01-Fundamentals Command Reference
HomeSupportSwitchesS10500 SeriesReference GuidesCommand ReferencesH3C S10500 Switch Series Command References-Release7178-6W10001-Fundamentals Command Reference
06-Configuration file management commands
06-Configuration file management commands 109.74 KB
archive configuration
Use archive configuration to manually archive the running configuration to the configuration archive directory.
Before manually archiving the running configuration, you must use the archive configuration location command to specify a directory and a name prefix for the configuration archives.
Configuration archive facilitates configuration rollback. It provides manual and automatic methods for saving the running configuration as checkpoint references. For more information about the archiving mechanism, see the section about configuration rollback in Fundamentals Configuration Guide.
# Archive the running configuration.
<Sysname> archive configuration
Save the running configuration to an archive file. Continue? [Y/N]: Y
The archive configuration file myarchive_1.cfg is saved.
·     archive configuration interval
·     archive configuration location
·     archive configuration max
·     display archive configuration
Use archive configuration interval to enable automatic running-configuration archiving and set the archiving interval.
Use undo archive configuration interval to restore the default.
archive configuration interval minutes
The system does not automatically archive the running configuration.
minutes: Specifies the interval (in minutes) for automatically saving the running configuration. The value range is 10 to 525600 (365 days).
Before enabling automatic configuration archiving, use the archive configuration location command to specify the configuration archive directory and archive file name prefix.
Configuration archive is a function that facilitates configuration rollback. It provides manual and automatic methods for saving the running configuration.
Automatic configuration archiving enables the system to periodically save the running configuration to the archive directory automatically. After the system finishes an automatic archive, it resets the archiving interval timer. For more information about the archiving mechanism, see the section about configuration rollback in Fundamentals Configuration Guide.
# Configure the system to archive the running configuration every 60 minutes.
[Sysname] archive configuration interval 60
Archive files will be saved every 60 minutes.
Use archive configuration location to configure the directory and file name prefix for archiving the running configuration.
Use undo archive configuration location to restore the default.
archive configuration location directory filename-prefix filename-prefix
No configuration archive directory or configuration archive file name prefix has been set.
directory: Specifies the name of a configuration archive directory, a case-insensitive string of 1 to 63 characters. The value for this argument must take the format storage-medium-name:/folder-name. The directory must already exist on the active MPU in standalone mode or exist on the global active MPU in IRF mode.
filename-prefix: Specifies a file name prefix for configuration archives, a case-insensitive string of 1 to 30 characters. Valid characters are letters, digits, underscores (_), and hyphens (-).
Before archiving the running configuration, either manually or automatically, you must configure a directory and file name prefix for configuration archives.
In standalone mode, the configuration archive function saves the running configuration only on the active MPU. In IRF mode, the function saves the running configuration only on the active MPU in the master device. To make sure the system can archive running configuration after an active/standby or master/subordinate switchover, create the configuration archive directory on all MPUs.
Configuration archives take the file name format prefix_serial number.cfg, for example, 20080620archive_1.cfg and 20080620archive_2.cfg. The serial number is automatically assigned from 1 to 1000, increasing by 1. After the serial number reaches 1000, it restarts from 1.
After you change the file directory or file name prefix, or reboot the device, all of the following events occur:
·     The old configuration archives are regarded as common configuration files.
·     The configuration archive counter is reset.
·     The display archive configuration command no longer displays the old configuration archives.
·     The serial number for new configuration archives starts at 1.
The undo archive configuration location command removes the configuration archive directory and file name prefix settings. The command also performs the following operations:
·     Disables the configuration archive function (both manual and automatic methods).
·     Restores the default settings of the archive configuration interval and archive configuration max commands.
·     Clears the configuration archive information displayed by using the display archive configuration command.
# Configure the configuration archive directory as flash:/archive/ and the archive file name prefix as my_archive.
<Sysname> mkdir flash:/archive
Creating directory flash:/archive... Done.
[Sysname] archive configuration location flash:/archive filename-prefix my_archive
Use archive configuration max to set the maximum number of configuration archives.
Use undo archive configuration max to restore the default.
archive configuration max file-number
Up to five configuration archives can be saved.
file-number: Specifies the maximum number of configuration archives that can be saved. The value range is 1 to 10. Adjust the setting depending on the amount of storage space available.
Before you can set a limit on configuration archives, use the archive configuration location command to specify a configuration archive directory and archive file name prefix.
After the maximum number of configuration archives is reached, the system deletes the oldest archive for the new archive.
Changing the limit setting to a lower value does not cause immediate deletion of excess archives. Instead, the configuration archive function deletes the oldest n files when a new archive is manually or automatically saved, where n = current archive count – new archive limit + 1.
Suppose seven configuration archives have been saved before the archive limit is set to four. When saving a new configuration archive, the system first deletes the oldest four (7 – 4 + 1) archives.
If you execute the undo archive configuration location command, the default archive limit is restored.
# Set the maximum number of configuration archives to 10.
[Sysname] archive configuration max 10
backup startup-configuration
Use backup startup-configuration to back up the main next-startup configuration file to a TFTP server.
backup startup-configuration to tftp-server [ dest-filename ]
tftp-server: Specifies a TFTP server by its IPv4 address or host name. The host name is a case-insensitive string of 1 to 253 characters. Valid characters include letters, digits, hyphens (-), underscores (_), and dots (.).
dest-filename: Specifies the target file name used for saving the file on the server, a case-insensitive string of 1 to 255 characters. The file name must use the .cfg extension. If you do not specify a target file name, the source file name is used.
This command is not supported in FIPS mode.
# Back up the main next-startup configuration file to the TFTP server at 2.2.2.2, and set the target file name to 192-168-1-26.cfg.
<Sysname> backup startup-configuration to 2.2.2.2 192-168-1-26.cfg
Backup next startup-configuration file to 2.2.2.2, please wait…finished
restore startup-configuration
configuration commit
Use configuration commit to commit the settings configured after the configuration commit delay command was executed.
You must execute the configuration commit delay command before executing this command.
As a best practice, enable the information center and configure the information center to output logs to the console. Determine whether to commit the settings depending on the logs. For more information about the information center, see Network Management and Monitoring Configuration Guide.
# Set the allowed delay time to 10 minutes for a manual commit to keep the settings configured subsequently in effect.
[Sysname] configuration commit delay 10
# Commit the settings configured after the configuration commit delay command was executed.
# Commit the settings configured after the configuration commit delay command was executed. In this example, the commit operation fails, because the allowed delay time has expired. The device is rolling back the configuration to the settings before the configuration commit delay command was executed.
The system is rolling back configuration. Please wait…
Use configuration commit delay to set the allowed delay time for a manual commit to keep the settings configured subsequently in effect.
configuration commit delay delay-time
delay-time: Sets the allowed delay time in the range of 1 to 65535 minutes.
Configure this command in a single-user environment.
If you do not execute the configuration commit command within the delay time, the device rolls back the configuration to the settings before the configuration commit delay command was executed. The device outputs logs to notify the user of the rollback operation. The user cannot perform other operations before the rollback is finished.
As a best practice, set the allowed delay time in the following situations:
·     The user configures the device remotely. The user might be disconnected from the device because of a setting. If the configuration commit delay command is configured and the setting is not committed, the user can reconnect to the device after the delay time expires.
·     The user is not familiar with the device configuration. If any parameters are configured incorrectly, the rollback mechanism can remove the incorrect settings after the delay time expires.
You can change the allowed delay time before the previous configured delay time expires. The new delay time configuration overwrites the previous delay time configuration after you enter Y to confirm the change. The allowed delay time is re-set.
# Re-set the allowed delay time to 60 minutes for a manual commit to keep the settings configured subsequently in effect.
[Sysname] configuration commit delay 60
The commit delay already set 10 minutes, overwrite it? [Y/N]:y
# Re-set the allowed delay time to 20 minutes for a manual commit to keep the settings configured subsequently in effect. In this example, the configuration fails, because the previous configured delay time has expired. The device is rolling back the configuration to the settings before the configuration commit delay command was executed the previous time.
[Sysname] configuration commit delay 20
configuration encrypt
Use configuration encrypt to enable configuration encryption.
Use undo configuration encrypt to restore the default.
configuration encrypt { private-key | public-key }
Configuration encryption is disabled. The running configuration is saved to a configuration file without encryption.
private-key: Encrypts configuration with a private key. All H3C devices running Comware 7 software use the same private key.
public-key: Encrypts configuration with a public key. All H3C devices running Comware 7 software use the same public key.
Configuration encryption enables the device to automatically encrypt a configuration file when saving the running configuration to the file.
Only H3C devices running Comware 7 software can decrypt the encrypted configuration file.
# Enable the public-key method for configuration encryption.
[Sysname] configuration encrypt public-key
configuration replace file
Use configuration replace file to perform configuration rollback.
filename: Specifies the name of the replacement configuration file for configuration rollback. The file name must use the .cfg extension. Excluding the .cfg extension, the file name is a case-insensitive string of 1 to 255 characters and can include path information. The file and file path must be valid.
To replace the running configuration with the configuration in a configuration file without rebooting the device, use the configuration rollback function. This function helps you revert to a previous configuration state or adapt the running configuration to different network environments.
To ensure a successful rollback, follow these guidelines:
·     Make sure the replacement configuration file is created by using the configuration archive function or the save command on the device.
·     If the configuration file is not created on the device, make sure the command lines in the configuration file are fully compatible with the device.
·     Make sure the replacement configuration file is not encrypted.
# Replace the running configuration with the configuration in the my_archive_1.cfg configuration file.
[Sysname] configuration replace file my_archive_1.cfg
Current configuration will be lost, save current configuration? [Y/N]:n
Now replacing the current configuration. Please wait...
Succeeded in replacing current configuration with the file my_archive_1.cfg.
Use display archive configuration to display configuration archive information, including the archive directory, archive prefix, archive interval, maximum number of archives, and saved archives.
# Display configuration archive information.
<Sysname> display archive configuration
Filename prefix: my_archive
Archive interval in minutes: 120
Maximum number of archive files: 10
Saved archive files:
  No. TimeStamp                  FileName
  1   Wed Jan 15 14:20:18 2014   my_archive_1.cfg
  2   Wed Jan 15 14:33:10 2014   my_archive_2.cfg
# 3   Wed Jan 15 14:49:37 2014   my_archive_3.cfg
'#' indicates the most recent archive file.
Next archive file to be saved: my_archive_4.cfg
Location
Absolute path of the directory for saving running-configuration archives.
Filename prefix
File name prefix for configuration archives.
Interval (in minutes) for the system to automatically archive the running configuration.
If automatic configuration saving is disabled, this field is not available.
Maximum number of configuration archives that can be saved.
Saved archive files
Configuration archives that have been saved.
TimeStamp
Time when the configuration archive was created.
display current-configuration
Use display current-configuration to display the running configuration.
display current-configuration [ configuration [ module-name ] | interface [ interface-type [ interface-number ] ] ]
configuration [ module-name ]: Displays feature configuration. The module-name argument specifies a feature module. If you do not specify a feature module, the command displays all feature settings you have made.
interface [ interface-type [ interface-number ] ]: Displays interface configuration. The interface-type argument represents the interface type and the interface-number argument represents the interface number. If you do not specify the interface-type interface-number arguments, the command displays the running configuration for all interfaces. If you specify only the interface-type argument, the command displays the running configuration for all interfaces of this type.
Use this command to verify the configuration you have made.
If the system has automatically changed the setting you have made for a parameter, this command displays the effective setting instead of the configured one. An automatic change typically occurs because of system restrictions.
This command does not display parameters that are using the default settings.
# Display local user configuration.
<Sysname> display current-configuration configuration local-user
local-user hpzlkf class manage
 password hash $h$6$k4IOwRxDRlPA4zyu$gY/YPyrnHrTXodkyVyV13LZQ6dVY1wiWIP44gGtD9fY
0dKwfuQq14os/EWe/VHZ+Kx6aeveAOb4lICMpTPiQJg==
 service-type ftp
 authorization-attribute idle-cut 120
 authorization-attribute work-directory flash:/
# Display GigabitEthernet interface configuration.
<Sysname> display current-configuration interface gigabitethernet
 port link-mode bridge
Return
display current-configuration diff
Use display current-configuration diff to display the configuration differences between the running configuration and the next-startup configuration file.
# Display the configuration differences between the running configuration and the next-startup configuration file.
<Sysname> display current-configuration diff
--- Startup configuration
+++ Current configuration
@@ -12,6 +12,11 @@
  irf member 1 priority 1
  irf mode enhanced
+isis 1
+ auto-cost enable
+ cost-style compatible
+ default-route-advertise route-policy n
  lldp global enable
  system-working-mode standard
<Sysname>
- - - A
+++ B
·     A displays Startup configuration, Current configuration, or the name of the source configuration file with its directory information.
·     B displays Current configuration, Startup configuration, or the name of the target configuration file with its directory information.
@@ -linenumber1,number1 +linenumber2,number2 @@
Location summary for a command line difference:
·     -linenumber1,number1—A total number of number1 lines are excerpted from line number linenumber1 in A. These lines contain a command line difference.
·     +linenumber2,number2—A total number of number2 lines are excerpted from line number linenumber2 in B. These lines contain a command line difference.
cmd1
- cmd2
+ cmd3
cmd4
Command line difference:
·     cmd1 and cmd4 provide a context for locating the different command lines.
·     - cmd2 represents the different command line in A.
·     + cmd3 represents the different command line in B.
·     display current-configuration
·     display diff
·     display saved-configuration
display default-configuration
Use display default-configuration to display the factory defaults.
The device is shipped with some basic settings called factory defaults. These default settings ensure that the device can start up and run correctly when it does not have any startup configuration file or the configuration file is corrupt.
# Display the factory defaults.
<Sysname> display default-configuration
display diff
Use display diff to display the configuration differences between two configuration files or between a configuration file and the running configuration.
display diff configfile file-name-s { configfile file-name-d | current-configuration | startup-configuration }
display diff current-configuration { configfile file-name-d | startup-configuration }
display diff startup-configuration { configfile file-name-d | current-configuration }
configfile file-name-s: Specifies the source configuration file for comparison.
configfile file-name-d: Specifies the target configuration file for comparison.
current-configuration: Specifies the running configuration. In the display diff current-configuration command, this keyword specifies the source configuration for comparison. In the display diff configfile file-name-s and display diff startup-configuration commands, this keyword specifies the target configuration.
startup-configuration: Specifies the next-startup configuration file. In the display diff startup-configuration command, this keyword specifies the source configuration file for comparison. In the display diff configfile file-name-s and display diff current-configuration commands, this keyword specifies the target configuration file.
# Display the configuration differences between startup.cfg and test.cfg.
<Sysname> display diff configfile startup.cfg configfile test.cfg
--- flash:/startup.cfg
+++ flash:/test.cfg
@@ -10,7 +10,7 @@
  irf auto-merge enable
  undo irf link-delay
- irf mode normal
+ irf mode enhanced
  lldp global enable
@@ -19,6 +19,9 @@
 vlan 1
<Sysname>
The output shows that startup.cfg contains the command line irf mode normal while test.cfg contains the command line irf mode enhanced.
<Sysname> display diff current-configuration startup-configuration
--- Current configuration
+++ Startup configuration
@@ -12,11 +12,6 @@
  irf mode enhanced
-isis 1
- auto-cost enable
- cost-style compatible
- default-route-advertise route-policy n
+  lldp global enable
<Sysname>
The output shows that the running configuration contains the command lines isis 1, auto-cost enable, cost-style compatible, and default-route-advertise route-policy n. The next-startup configuration file contains the command line lldp global enable.
For command output, see Table 2.
·     display current-configuration diff
Use display saved-configuration to display the contents of the configuration file for the next system startup.
Use this command to verify that important settings have been saved to the configuration file for the next system startup.
This command selects the configuration file to display in the following order:
1.     If the main startup configuration file is available, this command displays the contents of the main startup configuration file.
2.     If only the backup startup configuration file is available, this command displays the contents of the backup file.
3.     If both the main and backup startup configuration files are not available, this command does not display anything.
# Display the contents of the configuration file for the next system startup.
<Sysname> display saved-configuration
 version 7.1.045, Alpha 714101
mdc Admin id 1
 sysname Sysname
 ftp server enable
 telnet server enable
 domain default enable system
vlan 1
domain system
  ---- More ----
·     reset saved-configuration
·     save
display startup
Use display startup to display the names of the current startup configuration file and the next-startup configuration files.
display startup
Current startup configuration file is the configuration file that has been loaded. Next-startup configuration file is the configuration file used at the next startup.
In standalone mode:
The standby MPU always uses the same current startup configuration file as the active MPU. After an active/standby switchover, it is normal that the current startup configuration files on the MPUs are displayed as NULL. This is because the new active MPU continues to run with the running configuration rather than rebooting with a startup configuration file.
In IRF mode:
The global standby MPUs always use the same current startup configuration file as the global active MPU. After an active/standby switchover, it is normal that the current startup configuration files on all MPUs are displayed as NULL. This is because the new global active MPU continues to run with the running configuration rather than rebooting with a startup configuration file.
# (In standalone mode.) Display names of the startup configuration files.
<Sysname> display startup
MainBoard:
 Current startup saved-configuration file: flash:/startup.cfg
 Next main startup saved-configuration file: flash:/startup.cfg
 Next backup startup saved-configuration file: NULL
Slot 6:
MainBoard
Displays the startup configuration files on the active MPU.
Configuration file that the active MPU has started up with.
Primary startup configuration file to be used at the next startup.
Backup startup configuration file to be used at the next startup.
Slot n
Displays the startup configuration files on the MPU in slot n.
# (In IRF mode.) Display names of the startup configuration files.
MainBoard:
 Current startup saved-configuration file: NULL
 Next backup startup saved-configuration file: flash:/startup2.cfg
Chassis 2 Slot 6:
MainBoard
Displays the startup configuration files on the IRF master device.
Configuration file that the global active MPU has started up with.
Primary configuration file to be used at the next startup.
Backup configuration file to be used at the next startup.
(This file does not exist.)
If the specified next-startup configuration file has been deleted, this comment appears next to the file name.
Chassis x Slot n
Displays the startup configuration files on the MPU in slot n of IRF member x.
display this
Use display this to display the running configuration in the current view.
display this
Use this command to verify the configuration you have made in a certain view.
Some parameters can be successfully configured even if their dependent features are not enabled. For these parameters, this command displays their settings after the dependent features are enabled.
This command can be executed in any user line view to display the running configuration of all user lines.
# Display the running configuration on interface GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] display this
return
# Display the running configuration on user lines.
[Sysname] line vty 1
[Sysname-line-vty1] display this
line aux 1
line vty 0 63
 authentication-mode none
 idle-timeout 0 0
return
Use reset saved-configuration to delete next-startup configuration files.
backup: Deletes the backup next-startup configuration file.
main: Deletes the main next-startup configuration file.
CAUTION:
Use this command with caution. This command permanently deletes the next-startup configuration file from each MPU.
You can delete the main file, the backup file, or both.
To delete a file that is set as both main and backup next-startup configuration files, you must execute both the reset saved-configuration backup command and the reset saved-configuration main command. Using only one of the commands removes the specified file attribute instead of deleting the file.
For example, if the reset saved-configuration backup command is executed, the backup next-startup configuration file setting is set to NULL. However, the file is still used as the main file. To delete the file, you must also execute the reset saved-configuration main command.
If you do not specify a configuration file attribute, the reset saved-configuration command deletes the main next-startup configuration file.
# (In standalone mode.) Delete the main next-startup configuration file.
<Sysname> reset saved-configuration
The saved configuration file will be erased. Are you sure? [Y/N]:y
Configuration file in flash: is being cleared.
Please wait ...
MainBoard:
Configuration file is cleared.
Slot 6:
Erase next configuration file successfully
# (In IRF mode.) Delete the backup next-startup configuration file.
<Sysname> reset saved-configuration backup
Please wait ...
MainBoard:
Chassis 2 Slot 6:
Use restore startup-configuration to download a configuration file from a TFTP server and specify it as the main next-startup configuration file.
restore startup-configuration from tftp-server src-filename
tftp-server: Specifies a TFTP server's IPv4 address or host name. The host name is a case-insensitive string of 1 to 253 characters. Valid characters include letters, digits, hyphens (-), underscores (_), and dots (.).
src-filename: Specifies the file name of the configuration file to be downloaded.
Before restoring the configuration file for the next startup, make sure the following requirements are met:
·     The server is reachable.
·     The server is enabled with TFTP service.
·     You have read and write permissions to the server.
This command provides an easy method for configuration file restoration by automatically performing all operations required for restoring the main next-startup configuration file.
The configuration file is automatically saved to the root directory of the default storage medium on each MPU.
If the USB disk is used and partitioned, the configuration file is saved on the first partition.
This command assumes that all MPUs use the same type of storage medium. If a standby MPU uses a different type of storage medium than the active MPU, the command cannot propagate the configuration file to the standby MPU. For example, the standby MPU uses a USB disk, but the active MPU uses a flash memory. In this situation, you must manually restore the next-startup configuration file on the standby MPU.
# (In standalone mode.) Download the configuration file config.cfg from the TFTP server at 2.2.2.2, and specify the file as the main next-startup configuration file.
<Sysname> restore startup-configuration from 2.2.2.2 config.cfg
Restoring the next startup-configuration file from 2.2.2.2. Please wait...finished.
Now restoring the next startup-configuration file from main board to backup board. Please wait...finished.
# (In IRF mode.) Download the configuration file config.cfg from the TFTP server at 2.2.2.2 and specify the file as the main next-startup configuration file.
save
In standalone mode:
Use save file-url [ all | slot slot-number ] to save the running configuration to a configuration file, without specifying the file as a next-startup configuration file.
Use save [ safely ] [ backup | main ] [ force ] [ mdc-all ] to save the running configuration to a file in the root directory of the default storage medium. This command applies to each MDC or the MDC where you are logged in. It specifies the file as a next-startup configuration file at the same time.
In IRF mode:
Use save file-url [ all | chassis chassis-number slot slot-number ] to save the running configuration to a configuration file, without specifying the file as a next-startup configuration file.
In standalone mode:
In IRF mode:
file-url: Saves the running configuration to the specified file, without specifying the file as a next-startup configuration file. The file name must use the extension .cfg and can include path information. If you specify the all keyword or an MPU slot, the file path cannot include a chassis or slot number. If the file path includes a folder name, the folder must already exist.
all: Saves the running configuration to both MPUs. If you do not specify this keyword or the slot slot-number option, the command saves the running configuration only to the active MPU. (In standalone mode.)
all: Saves the running configuration to all MPUs. If you do not specify this keyword or the chassis chassis-number slot slot-number option, the command saves the running configuration only to the global active MPU in the IRF fabric. (In IRF mode.)
slot slot-number: Saves the running configuration to the standby MPU. If you do not specify this option or the all keyword, the command saves the running configuration only to the active MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Saves the running configuration to a standby MPU. If you do not specify this option or the all keyword, the command saves the running configuration only to the global active MPU in the IRF fabric. (In IRF mode.)
safely: Saves the configuration file in safe mode. If you do not specify this keyword, the device saves the configuration file in fast mode. Safe mode is slower than fast mode, but more secure. As a best practice, specify the safely keyword for the command.
backup: Saves the running configuration to a configuration file, and specifies the file as the backup next-startup configuration file. If you do not specify this keyword or the main keyword, the command specifies the saved file as the main next-startup configuration file.
main: Saves the running configuration to a configuration file, and specifies the file as the main next-startup configuration file. If you do not specify this keyword or the backup keyword, the command specifies the saved file as the main next-startup configuration file.
force: Saves the running configuration without prompting for confirmation. If you do not specify this keyword, the system prompts you to confirm the operation. If you do not confirm the operation within 30 seconds, the system automatically aborts the operation. If you enter Y within the time limit, you can continue the save process and change the target file name during the process.
mdc-all: Saves the running configuration for each MDC. This keyword is available only on the default MDC. If this keyword is not available or you do not specify this keyword, the save command saves the running configuration only for the MDC where you are logged in.
If the file specified for the command does not exist, the system creates the file before saving the configuration. If the file already exists, the system prompts you to confirm whether to overwrite the file. If you choose to not overwrite the file, the system cancels the save operation.
If you do not specify the file-url option for the command, the command saves the running configuration to an .mdb binary file as well as a .cfg text file. The two files use the same file name. An .mdb file takes less time to load than a .cfg file.
If you specify the file-url option for the command, the command only saves the running configuration to the specified .cfg file.
In safe mode, the system saves configuration in a temporary file and starts overwriting the target next-startup configuration file after the save operation is complete. If a reboot, power failure, or out of memory event occurs during the save operation, the next-startup configuration file is retained.
In fast mode, the device directly overwrites the target next-startup configuration file. If a reboot, power failure, or out of memory event occurs during this process, the next-startup configuration file is lost.
# Save the running configuration to the configuration file backup.cfg, without specifying the file as the next-startup configuration file.
<Sysname> save backup.cfg
The current configuration will be saved to flash:/backup.cfg. Continue? [Y/N]:y
Now saving current configuration to the device.
Saving configuration
flash:/backup.cfg. Please wait...
Configuration is saved to flash successfully.
# Save the running configuration to the main next-startup configuration file without any confirmation required.
<Sysname> save force
Validating file. Please wait....
Configuration is saved to device successfully.
# (In standalone mode.) Save the running configuration to a file in the root directory of the default storage medium, and specify the file as the main next-startup configuration file.
<Sysname> save
Slot 6:
Save next configuration file successfully.
# (In IRF mode.) Save the running configuration to a file in the root directory of the default storage medium, and specify the file as the main next-startup configuration file.
<Sysname> save
Chassis 1 Slot 6:
# Save the running configuration to a file in the root directory of the default storage medium for each MDC, and specify the file as the main next-startup configuration file.
<Sysname> save mdc-all
Save current configuration in MDC Admin? [Y/N]:y
Please input the file name(*.cfg)[flash:/1.cfg]
flash:/1.cfg exists, overwrite? [Y/N]:y
Chassis 1 Slot 6:
Save current configuration in MDC mdc1? [Y/N]:y
Please input the file name(*.cfg)[flash:/mdc1.cfg]
flash:/mdc1.cfg exists, overwrite? [Y/N]:y
Chassis 1 Slot 6:
In standalone mode:
Use startup saved-configuration to specify a file as a next-startup configuration file for both active MPU and standby MPU.
Use undo startup saved-configuration to configure the active MPU and the standby MPU to start up with factory defaults at the next startup.
In IRF mode:
Use startup saved-configuration to specify a file as a next-startup configuration file for all MPUs in the IRF fabric.
Use undo startup saved-configuration to configure all MPUs to start up with the factory defaults at the next startup.
No next-startup configuration file is specified.
cfgfile: Specifies the name of a .cfg file. This .cfg file must already exist in the root directory of the default storage medium.
backup: Specifies the configuration file as the backup next-startup configuration file.
main: Specifies the configuration file as the main next-startup configuration file. This is the primary configuration file that the device attempts to load at startup. If the loading attempt fails, the device tries the backup next-startup configuration file.
CAUTION:
In an IRF fabric, use the undo startup saved-configuration command with caution. This command can cause an IRF split after the IRF fabric or an IRF member reboots.
The startup saved-configuration command applies to all MPUs. To successfully configure the command, make sure the following conditions are met:
·     In standalone mode, the specified file already exists in the root directory of the default storage medium on both active MPU and standby MPU.
·     In IRF mode, the specified file already exists in the root directory of the default storage medium on each MPU.
·     All MPUs use the same type of storage medium as the default storage medium.
If the USB disk is used to store the next-startup configuration files, do not remove the USB disk during the startup process. If you remove the USB disk on a device, one of the following consequences occurs:
·     In standalone mode, the device starts up with the factory defaults.
·     In IRF mode, the device leaves the IRF fabric at the startup and runs with the factory defaults.
If you do not specify either backup or main, the startup saved-configuration command specifies the main next-startup configuration file.
Even though the main and backup next-startup configuration files can be the same one, specify them as separate files for high availability.
The undo startup saved-configuration command changes the file attribute of the main and backup next-startup configuration files to NULL. However, the command does not delete the two configuration files.
You can also specify a configuration file as a next startup file when you use the save command to save the running configuration to it.
# Specify the main next-startup configuration file.
<Sysname> startup saved-configuration testcfg.cfg
Please wait ....
... Done!
display startup
