03-Interface Command Reference
HomeSupportSwitchesS7500E SeriesReference GuidesCommand ReferencesH3C S7500E Switch Series Command References-Release7178-6W10003-Interface Command Reference
02-Ethernet interface commands
02-Ethernet interface commands 196.87 KB
Common Ethernet interface commands
bandwidth
Use bandwidth to configure the expected bandwidth of an interface.
bandwidth bandwidth-value
undo bandwidth
Ethernet interface view
The expected bandwidth of an interface affects the link costs in OSPF, OSPFv3, and IS-IS. For more information, see Layer 3—IP Routing Configuration Guide.
# Set the expected bandwidth of interface GigabitEthernet 1/0/1 to 1000 kbps.
[Sysname-GigabitEthernet1/0/1] bandwidth 1000
speed
combo enable
Use combo enable to activate the copper or fiber combo port of a combo interface.
combo enable { copper | fiber }
The fiber combo port of a combo interface is activated.
copper: Activates the copper combo port. In this case, use twisted pairs to connect the port.
fiber: Activates the fiber combo port. In this case, use optical fibers to connect the port.
A combo interface is a logical interface that physically contains one fiber combo port and one copper combo port on the device panel. The two ports share one forwarding interface. As a result, they cannot work simultaneously. When you activate either port, the other port is automatically disabled. You can select to activate the copper combo port or fiber combo port.
Before using this command, perform the following tasks according to the marks on the device panel:
·     Determine the combo interfaces on your device.
·     Identify the two physical interfaces that belong to each combo interface.
# Activate the copper combo port of combo interface GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] combo enable copper
# Activate the fiber combo port of combo interface GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] combo enable fiber
default
Use default to restore the default settings for an Ethernet interface.
default
CAUTION
CAUTION:
The default command might interrupt ongoing network services. Make sure you are fully aware of the impacts of this command when you use it in a live network.
This command might fail to restore the default settings for some commands because of command dependencies or system restrictions. You can use the display this command in interface view to identify these commands, and use their undo forms or follow the command reference to restore their default settings. If your restoration attempt still fails, follow the error message instructions to solve the problem.
# Restore the default settings for interface GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] default
description
Use description to change the description of an interface.
The description of an interface is the interface name plus Interface (for example, GigabitEthernet1/0/1 Interface).
text: Specifies the interface description, a case-sensitive string of 1 to 255 characters.
# Change the description of interface GigabitEthernet 1/0/1 to lan-interface.
[Sysname-GigabitEthernet1/0/1] description lan-interface
display counters
Use display counters to display interface traffic statistics.
display counters { inbound | outbound } interface [ interface-type [ interface-number ] ]
inbound: Displays inbound traffic statistics.
outbound: Displays outbound traffic statistics.
This command displays traffic statistics within a statistics polling interval specified by using the flow-interval command.
To clear the Ethernet interface traffic statistics, use the reset counters interface command.
If you do not specify an interface type, this command displays traffic statistics for all interfaces that have traffic counters.
If you specify an interface type but do not specify an interface number, this command displays traffic statistics for all interfaces of the specified type.
If you specify an interface type and an interface number, this command displays traffic statistics for the specified interface.
# Display inbound traffic statistics for all Ethernet interfaces.
<Sysname> display counters inbound interface gigabitEthernet
Interface            Total (pkts)    Broadcast (pkts)    Multicast (pkts)  Err (pkts)
GE1/0/1                       100                 100                   0           0
GE1/0/2                         0                   0                   0           0
GE1/0/3                  Overflow            Overflow            Overflow    Overflow
GE1/0/4                         0                   0                   0           0
 Overflow: More than 14 digits (7 digits for column "Err").
       --: Not supported.
Abbreviated interface name.
Total (pkts)
Total number of packets received or sent through the interface.
Broadcast (pkts)
Total number of broadcast packets received or sent through the interface.
Multicast (pkts)
Total number of multicast packets received or sent through the interface.
Err (pkts)
Total number of error packets received or sent through the interface.
The command displays Overflow when any of the following conditions exist:
·     The data length of an Err field value is greater than 7 decimal digits.
·     The data length of a non-Err field value is greater than 14 decimal digits.
--: Not supported
The statistical item is not supported.
·     flow-interval
·     reset counters interface
display counters rate
Use display counters rate to display traffic rate statistics for interfaces in up state over the last statistics polling interval.
display counters rate { inbound | outbound } interface [ interface-type [ interface-number ] ]
inbound: Displays inbound traffic rate statistics.
outbound: Displays outbound traffic rate statistics.
If you do not specify an interface type, this command displays traffic rate statistics for all up interfaces that have traffic counters over the last statistics polling interval.
If you specify an interface type, this command displays traffic rate statistics for all up interfaces of the specified type over the last statistics polling interval.
If an interface that you specify is always down over the last statistics polling interval, the system prompts that the interface does not support the command.
You can use the flow-interval command to set the statistics polling interval.
# Display the inbound traffic rate statistics for all GigabitEthernet interfaces.
<Sysname> display counters rate inbound interface gigabitethernet
Usage: Bandwidth utilization in percentage
Interface             Usage   Total (pps)    Broadcast (pps)    Multicast (pps)
GE3/0/1                 0%             0                 --                 --
GE3/0/3                 0%             0                 --                 --
GE3/0/6                 0%             0                 --                 --
 Overflow: More than 14 digits.
       --: Not supported.
Usage
Bandwidth utilization.
Total (pkts/sec)
Average receiving or sending rate (in pps) for unicast packets over the last statistics polling interval.
Broadcast (pkts/sec)
Average receiving or sending rate (in pps) for broadcast packets over the last statistics polling interval.
Multicast (pkts/sec)
Average receiving or sending rate (in pps) for multicast packets over the last statistics polling interval.
Overflow: more than 14 decimal digits
The command displays Overflow if the data length of a statistical item is greater than 14 decimal digits.
--: not supported
·     flow-interval
display ethernet statistics
Use display ethernet statistics to display the Ethernet module statistics.
In standalone mode:
display ethernet statistics slot slot-number
In IRF mode:
display ethernet statistics chassis chassis-number slot slot-number
slot slot-number: Specifies a card by its slot number. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device or specifies a PEX. The chassis-number argument represents the ID of the IRF member device or the virtual chassis number of the PEX. The slot-number argument represents the slot number of the card or PEX. (In IRF mode.)
# (In standalone mode.) Display the Ethernet module statistics for the card in slot 7.
<Sysname> display ethernet statistics slot 7
ETH receive packet statistics:
    Totalnum        : 22582          ETHIINum     : 22582
    SNAPNum         : 0              RAWNum       : 0
    LLCNum          : 0              UnknownNum   : 0
    ForwardNum      : 22581          ARP          : 0
    MPLS            : 0              ISIS         : 0
    ISIS2           : 0              IP           : 0
    IPV6            : 0
ETH receive error statistics:
    NullPoint       : 0              ErrIfindex   : 0
    ErrIfcb         : 0              IfShut       : 1
    ErrAnalyse      : 0              ErrSrcMAC    : 0
    ErrHdrLen       : 0
ETH send packet statistics:
    L3OutNum        : 3034           VLANOutNum   : 0
    FastOutNum      : 427            L2OutNum     : 0
ETH send error statistics:
    MbufRelayNum    : 0              NullMbuf     : 0
    ErrAdjFwd       : 0              ErrPrepend   : 0
    ErrHdrLen       : 0              ErrPad       : 0
    ErrQosTrs       : 0              ErrVLANTrs   : 0
    ErrEncap        : 0              ErrTagVLAN   : 0
    IfShut          : 0              IfErr        : 0
# (In IRF mode.) Display the Ethernet module statistics for the card in slot 7 of IRF member device 1.
<Sysname> display ethernet statistics chassis 1 slot 7
    MPLS            : 0              ISIS         : 0
    ISIS2           : 0              IP           : 0
    IPV6            : 0
    ErrHdrLen       : 0
Table 3 Output description
Statistics about the Ethernet packets received on the Ethernet module.
Totalnum
Total number of received packets:
·     ETHIINum—Number of packets encapsulated by using Ethernet II.
·     SNAPNum—Number of packets encapsulated by using SNAP.
·     RAWNum—Number of packets encapsulated by using RAW.
·     ISIS—Number of packets encapsulated by using IS-IS.
·     LLCNum—Number of packets encapsulated by using LLC.
·     UnknownNum—Number of packets encapsulated by using unknown methods.
·     ForwardNum—Number of packets forwarded at Layer 2 or sent to the CPU.
·     ARP—Number of ARP packets.
·     MPLS—Number of MPLS packets.
·     ISIS—Number of IS-IS packets.
·     ISIS2—Number of large 802.3/802.2 frames encapsulated by using IS-IS.
·     IP—Number of IP packets.
·     IPv6—Number of IPv6 packets.
Statistics about the error Ethernet packets in the outbound direction on the Ethernet module. Errors might be included in packets or occur during the receiving process. The items include:
·     NullPoint—Number of packets that include null pointers.
·     ErrIfindex—Number of packets that include incorrect interface indexes.
·     ErrIfcb—Number of packets that include incorrect interface control blocks.
·     IfShut—Number of packets that are being received when the interface is shut down.
·     ErrAnalyse—Number of packets that include packet parsing errors.
·     ErrSrcMAC—Number of packets that include incorrect source MAC addresses.
·     ErrHdrLen—Number of packets that include header length errors.
Statistics about the Ethernet packets sent by the Ethernet module:
·     L3OutNum—Number of packets sent out of Layer 3 Ethernet interfaces.
·     VLANOutNum—Number of packets sent out of VLAN interfaces.
·     FastOutNum—Number of packets fast forwarded.
·     L2OutNum—Number of packets sent out of Layer 2 Ethernet interfaces.
·     MbufRelayNum—Number of packets transparently sent.
Statistics about the error Ethernet packets in the outbound direction on the Ethernet module:
·     NullMbuf—Number of packets with null pointers.
·     ErrAdjFwd—Number of packets with adjacency table errors.
·     ErrPrepend—Number of packets with extension errors.
·     ErrHdrLen—Number of packets with header length errors.
·     ErrPad—Number of packets with padding errors.
·     ErrQoSTrs—Number of packets that failed to be sent by QoS.
·     ErrVLANTrs—Number of packets that failed to be sent in VLANs.
·     ErrEncap—Number of packets that failed to be sent due to link header encapsulation failures.
·     ErrTagVLAN—Number of packets that failed to be sent due to VLAN tag encapsulation failures.
·     IfShut—Number of packets that are being sent when the interface is shut down.
·     IfErr—Number of packets with incorrect outgoing interfaces.
reset ethernet statistics
display interface
Use display interface to display interface information.
display interface [ interface-type ] [ brief [ down ] ]
display interface [ interface-type [ interface-number ] ] [ brief [ description ] ]
down: Displays information about interfaces in down state and the causes. If you do not specify this keyword, the command displays information about interfaces in all states.
If you do not specify an interface type, this command displays information about all interfaces.
If you specify an interface type but do not specify an interface number, this command displays information about all interfaces of that type.
If you specify both the interface type and interface number, this command displays information about the specified interface.
# Display information about Layer 3 interface GigabitEthernet 3/0/1.
<Sysname> display interface gigabitethernet3/0/1
GigabitEthernet3/0/1
Current state: UP
Line protocol state: UP
Description: GigabitEthernet3/0/1 Interface
Bandwidth: 1000000 kbps
IP packet frame type: PKTFMT_ETHNT_2, hardware address: 0000-fc00-2501
IPv6 packet frame type: PKTFMT_ETHNT_2, hardware address: 0000-fc00-2501
Loopback is not set
Media type is twisted pair, port hardware type is 1000_BASE_T
Port priority: 0
1000Mbps-speed mode, full-duplex mode
Flow-control is not enabled
Maximum frame length: 9216
Last link flapping: Never
 Peak input rate: 0 bytes/sec, at 2014-12-12 09:24:49
 Peak output rate: 0 bytes/sec, at 2014-12-12 09:24:49
 Last 300 second input: 0 packets/sec 0 bytes/sec 0%
 Last 300 second output: 0 packets/sec 0 bytes/sec 0%
 Input (total):  0 packets, 0 bytes
 Input (normal):  0 packets, - bytes
          0 CRC, 0 frame, - overruns, 0 aborts
          - ignored, - parity errors
 Output (normal): 0 packets, - bytes
          0 lost carrier, - no carrier
# Display detailed information about Layer 2 interface GigabitEthernet 3/0/1.
<Sysname> display interface gigabitethernet 3/0/1
Current state: UP
IP packet frame type: Ethernet II, hardware address: 0000-fc00-2500
Loopback is not set
Allow jumbo frames to pass
Broadcast max-ratio: 100%
Multicast max-ratio: 100%
Unicast max-ratio: 100%
PVID: 1
MDI type: Automdix
Port link-type: Access
 Tagged VLANs:   None
 Untagged VLANs: 1
Port priority: 0
 Peak input rate: 8 bytes/sec, at 2014-12-12 08:58:43
 Peak output rate: 9 bytes/sec, at 2014-12-12 08:58:58
 Last 300 second input: 0 packets/sec 8 bytes/sec 0%
 Last 300 second output: 0 packets/sec 8 bytes/sec 0%
 Input (total):  136 packets, 11116 bytes
          0 unicasts, 2 broadcasts, 134 multicasts, 0 pauses
 Input (normal):  136 packets, - bytes
 Output (total): 139 packets, 11326 bytes
          0 unicasts, 4 broadcasts, 135 multicasts, 0 pauses
 Output (normal): 139 packets, - bytes
Current state
State of the interface:
·     Administratively DOWN—The interface was shut down with the shutdown command.
·     DOWN—The interface is administratively up but physically down. There might not be a physical link present or the link has failed.
·     UP—The interface is both administratively and physically up.
Line protocol state
Data link layer state of the interface. The state is determined through parameter negotiation at the data link layer.
·     UP—The interface is up at the data link layer.
·     UP (spoofing)—The data link layer protocol of the interface is UP. However, its link is an on-demand link or not present. This attribute is typical of Null interfaces and loopback interfaces.
·     DOWN—The data link layer protocol of the interface is down.
·     DOWN (protocol)—The data link layer of the interface is shut down by one or more protocols. The protocol argument can be an arbitrary combination of these protocols: DLDP, OAM, LAGG, BFD, and MACSEC.
¡     When protocol contains DLDP, the data link layer of the interface is down because DLDP detected that the link was unidirectional.
¡     When protocol contains OAM, the data link layer of the interface is down because OAM detected remote link failures.
¡     When protocol contains LAGG, the data link layer of the interface is down because the aggregate interface does not have Selected ports.
¡     When protocol contains BFD, the data link layer of the interface is down because BFD detected a link failure.
¡     When protocol contains MACSEC, the data link layer of the interface is down because MACSEC failed to negotiate the encryption parameters.
Bandwidth
Expected bandwidth of the interface.
MTU of the interface.
The interface cannot process IP packets.
Internet address: 192.168.1.200/24 (primary)
Primary IP address of the interface.
Ethernet framing format. PKTFMT_ETHNT_2 indicates that the frames are encapsulated in Ethernet II framing format.
hardware address
MAC address of the interface.
IPv6 packet framing format.
Loopback is set internal
An internal loopback test is running on the interface.
Loopback is set external
An external loopback test is running on the interface.
Loopback is not set
No loopback test is running on the interface.
10Mbps-speed mode
The interface is operating at 10 Mbps.
100Mbps-speed mode
The interface is operating at 100 Mbps.
1000Mbps-speed mode
The interface is operating at 1000 Mbps.
10Gbps-speed mode
The interface is operating at 10 Gbps.
40Gbps-speed mode
The interface is operating at 40 Gbps.
Unknown-speed mode
The speed of the interface is unknown because the speed negotiation fails or the interface is physically disconnected.
half-duplex mode
The interface is operating in half duplex mode.
full-duplex mode
The interface is operating in full duplex mode.
unknown-duplex mode
The duplex mode of the interface is unknown because the duplex mode negotiation fails or the interface is physically disconnected.
The interface is configured with the speed auto command.
Link speed type is force link
The interface is manually configured with a speed (for example, 10 Mbps or 100 Mbps) by using the speed command.
The interface is configured with the duplex auto command.
link duplex type is force link
The interface is manually configured with a duplex mode (for example, half or full) by using the duplex command.
Generic flow control is disabled on the interface.
Maximum length of Ethernet frames allowed to pass through the interface.
Last link flapping
The amount of time that has elapsed since the most recent physical state change of the interface. This field displays Never if the interface has been physically down since device startup.
Allow jumbo frame to pass
The interface allows jumbo frames to pass through.
Broadcast max-
Broadcast suppression threshold in ratio, pps, or kbps. The unit of the threshold depends on your configuration.
Multicast max-
Multicast suppression threshold in ratio, pps, or kbps. The unit of the threshold depends on your configuration.
Unicast max-
Unknown unicast suppression threshold in ratio, pps, or kbps. The unit of the threshold depends on your configuration.
PVID
Port VLAN ID (PVID) of the interface.
MDI type
MDIX mode of the interface:
·     Automdix.
·     Mdi.
·     Mdix.
Port link-type
Link type of the interface:
·     Access.
·     Trunk.
·     Hybrid.
Tagged VLANs
VLANs for which the interface sends packets without removing VLAN tags.
Untagged VLANs
VLANs for which the interface sends packets after removing VLAN tags.
Port priority
Priority of the interface.
Last 300 seconds input:  0 packets/sec 0 bytes/sec 0%
Last 300 seconds output:  0 packets/sec 0 bytes/sec 0%
Average inbound or outbound traffic rate (in pps and Bps) in the last 300 seconds, and the ratio of the actual rate to the interface bandwidth.
A hyphen (-) indicates that the statistical item is not supported.
Input(total):  0 packets, 0 bytes
The two fields on the first line represent the inbound traffic statistics (in packets and bytes) for the interface. All inbound normal packets, abnormal packets, and normal pause frames were counted.
The four fields on the second line represent:
·     Number of inbound unicast packets.
·     Number of inbound broadcasts.
·     Number of inbound multicasts.
·     Number of inbound pause frames.
Input(normal):  0 packets, 0 bytes
The two fields on the first line represent the inbound normal traffic and pause frame statistics (in packets and bytes) for the interface.
·     Number of inbound normal unicast packets.
·     Number of inbound normal broadcasts.
·     Number of inbound normal multicasts.
·     Number of inbound normal pause frames.
input errors
Statistics of incoming error packets.
runts
Number of inbound frames meeting the following conditions:
·     Shorter than 64 bytes.
·     In correct format.
·     Containing valid CRCs.
giants
Number of inbound giants. Giants refer to frames larger than the maximum frame length supported on the interface.
For an Ethernet interface that does not permit jumbo frames, the maximum frame length is as follows:
·     1518 bytes (without VLAN tags).
·     1522 bytes (with VLAN tags).
For an Ethernet interface that permits jumbo frames, the maximum Ethernet frame length is configured when you configure jumbo frame support on the interface.
throttles
Number of inbound frames that had a non-integer number of bytes.
CRC
Total number of inbound frames that had a normal length, but contained CRC errors.
frame
Total number of inbound frames that contained CRC errors and a non-integer number of bytes.
overruns
Number of packets dropped because the input rate of the port exceeded the queuing capability.
aborts
Total number of illegal inbound packets:
·     Fragment frames—CRC error frames shorter than 64 bytes. The length (in bytes) can be an integral or non-integral value.
·     Jabber frames—CRC error frames greater than the maximum frame length supported on the Ethernet interface (with an integral or non-integral length).
¡     For an Ethernet interface that does not permit jumbo frames, the maximum frame length is 1518 bytes (without VLAN tags) or 1522 bytes (with VLAN tags).
¡     For an Ethernet interface that permits jumbo frames, the maximum Ethernet frame length is configured when you configure jumbo frame support on the interface.
·     Symbol error frames—Frames that contained at least one undefined symbol.
·     Unknown operation code frames—Non-pause MAC control frames.
·     Length error frames—Frames whose 802.3 length fields did not match the actual frame length (46 to 1500 bytes).
ignored
Number of inbound frames dropped because the receiving buffer of the port ran low.
parity errors
Total number of frames with parity errors.
Output(total): 0 packets, 0 bytes
The two fields on the first line represent the outbound traffic statistics (in packets and bytes) for the interface. All outbound normal packets, abnormal packets, and normal pause frames were counted.
·     Number of outbound unicast packets.
·     Number of outbound broadcasts.
·     Number of outbound multicasts.
·     Number of outbound pause frames.
Output(normal): 0 packets, 0 bytes
The two fields on the first line represent the outbound normal traffic and pause frame statistics (in packets and bytes) for the interface.
·     Number of outbound normal unicast packets.
·     Number of outbound normal broadcasts.
·     Number of outbound normal multicasts.
·     Number of outbound normal pause frames.
output errors
Number of outbound packets with errors.
underruns
Number of packets dropped because the output rate of the interface exceeded the output queuing capability. This is a low-probability hardware anomaly.
buffer failures
Number of packets dropped because the transmitting buffer of the interface ran low.
aborts
Number of packets that failed to be transmitted, for example, because of Ethernet collisions.
deferred
Number of frames that the interface deferred to transmit because of detected collisions.
collisions
Number of frames that the interface stopped transmitting because Ethernet collisions were detected during transmission.
late collisions
Number of frames that the interface deferred to transmit after transmitting their first 512 bits because of detected collisions.
lost carrier
Number of carrier losses during transmission. This counter increases by one when a carrier is lost, and applies to serial WAN interfaces.
no carrier
Number of times that the port failed to detect the carrier when attempting to send frames. This counter increases by one when a port failed to detect the carrier, and applies to serial WAN interfaces.
Peak input rate
Peak rate of inbound traffic in Bps, and the time when the peak inbound traffic rate occurred.
Peak output rate
Peak rate of outbound traffic in Bps, and the time when the peak outbound traffic rate occurred.
# Display brief information about all interfaces.
Protocol: (s) – spoofing
GE1/0/1              UP   UP       10.1.1.2           Link to CoreRouter
GE1/0/2              DOWN DOWN     --
Loop0                UP   UP(s)    2.2.2.9
NULL0                UP   UP(s)    --
Vlan1                UP   DOWN     --
Vlan999              UP   UP       192.168.1.42
Speed: (a) - auto
GE1/0/2              DOWN auto    A      A    1
GE1/0/3              UP   100M(a) F(a)   A    1    aaaaaaaaaaaaaaaaaaaaaaaaaaa
GE1/0/4              DOWN auto    A      A    1
GE1/0/5              DOWN auto    A      A    1
GE1/0/6              UP   100M(a) F(a)   A    1
GE1/0/7              DOWN auto    A      A    1
GE1/0/8              UP   100M(a) F(a)   A    1
GE1/0/9              UP   100M(a) F(a)   A    999
# Display brief information about interface GigabitEthernet 1/0/3, including the complete description of the interface.
<Sysname> display interface gigabitethernet 1/0/3 brief description
Speed: (a) - auto
GE1/0/3              UP   100M(a) F(a)   A    1    test
# Display information about interfaces in DOWN state and the causes.
GE1/0/1              DOWN Not connected
GE1/0/2              DOWN Not connected
GE1/0/4              DOWN Not connected
GE1/0/5              DOWN Not connected
GE1/0/7              DOWN Not connected
Table 5 Command output
Brief information about Layer 3 interfaces.
Link status:
·     ADM—The interface has been shut down by the network administrator. To recover its physical layer state, use the undo shutdown command.
·     Stby—The interface is operating as a backup interface. To see the primary interface, use the display interface-backup state command.
This field displays UP (s), where s represents the spoofing flag, when the following conditions exist:
·     The data link layer protocol of the interface is UP.
·     The link of the interface is an on-demand link or not present.
This attribute is typical of interface Null 0 and loopback interfaces.
Interface name.
Link
Physical link state of the interface:
·     UP—The interface is physically up.
·     DOWN—The interface is physically down.
·     ADM—The interface has been administratively shut down. To bring up the interface, use the undo shutdown command.
·     Stby—The interface is a standby interface.
Protocol
Data link layer protocol state of the interface:
·     UP—The data link layer protocol of the interface is up.
·     UP(s)—The data link layer protocol of the interface is up. However, the link is an on-demand link or not present. This value is typical of interface Null 0 and loopback interfaces.
Primary IP
Primary IP address of the interface. A hyphen (-) indicates that the interface is not configured with an IP address.
Partial or complete interface description configured by using the description command:
·     If you do not specify the description keyword for the display interface brief command, this field displays only the first 27 characters of the interface description.
·     If you specify the description keyword for the display interface brief command, this field displays the complete interface description.
Brief information about Layer 2 interfaces.
Speed: (a) - auto
If the speed of an interface is automatically negotiated, the speed attribute of the interface includes the autonegotiation flag (the letter a in parentheses).
If an interface is configured to autonegotiate its speed but the autonegotiation has not started, its speed attribute is displayed as auto.
Duplex: (a)/A - auto; H - half; F – full
If the duplex mode of an interface is automatically negotiated, the duplex mode attribute of the interface includes the letter a in parentheses. H indicates the half duplex mode. F indicates the full duplex mode.
If an interface is configured to autonegotiate its duplex mode but the autonegotiation has not started, its duplex mode attribute is displayed as A.
Type: A - access; T - trunk; H – hybrid
Link type options for interfaces.
Speed
Interface rate, in bps.
Duplex
Duplex mode of the interface:
·     A—Autonegotiation.
·     F—Full duplex.
·     F(a)—Autonegotiated full duplex.
·     H—Half duplex.
·     H(a)—Autonegotiated half duplex.
·     A—Access.
·     H—Hybrid.
·     T—Trunk.
PVID
Port VLAN ID.
Cause
Cause for the physical link state of an interface to be DOWN:
·     Administratively—The interface is manually shut down by using the shutdown command. To restore the physical state of the interface, use the undo shutdown command.
·     DOWN ( Link-Aggregation interface down )—The interface is a member port of an aggregate interface, and the aggregate interface is shut down.
·     DOWN (Loopback detection down)—The interface is shut down because the loopback detection module has detected loops.
·     DOWN ( Monitor-Link uplink down )—The interface is shut down because the monitor link module has detected that the uplink is down.
·     IRF-link-down—When IRF detects that the IRF link is down on an MDC of a member device, the physical interfaces except the excluded ports on the MDC are physically down.
·     MAD ShutDown—After an IRF split, all interfaces except the excluded ports in the IRF in recovery state are physically down.
·     Not connected—The interface is down because no physical connection exists (possibly because the network cable is disconnected or faulty).
·     Storm-Constrain—The interface is shut down because the unknown unicast traffic, multicast traffic, or broadcast traffic exceeds the upper threshold.
·     STP DOWN—The interface is shut down by the STP BPDU guard function.
·     Port Security Disabled—The interface is shut down by the intrusion detection mechanism because the port receives illegal packets.
·     Standby—The interface is in Standby state.
display packet-drop
Use display packet-drop to display information about packets dropped on an interface or multiple interfaces.
display packet-drop { interface [ interface-type [ interface-number ] ] | summary }
interface-type: Specifies an interface type. If you do not specify an interface type, this command displays information about dropped packets on all interfaces on the device.
interface-number: Specifies an interface number. If you specify an interface type only, this command displays information about dropped packets on the specified type of interfaces.
summary: Displays the summary of dropped packets on all interfaces.
# Display information about dropped packets on GigabitEthernet 1/0/1.
<Sysname> display packet-drop interface gigabitethernet 1/0/1
GigabitEthernet1/0/1:
Packets dropped due to full GBP or insufficient bandwidth: 301
Packets dropped due to Fast Filter Processor FFP: 261
Packets dropped due to STP non-forwarding state: 321
# Display the summary of dropped packets on all interfaces.
<Sysname> display packet-drop summary
All interfaces:
  Packets dropped due to FFP: 261
Table 6 Command output
Packets that are dropped because the buffer is used up or the bandwidth is insufficient.
Packets that are filtered out.
Packets that are dropped because STP is in the non-forwarding state.
duplex
Use duplex to set the duplex mode for an Ethernet interface.
Use undo duplex to restore the default.
duplex { auto | full | half }
undo duplex
10-GE, 40-GE interfaces operate in full duplex mode, and all other types of Ethernet interfaces operate in autonegotiation mode.
auto: Configures the interface to autonegotiate the duplex mode with the peer.
full: Configures the interface to operate in full duplex mode. In this mode, the interface can receive and transmit packets simultaneously.
half: Configures the interface to operate in half duplex mode. In this mode, the interface can only receive or transmit packets at a given time.
Copper ports on LSQM2GT24PTSSC0, LSQM2GT24TSSC0, LSQM2GT48SC0, LSQM4GV48SC0, and LSQM2GT48SA0 interface modules or fiber ports do not support the half duplex mode.
For Ethernet interfaces connected to the same cable to operate correctly, you must configure the same duplex mode for them.
# Configure interface GigabitEthernet 1/0/1 to operate in full duplex mode.
[Sysname-GigabitEthernet1/0/1] duplex full
eee enable
Use eee enable to enable Energy Efficient Ethernet (EEE) on an interface.
Use undo eee enable to restore the default.
eee enable
undo eee enable
EEE is disabled.
This command is applicable only to copper ports on the following interface modules:
·     SA interface module: LSQM2GT48SA0.
·     SC interface modules:
¡     LSQM2GT24PTSSC0.
¡     LSQM2GT24TSSC0.
¡     LSQM4GV48SC0.
¡     LSQM2GT48SC0.
For this command to take effect on an interface, configure the interface to automatically negotiate a speed or duplex mode with the remote end.
With EEE enabled, a link-up interface enters low power state if it has not received any packet for a period of time. The time period depends on the chip specifications and is not configurable. When a packet arrives later, the interface restores to the normal state.
# Enable EEE on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] eee enable
flow-control
IMPORTANT
IMPORTANT:
·     This command is not applicable to interfaces that operate in half duplex mode.
·     Configuring the flow-control or undo flow-control command on an interface will cause the interface to go down and then come up.
Use flow-control to enable TxRx-mode generic flow control on an Ethernet interface.
Use undo flow-control to disable generic flow control on the Ethernet interface.
flow-control
undo flow-control
Generic flow control is disabled on an Ethernet interface.
With TxRx-mode generic flow control configured, an interface can both send and receive flow control frames.
·     When congested, the interface sends a flow control frame to its peer.
·     Upon receiving a flow control frame from the peer, the interface suspends sending packets.
To implement flow control on a link, enable generic flow control at both ends of the link.
# Enable TxRx-mode generic flow control on the interface GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] flow-control
flow-control receive enable
IMPORTANT
IMPORTANT:
·     Configuring the flow-control receive enable or undo flow-control command on an interface will cause the interface to go down and then come up.
Use flow-control receive enable to enable Rx-mode generic flow control on an Ethernet port.
Use undo flow-control to disable generic flow control on an Ethernet interface.
undo flow-control
Rx-mode flow control is disabled on Ethernet interfaces.
With Rx-mode flow control enabled, an interface can receive but cannot send flow control frames.
·     Upon receiving a flow control frame from the peer, the interface suspends sending packets to the peer.
·     When congested, the interface cannot send flow control frames to the peer.
To handle unidirectional traffic congestion on a link, configure the flow-control receive enable command at one end, and configure the flow-control command at the other. To enable both ends of the link to handle traffic congestion, configure the flow-control command at both ends.
# Enable Rx-mode generic flow control on GigabitEthernet 1/0/1.
[Sysname-gigabitethernet 1/0/1] flow-control receive enable
flow-control
flow-interval
Use flow-interval to set the statistics polling interval.
Use undo flow-interval to restore the default.
flow-interval interval
undo flow-interval
The statistics polling interval is 300 seconds.
interval: Sets the statistics polling interval, in seconds. The interval is in the range of 5 to 300 and must be a multiple of 5.
# Set the statistics polling interval to 100 seconds on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] flow-interval 100
interface
Use interface to enter interface view.
# Enter GigabitEthernet 1/0/1 interface view.
jumboframe enable
Use jumboframe enable to allow jumbo frames within the specified length to pass through.
Use undo jumboframe enable to prevent jumbo frames from passing through.
jumboframe enable [ value ]
The device allows jumbo frames within 9216 bytes to pass through.
Layer 2 Ethernet interface view, Layer 3 Ethernet interface view
value: Sets the maximum length of Ethernet frames that are allowed to pass through. The value range for this argument is 1536 to 9216.
If you set the value argument multiple times, the most recent configuration takes effect.
# Allow jumbo frames to pass through GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] jumboframe enable
link-delay
Use link-delay to set the physical state change suppression interval on an Ethernet interface.
Use undo link-delay to restore the default.
link-delay [ msec ] delay-time [ mode { up | updown } ]
undo link-delay
Physical state change suppression is disabled.
msec: Enables the physical state change suppression interval to be accurate to milliseconds. If you do not specify this keyword, the suppression interval is accurate to seconds.
delay-time: Sets the physical state change suppression interval on the Ethernet interface. A value of 0 means that physical state changes are immediately reported to the CPU and are not suppressed.
·     If you do not specify the msec keyword, the value range is 0 to 30 seconds.
·     If you specify the msec keyword, the value range is 0 to 10000 milliseconds, and the value must be a multiple of 100.
mode up: Suppresses the link-up events.
mode updown: Suppresses both the link-up and link-down events.
You can configure this feature to suppress only link-down events, only link-up events, or both. If an event of the specified type still exists when the suppression interval expires, the system reports the event.
When you configure this feature, follow these guidelines:
·     To suppress only link-down events, configure the link-delay [ msec ] delay-time command.
·     To suppress only link-up events, configure the link-delay [ msec ] delay-time mode up command.
·     To suppress both link-down and link-up events, configure the link-delay [ msec ] delay-time mode updown command.
On an interface, you can configure different suppression intervals for link-up and link-down events. If you configure the link-delay command multiple times for link-up or link-down events, the most recent configuration takes effect.
Do not configure this command on an interface with RRPP, MSTP, or Smart Link enabled.
# Set the link-down event suppression interval to 8 seconds on interface GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] link-delay 8
# Set the link-up event suppression interval to 800 milliseconds on interface GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] link-delay msec 800 mode up
loopback
CAUTION
CAUTION:
After you enable loopback testing on an Ethernet interface, the interface does not forward data traffic.
IMPORTANT
IMPORTANT:
This command is used only for debugging and troubleshooting.
Use loopback to enable loopback testing on an Ethernet interface.
Use undo loopback to disable loopback testing on an Ethernet interface.
undo loopback
Loopback testing is disabled on an Ethernet interface.
external: Enables external loopback testing on the Ethernet interface. 10-GE and 40-GE interfaces on an LSQM1SRP8X2QE0 MPU do not support this keyword.
internal: Enables internal loopback testing on the Ethernet interface.
You cannot enable loopback testing on an administratively shut down Ethernet interface (displayed as in ADM or Administratively DOWN state).
After you enable loopback testing on an Ethernet interface, the speed, duplex, mdix-mode, port up-mode, and shutdown commands are not available on the Ethernet interface.
After you enable loopback testing on an Ethernet interface, the Ethernet interface switches to full duplex mode. After you disable loopback testing, the Ethernet interface restores to its duplex setting.
Do not configure both this command and the voice-vlan vlan-id enable, mac-address max-mac-count count, undo mac-address mac-learning enable, dot1x, or mac-authentication command on an interface. Otherwise, these commands cannot take effect. To enable these commands to take effect, configure the undo loopback command and then these commands again.
# Enable internal loopback testing on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] loopback internal
port link-mode
Use port link-mode to change the link mode of an Ethernet interface.
Use undo port link-mode to restore the default.
undo port link-mode
An Ethernet interface operates in bridge mode.
bridge: Specifies the Layer 2 mode.
route: Specifies the Layer 3 mode.
An Ethernet interface can operate in either of the following modes:
·     bridge—The Ethernet interface operates as an Layer 2 interface.
·     route—The Ethernet interface operates as an Layer 3 interface.
This command is not applicable to IRF ports, internal interfaces on an LSQ OAP module, reflector ports of a remote source group. For more information about internal interfaces on an OAP module, see OAA Configuration Guide. For more information about reflector ports, see Network Management and Monitoring Configuration Guide.
Changing the link mode of an Ethernet interface also restores all commands (except shutdown and combo enable) on the Ethernet interface to their defaults in the new link mode.
# Configure GigabitEthernet 1/0/1 to operate in Layer 2 mode.
[Sysname-GigabitEthernet1/0/1] port link-mode bridge
port up-mode
CAUTION
CAUTION:
The following operations on a fiber port will cause link-down and link-up events before the port finally stays up:
·     Configure both the port up-mode command and the speed or duplex command.
·     Install or remove fibers or transceiver modules after you forcibly bring up the fiber port.
Use port up-mode to forcibly bring up a fiber port.
Use undo port up-mode to restore the default.
port up-mode
undo port up-mode
A fiber Ethernet port is not forcibly brought up. The physical state of a fiber port depends on the physical state of the fibers.
This command forcibly brings up a fiber Ethernet port and enables the port to forward packets unidirectionally over a single link. In this way, transmission links are well utilized.
Only GE, 10-GE, 40-GE fiber ports support this command. Copper ports and combo ports do not support this command.
The port up-mode command is mutually exclusive with both the shutdown and loopback commands.
A GE fiber port forcibly brought up cannot correctly forward traffic if it is installed with a fiber-to-copper converter, 100/1000-Mbps transceiver module, or 100-Mbps transceiver module. To solve the problem, use the undo port up-mode command on the fiber port.
# Forcibly bring up the fiber port GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] port up-mode
Use reset counters interface to clear the Ethernet interface statistics.
reset counters interface [ interface-type [ interface-number ] ]
Use this command to clear history statistics if you want to collect traffic statistics for a specific time period.
If you do not specify an interface type, this command clears statistics for all interfaces.
If you specify only the interface type, this command clears statistics for all interfaces of that type.
If you specify both the interface type and the interface number, this command clears statistics for the specified interface.
# Clear the statistics for GigabitEthernet 1/0/1.
<Sysname> reset counters interface gigabitethernet 1/0/1
·     display interface
·     display counters interface
·     display counters rate interface
Use reset ethernet statistics to clear the Ethernet module statistics.
In standalone mode:
reset ethernet statistics slot slot-number
In IRF mode:
reset ethernet statistics chassis chassis-number slot slot-number
# (In standalone mode.) Clear the Ethernet module statistics for slot 6.
<Sysname> reset ethernet statistics slot 6
# (In IRF mode.) Clear the Ethernet module statistics for the card in slot 1 of IRF member device 1.
<Sysname> reset ethernet statistics chassis 1 slot 1
reset packet-drop interface
Use reset packet-drop interface to clear the dropped packet statistics for an interface or multiple interfaces.
reset packet-drop interface [ interface-type [ interface-number ] ]
interface-type: Specify an interface type. If you do not specify an interface type, this command clears dropped packet statistics for all interfaces on the device.
interface-number: Specify an interface number. If you do not specify this argument, the command clears dropped packet statistics for all interfaces of the specified type.
# Clear dropped packet statistics for GigabitEthernet 1/0/1.
<Sysname> reset packet-drop interface gigabitethernet 1/0/1
# Clear dropped packet statistics for all interfaces.
display packet-drop
shutdown
Use shutdown to shut down an Ethernet interface.
Use undo shutdown to bring up an Ethernet interface.
shutdown
An Ethernet interface is up.
Some interface configurations might require an interface restart before taking effect.
# Shut down and then bring up GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] shutdown
[Sysname-GigabitEthernet1/0/1] undo shutdown
speed
Use speed to set the speed of an Ethernet interface.
Use undo speed to restore the default.
speed { 10 | 100 | 1000 | 10000 | 40000 | 100000 | auto }
undo speed
The speed of a 10-GE XFP fiber port is 10000 Mbps. The speeds of other Ethernet interfaces are autonegotiated.
10: Sets the interface speed to 10 Mbps.
100: Sets the interface speed to 100 Mbps.
1000: Sets the interface speed to 1000 Mbps.
10000: Sets the interface speed to 10000 Mbps.
40000: Sets the interface speed to 40000 Mbps.
100000: Sets the interface speed to 100000 Mbps.
auto: Enables the interface to negotiate a speed with its peer.
For Ethernet interfaces connected to the same cable to operate correctly, you must configure the same speed for them.
For an Ethernet copper port, use the speed command to set its speed to match the speed of the peer interface.
For a fiber port, use the speed command to set its speed to match the rate of a transceiver module.
40-GE QSFP+ interfaces and 40-GE CFP interfaces support only the 40000 and auto keywords.
10-GE XFP interfaces support only the 10000 keyword.
10-GE SFP+ interfaces support only the 1000, 10000, and auto keywords.
GE SFP interfaces support only the 100, 1000, and auto keywords.
10-GE copper ports support only the 100, 1000, 10000, and auto keywords.
GE copper ports support only the 10, 100, 1000, and auto keywords.
# Configure GigabitEthernet 1/0/1 to autonegotiate the speed.
[Sysname-GigabitEthernet1/0/1] speed auto
using fortygige
IMPORTANT
IMPORTANT:
·     Before you reboot a switch configured with the using fortygige command, save the combining configuration on the switch even if the switch is an IRF member switch. Otherwise, the combining configuration cannot take effect.
·     40-GE interfaces on an LSQM1SRP8X2QE0 MPU do not support this command.
Use using fortygige to combine four 10-GE breakout interfaces split from a 40-GE interface into a 40-GE interface.
Use undo using fortygige to cancel the configuration.
using fortygige
A 40-GE interface is not split and operates as a single interface.
10-GE breakout interface view
This command is not supported on non-default MDCs.
If you need higher bandwidth on a single interface, you can combine four 10-GE breakout interfaces split from a 40-GE interface into a 40-GE interface. To do so, execute this command on any of these 10-GE breakout interfaces.
After this command is successfully configured to combine four 10-GE breakout interfaces into a 40-GE interface, the system deletes the four 10-GE breakout interfaces and creates the combined 40-GE interface.
Reboot the interface module after you execute this command.
# Combine 10-GE breakout interfaces Ten-GigabitEthernet 1/1/16:1 through Ten-GigabitEthernet 1/1/16:4 into a 40-GE interface.
<System> system-view
[System] interface ten-gigabitethernet1/1/16:1
[System-Ten-GigabitEthernet1/1/16:1] using fortygige
The interfaces Ten-GigabitEthernet1/1/16:1 through Ten-GigabitEthernet1/1/16:4 will be deleted. Continue? [Y/N]:y
Reboot the line card to make the configuration take effect.
using tengige
using tengige
IMPORTANT
IMPORTANT:
·     Before you reboot a switch configured with the using tengige command, save the splitting configuration on the switch even if the switch is an IRF member switch. Otherwise, the splitting configuration cannot take effect.
Use using tengige to split a high bandwidth interface into multiple 10-GE breakout interfaces.
Use undo using tengige to cancel the configuration.
using tengige
undo using tengige
A high bandwidth interface is not split and operates as a single interface.
40-GE interface view
To improve port density, reduce costs, and improve network flexibility, you can split a high bandwidth interface into multiple 10-GE breakout interfaces. For example, you can split a 40-GE interface FortyGigE 1/3/49 into four 10-GE breakout interfaces Ten-GigabitEthernet 1/3/49:1 through Ten-GigabitEthernet 1/3/49:4.
The 10-GE breakout interfaces support the same configuration and attributes as common 10-GE interfaces, except that they are numbered in a different way.
After this command is successfully configured, the system deletes the high bandwidth interface and creates the 10-GE breakout interfaces.
# Split 40-GE interface FortyGigE 1/3/49 into four 10-GE breakout interfaces.
[System] interface FortyGigE 1/3/49
[System-FortyGigE1/3/49] using tengige
The interface FortyGigE1/3/49 will be deleted. Continue? [Y/N]:y
using fortygige
Layer 2 Ethernet interface commands
broadcast-suppression
Use broadcast-suppression to enable broadcast suppression and set the broadcast suppression threshold.
Use undo broadcast-suppression to restore the default.
Ethernet interfaces do not suppress broadcast traffic.
ratio: Sets the broadcast suppression threshold as a percentage of the interface bandwidth. The value range for this argument is 0 to 100. A smaller value means that less broadcast traffic is allowed to pass through.
pps max-pps: Specifies the maximum number of broadcast packets that the interface can forward per second. The value range for the max-pps argument (in pps) is 0 to 1.4881 × the interface bandwidth.
kbps max-kbps: Specifies the maximum number of kilobits of broadcast traffic that the Ethernet interface can forward per second. The value range for this argument (in kbps) is 0 to the interface bandwidth.
To configure the multicast-suppression command together with the broadcast-suppression command on a PEX physical interface in an IRF 3 system, set the same parameter for both commands. For example, if the multicast suppression threshold is configured in kbps, the broadcast suppression threshold must also be configured in kbps.
The broadcast suppression features limits the size of broadcast traffic to a threshold on an interface. When the broadcast traffic on the interface exceeds this threshold, the system drops packets until the traffic drops below this threshold.
Both storm-constrain and broadcast-suppression can suppress broadcast storm on a port. The broadcast-suppression command uses the chip to physically suppress broadcast traffic. It has less influence on the device performance than the storm-constrain command, which uses software to suppress broadcast traffic.
Do not configure both the storm constrain broadcast command and the broadcast-suppression command on an interface. Otherwise, the traffic suppression result is not determined.
When you configure the suppression threshold in kbps, the actual suppression threshold might be different from the configured one as follows:
·     If the configured value is smaller than 64, the value of 64 takes effect.
·     If the configured value is greater than 64 but not an integer multiple of 64, the integer multiple of 64 that is greater than and closest to the configured value takes effect.
To determine the suppression threshold that takes effect, see the prompts on the switch.
# Set the broadcast suppression threshold to 10000 kbps on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] broadcast-suppression kbps 10000
The actual value is 10048 on port GigabitEthernet1/0/1 currently.
The output shows that the value that takes effect is 10048 kbps (157 times of 64), because the chip only supports step 64.
·     multicast-suppression
·     unicast-suppression
display storm-constrain
Use display storm-constrain to display storm control settings and statistics.
display storm-constrain [ broadcast | multicast | unicast ] [ interface interface-type interface-number ]
broadcast: Displays broadcast storm control settings and statistics.
multicast: Displays multicast storm control settings and statistics.
unicast: Displays unknown unicast storm control settings and statistics.
If you do not specify any keywords, this command displays all storm control settings on all storm control-enabled interfaces.
# Display the storm control settings on all storm control-enabled ports.
<Sysname> display storm-constrain
 Abbreviation: BC - broadcast; MC - multicast; UC - unicast
               FW - forwarding
 Flow Statistic Interval: 10 (in seconds)
Port          Type Lower     Upper     Unit   CtrlMode  Status     Trap Log   SwitchNum
XGE1/0/1      MC   100      200        kbps   shutdown  shutdown   off  on    10
XGE1/0/2      UC   200      300        kbps   shutdown  normal     off  on    33
XGE1/0/3      BC   500      1500       pps    N/A       normal     on   on    0
Table 7 Command output
Traffic polling interval (in seconds) of the storm control module.
Port
Type of traffic subjected to storm control:
·     BC—Broadcast packets.
·     MC—Multicast packets.
·     UC—Unknown unicast packets.
Lower
Lower storm control threshold, in pps, kbps, or percentage.
Upper
Upper storm control threshold, in pps, kbps, or percentage.
Unit
Storm control threshold unit:
·     pps.
·     kbps.
·     percentage.
CtrlMode
Action (block or shutdown) taken on the interface when the upper threshold is reached. N/A indicates that no action is configured.
Status
Packet forwarding status:
·     forwarding—The port is forwarding traffic correctly.
·     shutdown—The port has been shut down.
·     block—The port drops the type of traffic.
Trap
Status of the storm control threshold event trap switch:
·     on—The port sends threshold event traps.
·     off—The port does not send threshold event traps.
Log
Status of the storm control threshold event log switch:
·     on—The port sends threshold event log messages.
·     off—The port does not send threshold event log messages.
SwitchNum
Number of forwarding state changes of the interface.
When the SwitchNum field reaches 65535, it resets automatically.
mdix-mode
IMPORTANT
IMPORTANT:
Fiber ports do not support this command.
Use mdix-mode to configure the Medium Dependent Interface Cross-Over (MDIX) mode of an Ethernet interface.
Use undo mdix-mode to restore the default.
mdix-mode { automdix | mdi| mdix }
undo mdix-mode
Ethernet interfaces operate in automdix mode.
automdix: Specifies that the interface negotiates pin roles with its peer.
mdi: Specifies that pins 1 and 2 are transmit pins and pins 3 and 6 are receive pins.
mdix: Specifies that pins 1 and 2 are receive pins and pins 3 and 6 are transmit pins.
# Configure GigabitEthernet 1/0/1 to operate in MDI mode.
[Sysname-GigabitEthernet1/0/1] mdix-mode mdi
Use multicast-suppression to enable multicast suppression and set the multicast suppression threshold.
Use undo multicast-suppression to restore the default.
Ethernet interfaces do not suppress multicast traffic.
ratio: Sets the multicast suppression threshold as a percentage of the interface bandwidth. The value range for this argument (in percentage) is 0 to 100. A smaller value means that less multicast traffic is allowed to pass through.
pps max-pps: Specifies the maximum number of multicast packets that the interface can forward per second. The value range for the max-pps argument (in pps) is 0 to 1.4881 × the interface bandwidth.
kbps max-kbps: Specifies the maximum number of kilobits of multicast traffic that the Ethernet interface can forward per second. The value range for this argument (in kbps) is 0 to the interface bandwidth.
The multicast suppression feature limits the size of multicast traffic to a threshold on an interface. When the multicast traffic on the interface exceeds this threshold, the system drops packets until the traffic drops below this threshold.
Both the storm-constrain and multicast-suppression can suppress multicast storm on a port. The multicast-suppression command uses the chip to physically suppress multicast traffic. It has less influence on the device performance than the storm-constrain command, which uses software to suppress broadcast traffic. Do not configure both the storm constrain multicast command and the multicast-suppression command on an interface. Otherwise, the traffic suppression result is not determined.
# Set the multicast suppression threshold to 10000 kbps on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] multicast-suppression kbps 10000
·     broadcast-suppression
port bridge enable
Use port bridge enable to enable bridging on an Ethernet interface.
Use undo port bridge enable to disable bridging on an Ethernet interface.
port bridge enable
Bridging is disabled on an Ethernet interface.
When a packet arrives at an interface, the switch looks up the destination MAC address of the packet in the MAC address table. If the outgoing interface of the entry found is the same as the incoming interface, the switch drops the packet. After you configure this command on the Ethernet interface, the switch forwards such packets rather than drops them.
If no entry is found for the destination MAC address, the switch sends an ARP packet out of all interfaces except the incoming interface. After you configure this command on the Ethernet interface, the switch also sends the ARP packet out of the incoming interface.
# Enable bridging on Layer 2 Ethernet interface Ten-GigabitEthernet 1/0/1.
[Sysname] interface ten-gigabitethernet1/0/1
[Sysname-Ten-GigabitEthernet1/0/1] port bridge enable
storm-constrain
Use storm-constrain to enable storm control and set thresholds for broadcast, multicast, or unknown unicast packets on an Ethernet interface.
Use undo storm-constrain to disable storm control for broadcast, multicast, unknown unicast, or all types of traffic.
storm-constrain { broadcast | multicast | unicast } { pps | kbps | ratio } upperlimit lowerlimit
undo storm-constrain { all | broadcast | multicast | unicast }
Traffic storm control is disabled.
all: Disables storm control for all types of traffic: broadcast, multicast, and unknown unicast.
broadcast: Enables or disables broadcast storm control.
multicast: Enables or disables multicast storm control.
unicast: Enables or disables unknown unicast storm control.
pps: Sets storm control thresholds in pps.
kbps: Sets storm control thresholds in kbps.
ratio: Sets storm control thresholds as a percentage of the transmission capacity of the interface.
upperlimit: Sets the upper threshold, in pps, kbps, or percentage.
lowerlimit: Sets the lower threshold, in pps, kbps, or percentage.
After you configure storm control for a type of traffic, the device collects the statistics of the type of traffic at the interval configured by using the storm-constrain interval command. When the type of traffic exceeds its upper threshold, the interface takes an action configured by using the storm-constrain control command.
The storm-constrain, broadcast-suppression, multicast-suppression, and unicast-suppression commands can suppress storms on an interface. The broadcast-suppression, multicast-suppression, and unicast-suppression commands use the chip to physically suppress traffic. They have less influence on the device performance than the storm-constrain command, which uses software to suppress traffic.
For the same type of traffic, do not configure both storm control and storm suppression. Otherwise, the traffic suppression result is not determined.
When configuring this command, make sure upperlimit is greater than lowerlimit.
# Enable unknown unicast storm control on GigabitEthernet 1/0/1 and set the upper and lower thresholds to 200 pps and 150 pps.
[Sysname-GigabitEthernet1/0/1] storm-constrain unicast pps 200 150
# Enable broadcast storm control on GigabitEthernet 1/0/2, and set the upper and lower thresholds to 2000 kbps and 1500 kbps.
[Sysname-GigabitEthernet1/0/2] storm-constrain broadcast kbps 2000 1500
# Enable multicast storm control on GigabitEthernet 1/0/3, and set the upper and lower thresholds to 80% and 15%.
[Sysname] interface gigabitethernet 1/0/3
[Sysname-GigabitEthernet1/0/3] storm-constrain multicast ratio 80 15
·     storm-constrain control
·     storm-constrain interval
Use storm-constrain control to configure the action to take on an Ethernet interface when a type of traffic (unknown unicast, multicast, or broadcast) exceeds the upper storm control threshold.
Use undo storm-constrain control to restore the default.
No action is taken on an Ethernet interface when a type of traffic exceeds the upper storm control threshold.
block: Blocks this type of traffic and forwards other types of traffic. Even though the interface does not forward the blocked traffic, it still counts the traffic. When the blocked traffic drops below the lower threshold, the port begins to forward the traffic.
shutdown: Goes down automatically. The interface goes down automatically and stops forwarding any traffic. When the blocked traffic drops below the lower threshold, the interface does not forward the traffic. To bring up the interface, use the undo shutdown command or disable storm control on the interface.
# Configure GigabitEthernet 1/0/1 to block a specific type of traffic when the type of traffic exceeds the upper storm control threshold.
[Sysname-GigabitEthernet1/0/1] storm-constrain control block
·     storm-constrain
storm-constrain enable log
Use storm-constrain enable log to enable an Ethernet interface to output log messages when it detects storm control threshold events.
Use undo storm-constrain enable log to disable an Ethernet interface from outputting log messages for storm control threshold events.
An Ethernet interface outputs log messages when monitored traffic exceeds the upper threshold or drops below the lower threshold.
# Enable GigabitEthernet 1/0/1 to output log messages when it detects storm control threshold events.
[Sysname-GigabitEthernet1/0/1] storm-constrain enable log
storm-constrain enable trap
Use storm-constrain enable trap to enable an Ethernet interface to send storm control threshold event traps.
Use undo storm-constrain enable trap to disable an Ethernet interface from sending storm control threshold event traps.
An interface sends out traps when monitored traffic exceeds the upper threshold or drops below the lower threshold.
# Enable GigabitEthernet 1/0/1 to send traps when it detects storm control threshold events.
[Sysname-GigabitEthernet1/0/1] storm-constrain enable trap
Use storm-constrain interval to set the traffic polling interval of the storm control module.
Use undo storm-constrain interval to restore the default.
storm-constrain interval seconds
The storm control module polls traffic statistics every 10 seconds.
seconds: Sets the traffic polling interval of the storm control module. The value range is 1 to 300 seconds.
The traffic polling interval set by using the storm-constrain interval command is specific to storm control. To set the statistics polling interval of an interface, use the flow-interval command.
For network stability, use the default or a higher polling interval.
# Set the traffic statistics polling interval of the storm control module to 60 seconds.
[Sysname] storm-constrain interval 60
·     storm-constrain
unicast-suppression
Use unicast-suppression to enable unknown unicast suppression and set the unknown unicast suppression threshold.
Use undo unicast-suppression to restore the default.
Ethernet interfaces do not suppress unknown unicast traffic.
ratio: Sets the unknown unicast suppression threshold as a percentage of the interface bandwidth. The value range for this argument (in percentage) is 0 to 100. A smaller value means that less unknown unicast traffic is allowed to pass through.
pps max-pps: Specifies the maximum number of unknown unicast packets that the interface can forward per second. The value range for the max-pps argument (in pps) is 0 to 1.4881 × the interface bandwidth.
kbps max-kbps: Specifies the maximum number of kilobits of unknown unicast traffic that the Ethernet interface can forward per second. The value range for this argument (in kbps) is 0 to the interface bandwidth.
PEXs do not support this command. For more information about PEXs, see Virtual Technologies Configuration Guide.
The unknown unicast suppression feature limits the size of unknown unicast traffic to a threshold on an interface. When the unknown unicast traffic on the interface exceeds this threshold, the system discards packets until the unknown unicast traffic drops below this threshold.
Both the storm-constrain and unicast-suppression can suppress unknown unicast storms on a port. The unicast-suppression command uses the chip to physically suppress unknown unicast traffic. It has less influence on the device performance than the storm-constrain command, which uses software to suppress broadcast traffic.
Do not configure both the storm constrain unicast command and the unicast-suppression command on an interface. Otherwise, the unknown unicast traffic suppression result is not determined.
# Set the unknown unicast suppression threshold to 10000 kbps on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] unicast-suppression kbps 10000
virtual-cable-test
IMPORTANT
IMPORTANT:
This command is not available on fiber ports.
Use virtual-cable-test to test the cable connection of an Ethernet interface and display the test result.
virtual-cable-test
If the link of an Ethernet interface is up, testing its cable connection will cause the link to go down and then up.
The test result is for reference only. The cable length detection error is up to 10 m (about 33 ft).
If a test item is not available, a hyphen (-) is displayed.
# Test the cable connection of GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] virtual-cable-test
Cable status: abnormal(open), 140 metre(s)
Pair Impedance mismatch: -
Pair skew: - ns
Pair swap: -
Pair polarity: -
Insertion loss: - db
Return loss: - db
Near-end crosstalk: - db
Table 8 Command output
Cable status
Cable status:
·     Normal—The cable is in good condition.
·     Abnormal—The cable is abnormal.
·     Abnormal (open)—An open circuit is detected.
·     Abnormal (short)—A short circuit is detected.
·     Failure—The test failed.
n metre(s)
If the cable connection is working correctly, this field displays the total length of the cable.
If the cable connection fails, this field displays the length from the local port to the faulty point.
Layer 3 Ethernet interface commands
mtu
Use mtu to set the MTU for an Ethernet interface.
mtu size
undo mtu
The MTU of an Ethernet interface is 1500 bytes.
size: Sets the MTU in bytes. The value range for this argument varies by interface type.
A smaller MTU size results in more fragments. When you set the MTU for an interface, consider QoS queue lengths, for example, consider that the default FIFO queue length is 75. To prevent a too small MTU from causing packet drops in QoS queuing, you can perform one of the following tasks:
·     Tune the MTU with the mtu command.
·     Tune QoS queue lengths with the qos fifo queue-length command.
For more information about the qos fifo queue-length command, see ACL and QoS Command Reference.
# Set the MTU to 1430 bytes for Layer 3 Ethernet interface GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] mtu 1430
