01-Fundamentals Command Reference
HomeSupportSwitchesS7500E-XS SeriesReference GuidesCommand ReferencesH3C S7500E-XS Switch Series Command References-Release7178-6W10001-Fundamentals Command Reference
09-Device management commands
09-Device management commands 279.41 KB
Device management commands· 1
clock datetime· 1
clock protocol 1
clock summer-time· 2
clock timezone· 4
command· 5
copyright-info enable· 5
display clock· 7
display copyright 7
display cpu-usage· 8
display cpu-usage configuration· 9
display cpu-usage history· 9
display device· 12
display device manuinfo· 12
display device manuinfo fan· 14
display device manuinfo power 14
display diagnostic-information· 15
display environment 16
display fan· 17
display memory· 18
display memory-threshold· 19
display power 20
display scheduler job· 21
display scheduler logfile· 22
display scheduler reboot 22
display scheduler schedule· 23
display switch-mode status· 24
display system stable state· 25
display system-working-mode· 26
display transceiver alarm·· 26
display transceiver diagnosis· 27
display transceiver interface· 28
display transceiver manuinfo· 30
display version· 30
display version-update-record· 31
fan prefer-direction· 32
hardware-failure-detection· 33
header 34
job· 35
memory-threshold· 36
memory-threshold usage· 37
monitor cpu-usage enable· 38
monitor cpu-usage interval 38
monitor cpu-usage threshold· 39
reboot 40
reset version-update-record· 41
reset scheduler logfile· 42
restore factory-default 42
scheduler job· 43
scheduler logfile size· 43
scheduler reboot at 44
scheduler reboot delay· 45
scheduler schedule· 46
shutdown-interval 47
switch-mode· 47
sysname· 48
system-working-mode· 49
temperature-limit 49
time at 50
time once· 51
time repeating· 52
transceiver phony-alarm-disable· 54
user-role· 54
clock datetime
Use clock datetime to set the local UTC time.
clock datetime time date
The local UTC time is the device manufacture time.
time: Specifies a time in the hh:mm:ss format. The value range for hh is 0 to 23. The value range for mm is 0 to 59. The value range for ss is 0 to 59. The leading zero in a segment can be omitted. If the seconds segment is 0 (hh:mm:00), you can omit it. If both the minutes and seconds segments are 0 (hh:00:00), you can omit both of the segments. For example, to specify 08:00:00, you can enter 8.
date: Specifies a date in the MM/DD/YYYY or YYYY/MM/DD format. The value range for YYYY is 2000 to 2035. The value range for MM is 1 to 12. The value range for DD varies by month.
Correct system time is essential to network management and communication. You must configure the system time correctly before you run the device on the network.
The system time is determined by the UTC time, the time zone, and the daylight saving time. You can use the display clock command to view the system time.
You can use this command to specify a UTC time for the device, or configure the device to obtain the UTC time from an NTP or PTP time source. The UTC time obtained from an NTP or PTP time source is more precise.
# Set the local UTC time to 08:08:08 01/01/2012.
<Sysname> clock datetime 8:8:8 1/1/2012
# Set the local UTC time to 08:10:00 01/01/2012.
<Sysname> clock datetime 8:10 2012/1/1
·     clock protocol
·     clock summer-time
·     clock timezone
·     display clock
clock protocol
Use clock protocol to specify the UTC time source.
Use undo clock protocol to restore the default.
clock protocol { none | ntp }
undo clock protocol
The device obtains the UTC time through NTP.
none: Uses the local UTC time set by using the clock datetime command.
ntp: Uses NTP to obtain a UTC time. You must configure NTP correctly. For more information about NTP and NTP configuration, see Network Management and Monitoring Configuration Guide.
The device can obtain the UTC time from one of the following time sources:
·     None—Local UTC time set by using the clock datetime command.
·     NTP—NTP time source.
The UTC time obtained from an NTP time source is more precise.
If you configure this command multiple times, the most recent configuration takes effect.
On an S7500E-XS switch, system time settings are restored to the default after a reboot. After an S7500E-XS switch reboots, you must reconfigure the system time for the switch.
# Configure the device to use the local UTC time.
[Sysname] clock protocol none
clock summer-time
Use clock summer-time to configure the device to use daylight saving time during a specific period of time.
Use undo clock summer-time to cancel the configuration.
Daylight saving time is disabled.
name: Specifies a name for the daylight saving time schedule, a case-sensitive string of 1 to 32 characters.
start-time: Specifies the start time in the hh:mm:ss format. The value range for hh is 0 to 23. The value range for mm is 0 to 59. The value range for ss is 0 to 59. The leading zero in a segment can be omitted. If the seconds segment is 0 (hh:mm:00), you can omit it. If both the minutes and seconds segments are 0 (hh:00:00), you can omit both of the segments. For example, to specify 08:00:00, you can enter 8.
start-date: Specifies the start date in one of the following formats:
·     MM/DD. The value range for MM is 1 to 12. The value range for DD varies by month.
·     month week date, where:
¡     month—Takes January, February, March, April, May, June, July, August, September, October, November or December.
¡     week—Represents week of the month. It takes first, second, third, fourth, fifth, or last.
¡     day—Takes Sunday, Monday, Tuesday, Wednesday, Thursday, Friday, or Saturday.
end-time: Specifies the end time in the hh:mm:ss format. The value range for hh is 0 to 23. The value range for mm is 0 to 59. The value range for ss is 0 to 59. The leading zero in a segment can be omitted. If the seconds segment is 0 (hh:mm:00), you can omit it. If both the minutes and seconds segments are 0 (hh:00:00), you can omit both of the segments. For example, to specify 08:00:00, you can enter 8.
end-date: Specifies the end date in one of the following formats:
add-time: Specifies the time to be added to the standard time, in the hh:mm:ss format. The value range for hh is 0 to 23. The value range for mm is 0 to 59. The value range for ss is 0 to 59. The leading zero in a segment can be omitted. If the seconds segment is 0 (hh:mm:00), you can omit it. If both the minutes and seconds segments are 0 (hh:00:00), you can omit both of the segments. For example, to specify 08:00:00, you can enter 8.
Make sure all devices on the network are using the same daylight saving time as the local time.
# Set the system time ahead 1 hour for the period between 06:00:00 on 08/01 and 06:00:00 on 09/01.
[Sysname] clock summer-time PDT 6 08/01 6 09/01 1
·     clock datetime
·     clock timezone
·     display clock
clock timezone
Use clock timezone to set the time zone.
Use undo clock timezone to restore the default.
undo clock timezone
The time zone is not set.
zone-name: Specifies a time zone by its name, a case-sensitive string of 1 to 32 characters.
add: Adds an offset to the UTC time.
minus: Decreases the UTC time by an offset.
zone-offset: Specifies an offset to the UTC time, in the hh:mm:ss format. The value range for hh is 0 to 23. The value range for mm is 0 to 59. The value range for ss is 0 to 59. The leading zero in a segment can be omitted. If the seconds segment is 0 (hh:mm:00), you can omit it. If both the minutes and seconds segments are 0 (hh:00:00), you can omit both of the segments. For example, to specify 08:00:00, you can enter 8.
Make sure all devices on the network are using the same time zone as the local time.
# Set the name of the local time zone to Z5, and add 5 hours to the UTC time.
[Sysname] clock timezone Z5 add 5
·     clock datetime
·     clock summer-time
·     display clock
command
Use command to assign a command to a job.
Use undo command to revoke a command.
command id command
undo command id
No command is assigned to a job.
Job view
id: Specifies an ID for the command, in the range of 0 to 4294967295. A command ID uniquely identifies a command in a job. Commands in a job are executed in ascending order.
command: Specifies the command to be assigned to the job.
To assign a command (command A) to a job, you must first assign the job the command or commands for entering the view of command A.
If you specify the ID of an existing command for another command, the existing command is replaced.
Make sure all commands in a schedule are compliant to the command syntax. The system does not examine the syntax when you assign a command to a job.
If a command requires a yes or no answer, the system always assumes that a Y or Yes is entered. If a command requires a character string input, the system assumes that either the default character string (if any) or a null string is entered.
A job cannot contain any of these commands: telnet, ftp, ssh2, or monitor process.
# Assign commands to job backupconfig to back up configuration file startup.cfg to the TFTP server at 192.168.100.11.
[Sysname] scheduler job backupconfig
[Sysname-job-backupconfig] command 2 tftp 192.168.100.11 put flash:/startup.cfg backup.cfg
scheduler job
Use copyright-info enable to enable displaying the copyright statement.
Use undo copyright-info enable to disable displaying the copyright statement.
The copyright statement is displayed.
# Enable displaying the copyright statement.
[Sysname] copyright-info enable
·     When a Telnet user logs in, the following statement appears:
* Copyright (c) 2004-2015 Hangzhou H3C Tech. Co., Ltd. All rights reserved.*
* Without the owner's prior written consent,                               *
* no decompiling or reverse-engineering shall be allowed.                  *
<Sysname>
·     When a console user quits user view, the system automatically restarts the session and displays the following message:
User interface aux0 is available.
Press ENTER to get started.
# Disable displaying the copyright statement.
[Sysname] undo copyright-info enable
·     When a Telnet user logs in, the user view prompt appears as follows:
<Sysname>
display clock
Use display clock to display the system time, date, local time zone, and daylight saving time.
display clock
# Display the system time and date when the local time zone is not specified.
<Sysname> display clock
10:09:00 UTC Fri 03/16/2012
# Display the system time and date when the local time zone Z5 is specified.
15:10:00 Z5 Fri 03/16/2012
Time Zone : Z5 add 05:00:00
# Display the system time and date when the local time zone Z5 and daylight saving time PDT are specified.
15:11:00 Z5 Fri 03/16/2012
·     clock datetime
·     clock timezone
·     clock summer-time
display copyright
Use display copyright to display the copyright statement.
display copyright
# Display the copyright statement.
<Sysname> display copyright
display cpu-usage
Use display cpu-usage to display the current CPU usage statistics.
display cpu-usage [ slot slot-number [ cpu cpu-number ] ]
slot slot-number: Specifies an IRF member device by its member ID or specifies a PEX by its virtual slot number. On an IRF fabric, this command displays information for all member devices if you do not specify a member device. On an IRF 3 system, this command displays information for all IRF member devices and PEXs if you do not specify an IRF member device or PEX.
cpu cpu-number: Specifies a CPU by its number.
After startup, the device tracks the average CPU usage at the following intervals:
·     5 seconds.
·     1 minute.
·     5 minutes.
This command displays the average CPU usage values for the last 5 seconds, 1 minute, and 5 minutes.
# Display the current CPU usage statistics.
<Sysname> display cpu-usage
Slot 3 CPU 0 CPU usage:
       2% in last 5 seconds
       2% in last 1 minute
       2% in last 5 minutes
Average CPU usage during the last 5-second interval.
2% in last 1 minute
Average CPU usage during the last 1-minute interval.
Average CPU usage during the last 5-minute interval.
Slot x CPU y CPU usage
Usage statistics for CPU y of the member device in slot x.
Use display cpu-usage configuration to display CPU usage monitoring settings.
slot slot-number: Specifies an IRF member device by its member ID or specifies a PEX by its virtual slot number. If you do not specify a member device or PEX, this command displays the CPU usage monitoring settings for the master device.
cpu cpu-number: Specifies a CPU by its number. If you do not specify this option, the command displays the CPU usage monitoring settings for the default CPU.
# Display the CPU usage monitoring settings.
<Sysname> display cpu-usage configuration
CPU usage monitor is enabled.
Current monitor interval is 60 seconds.
Current monitor threshold is 99%.
·     monitor cpu-usage enable
·     monitor cpu-usage interval
·     monitor cpu-usage threshold
Use display cpu-usage history to display the historical CPU usage statistics in a coordinate system.
job job-id: Specifies a process by its ID. If you do not specify this option, the command displays the historical statistics for the entire system's CPU usage (the total CPU usage of all processes). To view the IDs and names of the running processes, use the display process command. For more information, see Network Management and Monitoring Configuration Guide.
slot slot-number: Specifies an IRF member device by its member ID or specifies a PEX by its virtual slot number. If you specify a process but do not specify a member device, this command displays the statistics for the process on the master device. If you do not specify any options, this command displays the statistics for all processes in the IRF fabric.
cpu cpu-number: Specifies a CPU by its number. If you specify the job job-id option but do not specify this option, the command displays the historical CPU usage statistics for the default CPU. If you do not specify the job job-id option or this option, the command displays the historical statistics for all CPUs.
After CPU usage monitoring is enabled, the system regularly samples CPU usage and saves the samples to the history record buffer. This command displays the most recent 60 samples in a coordinate system as follows:
·     The vertical axis represents the CPU usage. If a statistic is not a multiple of the usage step, it is rounded up or down to the closest multiple of the usage step. For example, if the CPU usage step is 5%, the statistic 53% is rounded up to 55%, and the statistic 52% is rounded down to 50%.
·     The horizontal axis represents the time.
·     Consecutive pound signs (#) indicate the CPU usage at a specific time. The value on the vertical axis for the topmost pound sign at a specific time represents the CPU usage at that time.
# Display the historical CPU usage statistics for the entire system.
<Sysname> display cpu-usage history
100%|
 95%|
 90%|
 85%|
 80%|
 75%|
 70%|
 65%|
 60%|
 55%|
 50%|
 45%|
 40%|
 35%|
 30%|
 25%|
 20%|
 15%|             #
 10%|            ###  #
  5%|           ########
              10        20        30        40        50        60  (minutes)
                      cpu-usage (Slot 1 CPU 0) last 60 minutes (scmd)
The output shows the following items:
·     Process name. The name SYSTEM represents the entire system.
·     CPU that is holding the process is CPU 0 of the member device in slot 1.
·     Historical CPU usage statistics for the entire system during the last 60 minutes.
¡     12 minutes ago: Approximately 5%.
¡     13 minutes ago: Approximately 10%.
¡     14 minutes ago: Approximately 15%.
¡     15 minutes ago: Approximately 10%.
¡     16 and 17 minutes ago: Approximately 5%.
¡     18 minutes ago: Approximately 10%.
¡     19 minutes ago: Approximately 5%.
¡     Other time: 2% or lower than 2%.
# Display the historical CPU usage statistics for process 1.
<Sysname> display cpu-usage history job 1
100%|
 95%|
 90%|
 85%|
 80%|
 75%|
 70%|
 65%|
 60%|
 55%|
 50%|
 45%|
 40%|
 35%|
 30%|
 25%|
 20%|
 15%|
 10%|
  5%|                   #
·     Process name, which is scmd. A process name in  a pair of square brackets ([ ]) represents a kernel process.
·     Historical CPU usage statistics for process 1 in the last 60 minutes.
¡     20 minutes ago: Approximately 5%.
display device
Use display device to display device information.
display device [ flash | usb ] [ slot slot-number [ subslot subslot-number ] | verbose ]
flash: Specifies the flash memory.
usb: Specifies the device connected to the USB interface.
subslot subslot-number: Specifies an interface card by its subslot number. If you do not specify this option, the command does not display information about any interface card.
verbose: Displays detailed hardware information. If you do not specify this keyword, the command displays brief information.
# Display device information about all IRF member devices.
<Sysname> display device
Slot Type                 State    Subslot  Soft Ver             Patch Ver
1    S7502E-XS            Master   1        S7500EXS-7176P01     None
Slot
Device type.
Device status.
Status
Maximum number of interface cards supported.
Subslot
Software version of the device.
Soft Ver
Patch version of the device.
Use display device manuinfo to display electronic label information for the device.
display device manuinfo [ slot slot-number [ subslot subslot-number ] ]
slot slot-number: Specifies an IRF member device by its member ID or specifies a PEX by its virtual slot number. On an IRF fabric, this command displays electronic label information for all member devices if you do not specify a member device. On an IRF 3 system, this command displays electronic label information for all IRF member devices and PEXs if you do not specify a member device or PEX.
subslot subslot-number: Specifies an interface card by its subslot number. If you do not specify this option, the command does not display information about any interface cards.
An electronic label is a profile of a device or interface card. It contains the permanent configuration, including the serial number, manufacturing date, MAC address, and vendor name. The data is written to the storage component during debugging or testing.
# Display electronic label information for the device.
<Sysname> display device manuinfo
Slot 1 CPU 0:
Subslot 0:
DEVICE_NAME          : S7502E-XS
DEVICE_SERIAL_NUMBER : 210235A1ETH158000039
MAC_ADDRESS          : 741F-4A9B-818E
MANUFACTURING_DATE   : 2015-08-28
VENDOR_NAME          : H3C
Subslot 2:
DEVICE_NAME          : LSQM1TGT24QSM0
DEVICE_SERIAL_NUMBER : 210231A2U5H157000086
MANUFACTURING_DATE   : 2015-07-13
VENDOR_NAME          : H3C
Fan 1:
DEVICE_NAME          : LSQM1HFANSCB
DEVICE_SERIAL_NUMBER : 210231A1YTH155000074
MANUFACTURING_DATE   : 2015-06-02
VENDOR_NAME          : H3C
Fan 2:
DEVICE_SERIAL_NUMBER : 210231A1YTH155000071
VENDOR_NAME          : H3C
Power 1:
DEVICE_NAME          : LSVM1AC650
MANU SERIAL NUMBER   : 210231A0QMH154000271
VENDOR_NAME          : H3C
Slot m CPU n
Member ID of the member device and number of the CPU.
DEVICE_NAME
Device name.
Serial number.
MAC_ADDRESS
MAC address.
MANUFACTURING_DATE
Manufacturing date.
VENDOR_NAME
Vendor name.
Use display device manuinfo fan to display electronic label information for a fan.
display device manuinfo slot slot-number fan fan-id
fan-id: Specifies a fan by its ID.
# Display electronic label information for fan 1 on member device 1.
<Sysname> display device manuinfo slot 1 fan 1
Fan 1:
VENDOR_NAME          : H3C
Use display device manuinfo power to display electronic label information for a power module.
display device manuinfo slot slot-number power power-id
power-id: Specifies a power module by its ID.
# Display electronic label information for power module 1 on member device 1.
<Sysname> display device manuinfo slot 1 power 1
Power 1:
VENDOR_NAME          : H3C
Use display diagnostic-information to display or save device diagnostic information.
display diagnostic-information [ hardware | infrastructure | l2 | l3 | service ] [ filename ]
hardware: Displays hardware-related diagnostic information.
infrastructure: Displays diagnostic information about the fundamental modules.
l2: Displays diagnostic information about Layer 2 features.
l3: Displays diagnostic information about Layer 3 features.
service: Displays diagnostic information about upper-layer features.
filename: Saves the diagnostic information to a file. The filename argument must use the .tar.gz suffix. If you do not specify this argument, the command prompts you to choose whether to save the information to a file or display the information.
If you do not specify any feature options, the command displays or saves device diagnostic information about all feature modules.
This command does not support the |, >, and >> options.
You can use one of the following methods to collect device diagnostic information:
·     Use separate display commands to collect diagnostic information feature by feature or module by module.
·     Use the display diagnostic-information command to collect diagnostic information about multiple or all features and hardware modules.
If you specify the filename argument, the device also collects and saves core files to the specified file. The file is automatically compressed to save storage space. The default file name is in the diag_sysname_YYYYMMDD-hhmmss.tar.gz format, for example, diag_sysname_20140829-083832.tar.gz.
To view the file content:
1.     Use the tar extract command to extract the file.
2.     Execute the more command.
# Display diagnostic information about all feature modules.
08:44:14 UTC Sat 01/01/2011
H3C Comware Software, Version 7.1.045, Beta 7176P01
H3C S7502E-XS uptime is 0 weeks, 0 days, 8 hours, 46 minutes
Last reboot reason : Cold reboot
# Save the operating statistics for all feature modules to file test.tar.gz.
·     Method 1: Specify the filename in interactive mode.
Save or display diagnostic information (Y=save, N=display)? [Y/N]:y
Please input the file name(*.tar.gz)[flash:/diag_sysname_20140829-083832.tar.gz]: test.tar.gz
Diagnostic information is outputting to flash:/test.tar.gz.
Please wait...
Save successfully.
·     Method 2: Specify the filename for the command.
<Sysname> display diagnostic-information test.tar.gz
Please wait...
Save successfully.
·     more
·     tar extract
display environment
Use display environment to display the temperature statistics for the temperature sensors, including the current temperature and temperature thresholds.
# Display the temperature statistics for all temperature sensors on the device.
<Sysname> display environment
 System temperature information (degree centigrade):
 Slot  Sensor    Temperature  Lower  Warning  Alarm  Shutdown
 1     hotspot 1 27           0      55       65     NA
 1     hotspot 2 30           0      60       70     NA
 1     hotspot 3 29           0      60       70     NA
System Temperature information (degree centigrade)
Temperature information (°C).
sensor
Temperature sensor. The device has hotspot sensors.
Slot
Slot number.
Temperature
Current temperature.
LowerLimit
Lower temperature limit.
WarningLimit
Warning temperature threshold.
AlarmLimit
Alarming temperature threshold.
ShutdownLimit
Shutdown temperature threshold. When the sensor temperature reaches the limit, the system shuts down automatically.
display fan
Use display fan to display the operating states of fans.
display fan [ slot slot-number [ fan-id ] ]
slot slot-number: Specifies an IRF member device by its member ID or specifies a PEX by its virtual slot number. On an IRF fabric, this command displays fan operating status information for all member devices if you do not specify a member device. On an IRF 3 system, this command displays fan operating status information for all IRF member devices and PEXs if you do not specify a member device or PEX.
fan-id: Specifies a fan by its ID. If you do not specify this option, the command displays the operating states of all fans.
# Display the operating states of all fans.
<Sysname> display fan
Slot 1:
 Fan 1:
 State    : Normal
 Airflow Direction: Power-to-port
 Prefer Airflow Direction: Power-to-port
 Fan 2:
 State    : Normal
display memory
Use display memory to display memory usage information.
display memory [ slot slot-number [ cpu cpu-number ] ]
slot slot-number: Specifies an IRF member device by its member ID or specifies a PEX by its virtual slot number. If you do not specify a member device or PEX, this command displays memory usage for all member devices.
cpu cpu-number: Specifies a CPU by its number. If you do not specify this option, the command displays information about the default CPU.
# Display memory usage information.
<Sysname> display memory
The statistics about memory is measured in KB:
Slot 1:
             Total      Used      Free    Shared   Buffers    Cached   FreeRatio
Mem:       1771368    577776   1193592         0       152     53544       70.1%
-/+ Buffers/Cache:    524080   1247288
Swap:           0         0         0
Table 5 Command output
Slot
Slot number.
Mem
Memory usage information.
Total
Total size of the allocable physical memory space.
The memory space is virtually divided into two parts: the allocable part and the unallocable part. The latter is used for kernel codes, kernel management, and ISSU functions. The former can be allocated and used for such tasks as running service modules and storing files.
Used
Used physical memory.
Free
Free physical memory.
Shared
Physical memory shared by processes.
Buffers
Physical memory used for buffers.
Cached
Physical memory used for caches.
FreeRatio
Free memory ratio.
-/+ Buffers/Cache
-/+ Buffers/Cache:used = Mem:Used – Mem:Buffers – Mem:Cached, which indicates the physical memory used by applications.
-/+ Buffers/Cache:free = Mem:Free + Mem:Buffers + Mem:Cached, which indicates the physical memory available for applications.
Swap
Swap memory.
Use display memory-threshold to display memory alarm thresholds and statistics.
slot slot-number: Specifies an IRF member device by its member ID or specifies a PEX by its virtual slot number. If you do not specify a member device or PEX, this command displays the memory usage thresholds and statistics for the master device.
cpu cpu-number: Specifies a CPU by its number. If you do not specify this option, the command displays the memory usage thresholds and statistics for the default CPU.
For more information about memory usage notifications, see log information containing MEM_EXCEED_THRESHOLD or MEM_BELOW_THRESHOLD.
# Display memory alarm thresholds and statistics.
Memory usage threshold: 100%
Free memory threshold:
    Minor: 96M
    Severe: 64M
    Critical: 48M
    Normal: 128M
Current memory state: Normal
Event statistics:
 [Back to normal state]
    First notification: 0.0
    Latest notification: 0.0
    Total number of notifications sent: 0
 [Enter minor low-memory state]
    First notification at: 0.0
    Latest notification at: 0.0
 [Back to minor low-memory state]
 [Enter severe low-memory state]
 [Back to severe low-memory state]
 [Enter critical low-memory state]
display power
Use display power to display power module information.
display power [ slot slot-number [ power-id ] ]
power-id: Specifies a power module by its ID. If you do not specify this option, the command displays information about all power modules on the specified object.
This command does not display the power of an S5130-EI switch that acts as a PEX.
# Display power module information.
<Sysname> display power
 Slot 1:
 Input Power: 150(W)
 PowerID State          Mode   Current(A)  Voltage(V)  Power(W)
 1       Normal         AC        --          --          --
 2       Absent         --        --          --          --
Use display scheduler job to display job configuration information.
job-name: Specifies a job by its name, a case-sensitive string of 1 to 47 characters. If you do not specify this option, the command displays configuration information for all jobs.
# Display configuration information for all jobs.
<Sysname> display scheduler job
Job name: saveconfig
 copy startup.cfg backup.cfg
Job name: backupconfig
Job name: creat-VLAN100
 vlan 100
// The output shows that the device has three jobs: the first has one command, the second has no command, and the third has two commands. Jobs are separated by blank lines.
Use display scheduler logfile to display job execution log information.
# Display job execution log information.
<Sysname> display scheduler logfile
Logfile Size: 1902 Bytes.
Job name        : shutdown
Schedule name   : shutdown
Execution time  : Tue Dec 27 10:44:42 2011
Completion time : Tue Dec 27 10:44:47 2011
[Sysname]interface rang ten-gigabitethernet 1/1/1 to ten-gigabitethernet 1/1/3
[Sysname-if-range]shutdown
Table 6 Command output
Logfile Size
Size of the log file, in bytes.
Schedule name
Schedule to which the job belongs.
Execution time
Time when the job was started.
Completion time
Time when the job was completed. If the job has never been executed or the job has no commands, this field is blank.
Job output
Commands in the job and their output.
Use display scheduler reboot to display the automatic reboot schedule.
# Display the automatic reboot schedule.
<Sysname> display scheduler reboot
System will reboot at 16:32:00 05/23/2011 (in 1 hours and 39 minutes).
·     scheduler reboot at
·     scheduler reboot delay
Use display scheduler schedule to display schedule information.
schedule-name: Specifies a schedule by its name, a case-sensitive string of 1 to 47 characters. If you do not specify this option, the command displays information about all schedules.
# Display information about all schedules.
<Sysname> display scheduler schedule
Schedule type        : Run once after 0 hours 2 minutes
Start time           : Tue Dec 27 10:44:42 2011
Last execution time  : Tue Dec 27 10:44:42 2011
Last completion time : Tue Dec 27 10:44:47 2011
Execution counts     : 1
shutdown                                          Successful
Table 7 Command output
Schedule type
Execution time setting of the schedule. If no execution time is specified, this field is not displayed.
Start time
Time to execute the schedule for the first time. If no execution time is specified, this field is not displayed.
Last execution time
Last time when the schedule was executed. If no execution time is specified, this field is not displayed. If the schedule has never been executed, "Yet to be executed" is displayed for this field.
Last time when the schedule was completed. If no execution time is specified, this field is not displayed.
Execution counts
Number of times the schedule has been executed. If the schedule has never been executed, this field is not displayed.
Job name
Name of a job under the schedule.
Result of the most recent execution:
·     Successful.
·     Failed.
·     Waiting—The device is executing the schedule and the job is waiting to be executed.
·     In process—The job is being executed.
·     -NA-—The execution time has not arrived yet.
To view information about whether the commands in the job has been executed and the execution results, execute the display scheduler logfile command.
Use display switch-mode status to display table capacity mode information
# Display table capacity mode information.
<Sysname> display switch-mode status
Current: ROUTING
Config: ROUTING
Table 8 Command output
Current
Currently used table capacity mode:
·     BRIDGING—The bridging mode.
·     MIX—The mix-bridging-routing mode.
·     ROUTING—The routing mode.
Config
Table capacity mode to be used at the next startup:
switch-mode
Use display system stable state to display system stability and status information.
Before performing an ISSU or active/standby switchover, execute this command multiple times to identify whether the system is operating stably. If the value of the System State field is not Stable, you cannot perform an ISSU. If the value of the Redundancy Stable field is not Stable, you cannot perform an active/standby switchover.
The device takes some time to start up. If the values of the status fields do not change to Stable, execute this command multiple times to identify the members that are not in Stable state. You can also use other commands to identify the faulty components. For example:
·     Use the display device command to identify the member that is in Fault state.
·     Use the display ha service-group command to display the status of HA service groups and identify the groups that are in batch backup state.
# Display system stability and status information.
<Sysname> display system stable state
System state     : Stable
Redundancy state : No redundance
  Slot    CPU    Role       State
  1       0      Active     Stable
Table 9 Command output
System state
System status. The value of this field is fixed at Stable because the device executes this command only when it is operating stably.
Redundancy state
System redundancy status:
·     Stable—Member devices are operating stably. You can perform a switchover.
·     No Redundance—The system has only one member device. You cannot perform a switchover.
·     Not Ready—The system is not operating stably. You cannot perform a switchover.
Role
Role of the member device in the system:
·     Active—The device is the master.
·     Standby—The device is a subordinate member.
·     Other—The device is a PEX.
Member device status:
·     Stable—The member device is operating stably.
·     Board Inserted—The member device has just been installed.
·     Kernel Init—Member device kernel is being initialized.
·     Service Starting—Services are starting on the member device.
·     Service Stopping—Services are stopping on the member device.
·     HA Batch Backup—An HA batch backup is going on.
·     Interface Data Batch Backup—An interface data batch backup is in progress.
The object is not operating stably.
·     display device
·     display ha service-group (High Availability Command Reference)
Use display system-working-mode to display the current system working mode.
# Display the current system working mode.
<Sysname> display system-working-mode
The current system working mode is standard.
The next system working mode is standard.
Use display transceiver alarm to display transceiver alarms.
interface [ interface-type interface-number ]: Specifies an interface by its type and number. If no interface is specified, this command displays the alarms present on every transceiver module.
Table 10 shows the common transceiver alarms. If no error occurs, "None" is displayed.
Table 10 Common transceiver alarm components
SFP+:
RX
Receive
TX
Transmit
power
Optical power
Temp
Temperature
QSFP+:
RX
Receive
TX
Transmit
power
Optical power
Temp
Temperature
# Display the alarms present on the transceiver module in interface Ten-GigabitEthernet 1/1/1.
<Sysname> display transceiver alarm interface ten-gigabitethernet 1/1/1
Ten-GigabitEthernet1/1/1 transceiver current alarm information:
  RX power low
  RX signal loss
Table 11 Command output
Alarms present on the transceiver module.
RX signal loss
Received signals are lost.
RX power low
Received power is low.
Use display transceiver diagnosis to display the current values of the digital diagnosis parameters on transceiver modules.
interface [ interface-type interface-number ]: Specifies an interface by its type and number. If no interface is specified, this command displays the current values of the digital diagnosis parameters on every transceiver module.
This command cannot display information about some transceiver modules.
# Display the current values of the digital diagnosis parameters on the transceiver module in interface Ten-GigabitEthernet 1/1/1.
<Sysname> display transceiver diagnosis interface ten-gigabitethernet 1/1/1
Ten-GigabitEthernet1/1/1 transceiver diagnostic information:
    Temp.(°C) Voltage(V)  Bias(mA)  RX power(dBm)  TX power(dBm)
    30         3.36        7.82      -35.64         -2.23
  Alarm thresholds:
    High  73         3.80        13.20     1.00           0.00
    Low   -3         2.81        1.00      -9.50          -10.30
Table 12 Command output
Digital diagnosis information for the transceiver module in the interface.
Temp.(°C)
Temperature in °C, accurate to 1°C.
Voltage(V)
Voltage in V, accurate to 0.01 V.
Bias(mA)
Bias current in mA, accurate to 0.01 mA.
RX power(dBm)
RX power in dBm, accurate to 0.01 dBm.
TX power(dBm)
TX power in dBm, accurate to 0.01 dBm.
Use display transceiver interface to display the key parameters of transceiver modules.
interface-type interface-number: Specifies an interface by its type and number. If you do not specify this option, the command displays the key parameters of every transceiver module.
# Display the key parameters of the transceiver module in interface Ten-GigabitEthernet 1/1/1.
<Sysname> display transceiver interface ten-gigabitethernet 1/1/1
Ten-GigabitEthernet1/1/1 transceiver information:
  Transceiver Type              : 10G_BASE_SR_SFP
  Connector Type                : LC
  Wavelength(nm)                : 850
  Transfer Distance(m)          : 80(OM2),20(OM1),300(OM3)
  Digital Diagnostic Monitoring : YES
  Vendor Name                   : FINISAR CORP.
Table 13 Command output
Transceiver information.
Transceiver Type
Transceiver type.
Connector Type
Connector type options:
·     SC—Fiber connector developed by NTT.
·     LC—1.25 mm/RJ-45 fiber connector developed by Lucent.
·     RJ-45.
·     CX 4.
Wavelength(nm)
·     Fiber transceiver: Central wavelength (in nm) of the transmit laser. If the transceiver supports multiple wavelengths, every two wavelength values are separated by a comma.
·     Copper cable: Displayed as N/A.
Transfer Distance(xx)
Transmission distance, where xx indicates the distance unit:
·     km—Kilometers, for single-mode transceiver modules.
·     m—Meters, for other transceiver modules.
If the transceiver module supports multiple types of transmission media, this field displays the transmission distance for each type, in the form transmission distance (medium type).
Transmission medium types include:
·     9 um—9/125 µm single-mode fiber.
·     50 um—50/125 µm multimode fiber.
·     62.5 um—62.5/125 µm multimode fiber.
·     TP—Twisted pair.
·     CX4—CX4 cable.
Support for the digital diagnosis feature:
·     YES—Supported.
·     NO—Not supported.
Ordering Name
Product code.
Use display transceiver manuinfo to display electronic label information for transceiver modules.
interface [ interface-type interface-number ]: Specifies an interface by its type and number. If no interface is specified, this command displays electronic label information for the transceiver modules on all interfaces.
This command displays only part of the electronic label information.
# Display electronic label information for the transceiver module in interface Ten-GigabitEthernet 1/1/1.
<Sysname> display transceiver manuinfo interface ten-gigabitethernet 1/1/1
Ten-gigabitethernet 1/1/1 transceiver manufacture information:
  Manu. Serial Number  : 213410A0000054000251
  Manufacturing Date   : 2012-09-01
  Vendor Name          : H3C
Table 14 Command output
Manu. Serial Number
Serial number generated during production of the transceiver module.
Manufacturing Date
Date when the electronic label information was written to the transceiver module.
display version
Use display version to display system version information.
display version
# Display system version information.
<Sysname> display version
H3C S7502E-XS uptime is 0 weeks, 0 days, 1 hour, 4 minutes
Boot image: flash:/S7500EXS-CMW710-BOOT-test.bin
Boot image version: 7.1.045, Beta 7176P01
  Compiled Aug 10 2015 12:10:21
System image: flash:/S7500EXS-CMW710-SYSTEM-test.bin
System image version: 7.1.045, Beta 7176P01
Slot 1:
Uptime is 0 weeks,0 days,1 hour,4 minutes
H3C S7502E-XS with 2 Processors
BOARD TYPE:         S7502E-XS
DRAM:               4096M bytes
FLASH:              1024M bytes
PCB 1 Version:      VER.A
PCB 2 Version:      VER.A
Bootrom Version:    214
CPLD 1 Version:     001
CPLD 2 Version:     003
PowChip Version:    None
Release Version:    H3C S7502E-XS-7176P01
Patch Version  :    None
Reboot Cause  :     ColdReboot
[SubSlot 0] Main Board with 2*QSFP Plus
[SubSlot 2] 24*SFP Plus(MacSec) + 2*QSFP Plus
Use display version-update-record to display the startup software image upgrade history records for the master device.
The device records its current startup software version information and all subsequent version update information. Such information can survive reboots.
The maximum number of records is 10.
# Display the startup software image upgrade history records.
<Sysname> display version-update-record
Name                                   Version            Compile time
Record 1  (updated on Jan 01 2011 at 00:39:44):
 S7500EXS-CMW710-BOOT-TEST.bin    7.1.045 Beta 7176P01 Aug 10 2015 12:10:
21
 S7500EXS-CMW710-SYSTEM-TEST.bin  7.1.045 Beta 7176P01 Aug 10 2015 12:10:
21
 S7500EXS-CMW710-DEVKIT-TEST.bin  7.1.045 Beta 7176P01 Aug 10 2015 12:10:
21
 S7500EXS-CMW710-MANUFACTURE-TEST.bin 7.1.045 Beta 7176P01 Aug 10 2015 12
:10:21
Table 15 Command output
Name
Software image file name.
The new software image is different from the old one.
Use fan prefer-direction to specify the preferred airflow direction.
Use undo fan prefer-direction to restore the default.
fan prefer-direction slot slot-number { power-to-port | port-to-power }
undo fan prefer-direction slot slot-number
The default preferred airflow direction is from the power supply side to the port side.
slot slot-number: Specifies an IRF member device by its member ID, or a PEX by its virtual slot number.
power-to-port: Specifies the airflow direction from the power supply side to the port side.
port-to-power: Specifies the airflow direction from the port side to the power supply side.
This command is available only for parent devices and the following PEXs:
·     S5120-28SC-HI switches.
·     S5130-EI switches.
·     S6300 switches.
# Set the preferred airflow direction to port-to-power for member device 1.
[Sysname] fan prefer-direction slot 1 port-to-power
display fan
Use hardware-failure-detection to specify the action to be taken in response to device hardware failures.
Use undo hardware-failure-detection to restore the default.
hardware-failure-detection { board | chip | forwarding } { isolate | off | reset | warning }
undo hardware-failure-detection { board | chip | forwarding }
The system takes the action of warning in response to device hardware failures.
board: Specifies control path failures and device status problems.
chip: Specifies failures on components such as the chips, capacitances, resistances.
forwarding: Specifies failures on the forwarding plane (including services and other relevant items).
isolate: Shuts down the relevant ports to reduce impact from the failures.
off: Takes no action.
reset: Restarts the relevant components to recover from failures.
warning: Sends traps to notify you of the failures.
The device automatically detects hardware failures on components, cards, and the forwarding plane. You can specify the actions to be taken in response to detected failures.
# Configure the device to send traps in response to failures on components.
[Sysname] hardware-failure-detection chip warning
header
Use header to create a banner.
Use undo header to clear a banner.
header { incoming | legal | login | motd | shell } text
undo header { incoming | legal | login | motd | shell }
No banner is configured.
incoming: Configures the banner to be displayed before a modem dial-in user accesses user view. If authentication is required, the incoming banner appears after the authentication is passed. Modem dial-in is not supported in the current software version.
legal: Configures the banner to be displayed before a user inputs the username and password to access the CLI.
login: Configures the banner to be displayed before password or scheme authentication is performed for a login user.
motd: Configures the greeting banner to be displayed before the legal banner appears.
shell: Configures the banner to be displayed before a non-modem dial-in user accesses user view.
text: Specifies the banner message, which can be entered in two formats. For more information, see Fundamentals Configuration Guide.
# Create the legal banner, login banner, MOTD banner, and shell banner.
[Sysname] header legal
Welcome to legal (header legal)%
[Sysname] header login
Welcome to login(header login)%
[Sysname] header motd
Welcome to motd(header motd)%
[Sysname] header shell
Welcome to shell(header shell)%
In this example, the percentage sign (%) is the starting and ending character of the text argument. Entering the percentage sign after the text quits the header command. Because it is the starting and ending character, the percentage sign is not included in the banner.
# Test the configuration by using Telnet. The login banner appears only when password or scheme login authentication has been configured.
* Copyright (c) 2004-2014 Hangzhou H3C Tech. Co., Ltd. All rights reserved.  *
 Press Y or ENTER to continue, N to exit.
Login authentication
Password:
job
Use job to assign a job to a schedule.
Use undo job to revoke a job.
job job-name
undo job job-name
No job is assigned to a schedule.
Schedule view
job-name: Specifies the job name, a case-sensitive string of 1 to 47 characters.
You can assign multiple jobs to a schedule. The jobs in a schedule are executed concurrently.
The jobs to be assigned to a schedule must already exist. To create a job, use the scheduler job command.
# Assign job save-job to schedule saveconfig.
[Sysname] scheduler schedule saveconfig
[Sysname-schedule-saveconfig] job save-job
·     scheduler job
·     scheduler schedule
memory-threshold
Use memory-threshold to set free-memory thresholds.
Use undo memory-threshold to restore the defaults.
memory-threshold [ slot slot-number [ cpu cpu-number ] ] minor minor-value severe severe-value critical critical-value normal normal-value
undo memory-threshold [ slot slot-number [ cpu cpu-number ] ]
·     Minor alarm threshold: 96 MB.
·     Severe alarm threshold: 64 MB.
·     Critical alarm threshold: 48 MB.
·     Normal state threshold: 128 MB.
minor minor-value: Specifies the minor alarm threshold. This threshold must be equal to or less than the normal state threshold. Setting this threshold to 0 disables the minor alarm feature.
severe severe-value: Specifies the severe alarm threshold. This threshold must be equal to or less than the minor alarm threshold. Setting this threshold to 0 disables the severe alarm feature.
critical critical-value: Specifies the critical alarm threshold. This threshold must be equal to or less than the severe alarm threshold. Setting this threshold to 0 disables the critical alarm feature.
normal normal-value: Specifies the normal state threshold. This threshold must be equal to or less than the total memory size.
slot slot-number: Specifies an IRF member device by its member ID or specifies a PEX by its virtual slot number. If you do not specify a member device or PEX, this command sets free-memory thresholds for the master device.
cpu cpu-number: Specifies a CPU by its number. If you do not specify this option, the command sets free-memory thresholds for the default CPU.
To ensure correct operation and improve memory efficiency, the system monitors the amount of free memory space in real time. When a threshold is exceeded, the system sends an alarm notification or an alarm-removed notification to affected feature modules or processes so they can take countermeasures. For more information about the thresholds, see Fundamentals Configuration Guide.
# Set the minor alarm, severe alarm, critical alarm, and normal state thresholds to 64 MB, 48 MB, 32 MB, and 96 MB, respectively.
[Sysname] memory-threshold minor 64 severe 48 critical 32 normal 96
Use memory-threshold usage to set the memory usage threshold.
Use undo memory-threshold usage to restore the default.
undo memory-threshold [ slot slot-number [ cpu cpu-number ] ] usage
The memory usage threshold is 100.
memory-threshold: Specifies the memory usage threshold in percentage. The value range is 0 to 100.
slot slot-number: Specifies an IRF member device by its member ID or specifies a PEX by its virtual slot number. If you do not specify a member device or PEX, this command sets the memory usage threshold for the master device.
cpu cpu-number: Specifies a CPU by its number. If you do not specify this option, the command sets the memory usage threshold for the default CPU.
The device samples memory usage at an interval of 1 minute. If the sample is greater than the memory usage threshold, the device sends a trap.
# Set the memory usage threshold to 80%.
[Sysname] memory-threshold slot 1 cpu 0 usage 80
Use monitor cpu-usage enable to enable CPU usage monitoring.
Use undo monitor cpu-usage enable to disable CPU usage monitoring.
undo monitor cpu-usage enable [ slot slot-number [ cpu cpu-number ] ]
CPU usage monitoring is enabled.
slot slot-number: Specifies an IRF member device by its member ID or specifies a PEX by its virtual slot number. If you do not specify a member device or PEX, this command enables CPU usage monitoring for the master device.
cpu cpu-number: Specifies a CPU by its number. If you do not specify this option, the command enables CPU usage monitoring for the default CPU.
After CPU usage monitoring is enabled, the system samples and saves CPU usage at the interval specified by the monitor cpu-usage interval command. You can use the display cpu-usage history command to view recent CPU usage.
# Enable CPU usage monitoring.
[Sysname] monitor cpu-usage enable
·     display cpu-usage configuration
·     display cpu-usage history
Use monitor cpu-usage interval to set the sampling interval for CPU usage monitoring.
monitor cpu-usage interval interval-value [ slot slot-number [ cpu cpu-number ] ]
The system samples CPU usage every 1 minute.
interval-value: Specifies the sampling interval for CPU usage monitoring. Valid values include 5Sec for 5 seconds, 1Min for 1 minute, and 5Min for 5 minutes.
slot slot-number: Specifies an IRF member device by its member ID or specifies a PEX by its virtual slot number. If you do not specify a member device or PEX, this command sets the interval for the master device.
cpu cpu-number: Specifies a CPU by its number. If you do not specify this option, the command sets the interval for the default CPU.
After CPU usage monitoring is enabled, the system samples and saves CPU usage at the specified interval. You can use the display cpu-usage history command to view recent CPU usage.
# Set the sampling interval for CPU usage monitoring to 5 seconds.
[Sysname] monitor cpu-usage interval 5Sec
Use monitor cpu-usage threshold to set the CPU usage threshold.
Use undo monitor cpu-usage threshold to restore the default.
monitor cpu-usage threshold cpu-threshold [ slot slot-number [ cpu cpu-number ] ]
undo monitor cpu-usage threshold [ slot slot-number [ cpu cpu-number ] ]
The CPU usage threshold is 99.
cpu-threshold: Specifies the CPU usage threshold in percentage. The value range is 0 to 100.
slot slot-number: Specifies an IRF member device by its member ID or specifies a PEX by its virtual slot number. If you do not specify a member device or PEX, this command sets the CPU usage threshold for the master device.
cpu cpu-number: Specifies a CPU by its number. If you do not specify this option, the command sets the CPU usage threshold for the default CPU.
The device samples CPU usage at an interval of 1 minute. If the sample is greater than the CPU usage threshold, the device sends a trap.
# Set the CPU usage threshold to 80%.
[Sysname] monitor cpu-usage threshold 80
reboot
Use reboot to reboot an IRF member device, an interface card, or all IRF member devices.
reboot [ slot slot-number [ subslot subslot-number ] ] [ force ]
force: Reboots the device immediately without performing software or hard disk check. If this keyword is not specified, the system first checks whether the reboot might result in data loss or a system failure. For example, the system checks whether the main system software image file exists and whether a write operation is in progress on a storage medium. If the reboot might cause problems, the system does not reboot the device.
CAUTION
CAUTION:
·     A device reboot might interrupt network services.
·     If the main startup software images are corrupt or missing, you must re-specify a set of main startup software images before executing the reboot command.
·     Use the force keyword only when the device fails or a reboot command without the force keyword cannot perform a reboot correctly. A reboot command with the force keyword might result in file system corruption because it does not perform data protection.
For data security, the device does not reboot if you reboot the device while the device is performing file operations.
To reboot an interface card, specify both the IRF member ID and the subslot number.
To reboot an IRF member device or PEX, specify only the IRF member ID or virtual slot number.
To reboot all IRF member devices and PEXs, do not specify the slot number option.
# Reboot the device when no configuration change has occurred since the last time you saved the running configuration.
<Sysname> reboot
Now rebooting, please wait...
# If any configuration has changed, reboot the device and save the configuration.
<Sysname> reboot
Current configuration will be lost after the reboot, save current configuration? [Y/N]:y
Configuration is saved to flash successfully.
# If any configuration has changed, reboot the device but do not save the configuration.
<Sysname> reboot
Current configuration will be lost after the reboot, save current configuration? [Y/N]:n
# Reboot the device immediately without performing software check.
<Sysname> reboot force
A forced reboot might cause the storage medium to be corrupted. Continue? [Y/N]:y
Use reset version-update-record to clear the startup software image upgrade history records for the master device.
# Clear the startup software image upgrade history records.
[Sysname] reset version-update-record
This command will delete all records of version update. Continue? [Y/N]:y
Use reset scheduler logfile to clear job execution log information.
# Clear job execution log information.
<Sysname> reset scheduler logfile
Use restore factory-default to restore the factory-default configuration for the device.
CAUTION
CAUTION:
This command is disruptive. Use this command only when you cannot troubleshoot the device by using other methods, or you want to use the device in a different scenario.
This command performs the following tasks:
·     Deletes all configuration files (.cfg files) in the root directories of the storage media.
·     Deletes all log files (.log files in the folder /logfile).
·     Clears all log information (in the log buffer), trap information, and debugging information.
·     Restores the parameters for the BootWare to the factory-default settings.
·     Deletes all license files (.ak files).
After this command is executed, only the items required for fundamental device operation are retained, including the .bin files, the MAC addresses, and the electronic label information.
# Restore the factory-default configuration for the device.
<Sysname> restore factory-default
This command will restore the system to the factory default configuration and clear the operation data. Continue [Y/N]:y
Restoring the factory default configuration. This process might take a few minutes. Please wait..........................................................................................................Done.
Please reboot the system to place the factory default configuration into effect.
reboot
scheduler job
Use scheduler job to create a job and enter job view. If the job already exists, you enter job view directly.
Use undo scheduler job to delete a job.
scheduler job job-name
undo scheduler job job-name
No job exists.
A job can be referenced by multiple schedules. In job view, you can assign commands to the job.
# Create a job named backupconfig and enter job view.
·     command
Use scheduler logfile size to set the size of the job execution log file.
scheduler logfile size value
The size of the job execution log file is 16 KB.
value: Sets the size of the job execution log file, in KB. The value range is 16 to 1024.
The job execution log file saves the execution information of jobs. If the file is full, old records are deleted to make room for new records. If the size of the log information to be written to the file is greater than the file size, the excessive information is not written to the file.
# Set the size of the job execution log file to 32 KB.
[Sysname] scheduler logfile size 32
scheduler reboot at
Use scheduler reboot at to specify the reboot date and time.
Use undo scheduler reboot to delete the reboot schedule configuration.
No reboot date or time is specified.
time: Specifies the reboot time in the hh:mm format. The value range for hh is 0 to 23. The value range for mm is 0 to 59.
date: Specifies the reboot date in the MM/DD/YYYY or YYYY/MM/DD format. The value range for YYYY is 2000 to 2035. The value range for MM is 1 to 12. The value range for DD varies by month.
CAUTION
CAUTION:
Device reboot interrupts network services.
When the date argument is not specified, the system uses the following rules to determine the reboot time:
·     If the reboot time is later than the current time, a reboot occurs at the reboot time of the current day.
·     If the reboot time is earlier than the current time, a reboot occurs at the reboot time the next day.
For data security, if you are performing file operations at the reboot time, the system does not reboot.
The device supports only one device reboot schedule. If you configure both the schedule reboot delay and schedule reboot delay commands or configure one of the commands multiple times, the most recent configuration takes effect.
# Configure the device to reboot at 12:00 p.m. This example assumes that the current time is 11:43 a.m. on June 6, 2011.
<Sysname> scheduler reboot at 12:00
Reboot system at 12:00:00 06/06/2011 (in 0 hours and 16 minutes). Confirm? [Y/N]:
Use scheduler reboot delay to specify the reboot delay time.
scheduler reboot delay time
No reboot delay time is specified.
time: Specifies the reboot delay time in the hh:mm or mm format. This argument can contain up to six characters. When in the hh:mm format, mm must be in the range of 0 to 59.
CAUTION
CAUTION:
# Configure the device to reboot after 88 minutes. This example assumes that the current time is 11:48 a.m. on June 6, 2011.
<Sysname> scheduler reboot delay 88
Reboot system at 13:16 06/06/2011(in 1 hours and 28 minutes). Confirm? [Y/N]:
scheduler schedule
Use scheduler schedule to create a schedule and enter schedule view. If the schedule already exists, you enter schedule view directly.
Use undo scheduler schedule to delete a schedule.
undo scheduler schedule schedule-name
No schedule exists.
schedule-name: Specifies the schedule name, a case-sensitive string of 1 to 47 characters.
You can configure a schedule to have the device automatically run a command or a set of commands without administrative interference.
To configure a schedule:
1.     Use the scheduler job command to create a job and enter job view.
2.     Use the command command to assign commands to the job.
3.     Use the scheduler schedule command to create a schedule and enter schedule view.
4.     Use the job command to assign the job to the schedule. You can assign multiple jobs to a schedule. The jobs must already exist.
5.     Use the user-role command to assign user roles to the schedule. You can assign up to 64 user roles to a schedule.
6.     Use the time at, time once, or time repeating command to specify an execution time for the schedule. You can specify only one execution time for a schedule.
# Create a schedule named saveconfig.
·     job
·     time at
·     time once
shutdown-interval
Use shutdown-interval to set the port status detection timer.
Use undo shutdown-interval to restore the default.
shutdown-interval time
The port status detection interval is 30 seconds.
time: Specifies a port status detection timer (in seconds) in the range of 0 to 300. To disable port status detection, set this argument to 0.
The device starts a detection timer when a port is shut down by a protocol. Once the timer expires, the device brings up the port so the port status reflects the port's physical status.
If you change the timer during port detection, the device compares the new setting (T1) with the time that elapsed since the port was shut down (T).
·     If T < T1, the port will be brought up after T1 – T seconds.
·     If T ≥ T1, the port is brought up immediately.
For example, the timer is 30 seconds. If you change it to 10 seconds 2 seconds after the port is shut down, the port will come up 8 seconds later. If you change the timer to 2 seconds 10 seconds after the port is shut down, the port comes up immediately.
# Set the port status detection timer to 100 seconds.
[Sysname] shutdown-interval 100
switch-mode
Use switch-mode to set the table capacity mode.
switch-mode { bridging | mix-bridging-routing | routing }
The table capacity mode is mix-bridging-routing.
bridging: Sets the table capacity mode to bridging.
mix-bridging-routing: Sets the table capacity mode to mix-bridging-routing.
routing: Sets the table capacity mode to routing.
The device supports multiple table capacity modes. The capacities of the MAC address table and routing tables vary by table capacity mode. For more information, see Fundamentals Configuration Guide.
A table capacity mode change takes effect after a reboot. Before rebooting the switch, make sure you know the possible impact on the network.
# Set the table capacity mode to routing.
[Sysname] switch-mode routing
Reboot device to make the configuration take effect.
sysname
Use sysname to set the device name.
Use undo sysname to restore the default.
sysname sysname
undo sysname
The default device name is H3C.
sysname: Specifies a name for the device, a string of 1 to 64 characters.
A device name identifies a device in a network and is used as the user view prompt at the CLI. For example, if the device name is Sysname, the user view prompt is <Sysname>.
# Set the name of the device to R2000.
[Sysname] sysname R2000
[R2000]
system-working-mode
Use system-working-mode to set the system operating mode.
Use undo system-working-mode to restore the default.
system-working-mode { advance | standard }
The device operates in standard mode.
advance: Sets the system operating mode to advanced.
standard: Sets the system operating mode to standard.
The supported features and the specifications of the supported features vary by system operating mode. For example, the FCoE feature is supported only in advanced mode.
If the command displays the Not enough hardware resources available. error message, perform the following tasks before trying again:
·     Use the display qos-acl resource command to display the current ACL resource usage information.
·     Use the undo acl command to release used ACL resources as required.
For more information about the display qos-acl resource and undo acl commands, see ACL and QoS Command Reference.
After changing the operating mode, you must reboot the device to make the device operate in the new mode.
# Set the system operating mode to advanced.
[Sysname] system-working-mode advance
Do you want to change the system working mode? [Y/N]:y
The system working mode is changed, please save the configuration and reboot the
 system to make it effective.
temperature-limit
Use temperature-limit to set the temperature alarm thresholds for the device.
Use undo temperature-limit to restore the default.
temperature-limit slot slot-number hotspot sensor-number lowlimit warninglimit [ alarmlimit ]
undo temperature-limit slot slot-number hotspot sensor-number
To view the default thresholds, use the undo temperature-limit command to restore the default and execute the display environment command.
slot slot-number: Specifies an IRF member device by its member ID.
hotspot: Configures temperature alarm thresholds for hotspot sensors. A hotspot sensor is typically near the chip that generates a great amount of heat and used to monitor the chip.
sensor-number: Specifies a sensor by its number, an integer starting from 1. Each number represents a temperature sensor on the device.
lowlimit: Specifies the low-temperature threshold in Celsius degrees.
warninglimit: Specifies the high-temperature warning threshold in Celsius degrees. This threshold must be greater than the low-temperature threshold.
alarmlimit: Specifies the high-temperature alarming threshold in Celsius degrees. This threshold must be greater than the high-temperature warning threshold.
When the temperature drops below the low-temperature threshold or reaches the high-temperature warning threshold, the device sends a log message and a trap.
When the temperature reaches the high-temperature alarming threshold, the device sends log messages and traps repeatedly and sets LEDs on the device.
Different devices have different threshold value ranges. To view the value ranges, use the CLI online help.
# Set temperature alarm thresholds for hotspot sensor 1 on IRF member device 1.
[sysname] temperature-limit slot 1 hotspot 1 -5 80 95
time at
Use time at to specify an execution date and time for a non-periodic schedule.
Use undo time to delete the execution date and time configuration for a non-periodic schedule.
time at time date
undo time
No execution time or date is specified for a non-periodic schedule.
Schedule view
time: Specifies the schedule execution time in the hh:mm format. The value range for hh is 0 to 23. The value range for mm is 0 to 59.
date: Specifies the schedule execution date in the MM/DD/YYYY or YYYY/MM/DD format. The value range for YYYY is 2000 to 2035. The value range for MM is 1 to 12. The value range for DD varies by month.
The specified time (date plus time) must be later than the current system time.
The time at command, the time once command, and the time repeating command overwrite one another. The most recently configured command takes effect.
# Configure the device to execute schedule saveconfig at 01:01 a.m. on May 11, 2011.
[Sysname-schedule-saveconfig] time at 1:1 2011/05/11
scheduler schedule
time once
Use time once to specify one or more execution days and the execution time for a non-periodic schedule.
Use undo time to delete the execution day and time configuration for a non-periodic schedule.
time once delay time
undo time
No execution time or day is specified for a non-periodic schedule.
Schedule view
at time: Specifies the execution time in the hh:mm format. The value range for hh is 0 to 23. The value range for mm is 0 to 59.
month-date month-day: Specifies a day in the current month, in the range of 1 to 31. If you specify a day that does not exist in the current month, the configuration takes effect on that day in the next month.
week-day week-day&<1-7>: Specifies a space-separated list of up to seven week days for the schedule. Valid week day values include Mon, Tue, Wed, Thu, Fri, Sat, and Sun.
delay time: Specifies the delay time for executing the schedule, in the hh:mm or mm format. This argument can contain up to six characters. When in the hh:mm format, mm must be in the range of 0 to 59.
If the specified time has already occurred, the schedule will be executed at the specified time the following day.
If the day in the month has already occurred, the schedule will be executed at the specified day in the following month.
If the specified day in a week has already occurred, the schedule will be executed at the specified day in the following week.
# Configure the device to execute schedule saveconfig once at 15:00.
[Sysname-schedule-saveconfig] time once at 15:00
Schedule starts at 15:00 5/11/2011.
# Configure the device to execute schedule saveconfig once at 15:00 on the coming 15th day in a month.
[Sysname-schedule-saveconfig] time once at 15:00 month-date 15
# Configure the device to execute schedule saveconfig at 12:00 p.m. on the coming Monday and Friday.
[Sysname-schedule-saveconfig] time once at 12:00 week-day mon fri
# Configure the device to execute schedule saveconfig after 10 minutes.
[Sysname-schedule-saveconfig] time once delay 10
scheduler schedule
time repeating
Use time repeating to specify an execution time table for a periodic schedule.
Use undo time to delete the execution time table configuration for a periodic schedule.
time repeating [ at time [ date ] ] interval interval-time
undo time
No execution time table is specified for a periodic schedule.
Schedule view
at time: Specifies the execution time in the hh:mm format. The value range for hh is 0 to 23. The value range for mm is 0 to 59. If you do not specify this option, the current system time is used as the execution time.
date: Specifies the start date for the periodic schedule, in the MM/DD/YYYY or YYYY/MM/DD format. The value range for YYYY is 2000 to 2035. The value range for MM is 1 to 12. The value range for DD varies by month. If you do not specify this argument, the execution start date is the first day when the specified time arrives.
interval interval-time: Specifies the execution time interval in the hh:mm or mm format. This argument can contain up to six characters. When in the hh:mm format, mm must be in the range of 0 to 59. When in the mm format, this argument must be equal to or greater than 1 minute.
month-date [ month-day | last ]: Specifies a day in a month, in the range 1 to 31. The last keyword indicates the last day of a month. If you specify a day that does not exist in a month, the configuration takes effect on that day in the next month.
The time repeating [ at time [ date ] ] interval interval-time command configures the device to execute a schedule at an interval from the specified time on.
The time repeating at time [ month-date [ month-day | last ] | week-day week-day&<1-7> ] command configures the device to execute a schedule at the specified time on every specified day in a month or week.
The time at command, the time once command, and the time repeating command overwrite one another, whichever is configured most recently takes effect.
# Configure the device to execute schedule saveconfig once a hour from 8:00 a.m. on.
[Sysname-schedule-saveconfig] time repeating at 8:00 interval 60
# Configure the device to execute schedule saveconfig at 12:00 p.m. every day.
[Sysname-schedule-saveconfig] time repeating at 12:00
# Configure the device to execute schedule saveconfig at 8:00 a.m. on the 5th of every month.
[Sysname-schedule-saveconfig] time repeating at 8:00 month-date 5
# Configure the device to execute schedule saveconfig at 8:00 a.m. on the last day of every month.
[Sysname-schedule-saveconfig] time repeating at 8:00 month-date last
# Configure the device to execute schedule saveconfig at 8:00 a.m. every Friday and Saturday.
[Sysname-schedule-saveconfig] time repeating at 8:00 week-day fri sat
scheduler schedule
transceiver phony-alarm-disable
Use transceiver phony-alarm-disable to disable alarm traps for transceiver modules.
Use undo transceiver phony-alarm-disable to restore the default.
Alarm traps are enabled for transceiver modules.
Disable alarm traps if the transceiver modules were manufactured or sold by H3C.
The device regularly detects transceiver modules that have a vendor name other than H3C or do not have a vendor name. Upon detecting such a transceiver module, the device repeatedly outputs traps and logs to notify the user to replace the module.
# Disable alarm traps for transceiver modules.
[Sysname] transceiver phony-alarm-disable
user-role
Use user-role to assign user roles to a schedule.
Use undo user-role to remove user roles from a schedule.
user-role role-name
undo user-role role-name
A schedule has the user roles of the schedule creator.
Schedule view
role-name: Specifies a user role name, a case-sensitive string of 1 to 63 characters. The user role can be user-defined or predefined. Predefined user roles include network-admin, network-operator, and level-0 to level-15.
A schedule must have one or more user roles. A command in a schedule can be executed if it is permitted by one or more user roles of the schedule. For more information about user roles, see the RBAC configuration in Fundamentals Configuration Guide.
A schedule can have a maximum of 64 user roles. After the limit is reached, you cannot assign additional user roles to the schedule.
# Assign user role rolename to schedule test.
<sysname> system-view
[Sysname] scheduler schedule test
[Sysname-schedule-test] user-role rolename
·     command
