01-Fundamentals Command Reference
HomeSupportSwitchesS7500E-XS SeriesReference GuidesCommand ReferencesH3C S7500E-XS Switch Series Command References-Release7178-6W10001-Fundamentals Command Reference
11-Password recovery control command
11-Password recovery control command 30.62 KB
password-recovery enable
Use password-recovery enable to enable password recovery capability.
Use undo password-recovery enable to disable password recovery capability.
Password recovery capability is enabled.
Password recovery capability controls console user access to the device configuration and SDRAM from BootWare menus.
If password recovery capability is enabled, a console user can access the device configuration without authentication to configure new passwords.
If password recovery capability is disabled, console users must restore the factory-default configuration before they can configure new passwords. Restoring the factory-default configuration deletes the next-startup configuration files.
To enhance system security, disable password recovery capability.
Table 1 summarizes options whose availability depends on the password recovery capability setting.
Table 1 BootWare options and password recovery capability compatibility matrix
BootWare menu option
Password recovery enabled
Password recovery disabled
Tasks that can be performed
Ctrl+R: Download image to SDRAM and run
Yes
No
Load and run Comware software images in SDRAM.
Set configuration file
Yes
No
Specify the main and backup configuration files for the next startup.
Ctrl+P: Change authentication for console login
Yes
No
Skip console login authentication at the next startup.
The skip is a one-time operation. It takes effect only for the first system boot or reboot after you choose this option.
Skip current system configuration
Yes
No
Skip the configuration file at the next startup.
The skip is a one-time operation. It takes effective only for the first system boot or reboot after you choose this option.
This option does not delete the configuration file.
Restore to factory default configuration
No
Yes
Delete the next-startup configuration file and load the factory-default configuration.
# Disable password recovery capability.
[Sysname] undo password-recovery enable
