03-Interface Command Reference
HomeSupportSwitchesS7500E SeriesReference GuidesCommand ReferencesH3C S7500E Switch Series Command References-Release7178-6W10003-Interface Command Reference
03-Loopback, null, and inloopback interface commands
bandwidth
Use bandwidth to configure the expected bandwidth of an interface.
bandwidth bandwidth-value
undo bandwidth
The expected bandwidth of a loopback interface is 0 kbps.
Loopback interface view
The expected bandwidth of an interface affects the link costs in OSPF, OSPFv3, and IS-IS. For more information, see Layer 3—IP Routing Configuration Guide.
# Set the expected bandwidth of Loopback 1 to 1000 kbps.
[Sysname] interface loopback 1
[Sysname-LoopBack1] bandwidth 1000
default
Use default to restore the default settings for an interface.
default
Loopback interface view, null interface view
CAUTION
CAUTION:
The default command might interrupt ongoing network services. Make sure you are fully aware of the impact of this command before using it on a live network.
This command might fail to restore the default settings for some commands for reasons such as command dependencies and system restrictions. Use the display this command in interface view to identify these commands, and then use their undo forms or follow the command reference to restore their default settings. If your restoration attempt still fails, follow the error message instructions to resolve the problem.
# Restore the default settings for loopback 1.
[Sysname-LoopBack1] default
description
The interface description uses the interface name Interface format, for example, LoopBack1 Interface.
text: Specifies the description, a case-sensitive string of 1 to 255 characters.
Configure a description for an interface for easy identification and management purposes.
You can use the display interface command to view the configured description.
# Configure the description of Loopback 1 as for RouterID.
[Sysname-LoopBack1] description for RouterID
display interface inloopback
Use display interface inloopback to display information about the inloopback interface.
display interface inloopback [ brief [ description | down ] ]
display interface inloopback [ 0 ] [ brief [ description ] ]
0: Specifies Inloopback 0.
description: Displays complete interface descriptions. If you do not specify this keyword, the command displays only the first 27 characters of interface descriptions. The description of an inloopback interface is always InLoopBack0 Interface and cannot be configured.
down: Displays information about interfaces in down state and the causes. If you do not specify this keyword, the command displays information about interfaces in all states.
The device has only one inloopback interface Inloopback 0. If you specify the inloopback keyword, the command displays information about the interface Inloopback 0 regardless of whether you specify the 0 keyword.
# Display detailed information about Inloopback 0.
<Sysname> display interface inloopback
InLoopBack0
Current state: UP
Line protocol state: UP(spoofing)
Description: InLoopBack0 Interface
Bandwidth: 0kbps
Maximum transmission unit: 1536
Physical: InLoopBack
Current state
Physical layer state of the interface, which is always UP, meaning that the inloopback interface can receive and transmit packets.
Line protocol state
Data link layer protocol state of the interface, which is always UP(spoofing). UP(spoofing) means that the data link layer protocol state of the interface is up, but the link is an on-demand link or is not present.
Description string of the interface, which is always InLoopBack0 Interface and cannot be configured.
Bandwidth
Expected bandwidth of the interface.
MTU of the interface, which is always 1536 and cannot be configured
The physical type of the interface is inloopback.
Last 300 seconds input:  0 bytes/sec, 0 bits/sec, 0 packets/sec
Average input rate during the last 300 seconds:
·     bytes/sec—Average number of bytes received per second.
·     bits/sec—Average number of bits received per second.
·     packets/sec—Average number of packets received per second.
Last 300 seconds output:  0 bytes/sec, 0 bits/sec, 0 packets/sec
Average output rate over the last 300 seconds:
·     bytes/sec—Average number of bytes sent per second.
·     bits/sec—Average number of bits sent per second.
·     packets/sec—Average number of packets sent per second.
Total number and size (in bytes) of incoming packets of the interface and the number of dropped packets.
Total number and size (in bytes) of outgoing packets of the interface and the number of dropped packets.
# Display brief information about Inloopback 0.
<Sysname> display interface inloopback 0 brief
Protocol: (s) - spoofing
Interface            Link Protocol Primary IP      Description
InLoop0              UP   UP(s)    --
Brief information about the inloopback interface.
Explains the Link field values:
·     ADM—The interface has been shut down by the network administrator. To recover its physical layer state, run the undo shutdown command.
·     Stby—The interface is a standby interface..
Explains the Protocol field value.
(s) represents spoofing. If the data link layer protocol of an interface is up, but its link is an on-demand link or is not present, the Protocol field displays UP(s). This attribute is typical of interface Null 0, Inloopback 0, and loopback interfaces.
Interface name.
Link
Physical layer state of the interface, which is always UP, meaning that the link is physically up.
Protocol
Data link layer protocol state of the interface, which is always UP(s).
Primary IP
IP address of the interface.
Because inloopback interfaces do not support CLI configuration, this field does not display a value.
Description of the interface. Because the inloopback interface does not support CLI configuration, this field does not display a value.
display interface loopback
Use display interface loopback to display information about the specified or all existing loopback interfaces.
display interface loopback [ brief [ description | down ] ]
display interface loopback [ interface-number ] [ brief [ description ] ]
interface-number: Specifies a loopback interface by its number, which can be the number of any existing loopback interface. If you do not specify this argument, the command displays information about all existing loopback interfaces on the device.
down: Displays information about interfaces in down state and the causes. If do not specify this keyword, the command displays information about interfaces in all states.
This command is supported only after a loopback interface is created.
# Display detailed information about Loopback 0.
<Sysname> display interface loopback 0
LoopBack0
Current state: UP
Description: LoopBack0 Interface
Bandwidth: 0kbps
Internet protocol processing: disabled
Physical: Loopback
Last clearing of counters:  Never
Current state
Physical layer state of the interface:
·     UP—The loopback interface can receive and transmit packets.
·     Administratively DOWN—The interface was manually shut down by using the shutdown command.
Line protocol state
Data link layer protocol state of the interface. UP (spoofing) means that the data link layer protocol state of the interface is up, but the link is an on-demand link or is not present.
Description string of the interface.
Bandwidth
MTU of the interface.
Indicates that the interface cannot process Layer 3 packets (displayed when the interface is not configured with an IP address).
Internet Address is 1.1.1.1/32 Primary
Primary IP address of the interface (displayed when the interface is configured with a primary IP address).
Physical: Loopback
The physical type of the interface is loopback.
Time when statistics on the logical interface were last cleared by using the reset counters interface command.
If the statistics of the interface have never been cleared by using the reset counters interface command since the device started, this field displays Never.
# Display brief information about all loopback interfaces.
<Sysname> display interface loopback brief
Loop0                UP   UP(s)    --              aaaaaaaaaaaaaaaaaaaaaaaaaaaaa
# Display brief information about all existing loopback interfaces, including the complete description of each loopback interface.
<Sysname> display interface loopback brief description
# Display information about all loopback interfaces in down state and the causes.
<Sysname> display interface loopback brief down
Loop1                ADM  Administratively
Brief information about loopback interfaces.
Interface name.
Link
·     UP—The interface is up.
·     DOWN—The interface is physically down.
·     ADM—The interface has been administratively shut down. To recover its physical state, run the undo shutdown command.
Protocol
Interface description configured by using the description command. If the description keyword is not specified in the display interface brief command, the Description field allows a maximum of 27 characters. If the description keyword is specified in the display interface brief command, the field displays the complete interface description.
Cause
Cause of the interface down event. If the interface has been shut down by using the shutdown command, this field displays Administratively. To restore the physical state of the interface, execute the undo shutdown command.
·     interface loopback
·     reset counters interface loopback
display interface null
Use display interface null to display information about the null interface.
display interface null [ brief [ description | down ] ]
display interface null [ 0 ] [ brief [ description ] ]
0: Specifies interface Null 0.
The device has only one null interface Null 0. If you specify the null keyword, the command displays information about the interface Null 0 regardless of whether you specify the 0 keyword.
# Display detailed information about Null 0.
<Sysname> display interface null 0
NULL0
Current state: UP
Description: NULL0 Interface
Bandwidth: 0kbps
Physical: NULL DEV
# Display brief information about Null 0.
<Sysname> display interface null 0 brief
NULL0                UP   UP(s)    --              aaaaaaaaaaaaaaaaaaaaaaaaaaa
# Display brief information about Null 0, including the complete description of the null interface.
<Sysname> display interface null 0 brief description
NULL0                UP   UP(s)    --              aaaaaaaaaaaaaaaaaaaaaaaaaaaaa
For the command output, see Table 3 and Table 4.
·     interface null
·     reset counters interface null
interface loopback
Use interface loopback to create a loopback interface and enter loopback interface view.
Use undo interface loopback to remove a loopback interface.
interface loopback interface-number
undo interface loopback interface-number
No loopback interface exists.
interface-number: Specifies a loopback interface by its number. The value range for the interface-number argument is 0 to 1023.
The physical layer state and link layer protocols of a loopback interface are always up unless the loopback interface is manually shut down. You can use a loopback interface to achieve the following purposes:
·     Prevent the connection from being affected by the physical state of the interface.
·     Improve the reliability of the connection.
For example, you can:
·     Configure a loopback interface as the source interface for establishing an FTP connection.
·     Use the loopback interface address as the Router ID in BGP.
# Create interface loopback 1.
[Sysname-LoopBack1]
interface null
Use interface null to enter null interface view.
interface null 0
A device has only one null interface (Null 0), which cannot be created or deleted.
0: Specifies interface Null 0. The null interface number is always 0.
# Enter Null 0 interface view.
[Sysname] interface null 0
[Sysname-NULL0]
Use reset counters interface loopback to clear the statistics on the specified or all loopback interfaces.
reset counters interface loopback [ interface-number ]
interface-number: Specifies a loopback interface by its number, which can be the number of any existing loopback interface. If you do not specify the interface-number argument, the command clears the statistics on all loopback interfaces.
To determine whether a loopback interface works correctly within a period by collecting the traffic statistics within that period, first use the reset counters interface [ loopback [ interface-number ] ] command to clear the statistics. Then have the interface automatically collect the statistics.
This command is available only if at least one loopback interface has been created.
# Clear the statistics on loopback interface Loopback 1.
<Sysname> reset counters interface loopback 1
Use reset counters interface null to clear the statistics on the null interface.
reset counters interface null [ 0 ]
0: Specifies the number of the null interface, which is always 0.
To determine whether the null interface works correctly within a period by collecting the traffic statistics within that period, first use the reset counters interface [ null [ 0 ] ] command to clear the statistics. Then have the interface automatically collect the statistics.
# Clear the statistics on interface Null 0.
<Sysname> reset counters interface null 0
shutdown
Use shutdown to shut down a loopback interface.
Use undo shutdown to bring up a loopback interface.
shutdown
A loopback interface is up.
Use the shutdown command with caution, because the command disconnects the connection of the interface and disables the interface from communicating.
# Shut down interface loopback 1.
[Sysname-LoopBack1] shutdown
