05 Layer 3 - IP Routing Configuration Guide
HomeSupportSwitchesH3C S7500E-XS Switch SeriesConfigure & DeployConfiguration GuidesH3C S7500E-XS Configuration Guides-R2418P05-6W10005 Layer 3 - IP Routing Configuration Guide
06-BGP configuration
06-BGP configuration 1.17 MB
Configuring BGP· 1
Overview·· 1
BGP speaker and BGP peer 1
BGP message types 1
BGP path attributes 2
BGP route selection· 6
BGP route advertisement rules 6
BGP load balancing· 6
Settlements for problems in large-scale BGP networks 8
MP-BGP· 10
BGP configuration views 11
Protocols and standards 12
BGP configuration task list 13
Configuring basic BGP· 16
Enabling BGP· 16
Configuring a BGP peer 17
Configuring dynamic BGP peers 18
Configuring a BGP peer group· 19
Specifying the source interface for TCP connections 26
Generating BGP routes 27
Injecting a local network· 28
Redistributing IGP routes 28
Controlling route distribution and reception· 29
Configuring BGP route summarization· 30
Advertising optimal routes in the IP routing table· 31
Advertising a default route to a peer or peer group· 31
Limiting routes received from a peer or peer group· 32
Configuring BGP route filtering policies 33
Configuring BGP update sending delay· 38
Configuring BGP route dampening· 39
Controlling BGP path selection· 40
Specifying a preferred value for routes received· 40
Configuring preferences for BGP routes 41
Configuring the default local preference· 42
Configuring the MED attribute· 43
Configuring the NEXT_HOP attribute· 47
Configuring the AS_PATH attribute· 49
Tuning and optimizing BGP networks 54
Configuring the keepalive interval and hold time· 54
Configuring the interval for sending updates for the same route· 55
Enabling BGP to establish an EBGP session over multiple hops 56
Enabling immediate re-establishment of direct EBGP connections upon link failure· 57
Enabling 4-byte AS number suppression· 57
Enabling MD5 authentication for BGP peers 58
Configuring BGP load balancing· 59
Configuring IPsec for IPv6 BGP· 60
Disabling BGP to establish a session to a peer or peer group· 61
Configuring GTSM for BGP· 61
Configuring BGP soft-reset 62
Protecting an EBGP peer when memory usage reaches level 2 threshold· 66
Configuring a large-scale BGP network· 67
Configuring BGP community· 67
Configuring BGP route reflection· 69
Configuring a BGP confederation· 71
Configuring BGP GR· 72
Configuring BGP NSR· 73
Enabling SNMP notifications for BGP· 74
Enabling logging of session state changes 74
Configuring BFD for BGP· 74
Configuring BGP FRR· 75
Configuring 6PE· 78
Configuring basic 6PE· 79
Configuring optional 6PE capabilities 79
Displaying and maintaining BGP· 81
IPv4 BGP configuration examples 83
Basic BGP configuration example· 83
BGP and IGP route redistribution configuration example· 88
BGP route summarization configuration example· 90
BGP load balancing configuration example· 93
BGP community configuration example· 96
BGP route reflector configuration example· 99
BGP confederation configuration example· 102
BGP path selection configuration example· 106
BGP GR configuration example· 109
BFD for BGP configuration example· 110
BGP FRR configuration example· 114
IPv6 BGP configuration examples 118
IPv6 BGP basic configuration example· 118
IPv6 BGP route reflector configuration example· 121
6PE configuration example· 123
BFD for IPv6 BGP configuration example· 126
IPv6 BGP FRR configuration example· 130
IPsec for IPv6 BGP packets configuration example· 134
Troubleshooting BGP· 138
Symptom·· 138
Analysis 139
Solution· 139
Configuring BGP
Overview
Border Gateway Protocol (BGP) is an exterior gateway protocol (EGP). It is called internal BGP (IBGP) when it runs within an AS and called external BGP (EBGP) when it runs between ASs.
The current version in use is BGP-4 (RFC 4271).
BGP has the following characteristics:
·     Focuses on route control and selection rather than route discovery and calculation.
·     Uses TCP to enhance reliability.
·     Measures the distance of a route by using a list of ASs that the route must travel through to reach the destination. BGP is also called a path-vector protocol.
·     Supports CIDR.
·     Reduces bandwidth consumption by advertising only incremental updates. BGP is very suitable to advertise large numbers of routes on the Internet.
·     Eliminates routing loops by adding AS path information to BGP route updates.
·     Uses policies to implement flexible route filtering and selection.
·     Has good scalability.
A router running BGP is a BGP speaker. A BGP speaker establishes peer relationships with other BGP speakers to exchange routing information over TCP connections.
BGP peers include the following types:
·     IBGP peers—Reside in the same AS as the local router.
·     EBGP peers—Reside in different ASs from the local router.
BGP message types
BGP uses the following message types:
·     Open—After establishing a TCP connection, BGP sends an Open message to establish a session with the peer.
·     Update—BGP sends update messages to exchange routing information between peers. Each update message can advertise a group of feasible routes with identical attributes and multiple withdrawn routes.
·     Keepalive—BGP sends Keepalive messages between peers to maintain connectivity.
·     Route-refresh—BGP sends a Route-refresh message to request the routing information of a specified address family from a peer.
·     Notification—BGP sends a Notification message upon detecting an error and immediately closes the connection.
BGP path attributes
BGP uses the following path attributes in update messages for route filtering and selection:
·     ORIGIN
The ORIGIN attribute specifies the origin of BGP routes. This attribute has the following types:
¡     IGPHas the highest priority. Routes generated in the local AS have the IGP attribute.
¡     EGPHas the second highest priority. Routes obtained through EGP have the EGP attribute.
¡     INCOMPLETEHas the lowest priority. The source of routes with this attribute is unknown. Routes redistributed from other routing protocols have the INCOMPLETE attribute.
·     AS_PATH
The AS_PATH attribute identifies the ASs through which a route has passed. Before advertising a route to another AS, BGP adds the local AS number into the AS_PATH attribute, so the receiver can determine ASs to route the message back.
The AS_PATH attribute has the following types:
¡     AS_SEQUENCE—Arranges AS numbers in sequence. As shown in Figure 1, the number of the AS closest to the receiver's AS is leftmost.
¡     AS_SET—Arranges AS numbers randomly.
Figure 1 AS_PATH attribute
BGP uses the AS_PATH attribute to implement the following functions:
¡     Avoid routing loopsA BGP router does not receive routes containing the local AS number to avoid routing loops.
¡     Affect route selectionBGP gives priority to the route with the shortest AS_PATH length if other factors are the same. As shown in Figure 1, the BGP router in AS 50 gives priority to the route passing AS 40 for sending data to the destination 8.0.0.0. In some applications, you can apply a routing policy to control BGP route selection by modifying the AS_PATH length. For more information about routing policy, see "Configuring routing policies."
¡     Filter routesBy using an AS path list, you can filter routes based on AS numbers contained in the AS_PATH attribute. For more information about AS path list, see "Configuring routing policies."
·     NEXT_HOP
The NEXT_HOP attribute may not be the IP address of a directly-connected router. Its value is determined as follows:
¡     When a BGP speaker advertises a self-originated route to a BGP peer, it sets the address of the sending interface as the NEXT_HOP.
¡     When a BGP speaker sends a received route to an EBGP peer, it sets the address of the sending interface as the NEXT_HOP.
¡     When a BGP speaker sends a route received from an EBGP peer to an IBGP peer, it does not modify the NEXT_HOP attribute. If load balancing is configured, BGP modifies the NEXT_HOP attribute for the equal-cost routes. For load balancing information, see "BGP load balancing."
Figure 2 NEXT_HOP attribute
·     MED (MULTI_EXIT_DISC)
BGP advertises the MED attribute between two neighboring ASs, each of which does not advertise the attribute to any other AS.
Similar to metrics used by IGPs, MED is used to determine the optimal route for traffic going into an AS. When a BGP router obtains multiple routes to the same destination but with different next hops, it considers the route with the smallest MED value as the optimal route. As shown in Figure 3, traffic from AS 10 to AS 20 travels through Router B that is selected according to MED.
Figure 3 MED attribute
Generally BGP only compares MEDs of routes received from the same AS. You can also use the compare-different-as-med command to force BGP to compare MED values of routes received from different ASs.
·     LOCAL_PREF
The LOCAL_PREF attribute is exchanged between IBGP peers only, and is not advertised to any other AS. It indicates the priority of a BGP router.
BGP uses LOCAL_PREF to determine the optimal route for traffic leaving the local AS. When a BGP router obtains multiple routes to the same destination but with different next hops, it considers the route with the highest LOCAL_PREF value as the optimal route. As shown in Figure 4, traffic from AS 20 to AS 10 travels through Router C that is selected according to LOCAL_PREF.
Figure 4 LOCAL_PREF attribute
·     COMMUNITY
The COMMUNITY attribute identifies the community of BGP routes. A BGP community is a group of routes with the same characteristics. It has no geographical boundaries. Routes of different ASs can belong to the same community.
A route can carry one or more COMMUNITY attribute values (each of which is represented by a 4-byte integer). A router uses the COMMUNITY attribute to determine whether to advertise the route and the advertising scope without using complex filters such as ACLs. This mechanism simplifies routing policy configuration, management, and maintenance.
Well-known COMMUNITY attributes involve the following:
¡     INTERNET—By default, all routes belong to the Internet community. Routes with this attribute can be advertised to all BGP peers.
¡     NO_EXPORT—Routes with this attribute cannot be advertised out of the local AS or out of the local confederation, but can be advertised to other sub-ASs in the confederation. For confederation information, see "Settlements for problems in large-scale BGP networks."
¡     No_ADVERTISE—Routes with this attribute cannot be advertised to other BGP peers.
¡     No_EXPORT_SUBCONFED—Routes with this attribute cannot be advertised out of the local AS or other sub-ASs in the local confederation.
You can configure BGP community lists to filter BGP routes based on the BGP COMMUNITY attribute.
·     Extended community attribute
To meet new demands, BGP defines the extended community attribute. The extended community attribute has the following advantages over the COMMUNITY attribute:
¡     Provides more attribute values by extending the attribute length to eight bytes.
¡     Allows for using different types of extended community attributes in different scenarios to enhance route filtering and control and simplify configuration and management.
Currently, the device supports the Route-Target attribute for VPN and Site of Origin (SoO) attribute. For more information, see MPLS Configuration Guide.
BGP route selection
BGP discards routes with unreachable NEXT_HOPs. If multiple routes to the same destination are available, BGP selects the optimal route in the following sequence:
1.     The route with the highest Preferred_value.
2.     The route with the highest LOCAL_PREF.
3.     The route generated by the network command, the route redistributed by the import-route command, or the summary route in turn.
4.     The route with the shortest AS_PATH.
5.     The IGP, EGP, or INCOMPLETE route in turn.
6.     The route with the lowest MED value.
7.     The route learned from EBGP, confederation EBGP, confederation IBGP, or IBGP in turn.
8.     The route with the smallest next hop metric.
9.     The route with the shortest CLUSTER_LIST.
10.     The route with the smallest ORIGINATOR_ID.
11.     The route advertised by the router with the smallest router ID.
12.     The route advertised by the peer with the lowest IP address.
The CLUSTER_IDs of route reflectors form a CLUSTER_LIST. If a route reflector receives a route that contains its own CLUSTER ID in the CLUSTER_LIST, the router discards the route to avoid routing loops.
If load balancing is configured, the system selects available routes to implement load balancing.
BGP follow these rules for route advertisement:
·     When multiple feasible routes to a destination exist, BGP advertises only the optimal route to its peers. If the advertise-rib-active command is configured, BGP advertises the optimal route in the IP routing table. If not, BGP advertises the optimal route in the BGP routing table.
·     BGP advertises only routes that it uses.
·     BGP advertises routes learned from an EBGP peer to all BGP peers, including both EBGP and IBGP peers.
·     BGP advertises routes learned from an IBGP peer to EBGP peers, rather than other IBGP peers.
·     After establishing a session with a new BGP peer, BGP advertises all the routes matching the above rules to the peer. After that, BGP advertises only incremental updates to the peer.
BGP load balancing
BGP implements load balancing through route recursion and route selection.
·     BGP load balancing through route recursion.
The next hop of a BGP route may not be directly connected. One of the reasons is next hops in routing information exchanged between IBGP peers are not modified. The BGP router must find the directly-connected next hop through IGP. The matching route with the direct next hop is called the "recursive route." The process of finding a recursive route is route recursion.
The system supports BGP load balancing based on route recursion. If multiple recursive routes to the same destination are load balanced, BGP generates the same number of next hops to forward packets. BGP load balancing based on route recursion is always enabled by the system rather than configured by using commands.
·     BGP load balancing through route selection.
IGP routing protocols, such as RIP and OSPF, compute the metrics of routes, and implement load balancing over the routes with the same metric and to the same destination. The route selection criterion is metric.
BGP has no route computation algorithm, so it cannot perform load balancing according to the metrics of routes. BGP implements load balancing over the routes that meet the following requirements:
¡     The routes have the same AS_PATH, ORIGIN, LOCAL_PREF, and MED attributes. (When the as-path-neglect keyword is specified in the balance command, BGP implements load balancing over routes with different AS_PATH attributes. Use the as-path-neglect keyword according to your network, and make sure a routing loop does not occur.)
¡     The routes are all reflected or not reflected by the route reflector.
BGP does not use the route selection rules described in "BGP route selection" for load balancing.
Figure 5 Network diagram
As shown in Figure 5, Router A and Router B are IBGP peers of Router C. Router D and Router E both advertise a route 9.0.0.0 to Router C. Router C installs the two routes to its routing table for load balancing if the following conditions exist:
¡     Load balancing with a maximum number of two routes is configured on Router C.
¡     The two routes have the same AS_PATH, ORIGIN, LOCAL_PREF, and MED.
After that, Router C forwards to Router A and Router B a single route that has NEXT_HOP changed to Router C and other attributes changed to those of the optimal route.
BGP load balancing is applicable between EBGP peers, between IBGP peers, and between confederations.
You can use the following methods to facilitate management and improve route distribution efficiency on a large-scale BGP network.
·     Route summarization
Route summarization can reduce the BGP routing table size by advertising summary routes rather than more specific routes.
The system supports both manual and automatic route summarization. Manual route summarization allows you to determine the attribute of a summary route and whether to advertise more specific routes.
·     Route dampening
Route frapping (a route comes up and disappears in the routing table frequently) causes BGP to send many routing updates. It can consume too many resources and affect other operations.
In most cases, BGP runs in complex networks where route changes are more frequent. To solve the problem caused by route flapping, you can use BGP route dampening to suppress unstable routes.
BGP route dampening uses a penalty value to judge the stability of a route. The bigger the value, the less stable the route. Each time a route state changes from reachable to unreachable, or a reachable route's attribute changes, BGP adds a penalty value of 1000 to the route. When the penalty value of the route exceeds the suppress value, the route is suppressed and cannot become the optimal route. When the penalty value reaches the upper limit, no penalty value is added.
If the suppressed route does not flap, its penalty value gradually decreases to half of the suppress value after a period of time. This period is called "Half-life." When the value decreases to the reusable threshold value, the route is usable again.
Figure 6 BGP route dampening
·     Peer group
You can organize BGP peers with the same attributes into a group to simplify their configurations.
When a peer joins the peer group, the peer obtains the same configuration as the peer group. If the configuration of the peer group is changed, the configuration of group members is changed.
·     Community
You can apply a community list or an extended community list to a routing policy for route control. For more information, see "BGP path attributes."
·     Route reflector
IBGP peers must be fully meshed to maintain connectivity. If n routers exist in an AS, the number of IBGP connections is n(n-1)/2. If a large number of IBGP peers exist, large amounts of network and CPU resources are consumed to maintain sessions.
Using route reflectors can solve this issue. In an AS, a router acts as a route reflector, and other routers act as clients connecting to the route reflector. The route reflector forwards routing information received from a client to other clients. In this way, all clients can receive routing information from one another without establishing BGP sessions.
A router that is neither a route reflector nor a client is a non-client, which, as shown in Figure 7, must establish BGP sessions to the route reflector and other non-clients.
Figure 7 Network diagram for a route reflector
The route reflector and clients form a cluster. Typically a cluster has one route reflector. The ID of the route reflector is the Cluster_ID. You can configure more than one route reflector in a cluster to improve availability, as shown in Figure 8. The configured route reflectors must have the same Cluster_ID to avoid routing loops.
Figure 8 Network diagram for route reflectors
When the BGP routers in an AS are fully meshed, route reflection is unnecessary because it consumes more bandwidth resources. You can use commands to disable route reflection instead of modifying network configuration or changing network topology.
After route reflection is disabled between clients, routes can still be reflected between a client and a non-client.
·     Confederation
Confederation is another method to manage growing IBGP connections in an AS. It splits an AS into multiple sub-ASs. In each sub-AS, IBGP peers are fully meshed. As shown in Figure 9, intra-confederation EBGP connections are established between sub-ASs in AS 200.
Figure 9 Confederation network diagram
A non-confederation BGP speaker does not need to know sub-ASs in the confederation. It considers the confederation as one AS, and the confederation ID as the AS number. In the above figure, AS 200 is the confederation ID.
Confederation has a deficiency. When you change an AS into a confederation, you must reconfigure the routers, and the topology will be changed.
In large-scale BGP networks, you can use both route reflector and confederation.
MP-BGP
BGP-4 carries only IPv4 unicast routing information. IETF extended BGP-4 by introducing Multiprotocol Extensions for BGP-4 (MP-BGP). MP-BGP can carry routing information for multiple address families, including IPv4 multicast, IPv6 unicast, IPv6 multicast, and VPNv4.
MP-BGP is backward compatible with BGP.
MP-BGP extended attributes
Prefixes and next hops are key routing information. BGP-4 uses update messages to carry the following information:
·     Feasible route prefixes in the Network Layer Reachability Information (NLRI) field.
·     Unfeasible route prefixes in the withdrawn routes field.
·     Next hops in the NEXT_HOP attribute.
BGP-4 cannot carry routing information for multiple network layer protocols.
To support multiple network layer protocols, MP-BGP defines the following path attributes:
·     MP_REACH_NLRICarries feasible route prefixes and next hops for multiple network layer protocols.
·     MP_UNREACH_NLRICarries unfeasible route prefixes for multiple network layer protocols.
MP-BGP uses these two attributes to advertise feasible and unfeasible routes for different network layer protocols. BGP speakers not supporting MP-BGP ignore updates containing these attributes and do not forward them to its peers.
The current MP-BGP implementation supports multiple protocol extensions, including VPN, IPv6, and multicast. For more information about VPN, see MPLS Configuration Guide.
Address family
MP-BGP uses address families and subsequent address families to identify different network layer protocols for routes contained in the MP_REACH_NLRI and MP_UNREACH_NLRI attributes. For example, an Address Family Identifier (AFI) of 2 and a Subsequent Address Family Identifier (SAFI) of 1 identify IPv6 unicast routing information carried in the MP_REACH_NLRI attribute. For address family values, see RFC 1700.
BGP uses different views to manage routing information for different address families and different VPN instances. Most BGP commands are available in all BGP views. BGP supports multiple VPN instances by establishing a separate routing table for each VPN instance.
Table 1 describes different BGP configuration views.
Table 1 BGP configuration views
View names
Ways to enter the views
Remarks
BGP view
[Sysname] bgp 100
[Sysname-bgp]
Configurations in this view apply to all address families of the public network and all VPN instances (such as confederation, GR, and logging configurations), or apply to all address families of the public network.
BGP IPv4 unicast address family view
[Sysname] bgp 100
[Sysname-bgp] address-family ipv4 unicast
[Sysname-bgp-ipv4]
Configurations in this view apply to IPv4 unicast routes and peers on the public network.
BGP IPv6 unicast address family view
[Sysname] bgp 100
[Sysname-bgp] address-family ipv6 unicast
[Sysname-bgp-ipv6]
Configurations in this view apply to IPv6 unicast routes and peers on the public network.
BGP VPNv4 address family view
[Sysname] bgp 100
[Sysname-bgp] address-family vpnv4
[Sysname-bgp-vpnv4]
Configurations in this view apply to VPNv4 routes and peers.
For more information about BGP VPNv4 address family view, see MPLS Configuration Guide.
BGP VPNv6 address family view
[Sysname] bgp 100
[Sysname-bgp] address-family vpnv6
[Sysname-bgp-vpnv6]
Configurations in this view apply to VPNv6 routes and peers.
For more information about BGP VPNv6 address family view, see MPLS Configuration Guide.
BGP L2VPN address family view
[Sysname] bgp 100
[Sysname-bgp] address-family l2vpn
[Sysname-bgp-l2vpn]
Configurations in this view apply to L2VPN information and L2VPN peers.
For more information about BGP l2VPN address family view, see MPLS Configuration Guide.
BGP-VPN instance view
[Sysname] bgp 100
[Sysname-bgp] ip vpn-instance vpn1
[Sysname-bgp-vpn1]
Configurations in this view apply to all address families in the specified VPN instance.
BGP-VPN IPv4 unicast address family view
[Sysname] bgp 100
[Sysname-bgp-vpn1] address-family ipv4 unicast
[Sysname-bgp-ipv4-vpn1]
Configurations in this view apply to IPv4 unicast routes and peers in the specified VPN instance.
BGP-VPN IPv6 unicast address family view
[Sysname] bgp 100
[Sysname-bgp-vpn1] address-family ipv6 unicast
[Sysname-bgp-ipv6-vpn1]
Configurations in this view apply to IPv6 unicast routes and peers in the specified VPN instance.
BGP-VPN VPNv4 address family view
[Sysname] bgp 100
[Sysname-bgp-vpn1] address-family vpnv4
[Sysname-bgp-vpnv4-vpn1]
Configurations in this view apply to VPNv4 routes and peers in the specified VPN instance.
For more information about BGP-VPN VPNv4 address family view, see MPLS Configuration Guide.
·     RFC 1700, ASSIGNED NUMBERS
·     RFC 1771, A Border Gateway Protocol 4 (BGP-4)
·     RFC 1997, BGP Communities Attribute
·     RFC 2439, BGP Route Flap Damping
·     RFC 2796, BGP Route Reflection
·     RFC 2858, Multiprotocol Extensions for BGP-4
·     RFC 2918, Route Refresh Capability for BGP-4
·     RFC 3065, Autonomous System Confederations for BGP
·     RFC 3392, Capabilities Advertisement with BGP-4
·     RFC 4271, A Border Gateway Protocol 4 (BGP-4)
·     RFC 4360, BGP Extended Communities Attribute
·     RFC 4724, Graceful Restart Mechanism for BGP
·     RFC 4760, Multiprotocol Extensions for BGP-4
·     RFC 5082, The Generalized TTL Security Mechanism (GTSM)
In a basic BGP network, you only need to perform the following configurations:
·     Enable BGP.
·     Configure BGP peers or peer groups. If you configure a BGP setting at both the peer group and the peer level, the most recent configuration takes effect on the peer.
·     Control BGP route generation.
To control BGP route distribution and path selection, you must perform additional configuration tasks.
To configure BGP, perform the following tasks (IPv4):
Tasks at a glance
Remarks
Configuring basic BGP:
·     (Required.) Enabling BGP
·     (Required.) Perform one of the following tasks:
¡ Configuring a BGP peer
¡ Configuring dynamic BGP peers
¡ Configuring a BGP peer group
·     (Optional.) Specifying the source interface for TCP connections
H3C recommends that you configure BGP peer groups on large scale BGP networks for easy configuration and maintenance.
Generating BGP routes (perform at least one of the following tasks):
·     Injecting a local network
·     Redistributing IGP routes
N/A
(Optional.) Controlling route distribution and reception:
·     Configuring BGP route summarization
·     Advertising optimal routes in the IP routing table
·     Advertising a default route to a peer or peer group
·     Limiting routes received from a peer or peer group
·     Configuring BGP route filtering policies
·     Configuring BGP route dampening
N/A
(Optional.) Controlling BGP path selection:
·     Specifying a preferred value for routes received
·     Configuring preferences for BGP routes
·     Configuring the default local preference
·     Configuring the MED attribute
·     Configuring the NEXT_HOP attribute
·     Configuring the AS_PATH attribute
N/A
(Optional.) Tuning and optimizing BGP networks:
·     Configuring the keepalive interval and hold time
·     Configuring the interval for sending updates for the same route
·     Enabling BGP to establish an EBGP session over multiple hops
·     Enabling immediate re-establishment of direct EBGP connections upon link failure
·     Enabling 4-byte AS number suppression
·     Enabling MD5 authentication for BGP peers
·     Configuring BGP load balancing
·     Configuring IPsec for IPv6 BGP
·     Disabling BGP to establish a session to a peer or peer group
·     Configuring GTSM for BGP
·     Configuring BGP soft-reset
·     Protecting an EBGP peer when memory usage reaches level 2 threshold
N/A
(Optional.) Configuring a large-scale BGP network:
·     Configuring BGP community
·     Configuring BGP route reflection
·     Ignoring the ORIGINATOR_ID attribute
·     Configuring a BGP confederation
N/A
(Optional.) Configuring BGP GR
N/A
(Optional.) Configuring BGP NSR
(Optional.) Enabling SNMP notifications for BGP
N/A
(Optional.) Enabling logging of session state changes
N/A
(Optional.) Configuring BFD for BGP
N/A
(Optional.) Configuring BGP FRR
N/A
To configure BGP, perform the following tasks (IPv6):
Tasks at a glance
Remarks
N/A
·     Configuring BGP update sending delay
N/A
N/A
N/A
N/A
N/A
N/A
N/A
N/A
N/A
(Optional.) Configuring 6PE
N/A
This section describes the basic settings required for a BGP network to run.
Enabling BGP
A router ID is the unique identifier of a BGP router in an AS.
·     To ensure the uniqueness of a router ID and enhance availability, specify in BGP view the IP address of a local loopback interface as the router ID.
·     If no router ID is specified in BGP view, the global router ID is used.
·     To modify a non-zero router ID of BGP, use the router-id command in BGP view, rather than the router id command in system view.
·     If you specify a router ID in BGP view and then remove the interface that owns the router ID, the router does not select a new router ID. To select a new router ID, use the undo router-id command in BGP view.
To enable BGP:
Step
Remarks
N/A
2.     Configure a global router ID.
router id router-id
By default, no global router ID is configured, and BGP uses the highest loopback interface IP address—if any—as the router ID. If no loopback interface IP address is available, BGP uses the highest physical interface IP address as the route ID regardless of the interface status.
3.     Enable BGP and enter BGP view or BGP-VPN instance view.
·     Enable BGP and enter BGP view:
bgp as-number
·     Enable BGP and enter BGP-VPN instance view:
a.     bgp as-number
a.     ip vpn-instance vpn-instance-name
By default, BGP is not enabled.
A router can reside in only one AS, so the router can run only one BGP process.
To enter BGP-VPN instance view, the specified VPN instance must already exist and have the route distinguisher (RD) configured. For more information, see MPLS Configuration Guide.
4.     Configure the router ID.
By default, the global router ID is used.
The auto-select keyword is supported only in BGP-VPN instance view.
Configuring an IPv4 BGP peer
Step
Remarks
N/A
2.     Enter BGP view or BGP-VPN instance view.
·     Enter BGP view:
bgp as-number
·     Enter BGP-VPN instance view:
a.     bgp as-number
b.     ip vpn-instance vpn-instance-name
N/A
3.     Create an IPv4 BGP peer and specify its AS number.
peer ip-address as-number as-number
By default, no IPv4 BGP peer is created.
4.     (Optional.) Configure a description for a peer.
peer ip-address description description-text
By default, no description is configured for a peer.
5.     Create the BGP IPv4 unicast address family or BGP-VPN IPv4 unicast address family and enter its view.
By default, the BGP IPv4 unicast address family or BGP-VPN IPv4 unicast address family is not created.
6.     Enable the router to exchange IPv4 unicast routing information with the specified peer.
peer ip-address enable
By default, the router cannot exchange IPv4 unicast routing information with the peer.
Configuring an IPv6 BGP peer
Step
Remarks
N/A
·     Enter BGP view:
bgp as-number
a.     bgp as-number
N/A
3.     Create an IPv6 BGP peer and specify its AS number.
By default, no IPv6 BGP peer is created.
BGP can use an IPv6 link-local address to establish a peer relationship with a peer when the following conditions exist:
·     The IPv6 link-local address belongs to the interface directly connected to the local router.
·     The peer connect-interface command is configured on the peer to specify the interface as the source interface.
peer ipv6-address description description-text
5.     Create the BGP IPv6 unicast address family or BGP-VPN IPv6 unicast address family and enter its view.
By default, the BGP IPv6 unicast address family or BGP-VPN IPv6 unicast address family is not created.
6.     Enable the router to exchange IPv6 unicast routing information with the specified peer.
peer ipv6-address enable
By default, the router cannot exchange IPv6 unicast routing information with the peer.
This feature enables BGP to establish dynamic BGP peer relationships with devices in a network. BGP accepts connection requests from the network but it does not initiate connection requests to the network.
After a device in the network initiates a connection request, BGP establishes a dynamic peer relationship with the device.
If multiple BGP peers reside in the same network, you can use this feature to simplify BGP peer configuration.
Configuring dynamic BGP peers (IPv4 unicast address family)
Step
Remarks
N/A
·     Enter BGP view:
bgp as-number
a.     bgp as-number
N/A
3.     Specify devices in a network as dynamic BGP peers and specify an AS number for the peers.
peer ip-address mask-length as-number as-number
By default, no dynamic BGP peer is specified.
4.     (Optional.) Configure a description for dynamic BGP peers.
peer ip-address mask-length description description-text
By default, no description is configured for dynamic BGP peers.
6.     Enable BGP to exchange IPv4 unicast routing information with dynamic BGP peers in the specified network.
peer ip-address mask-length enable
By default, BGP cannot exchange IPv4 unicast routing information with dynamic BGP peers.
Configuring dynamic BGP peers (IPv6 unicast address family)
Step
Remarks
N/A
·     Enter BGP view:
bgp as-number
a.     bgp as-number
N/A
peer ipv6-address prefix-length description description-text
6.     Enable BGP to exchange IPv6 unicast routing information with dynamic BGP peers in the specified network.
By default, BGP cannot exchange IPv6 unicast routing information with dynamic BGP peers.
The peers in a peer group use the same route selection policy.
In a large-scale network, many peers can use the same route selection policy. You can configure a peer group and add these peers into this group. When you change the policy for the group, the modification also applies to the peers in the group.
A peer group is an IBGP peer group if peers in it belong to the local AS, and is an EBGP peer group if peers in it belong to different ASs.
Configuring an IBGP peer group
After you create an IBGP peer group and then add a peer into it, the system creates the peer in BGP view and specifies the local AS number for the peer.
To configure an IBGP peer group (IPv4):
Step
Remarks
N/A
·     Enter BGP view:
bgp as-number
a.     bgp as-number
N/A
3.     Create an IBGP peer group.
group group-name [ internal ]
By default, no IBGP peer group is created.
4.     Add a peer into the IBGP peer group.
peer ip-address [ mask-length ] group group-name [ as-number as-number ]
By default, no peer exists in the peer group.
To use the as-number as-number option, you must specify the local AS number.
5.     (Optional.) Configure a description for a peer group.
peer group-name description description-text
By default, no description is configured for the peer group.
6.     Create the BGP IPv4 unicast address family or BGP-VPN IPv4 unicast address family and enter its view.
7.     Enable the router to exchange IPv4 unicast routing information with peers in the specified peer group.
peer group-name enable
By default, the router cannot exchange IPv4 unicast routing information with the peers.
To configure an IBGP peer group (IPv6):
Step
Remarks
N/A
·     Enter BGP view:
bgp as-number
a.     bgp as-number
N/A
6.     Create the BGP IPv6 unicast address family or BGP-VPN IPv6 unicast address family and enter its view.
7.     Enable the router to exchange IPv6 unicast routing information with peers in the specified peer group.
By default, the router cannot exchange IPv6 unicast routing information with the peers.
Configuring an EBGP peer group
If peers in an EBGP group belong to the same external AS, the EBGP peer group is a pure EBGP peer group. If not, it is a mixed EBGP peer group.
Use one of the following methods to configure an EBGP peer group:
·     Method 1—Create an EBGP peer group, specify its AS number, and add peers into it. All the added peers have the same AS number. All peers in the peer group have the same AS number as the peer group. You can specify an AS number for a peer before adding it into the peer group. The AS number must be the same as that of the peer group.
·     Method 2Create an EBGP peer group, specify an AS number for a peer, and add the peer into the peer group. Peers added in the group can have different AS numbers.
·     Method 3Create an EBGP peer group and add a peer with an AS number into it. Peers added in the group can have different AS numbers.
To configure an EBGP peer group by using Method 1 (IPv4):
Step
Remarks
N/A
·     Enter BGP view:
bgp as-number
a.     bgp as-number
N/A
3.     Create an EBGP peer group.
group group-name external
By default, no EBGP peer group is created.
4.     Specify the AS number for the group.
By default, no AS number is specified.
If a peer group contains peers, you cannot remove or change its AS number.
5.     Add a peer into the EBGP peer group.
The as-number as-number option, if used, must specify the same AS number as the peer group-name as-number as-number command.
6.     (Optional.) Configure a description for a peer group.
7.     Create the BGP IPv4 unicast address family or BGP-VPN IPv4 unicast address family and enter its view.
8.     Enable the router to exchange IPv4 unicast routing information with peers in the specified peer group.
To configure an EBGP peer group by using Method 1 (IPv6):
Step
Remarks
N/A
·     Enter BGP view:
bgp as-number
a.     bgp as-number
N/A
7.     Create the BGP IPv6 unicast address family or BGP-VPN IPv6 unicast address family and enter its view.
8.     Enable the router to exchange IPv6 unicast routing information with peers in the specified peer group.
To configure an EBGP peer group by using Method 2 (IPv4):
Step
Remarks
N/A
·     Enter BGP view:
bgp as-number
a.     bgp as-number
N/A
4.     Create an IPv4 BGP peer and specify its AS number.
peer ip-address [ mask-length ] as-number as-number
5.     Add the peer into the EBGP peer group.
The as-number as-number option, if used, must specify the same AS number as the peer ip-address as-number as-number command.
To configure an EBGP peer group by using Method 2 (IPv6):
Step
Remarks
N/A
·     Enter BGP view:
bgp as-number
a.     bgp as-number
N/A
4.     Create an IPv6 BGP peer and specify its AS number.
peer ipv6-address [ prefix-length ] as-number as-number
The as-number as-number option, if used, must specify the same AS number as the peer ipv6-address [ prefix-length ] as-number as-number command.
6.     (Optional.) Configure a description for the peer group.
To configure an EBGP peer group by using Method 3 (IPv4):
Step
Remarks
N/A
·     Enter BGP view:
bgp as-number
a.     bgp as-number
N/A
4.     Add a peer into the EBGP peer group.
peer ip-address [ mask-length ] group group-name as-number as-number
5.     (Optional.) Configure a description for the peer group.
To configure an EBGP peer group by using Method 3 (IPv6):
Step
Remarks
N/A
·     Enter BGP view:
bgp as-number
a.     bgp as-number
N/A
By default, BGP uses the output interface of the optimal route to a peer or peer group as the source interface for establishing TCP connections to the peer or peer group, and it uses the IP address/IPv6 address of the output interface as the source IP address/IPv6 address of TCP connections. You can change the source interface in the following scenarios:
·     If the peer's IP/IPv6 address belongs to an interface indirectly connected to the local router, specify that interface as the source interface for TCP connections on the peer. For example, interface A on the local end is directly connected to interface B on the peer. If you use the peer x.x.x.x as-number as-number command on the local end, and x.x.x.x is not the IP address of interface B, you must do the following:
a.     Use the peer connect-interface command on the peer.
b.     Specify the interface whose IP address is x.x.x.x as the source interface.
¡     The IPv6 link-local address belongs to the interface directly connected to the local router.
¡     The peer connect-interface command is configured on the peer to specify the interface as the source interface.
·     If the source interface fails on a BGP router that has multiple links to a peer, BGP must re-establish TCP connections. To avoid this problem, use a loopback interface as the source interface.
·     To establish multiple BGP sessions between two routers, specify the source interface for establishing TCP connections to each peer on the local router. Otherwise, the local BGP router may fail to establish a TCP connection to a peer when using the output interface of the optimal route to the peer as the source interface.
To specify the source interface for TCP connections (IPv4):
Step
Remarks
N/A
·     Enter BGP view:
bgp as-number
a.     bgp as-number
N/A
3.     Specify the source interface for establishing TCP connections to a peer or peer group.
peer { group-name | ip-address [ mask-length ] } connect-interface interface-type interface-number
By default, BGP uses the output interface of the optimal route to the BGP peer or peer group as the source interface for establishing a TCP connection to the peer or peer group.
To specify the source interface for TCP connections (IPv6):
Step
Remarks
N/A
·     Enter BGP view:
bgp as-number
a.     bgp as-number
N/A
BGP can generate routes in the following ways:
·     Advertise local networks.
·     Redistribute IGP routes.
Perform this task to inject a network in the local routing table to the BGP routing table, so BGP can advertise the network to BGP peers. The ORIGIN attribute of BGP routes advertised in this way is IGP. You can also use a routing policy to control route advertisement.
The specified network must be available and active in the local IP routing table.
To inject a local network (IPv4):
Step
Remarks
N/A
·     Enter BGP view:
bgp as-number
a.     bgp as-number
N/A
3.     Enter BGP IPv4 unicast address family view or BGP-VPN IPv4 unicast address family view.
N/A
4.     Inject a local network to the BGP routing table.
network ip-address [ mask | mask-length ] [ route-policy route-policy-name ]
By default, BGP does not advertise any local network.
To inject a local network (IPv6):
Step
Remarks
N/A
·     Enter BGP view:
bgp as-number
a.     bgp as-number
N/A
3.     Enter BGP IPv6 unicast address family view or BGP-VPN IPv6 unicast address family view.
N/A
4.     Inject a local network to the IPv6 BGP routing table.
Perform this task to configure route redistribution from an IGP to BGP.
By default, BGP does not redistribute default IGP routes. You can use the default-route imported command to redistribute default IGP routes into the BGP routing table.
Only active routes can be redistributed. To view route state information, use the display ip routing-table protocol or display ipv6 routing-table protocol command.
The ORIGIN attribute of BGP routes redistributed from IGPs is INCOMPLETE.
To configure BGP to redistribute IGP routes (IPv4):
Step
Remarks
N/A
·     Enter BGP view:
bgp as-number
a.     bgp as-number
N/A
N/A
4.     Enable route redistribution from the specified IGP into BGP.
import-route protocol [ { process-id | all-processes } [ med med-value | route-policy route-policy-name ] * ]
By default, BGP does not redistribute IGP routes.
5.     (Optional.) Enable default route redistribution into BGP.
By default, BGP does not redistribute default routes.
To configure BGP to redistribute IGP routes (IPv6):
Step
Remarks
N/A
·     Enter BGP view:
bgp as-number
a.     bgp as-number
N/A
N/A
import-route protocol [ process-id [ med med-value | route-policy route-policy-name ] * ]
This section describes how to control route distribution and reception.
Route summarization can reduce the number of redistributed routes and the routing table size. IPv4 BGP supports automatic route summarization and manual route summarization. Manual summarization takes precedence over automatic summarization. IPv6 BGP supports only manual route summarization.
The output interface of a BGP summary route is Null 0 on the originating router. Therefore, a summary route must not be an optimal route on the originating router. Otherwise, BGP will fail to forward packets matching the route. If a summarized specific route has the same mask as the summary route, but has a lower priority, the summary route becomes the optimal route. To ensure correct packet forwarding, change the priority of the summary or specific route to make the specific route the optimal route.
Configuring automatic route summarization
Automatic route summarization enables BGP to summarize IGP subnet routes redistributed by the import-route command so BGP advertises only natural network routes.
To configure automatic route summarization (IPv4):
Step
Remarks
N/A
·     Enter BGP view:
bgp as-number
a.     bgp as-number
N/A
N/A
4.     Configure automatic route summarization.
summary automatic
By default, automatic route summarization is not configured.
Configuring manual route summarization
By configuring manual route summarization, you can do the following:
·     Summarize both redistributed routes and routes injected using the network command.
·     Determine the mask length for a summary route.
To configure BGP manual route summarization (IPv4):
Step
Remarks
N/A
·     Enter BGP view:
bgp as-number
a.     bgp as-number
N/A
N/A
4.     Create a summary route in the BGP routing table.
aggregate ip-address { mask | mask-length } [ as-set | attribute-policy route-policy-name | detail-suppressed | origin-policy route-policy-name | suppress-policy route-policy-name ] *
By default, no summary route is configured.
To configure BGP manual route summarization (IPv6):
Step
Remarks
N/A
2.     Enter BGP view.
bgp as-number
N/A
3.     Enter BGP IPv6 unicast address family view.
N/A
4.     Create a summary route in the IPv6 BGP routing table.
By default, BGP advertises optimal routes in the BGP routing table, which may not be optimal in the IP routing table. This task allows you to advertise BGP routes that are optimal in the IP routing table to all BGP peers.
To enable BGP to advertise optimal routes in the IP routing table:
Step
Remarks
N/A
2.     Enter BGP view.
bgp as-number
N/A
3.     Enable BGP to advertise optimal routes in the IP routing table.
By default, BGP advertises optimal routes in the BGP routing table.
Perform this task to advertise a default BGP route with the next hop being the advertising router to a peer or peer group.
To advertise a default route to a peer or peer group (IPv4):
Step
Remarks
N/A
·     Enter BGP view:
bgp as-number
a.     bgp as-number
N/A
N/A
4.     Advertise a default route to a peer or peer group.
peer { group-name | ip-address [ mask-length ] } default-route-advertise [ route-policy route-policy-name ]
By default, no default route is advertised.
To advertise a default route to a peer or peer group (IPv6):
Step
Remarks
N/A
2.     Enter BGP view.
bgp as-number
N/A
N/A
peer { group-name | ipv6-address [ prefix-length ] } default-route-advertise [ route-policy route-policy-name ]
This feature can prevent attacks that send a large number of BGP routes to the router.
If the number of routes received from a peer or peer group exceeds the upper limit, the router takes one of the following actions based on your configuration:
·     Tears down the BGP session to the peer or peer group and does not attempt to re-establish the session.
·     Continues to receive routes from the peer or peer group and generates a log message.
·     Tears down the BGP session to the peer or peer group and, after a specified period of time, re-establishes a BGP session to the peer or peer group.
You can specify a percentage threshold for the router to generate a log message. When the ratio of the number of received routes to the maximum number reaches the percentage value, the router generates a log message.
To limit routes that a router can receive from a peer or peer group (IPv4):
Step
Remarks
N/A
·     Enter BGP view:
bgp as-number
a.     bgp as-number
N/A
N/A
4.     Specify the maximum number of routes that a router can receive from a peer or peer group.
peer { group-name | ip-address [ mask-length ] } route-limit prefix-number [ { alert-only | discard | reconnect reconnect-time } | percentage-value ] *
By default, the number of routes that a router can receive from a peer or peer group is not limited.
To limit routes that a router can receive from a peer or peer group (IPv6):
Step
Remarks
N/A
2.     Enter BGP view.
bgp as-number
N/A
N/A
peer { group-name | ipv6-address [ prefix-length ] } route-limit prefix-number [ { alert-only | discard | reconnect reconnect-time } | percentage-value ] *
Configuration prerequisites
Before you configure BGP routing filtering policies, configure the following filters used for route filtering as needed:
·     ACL (see ACL and QoS Configuration Guide).
·     Prefix list (see "Configuring routing policies").
·     Routing policy (see "Configuring routing policies").
·     AS path list (see "Configuring routing policies").
Configuring BGP route distribution filtering policies
To configure BGP route distribution filtering policies, use the following methods:
·     Use an ACL or prefix list to filter routing information advertised to all peers.
·     Use a routing policy, ACL, AS path list, or prefix list to filter routing information advertised to a peer or peer group.
If you configure multiple filtering policies, apply them in the following sequence:
1.     filter-policy export
2.     peer filter-policy export
3.     peer as-path-acl export
4.     peer prefix-list export
5.     peer route-policy export
Only routes passing all the configured policies can be advertised.
To configure BGP route distribution filtering policies (IPv4):
Step
Remarks
N/A
·     Enter BGP view:
bgp as-number
a.     bgp as-number
N/A
N/A
4.     Configure BGP route distribution filtering policies.
·     Reference an ACL or IP prefix list to filter advertised BGP routes:
filter-policy { acl-number | prefix-list prefix-list-name } export [ direct | isis process-id | ospf process-id | rip process-id | static ]
·     Reference a routing policy to filter BGP routes advertised to a peer or peer group:
peer { group-name | ip-address [ mask-length ] } route-policy route-policy-name export
·     Reference an ACL to filter BGP routes advertised to a peer or peer group:
peer { group-name | ip-address [ mask-length ] } filter-policy acl-number export
·     Reference an AS path list to filter BGP routes advertised to a peer or peer group:
peer { group-name | ip-address [ mask-length ] } as-path-acl as-path-acl-number export
·     Reference an IPv4 prefix list to filter BGP routes advertised to a peer or peer group:
peer { group-name | ip-address [ mask-length ] } prefix-list prefix-list-name export
Use at least one method.
By default, no BGP distribution filtering policy is configured.
To configure BGP route distribution filtering policies (IPv6):
Step
Remarks
N/A
·     Enter BGP view:
bgp as-number
a.     bgp as-number
N/A
N/A
·     Reference an ACL or IPv6 prefix list to filter advertised BGP routes:
filter-policy { acl6-number | prefix-list ipv6-prefix-name } export [ direct | isisv6 process-id | ospfv3 process-id | ripng process-id | static ]
peer { group-name | ipv6-address [ prefix-length ] } route-policy route-policy-name export
peer { group-name | ipv6-address [ prefix-length ] } filter-policy acl6-number export
peer { group-name | ipv6-address [ prefix-length ] } as-path-acl as-path-acl-number export
·     Reference an IPv6 prefix list to filter BGP routes advertised to a peer or peer group
 peer { group-name | ipv6-address [ prefix-length ] } prefix-list ipv6-prefix-name export
Not configured by default.
Configuring BGP route reception filtering policies
You can use the following methods to configure BGP route reception filtering policies:
·     Use an ACL or prefix list to filter routing information received from all peers.
·     Use a routing policy, ACL, AS path list, or prefix list to filter routing information received from a peer or peer group.
1.     filter-policy import
2.     peer filter-policy import
3.     peer as-path-acl import
4.     peer prefix-list import
5.     peer route-policy import
Only routes passing all the configured policies can be received.
To configure BGP route reception filtering policies (IPv4):
Step
Remarks
N/A
·     Enter BGP view:
bgp as-number
a.     bgp as-number
N/A
N/A
4.     Configure BGP route reception filtering policies.
·     Reference an ACL or IP prefix list to filter BGP routes received from all peers:
filter-policy { acl-number | prefix-list prefix-list-name } import
·     Reference a routing policy to filter BGP routes received from a peer or peer group:
peer { group-name | ip-address [ mask-length ] } route-policy route-policy-name import
·     Reference an ACL to filter BGP routes received from a peer or peer group:
peer { group-name | ip-address [ mask-length ] } filter-policy acl-number import
·     Reference  an AS path list to filter BGP routes received from a peer or peer group:
peer { group-name | ip-address [ mask-length ] } as-path-acl as-path-acl-number import
·     Reference an IPv4 prefix list to filter BGP routes received from a peer or peer group:
peer { group-name | ip-address [ mask-length ] } prefix-list prefix-list-name import
By default, no route reception filtering is configured.
To configure BGP route reception filtering policies (IPv6):
Step
Remarks
N/A
·     Enter BGP view:
bgp as-number
a.     bgp as-number
N/A
N/A
·     Reference ACL or IPv6 prefix list to filter BGP routes received from all peers:
filter-policy { acl6-number | prefix-list ipv6-prefix-name } import
peer { group-name | ipv6-address [ prefix-length ] } route-policy route-policy-name import
peer { group-name | ipv6-address [ prefix-length ] } filter-policy acl6-number import
peer { group-name | ipv6-address [ prefix-length ] } as-path-acl as-path-acl-number import
·     Reference an IPv6 prefix list to filter BGP routes received from a peer or peer group:
peer { group-name | ipv6-address [ prefix-length ] } prefix-list ipv6-prefix-name import
Perform this task to configure BGP to delay sending updates on reboot. After this feature is configured, BGP redistributes all routes from other neighbors on reboot, and then advertises the optimal route. This configuration reduces traffic loss due to the reboot.
To configure BGP update sending delay:
Step
Remarks
N/A
2.     Enter BGP view.
bgp as-number
N/A
3.     Configure BGP update sending delay.
By default, BGP immediately sends updates on reboot.
4.     Configure BGP to immediately send updates for routes that match a prefix list on reboot.
bgp update-delay on-startup prefix-list prefix-list-name
By default, BGP delays sending updates for all routes on reboot.
Use this command when updates for routes that match a prefix list must be sent immediately.
Route dampening enables BGP to not select unstable routes as optimal routes. This feature applies to EBGP routes but not to IBGP routes.
To configure BGP route dampening (IPv4):
Step
Remarks
N/A
·     Enter BGP view:
bgp as-number
a.     bgp as-number
N/A
N/A
4.     Configure BGP route dampening.
By default, BGP route dampening is not configured.
To configure BGP route dampening (IPv6):
Step
Remarks
N/A
·     Enter BGP view:
bgp as-number
a.     bgp as-number
N/A
N/A
4.     Configure IPv6 BGP route dampening.
By default, IPv6 BGP route dampening is not configured.
By configuring BGP path attributes, you can control BGP path selection.
Perform this task to set a preferred value for specific routes to control BGP path selection.
Among multiple routes that have the same destination/mask and are learned from different peers, the one with the greatest preferred value is selected as the optimal route.
To specify a preferred value for routes from a peer or peer group (IPv4):
Step
Remarks
N/A
·     Enter BGP view:
bgp as-number
a.     bgp as-number
N/A
N/A
4.     Specify a preferred value for routes received from a peer or peer group.
peer { group-name | ip-address [ mask-length ] } preferred-value value
The default preferred value is 0.
To specify a preferred value for routes from a peer or peer group (IPv6):
Step
Remarks
N/A
·     Enter BGP view:
bgp as-number
a.     bgp as-number
N/A
N/A
peer { group-name | ipv6-address [ prefix-length ] } preferred-value value
Routing protocols each have a default preference. If they find multiple routes destined for the same network, the route found by the routing protocol with the highest preference is selected as the optimal route.
You can use the preference command to modify preferences for EBGP, IBGP, and local BGP routes, or reference a routing policy to set a preference for matching routes. For routes not matching the routing policy, the default preference applies.
If a device has an EBGP route and a local BGP route to reach the same destination, it does not select the EBGP route because the EBGP route has a lower preference than the local BGP route by default. You can use the network short-cut command to configure the EBGP route as a shortcut route that has the same preference as the local BGP route. The EBGP route will more likely become the optimal route.
To configure preferences for BGP routes (IPv4):
Step
Remarks
N/A
·     Enter BGP view:
bgp as-number
a.     bgp as-number
N/A
N/A
4.     Configure preferences for EBGP, IBGP, and local BGP routes.
The default preferences for EBGP, IBGP, and local BGP routes are 255, 255, and 130.
5.     Configure an EBGP route as a shortcut route.
network ip-address [ mask | mask-length ] short-cut
By default, an EBGP route has a preference of 255.
To configure preferences for BGP routes (IPv6):
Step
Remarks
N/A
·     Enter BGP view:
bgp as-number
a.     bgp as-number
N/A
N/A
The local preference is used to determine the optimal route for traffic leaving the local AS. When a BGP router obtains from several IBGP peers multiple routes to the same destination, but with different next hops, it considers the route with the highest local preference as the optimal route.
This task allows you to specify the default local preference for routes sent to IBGP peers.
To specify the default local preference (IPv4):
Step
Remarks
N/A
·     Enter BGP view:
bgp as-number
a.     bgp as-number
N/A
N/A
4.     Configure the default local preference.
The default local preference is 100.
To specify the default local preference (IPv6):
Step
Remarks
N/A
·     Enter BGP view:
bgp as-number
a.     bgp as-number
N/A
N/A
BGP uses MED to determine the optimal route for traffic going into an AS. When a BGP router obtains multiple routes with the same destination but with different next hops, it considers the route with the smallest MED value as the optimal route if other conditions are the same.
Configuring the default MED value
To configure the default MED value (IPv4):
Step
Remarks
N/A
·     Enter BGP view:
bgp as-number
a.     bgp as-number
N/A
N/A
4.     Configure the default MED value.
default med med-value
The default MED value is 0.
To configure the default MED value (IPv6):
Step
Remarks
N/A
·     Enter BGP view:
bgp as-number
a.     bgp as-number
N/A
N/A
Enabling MED comparison for routes from different ASs
This task enables BGP to compare the MEDs of routes from different ASs.
To enable MED comparison for routes from different ASs (IPv4):
Step
Remarks
N/A
·     Enter BGP view:
bgp as-number
a.     bgp as-number
N/A
N/A
4.     Enable MED comparison for routes from different ASs.
To enable MED comparison for routes from different ASs (IPv6):
Step
Remarks
N/A
2.     Enter BGP view.
bgp as-number
N/A
N/A
Enabling MED comparison for routes on a per-AS basis
This task enables BGP to compare the MEDs of routes from an AS.
Figure 10 Route selection based on MED (in an IPv4 network)
As shown in Figure 10, Router D learns network 10.0.0.0 from both Router A and Router B. Because Router B has a smaller router ID, the route learned from Router B is optimal.
 *>i  10.0.0.0          2.2.2.2         50                    0       300e
 * i                    3.3.3.3         50                    0       200e
When Router D learns network 10.0.0.0 from Router C, it compares the route with the optimal route in its routing table. Because Router C and Router B reside in different ASs, BGP does not compare the MEDs of the two routes. Router C has a smaller router ID than Router B so the route from Router C becomes optimal.
 *>i  10.0.0.0          1.1.1.1         60                    0       200e
 * i  10.0.0.0          2.2.2.2         50                    0       300e
However, Router C and Router A reside in the same AS, and Router C has a greater MED, so network 10.0.0.0 learned from Router C should not be optimal.
To avoid this problem, you can configure the bestroute compare-med command to enable MED comparison for routes from the same AS on Router D. After that, Router D puts the routes received from each AS into a group, selects the route with the lowest MED from each group, and compares routes from different groups. The following output shows the BGP routing table on Router D after this feature is enabled. Network 10.0.0.0 learned from Router B is the optimal route.
 * i                    1.1.1.1         60                    0       200e
To enable MED comparison for routes on a per-AS basis (IPv4):
Step
Remarks
N/A
·     Enter BGP view:
bgp as-number
a.     bgp as-number
N/A
N/A
4.     Enable MED comparison for routes on a per-AS basis.
To enable MED comparison for routes on a per-AS basis (IPv6):
Step
Remarks
N/A
2.     Enter BGP view.
bgp as-number
N/A
N/A
Enabling MED comparison for routes from confederation peers
This task enables BGP to compare the MEDs of routes received from confederation peers. However, if a route received from a confederation peer has an AS number that does not belong to the confederation, BGP does not compare the route with other routes. For example, a confederation has three AS numbers 65006, 65007, and 65009. BGP receives three routes from different confederation peers. The AS_PATH attributes of these routes are 65006 65009, 65007 65009, and 65008 65009, and the MED values of them are 2, 3, and 1. Because the third route's AS_PATH attribute contains AS number 65008 that does not belong to the confederation, BGP does not compare it with other routes. As a result, the first route becomes the optimal route.
To enable MED comparison for routes from confederation peers (IPv4):
Step
Remarks
N/A
·     Enter BGP view:
bgp as-number
a.     bgp as-number
N/A
N/A
4.     Enable MED comparison for routes from confederation peers.
bestroute med-confederation
To enable MED comparison for routes from confederation peers (IPv6):
Step
Remarks
N/A
2.     Enter BGP view.
bgp as-number
N/A
N/A
By default, a BGP router does not set itself as the next hop for routes advertised to an IBGP peer or peer group. In some cases, however, you must configure the advertising router as the next hop to make sure the BGP peer can find the correct next hop.
For example, as shown in Figure 11, Router A and Router B establish an EBGP neighbor relationship, and Router B and Router C establish an IBGP neighbor relationship. If Router C has no route destined for IP address 1.1.1.1/24, you must configure Router B to set itself 3.1.1.1/24 as the next hop for the network 2.1.1.1/24 advertised to Router C.
Figure 11 NEXT_HOP attribute configuration
If a BGP router has two peers on a broadcast network, it does not set itself as the next hop for routes sent to an EBGP peer by default. As shown in Figure 12, Router A and Router B establish an EBGP neighbor relationship, and Router B and Router C establish an IBGP neighbor relationship. They are on the same broadcast network 1.1.1.0/24. When Router B sends EBGP routes to Router A, it does not set itself as the next hop by default. However, you can configure Router B to set it (1.1.1.2/24) as the next hop for routes sent to Router A by using the peer next-hop-local command as needed.
Figure 12 NEXT_HOP attribute configuration
IMPORTANT:
If you have configured BGP load balancing, the router sets itself as the next hop for routes sent to an IBGP peer or peer group regardless of whether the peer next-hop-local command is configured.
To configure the NEXT_HOP attribute (IPv4):
Step
Remarks
N/A
·     Enter BGP view:
bgp as-number
a.     bgp as-number
N/A
N/A
4.     Specify the router as the next hop for routes sent to a peer or peer group.
peer { group-name | ip-address } next-hop-local
By default, the router sets itself as the next hop for routes sent to an EBGP peer or peer group. However, it does not set itself as the next hop for routes sent to an IBGP peer or peer group.
To configure the NEXT_HOP attribute (IPv6):
Step
Remarks
N/A
2.     Enter BGP view.
bgp as-number
N/A
N/A
peer { group-name | ipv6-address } next-hop-local
Permitting local AS number to appear in routes from a peer or peer group
In general, BGP checks whether the AS_PATH attribute of a route from a peer contains the local AS number. If yes, it discards the route to avoid routing loops.
In certain network environments (for example, a Hub&Spoke network in MPLS L3VPN), however, the AS_PATH attribute of a route from a peer must be allowed to contain the local AS number. Otherwise, the route cannot be advertised correctly.
To permit the local AS number to appear in routes from a peer or peer group and specify the appearance times (IPv4):
Step
Remarks
N/A
·     Enter BGP view:
bgp as-number
a.     bgp as-number
N/A
N/A
4.     Permit the local AS number to appear in routes from a peer or peer group and specify the appearance times.
By default, the local AS number is not allowed in routes from a peer or peer group.
To permit the local AS number to appear in routes from a peer or peer group and specify the appearance times (IPv6):
Step
Remarks
N/A
·     Enter BGP view:
bgp as-number
a.     bgp as-number
N/A
N/A
peer { group-name | ipv6-address [ prefix-length ] } allow-as-loop [ number ]
Disabling BGP from considering AS_PATH during optimal route selection
To disable BGP from considering AS_PATH during optimal route selection (IPv4):
Step
Remarks
N/A
·     Enter BGP view:
bgp as-number
a.     bgp as-number
N/A
N/A
4.     Disable BGP from considering AS_PATH during optimal route selection.
bestroute as-path-neglect
By default, BGP considers AS_PATH during optimal route selection.
To disable BGP from considering AS_PATH during optimal route selection (IPv6):
Step
Remarks
N/A
·     Enter BGP view:
bgp as-number
a.     bgp as-number
N/A
N/A
Advertising a fake AS number to a peer or peer group
After you move a BGP router from an AS to another AS (from AS 2 to AS 3 for example), you have to modify the AS number of the router on all its EBGP peers. To avoid such modifications, you can configure the router to advertise a fake AS number 2 to its EBGP peers so that the EBGP peers still think that Router A is in AS 2.
To advertise a fake AS number to a peer or peer group (IPv4):
Step
Remarks
N/A
·     Enter BGP view:
bgp as-number
a.     bgp as-number
N/A
3.     Advertise a fake AS number to a peer or peer group.
peer { group-name | ip-address [ mask-length ] } fake-as as-number
By default, no fake AS number is advertised to a peer or peer group.
This command applies only to EBGP peers or EBGP peer groups.
To advertise a fake AS number to a peer or peer group (IPv6):
Step
Remarks
N/A
·     Enter BGP view:
bgp as-number
a.     bgp as-number
N/A
peer { group-name | ipv6-address [ prefix-length ] } fake-as as-number
Configuring AS number substitution
IMPORTANT:
Do not configure AS number substitution in normal circumstances. Otherwise, routing loops might occur.
To use BGP between PE and CE in MPLS L3VPN, VPN sites in different geographical areas should have different AS numbers. Otherwise, BGP discards route updates containing the local AS number. If two CEs connected to different PEs use the same AS number, you must configure AS number substitution on each PE. This substitution can replace the AS number in route updates originated by the remote CE as its own AS number before advertising them to the connected CE.
Figure 13 AS number substitution configuration (in an IPv4 network)
For example, as shown in Figure 13, CE 1 and CE 2 use the same AS number 800. To ensure bidirectional communication between the two sites, configure AS number substitution on PE 2. PE 2 replaces AS 800 with AS 100 for the BGP route update originated from CE 1 before advertising it to CE 2. Perform the same configuration on PE 1.
To configure AS number substitution for a peer or peer group (IPv4):
Step
Remarks
N/A
·     Enter BGP view:
bgp as-number
a.     bgp as-number
N/A
3.     Configure AS number substitution for a peer or peer group.
peer { group-name | ip-address [ mask-length ] } substitute-as
By default, AS number substitution is not configured.
To configure AS number substitution for a peer or peer group (IPv6):
Step
Remarks
N/A
·     Enter BGP view:
bgp as-number
a.     bgp as-number
N/A
peer { group-name | ipv6-address [ prefix-length ] } substitute-as
Removing private AS numbers from updates sent to an EBGP peer or peer group
Private AS numbers are typically used in test networks, and should not be transmitted in public networks. The range of private AS numbers is from 64512 to 65535.
To remove private AS numbers from updates sent to an EBGP peer or peer group (IPv4):
Step
Remarks
N/A
·     Enter BGP view:
bgp as-number
a.     bgp as-number
N/A
N/A
4.     Configure BGP to remove private AS numbers from the AS_PATH attribute of updates sent to an EBGP peer or peer group.
peer { group-name | ip-address [ mask-length ] } public-as-only
By default, this feature is not configured.
This command is only applicable to EBGP peers or peer groups.
To remove private AS numbers from updates sent to an EBGP peer or peer group (IPv6):
Step
Remarks
N/A
·     Enter BGP view:
bgp as-number
a.     bgp as-number
N/A
N/A
peer { group-name | ipv6-address [ prefix-length ] } public-as-only
Ignoring the first AS number of EBGP route updates
By default, BGP checks the first AS number of a received EBGP route update. If the first AS number is neither the AS number of the EBGP peer nor a private AS number, the BGP router disconnects the BGP session to the peer.
To ignore the first AS number of EBGP route updates:
Step
Remarks
N/A
2.     Enter BGP view.
bgp as-number
N/A
3.     Configure BGP to ignore the first AS number of EBGP route updates.
ignore-first-as
By default, BGP checks the first AS number of EBGP route updates.
This section describes how to tune and optimize BGP networks.
BGP sends keepalive messages at a specific interval to keep the BGP session between two routers.
If a router receives no keepalive or update message from a peer within the hold time, it tears down the session.
You can configure the keepalive interval and hold time globally or for a specific peer or peer group. The individual settings take precedence over the global settings.
The actual keepalive interval and hold time are determined as follows:
·     If the hold time settings on the local and peer routers are different, the smaller setting is used. If the hold time is 0, BGP does not send keepalive messages to its peers and never tears down the session.
·     If the keepalive interval is 0 and the negotiated hold time is not 0, the actual keepalive interval equals 1/3 of the hold time. If the keepalive interval is not 0, the actual keepalive interval is the smaller one between 1/3 of the hold time and the keepalive interval.
To configure the keepalive interval and hold time (IPv4):
Step
Remarks
N/A
·     Enter BGP view:
bgp as-number
a.     bgp as-number
N/A
3.     Configure the keepalive interval and hold time.
·     Configure the global keepalive interval and hold time:
·     Configure the keepalive interval and hold time for a peer or peer group:
peer { group-name | ip-address [ mask-length ] } timer keepalive keepalive hold holdtime
By default, the keepalive interval is 60 seconds, and hold time is 180 seconds.
The timer command takes effect for new BGP sessions and does not affect existing sessions.
If you modify the timers with the peer timer command, BGP immediately closes the existing BGP session and creates a new session to the peer by using the new settings.
The holdtime must be at least three times the keepalive interval.
To configure the keepalive interval and hold time (IPv6):
Step
Remarks
N/A
·     Enter BGP view:
bgp as-number
a.     bgp as-number
N/A
peer { group-name | ipv6-address [ prefix-length ] } timer keepalive keepalive hold holdtime
A BGP router sends an update message to its peers when a route is changed. If the route changes frequently, the BGP router keeps sending updates for the same route, resulting route flapping. To prevent this situation, perform this task to configure the interval for sending updates for the same route to a peer or peer group.
To configure the interval for sending the same update to a peer or peer group (IPv4):
Step
Remarks
N/A
·     Enter BGP view:
bgp as-number
a.     bgp as-number
N/A
3.     Configure the interval for sending updates for the same route to a peer or peer group.
peer { group-name | ip-address [ mask-length ] } route-update-interval interval
By default, the interval is 15 seconds for an IBGP peer and 30 seconds for an EBGP peer.
To configure the interval for sending the same update to a peer or peer group (IPv6):
Step
Remarks
N/A
·     Enter BGP view:
bgp as-number
a.     bgp as-number
N/A
peer { group-name | ipv6-address [ prefix-length ] } route-update-interval interval
IMPORTANT
IMPORTANT:
When GTSM is configured, the local device can establish an EBGP session with the peer after both devices pass GTSM check, regardless of whether the maximum number of hops is reached.
To establish an EBGP connection, two routers must have a direct physical link. If no direct link is available, you must use the peer ebgp-max-hop command to enable BGP to establish an EBGP session over multiple hops and specify the maximum hops.
If directly connected EBGP peers use loopback interfaces to establish a BGP session, you do not need to configure the peer ebgp-max-hop command.
To enable BGP to establish an indirect EBGP session (IPv4):
Step
Remarks
N/A
·     Enter BGP view:
bgp as-number
a.     bgp as-number
N/A
3.     Enable BGP to establish an EBGP session to an indirectly-connected peer or peer group and specify the maximum hop count.
peer { group-name | ip-address [ mask-length ] } ebgp-max-hop [ hop-count ]
By default, BGP cannot establish an EBGP session to an indirectly-connected peer or peer group.
To enable BGP to establish an indirect EBGP session (IPv6):
Step
Remarks
N/A
·     Enter BGP view:
bgp as-number
a.     bgp as-number
N/A
peer { group-name | ipv6-address [ prefix-length ] } ebgp-max-hop [ hop-count ]
When the link to a directly-connected EBGP peer goes down, the router does not re-establish a session to the peer until the hold time timer expires. This feature enables BGP to immediately recreate the session in that situation. When this feature is disabled, route flapping does not affect EBGP session state.
To enable immediate re-establishment of direct EBGP connections:
Step
Remarks
N/A
2.     Enter BGP view.
bgp as-number
N/A
3.     Enable immediate re-establishment of direct EBGP connections upon link failure.
ebgp-interface-sensitive
By default, this feature is enabled.
BGP supports 4-byte AS numbers. The 4-byte AS number occupies four bytes, in the range of 1 to 4294967295. By default, a device sends an Open message to the peer device for session establishment. The Open message indicates that the device supports 4-byte AS numbers. If the peer device supports 2-byte AS numbers instead of 4-byte AS numbers, the session cannot be established. To resolve this issue, enable the 4-byte AS number suppression function. The device then sends an Open message to inform the peer that it does not support 4-byte AS numbers, so the BGP session can be established.
If the peer device supports 4-byte AS numbers, do not enable the 4-byte AS number suppression function. Otherwise, the BGP session cannot be established.
To enable 4-byte AS number suppression (IPv4):
Step
Remarks
N/A
·     Enter BGP view:
bgp as-number
a.     bgp as-number
N/A
3.     Enable 4-byte AS number suppression.
peer { group-name | ip-address [ mask-length ] } capability-advertise suppress-4-byte-as
By default, 4-byte AS number suppression is not enabled.
To enable 4-byte AS number suppression (IPv6):
Step
Remarks
N/A
·     Enter BGP view:
bgp as-number
a.     bgp as-number
N/A
peer { group-name | ipv6-address [ prefix-length ] } capability-advertise suppress-4-byte-as
MD5 authentication provides the following benefits:
·     Peer authentication makes sure that only BGP peers that have the same password can establish TCP connections.
·     Integrity check makes sure that BGP packets exchanged between peers are intact.
To enable MD5 authentication for BGP peers (IPv4):
Step
Remarks
N/A
·     Enter BGP view:
bgp as-number
a.     bgp as-number
N/A
3.     Enable MD5 authentication for a BGP peer group or peer.
peer { group-name | ip-address [ mask-length ] } password { cipher | simple } password
By default, MD5 authentication is disabled.
To enable MD5 authentication for BGP peers (IPv6):
Step
Remarks
N/A
·     Enter BGP view:
bgp as-number
a.     bgp as-number
N/A
peer { group-name | ipv6-address [ prefix-length ] } password { cipher | simple } password
Perform this task to specify the maximum number of BGP ECMP routes for load balancing.
To specify the maximum number of BGP ECMP routes for load balancing (IPv4):
Step
Remarks
N/A
·     Enter BGP view:
bgp as-number
a.     bgp as-number
N/A
N/A
4.     Specify the maximum number of BGP ECMP routes for load balancing.
balance { [ ebgp | eibgp | ibgp ] number | as-path-neglect }
By default, load balancing is disabled.
To specify the maximum number of BGP ECMP routes for load balancing (IPv6):
Step
Remarks
N/A
·     Enter BGP view:
bgp as-number
a.     bgp as-number
N/A
N/A
With the as-path-neglect keyword specified, the balance command enables BGP to implement load balancing over routes with different AS_PATH attributes. Use the as-path-neglect keyword according to your network, and make sure a routing loop does not occur.
Perform this task to configure IPsec for IPv6 BGP. IPsec can provide privacy, integrity, and authentication for IPv6 BGP packets exchanged between BGP peers.
When two IPv6 BGP peers are configured with IPsec (for example, Device A and Device B), Device A encapsulates an IPv6 BGP packet with IPsec before sending it to Device B. If Device B successfully receives and de-encapsulates the packet, it establishes an IPv6 BGP peer relationship with Device A and learns IPv6 BGP routes from Device A. If Device B receives but fails to de-encapsulate the packet, or receives a packet not protected by IPsec, it discards the packet.
To configure IPsec for IPv6 BGP packets:
Step
Remarks
N/A
2.     Configure an IPsec transform set and a manual IPsec profile.
See Security Configuration Guide.
By default, no IPsec transform set or manual IPsec profile exists.
3.     Enter BGP view or BGP-VPN instance view.
·     Enter BGP view:
bgp as-number
a.     bgp as-number
N/A
4.     Apply the IPsec profile to an IPv6 BGP peer or peer group.
peer { group-name | ipv6-address [ prefix-length ] } ipsec-profile profile-name
By default, no IPsec profile is configured for any IPv6 BGP peer or peer group.
This command supports only IPsec profiles in manual mode.
This task enables you to temporarily tear down the BGP session to a specific peer or peer group. Then you can perform network upgrade and maintenance without needing to delete and reconfigure the peer or peer group. To recover the session, execute the undo peer ignore command.
To disable BGP to establish a session to a peer or peer group (IPv4):
Step
Remarks
N/A
·     Enter BGP view:
bgp as-number
a.     bgp as-number
N/A
3.     Disable BGP to establish a session to a peer or peer group.
peer { group-name | ip-address [ mask-length ] } ignore
By default, BGP can establish a session to a peer or peer group.
To disable BGP to establish a session to a peer or peer group (IPv6):
Step
Remarks
N/A
·     Enter BGP view:
bgp as-number
a.     bgp as-number
N/A
peer { group-name | ipv6-address [ prefix-length ] } ignore
By default, BGP can establish a session to a peer.
IMPORTANT
IMPORTANT:
·     When GTSM is configured, the local device can establish an EBGP session with the peer after both devices pass GTSM check, regardless of whether the maximum number of hops is reached.
·     To use GTSM, you must configure GTSM on both the local and peer devices. You can specify different hop-count values for them.
The Generalized TTL Security Mechanism (GTSM) protects a BGP session by comparing the TTL value in the IP header of incoming BGP packets against a valid TTL range. If the TTL value is within the valid TTL range, the packet is accepted. If not, the packet is discarded.
The valid TTL range is from 255 – the configured hop count + 1 to 255.
When GTSM is configured, the BGP packets sent by the device have a TTL of 255.
GTSM provides best protection for directly connected EBGP sessions, but not for multihop EBGP or IBGP sessions because the TTL of packets might be modified by intermediate devices.
To configure GTSM for BGP (IPv4 unicast/multicast address family):
Step
Remarks
N/A
·     Enter BGP view:
bgp as-number
a.     bgp as-number
N/A
3.     Configure GTSM for the specified BGP peer or peer group.
peer { group-name | ip-address [ mask-length ] } ttl-security hops hop-count
By default, GTSM is not configured.
To configure GTSM for BGP (IPv6 unicast/multicast address family):
Step
Remarks
N/A
·     Enter BGP view:
bgp as-number
a.     bgp as-number
N/A
peer { group-name | ipv6-address [ prefix-length ] } ttl-security hops hop-count
After you modify the route selection policy, for example, modify the preferred value, you must reset BGP sessions to apply the new policy. The reset operation tears down and re-establishes BGP sessions.
To avoid tearing down BGP sessions, you can use one of the following soft-reset methods to apply the new policy:
·     Enabling route-refresh—The BGP router advertises a route-refresh message to the specified peer, and the peer resends its routing information to the router. After receiving the routing information, the router filters the routing information by using the new policy.
This method requires that both the local router and the peer support route refresh.
·     Saving updates—Use the peer keep-all-routes command to save all route updates from the specified peer. After modifying the route selection policy, filter routing information by using the new policy.
This method does not require that the local router and the peer support route refresh but it uses more memory resources to save routes.
·     Manual soft-reset—Use the refresh bgp command to enable BGP to send local routing information or advertise a route-refresh message to the specified peer. The peer then resends its routing information. After receiving the routing information, the router filters the routing information by using the new policy.
To enable BGP route refresh for a peer or peer group (IPv4):
Step
Remarks
4.     Enter system view.
N/A
5.     Enter BGP view or BGP-VPN instance view.
·     Enter BGP view:
bgp as-number
a.     bgp as-number
N/A
6.     Enable BGP route refresh for a peer or peer group.
·     Enable BGP route refresh for the specified peer or peer group:
peer { group-name | ip-address [ mask-length ] } capability-advertise route-refresh
·     Enable BGP route refresh and multi-protocol extension capability for the specified peer or peer group:
undo peer { group-name | ip-address [ mask-length ] } capability-advertise conventional
By default, BGP route refresh and multi-protocol extension capability are enabled.
To enable BGP route refresh for a peer or peer group (IPv6):
Step
Remarks
N/A
·     Enter BGP view:
bgp as-number
a.     bgp as-number
N/A
3.     Enable BGP route refresh for a peer or peer group.
peer { group-name | ipv6-address [ prefix-length ] } capability-advertise route-refresh
undo peer { group-name | ipv6-address [ prefix-length ] } capability-advertise conventional
Saving updates
To save all route updates from the specified peer or peer group (IPv4):
Step
Remarks
N/A
·     Enter BGP view:
bgp as-number
a.     bgp as-number
N/A
N/A
4.     Save all route updates from the peer or peer group.
peer { group-name | ip-address [ mask-length ] } keep-all-routes
By default, the routes are not saved.
This command takes effect only for the routes received after this command is executed.
To save all route updates from the specified peer or peer group (IPv6):
Step
Remarks
N/A
2.     Enter BGP view
bgp as-number
N/A
N/A
peer { group-name | ipv6-address [ prefix-length ] } keep-all-routes
Configuring manual soft-reset
To configure manual soft-reset (IPv4):
Step
Remarks
N/A
·     Enter BGP view:
bgp as-number
a.     bgp as-number
N/A
4.     Return to user view.
return
N/A
5.     Perform manual soft-reset.
refresh bgp { ip-address [ mask-length ] | all | external | group group-name | internal } { export | import } ipv4 [ unicast ] [ vpn-instance vpn-instance-name ]
N/A
To configure manual soft-reset (IPv6):
Step
Remarks
N/A
·     Enter BGP view:
bgp as-number
a.     bgp as-number
N/A
return
N/A
refresh bgp { ipv6-address [ prefix-length ] | all | external | group group-name | internal } { export | import } ipv6 [ unicast ] [ vpn-instance vpn-instance-name ]
N/A
Memory usage includes the following threshold levels: normal, level 1, level 2, and level 3. When the level 2 threshold is reached, BGP periodically tears down an EBGP session to release memory resources until the memory usage falls below the level 2 threshold. You can configure this feature to avoid tearing down the EBGP session with a specific EBGP peer when the memory usage reaches the level 2 threshold.
For more information about memory usage thresholds, see Fundamentals Configuration Guide.
To configure BGP to protect an EBGP peer or peer group when the memory usage reaches level 2 threshold (IPv4):
Step
Remarks
N/A
·     Enter BGP view:
bgp as-number
a.     bgp as-number
N/A
3.     Configure BGP to protect an EBGP peer or peer group when the memory usage reaches level 2 threshold.
peer { group-name | ip-address [ mask-length ] } low-memory-exempt
By default, BGP periodically tears down an EBGP session to release memory resources when level 2 threshold is reached.
To configure BGP to protect an EBGP peer or peer group when the memory usage reaches level 2 threshold (IPv6):
Step
Remarks
N/A
·     Enter BGP view:
bgp as-number
a.     bgp as-number
N/A
peer { group-name | ipv6-address [ prefix-length ] } low-memory-exempt
By default, BGP tears down an EBGP session to release memory resources periodically when level 2 threshold is reached.
In a large network, the number of BGP connections is huge and BGP configuration and maintenance are complicated. To simply BGP configuration, you can use the peer group, community, route reflector, and confederation features as needed. For more information about configuring peer groups, see "Configuring a BGP peer group."
By default, a router does not advertise the COMMUNITY or extended community attribute to its peers or peer groups. When the router receives a route carrying the COMMUNITY or extended community attribute, it removes the attribute before advertising the route to other peers or peer groups.
Perform this task to enable a router to advertise the COMMUNITY or extended community attribute to its peers for route filtering and control. You can also reference a routing policy to add or modify the COMMUNITY or extended community attribute for specific routes. For more information about routing policy, see "Configuring routing policies."
To configure BGP community (IPv4):
Step
Remarks
N/A
·     Enter BGP view:
bgp as-number
a.     bgp as-number
N/A
N/A
4.     Advertise the COMMUNITY or extended community attribute to a peer or peer group.
·     Advertise the COMMUNITY attribute to a peer or peer group:
peer { group-name | ip-address [ mask-length ] } advertise-community
·     Advertise the extended community attribute to a peer or peer group:
peer { group-name | ip-address [ mask-length ] } advertise-ext-community
By default, the COMMUNITY or extended community attribute is not advertised.
5.     (Optional.) Apply a routing policy to routes advertised to a peer or peer group.
By default, no routing policy is applied.
To configure BGP community (IPv6):
Step
Remarks
N/A
·     Enter BGP view:
bgp as-number
a.     bgp as-number
N/A
N/A
peer { group-name | ipv6-address [ prefix-length ] } advertise-community
peer { group-name | ipv6-address [ prefix-length ] } advertise-ext-community
The peer advertise-ext-community command is not supported in BGP-VPN IPv6 unicast address family view.
Configuring BGP route reflection
Configuring a BGP route reflector
Perform this task to configure a BGP route reflector and its clients. The route reflector and its clients automatically form a cluster identified by the router ID of the route reflector. The route reflector forwards route updates among its clients.
To improve availability, you can specify multiple route reflectors for a cluster. The route reflectors in the cluster must have the same cluster ID to avoid routing loops.
To configure a BGP route reflector (IPv4):
Step
Remarks
N/A
·     Enter BGP view:
bgp as-number
a.     bgp as-number
N/A
N/A
4.     Configure the router as a route reflector and specify a peer or peer group as its client.
By default, no route reflector or client is configured.
5.     Enable route reflection between clients.
reflect between-clients
By default, route reflection between clients is enabled.
6.     (Optional.) Configure the cluster ID of the route reflector.
By default, a route reflector uses its own router ID as the cluster ID.
To configure a BGP route reflector (IPv6):
Step
Remarks
N/A
2.     Enter BGP view.
bgp as-number
N/A
N/A
peer { group-name | ipv6-address [ prefix-length ] } reflect-client
Ignoring the ORIGINATOR_ID attribute
By default, BGP drops incoming route updates whose ORIGINATOR_ID attribute is the same as the local router ID. Some special networks such as firewall networks require BGP to accept such route updates. To meet the requirement, you must configure BGP to ignore the ORIGINATOR_ID attribute.
To ignore the ORIGINATOR_ID attribute (IPv4):
Step
Remarks
N/A
2.     Enter BGP view or BGP-VPN instance view.
·     Enter BGP view:
bgp as-number
·     Enter BGP-VPN instance view:
a.     bgp as-number
b.     ip vpn-instance vpn-instance-name
N/A
3.     Ignore the ORIGINATOR_ID attribute.
peer { group-name | ip-address [ mask-length ] } ignore-originatorid
By default, BGP does not ignore the ORIGINATOR_ID attribute.
Make sure that this command does not result in a routing loop.
After you execute this command, BGP also ignores the CLUSTER_LIST attribute.
To ignore the ORIGINATOR_ID attribute (IPv6):
Step
Remarks
N/A
·     Enter BGP view:
bgp as-number
a.     bgp as-number
N/A
peer { group-name | ipv6-address [ prefix-length ] } ignore-originatorid
Make sure this command does not result in a routing loop.
Configuring a BGP confederation
BGP confederation provides another way to reduce IBGP connections in an AS.
A confederation contains sub-ASs. In each sub-AS, IBGP peers are fully meshed. Sub-ASs establish EBGP connections in between.
After you split an AS into multiple sub-ASs, configure a router in a sub-AS as follows:
1.     Enable BGP and specify the AS number of the router. For more information, see "Enabling BGP."
2.     Specify the confederation ID. From an outsider's perspective, the sub-ASs of the confederation is a single AS, which is identified by the confederation ID.
3.     If the router needs to establish EBGP connections to other sub-ASs, you must specify the peering sub-ASs in the confederation.
A confederation can contain a maximum of 32 sub-ASs. The AS number of a sub-AS is effective only in the confederation.
To configure a BGP confederation:
Step
Remarks
N/A
2.     Enter BGP view.
bgp as-number
N/A
3.     Configure a confederation ID.
confederation id as-number
By default, no confederation ID is configured.
4.     Specify confederation peer sub-ASs in the confederation.
By default, no confederation peer sub-AS is specified.
Configuring confederation compatibility
If any routers in the confederation do not comply with RFC 3065, enable confederation compatibility to allow the router to work with those routers.
To configure confederation compatibility:
Step
Remarks
N/A
2.     Enter BGP view.
bgp as-number
N/A
3.     Enable confederation compatibility.
confederation nonstandard
By default, confederation compatibility is disabled.
Configuring BGP GR
Graceful Restart (GR) ensures forwarding continuous when a routing protocol restarts or an active/standby switchover occurs. Two routers are required to complete a GR process. The following are router roles in a GR process:
·     GR restarter—Performs GR upon a BGP restart or active/standby switchover.
·     GR helper—Helps the GR restarter to complete the GR process.
A device can act as a GR restarter and GR helper at the same time.
BGP GR works as follows:
1.     The BGP GR restarter and helper exchange Open messages for GR capability negotiation. If both parties have the GR capability, they establish a GR-capable session. The GR restarter sends the GR timer set by the graceful-restart timer restart command to the GR helper in an Open message.
2.     When an active/standby switchover occurs or BGP restarts, the GR restarter does not remove existing BGP routes from Routing Information Base (RIB) and Forwarding Information Base (FIB). It still uses these routes for packet forwarding, and it starts the RIB purge timer set by the graceful-restart timer purge-time command. The GR helper marks all routes learned from the GR restarter as stale instead of deleting them. It continues to use these routes for packet forwarding. During the GR process, packet forwarding is not interrupted.
3.     After the active/standby switchover or BGP restart completes, the GR restarter re-establishes a BGP session with the GR helper. If the BGP session fails to be established within the GR timer advertised by the GR restarter, the GR helper removes the stale routes.
4.     If the BGP session is established, routing information is exchanged for the GR restarter to retrieve route entries and for the GR helper to recover stale routes.
5.     Both the GR restarter and the GR helper start the End-Of-RIB marker waiting timer.
The End-Of-RIB marker waiting timer is set by the graceful-restart timer wait-for-rib command. If routing information exchange is not completed within the time, the GR restarter does not receive new routes. The GR restarter updates the RIB with the BGP routes already learned, and removes the stale routes from the RIB. The GR helper removes the stale routes.
6.     The GR restarter quits the GR process if route information exchange is not completed before the RIB purge timer expires. It updates the RIB with the BGP routes already learned, and removes the stale routes.
Follow these guidelines when you configure BGP GR:
·     The End-Of-RIB indicates the end of route updates.
·     The maximum time to wait for the End-of-RIB marker configured on the local end is not advertised to the peer. It controls the time for the local end to receive updates from the peer.
Perform the following configuration on the GR restarter and GR helper.
To configure BGP GR:
Step
Remarks
N/A
2.     Enter BGP view.
bgp as-number
N/A
3.     Enable GR capability for BGP.
graceful-restart
By default, GR capability is disabled for BGP.
4.     Configure the GR timer.
The default setting is 150 seconds.
The time that a peer waits to re-establish a session must be less than the hold time.
5.     Configure the maximum time to wait for the End-of-RIB marker.
The default setting is 180 seconds.
6.     Configure the RIB purge timer.
The default setting is 480 seconds.
Configuring BGP NSR
BGP nonstop routing (NSR) ensures continuous routing by synchronizing BGP state and data information from the active BGP process to the standby BGP process. The standby BGP process can seamlessly take over all services when the active process fails in one of the following situations:
·     The active BGP process restarts.
·     The member device that runs the active BGP process fails.
·     An ISSU is performed on the member device that runs the active BGP process.
GR and NSR have the following differences:
·     To implement NSR, the IRF fabric must have at least two member devices because the active and standby BGP processes run on different member devices. To implement GR, the IRF fabric only needs to have one member device.
·     GR requires GR-capable neighbors to help restore routing information. NSR does not need help because the standby process has all the BGP state and data information of the active process.
When both GR and NSR are configured for BGP, NSR has a higher priority than GR. The device will not act as the GR restarter. If the device acts as a GR helper, it cannot help the restarter to complete GR.
To configure BGP NSR:
Step
Remarks
N/A
2.     Enter BGP view.
bgp as-number
N/A
3.     Enable BGP NSR.
non-stop-routing
By default, BGP NSR is disabled.
Enabling SNMP notifications for BGP
This feature enables BGP to generate SNMP notifications. The generated SNMP notifications are sent to the SNMP module.
For more information about SNMP notifications, see Network Management and Monitoring Configuration Guide.
To enable SNMP notifications for BGP:
Step
Remarks
N/A
2.     Enable SNMP notifications for BGP.
snmp-agent trap enable bgp
By default, SNMP notifications for BGP are enabled.
Enabling logging of session state changes
Perform this task to enable BGP to log BGP session establishment and disconnection events. To view the log information, use the display bgp peer ipv4 unicast log-info command or the display bgp peer ipv6 unicast log-info command. The logs are sent to the information center. The output rules of the logs (whether to output the logs and where to output) are determined by the information center configuration.
For more information about information center configuration, see Network Management and Monitoring Configuration Guide.
To enable the logging of session state changes:
Step
Remarks
N/A
2.     Enter BGP view.
bgp as-number
N/A
3.     Enable the logging of session state changes globally.
log-peer-change
By default, logging of session state changes is enabled globally.
Configuring BFD for BGP
IMPORTANT:
If you have enabled GR, use BFD with caution because BFD might detect a failure before the system performs GR, which will result in GR failure. If you have enabled both BFD and GR for BGP, do not disable BFD during a GR process to avoid GR failure.
BGP maintains neighbor relationships based on the keepalive timer and hold timer in seconds. It requires that the hold time must be at least three times the keepalive interval. This mechanism slows down link failure detection. Once a failure occurs on a high-speed link, a large quantity of packets will be dropped before routing convergence completes. BFD for BGP can solve this problem by fast detecting link failures to reduce convergence time.
For more information about BFD, see High Availability Configuration Guide.
Before you can enable BFD for the BGP peer, establish a BGP session between the local router and the peer.
To enable BFD for a BGP peer (IPv4):
Step
Remarks
N/A
·     Enter BGP view:
bgp as-number
a.     bgp as-number
N/A
3.     Enable BFD to detect the link to the specified BGP peer.
peer ip-address [ mask-length ] bfd [ multi-hop | single-hop ]
By default, BFD is not enabled.
To enable BFD for a BGP peer (IPv6):
Step
Remarks
N/A
·     Enter BGP view:
bgp as-number
a.     bgp as-number
N/A
3.     Enable BFD to detect the link to the specified IPv6 BGP peer.
peer ipv6-address [ prefix-length ] bfd [ multi-hop | single-hop ]
Configuring BGP FRR
When a link fails, the packets on the link are discarded, and a routing loop might occur until BGP completes routing convergence based on the new network topology.
You can enable BGP fast reroute (FRR) to resolve this issue.
Figure 14 Network diagram for BGP FRR
After you configure FRR on Router B as shown in Figure 14, BGP generates a backup next hop Router C for the primary route. BGP uses ARP, echo-mode BFD (for IPv4), or ND (for IPv6) to detect the connectivity to Router D. When the link to Router D fails, BGP directs packets to the backup next hop. At the same time, BGP calculates a new optimal route, and forwards packets over the optimal route after route selection.
You can use the following methods to configure BGP FRR:
·     Method 1Execute the pic command in BGP address family view. BGP calculates a backup next hop for a BGP route in the address family if there are two or more unequal-cost routes that reaches the destination.
·     Method 2Execute the fast-reroute route-policy command to reference a routing policy in which a backup next hop is specified by using the apply [ ipv6 ] fast-reroute backup-nexthop command. The backup next hop calculated by BGP must be the same as the specified backup next hop. Otherwise, BGP does not generate a backup next hop for the primary route. You can also configure if-match clauses in the routing policy to identify the routes protected by FRR.
If both methods are configured, Method 2 takes precedence over Method 1.
BGP supports FRR for IPv4 and IPv6 unicast routes, but not for IPv4 and IPv6 multicast routes.
To configure BGP FRR (IPv4 unicast address family):
Step
Remarks
N/A
2.     Configure the source address of echo packets.
bfd echo-source-ip ip-address
By default, no source address is specified for echo packets.
This step is required when echo-mode BFD is used to detect the connectivity to the next hop of the primary route.
Specify a source IP address that does not belong to any local network.
For more information about this command, see High Availability Command Reference.
3.     Create a routing policy and enter routing policy view.
route-policy route-policy-name permit node node-number
By default, no routing policy is created.
This step is required when Method 2 is used to enable BGP FRR.
For more information about this command, see Layer 3—IP Routing Command Reference.
4.     Set the backup next hop for FRR.
apply fast-reroute backup-nexthop ip-address
By default, no backup next hop is set.
5.     Return to system view.
N/A
6.     Enter BGP view.
bgp as-number
N/A
7.     (Optional.) Use echo-mode BFD to detect the connectivity to the next hop of the primary route.
primary-path-detect bfd echo
By default, ARP is used to detect the connectivity to the next hop.
8.     (Optional.) Enter BGP-VPN instance view.
N/A
9.     Enter BGP IPv4 unicast address family view or BGP-VPN IPv4 unicast address family view.
N/A
10.     Enable BGP FRR.
·     (Method 1) Enable BGP FRR for the address family:
pic
·     (Method 2) Reference a routing policy to specify a backup next hop for the address family:
By default, BGP FRR is disabled.
Method 1 might result in routing loops. Use it with caution.
By default, no routing policy is referenced.
The apply fast-reroute backup-nexthop and apply ipv6 fast-reroute backup-nexthop commands can take effect in the referenced routing policy. Other apply commands do not take effect.
To configure BGP FRR (IPv6 unicast address family):
Step
Remarks
N/A
2.     Create a routing policy and enter routing policy view.
3.     Set the backup next hop for FRR.
apply ipv6 fast-reroute backup-nexthop ipv6-address
4.     Return to system view.
N/A
·     Enter BGP view:
bgp as-number
a.     bgp as-number
N/A
6.     Enter BGP IPv6 unicast address family view or BGP-VPN IPv6 unicast address family view.
N/A
7.     Enable BGP FRR.
pic
Configuring 6PE
IPv6 provider edge (6PE) is a transition technology that uses MPLS to connect sparsely populated IPv6 networks through an existing IPv4 backbone network. It is an efficient solution for ISP IPv4/MPLS networks to provide IPv6 traffic switching capability.
Figure 15 Network diagram for 6PE
6PE mainly performs the following operations:
·     6PE assigns a label to IPv6 routing information received from a CE router, and sends the labeled IPv6 routing information to the peer 6PE device through an MP-BGP session. The peer 6PE device then forwards the IPv6 routing information to the attached customer site.
·     6PE provides tunnels over the IPv4 backbone so the IPv4 backbone can forward packets for IPv6 networks. The tunnels can be GRE tunnels, MPLS LSPs, or MPLS TE tunnels.
·     Upon receiving an IPv6 packet, 6PE adds an inner tag (corresponding to the IPv6 packet) and then an outer tag (corresponding to the public network tunnel) to the IPv6 packet. Devices in the IPv4 backbone network forwards the packet based on the outer tag. When the peer 6PE device receives the packet, it removes the outer and inner tags and forwards the original IPv6 packet to the attached customer site.
To implement exchange of IPv6 routing information, you can configure IPv6 static routing, an IPv6 IGP protocol, or IPv6 BGP between CE and 6PE devices.
For more information about MPLS, MPLS TE, CE, and P (Provider), see MPLS Configuration Guide. For more information about GRE, see Layer 3—IP Services Configuration Guide.
Configuring basic 6PE
Before you configure 6PE, complete the following tasks:
·     Establish tunnels in the IPv4 backbone network (see Layer 3—IP Services Configuration Guide).
·     Configure basic MPLS on 6PE devices (see MPLS Configuration Guide).
·     Configure BGP on 6PE devices so that they can advertise tagged IPv6 routing information through BGP sessions. The following describes only BGP configurations on 6PE devices.
To configure basic 6PE:
Step
Remarks
N/A
2.     Enter BGP view.
bgp as-number
N/A
3.     Specify a 6PE peer or peer group and its AS number.
peer { group-name | ip-address [ mask-length ] } as-number as-number
No 6PE peer is specified by default.
4.     Enter BGP IPv6 unicast address family view.
N/A
5.     Enable BGP to exchange IPv6 unicast routing information with the 6PE peer or peer group.
This function is disabled by default.
6.     Enable BGP to exchange labeled IPv6 routes with the 6PE peer or peer group.
peer { group-name | ip-address [ mask-length ] } label-route-capability
Configuring optional 6PE capabilities
Step
Remarks
N/A
2.     Enter BGP view.
bgp as-number
N/A
3.     Enter BGP IPv6 unicast address family view.
N/A
4.     Advertise COMMUNITY attribute to the 6PE peer or peer group.
By default, the COMMUNITY attribute is not advertised.
5.     Advertise extended community attribute to the 6PE peer or peer group.
By default, the extended community attribute is not advertised.
6.     Allow the local AS number to appear in routes from the 6PE peer or peer group and specify the repeat times.
By default, the local AS number is not allowed to appear in routes from the 6PE peer or peer group.
7.     Specify an AS path list to filter routes advertised to or received from the 6PE peer or peer group.
peer { group-name | ip-address [ mask-length ] } as-path-acl as-path-acl-number { export | import }
By default, no AS path list is specified.
8.     Specify an IPv6 ACL to filter routes advertised to or received from the 6PE peer or peer group.
peer { group-name | ip-address [ mask-length ] } filter-policy acl6-number { export | import }
By default, no ACL is specified.
9.     Specify an IPv6 prefix list to filter routes advertised to or received from the 6PE peer or peer group.
peer { group-name | ip-address [ mask-length ] } prefix-list ipv6-prefix-name { export | import }
By default, no IPv6 prefix list is specified.
10.     Specify a routing policy to filter routes advertised to or received from the 6PE peer or peer group.
peer { group-name | ip-address [ mask-length ] } route-policy route-policy-name { export | import }
By default, no routing policy is specified.
11.     Advertise a default route to the 6PE peer or peer group.
peer { group-name | ip-address [ mask-length ] } default-route-advertise [ route-policy route-policy-name ]
By default, no default route is advertised.
12.     Save all routes from the 6PE peer or peer group.
By default, routes from a peer or peer group are not saved.
13.     Configure BGP updates sent to the 6PE peer or peer group to carry only the public AS number.
14.     Specify the maximum number of routes that BGP can receive from the 6PE peer or peer group.
peer { group-name | ip-address [ mask-length ] } route-limit prefix-number [ { alert-only discard | reconnect reconnect-time } | percentage-value ] *
By default, the number of routes that a router can receive from the 6PE peer or peer group is not limited.
15.     Specify a preferred value for routes received from the 6PE peer or peer group.
By default, the preferred value is 0.
16.     Configure the device as a route reflector and the 6PE peer or peer group as a client.
17.     Return to user view.
return
N/A
18.     Display information about the 6PE peer or peer group.
display bgp peer ipv6 [ unicast ] [ group-name log-info | ip-address { log-info | verbose } | verbose ]
Available in any view.
19.     Display routing information advertised to or received from the 6PE peer or peer group.
display bgp routing-table ipv6 [ unicast ] peer ip-address { advertised-routes | received-routes } [ network-address prefix-length | statistics ]
20.     Perform soft reset on the inbound or outbound BGP 6PE connection.
refresh bgp ip-address { export | import } ipv6 [ unicast ]
Available in user view.
21.     Reset a BGP 6PE connection.
reset bgp ip-address ipv6 [ unicast ]
Displaying and maintaining BGP
Execute display commands in any view and reset commands in user view (IPv4).
Display BGP NSR status information.
display bgp non-stop-routing status
Display BGP IPv4 unicast peer group information.
display bgp group ipv4 [ unicast ] [ vpn-instance vpn-instance-name ] [ group-name ]
Display BGP IPv4 unicast peer or peer group information.
display bgp peer ipv4 [ unicast ] [ vpn-instance vpn-instance-name ] [ ip-address { log-info | verbose } | group-name log-info | verbose ]
Display BGP IPv4 unicast routing information.
display bgp routing-table ipv4 [ unicast ] [ vpn-instance vpn-instance-name ] [ network-address [ { mask | mask-length } [ longest-match ] ] ]
Display BGP IPv4 unicast route advertisement information.
display bgp routing-table ipv4 [ unicast ] [ vpn-instance vpn-instance-name ] network-address [ mask | mask-length ] advertise-info
Display BGP IPv4 unicast routing information sent to/received from the specified BGP peer.
display bgp routing-table ipv4 [ unicast ] [ vpn-instance vpn-instance-name ] peer ip-address { advertised-routes | received-routes } [ network-address [ mask | mask-length ] | statistic ]
Display BGP IPv4 unicast routing statistics.
display bgp routing-table ipv4 [ unicast ] [ vpn-instance vpn-instance-name ] statistic
Display BGP IPv4 unicast routing information matching the specified AS path list.
display bgp routing-table ipv4 [ unicast ] [ vpn-instance vpn-instance-name ] as-path-acl as-path-acl-number
Display BGP IPv4 unicast routing information matching the specified BGP community list.
display bgp routing-table ipv4 [ unicast ] [ vpn-instance vpn-instance-name ] community-list { { basic-community-list-number | comm-list-name } [ whole-match ] | adv-community-list-number }
Display dampened BGP IPv4 unicast routing information.
display bgp routing-table dampened ipv4 [ unicast ] [ vpn-instance vpn-instance-name ]
Display BGP dampening parameter information.
display bgp dampening parameter ipv4 [ unicast ] [ vpn-instance vpn-instance-name ]
Display BGP IPv4 unicast routing flap statistics.
display bgp routing-table flap-info ipv4 [ unicast ] [ vpn-instance vpn-instance-name ] [ network-address [ { mask | mask-length } [ longest-match ] ] | as-path-acl as-path-acl-number ]
Display information about routes advertised by the network command and shortcut routes configured by the network short-cut command.
display bgp network ipv4 [ unicast ] [ vpn-instance vpn-instance-name ]
Display BGP path attribute information.
display bgp paths [ as-regular-expression ]
Display BGP IPv4 unicast address family update group information.
display bgp update-group ipv4 [ unicast ] [ vpn-instance vpn-instance-name ] [ ip-address ]
Reset all BGP sessions.
reset bgp all
Reset IPv4 unicast BGP sessions.
reset bgp { as-number | ip-address | all | external | group group-name | internal } ipv4 [ unicast ] [ vpn-instance vpn-instance-name ]
Clear dampened BGP IPv4 unicast routing information and release suppressed routes.
reset bgp dampening ipv4 [ unicast ] [ vpn-instance vpn-instance-name ] [ network-address [ mask | mask-length ] ]
Clear BGP IPv4 unicast route flap information.
reset bgp flap-info ipv4 [ unicast ] [ vpn-instance vpn-instance-name ] [ network-address [ mask | mask-length ] | as-path-acl as-path-acl-number | peer peer-address ]
Execute display commands in any view and reset commands in user view (IPv6).
Display BGP IPv6 unicast peer group information.
display bgp group ipv6 [ unicast ] [ vpn-instance vpn-instance-name ] [ group-name ]
Display BGP IPv6 unicast peer or peer group information.
display bgp peer ipv6 [ unicast ] [ group-name log-info | ip-address { log-info | verbose } | ipv6-address { log-info | verbose } | verbose ]
display bgp peer ipv6 [ unicast ] vpn-instance vpn-instance-name [ group-name log-info | ipv6-address { log-info | verbose } | verbose ]
Display BGP IPv6 unicast routing information.
display bgp routing-table ipv6 [ unicast ] [ vpn-instance vpn-instance-name ] [ network-address prefix-length [ advertise-info ] ]
Display BGP IPv6 unicast routing information sent to/received from the specified BGP peer.
display bgp routing-table ipv6 [ unicast ] peer { ip-address | ipv6-address } { advertised-routes | received-routes } [ network-address prefix-length | statistics ]
display bgp routing-table ipv6 [ unicast ] vpn-instance vpn-instance-name peer ipv6-address { advertised-routes | received-routes } [ network-address prefix-length | statistics ]
Display BGP IPv6 unicast routing statistics.
display bgp routing-table ipv6 [ unicast ] [ vpn-instance vpn-instance-name ] statistics
Display BGP IPv6 unicast routing information matching the specified AS path list.
display bgp routing-table ipv6 [ unicast ] [ vpn-instance vpn-instance-name ] as-path-acl as-path-acl-number
Display BGP IPv6 unicast routing information matching the specified BGP community list.
display bgp routing-table ipv6 [ unicast ] [ vpn-instance vpn-instance-name ] community-list { { basic-community-list-number | comm-list-name } [ whole-match ] | adv-community-list-number }
Display dampened BGP IPv6 unicast routing information.
display bgp routing-table dampened ipv6 [ unicast ] [ vpn-instance vpn-instance-name ]
display bgp dampening parameter ipv6 [ unicast ] [ vpn-instance vpn-instance-name ]
Display BGP IPv6 unicast routing flap statistics.
display bgp routing-table flap-info ipv6 [ unicast ] [ vpn-instance vpn-instance-name ] [ network-address prefix-length | as-path-acl as-path-acl-number ]
Display the incoming label of BGP IPv6 unicast routing information.
display bgp routing-table ipv6 [ unicast ] inlabel
Display the outgoing label of BGP IPv6 unicast routing information.
display bgp routing-table ipv6 [ unicast ] outlabel
display bgp network ipv6 [ unicast ] [ vpn-instance vpn-instance-name ]
Display BGP IPv6 unicast address family update group information.
display bgp update-group ipv6 [ unicast ] [ ip-address | ipv6-address ]
display bgp update-group ipv6 [ unicast ] vpn-instance vpn-instance-name [ ipv6-address ]
Reset IPv6 unicast BGP sessions.
reset bgp { as-number | ipv6-address | all | external | group group-name | internal } ipv6 [ unicast ] [ vpn-instance vpn-instance-name ]
Clear dampened BGP IPv6 unicast routing information and release suppressed routes.
reset bgp dampening ipv6 [ unicast ] [ vpn-instance vpn-instance-name ] [ network-address prefix-length ]
Clear BGP IPv6 unicast route flap information.
reset bgp flap-info ipv6 [ unicast ] [ vpn-instance vpn-instance-name ] [ network-address prefix-length | as-path-acl as-path-acl-number | peer ipv6-address ]
IPv4 BGP configuration examples
Basic BGP configuration example
Network requirements
As shown in Figure 16, all switches run BGP. Run EBGP between Switch A and Switch B, and run IBGP between Switch B and Switch C to allow Switch C to access network 8.1.1.0/24 connected to Switch A.
Figure 16 Network diagram
Requirements analysis
To prevent route flapping caused by port state changes, this example uses loopback interfaces to establish IBGP connections. Because loopback interfaces are virtual interfaces, use the peer connect-interface command to specify the loopback interface as the source interface for establishing BGP connections. Enable OSPF in AS 65009 to make sure that Switch B can communicate with Switch C through loopback interfaces.
The EBGP peers, Switch A and Switch B (usually belong to different carriers), are located in different ASs. Typically, their loopback interfaces are not reachable to each other, so directly connected interfaces are used for establishing EBGP sessions. To enable Switch C to access the network 8.1.1.0/24 connected directly to Switch A, inject network 8.1.1.0/24 to the BGP routing table of Switch A.
Configuration procedure
1.     Configure IP addresses for interfaces. (Details not shown.)
2.     Configure IBGP:
# Configure Switch B.
[SwitchB] bgp 65009
[SwitchB-bgp] router-id 2.2.2.2
[SwitchB-bgp] peer 3.3.3.3 as-number 65009
[SwitchB-bgp] peer 3.3.3.3 connect-interface loopback 0
[SwitchB-bgp] address-family ipv4 unicast
[SwitchB-bgp-ipv4] peer 3.3.3.3 enable
[SwitchB-bgp-ipv4] quit
[SwitchB-bgp] quit
[SwitchB] ospf 1
[SwitchB-ospf-1] area 0
[SwitchB-ospf-1] quit
# Configure Switch C.
[SwitchC] bgp 65009
[SwitchC-bgp] router-id 3.3.3.3
[SwitchC-bgp] peer 2.2.2.2 as-number 65009
[SwitchC-bgp] peer 2.2.2.2 connect-interface loopback 0
[SwitchC-bgp] address-family ipv4 unicast
[SwitchC-bgp-ipv4] peer 2.2.2.2 enable
[SwitchC-bgp-ipv4] quit
[SwitchC-bgp] quit
[SwitchC] ospf 1
[SwitchC-ospf-1] area 0
[SwitchC-ospf-1] quit
 BGP local router ID : 3.3.3.3
 Local AS number : 65009
 Total number of peers : 1                 Peers in established state : 1
  2.2.2.2              65009        2        2    0       0 00:00:13 Established
The output shows that Switch C has established an IBGP peer relationship with Switch B.
3.     Configure EBGP:
# Configure Switch A.
[SwitchA] bgp 65008
[SwitchA-bgp] router-id 1.1.1.1
[SwitchA-bgp] peer 3.1.1.1 as-number 65009
[SwitchA-bgp] address-family ipv4 unicast
[SwitchA-bgp-ipv4] peer 3.1.1.1 enable
[SwitchA-bgp-ipv4] network 8.1.1.0 24
[SwitchA-bgp-ipv4] quit
[SwitchA-bgp] quit
[SwitchB] bgp 65009
[SwitchB-bgp] peer 3.1.1.2 as-number 65008
[SwitchB-bgp-ipv4] peer 3.1.1.2 enable
[SwitchB-bgp] quit
# Display BGP peer information on Switch B.
 BGP local router ID : 2.2.2.2
 Total number of peers : 2                 Peers in established state : 2
  3.3.3.3              65009        4        4    0       0 00:02:49 Established
  3.1.1.2              65008        2        2    0       0 00:00:05 Established
The output shows that Switch B has established an IBGP peer relationship with Switch C and an EBGP peer relationship with Switch A.
# Display the BGP routing table on Switch A.
 Total number of routes: 1
* >  8.1.1.0/24         8.1.1.1         0                     32768   i
# Display the BGP routing table on Switch B.
* >e 8.1.1.0/24         3.1.1.2         0                     0       65008i
# Display the BGP routing table on Switch C.
   i 8.1.1.0/24         3.1.1.2         0          100        0       65008i
The outputs show that Switch A has learned no route to AS 65009, and Switch C has learned network 8.1.1.0, but the next hop 3.1.1.2 is unreachable. As a result, the route is invalid.
4.     Redistribute direct routes:
Configure BGP to redistribute direct routes on Switch B, so that Switch A can obtain the route to 9.1.1.0/24, and Switch C can obtain the route to 3.1.1.0/24.
[SwitchB] bgp 65009
[SwitchB-bgp-ipv4] import-route direct
[SwitchB-bgp] quit
 Total number of routes: 4
* >e 2.2.2.2/32         3.1.1.1         0                     0       65009?
* >e 3.1.1.0/24         3.1.1.1         0                     0       65009?
* >e 9.1.1.0/24         3.1.1.1         0                     0       65009?
Two routes, 2.2.2.2/32 and 9.1.1.0/24, have been added in Switch A's routing table.
* >i 2.2.2.2/32         2.2.2.2         0          100        0       ?
* >i 3.1.1.0/24         2.2.2.2         0          100        0       ?
* >i 8.1.1.0/24         3.1.1.2         0          100        0       65008i
* >i 9.1.1.0/24         2.2.2.2         0          100        0       ?
The output shows that the route 8.1.1.0 becomes valid with the next hop as Switch A.
# Ping 8.1.1.1 from Switch C.
[SwitchC] ping 8.1.1.1
Ping 8.1.1.1 (8.1.1.1): 56 data bytes, press CTRL_C to break
BGP and IGP route redistribution configuration example
As shown in Figure 17, all devices of company A belong to AS 65008, and all devices of company B belong to AS 65009.
Configure BGP and IGP route redistribution to allow Switch A to access network 9.1.2.0/24 in AS 65009, and Switch C to access network 8.1.1.0/24 in AS 65008.
Figure 17 Network diagram
Configure BGP to redistribute routes from OSPF on Switch B, so Switch A can obtain the route to 9.1.2.0/24. Configure OSPF to redistribute routes from BGP on Switch B, so Switch C can obtain the route to 8.1.1.0/24.
2.     Configure OSPF:
Enable OSPF in AS 65009, so Switch B can obtain the route to 9.1.2.0/24.
[SwitchB] ospf 1
[SwitchC] ospf 1
3.     Configure the EBGP connection:
Configure the EBGP connection and inject network 8.1.1.0/24 to the BGP routing table of Switch A, so that Switch B can obtain the route to 8.1.1.0/24.
[SwitchA] bgp 65008
[SwitchA-bgp] quit
[SwitchB] bgp 65009
4.     Configure BGP and IGP route redistribution:
# Configure route redistribution between BGP and OSPF on Switch B.
[SwitchB-bgp-ipv4] import-route ospf 1
[SwitchB-bgp] quit
[SwitchB] ospf 1
 Total number of routes: 3
* >e 3.3.3.3/32         3.1.1.1         1                     0       65009?
* >e 9.1.2.0/24         3.1.1.1         1                     0       65009?
# Display the OSPF routing table on Switch C.
                   Routing Tables
 Routing for Network
 9.1.1.0/24         1        Transit 9.1.1.2         3.3.3.3         0.0.0.0
 2.2.2.2/32         1        Stub    9.1.1.1         2.2.2.2         0.0.0.0
 Routing for ASEs
 Destination        Cost     Type    Tag         NextHop         AdvRouter
 8.1.1.0/24         1        Type2   1           9.1.1.1         2.2.2.2
 Total Nets: 3
 Intra Area: 2  Inter Area: 0  ASE: 1  NSSA: 0
# Use ping to test connectivity.
Ping 9.1.2.1 (9.1.2.1) from 8.1.1.1: 56 data bytes, press CTRL_C to break
Ping 8.1.1.1 (8.1.1.1) from 9.1.2.1: 56 data bytes, press CTRL_C to break
BGP route summarization configuration example
As shown in Figure 18, run EBGP between Switch C and Switch D, so the internal network and external network can communicate with each other.
·     In AS 65106, perform the following configurations so the devices in the internal network can communicate:
¡     Configure static routing between Switch A and Switch B.
¡     Configure OSPF between Switch B and Switch C.
¡     Configure OSPF to redistribute static routes.
·     Configure route summarization on Switch C so BGP advertises a summary route instead of advertising routes to the 192.168.64.0/24, 192.168.74.0/24, and 192.168.99.0/24 networks to Switch D.
Figure 18 Network diagram
2.     Configure static routing between Switch A and Switch B:
# Configure a default route with the next hop 192.168.212.1 on Switch A.
[SwitchA] ip route-static 0.0.0.0 0 192.168.212.1
# Configure static routes to 192.168.64.0/24, 192.168.74.0/24, and 192.168.99.0/24 with the same next hop 192.168.212.161 on Switch B.
[SwitchB] ip route-static 192.168.64.0 24 192.168.212.161
[SwitchB] ip route-static 192.168.74.0 24 192.168.212.161
[SwitchB] ip route-static 192.168.99.0 24 192.168.212.161
3.     Configure OSPF between Switch B and Switch C and configure OSPF on Switch B to redistribute static routes:
# Configure OSPF to advertise the local network and enable OSPF to redistribute static routes on Switch B.
[SwitchB] ospf
[SwitchB-ospf-1-area-0.0.0.0] network 172.17.100.0 0.0.0.255
[SwitchB-ospf-1] import-route static
# Configure OSPF to advertise the local networks on Switch C.
[SwitchC] ospf
[SwitchC-ospf-1-area-0.0.0.0] network 172.17.100.0 0.0.0.255
[SwitchC-ospf-1-area-0.0.0.0] network 10.220.2.0 0.0.0.255
# Display the IP routing table on Switch C.
[SwitchC] display ip routing-table protocol ospf
Summary Count : 5
Summary Count : 3
192.168.64.0/24     OSPF   150  1            172.17.100.1    Vlan100
192.168.74.0/24     OSPF   150  1            172.17.100.1    Vlan100
192.168.99.0/24     OSPF   150  1            172.17.100.1    Vlan100
Summary Count : 2
10.220.2.0/24       OSPF   10   1            10.220.2.16     Vlan200
172.17.100.0/24     OSPF   10   1            172.17.100.2    Vlan100
The output shows that Switch C has learned routes to 192.168.64.0/24, 192.168.99.0/24, and 192.168.64.0/18 through OSPF.
4.     Configure BGP between Switch C and Switch D and configure BGP on Switch C to redistribute OSPF routes:
# On Switch C, enable BGP, specify Switch D as an EBGP peer, and configure BGP to redistribute OSPF routes.
[SwitchC] bgp 65106
[SwitchC-bgp] peer 10.220.2.217 as-number 64631
[SwitchC-bgp-ipv4] peer 10.220.2.217 enable
[SwitchC-bgp-ipv4] import-route ospf
# Enable BGP, and configure Switch C as an EBGP peer on Switch D.
[SwitchD] bgp 64631
[SwitchD-bgp] router-id 4.4.4.4
[SwitchD-bgp] peer 10.220.2.16 as-number 65106
[SwitchD-bgp] address-family ipv4 unicast
[SwitchD-bgp-ipv4] peer 10.220.2.16 enable
[SwitchD-bgp-ipv4] quit
[SwitchD-bgp] quit
# Display the IP routing table on Switch D.
[SwitchD] display ip routing-table protocol bgp
Summary Count : 3
Summary Count : 3
192.168.64.0/24     BGP    255  1            10.220.2.16     Vlan200
192.168.74.0/24     BGP    255  1            10.220.2.16     Vlan200
192.168.99.0/24     BGP    255  1            10.220.2.16     Vlan200
Summary Count : 0
The output shows that Switch D has learned routes to 192.168.64.0/24, 192.168.74.0/24, and 192.168.99.0/24 through BGP.
# Verify that Switch D can ping hosts on networks 192.168.74.0/24, 192.168.99.0/24, and 192.168.64.0/18. (Details not shown.)
5.     Configure route summarization on Switch C to summarize 192.168.64.0/24, 192.168.74.0/24, and 192.168.99.0/24 into a single route 192.168.64.0/18 on Switch C, and disable advertisement of specific routes.
[SwitchC-bgp-ipv4] aggregate 192.168.64.0 18 detail-suppressed
[SwitchC-bgp] quit
# Display IP routing table on Switch C.
[SwitchC] display ip routing-table | include 192.168
192.168.64.0/18     BGP    130  0            127.0.0.1       NULL0
The output shows that Switch C has a summary route 192.168.64.0/18 with the output interface Null0.
# Display IP routing table on Switch D.
Summary Count : 1
Summary Count : 1
Destination/Mask    Proto  Pre  Cost         NextHop         Interface
192.168.64.0/18     BGP    255  0            10.220.2.16     Vlan200
Summary Count : 0
The output shows that Switch D has only one route 192.168.64.0/18 to AS 65106.
# Verify that Switch D can ping the hosts on networks 192.168.64.0/24, 192.168.74.0/24 and 192.168.99.0/24. (Details not shown.)
BGP load balancing configuration example
As shown in Figure 19, run EBGP between Switch A and Switch B, and between Switch A and Switch C. Run IBGP between Switch B and Switch C. Configure load balancing over the two EBGP links on Switch A.
Figure 19 Network diagram
On Switch A:
·     Establish EBGP connections with Switch B and Switch C.
·     Configure BGP to advertise network 8.1.1.0/24 to Switch B and Switch C, so that Switch B and Switch C can access the internal network connected to Switch A.
On Switch B:
·     Establish an EBGP connection with Switch A and an IBGP connection with Switch C.
·     Configure BGP to advertise network 9.1.1.0/24 to Switch A, so that Switch A can access the intranet through Switch B.
·     Configure a static route to interface loopback 0 on Switch C (or use a routing protocol like OSPF) to establish the IBGP connection.
On Switch C:
·     Establish an EBGP connection with Switch A and an IBGP connection with Switch B.
·     Configure BGP to advertise network 9.1.1.0/24 to Switch A, so that Switch A can access the intranet through Switch C.
·     Configure a static route to interface loopback 0 on Switch B (or use another protocol like OSPF) to establish the IBGP connection.
Configure load balancing on Switch A.
2.     Configure BGP connections:
[SwitchA] bgp 65008
[SwitchA-bgp] peer 3.1.2.1 as-number 65009
[SwitchA-bgp-ipv4] peer 3.1.2.1 enable
[SwitchA-bgp] quit
[SwitchB] bgp 65009
[SwitchB-bgp-ipv4] network 9.1.1.0 24
[SwitchB-bgp] quit
[SwitchB] ip route-static 3.3.3.3 32 9.1.1.2
[SwitchC] bgp 65009
[SwitchC-bgp] peer 3.1.2.2 as-number 65008
[SwitchC-bgp-ipv4] peer 3.1.2.2 enable
[SwitchC-bgp-ipv4] network 9.1.1.0 24
[SwitchC-bgp] quit
[SwitchC] ip route-static 2.2.2.2 32 9.1.1.1
* >e 9.1.1.0/24         3.1.1.1         0                     0       65009i
*  e                    3.1.2.1         0                     0       65009i
¡     The output shows two valid routes to destination 9.1.1.0/24. The route with next hop 3.1.1.1 is marked with a greater-than sign (>), indicating it is the optimal route (because the ID of Switch B is smaller). The route with next hop 3.1.2.1 is marked with an asterisk (*), indicating it is a valid route, but not the optimal route.
¡     By using the display ip routing-table command, you can find only one route to 9.1.1.0/24 with next hop 3.1.1.1 and output interface VLAN-interface 200.
3.     Configure loading balancing:
Because Switch A has two routes to reach AS 65009, configuring load balancing over the two BGP routes on Switch A can improve link usage.
[SwitchA] bgp 65008
[SwitchA-bgp-ipv4] balance 2
[SwitchA-bgp] quit
* >e                    3.1.2.1         0                     0       65009i
The output shows that the route 9.1.1.0/24 has two next hops, 3.1.1.1 and 3.1.2.1, both of which are marked with a greater-than sign (>), indicating that they are the optimal routes.
The display ip routing-table command output shows two routes to 9.1.1.0/24. One has next hop 3.1.1.1 and output interface VLAN-interface 200, and the other has next hop 3.1.2.1 and output interface VLAN-interface 300.
BGP community configuration example
As shown in Figure 20, Switch B establishes EBGP connections with Switch A and Switch C. Configure NO_EXPORT community attribute on Switch A to make routes from AS 10 not advertised by AS 20 to any other AS.
Figure 20 Network diagram
2.     Configure EBGP:
[SwitchA] bgp 10
[SwitchA-bgp] peer 200.1.2.2 as-number 20
[SwitchA-bgp-ipv4] peer 200.1.2.2 enable
[SwitchA-bgp-ipv4] network 9.1.1.0 255.255.255.0
[SwitchA-bgp] quit
[SwitchB] bgp 20
[SwitchB-bgp] peer 200.1.2.1 as-number 10
[SwitchB-bgp] peer 200.1.3.2 as-number 30
[SwitchB-bgp-ipv4] peer 200.1.2.1 enable
[SwitchB-bgp-ipv4] peer 200.1.3.2 enable
[SwitchB-bgp] quit
[SwitchC] bgp 30
[SwitchC-bgp] peer 200.1.3.1 as-number 20
[SwitchC-bgp-ipv4] peer 200.1.3.1 enable
[SwitchC-bgp] quit
[SwitchB] display bgp routing-table ipv4 9.1.1.0
 BGP local router ID: 2.2.2.2
 Local AS number: 20
 Paths:   1 available, 1 best
 Relay nexthop   : 200.1.2.1
 Original nexthop: 200.1.2.1
 OutLabel        : NULL
 AS-path         : 10
 Origin          : igp
 Attribute value : pref-val 0
 State           : valid, external, best,
# Display advertisement information of network 9.1.1.0 on Switch B.
[SwitchB] display bgp routing-table ipv4 9.1.1.0 advertise-info
 Local AS number: 20
 Paths:   1 best
    200.1.3.2
The output shows that Switch B can advertise the route with the destination 9.1.1.0/24 to other ASs through BGP.
* >e 9.1.1.0/24         200.1.3.1                             0       20 10i
The output shows that Switch C has learned route 9.1.1.0/24 from Switch B.
3.     Configure BGP community:
# Configure a routing policy.
[SwitchA] route-policy comm_policy permit node 0
[SwitchA-route-policy-comm_policy-0] apply community no-export
[SwitchA-route-policy-comm_policy-0] quit
# Apply the routing policy.
[SwitchA] bgp 10
[SwitchA-bgp-ipv4] peer 200.1.2.2 route-policy comm_policy export
[SwitchA-bgp-ipv4] peer 200.1.2.2 advertise-community
# Display the routing table on Switch B.
 Local AS number: 20
 OutLabel        : NULL
 Community       : No-Export
 AS-path         : 10
 Origin          : igp
# Display advertisement information for the route 9.1.1.0 on Switch B.
 Local AS number: 20
 Paths:   1 best
 Total number of routes: 0
The output shows BGP has not learned any route.
BGP route reflector configuration example
As shown in Figure 21, all switches run BGP. Run EBGP between Switch A and Switch B, and run IBGP between Switch C and Switch B, and between Switch C and Switch D.
Configure Switch C as a route reflector with clients Switch B and Switch D to allow Switch D to learn route 20.0.0.0/8 from Switch C.
Figure 21 Network diagram
1.     Configure IP addresses for interfaces and configure OSPF in AS 200. (Details not shown.)
[SwitchA] bgp 100
[SwitchA-bgp] peer 192.1.1.2 as-number 200
[SwitchA-bgp-ipv4] peer 192.1.1.2 enable
# Inject network 20.0.0.0/8 to the BGP routing table.
[SwitchA-bgp-ipv4] network 20.0.0.0
[SwitchA-bgp] quit
[SwitchB] bgp 200
[SwitchB-bgp] peer 192.1.1.1 as-number 100
[SwitchB-bgp] peer 193.1.1.1 as-number 200
[SwitchB-bgp-ipv4] peer 192.1.1.1 enable
[SwitchB-bgp-ipv4] peer 193.1.1.1 enable
[SwitchB-bgp-ipv4] peer 193.1.1.1 next-hop-local
[SwitchB-bgp] quit
[SwitchC] bgp 200
[SwitchC-bgp] peer 193.1.1.2 as-number 200
[SwitchC-bgp] peer 194.1.1.2 as-number 200
[SwitchC-bgp-ipv4] peer 193.1.1.2 enable
[SwitchC-bgp-ipv4] peer 194.1.1.2 enable
[SwitchC-bgp] quit
# Configure Switch D.
<SwitchD> system-view
[SwitchD] bgp 200
[SwitchD-bgp] peer 194.1.1.1 as-number 200
[SwitchD-bgp-ipv4] peer 194.1.1.1 enable
[SwitchD-bgp] quit
3.     Configure Switch C as the route reflector.
[SwitchC] bgp 200
[SwitchC-bgp-ipv4] peer 193.1.1.2 reflect-client
[SwitchC-bgp-ipv4] peer 194.1.1.2 reflect-client
[SwitchC-bgp] quit
* >e 20.0.0.0           192.1.1.1       0                     0       100i
# Display the BGP routing table on Switch D.
[SwitchD] display bgp routing-table ipv4
* >i 20.0.0.0           193.1.1.2       0          100        0       100i
The output shows that Switch D has learned route 20.0.0.0/8 from Switch C.
BGP confederation configuration example
As shown in Figure 22, split AS 200 into three sub-ASs (AS 65001, AS 65002, and AS 65003) to reduce IBGP connections. Switches in AS65001 are fully meshed.
Figure 22 Network diagram
Device
IP address
Device
IP address
Switch A
Vlan-int100
200.1.1.1/24
Switch D
Vlan-int200
10.1.5.1/24
Vlan-int200
10.1.1.1/24
Vlan-int400
10.1.3.2/24
Vlan-int300
10.1.2.1/24
Switch E
Vlan-int200
10.1.5.2/24
Vlan-int400
10.1.3.1/24
Vlan-int500
10.1.4.2/24
Vlan-int500
10.1.4.1/24
Switch F
Vlan-int100
200.1.1.2/24
Switch B
Vlan-int200
10.1.1.2/24
Vlan-int600
9.1.1.1/24
Switch C
Vlan-int300
10.1.2.2/24
2.     Configure BGP confederation:
[SwitchA] bgp 65001
[SwitchA-bgp] confederation id 200
[SwitchA-bgp] confederation peer-as 65002 65003
[SwitchA-bgp] peer 10.1.1.2 as-number 65002
[SwitchA-bgp] peer 10.1.2.2 as-number 65003
[SwitchA-bgp-ipv4] peer 10.1.1.2 enable
[SwitchA-bgp-ipv4] peer 10.1.2.2 enable
[SwitchA-bgp-ipv4] peer 10.1.1.2 next-hop-local
[SwitchA-bgp-ipv4] peer 10.1.2.2 next-hop-local
[SwitchA-bgp] quit
[SwitchB] bgp 65002
[SwitchB-bgp] confederation id 200
[SwitchB-bgp] confederation peer-as 65001 65003
[SwitchB-bgp] peer 10.1.1.1 as-number 65001
[SwitchB-bgp-ipv4] peer 10.1.1.1 enable
[SwitchB-bgp] quit
[SwitchC] bgp 65003
[SwitchC-bgp] confederation id 200
[SwitchC-bgp] confederation peer-as 65001 65002
[SwitchC-bgp] peer 10.1.2.1 as-number 65001
[SwitchC-bgp-ipv4] peer 10.1.2.1 enable
[SwitchC-bgp] quit
3.     Configure IBGP connections in AS 65001:
[SwitchA] bgp 65001
[SwitchA-bgp] peer 10.1.3.2 as-number 65001
[SwitchA-bgp] peer 10.1.4.2 as-number 65001
[SwitchA-bgp-ipv4] peer 10.1.3.2 enable
[SwitchA-bgp-ipv4] peer 10.1.4.2 enable
[SwitchA-bgp-ipv4] peer 10.1.3.2 next-hop-local
[SwitchA-bgp-ipv4] peer 10.1.4.2 next-hop-local
[SwitchA-bgp] quit
[SwitchD] bgp 65001
[SwitchD-bgp] confederation id 200
[SwitchD-bgp] peer 10.1.3.1 as-number 65001
[SwitchD-bgp] peer 10.1.5.2 as-number 65001
[SwitchD-bgp-ipv4] peer 10.1.3.1 enable
[SwitchD-bgp-ipv4] peer 10.1.5.2 enable
[SwitchD-bgp] quit
# Configure Switch E.
<SwitchE> system-view
[SwitchE] bgp 65001
[SwitchE-bgp] router-id 5.5.5.5
[SwitchE-bgp] confederation id 200
[SwitchE-bgp] peer 10.1.4.1 as-number 65001
[SwitchE-bgp] peer 10.1.5.1 as-number 65001
[SwitchE-bgp] address-family ipv4 unicast
[SwitchE-bgp-ipv4] peer 10.1.4.1 enable
[SwitchE-bgp-ipv4] peer 10.1.5.1 enable
[SwitchE-bgp-ipv4] quit
[SwitchE-bgp] quit
4.     Configure the EBGP connection between AS 100 and AS 200:
[SwitchA] bgp 65001
[SwitchA-bgp] peer 200.1.1.2 as-number 100
[SwitchA-bgp-ipv4] peer 200.1.1.2 enable
[SwitchA-bgp] quit
# Configure Switch F.
<SwitchF> system-view
[SwitchF] bgp 100
[SwitchF-bgp] router-id 6.6.6.6
[SwitchF-bgp] peer 200.1.1.1 as-number 200
[SwitchF-bgp] address-family ipv4 unicast
[SwitchF-bgp-ipv4] peer 200.1.1.1 enable
[SwitchF-bgp-ipv4] network 9.1.1.0 255.255.255.0
[SwitchF-bgp-ipv4] quit
[SwitchF-bgp] quit
* >i 9.1.1.0/24         10.1.1.1        0          100        0       (65001)
        100i
 Local AS number: 65002
 Relay nexthop   : 10.1.1.1
 Original nexthop: 10.1.1.1
 OutLabel        : NULL
 AS-path         : (65001) 100
 Origin          : igp
 State           : valid, external-confed, best,
* >i 9.1.1.0/24         10.1.3.1        0          100        0       100i
[SwitchD] display bgp routing-table ipv4 9.1.1.0
 BGP local router ID: 4.4.4.4
 Local AS number: 65001
 Relay nexthop   : 10.1.3.1
 Original nexthop: 10.1.3.1
 OutLabel        : NULL
 AS-path         : 100
 Origin          : igp
 State           : valid, internal-confed, best,
·     Switch F can send route information to Switch B and Switch C through the confederation by establishing only an EBGP connection with Switch A.
·     Switch B and Switch D are in the same confederation, but belong to different sub-ASs. They obtain external route information from Switch A, and generate identical BGP route entries although they have no direct connection in between.
BGP path selection configuration example
As shown in Figure 23, all switches run BGP.
·     EBGP runs between Switch A and Switch B, and between Switch A and Switch C.
·     IBGP runs between Switch B and Switch D, and between Switch D and Switch C. OSPF is the IGP protocol in AS 200.
Configure routing policies, making Switch D use the route 1.0.0.0/8 from Switch C as the optimal.
Figure 23 Network diagram
Table 3 Interface and IP address assignment
Device
IP address
Device
IP address
Switch A
Vlan-int101
1.0.0.1/8
Switch D
Vlan-int400
195.1.1.1/24
Vlan-int100
192.1.1.1/24
Vlan-int300
194.1.1.1/24
Vlan-int200
193.1.1.1/24
Switch C
Vlan-int400
195.1.1.2/24
Switch B
Vlan-int100
192.1.1.2/24
Vlan-int200
193.1.1.2/24
Vlan-int300
194.1.1.2/24
2.     Configure OSPF on Switch B, Switch C, and Switch D:
[SwitchB] ospf
[SwitchB-ospf] area 0
[SwitchB-ospf-1-area-0.0.0.0] network 194.1.1.0 0.0.0.255
[SwitchC] ospf
[SwitchC-ospf] area 0
[SwitchC-ospf-1-area-0.0.0.0] network 193.1.1.0 0.0.0.255
[SwitchC-ospf-1-area-0.0.0.0] network 195.1.1.0 0.0.0.255
[SwitchD] ospf
[SwitchD-ospf] area 0
[SwitchD-ospf-1-area-0.0.0.0] network 194.1.1.0 0.0.0.255
[SwitchD-ospf-1-area-0.0.0.0] network 195.1.1.0 0.0.0.255
[SwitchD-ospf-1] quit
3.     Configure BGP connections:
[SwitchA] bgp 100
[SwitchA-bgp] peer 193.1.1.2 as-number 200
[SwitchA-bgp-ipv4] peer 193.1.1.2 enable
# Inject network 1.0.0.0/8 to the BGP routing table on Switch A.
[SwitchA-bgp-ipv4] network 1.0.0.0 8
[SwitchA-bgp] quit
[SwitchB] bgp 200
[SwitchB-bgp] peer 194.1.1.1 as-number 200
[SwitchB-bgp-ipv4] peer 194.1.1.1 enable
[SwitchB-bgp] quit
[SwitchC] bgp 200
[SwitchC-bgp] peer 193.1.1.1 as-number 100
[SwitchC-bgp] peer 195.1.1.1 as-number 200
[SwitchC-bgp-ipv4] peer 193.1.1.1 enable
[SwitchC-bgp-ipv4] peer 195.1.1.1 enable
[SwitchC-bgp] quit
[SwitchD] bgp 200
[SwitchD-bgp] peer 194.1.1.2 as-number 200
[SwitchD-bgp] peer 195.1.1.2 as-number 200
[SwitchD-bgp-ipv4] peer 194.1.1.2 enable
[SwitchD-bgp-ipv4] peer 195.1.1.2 enable
[SwitchD-bgp] quit
4.     Configure local preference for route 1.0.0.0/8, making Switch D give priority to the route learned from Switch C:
# Define an ACL numbered 2000 on Switch C, permitting route 1.0.0.0/8.
[SwitchC] acl number 2000
[SwitchC-acl-basic-2000] rule permit source 1.0.0.0 0.255.255.255
[SwitchC-acl-basic-2000] quit
# Configure a routing policy named localpref on Switch C, setting the local preference of route 1.0.0.0/8 to 200 (the default is 100).
[SwitchC] route-policy localpref permit node 10
[SwitchC-route-policy-localpref-10] if-match ip address acl 2000
[SwitchC-route-policy-localpref-10] apply local-preference 200
[SwitchC-route-policy-localpref-10] quit
# Apply routing policy localpref to routes from peer 193.1.1.1.
[SwitchC] bgp 200
[SwitchC-bgp-ipv4] peer 193.1.1.1 route-policy localpref import
[SwitchC-bgp] quit
 Total number of routes: 2
* >i 1.0.0.0            193.1.1.1                  200        0       100i
*  i                    192.1.1.1                  100        0       100i
The output shows that Route 1.0.0.0/8 learned from Switch C is the optimal.
BGP GR configuration example
As shown in Figure 24, all switches run BGP. EBGP runs between Switch A and Switch B. IBGP runs between Switch B and Switch C.
Enable GR capability for BGP so that the communication between Switch A and Switch C is not affected when an active/standby switchover occurs on Switch B.
Figure 24 Network diagram
1.     Configure Switch A:
# Configure IP addresses for interfaces. (Details not shown.)
# Configure the EBGP connection.
[SwitchA] bgp 65008
[SwitchA-bgp] peer 200.1.1.1 as-number 65009
# Enable GR capability for BGP.
[SwitchA-bgp] graceful-restart
# Inject network 8.0.0.0/8 to the BGP routing table.
[SwitchA-bgp-ipv4] network 8.0.0.0
# Enable Switch A to exchange IPv4 unicast routing information with Switch B.
[SwitchA-bgp-ipv4] peer 200.1.1.1 enable
2.     Configure Switch B:
[SwitchB] bgp 65009
[SwitchB-bgp] peer 200.1.1.2 as-number 65008
# Configure the IBGP connection.
[SwitchB-bgp] peer 9.1.1.2 as-number 65009
[SwitchB-bgp] graceful-restart
# Inject networks 200.1.1.0/24 and 9.1.1.0/24 to the BGP routing table.
[SwitchB-bgp-ipv4] network 200.1.1.0 24
# Enable Switch B to exchange IPv4 unicast routing information with Switch A and Switch C.
[SwitchB-bgp-ipv4] peer 200.1.1.2 enable
[SwitchB-bgp-ipv4] peer 9.1.1.2 enable
3.     Configure Switch C:
[SwitchC] bgp 65009
[SwitchC-bgp] peer 9.1.1.1 as-number 65009
[SwitchC-bgp] graceful-restart
# Enable Switch C to exchange IPv4 unicast routing information with Switch B.
[SwitchC-bgp-ipv4] peer 9.1.1.1 enable
Ping Switch C on Switch A. Meanwhile, perform an active/standby switchover on Switch B. The ping operation is successful during the whole switchover process.
BFD for BGP configuration example
As shown in Figure 25, configure OSPF as the IGP in AS 200.
·     Establish two IBGP connections between Switch A and Switch C. When both paths operate correctly, Switch C uses the path Switch A<—>Switch B<—>Switch C to exchange packets with network 1.1.1.0/24.
·     Configure BFD over the path. When the path fails, BFD can quickly detect the failure and notify it to BGP. Then, the path Switch A<—>Switch D<—>Switch C takes effect immediately.
Figure 25 Network diagram
Table 4 Interface and IP address assignment
Device
IP address
Device
IP address
Switch A
Vlan-int100
3.0.1.1/24
Switch C
Vlan-int101
3.0.2.2/24
Vlan-int200
2.0.1.1/24
Vlan-int201
2.0.2.2/24
Switch B
Vlan-int100
3.0.1.2/24
Switch D
Vlan-int200
2.0.1.2/24
Vlan-int101
3.0.2.1/24
Vlan-int201
2.0.2.1/24
2.     Configure OSPF to make sure that Switch A and Switch C are reachable to each other. (Details not shown.)
3.     Configure BGP on Switch A:
# Establish two IBGP connections to Switch C.
[SwitchA] bgp 200
[SwitchA-bgp] peer 3.0.2.2 as-number 200
[SwitchA-bgp] peer 2.0.2.2 as-number 200
[SwitchA-bgp-ipv4] peer 3.0.2.2 enable
[SwitchA-bgp-ipv4] peer 2.0.2.2 enable
[SwitchA-bgp] quit
# Create ACL 2000 to permit 1.1.1.0/24 to pass.
[SwitchA] acl number 2000
[SwitchA-acl-basic-2000] rule permit source 1.1.1.0 0.0.0.255
[SwitchA-acl-basic-2000] quit
# Create two route policies, apply_med_50 and apply_med_100. Policy apply_med_50 sets the MED for route 1.1.1.0/24 to 50. Policy apply_med_100 sets that to 100.
[SwitchA] route-policy apply_med_50 permit node 10
[SwitchA-route-policy-apply_med_50-10] if-match ip address acl 2000
[SwitchA-route-policy-apply_med_50-10] apply cost 50
[SwitchA-route-policy-apply_med_50-10] quit
[SwitchA] route-policy apply_med_100 permit node 10
[SwitchA-route-policy-apply_med_100-10] if-match ip address acl 2000
[SwitchA-route-policy-apply_med_100-10] apply cost 100
[SwitchA-route-policy-apply_med_100-10] quit
# Apply routing policy apply_med_50 to routes outgoing to peer 3.0.2.2, and apply routing policy apply_med_100 to routes outgoing to peer 2.0.2.2.
[SwitchA] bgp 200
[SwitchA-bgp-ipv4] peer 3.0.2.2 route-policy apply_med_50 export
[SwitchA-bgp-ipv4] peer 2.0.2.2 route-policy apply_med_100 export
# Enable BFD for peer 3.0.2.2.
[SwitchA-bgp] peer 3.0.2.2 bfd
[SwitchA-bgp] quit
4.     Configure BGP on Switch C:
# Establish two IBGP connections to Switch A.
[SwitchC] bgp 200
[SwitchC-bgp] peer 3.0.1.1 as-number 200
[SwitchC-bgp] peer 2.0.1.1 as-number 200
[SwitchC-bgp-ipv4] peer 3.0.1.1 enable
[SwitchC-bgp-ipv4] peer 2.0.1.1 enable
[SwitchC-bgp] quit
# Enable BFD for peer 3.0.1.1.
[SwitchC-bgp] peer 3.0.1.1 bfd
[SwitchC-bgp] quit
[SwitchC] quit
# Display detailed BFD session information on Switch C.
<SwitchC> display bfd session verbose
       Local Discr: 513                  Remote Discr: 513
         Source IP: 3.0.2.2            Destination IP: 3.0.1.1
     Session State: Up                      Interface: N/A
      Min Tx Inter: 500ms                Act Tx Inter: 500ms
      Min Rx Inter: 500ms                Detect Inter: 2500ms
          Rx Count: 135                      Tx Count: 135
      Connect Type: Indirect           Running Up for: 00:00:58
         Hold Time: 2457ms                  Auth mode: None
       Detect Mode: Async                        Slot: 0
          Protocol: BGP
         Diag Info: No Diagnostic
The output shows that a BFD session has been established between Switch A and Switch C.
# Display BGP peer information on Switch C.
<SwitchC> display bgp peer ipv4
 BGP local router ID: 3.3.3.3
 Local AS number: 200
 Total number of peers: 2                  Peers in established state: 2
  2.0.1.1                200        4        5    0       0 00:01:55 Established
  3.0.1.1                200        4        5    0       0 00:01:52 Established
The output shows that Switch C has established two BGP connections with Switch A, and both connections are in Established state.
# Display route 1.1.1.0/24 on Switch C.
<SwitchC> display ip routing-table 1.1.1.0 24 verbose
Summary Count : 1
Destination: 1.1.1.0/24
   Protocol: BGP             Process ID: 0
  SubProtID: 0x1                    Age: 00h00m09s
       Cost: 50              Preference: 255
        Tag: 0                    State: Active Adv
  OrigTblID: 0x1                OrigVrf: default-vrf
    TableID: 0x2                 OrigAs: 0
      NBRID: 0x15000001          LastAs: 0
     AttrID: 0x1               Neighbor: 3.0.1.1
      Flags: 0x10060        OrigNextHop: 3.0.1.1
      Label: NULL           RealNextHop: 3.0.2.1
    BkLabel: NULL             BkNextHop: N/A
  Tunnel ID: Invalid          Interface: Vlan-interface101
BkTunnel ID: Invalid        BkInterface: N/A
The output shows that Switch C communicates with network 1.1.1.0/24 through the path Switch C<—>Switch B<—>Switch A.
# Break down the path Switch C<—>Switch B<—>Switch A and then display route 1.1.1.0/24 on Switch C.
Summary Count : 1
  SubProtID: 0x1                    Age: 00h03m08s
       Cost: 100             Preference: 255
      NBRID: 0x15000000          LastAs: 0
     AttrID: 0x0               Neighbor: 2.0.1.1
      Flags: 0x10060        OrigNextHop: 2.0.1.1
      Label: NULL           RealNextHop: 2.0.2.1
  Tunnel ID: Invalid          Interface: Vlan-interface201
The output shows that Switch C communicates with network 1.1.1.0/24 through the path Switch C<—>Switch D<—>Switch A.
BGP FRR configuration example
As shown in Figure 26, configure BGP FRR so that when Link B fails, BGP uses Link A to forward traffic.
Figure 26 Network diagram
2.     Configure OSPF in AS 200 to ensure connectivity among Switch B, Switch C and Switch D. (Details not shown.)
# Configure Switch A to establish EBGP sessions with Switch B and Switch C, and advertise network 1.1.1.1/32.
[SwitchA] bgp 100
[SwitchA-bgp] peer 10.1.1.2 as-number 200
[SwitchA-bgp] peer 30.1.1.3 as-number 200
[SwitchA-bgp-ipv4] peer 30.1.1.3 enable
[SwitchA-bgp-ipv4] network 1.1.1.1 32
# Configure Switch B to establish an EBGP session with Switch A, and an IBGP session with Switch D.
[SwitchB] bgp 200
[SwitchB-bgp] peer 10.1.1.1 as-number 100
[SwitchB-bgp] peer 4.4.4.4 as-number 200
[SwitchB-bgp] peer 4.4.4.4 connect-interface loopback 0
[SwitchB-bgp-ipv4] peer 4.4.4.4 enable
[SwitchB-bgp-ipv4] peer 4.4.4.4 next-hop-local
[SwitchB-bgp] quit
# Configure Switch C to establish an EBGP session with Switch A, and an IBGP session with Switch D.
[SwitchC] bgp 200
[SwitchC-bgp] peer 30.1.1.1 as-number 100
[SwitchC-bgp] peer 4.4.4.4 as-number 200
[SwitchC-bgp] peer 4.4.4.4 connect-interface loopback 0
[SwitchC-bgp-ipv4] peer 30.1.1.1 enable
[SwitchC-bgp-ipv4] peer 4.4.4.4 enable
[SwitchC-bgp-ipv4] peer 4.4.4.4 next-hop-local
[SwitchC-bgp] quit
# Configure Switch D to establish IBGP sessions with Switch B and Switch C, and advertise network 4.4.4.4/32.
[SwitchD] bgp 200
[SwitchD-bgp] peer 2.2.2.2 as-number 200
[SwitchD-bgp] peer 2.2.2.2 connect-interface loopback 0
[SwitchD-bgp] peer 3.3.3.3 as-number 200
[SwitchD-bgp] peer 3.3.3.3 connect-interface loopback 0
[SwitchD-bgp-ipv4] peer 2.2.2.2 enable
[SwitchD-bgp-ipv4] peer 3.3.3.3 enable
[SwitchD-bgp-ipv4] network 4.4.4.4 32
4.     Configure preferred values so Link B is used to forward traffic between Switch A and Switch D:
# Configure Switch A to set the preferred value to 100 for routes received from Switch B.
[SwitchA-bgp-ipv4] peer 10.1.1.2 preferred-value 100
[SwitchA-bgp] quit
# Configure Switch D to set the preferred value to 100 for routes received from Switch B.
[SwitchD-bgp-ipv4] peer 2.2.2.2 preferred-value 100
[SwitchD-bgp] quit
5.     Configure BGP FRR:
# On Switch A, configure the source address of BFD echo packets as 11.1.1.1.
[SwitchA] bfd echo-source-ip 11.1.1.1
# Create routing policy frr to set a backup next hop 30.1.1.3 (Switch C) for the route destined for 4.4.4.4/32.
[SwitchA-route-policy] if-match ip address prefix-list abc
[SwitchA-route-policy] apply fast-reroute backup-nexthop 30.1.1.3
[SwitchA-route-policy] quit
# Apply the routing policy to BGP FRR for BGP IPv4 unicast address family.
[SwitchA] bgp 100
[SwitchA-bgp-ipv4] fast-reroute route-policy frr
[SwitchA-bgp] quit
# On Switch D, configure the source address of BFD echo packets as 44.1.1.1.
[SwitchD] bfd echo-source-ip 44.1.1.1
# Create routing policy frr to set a backup next hop 3.3.3.3 (Switch C) for the route destined for 1.1.1.1/32.
[SwitchD] ip prefix-list abc index 10 permit 1.1.1.1 32
[SwitchD-route-policy] if-match ip address prefix-list abc
[SwitchD-route-policy] apply fast-reroute backup-nexthop 3.3.3.3
[SwitchD-route-policy] quit
[SwitchD] bgp 200
[SwitchD-bgp-ipv4] fast-reroute route-policy frr
[SwitchD-bgp] quit
# Display detailed information about the route to 4.4.4.4/32 on Switch A. The output shows the backup next hop for the route.
[SwitchA] display ip routing-table 4.4.4.4 32 verbose
Summary Count : 1
Destination: 4.4.4.4/32
  SubProtID: 0x2                    Age: 00h01m52s
       Cost: 0               Preference: 255
      IpPre: N/A             QosLocalID: N/A
  OrigTblID: 0x0                OrigVrf: default-vrf
    TableID: 0x2                 OrigAs: 200
      NibID: 0x15000003          LastAs: 200
     AttrID: 0x5               Neighbor: 10.1.1.2
      Flags: 0x10060        OrigNextHop: 10.1.1.2
      Label: NULL           RealNextHop: 10.1.1.2
    BkLabel: NULL             BkNextHop: 30.1.1.3
  Tunnel ID: Invalid          Interface: Vlan-interface 100
BkTunnel ID: Invalid        BkInterface: Vlan-interface 200
   FtnIndex: 0x0
# Display detailed information about the route to 1.1.1.1/32 on Switch D. The output shows the backup next hop for the route.
[SwitchD] display ip routing-table 1.1.1.1 32 verbose
Summary Count : 1
Destination: 1.1.1.1/32
  SubProtID: 0x1                    Age: 00h00m36s
    TableID: 0x2                 OrigAs: 100
      NibID: 0x15000003          LastAs: 100
     AttrID: 0x1               Neighbor: 2.2.2.2
      Flags: 0x10060        OrigNextHop: 2.2.2.2
      Label: NULL           RealNextHop: 20.1.1.2
    BkLabel: NULL             BkNextHop: 40.1.1.3
  Tunnel ID: Invalid          Interface: Vlan-interface 101
BkTunnel ID: Invalid        BkInterface: Vlan-interface 201
   FtnIndex: 0x0
IPv6 BGP configuration examples
IPv6 BGP basic configuration example
As shown in Figure 27, all switches run BGP. Run EBGP between Switch A and Switch B, and run IBGP between Switch B and Switch C to allow Switch C to access network 50::/64 connected to Switch A.
Figure 27 Network diagram
2.     Configure IBGP:
[SwitchB] bgp 65009
[SwitchB-bgp] peer 9::2 as-number 65009
[SwitchB-bgp] address-family ipv6
[SwitchB-bgp-ipv6] peer 9::2 enable
[SwitchB-bgp-ipv6] quit
[SwitchC] bgp 65009
[SwitchC-bgp] peer 9::1 as-number 65009
[SwitchC-bgp] address-family ipv6
[SwitchC-bgp-ipv6] peer 9::1 enable
3.     Configure EBGP:
[SwitchA] bgp 65008
[SwitchA-bgp] peer 10::1 as-number 65009
[SwitchA-bgp] address-family ipv6
[SwitchA-bgp-ipv6] peer 10::1 enable
[SwitchB-bgp] peer 10::2 as-number 65008
[SwitchB-bgp-ipv6] peer 10::2 enable
4.     Inject network routes to the BGP routing table:
[SwitchA-bgp-ipv6] network 10:: 64
[SwitchA-bgp-ipv6] network 50:: 64
[SwitchA-bgp-ipv6] quit
[SwitchA-bgp] quit
[SwitchB-bgp-ipv6] network 10:: 64
[SwitchB-bgp-ipv6] network 9:: 64
[SwitchB-bgp] quit
[SwitchC-bgp-ipv6] network 9:: 64
[SwitchC-bgp-ipv6] quit
[SwitchC-bgp] quit
# Display IPv6 BGP peer information on Switch B.
[SwitchB] display bgp peer ipv6
 Local AS number: 65009
  9::2                 65009       41       43    0       1 00:29:00 Established
  10::2                65008       38       38    0       2 00:27:20 Established
The output shows that Switch A and Switch B have established an EBGP connection, and Switch B and Switch C have established an IBGP connection.
# Display IPv6 BGP routing table information on Switch A.
[SwitchA] display bgp routing-table ipv6
* >e Network : 9::                                      PrefixLen : 64
     NextHop : 10::1                                    LocPrf    :
     MED     : 0
     Path/Ogn: 65009i
* >  Network : 10::                                     PrefixLen : 64
     NextHop : ::                                       LocPrf    :
     PrefVal : 32768                                    OutLabel  : NULL
     MED     : 0
     Path/Ogn: i
*  e Network : 10::                                     PrefixLen : 64
     MED     : 0
     Path/Ogn: 65009i
* >  Network : 50::                                     PrefixLen : 64
     MED     : 0
     Path/Ogn: i
The output shows that Switch A has learned routing information of AS 65009.
# Display IPv6 BGP routing table information on Switch C.
[SwitchC] display bgp routing-table ipv6
* >  Network : 9::                                      PrefixLen : 64
     MED     : 0
     Path/Ogn: i
*  i Network : 9::                                      PrefixLen : 64
     NextHop : 9::1                                     LocPrf    : 100
     MED     : 0
     Path/Ogn: i
* >i Network : 10::                                     PrefixLen : 64
     MED     : 0
     Path/Ogn: i
* >i Network : 50::                                     PrefixLen : 64
     NextHop : 10::2                                    LocPrf    : 100
     MED     : 0
     Path/Ogn: 65008i
The output shows that Switch C has learned the route 50::/64.
# Verify that Switch C can ping hosts on network 50::/64. (Details not shown.)
IPv6 BGP route reflector configuration example
As shown in Figure 28, run EBGP between Switch A and Switch B, run IBGP between Switch C and Switch B, and between Switch C and Switch D.
Configure Switch C as a route reflector with clients Switch B and Switch D.
Figure 28 Network diagram
1.     Configure IPv6 addresses for interfaces and IPv4 addresses for loopback interfaces. (Details not shown.)
2.     Configure IBGP and EBGP connections and advertise network routes through IPv6 BGP:
[SwitchA] bgp 100
[SwitchA-bgp] peer 100::2 as-number 200
[SwitchA-bgp-ipv6] peer 100::2 enable
[SwitchA-bgp-ipv6] network 1:: 64
[SwitchA-bgp-ipv6] network 100:: 96
[SwitchA-bgp] quit
[SwitchB] bgp 200
[SwitchB-bgp] peer 100::1 as-number 100
[SwitchB-bgp] peer 101::1 as-number 200
[SwitchB-bgp-ipv6] peer 100::1 enable
[SwitchB-bgp-ipv6] peer 101::1 enable
[SwitchB-bgp-ipv6] peer 101::1 next-hop-local
[SwitchB-bgp-ipv6] network 100:: 96
[SwitchB-bgp-ipv6] network 101:: 96
[SwitchB-bgp] quit
[SwitchC] bgp 200
[SwitchC-bgp] peer 101::2 as-number 200
[SwitchC-bgp] peer 102::2 as-number 200
[SwitchC-bgp-ipv6] peer 101::2 enable
[SwitchC-bgp-ipv6] peer 102::2 enable
[SwitchC-bgp-ipv6] network 101:: 96
[SwitchC-bgp-ipv6] network 102:: 96
[SwitchD] bgp 200
[SwitchD-bgp] peer 102::1 as-number 200
[SwitchD-bgp] address-family ipv6
[SwitchD-bgp-ipv6] peer 102::1 enable
[SwitchD-bgp-ipv6] network 102:: 96
3.     Configure Switch C as a route reflector, and configure Switch B and Switch D as its clients.
[SwitchC-bgp-ipv6] peer 101::2 reflect-client
[SwitchC-bgp-ipv6] peer 102::2 reflect-client
[SwitchC-bgp] quit
# Execute the display bgp routing-table ipv6 command on Switch D.
[SwitchD] display bgp routing-table ipv6
 Total number of routes: 5
* >i Network : 1::                                      PrefixLen : 64
     NextHop : 101::2                                   LocPrf    : 100
     MED     : 0
     Path/Ogn: 100i
* >i Network : 100::                                    PrefixLen : 96
     MED     : 0
     Path/Ogn: i
* >i Network : 101::                                    PrefixLen : 96
     NextHop : 102::1                                   LocPrf    : 100
     MED     : 0
     Path/Ogn: i
* >  Network : 102::                                    PrefixLen : 96
     MED     : 0
     Path/Ogn: i
*  i Network : 102::                                    PrefixLen : 96
     MED     : 0
     Path/Ogn: i
The output shows that Switch D has learned the network 1::/64 from Switch C through route reflection.
6PE configuration example
As shown in Figure 29, use 6PE to connect two isolated IPv6 networks over an IPv4/MPLS network.
·     The ISP uses OSPF as the IGP.
·     PE 1 and PE 2 are edge devices of the ISP, and establish an IPv4 IBGP connection between them.
·     CE 1 and CE 2 are edge devices of the IPv6 networks, and they connect the IPv6 networks to the ISP.
·     A CE and a PE exchange IPv6 packets through IPv6 static routing.
Figure 29 Network diagram
1.     Configure IPv6 addresses and IPv4 addresses for interfaces. (Details not shown.)
2.     Configure PE 1:
# Enable LDP globally, and configure the LSP generation policy.
<PE1> system-view
[PE1] mpls lsr-id 2.2.2.2
[PE1] mpls ldp
[PE1-ldp] lsp-trigger all
[PE1-ldp] quit
# Enable MPLS and LDP on VLAN-interface 30.
[PE1] interface vlan-interface 30
[PE1-Vlan-interface30] mpls enable
[PE1-Vlan-interface30] mpls ldp enable
[PE1-Vlan-interface30] quit
# Configure IBGP, enable the peer's 6PE capabilities, and redistribute IPv6 direct and static routes.
[PE1] bgp 65100
[PE1-bgp] router-id 2.2.2.2
[PE1-bgp] peer 3.3.3.3 as-number 65100
[PE1-bgp] peer 3.3.3.3 connect-interface loopback 0
[PE1-bgp] address-family ipv6
[PE1-bgp-ipv6] import-route direct
[PE1-bgp-ipv6] import-route static
[PE1-bgp-ipv6] peer 3.3.3.3 enable
[PE1-bgp-ipv6] peer 3.3.3.3 label-route-capability
[PE1-bgp-ipv6] quit
[PE1-bgp] quit
# Configure a static route to CE 1.
[PE1] ipv6 route-static 1::1 128 10::1
# Configure OSPF for the ISP.
[PE1] ospf
[PE1-ospf-1] area 0
[PE1-ospf-1-area-0.0.0.0] network 2.2.2.2 0.0.0.0
[PE1-ospf-1-area-0.0.0.0] network 1.1.0.0 0.0.255.255
[PE1-ospf-1] quit
3.     Configure PE 2:
<PE2> system-view
[PE2] mpls lsr-id 3.3.3.3
[PE2] mpls ldp
[PE2-mpls-ldp] lsp-trigger all
[PE2-mpls-ldp] quit
[PE2] interface vlan-interface 30
[PE2-Vlan-interface30] mpls enable
[PE2-Vlan-interface30] mpls ldp enable
[PE2-Vlan-interface30] quit
[PE2] bgp 65100
[PE2-bgp] router-id 3.3.3.3
[PE2-bgp] peer 2.2.2.2 as-number 65100
[PE2-bgp] peer 2.2.2.2 connect-interface loopback 0
[PE2-bgp] address-family ipv6
[PE2-bgp-ipv6] import-route direct
[PE2-bgp-ipv6] import-route static
[PE2-bgp-ipv6] peer 2.2.2.2 enable
[PE2-bgp-ipv6] peer 2.2.2.2 label-route-capability
[PE2-bgp-ipv6] quit
[PE2-bgp] quit
# Configure the static route to CE 2.
[PE2] ipv6 route-static 4::4 128 20::1
[PE2] ospf
[PE2-ospf-1] area 0
[PE2-ospf-1-area-0.0.0.0] network 3.3.3.3 0.0.0.0
[PE2-ospf-1-area-0.0.0.0] network 1.1.0.0 0.0.255.255
[PE2-ospf-1] quit
4.     Configure a static route on CE 1, with PE 1 as the default next hop.
<CE1> system-view
[CE1] ipv6 route-static :: 0 10::2
5.     Configure a static route on CE 2, with PE 2 as the default next hop.
<CE2> system-view
[CE2] ipv6 route-static :: 0 20::2
Display the IPv6 BGP routing tables on PE 1 and PE 2, and the output shows that each of them has two IPv6 network routes.
# Display the IPv6 BGP routing table on PE 1.
[PE1] display bgp routing-table ipv6
* >  Network : 1::1                                     PrefixLen : 128
     MED     : 0
     Path/Ogn: ?
* >i Network : 4::4                                     PrefixLen : 128
     NextHop : ::FFFF:3.3.3.3                           LocPrf    : 100
     PrefVal : 0                                        OutLabel  : 1279
     MED     : 0
     Path/Ogn: ?
     MED     : 0
     Path/Ogn: ?
* >  Network : 10::2                                    PrefixLen : 128
     NextHop : ::1                                      LocPrf    :
     MED     : 0
     Path/Ogn: ?
* >i Network : 20::                                     PrefixLen : 64
     PrefVal : 0                                        OutLabel  : 1278
     MED     : 0
     Path/Ogn: ?
# Verify that CE 1 can ping the IPv6 address 4::4 (loopback interface address) of CE 2. (Details not shown.)
BFD for IPv6 BGP configuration example
As shown in Figure 30, configure OSPFv3 as the IGP in AS 200.
·     Establish two IBGP connections between Switch A and Switch C. When both paths operate correctly, Switch C uses the path Switch A<—>Switch B<—>Switch C to exchange packets with network 1200::0/64.
·     Configure BFD over the path. When the path fails, BFD can quickly detect the failure and notify it to IPv6 BGP. Then, the path Switch A<—>Switch D<—>Switch C takes effect immediately.
Figure 30 Network diagram
Table 5 Interface and IP address assignment
Device
IP address
Device
IP address
Switch A
Vlan-int100
3000::1/64
Switch C
Vlan-int101
3001::3/64
Vlan-int200
2000::1/64
Vlan-int201
2001::3/64
Switch B
Vlan-int100
3000::2/64
Switch D
Vlan-int200
2000::2/64
Vlan-int101
3001::2/64
Vlan-int201
2001::2/64
1.     Configure IPv6 addresses for interfaces. (Details not shown.)
2.     Configure OSPFv3 so that Switch A and Switch C can reach each other. (Details not shown.)
3.     Configure IPv6 BGP on Switch A:
[SwitchA] bgp 200
[SwitchA-bgp] peer 3001::3 as-number 200
[SwitchA-bgp] peer 2001::3 as-number 200
[SwitchA-bgp-ipv6] peer 3001::3 enable
[SwitchA-bgp-ipv6] peer 2001::3 enable
# Create IPv6 ACL 2000 to permit 1200::0/64 to pass.
[SwitchA] acl ipv6 number 2000
[SwitchA-acl6-basic-2000] rule permit source 1200:: 64
[SwitchA-acl6-basic-2000] quit
# Create two route policies, apply_med_50 and apply_med_100. Policy apply_med_50 sets the MED for route 1200::0/64 to 50. Policy apply_med_100 sets that to 100.
[SwitchA-route-policy-apply_med_50-10] if-match ipv6 address acl 2000
[SwitchA-route-policy-apply_med_100-10] if-match ipv6 address acl 2000
# Apply routing policy apply_med_50 to routes outgoing to peer 3001::3, and apply routing policy apply_med_100 to routes outgoing to peer 2001::3.
[SwitchA] bgp 200
[SwitchA-bgp] address-family ipv6 unicast
[SwitchA-bgp-ipv6] peer 3001::3 route-policy apply_med_50 export
[SwitchA-bgp-ipv6] peer 2001::3  route-policy apply_med_100 export
# Enable BFD for peer 3001::3.
[SwitchA-bgp] peer 3001::3 bfd
[SwitchA-bgp] quit
4.     Configure IPv6 BGP on Switch C:
[SwitchC] bgp 200
[SwitchC-bgp] peer 3000::1 as-number 200
[SwitchC-bgp] peer 2000::1 as-number 200
[SwitchC-bgp-ipv6] peer 3000::1 enable
[SwitchC-bgp-ipv6] peer 2000::1 enable
# Enable BFD for peer 3001::1.
[SwitchC-bgp] peer 3000::1 bfd
[SwitchC-bgp] quit
[SwitchC] quit
 IPv6 Session Working Under Ctrl Mode:
         Source IP: 3001::3
    Destination IP: 3000::1
          Rx Count: 13                       Tx Count: 14
      Connect Type: Indirect           Running Up for: 00:00:05
         Hold Time: 2243ms                  Auth mode: None
          Protocol: BGP6
<SwitchC> display bgp peer ipv6
  2000::1                200        8        8    0       0 00:04:45 Established
  3000::1                200        5        4    0       0 00:01:53 Established
# Display route 1200::0/64 on Switch C.
<SwitchC> display ipv6 routing-table 1200::0 64 verbose
Summary Count : 1
Destination: 1200::/64
   Protocol: BGP4+           Process ID: 0
  SubProtID: 0x1                    Age: 00h01m07s
    TableID: 0xa                 OrigAs: 0
      NBRID: 0x25000001          LastAs: 0
     AttrID: 0x1               Neighbor: 3000::1
      Flags: 0x10060        OrigNextHop: 3000::1
      Label: NULL           RealNextHop: FE80::20C:29FF:FE4A:3873
The output shows that Switch C communicates with network 1200::0/64 through the path Switch C<—>Switch B<—>Switch A.
# Break down the path Switch C<—>Switch B<—>Switch A and then display route 1200::0/64 on Switch C.
Summary Count : 1
  SubProtID: 0x1                    Age: 00h00m57s
      NBRID: 0x25000000          LastAs: 0
     AttrID: 0x0               Neighbor: 2000::1
      Flags: 0x10060        OrigNextHop: 2000::1
      Label: NULL           RealNextHop: FE80::20C:29FF:FE40:715
The output shows that Switch C communicates with network 1200::0/64 through the path Switch C<—>Switch D<—>Switch A.
IPv6 BGP FRR configuration example
As shown in Figure 31, configuring BGP FRR so that when Link B fails, BGP uses Link A to forward traffic.
Figure 31 Network diagram
2.     Configure OSPFv3 in AS 200 to ensure connectivity among Switch B, Switch C and Switch D. (Details not shown.)
# Configure Switch A to establish EBGP sessions with Switch B and Switch C, and advertise network 1::/64.
[SwitchA] bgp 100
[SwitchA] router-id 1.1.1.1
[SwitchA-bgp] peer 3001::2 as-number 200
[SwitchA-bgp] peer 2001::2 as-number 200
[SwitchA-bgp-ipv6] peer 3001::2 enable
[SwitchA-bgp-ipv6] peer 2001::2 enable
[SwitchA-bgp] quit
[SwitchB] bgp 200
[SwitchB] router-id 2.2.2.2
[SwitchB-bgp] peer 3001::1 as-number 100
[SwitchB-bgp] peer 3002::2 as-number 200
[SwitchB-bgp] address-family ipv6 unicast
[SwitchB-bgp-ipv6] peer 3001::1 enable
[SwitchB-bgp-ipv6] peer 3002::2 enable
[SwitchB-bgp-ipv6] peer 3002::2 next-hop-local
[SwitchB-bgp] quit
[SwitchC] bgp 200
[SwitchC] router-id 3.3.3.3
[SwitchC-bgp] peer 2001::1 as-number 100
[SwitchC-bgp] peer 2002::2 as-number 200
[SwitchC-bgp] address-family ipv6 unicast
[SwitchC-bgp-ipv6] peer 2001::1 enable
[SwitchC-bgp-ipv6] peer 2002::2 enable
[SwitchC-bgp-ipv6] peer 2002::2 next-hop-local
[SwitchC-bgp] quit
# Configure Switch D to establish IBGP sessions with Switch B and Switch C, and advertise network 4::/64.
[SwitchD] bgp 200
[SwitchD-bgp] peer 3002::1 as-number 200
[SwitchD-bgp] peer 2002::1 as-number 200
[SwitchD-bgp] address-family ipv6 unicast
[SwitchD-bgp-ipv6] peer 3002::1 enable
[SwitchD-bgp-ipv6] peer 2002::1 enable
[SwitchD-bgp-ipv6] network 4:: 64
[SwitchD-bgp-ipv6] quit
[SwitchD-bgp] quit
[SwitchA-bgp-ipv6] peer 3001::2 preferred-value 100
[SwitchA-bgp] quit
[SwitchD-bgp-ipv6] peer 3002::1 preferred-value 100
[SwitchD-bgp] quit
# On Switch A, create routing policy frr to set a backup next hop 2001::2 (Switch C) for the route destined for 4::/64.
[SwitchA] ipv6 prefix-list abc index 10 permit 4:: 64
[SwitchA-route-policy] if-match ipv6 address prefix-list abc
[SwitchA-route-policy] apply ipv6 fast-reroute backup-nexthop 2001::2
# Apply the routing policy to BGP FRR for BGP IPv6 unicast address family.
[SwitchA] bgp 100
[SwitchA-bgp-ipv6] fast-reroute route-policy frr
[SwitchA-bgp] quit
# On Switch D, create routing policy frr to set a backup next hop 2002::1 (Switch C) for the route destined for 1::/64.
[SwitchD] ipv6 prefix-list abc index 10 permit 1:: 64
[SwitchD-route-policy] if-match ipv6 address prefix-list abc
[SwitchD-route-policy] apply ipv6 fast-reroute backup-nexthop 2002::1
[SwitchD] bgp 200
[SwitchD-bgp-ipv6] fast-reroute route-policy frr
[SwitchD-bgp] quit
# Display detailed information about the route to 4::/64 on Switch A. The output shows the backup next hop for the route.
[SwitchA] display ipv6 routing-table 4:: 64 verbose
Summary Count : 1
Destination: 4::/64
  SubProtID: 0x2                    Age: 00h00m58s
    TableID: 0xa                 OrigAs: 200
      NibID: 0x25000003          LastAs: 200
     AttrID: 0x3               Neighbor: 3001::2
      Flags: 0x10060        OrigNextHop: 3001::2
      Label: NULL           RealNextHop: 3001::2
    BkLabel: NULL             BkNextHop: 2001::2
   FtnIndex: 0x0
# Display detailed information about the route to 1::/64 on Switch D. The output shows the backup next hop for the route.
[SwitchD] display ipv6 routing-table 1:: 64 verbose
Summary Count : 1
Destination: 1::/64
  SubProtID: 0x1                    Age: 00h03m24s
    TableID: 0xa                 OrigAs: 100
      NibID: 0x25000003          LastAs: 100
     AttrID: 0x4               Neighbor: 3002::1
      Flags: 0x10060        OrigNextHop: 3002::1
      Label: NULL           RealNextHop: 3002::1
    BkLabel: NULL             BkNextHop: 2002::1
   FtnIndex: 0x0
IPsec for IPv6 BGP packets configuration example
As shown in Figure 32, all switches run IPv6 BGP. Establish an IBGP connection between Switch A and Switch B. Establish an EBGP connection between Switch B and Switch C.
To enhance security, configure IPsec to protect IPv6 BGP packets.
Figure 32 Network diagram
2.     Establish an IBGP connection between Switch A and Switch B:
[SwitchA] bgp 65008
[SwitchA-bgp] group ibgp internal
[SwitchA-bgp] peer 1::2 group ibgp
[SwitchA-bgp-ipv6] peer ibgp enable
[SwitchA-bgp] quit
[SwitchB] bgp 65008
[SwitchB-bgp] group ibgp internal
[SwitchB-bgp] peer 1::1 group ibgp
[SwitchB-bgp-ipv6] peer ibgp enable
3.     Establish an EBGP connection between Switch B and Switch C:
[SwitchC] bgp 65009
[SwitchC-bgp] group ebgp external
[SwitchC-bgp] peer 3::1 as-number 65008
[SwitchC-bgp] peer 3::1 group ebgp
[SwitchC-bgp-ipv6] peer ebgp enable
[SwitchC-bgp] quit
[SwitchB-bgp] group ebgp external
[SwitchB-bgp] peer 3::2 as-number 65009
[SwitchB-bgp] peer 3::2 group ebgp
[SwitchB-bgp-ipv6] peer ebgp enable
[SwitchB-bgp] quit
4.     Configure IPsec transform sets and IPsec profiles:
# On Switch A, create an IPsec transform set named tran1.
[SwitchA] ipsec transform-set tran1
# Set the encapsulation mode to transport mode.
[SwitchA-ipsec-transform-set-tran1] encapsulation-mode transport
# Set the security protocol to ESP, the encryption algorithm to DES, and authentication algorithm to SHA1.
[SwitchA-ipsec-transform-set-tran1] esp encryption-algorithm des
[SwitchA-ipsec-transform-set-tran1] esp authentication-algorithm sha1
[SwitchA-ipsec-transform-set-tran1] quit
# Create an IPsec profile named policy001, and specify the manual mode for it.
[SwitchA] ipsec profile policy001 manual
# Reference IPsec transform set tran1.
[SwitchA-ipsec-profile-policy001-manual] transform-set tran1
# Set the SPIs of the inbound and outbound SAs to 12345.
[SwitchA-ipsec-profile-policy001-manual] sa spi outbound esp 12345
[SwitchA-ipsec-profile-policy001-manual] sa spi inbound esp 12345
# Set the keys for the inbound and outbound SAs using ESP to abcdefg.
[SwitchA-ipsec-profile-policy001-manual] sa string-key outbound esp simple abcdefg
[SwitchA-ipsec-profile-policy001-manual] sa string-key inbound esp simple abcdefg
[SwitchA-ipsec-profile-policy001-manual] quit
# On Switch B, create an IPsec transform set named tran1.
[SwitchB] ipsec transform-set tran1
[SwitchB-ipsec-transform-set-tran1] encapsulation-mode transport
[SwitchB-ipsec-transform-set-tran1] esp encryption-algorithm des
[SwitchB-ipsec-transform-set-tran1] esp authentication-algorithm sha1
[SwitchB-ipsec-transform-set-tran1] quit
# Create IPsec profile named policy001, and specify the manual mode for it.
[SwitchB] ipsec profile policy001 manual
[SwitchB-ipsec-profile-policy001-manual] transform-set tran1
[SwitchB-ipsec-profile-policy001-manual] sa spi outbound esp 12345
[SwitchB-ipsec-profile-policy001-manual] sa spi inbound esp 12345
[SwitchB-ipsec-profile-policy001-manual] sa string-key outbound esp simple abcdefg
[SwitchB-ipsec-profile-policy001-manual] sa string-key inbound esp simple abcdefg
[SwitchB-ipsec-profile-policy001-manual] quit
# Create an IPsec transform set named tran2.
[SwitchB] ipsec transform-set tran2
[SwitchB-ipsec-transform-set-tran2] encapsulation-mode transport
[SwitchB-ipsec-transform-set-tran2] esp encryption-algorithm des
[SwitchB-ipsec-transform-set-tran2] esp authentication-algorithm sha1
[SwitchB-ipsec-transform-set-tran2] quit
# Create IPsec profile named policy002, and specify the manual mode for it.
[SwitchB] ipsec profile policy002 manual
# Reference IPsec transform set tran2.
[SwitchB-ipsec-profile-policy002-manual] transform-set tran2
# Set the SPIs of the inbound and outbound SAs to 54321.
[SwitchB-ipsec-profile-policy002-manual] sa spi outbound esp 54321
[SwitchB-ipsec-profile-policy002-manual] sa spi inbound esp 54321
# Set the keys for the inbound and outbound SAs using ESP to gfedcba.
[SwitchB-ipsec-profile-policy002-manual] sa string-key outbound esp simple gfedcba
[SwitchB-ipsec-profile-policy002-manual] sa string-key inbound esp simple gfedcba
[SwitchB-ipsec-profile-policy002-manual] quit
# On Switch C, create an IPsec transform set named tran2.
[SwitchC] ipsec transform-set tran2
[SwitchC-ipsec-transform-set-tran2] encapsulation-mode transport
[SwitchC-ipsec-transform-set-tran2] esp encryption-algorithm des
[SwitchC-ipsec-transform-set-tran2] esp authentication-algorithm sha1
[SwitchC-ipsec-transform-set-tran2] quit
[SwitchC] ipsec profile policy002 manual
[SwitchC-ipsec-profile-policy002-manual] transform-set tran2
[SwitchC-ipsec-profile-policy002-manual] sa spi outbound esp 54321
[SwitchC-ipsec-profile-policy002-manual] sa spi inbound esp 54321
[SwitchC-ipsec-profile-policy002-manual] sa string-key outbound esp simple gfedcba
[SwitchC-ipsec-profile-policy002-manual] sa string-key inbound esp simple gfedcba
[SwitchC-ipsec-profile-policy002-manual] quit
5.     Configure IPsec to protect IPv6 BGP packets between Switch A and Switch B:
[SwitchA] bgp 65008
[SwitchA-bgp] peer 1::2 ipsec-profile policy001
[SwitchA-bgp] quit
[SwitchB] bgp 65008
[SwitchB-bgp] peer 1::1 ipsec-profile policy001
[SwitchB-bgp] quit
6.     Configure IPsec to protect IPv6 BGP packets between Router B and Switch C:
[SwitchC] bgp 65009
[SwitchC-bgp] peer ebgp ipsec-profile policy002
[SwitchC-bgp] quit
[SwitchB] bgp 65008
[SwitchB-bgp] peer ebgp ipsec-profile policy002
[SwitchB-bgp] quit
# Display detailed information about IPv6 BGP peers on Switch B.
[SwitchB] display bgp peer ipv6 verbose
         Peer: 1::1      Local: 2.2.2.2
         Type: IBGP link
         BGP version 4, remote router ID 1.1.1.1
         BGP current state: Established, Up for 00h05m54s
         BGP last state: OpenConfirm
         Port:  Local - 24896    Remote - 179
         Configured: Active Hold Time: 180 sec   Keepalive Time: 60 sec
         Received  : Active Hold Time: 180 sec
         Negotiated: Active Hold Time: 180 sec   Keepalive Time: 60 sec
         Peer optional capabilities:
         Peer support BGP multi-protocol extended
         Peer support BGP route refresh capability
         Peer support BGP route AS4 capability
 Received: Total 9 messages, Update messages 1
 Sent: Total 9 messages, Update messages 1
 Threshold: 75%
 Minimum time between advertisements is 15 seconds
 Optional capabilities:
 Peer preferred value: 0
 IPsec profile name: policy001
 Routing policy configured:
         Peer: 3::2      Local: 2.2.2.2
         Type: EBGP link
         BGP version 4, remote router ID 3.3.3.3
         BGP current state: Established, Up for 00h05m00s
         Port:  Local - 24897    Remote - 179
 Received: Total 8 messages, Update messages 1
 Sent: Total 8 messages, Update messages 1
 Threshold: 75%
 IPsec profile name: policy002
The output shows that IBGP and EBGP peers are established and both sent and received IPv6 BGP packets are encapsulated by IPsec.
Troubleshooting BGP
Symptom
Display BGP peer information by using the display bgp peer ipv4 unicast or display bgp peer ipv6 unicast command. The state of the connection to a peer cannot become established.
Analysis
To become BGP peers, any two routers must establish a TCP connection using port 179 and exchange Open messages successfully.
Solution
1.     To resolve the problem:
a.     Use the display current-configuration command to verify the current configuration, and verify that the peer's AS number is correct.
b.     Use the display bgp peer ipv4 unicast or display bgp peer ipv6 unicast command to verify that the peer's IP address/IPv6 address is correct.
c.     If a loopback interface is used, verify that the loopback interface is specified with the peer connect-interface command.
d.     If the peer is a non-direct EBGP peer, verify that the peer ebgp-max-hop command is configured.
e.     Verify that a valid route to the peer is available.
f.     Use the ping command to verify the connectivity to the peer.
g.     Use the display tcp verbose or display ipv6 tcp verbose command to verify the TCP connection.
h.     Verify that no ACL rule is applied to disable TCP port 179.
2.     If the problem persists, contact H3C Support.
