of 2000 to 3999 to filter received routes.
prefix-list prefix-list-name: Specifies an IPv6 prefix list by its name, a string of 1 to 63 characters, to filter received routes.
The source keyword specifies the destination address of a route and the destination keyword specifies the prefix of the route. The prefix must be contiguous. Otherwise, the configuration does not take effect.
# Use IPv6 prefix list abc to filter received RIPng updates.
[Sysname] ripng 100
[Sysname-ripng-100] filter-policy prefix-list abc import
# Configure IPv6 ACL 3000 to permit only route 2001::1/128 to pass. Use IPv6 ACL 3000 to filter received routes.
[Sysname] ripng 100
[Sysname-ripng-100] filter-policy 3000 import
graceful-restart
Use graceful-restart to enable Graceful Restart (GR) for RIPng.
Use undo graceful-restart to disable RIPng GR capability.
graceful-restart
RIPng GR is disabled.
RIPng view
# Enable GR for RIPng process 1.
[Sysname] ripng 1
[Sysname-ripng-1] graceful-restart
import-route
Use import-route to redistribute routes from another routing protocol.
Use undo import-route to disable route redistribution.
import-route protocol [ process-id ] [ allow-ibgp ] [ cost cost | route-policy route-policy-name ] *
undo import-route protocol [ process-id ]
RIPng does not redistribute routes from another routing protocol.
RIPng view
protocol: Specifies a routing protocol from which RIPng redistributes routes. It can be bgp4+, direct, isisv6, ospfv3, ripng, or static.
process-id: Specifies a process by its ID in the range of 1 to 65535. The default is 1. This argument is available only when the protocol is isisv6, ospfv3, or ripng.
allow-ibgp: Allows redistribution of IBGP routes. This keyword is available when the protocol argument is set to bgp4+.
cost cost: Specifies a metric for redistributed routes, in the range of 0 to 16. The default metric is 0.
route-policy route-policy-name: Specifies a routing policy by its name, a case-sensitive string of 1 to 63 characters.
The import-route bgp4+ command redistributes only EBGP routes. The import-route bgp4+ allow-ibgp command redistributes both EBGP and IBGP routes.
# Redistribute routes from IPv6 IS-IS process 7 into RIPng and set the metric for redistributed routes to 7.
[Sysname] ripng 100
[Sysname-ripng-100] import-route isisv6 7 cost 7
maximum load-balancing
Use maximum load-balancing to set the maximum number of equal-cost multi-path (ECMP) routes for load balancing.
Use undo maximum load-balancing to restore the default.
maximum load-balancing number
The maximum number of RIPng ECMP routes equals the maximum number of ECMP routes supported by the system.
RIPng view
number: Specifies the maximum number of ECMP routes. When this argument takes a value of 1, RIPng does not perform load balancing.
If you use the max-ecmp-num command to configure the maximum number of ECMP routes supported by the system as m:
·     The default setting for the maximum load-balancing command is m.
·     The value range for the number argument of the maximum load-balancing command is 1 to m.
# Specify the maximum number of ECMP routes as 2.
[Sysname] ripng 100
[Sysname-ripng-100] maximum load-balancing 2
max-ecmp-num
preference
Use preference to set the preference for RIPng routes.
Use undo preference to restore the default.
preference [ route-policy route-policy-name ] value
undo preference
The preference of RIPng routes is 100.
RIPng view
value: Specifies the preference for RIPng routes, in the range of 1 to 255. The smaller the value, the higher the preference.
You can specify a routing policy to set a preference for the matching RIPng routes.
·     The preference set by the routing policy applies to all matching RIPng routes. The preference of other routes is set by the preference command.
·     If no preference is set by the routing policy, the preference of all RIPng routes is set by the preference command.
# Set the preference for RIPng routes to 120.
[Sysname] ripng 100
[Sysname-ripng-100] preference 120
reset ripng process
Use reset ripng process to restart a RIPng process.
reset ripng process-id process
After executing the command, you are prompted to confirm the operation.
# Restart RIPng process 100.
<Sysname> reset ripng 100 process
Reset RIPng process? [Y/N]:y
reset ripng statistics
Use reset ripng statistics to clear statistics for a RIPng process.
reset ripng process-id statistics
# Clear statistics for RIPng process 100.
<Sysname> reset ripng 100 statistics
ripng
Use ripng to create a RIPng process and enter RIPng view.
Use undo ripng to disable a RIPng process.
ripng [ process-id ] [ vpn-instance vpn-instance-name ]
undo ripng [ process-id ]
No RIPng process is enabled.
process-id: Specifies a RIPng process by its ID in the range of 1 to 65535. The default value is 1.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, the RIPng process runs on the public network.
Before you configure global RIPng parameters, you must create a RIPng process. This restriction does not apply to configuring interface RIPng parameters.
If you disable a RIPng process, the configured RIPng parameters become invalid.
# Create RIPng process 100 and enter its view.
[Sysname] ripng 100
[Sysname-ripng-100]
ripng default-route
Use ripng default-route to configure a RIPng interface to advertise a default route with a specified metric.
Use undo ripng default-route to disable a RIPng interface from sending a default route.
ripng default-route { only | originate } [ cost cost ]
A RIPng process does not advertise a default route.
Interface view
only: Advertises only an IPv6 default route (::/0).
originate: Advertises an IPv6 default route (::/0) and other routes.
cost: Specifies a cost for the default route, in the range of 1 to 15. The default is 1.
This command enables the interface to advertise a RIPng default route in a route update regardless of whether the default route exists in the local IPv6 routing table.
A RIPng interface configured to advertise a default route does not receive any default routes from its neighbors.
# Configure RIPng on VLAN-interface 100 to advertise only a default route.
[Sysname-Vlan-interface100] ripng default-route only
# Configure RIPng on VLAN-interface 101 to advertise a default route and other routes.
[Sysname] interface vlan-interface 101
[Sysname-Vlan-interface101] ripng default-route originate
ripng enable
Use ripng enable to enable RIPng on an interface.
Use undo ripng enable to disable RIPng on an interface.
ripng process-id enable
undo ripng enable
RIPng is disabled on an interface.
Interface view
# Enable RIPng 100 on VLAN-interface 100.
[Sysname-Vlan-interface100] ripng 100 enable
ripng ipsec-profile
Use ripng ipsec-profile to apply an IPsec profile to a RIPng interface.
Use undo ripng ipsec-profile to remove the IPsec profile from the interface.
ripng ipsec-profile profile-name
No IPsec profile is applied to the RIPng interface.
Interface view
# Apply the IPsec profile profile001 to VLAN-interface 100.
[Sysname-Vlan-interface100] ripng ipsec-profile profile001
ripng metricin
Use ripng metricin to configure an interface to add a metric to inbound RIPng routes.
Use undo ripng metricin to restore the default.
ripng metricin value
undo ripng metricin
The additional metric of an inbound route is 0.
Interface view
value: Adds an additional metric to inbound routes, in the range of 0 to 16.
# Configure VLAN-interface 100 to add a metric of 12 to inbound RIPng routes.
[Sysname-Vlan-interface100] ripng metricin 12
ripng metricout
Use ripng metricout to configure an interface to add a metric to outbound RIPng routes.
Use undo ripng metricout to restore the default.
ripng metricout value
The additional metric of outbound routes is 1.
Interface view
value: Adds an additional metric to outbound routes, in the range of 1 to 16.
# Configure RIPng on VLAN-interface 100 to add a metric of 12 to outbound routes.
[Sysname-Vlan-interface100] ripng metricout 12
ripng poison-reverse
Use ripng poison-reverse to enable poison reverse.
Use undo ripng poison-reverse to disable poison reverse.
Poison reverse is disabled.
Interface view
# Enable poison reverse for RIPng update messages on VLAN-interface 100.
[Sysname-Vlan-interface100] ripng poison-reverse
ripng split-horizon
Use ripng split-horizon to enable split horizon.
Use undo ripng split-horizon to disable split horizon.
ripng split-horizon
Split horizon is enabled.
Interface view
Split horizon prevents routing loops. If you want to disable this feature, make sure the operation is indispensable.
If both poison reverse and split horizon are enabled, only poison reverse takes effect.
On NBMA networks, such as FR and X.25 where multiple VCs are configured on the primary and secondary interfaces, disable split horizon to ensure correct route advertisement. For more information, see Layer 2—WAN Configuration Guide.
# Enable split horizon on VLAN-interface 100.
[Sysname-Vlan-interface100] ripng split-horizon
ripng summary-address
Use ripng summary-address to configure a summary network to be advertised through the interface.
Use undo ripng summary-address to remove the summary.
ripng summary-address ipv6-address prefix-length
undo ripng summary-address ipv6-address prefix-length
The summary network to be advertised through the interface is not configured.
Interface view
ipv6-address: Specifies the destination IPv6 address of the summary route.
prefix-length: Specifies the prefix length of the destination IPv6 address of the summary route, in the range of 0 to 128. It indicates the number of consecutive 1s of the prefix, which defines the network ID.
Networks on the summary network will not be advertised. The cost of the summary route is the lowest cost among summarized routes.
# Assign an IPv6 address with the 64-bit prefix to VLAN-interface 100 and configure a summary with the 35-bit prefix.
[Sysname-Vlan-interface100] ipv6 address 2001:200::3EFF:FE11:6770/64
[Sysname-Vlan-interface100] ripng summary-address 2001:200:: 35
timers
Use timers to configure RIPng timers.
Use undo timers to restore the default.
undo timers { garbage-collect | suppress | timeout | update } *
The garbage-collect timer is 120 seconds, the suppress timer is 120 seconds, the timeout timer is 180 seconds, and the update timer is 30 seconds.
RIPng view
Predefines user roles
garbage-collect-value: Sets the garbage-collect timer in the range of 1 to 86400 seconds.
suppress-value: Sets the suppress timer in the range of 0 to 86400 seconds.
timeout-value: Sets the timeout timer in the range of 1 to 86400 seconds.
update-value: Sets the update timer in the range of 1 to 86400 seconds.
RIPng has the following timers:
·     Update timerInterval between update messages.
·     Timeout timerRoute aging time. If no update for a route is received before the timer expires, RIPng sets the metric of the route to 16.
·     Suppress timerHow long a RIPng route stays in suppressed state. When the metric of a route becomes 16, the route enters the suppressed state. If RIPng receives an update for the route from the same neighbor and the route in the update has a metric less than 16, RIPng uses the route to replace the suppressed route.
·     Garbage-collect timerInterval from when the metric of a route becomes 16 to when it is deleted from the routing table. During the garbage-collect timer length, RIPng advertises the route with a metric of 16. If no update is announced for that route before the garbage-collect timer expires, RIPng deletes the route from the routing table.
As a best practice, do not change the default values of these timers.
The timer lengths must be kept consistent on all routers in the network.
# Configure the update, timeout, suppress, and garbage-collect timers as 5 seconds, 15 seconds, 15 seconds, and 30 seconds.
[Sysname] ripng 1
[Sysname-ripng-1] timers update 5 timeout 15 suppress 15 garbage-collect 30
