08 ACL and QoS Configuration Guide
HomeSupportSwitchesS7500E-XS SeriesConfigure & DeployConfiguration GuidesH3C S7500E-XS Configuration Guides-R2418P05-6W10008 ACL and QoS Configuration Guide
04-Data buffer configuration
04-Data buffer configuration 102.09 KB
An interface stores outgoing packets in the egress buffer when congestion occurs.
An egress buffer uses the following types of resources:
·     Cell resources—Store packets. The buffer uses cell resources based on packet sizes. Suppose a cell resource provides 208 bytes. The buffer allocates one cell resource to a 128-byte packet and two cell resources to a 300-byte packet.
·     Packet resources—Store packet pointers. A packet pointer indicates where the packet is located in cell resources. The buffer uses one packet resource for each incoming or outgoing packet.
Each type of resources has a fixed area and a shared area.
·     Fixed area—Partitioned into queues, each of which is equally divided by all the interfaces on a device, as shown in Figure 1. When congestion occurs, the following rules apply:
a.     An interface first uses the relevant queues of the fixed area to store packets.
b.     When a queue is full, the interface uses the space for the queue in the shared area.
c.     When the queue in the shared area is also full, the interface discards subsequent packets.
The system allocates the fixed area among queues as specified by the user. Even if a queue is not full, other queues cannot preempt its space. Similarly, the share of a queue for an interface cannot be preempted by other interfaces even if it is not full.
·     Shared area—Partitioned into queues, each of which is not equally divided by the interfaces, as shown in Figure 1. The system determines the actual shared-area ratio for each queue according to user configuration and the number of packets actually sent. If a queue is not full, other queues can preempt its space.
The system puts packets received on all interfaces into a queue in the order they arrive. When the queue is full, subsequent packets are dropped.
Figure 1 Fixed area and shared area
Configuration task list
You can configure data buffers either automatically by enabling the Burst function or manually.
If you have configured data buffers in one way, delete the configuration before using the other way. Otherwise, the new configuration does not take effect.
To configure the data buffer, perform the following tasks:
Tasks at a glance
Perform one of the following tasks:
·     Enabling the Burst function
·     Configuring data buffers manually
? Configuring the total shared-area ratio
? Setting the maximum shared-area ratio for a queue
? Setting the fixed-area ratio for a queue
? Applying data buffer configuration
The Burst function enables the device to automatically allocate cell and packet resources. It is well suited to the following scenarios:
·     Broadcast or multicast traffic is intensive, resulting in bursts of traffic.
·     Traffic enters and goes out in one of the following ways:
?     Enters from a high-speed interface and goes out of a low-speed interface.
?     Enters from multiple same-rate interfaces at the same time and goes out of an interface with the same rate.
To enable the Burst function:
Step
Remarks
N/A
2.     Enable the Burst function.
burst-mode enable
By default, the Burst function is disabled.
CAUTION
CAUTION:
·     To avoid impact on the forwarding function of the system, do not manually change data buffer settings. If large buffer spaces are needed, use the Burst function.
·     Manually configuring data buffers might cause generic flow control and PFC to operate incorrectly. For more information about generic flow control and PFC, see Layer 2—LAN Switching Configuration Guide.
The switch only supports configuring cell resources.
Each type of resources of a buffer, packet or cell, has a fixed size. After you set the total shared-area ratio for a type of resources, the rest is automatically assigned to the fixed area.
To configure the total shared-area ratio:
Step
Remarks
N/A
2.     Configure the total shared-area ratio.
buffer egress [ slot slot-number ] cell total-shared ratio ratio-value
By default, the total shared-area ratio is 84% of the buffer.
By default, all queues have an equal share of the shared area. This task allows you to change the maximum shared-area ratio for a queue. The unconfigured queues use the default setting.
The actual maximum shared-area ratio for each queue is determined by the chip based on your configuration and the number of packets to be sent.
To set the maximum shared-area ratio for a queue:
Step
Remarks
N/A
2.     Set the maximum shared-area ratio for a queue.
buffer egress [ slot slot-number ] cell queue queue-id shared ratio ratio-value
The default setting is 33% for each queue.
For the maximum shared-area ratio for a queue, the percentage values 0 to 100 are divided into 10 ranges. Table 1 shows the effective values that correspond to the configured values of ratio-value.
Table 1 Mapping between values of ratio-value and effective values
Value of ratio-value
Effective value
0 to 1
1
2 to 3
3
4 to 7
6
8 to 16
11
17 to 29
20
30 to 42
33
43 to 60
50
61 to 76
67
77 to 86
80
87 to 100
89
By default, all queues have an equal share of the fixed area. This task allows you to change the fixed-area ratio for a queue. The unconfigured queues equally share the remaining part.
The fixed-area space for a queue cannot be used by other queues. It is also called the minimum guaranteed buffer.
When you set the fixed-area ratio for a queue, follow these restrictions and guidelines:
·     The sum of ratios configured for all queues cannot be greater than or equal to 100%. Queues 5, 6, and 7 must have available fixed-area space.
·     After you configure the fixed-area ratios for some queues, the other queues each are assigned an equal share of the remaining part of the fixed area. The display buffer queue command displays the preceding whole number for each assignment result. Therefore, the sum of the ratios for all queues might be less than 100%.
To set the fixed-area ratio for a queue:
Step
Remarks
N/A
2.     Set the fixed-area ratio for a queue.
buffer egress [ slot slot-number ] cell queue queue-id guaranteed ratio ratio-value
The default setting is 12.5% for each queue, but the default value in the display buffer queue command output is 13%.
Perform this task to apply the data buffer configuration.
You cannot directly modify the applied configuration. To modify the configuration, you must cancel the application, reconfigure data buffers, and reapply the configuration.
To apply data buffer configuration:
Step
2.     Apply data buffer configuration.
buffer apply
Displaying and maintaining data buffers
Display data buffer configuration.
display buffer [ slot slot-number ] [ queue [ queue-id ] ]
Display data buffer usage.
display buffer usage [ slot slot-number ]
