- 05 Layer 3 - IP Routing Configuration Guide
- 01-Basic IP routing configuration
- 02-Static routing configuration
- 03-RIP configuration
- 04-OSPF configuration
- 05-IS-IS configuration
- 06-BGP configuration
- 07-Policy-based routing configuration
- 08-IPv6 static routing configuration
- 09-RIPng configuration
- 10-OSPFv3 configuration
- 11-IPv6 IS-IS configuration
- 12-IPv6 policy-based routing configuration
- 13-Routing policy configuration
| 12-IPv6 policy-based routing configuration | 142.05 KB |
IPv6 PBR configuration task list
Configuring match criteria for an IPv6 node
Configuring actions for an IPv6 node
Configuring IPv6 interface PBR
Displaying and maintaining IPv6 PBR
IPv6 PBR configuration examples
Configuring IPv6 PBR
Overview
Policy-based routing (PBR) uses user-defined policies to route packets. A policy can specify the next hop for packets that match specific criteria such as ACLs.
A device forwards received packets using the following process:
1. The device uses PBR to forward matching packets.
2. If the packets do not match the PBR policy or the PBR-based forwarding fails, the device uses the routing table, excluding the default route, to forward the packets.
3. If the routing table-based forwarding fails, the device uses the default next hop or default output interface defined in PBR to forward packets.
4. If the default next hop or default output interface-based forwarding fails, the device uses the default route to forward packets.
PBR includes local PBR and interface PBR.
· Local PBR guides the forwarding of locally generated packets, such as the ICMP packets generated by using the ping command.
· Interface PBR guides the forwarding of packets received on an interface only.
Policy
An IPv6 policy includes match criteria and actions to be taken on the matching packets. A policy can have one or multiple nodes as follows:
· Each node is identified by a node number. A smaller node number has a higher priority.
· A node contains if-match and apply clauses. An if-match clause specifies a match criterion, and an apply clause specifies an action.
· A node has a match mode of permit or deny.
An IPv6 policy matches nodes in priority order against packets. If a packet matches the criteria on a node, it is processed by the action on the node. Otherwise, it goes to the next node for a match. If the packet does not match the criteria on any node, it is forwarded according to the routing table.
if-match clause
IPv6 PBR supports the if-match acl clause to set an ACL match criterion. You can specify only one if-match acl clause for a node.
apply clause
IPv6 PBR supports the apply next-hop clause to set next hops for packets.
Relationship between the match mode and clauses on the node
Match mode |
In permit mode |
In deny mode |
Yes |
· If the node is configured with an apply clause, IPv6 PBR executes the apply clause on the node. ¡ If IPv6 PBR successfully guides the forwarding of the packet, IPv6 PBR does not match the packet against the next node. ¡ If IPv6 PBR fails to guide the forwarding of the packet and the apply continue clause is not configured, IPv6 PBR does not match the packet against the next node. ¡ If IPv6 PBR fails to guide the forwarding of the packet and the apply continue clause is configured, IPv6 PBR matches the packet against the next node. · If the node is configured with no apply clause, the packet is forwarded according to the routing table. |
The packet is forwarded according to the routing table. |
No |
IPv6 PBR matches the packet against the next node. |
A node that has no if-match clauses matches any packet.
PBR and Track
PBR can work with the Track feature to dynamically adapt the availability status of an apply clause to the link status of a tracked next hop.
· When the track entry associated with an object changes to Negative, the apply clause is invalid.
· When the track entry changes to Positive or NotReady, the apply clause is valid.
For more information about Track-PBR collaboration, see High Availability Configuration Guide.
Tasks at a glance |
(Required.) Configuring an IPv6 policy: |
(Required.) Configuring IPv6 PBR: |
Creating an IPv6 node
Step |
Command |
Remarks |
1. Enter system view. |
system-view |
N/A |
2. Create an IPv6 policy or policy node, and enter IPv6 policy node view. |
ipv6 policy-based-route policy-name [ deny | permit ] node node-number |
By default, no IPv6 policy node is created. |
Step |
Command |
Remarks |
system-view |
N/A |
2. Enter IPv6 policy node view. |
N/A |
3. Configure an ACL match criterion. |
if-match acl { acl6-number | name acl6-name } |
By default, no ACL match criterion is configured. |
NOTE: An ACL match criterion uses the specified ACL to match packets regardless of the permit or deny action and the time range of the ACL. If the specified ACL does not exist, no packet can match the criterion. |
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
3. Set next hops for permitted IPv6 packets. |
apply next-hop [ vpn-instance vpn-instance-name ] { ipv6-address [ direct ] [ track track-entry-number ] }&<1-n> |
By default, no next hop is specified. You can specify multiple next hops for backup by executing this command once or multiple times. You can specify a maximum of two next hops for a node. |
Configuring IPv6 local PBR
Configure IPv6 PBR by applying a policy locally. IPv6 PBR uses the policy to guide the forwarding of locally generated packets. The specified policy must already exist. Otherwise, the IPv6 local PBR configuration fails.
You can apply only one policy locally. Before you apply a new policy, you must first remove the current policy.
IPv6 local PBR might affect local services, such as ping and Telnet. Do not configure IPv6 local PBR unless doing so is required.
To configure IPv6 local PBR:
Step |
Command |
Remarks |
system-view |
N/A |
2. Apply a policy locally. |
ipv6 local policy-based-route policy-name |
By default, no policy is locally applied. |
Configure IPv6 PBR by applying an IPv6 policy to an interface. IPv6 PBR uses the policy to guide the forwarding of IPv6 packets received on the interface. The specified policy must already exist. Otherwise, the IPv6 interface PBR configuration fails.
You can apply only one policy to an interface. Before you apply a new policy, you must first remove the current policy from the interface.
You can apply a policy to multiple interfaces.
To configure IPv6 interface PBR:
Step |
Command |
Remarks |
system-view |
N/A |
2. Enter interface view. |
N/A |
3. Apply an IPv6 policy to the interface. |
ipv6 policy-based-route policy-name |
By default, no IPv6 policy is applied to the interface. |
Task |
Command |
Display IPv6 PBR policy information. |
display ipv6 policy-based-route [ policy policy-name ] |
Display IPv6 PBR configuration. |
display ipv6 policy-based-route setup |
Display IPv6 local PBR configuration and statistics. |
display ipv6 policy-based-route local [ slot slot-number ] |
Display IPv6 interface PBR configuration and statistics. |
display ipv6 policy-based-route interface interface-type interface-number [ slot slot-number ] |
Clear IPv6 PBR statistics. |
reset ipv6 policy-based-route statistics [ policy policy-name ] |
Packet type-based IPv6 local PBR configuration example
Network requirements
As shown in Figure 1, configure IPv6 PBR on Switch A to forward all TCP packets to the next hop 1::2. Switch A forwards other packets according to the routing table.
Configuration procedure
1. Configure Switch A:
# Create VLAN 10 and VLAN 20.
[SwitchA] vlan 10
[SwitchA-vlan10] quit
[SwitchA] vlan 20
[SwitchA-vlan20] quit
# Configure the IPv6 addresses of VLAN-interface 10 and VLAN-interface 20.
[SwitchA-Vlan-interface10] ipv6 address 1::1 64
[SwitchA-Vlan-interface20] ipv6 address 2::1 64
# Configure ACL 3001 to match TCP packets.
[SwitchA] acl ipv6 number 3001
[SwitchA-acl6-adv-3001] rule permit tcp
[SwitchA-acl6-adv-3001] quit
# Configure Node 5 for policy aaa to forward TCP packets to next hop 1::2.
[SwitchA] ipv6 policy-based-route aaa permit node 5
[SwitchA-pbr6-aaa-5] if-match acl 3001
[SwitchA-pbr6-aaa-5] apply next-hop 1::2
[SwitchA-pbr6-aaa-5] quit
# Configure IPv6 local PBR by applying policy aaa to Switch A.
[SwitchA] ipv6 local policy-based-route aaa
2. Configure Switch B:
# Create VLAN 10.
[SwitchB] vlan 10
[SwitchB-vlan10] quit
# Configure the IPv6 address of VLAN-interface 10.
[SwitchB-Vlan-interface10] ipv6 address 1::2 64
3. Configure Switch C:
# Create VLAN 20.
[SwitchC] vlan 20
[SwitchC-vlan20] quit
# Configure the IPv6 address of VLAN-interface 20.
[SwitchC] interface vlan-interface 20
[SwitchC-Vlan-interface20] ipv6 address 2::2 64
# Telnet to Switch B on Switch A. The operation succeeds.
# Telnet to Switch C on Switch A. The operation fails.
# Ping Switch C from Switch A. The operation succeeds.
Telnet uses TCP, and ping uses ICMP. The results show the following:
· All TCP packets sent from Switch A are forwarded to the next hop 1::2.
· Other packets are forwarded through VLAN-interface 20.
· The IPv6 local PBR configuration is effective.
Packet type-based IPv6 interface PBR configuration example
As shown in Figure 2, configure IPv6 PBR on Switch A to forward all TCP packets received on VLAN-interface 11 to the next hop 1::2. Switch A forwards other IPv6 packets according to the routing table.
[SwitchA] vlan 10
[SwitchA] vlan 20
# Configure RIPng.
[SwitchA] ripng 1
[SwitchA-ripng-1] quit
[SwitchA-Vlan-interface10] ripng 1 enable
[SwitchA-Vlan-interface20] ripng 1 enable
# Configure IPv6 interface PBR by applying policy aaa to VLAN-interface 11.
[SwitchA-Vlan-interface11] ipv6 address 10::2 64
[SwitchA-Vlan-interface11] undo ipv6 nd ra halt
[SwitchA-Vlan-interface11] ripng 1 enable
[SwitchA-Vlan-interface11] ipv6 policy-based-route aaa
# Create VLAN 10.
[SwitchB] vlan 10
# Configure RIPng.
[SwitchB] ripng 1
[SwitchB-ripng-1] quit
[SwitchB-Vlan-interface10] ripng 1 enable
# Create VLAN 20.
[SwitchC] vlan 20
# Configure RIPng.
[SwitchC] ripng 1
[SwitchC-ripng-1] quit
[SwitchC-Vlan-interface20] ripng 1 enable
[SwitchC-Vlan-interface20] quit
# Enable IPv6 and configure the IPv6 address 10::3 for Host A.
C:\>ipv6 install
Installing...
Succeeded.
C:\>ipv6 adu 4/10::3
# On Host A, Telnet to Switch B that is directly connected to Switch A. The operation succeeds.
# On Host A, Telnet to Switch C that is directly connected to Switch A. The operation fails.
# Ping Switch C from Host A. The operation succeeds.
· All TCP packets arriving on VLAN-interface 11 of Switch A are forwarded to next hop 1::2.
· The IPv6 interface PBR configuration is effective.
