01-Fundamentals Command Reference
HomeSupportSwitchesS10500 SeriesReference GuidesCommand ReferencesH3C S10500 Switch Series Command References-Release7178-6W10001-Fundamentals Command Reference
12-Password recovery control command
12-Password recovery control command 31.43 KB
password-recovery enable
Use password-recovery enable to enable password recovery capability.
Use undo password-recovery enable to disable password recovery capability.
Password recovery capability is enabled.
Password recovery capability controls console user access to the device configuration and SDRAM from BootWare menus.
If password recovery capability is enabled, a console user can access the device configuration without authentication to configure new passwords.
If password recovery capability is disabled, console users must restore the factory-default configuration before they can configure new passwords. Restoring the factory-default configuration deletes the next-startup configuration files.
To enhance system security, disable password recovery capability.
This command is supported only on the default MDC. For more information about MDC, see Virtual Technologies Configuration Guide.
Table 1 summarizes options whose availability depends on the password recovery capability setting.
Table 1 BootWare options and password recovery capability compatibility matrix
BootWare menu option
Password recovery enabled
Password recovery disabled
Tasks that can be performed
Download Image Program To SDRAM And Run
Yes
No
Load a system software image to SDRAM and run it.
Download Files(*.*)
Yes
No
Download a file to the current storage medium.
Skip Authentication for Console Login
Yes
No
Enable console login without authentication.
This is a one-time operation. It takes effective only for the first system boot or reboot after you choose this option.
Skip Current System Configuration
Yes
No
Load the factory-default configuration without deleting the next-startup configuration file.
This is a one-time operation. It takes effective only for the first system boot or reboot after you perform the operation.
Restore to Factory Default Configuration
No
Yes
Delete the next-startup configuration file and load the factory-default configuration.
# Disable password recovery capability.
[Sysname] undo password-recovery enable
