02 IRF Configuration Guide
HomeSupportSwitchesS7500E-XS SeriesConfigure & DeployConfiguration GuidesH3C S7500E-XS Configuration Guides-R2418P05-6W10002 IRF Configuration Guide
Table of Contents
Related Documents
01-IRF configuration
01-IRF configuration 612.62 KB
Setting up an IRF fabric· 1
Overview·· 1
Network topology· 2
Basic concepts 2
Interface naming conventions 4
File system naming conventions 4
Configuration synchronization mechanism·· 6
Master election· 6
Multi-active handling procedure· 6
MAD mechanisms 7
Hardware compatibility· 12
General restrictions and configuration guidelines 12
Software requirements 12
IRF physical interface requirements 13
Connecting IRF ports 13
Feature compatibility and configuration restrictions 13
Licensing requirements 14
Configuration backup· 14
Setup and configuration task list 14
Planning the IRF fabric setup· 15
Assigning a member ID to each IRF member device· 16
Specifying a priority for each member device· 16
Connecting IRF physical interfaces 17
Binding physical interfaces to IRF ports 18
Accessing the IRF fabric· 20
Configuring a member device description· 20
Configuring IRF link load sharing mode· 20
Configuration restrictions and guidelines 20
Configuring the global load sharing mode· 21
Configuring a port-specific load sharing mode· 21
Configuring IRF bridge MAC persistence· 21
Enabling software auto-update for software image synchronization· 23
Configuration prerequisites 23
Configuration procedure· 23
Setting the IRF link down report delay· 24
Configuring MAD·· 24
Configuring LACP MAD·· 25
Configuring BFD MAD·· 26
Configuring ARP MAD·· 28
Configuring ND MAD·· 30
Excluding a port from the shutdown action upon detection of multi-active collision· 32
Recovering an IRF fabric· 32
Removing an expansion interface card that has IRF physical interfaces 33
Replacing an expansion interface card that has IRF physical interfaces 34
Displaying and maintaining an IRF fabric· 34
Configuration examples 35
LACP MAD-enabled IRF configuration example· 35
BFD MAD-enabled IRF configuration example· 39
ARP MAD-enabled IRF configuration example· 43
ND MAD-enabled IRF configuration example· 48
Overview
H3C Intelligent Resilient Framework (IRF) technology virtualizes multiple physical devices at the same layer into one virtual fabric to provide data center class availability and scalability. IRF virtualization technology offers processing power, interaction, unified management, and uninterrupted maintenance of multiple devices.
Figure 1 shows an IRF fabric that has two member devices, which appear as a single node to the upper-layer and lower-layer devices.
Figure 1 IRF application scenario
IRF provides the following benefits:
·     Simplified topology and easy management—An IRF fabric appears as one node and is accessible at a single IP address on the network. You can use this IP address to log in at any member device to manage all the members of the IRF fabric. In addition, you do not need to run the spanning tree feature among the IRF members.
·     1:N redundancy—In an IRF fabric, one member acts as the master to manage and control the entire IRF fabric. All the other members process services while backing up the master. When the master fails, all the other member devices elect a new master from among them to take over without interrupting services.
·     IRF link aggregation—You can assign several physical links between neighboring members to their IRF ports to create a load-balanced aggregate IRF connection with redundancy.
·     Multichassis link aggregation—You can use the Ethernet link aggregation feature to aggregate the physical links between the IRF fabric and its upstream or downstream devices across the IRF members.
·     Network scalability and resiliency—Processing capacity of an IRF fabric equals the total processing capacities of all the members. You can increase ports, network bandwidth, and processing capacity of an IRF fabric simply by adding member devices without changing the network topology.
Network topology
An IRF fabric can use a daisy-chain or ring topology. IRF does not support the full mesh topology. For information about connecting IRF member devices, see "Connecting IRF physical interfaces."
Basic concepts
IRF member roles
IRF uses two member roles: master and standby (called subordinate throughout the documentation).
When devices form an IRF fabric, they elect a master to manage and control the IRF fabric, and all the other devices back up the master. When the master device fails, the other devices automatically elect a new master. For more information about master election, see "Master election."
IRF member ID
An IRF fabric uses member IDs to uniquely identify and manage its members. This member ID information is included as the first part of interface numbers and file paths to uniquely identify interfaces and files in an IRF fabric. For more information about interface and file path naming, see "Interface naming conventions" and "File system naming conventions."
If two devices have the same IRF member ID, they cannot form an IRF fabric. If the IRF member ID of a device has been used in an IRF fabric, the device cannot join the fabric.
IRF port
An IRF port is a logical interface that connects IRF member devices. Every IRF-capable device supports two IRF ports. The IRF ports are named IRF-port n/1 and IRF-port n/2, where n is the member ID of the device. The two IRF ports are referred to as IRF-port 1 and IRF-port 2 in this book.
To use an IRF port, you must bind a minimum of one physical interface to it. The physical interfaces assigned to an IRF port automatically form an aggregate IRF link. An IRF port goes down only if all its IRF physical interfaces are down.
IRF physical interfaces connect IRF member devices and must be bound to an IRF port. They forward the IRF protocol packets between IRF member devices and the data packets that must travel across IRF member devices.
For more information about physical interfaces that can be used for IRF links, see "IRF physical interface requirements."
MAD
An IRF link failure causes an IRF fabric to split in two IRF fabrics operating with the same Layer 3 settings, including the same IP address. To avoid IP address collision and network problems, IRF uses multi-active detection (MAD) mechanisms to detect the presence of multiple identical IRF fabrics, handle collisions, and recover from faults.
IRF domain ID
One IRF fabric forms one IRF domain. IRF uses IRF domain IDs to uniquely identify IRF fabrics and prevent IRF fabrics from interfering with one another.
As shown in Figure 2, IRF fabric 1 contains Device A and Device B, and IRF fabric 2 contains Device C and Device D. Both fabrics use the LACP aggregate links between them for MAD. When a member device receives an extended LACPDU for MAD, it checks the domain ID to see whether the packet is from the local IRF fabric. Then, the device can handle the packet correctly.
Figure 2 A network that contains two IRF domains
IRF split
IRF split occurs when an IRF fabric breaks up into multiple IRF fabrics because of IRF link failures, as shown in Figure 3. The split IRF fabrics operate with the same IP address. IRF split causes routing and forwarding problems on the network. To quickly detect a multi-active collision, configure a minimum of one MAD mechanism (see "Configuring MAD").
Figure 3 IRF split
IRF merge
IRF merge occurs when two split IRF fabrics reunite or when two independent IRF fabrics are united, as shown in Figure 4.
Figure 4 IRF merge
Member priority
Member priority determines the possibility of a member device to be elected the master. A member with higher priority is more likely to be elected the master.
An interface is named in the chassis-number/slot-number/port-index format.
·     chassis-number—IRF member ID of the switch. This argument defaults to 1. The IRF member ID always takes effect, whether or not the device has formed an IRF fabric with other devices. If the device is alone, the device is considered to be a one-chassis IRF fabric.
·     slot-numberSlot number of the front panel or expansion interface card.
?     The front panel slot number is fixed at 0 for all S7500E-XS switches.
?     The expansion interface card slot numbers vary by device model.
-     On an S7502E-XS switch, the slot numbers are 1 and 2, from left to right, when you face the slots.
-     On an S7504E-XS switch, the slot numbers are 1 to 4, clockwise from the top left, when you face the slots.
·     port-index—Index of the port on the device. Port index depends on the number of ports available on the device. To identify the index of a port, examine its port index mark on the chassis.
For example:
·     On the single-chassis IRF fabric Sysname, FortyGigE 1/1/1 represents the first port on expansion interface card 1. Set its link type to trunk, as follows:
[Sysname] interface FortyGigE 1/1/1
[Sysname-FortyGigE1/1/1] port link-type trunk
·     On the multichassis IRF fabric Master, FortyGigE 3/1/1 represents the first port on expansion interface card 1 of member device 3. Set its link type to trunk, as follows:
<Master> system-view
[Master] interface FortyGigE 3/1/1
[Master-FortyGigE3/1/1] port link-type trunk
On a single-chassis fabric, you can use its storage device name to access its file system.
On a multichassis IRF fabric, you can use the storage device name to access the file system of the master. To access the file system of any other member device, use the name in the slotmember-ID#storage-device-name format.
For example:
To access the test folder under the root directory of the flash memory on the master device:
<Master> mkdir test
<Master> dir
Directory of flash:
   0 -rw-    43548660 Jan 01 2011 08:21:29   system.ipe
   1 drw-           - Jan 01 2011 00:00:30   diagfile
   2 -rw-         567 Jan 02 2011 01:41:54   dsakey
   3 -rw-         735 Jan 02 2011 01:42:03   hostkey
   4 -rw-          36 Jan 01 2011 00:07:52   ifindex.dat
   5 -rw-           0 Jan 01 2011 00:53:09   lauth.dat
   6 drw-           - Jan 01 2011 06:33:55   license
   7 drw-           - Jan 02 2000 00:00:07   logfile
   8 -rw-    23724032 Jan 01 2011 00:49:47   switch-cmw710-system.bin
   9 drw-           - Jan 01 2000 00:00:07   seclog
  10 -rw-         591 Jan 02 2011 01:42:03   serverkey
  11 -rw-        4609 Jan 01 2011 00:07:53   startup.cfg
  12 -rw-        3626 Jan 01 2011 01:51:56   startup.cfg_bak
  13 -rw-       78833 Jan 01 2011 00:07:53   startup.mdb
  14 drw-           - Jan 01 2011 00:15:48   test
  25 drw-           - Jan 01 2011 04:16:53   versionInfo
524288 KB total (365292 KB free)
To create and access the test folder under the root directory of the flash memory on member device 3:
<Master> mkdir slot3#flash:/test
Creating directory slot3#flash:/test... Done.
<Master> cd slot3#flash:/test
<Master> pwd
slot3#flash:/test
Or:
<Master> mkdir test
To copy the file test.ipe on the master to the root directory of the flash memory on member device 3:
# Display the current working path. In this example, the current working path is the root directory of the flash on member device 3.
<Master> pwd
slot3#flash:
# Change the current working path to the root directory of the flash memory on the master device.
<Master> cd flash:/
<Master> pwd
flash:
# Copy the file to member device 3.
<Master> copy test.ipe slot3#flash:/
Copy flash:/test.ipe to slot3#flash:/test.ipe?[Y/N]:y
Copying file flash:/test.ipe to slot3#flash:/test.ipe... Done.
For more information about storage device naming conventions, see Fundamentals Configuration Guide.
IRF uses a strict running-configuration synchronization mechanism. In an IRF fabric, all chassis get and run the running configuration of the master. Any configuration change is automatically propagated from the master to the other member devices. The configuration files of these devices are still retained, but these files do not take effect. The devices use their own startup configuration files only after they are removed from the IRF fabric.
For more information about configuration management, see Fundamentals Configuration Guide.
Master election
Master election occurs each time the IRF fabric topology changes in the following situations:
·     The IRF fabric is established.
·     The master device fails or is removed.
·     The IRF fabric splits.
·     Independent IRF fabrics merge.
Master election does not occur when two split IRF fabrics merge.
Master election selects a master in descending order:
1.     Current master, even if a new member has higher priority.
When an IRF fabric is being formed, all members consider themselves as the master. This rule is skipped.
2.     Member with higher priority. If all members have the same priority, this rule is skipped.
3.     Member with the longest system uptime.
Two members are considered to start up at the same time if the difference between their startup times is equal to or less than 10 minutes. For these members, the next tiebreaker applies.
4.     Member with the lowest CPU MAC address.
For the setup of a new IRF fabric, the subordinate devices must reboot to complete the setup after the master election.
For an IRF merge, devices must reboot if they are in the IRF fabric that fails the master election.
The multi-active handling procedure includes detection, collision handling, and failure recovery.
Detection
MAD identifies each IRF fabric with a domain ID and an active ID (the member ID of the master). If multiple active IDs are detected in a domain, MAD determines that an IRF collision or split has occurred.
For more information about the MAD mechanisms and their application scenarios, see "MAD mechanisms."
Collision handling
When MAD detects a multi-active collision, it sets all IRF fabrics except one to the Recovery state. The fabric that is not placed in Recovery state can continue to forward traffic. The Recovery-state IRF fabrics are inactive and cannot forward traffic.
LACP MAD uses the following process to handle a multi-active collision:
1.     Compares the number of members in each fabric.
2.     Sets all fabrics to the Recovery state except the one that has the most members.
3.     Compares the member IDs of the masters if all IRF fabrics have the same number of members.
4.     Sets all fabrics to the Recovery state except the one that has the lowest numbered master.
5.     Shuts down all physical network ports in the Recovery-state fabrics except for the following ports:
?     IRF physical interfaces.
?     Ports you have specified with the mad exclude interface command.
In contrast, BFD MAD, ARP MAD, and ND MAD do not compare the number of members in fabrics. These MAD mechanisms use the following process to hand a multi-active collision:
1.     Compare the member IDs of the masters in the IRF fabrics.
2.     Set all fabrics to the Recovery state except the one that has the lowest numbered master.
3.     Take the same action on the network ports in Recovery-state fabrics as LACP MAD.
Failure recovery
To merge two split IRF fabrics, first repair the failed IRF link and remove the IRF link failure.
·     If the IRF fabric in Recovery state fails before the failure is recovered, repair the failed IRF fabric and the failed IRF link.
·     If the active IRF fabric fails before the failure is recovered, enable the inactive IRF fabric to take over the active IRF fabric. Then, recover the MAD failure.
MAD mechanisms
IRF provides MAD mechanisms by extending LACP, BFD, ARP, and IPv6 ND.
IMPORTANT
IMPORTANT:
You can configure BFD MAD, ARP MAD, and ND MAD together in an IRF fabric for prompt IRF split detection. However, do not configure any of these mechanisms together with LACP MAD, because they handle collisions differently.
Table 1 compares the MAD mechanisms and their application scenarios.
Table 1 Comparison of MAD mechanisms
MAD mechanism
Advantages
Disadvantages
Application scenario
LACP MAD
·     Detection speed is fast.
·     Does not require MAD-dedicated physical links or Layer 3 interfaces.
Requires an intermediate device that supports extended LACP for MAD.
Link aggregation is used between the IRF fabric and its upstream or downstream device.
For information about LACP, see Layer 2—LAN Switching Configuration Guide.
BFD MAD
·     No intermediate device is required.
·     Intermediate device, if used, can come from any vendor.
·     Requires MAD dedicated physical links and Layer 3 interfaces, which cannot be used for transmitting user traffic.
·     If no intermediate device is used, any two IRF members must have a BFD MAD link to each other.
·     If an intermediate device is used, every IRF member must have a BFD MAD link to the intermediate device.
·     No special requirements for network scenarios.
·     If no intermediate device is used, this mechanism is only suitable for IRF fabrics that have a small number of members that are geographically close to one another.
For information about BFD, see High Availability Configuration Guide.
ARP MAD
·     Does not require MAD dedicated ports.
·     Detection speed is slower than BFD MAD and LACP MAD.
·     The spanning tree feature must be enabled if common Ethernet ports are used for ARP MAD links.
If common Ethernet ports are used, this MAD mechanism is applicable only to the spanning tree-enabled non-link aggregation IPv4 network scenario.
For information about ARP, see Layer 3—IP Services Configuration Guide.
ND MAD
·     The spanning tree feature must be enabled.
Spanning tree-enabled non-link aggregation IPv6 network scenario.
LACP MAD
As shown in Figure 5, LACP MAD has the following requirements:
·     Every IRF member must have a link with an intermediate device.
·     All the links form a dynamic link aggregation group.
·     The intermediate device must be a device that supports extended LACP for MAD.
The IRF member devices send extended LACPDUs that convey a domain ID and an active ID. The intermediate device transparently forwards the extended LACPDUs received from one member device to all the other member devices.
·     If the domain IDs and active IDs sent by all the member devices are the same, the IRF fabric is integrated.
·     If the extended LACPDUs convey the same domain ID but different active IDs, a split has occurred. LACP MAD handles this situation as described in "Collision handling."
Figure 5 LACP MAD scenario
BFD MAD
You can use common or management Ethernet ports for BFD MAD links.
·     If management Ethernet ports are used, BFD MAD has the following requirements:
?     Each IRF member device has a BFD MAD link to an intermediate device.
?     Each member device is assigned a MAD IP address on the master's management Ethernet port.
·     If common Ethernet ports are used, BFD MAD has the following requirements:
?     Each member device has a BFD MAD link to an intermediate device, or all member devices have a BFD MAD link to each other.
?     Each member device is assigned a MAD IP address on a VLAN interface.
The BFD MAD links must be dedicated. Do not use BFD MAD links for any other purposes.
·     The MAD addresses identify the member devices and must belong to the same subnet.
·     Of all management Ethernet ports on an IRF fabric, only the master's management Ethernet port is accessible.
Figure 6 shows a typical BFD MAD scenario that uses an intermediate device. Figure 7 shows a typical BFD MAD scenario that does not use an intermediate device.
With BFD MAD, the master tries to establish BFD sessions with other member devices by using its MAD IP address as the source IP address.
·     If the IRF fabric is integrated, only the MAD IP address of the master is effective. The master cannot establish a BFD session with any other member. If you execute the display bfd session command, the state of the BFD sessions is Down.
·     When the IRF fabric splits, the IP addresses of the masters in the split IRF fabrics take effect. The masters can establish a BFD session. If you execute the display bfd session command, the state of the BFD session between the two devices is Up.
Figure 6 BFD MAD scenario with intermediate device
Figure 7 BFD MAD scenario without intermediate device
ARP MAD
ARP MAD detects multi-active collisions by using extended ARP packets that convey the IRF domain ID and the active ID.
You can use common or management Ethernet ports for ARP MAD.
·     If management Ethernet ports are used, ARP MAD must work with an intermediate device. Make sure the following requirements are met:
?     Connect the management Ethernet port on each member device to the intermediate device.
?     On the intermediate device, you must assign the ports used for ARP MAD to the same VLAN.
·     If common Ethernet ports are used, ARP MAD can work with or without an intermediate device. Make sure the following requirements are met:
?     If an intermediate device is used, connect each IRF member device to the intermediate device. Run the spanning tree feature between the IRF fabric and the intermediate device. In this situation, data links can be used.
?     If an intermediate device is not used, connect each IRF member device to all other member devices. In this situation, IRF links cannot be used for ARP MAD.
Figure 8 shows a typical ARP MAD scenario that uses an intermediate device.
Each IRF member compares the domain ID and the active ID in incoming extended ARP packets with its domain ID and active ID.
·     If the domain IDs are different, the extended ARP packet is from a different IRF fabric. The device does not continue to process the packet with the MAD mechanism.
·     If the domain IDs are the same, the device compares the active IDs.
?     If the active IDs are different, the IRF fabric has split.
?     If the active IDs are the same, the IRF fabric is integrated.
Figure 8 ARP MAD scenario
ND MAD
ND MAD detects multi-active collisions by using NS packets to transmit the IRF domain ID and the active ID.
You can set up ND MAD links between neighbor IRF member devices, or between each IRF member device and an intermediate device (see Figure 9). If an intermediate device is used, you must also run the spanning tree protocol between the IRF fabric and the intermediate device.
Each IRF member device compares the domain ID and the active ID in incoming NS packets with its domain ID and active ID.
·     If the domain IDs are different, the NS packet is from a different IRF fabric. The device does not continue to process the packet with the MAD mechanism.
Figure 9 ND MAD scenario
An H3C S7500E-XS switch can form an IRF fabric only with devices in the same series.
For a successful IRF setup, follow the restrictions and guidelines in this section and the setup procedure in "Setup and configuration task list."
All IRF member devices must run the same software image version. Make sure the software auto-update feature is enabled on all member devices.
Candidate IRF physical interfaces
Use 10-GE, SFP+, and QSFP+ ports for IRF links.
Selecting transceiver modules and cables
When you select transceiver modules and cables, follow these restrictions and guidelines:
·     Use Category 6A (or above) twisted-pair cables to connect 10-GE ports in a short distance.
·     Use SFP+ or QSFP+ DAC cables to connect SFP+ or QSFP+ ports in a short distance.
·     Use SFP+ or QSFP+ transceiver modules and fibers to connect SFP+ or QSFP+ ports in a long distance.
·     The transceiver modules at the two ends of an IRF link must be the same type.
For more information about available SFP+ and QSFP+ ports, cables, and transceiver modules, see the switch installation guide. For a detailed description of the SFP+ and QSFP+ transceiver modules, see H3C Low End Series Ethernet Switches Pluggable Modules Manual.
The modules and DAC cables available for IRF links are subject to change over time. For the most up-to-date list of modules and DAC cables for IRF links, contact your H3C sales representative.
When you connect two neighboring IRF members, connect the physical interfaces of IRF-port 1 on one member to the physical interfaces of IRF-port 2 on the other.
Make sure the feature settings in Table 2 are the same across member devices.
Table 2 IRF and feature compatibility
Feature
Remarks
Enhanced ECMP mode
ecmp mode enhanced
See Layer 3—IP Routing Configuration Guide.
Maximum number of ECMP routes
max-ecmp-num
Table capacity mode
switch-mode
See Fundamentals Configuration Guide.
Support for the IPv6 routes with prefixes longer than 64 bits
switch-routing-mode ipv6-128
System operating mode
system-working-mode
For a license-based feature to run correctly on an IRF fabric, make sure the licenses installed for the feature on all member devices are the same. For more information about feature licensing, see Fundamentals Configuration Guide.
H3C recommends that you back up the next-startup configuration file on a device before adding the device to an IRF fabric as a subordinate.
A subordinate device's next-startup configuration file might be overwritten if the master and the subordinate use the same file name for their next-startup configuration files. You can use the backup file to restore the original configuration after removing the subordinate from the IRF fabric.
H3C recommends the basic IRF setup procedure in Figure 10. Perform the tasks in this figure on each member device.
Figure 10 Basic IRF setup flow chart
To set up an IRF fabric, perform the following tasks:
Tasks at a glance
Remarks
1.     (Required.) Planning the IRF fabric setup
N/A
2.     (Required.) Assigning a member ID to each IRF member device
Perform this task on each member device.
3.     (Required.) Specifying a priority for each member device
4.     (Optional.) Installing expansion interface cards
This task is beyond the scope of this document. For information about installing expansion interface cards, see the switch installation guide.
5.     (Required.) Connecting IRF physical interfaces
N/A
6.     (Required.) Binding physical interfaces to IRF ports
When you complete IRF port binding and activation on all IRF member devices, the IRF fabric is formed.
7.     (Required.) Accessing the IRF fabric
When you log in to the IRF fabric, you are placed at the master's CLI, where you complete subsequent IRF settings and configure other features for the member devices as if they were one device.
8.     (Optional.) Configuring a member device description
N/A
9.     (Optional.) Configuring IRF link load sharing mode:
? Configuring the global load sharing mode
? Configuring a port-specific load sharing mode
N/A
10.     (Optional.) Configuring IRF bridge MAC persistence
N/A
11.     (Optional.) Enabling software auto-update for software image synchronization
H3C recommends enabling software auto-update to ensure system software image synchronization.
12.     (Optional.) Setting the IRF link down report delay
N/A
13.     (Required.) Configuring MAD:
? Configuring LACP MAD
? Configuring BFD MAD
? Configuring ARP MAD
? Configuring ND MAD
? Excluding a port from the shutdown action upon detection of multi-active collision
MAD mechanisms are independent of one another. You can configure multiple MAD mechanisms for an IRF fabric.
14.     (Optional.) Maintaining an IRF fabric:
? Recovering an IRF fabric
? Removing an expansion interface card that has IRF physical interfaces
? Replacing an expansion interface card that has IRF physical interfaces
N/A
Consider the following items when you plan an IRF fabric:
·     Hardware compatibility and restrictions.
·     IRF fabric size.
·     Master device.
·     IRF physical interfaces.
·     Member ID and priority assignment scheme.
·     Fabric topology and cabling scheme.
For more information about hardware and cabling, see the switch installation guide.
CAUTION
CAUTION:
In an IRF fabric, changing IRF member IDs might cause undesirable configuration changes and even data loss. Before you do that, back up the configuration and make sure you fully understand the impact on your network. For example, all member devices in an IRF fabric are the same model. If you swapped the IDs of any two members, their interface settings would also be swapped.
To create an IRF fabric, you must assign a unique IRF member ID to each member device.
To prevent any undesirable configuration change or data loss, avoid changing member IDs after the IRF fabric is formed.
The new member ID takes effect at a reboot. After the device reboots, the settings on all member ID-related physical resources (including common physical network ports) are removed, regardless of whether you have saved the configuration.
To assign a member ID to a device:
Step
Remarks
N/A
2.     Assign a member ID to a member device.
irf member member-id renumber new-member-id
The default IRF member ID is 1.
3.     (Optional.) Save the configuration.
save
If you have bound physical interfaces to IRF ports or assigned member priority, save the configuration before rebooting the device so these settings can continue to take effect after the reboot.
4.     Reboot the device.
N/A
IRF member priority represents the possibility for a device to be elected the master in an IRF fabric. The higher the priority, the higher the possibility.
A change to member priority affects the election result at the next master election. However, it does not cause an immediate master re-election.
To specify a priority for a member device:
Step
Remarks
N/A
2.     Specify a priority for the device.
irf member member-id priority priority
The default IRF member priority is 1.
When you connect two neighboring IRF members, connect the physical interfaces of IRF-port 1 on one member to the physical interfaces of IRF-port 2 on the other (see Figure 11).
For example, you have four chassis: A, B, C, and D. IRF-port 1 and IRF-port 2 are represented by A1 and A2 on chassis A, represented by B1 and B2 on chassis B, and so on. To connect the four chassis into a ring topology of A-B-C-D(A), the IRF link cabling scheme must be one of the following:
·     A1-B2, B1-C2, C1-D2, and D1-A2.
·     A2-B1, B2-C1, C2-D1, and D2-A1.
IMPORTANT
IMPORTANT:
No intermediate devices are allowed between neighboring members.
Figure 11 Connecting IRF physical interfaces
Connect the devices into a daisy-chain topology or a ring topology. A ring topology is more reliable (see Figure 12). In ring topology, the failure of one IRF link does not cause the IRF fabric to split as in daisy-chain topology. Rather, the IRF fabric changes to a daisy-chain topology without interrupting network services.
Figure 12 Daisy-chain topology vs. ring topology
When you bind physical interfaces to IRF ports, follow these guidelines:
·     Follow the restrictions in "IRF physical interface requirements."
·     You must always shut down a physical interface before binding it to an IRF port or removing the binding. Start the shutdown operation on the master, and then the member device that has the fewest number of hops from the master.
On a physical interface bound to an IRF port, you can execute only the following commands:
Command category
Commands
Remarks
Basic Ethernet interface commands
·     description
·     flow-interval
·     shutdown
See Layer 2—LAN Switching Configuration Guide.
LLDP commands
·     lldp admin-status
·     lldp check-change-interval
·     lldp enable
·     lldp encapsulation snap
·     lldp notification remote-change enable
·     lldp tlv-enable
To bind physical interfaces to IRF ports:
Step
Remarks
N/A
2.     Enter interface view or interface range view.
·     Enter interface range view:
interface range { interface-type interface-number [ to interface-type interface-number ] } &<1-24>
·     Enter interface view:
To shut down a range of IRF physical interfaces, enter interface range view.
To shut down one IRF physical interface, enter its interface view.
3.     Shut down the interface or the range of interfaces.
shutdown
By default, all interfaces are up.
4.     Return to system view.
N/A
5.     Enter IRF port view.
irf-port member-id/port-number
N/A
6.     Bind each physical interface to the IRF port.
port group interface interface-type interface-number
By default, no physical interfaces are bound to any IRF port.
Repeat this step to assign multiple physical interfaces to the IRF port for link redundancy.
You can bind up to four physical interfaces to an IRF port.
7.     Return to system view.
N/A
8.     Enter interface view or interface range view.
N/A
9.     Bring up the interface or the range of interfaces.
N/A
10.     Return to system view.
N/A
11.     Save the configuration.
save
Activating IRF port settings causes IRF merge and reboot. To avoid data loss, save the running configuration to the startup configuration file before you perform the operation.
12.     Activate the IRF port settings.
irf-port-configuration active
After this step is performed, the state of the IRF port changes to UP, the member devices elect a master automatically, and the subordinate device reboots automatically.
After the IRF fabric is formed, you can add additional physical interfaces to an IRF port (in UP state) without repeating this step.
The IRF fabric appears as one device after it is formed. You configure and manage all IRF members at the CLI of the master. All settings you have made are automatically propagated to the IRF members.
The following methods are available for accessing an IRF fabric:
·     Local login—Log in through the console port of any member device.
·     Remote login—Log in at a Layer 3 interface on any member device by using methods including Telnet and SNMP.
When you log in to an IRF fabric, you are placed at the CLI of the master, regardless of at which member device you are logged in.
For more information, see login configuration in Fundamentals Configuration Guide.
Step
Remarks
N/A
2.     Configure a description for a member device.
irf member member-id description text
By default, no member device description is configured.
An IRF port distributes traffic across its physical links.
By default, traffic is distributed automatically based on packet types, including Layer 2, IPv4, and IPv6. You can configure the IRF port to distribute traffic based on criteria including IP addresses, MAC addresses, and the combination of IP and MAC addresses. If the device does not support a criterion combination, the system displays an error message.
Configure the IRF link load sharing mode for IRF links in system view or IRF port view:
·     In system view, the configuration is global and takes effect on all IRF ports.
·     In IRF port view, the configuration is port specific and takes effect only on the specified IRF port.
An IRF port preferentially uses the port-specific load sharing mode. If no port-specific load sharing mode is available, the IRF port uses the global load sharing mode.
The IRF link load sharing mode takes effect on all types of packets, including unicast, multicast, and broadcast.
To distribute traffic based on TCP/UDP ports, use one of the following methods:
·     Use the default setting for both global and port-specific IRF link load sharing modes.
·     Set the IRF link load sharing mode and the global load sharing mode for Ethernet link aggregation as follows:
?     Set the IRF link load sharing mode to distribute traffic based on source IP, destination IP, or both source and destination IP addresses. The command syntax is irf-port load-sharing mode { destination-ip | source-ip } *.
?     Set the global load sharing mode for Ethernet link aggregation to distribute traffic based on source service port, destination service port, or both source and destination service ports. The command syntax is link-aggregation global load-sharing mode { destination-port | source-port } *. For more information about Ethernet link aggregation load sharing, see Layer 2—LAN Switching Configuration Guide.
Step
Remarks
N/A
2.     Configure the global IRF link load sharing mode.
irf-port global load-sharing mode { destination-ip | destination-mac | source-ip | source-mac } *
By default, packets are distributed automatically across IRF member links based on packet types.
Before you configure a port-specific load sharing mode, make sure you have bound a minimum of one physical interface to the IRF port.
To configure a port-specific load sharing mode for an IRF port:
Step
Remarks
N/A
2.     Enter IRF port view.
N/A
3.     Configure the port-specific load sharing mode.
irf-port load-sharing mode { destination-ip | destination-mac | source-ip | source-mac } *
By default, the global IRF link load sharing mode applies.
By default, an IRF fabric uses the bridge MAC address of the master device as its bridge MAC address. Layer 2 protocols, such as LACP, use this bridge MAC address to identify the IRF fabric. On a switched LAN, the bridge MAC address must be unique.
To avoid duplicate bridge MAC addresses, an IRF fabric can change its bridge MAC address automatically after its bridge MAC owner leaves. However, the change causes temporary traffic disruption.
Depending on the network condition, enable the IRF fabric to preserve or change its bridge MAC address after the address owner leaves. Available options include:
·     irf mac-address persistent timerBridge MAC address of the IRF fabric remains unchanged for 6 minutes after the address owner leaves. If the owner does not return before the timer expires, the IRF fabric uses the bridge MAC address of the current master as its bridge MAC address. This option avoids unnecessary bridge MAC address changes caused by device reboot, transient link failure, or purposeful link disconnection.
·     irf mac-address persistent alwaysBridge MAC address of the IRF fabric does not change after the address owner leaves.
IRF fabrics that have the same bridge MAC address cannot merge. If you use the removed bridge MAC owner as the master device in a new fabric, the bridge MAC of the new fabric is the same as the old fabric. For the two IRF fabrics to merge, you must change the bridge MAC address of the old IRF fabric.
·     undo irf mac-address persistent—Bridge MAC address of the current master replaces the original one as soon as the owner of the original bridge MAC leaves.
When you configure IRF bridge MAC persistence, follow these guidelines:
·     If ARP MAD or ND MAD is used, configure the undo irf mac-address persistent command to enable immediate bridge MAC address change after the address owner leaves.
·     Configure the irf mac-address persistent always command in the following situations:
?     TRILL is configured. The persistence setting ensures that other devices in the TRILL network can maintain correct network topology after the address owner leaves.
?     The IRF fabric uses a daisy-chain topology, and it has aggregate links with upstream or downstream devices. The persistence setting prevents transmission delay or packet loss after the address owner leaves.
To configure the IRF bridge MAC persistence setting:
Step
Remarks
N/A
2.     Configure IRF bridge MAC persistence.
·     Retain the bridge MAC address permanently even if the owner has left the IRF fabric:
·     Retain the bridge MAC address for 6 minutes after the owner leaves the fabric:
·     Change the bridge MAC address as soon as the owner leaves the fabric:
By default, the IRF bridge MAC address remains unchanged for 6 minutes after the address owner leaves the fabric.
IMPORTANT
IMPORTANT:
To ensure a successful software auto-update in a multi-user environment, prevent anyone from rebooting member devices during the auto-update process. To inform administrators of the auto-update status, configure the information center to output the status messages to configuration terminals (see Network Management and Monitoring Configuration Guide).
The software auto-update feature synchronizes the current software images of the master in an IRF fabric to all its members automatically.
To join an IRF fabric, a device must use the same software images as the master in the fabric.
When you add a device to the IRF fabric, software auto-update compares the startup software images of the device with the current software images of the IRF master. If the two sets of images are different, the device automatically performs the following operations:
1.     Downloads the current software images of the master.
2.     Sets the downloaded images as main startup software images.
3.     Reboots with the new software images to rejoin the IRF fabric.
You must manually update the new device with the software images running on the IRF fabric in the following situations:
·     Software auto-update is disabled.
·     Software auto-update fails to update software. This situation might occur if the IRF fabric cannot identify the software version used on the new device.
Make sure the device you are adding to the IRF fabric has sufficient storage space for the new software images.
If sufficient storage space is not available, the device automatically deletes the current software images. If the reclaimed space is still insufficient, the device cannot complete the auto-update. You must reboot the device, and then access the Boot menus to delete files.
To enable software image synchronization:
Step
Remarks
N/A
2.     Enable software auto-update.
irf auto-update enable
By default, software auto-update is enabled.
To prevent frequent IRF splits and merges during link flapping, configure the IRF ports to delay reporting link down events.
An IRF port does not report a link down event to the IRF fabric immediately after its link changes from up to down. If the IRF link state is still down when the delay is reached, the port reports the change to the IRF fabric.
IRF ports do not delay link up events. They report the link up event immediately after the IRF link comes up.
When you configure the IRF link down report delay, follow these restrictions and guidelines:
·     Make sure the IRF link down report delay is shorter than the heartbeat or hello timeout settings of upper-layer protocols (for example, CFD, VRRP, and OSPF). If the report delay is longer than the timeout setting of a protocol, unnecessary recalculations might occur.
·     Set the delay to 0 seconds in the following situations:
?     The IRF fabric requires a fast master/subordinate or IRF link switchover.
?     The BFD or GR feature is used.
?     You want to shut down an IRF physical interface or reboot an IRF member device. (After you complete the operation, reconfigure the delay depending on the network condition.)
To set the IRF link down report delay:
Step
Remarks
N/A
2.     Set the IRF link down report delay.
irf link-delay interval
The default IRF link down report delay is 4 seconds.
Configuring MAD
When you configure MAD, follow these restrictions and guidelines:
·     You can configure BFD MAD, ARP MAD, and ND MAD together in an IRF fabric for prompt IRF split detection. However, do not configure any of these mechanisms together with LACP MAD, because they handle collisions differently.
·     If LACP MAD, ARP MAD, or ND MAD runs between two IRF fabrics, assign each fabric a unique IRF domain ID. (For BFD MAD, this task is optional.)
·     An IRF fabric has only one IRF domain ID. You can change the IRF domain ID by using the following commands: irf domain, mad enable, mad arp enable, or mad nd enable. The IRF domain IDs configured by using these commands overwrite each other.
·     To prevent a port from being shut down when the IRF fabric transits to the Recovery state, use the mad exclude interface command. To bring up ports in a Recovery-state IRF fabric, use the mad restore command instead of the undo shutdown command. The mad restore command activates the Recovery-state IRF fabric.
When you use LACP MAD, follow these restrictions and guidelines:
·     If the intermediate device is also an IRF fabric, assign the two IRF fabrics different domain IDs for correct split detection.
·     Use dynamic link aggregation mode. MAD is LACP dependent. Even though LACP MAD can be configured on both static and dynamic aggregate interfaces, it takes effect only on dynamic aggregate interfaces.
·     Configure link aggregation settings on the intermediate device.
To configure LACP MAD:
Step
Remarks
N/A
2.     Assign a domain ID to the IRF fabric.
irf domain domain-id
The default IRF domain ID is 0.
3.     Create an aggregate interface and enter aggregate interface view.
·     Enter Layer 2 aggregate interface view:
·     Enter Layer 3 aggregate interface view:
Perform this step also on the intermediate device.
4.     Configure the aggregation group to operate in dynamic aggregation mode.
link-aggregation mode dynamic
By default, an aggregation group operates in static aggregation mode.
5.     Enable LACP MAD.
mad enable
By default, LACP MAD is disabled.
6.     Return to system view.
N/A
7.     Enter Ethernet interface view or interface range view.
·     Enter Ethernet interface view:
To assign a range of ports to the aggregation group, enter interface range view.
To assign one port to the aggregation group, enter Ethernet interface view.
8.     Assign the Ethernet port or the range of Ethernet ports to the specified aggregation group.
port link-aggregation group number
Multichassis link aggregation is allowed.
Also perform this step on the intermediate device.
Configuring BFD MAD
Before you configure BFD MAD, choose a BFD MAD link scheme as described in "BFD MAD."
H3C recommends that you connect the BFD MAD links after you finish the BFD MAD configuration.
Configuring BFD MAD that uses common Ethernet ports
Configure BFD MAD on a VLAN interface if you use common Ethernet ports for BFD MAD.
When you configure BFD MAD settings, follow these restrictions and guidelines:
Category
BFD MAD VLAN
·     Do not enable BFD MAD on VLAN-interface 1.
·     If you are using an intermediate device, perform the following tasks both on the IRF fabric and the intermediate device:
? Create a VLAN and VLAN interface for BFD MAD.
? Assign the ports of BFD MAD links to the BFD MAD VLAN.
·     Make sure the IRF fabrics on the network use different BFD MAD VLANs.
·     Make sure the BFD MAD VLAN contains only ports on the BFD MAD links. Exclude a port from the BFD MAD VLAN if the port is not on the BFD MAD link. For example, if you have assigned the port to all VLANs by using the port trunk permit vlan all command, use the undo port trunk permit command to exclude the port from the BFD MAD VLAN.
BFD MAD VLAN and feature compatibility
Do not use the BFD MAD VLAN for any purpose other than configuring BFD MAD.
·     Configure only the mad bfd enable and mad ip address commands on the VLAN interface used for BFD MAD. If you configure other features, both BFD MAD and other features on the interface might run incorrectly.
·     Disable the spanning tree feature on all Layer 2 Ethernet ports in the BFD MAD VLAN. The MAD feature is mutually exclusive with the spanning tree feature.
MAD IP address
·     Use the mad ip address command instead of the ip address command to configure MAD IP addresses on the BFD MAD-enabled VLAN interface.
·     Make sure all the MAD IP addresses are on the same subnet.
To configure BFD MAD that uses common Ethernet ports:
Step
Remarks
N/A
2.     (Optional.) Assign a domain ID to the IRF fabric.
By default, the domain ID of an IRF fabric is 0.
3.     Create a VLAN dedicated to BFD MAD.
vlan vlan-id
The default VLAN on the device is VLAN 1.
N/A
5.     Enter interface view or interface range view.
To assign a range of ports to the BFD MAD VLAN, enter interface range view.
To assign one port to the BFD MAD VLAN, enter Ethernet interface view.
6.     Assign the port or the range of ports to the BFD MAD VLAN.
·     Assign the port to the VLAN as an access port:
port access vlan vlan-id
·     Assign the port to the VLAN as a trunk port:
vlan-id
·     Assign the port to the VLAN as a hybrid port:
port hybrid vlan
vlan-id { tagged | untagged }
The link type of BFD MAD ports can be access, trunk, or hybrid.
The default link type of a port is access.
N/A
8.     Create the VLAN interface and enter VLAN interface view.
interface vlan-interface vlan-interface-id
N/A
9.     Enable BFD MAD.
mad bfd enable
By default, BFD MAD is disabled.
10.     Assign a MAD IP address to a member device on the VLAN interface.
mad ip address ip-address { mask | mask-length } member member-id
By default, no MAD IP addresses are configured on any VLAN interfaces.
Repeat this step to assign a MAD IP address to each member device on the VLAN interface.
Configuring BFD MAD that uses management Ethernet ports
When you configure BFD MAD that uses management Ethernet ports, follow these restrictions and guidelines:
Category
Ports on the intermediate device for BFD MAD
Use common Ethernet ports on the intermediate device to connect the management Ethernet ports on the IRF fabric.
BFD MAD VLAN
·     On the intermediate device, create a VLAN for BFD MAD, and assign the ports used for BFD MAD to the VLAN. On the IRF fabric, you do not need to assign the management Ethernet ports to the VLAN.
·     Make sure the BFD MAD VLAN on the intermediate device contains only ports on the BFD MAD links. Exclude a port from the BFD MAD VLAN if the port is not on the BFD MAD link. For example, if you have assigned the port to all VLANs by using the port trunk permit vlan all command, use the undo port trunk permit command to exclude the port from the BFD MAD VLAN.
MAD IP address
·     Use the mad ip address command instead of the ip address command to configure MAD IP addresses on the BFD MAD-enabled management Ethernet ports.
To configure BFD MAD that uses management Ethernet ports:
Step
Remarks
N/A
3.     Enter management Ethernet interface view.
interface m-gigabitethernet interface-number
4.     Enable BFD MAD.
mad bfd enable
5.     Assign a MAD IP address to each member device.
By default, no MAD IP addresses are configured.
Configuring ARP MAD
Before you configure ARP MAD, choose an ARP MAD link scheme as described in "ARP MAD."
If you are not using existing data links as ARP MAD links, H3C recommends that you connect the ARP MAD links after you finish the ARP MAD configuration.
Configuring ARP MAD that uses common Ethernet ports
Configure ARP MAD on a VLAN interface if you use common Ethernet ports for ARP MAD.
When you configure ARP MAD that uses common Ethernet ports, follow these restrictions and guidelines:
Category
ARP MAD VLAN
·     Do not enable ARP MAD on VLAN-interface 1.
? Create a VLAN and VLAN interface for ARP MAD.
? Assign the ports of ARP MAD links to the ARP MAD VLAN.
·     Do not use the ARP MAD VLAN for any other purposes.
ARP MAD and feature configuration
If an intermediate device is used, make sure the following requirements are met:
·     Run the spanning tree feature between the IRF fabric and the intermediate device to ensure that there is only one ARP MAD link in forwarding state. For more information about the spanning tree feature and its configuration, see Layer 2—LAN Switching Configuration Guide.
·     Enable the IRF fabric to change its bridge MAC address as soon as the address owner leaves.
To configure ARP MAD that uses common Ethernet ports:
Step
Remarks
N/A
3.     Configure the IRF bridge MAC address to change as soon as the address owner leaves.
By default, the IRF bridge MAC address remains unchanged for 6 minutes after the address owner leaves.
4.     Create a VLAN dedicated to ARP MAD.
vlan vlan-id
5.     Return to system view.
N/A
6.     Enter Ethernet interface view.
N/A
7.     Assign the port to the ARP MAD VLAN.
vlan-id
port hybrid vlan
The link type of ARP MAD ports can be access, trunk, or hybrid.
8.     Return to system view.
N/A
9.     Create the VLAN interface and enter VLAN interface view.
N/A
10.     Assign the interface an IP address.
By default, no IP addresses are assigned to any VLAN interfaces.
11.     Enable ARP MAD.
mad arp enable
By default, ARP MAD is disabled.
Configuring ARP MAD that uses management Ethernet ports
When you configure ARP MAD that uses management Ethernet ports, follow these restrictions and guidelines:
Category
Ports on the intermediate device for ARP MAD
ARP MAD VLAN
On the intermediate device, create a VLAN for ARP MAD, and assign the ports used for ARP MAD to the VLAN. On the IRF fabric, you do not need to assign the management Ethernet ports to the VLAN.
To configure ARP MAD that uses management Ethernet ports:
Step
Remarks
N/A
4.     Enter management Ethernet interface view.
5.     Assign an IP address to the management Ethernet ports.
By default, no IP addresses are configured.
6.     Enable ARP MAD.
mad arp enable
Configuring ND MAD
ND MAD can use only common Ethernet ports.
When you use ND MAD, follow these restrictions and guidelines:
·     Do not configure ND MAD on VLAN-interface 1.
·     Do not use the VLAN configured for ND MAD for any other purposes.
·     If an intermediate device is used, you can use data links as ND MAD links. If no intermediate device is used, set up dedicated ND MAD links between IRF member devices.
·     If an intermediate device is used, make sure the following requirements are met:
?     Run the spanning tree feature between the IRF fabric and the intermediate device. Make sure there is only one ND MAD link in forwarding state. For more information about the spanning tree feature and its configuration, see Layer 2—LAN Switching Configuration Guide.
?     Enable the IRF fabric to change its bridge MAC address as soon as the address owner leaves.
?     Create an ND MAD VLAN and assign the ports on the ND MAD links to the VLAN.
?     If the intermediate device is also an IRF fabric, assign the two IRF fabrics different domain IDs for correct split detection.
To configure ND MAD:
Step
Remarks
N/A
4.     Create a VLAN dedicated to ND MAD.
vlan vlan-id
N/A
N/A
7.     Assign the port to the ND MAD VLAN.
vlan-id
port hybrid vlan
The link type of ND MAD ports can be access, trunk, or hybrid.
N/A
N/A
ipv6 address { ipv6-address/pre-length | ipv6 address pre-length }
By default, no IPv6 addresses are assigned to any VLAN interfaces.
11.     Enable ND MAD.
mad nd enable
By default, ND MAD is disabled.
CAUTION
CAUTION:
Do not exclude a VLAN interface and its Layer 2 ports from the shutdown action if the Layer 2 ports are distributed on multiple member devices. The exclusion introduces IP collision risks because the VLAN interface might be up on both active and inactive IRF fabrics.
By default, all ports (except the console and IRF physical interfaces) shut down automatically when the IRF fabric transits to the Recovery state.
You can exclude a network port from the shutdown action for management or other special purposes. For example:
·     Exclude a port from the shutdown action so you can Telnet to the port for managing the device.
·     Exclude a VLAN interface and its Layer 2 ports from the shutdown action so you can log in through the VLAN interface.
To configure a port to not shut down when the IRF fabric transits to the Recovery state:
Step
Remarks
N/A
2.     Configure a network port to not shut down when the IRF fabric transits to the Recovery state.
mad exclude interface interface-type interface-number
By default, all network ports on a Recovery-state IRF fabric are shut down, except for the IRF physical interfaces and console port.
When the failed IRF link between two split IRF fabrics is recovered, all member devices in the inactive IRF fabric automatically join the active IRF fabric as subordinate members. The network ports that have been shut down by MAD automatically restore their original physical state, as shown in Figure 13.
Figure 13 Recovering the IRF fabric
If the active IRF fabric fails before the IRF link is recovered (see Figure 14), use the mad restore command on the inactive IRF fabric to recover the inactive IRF fabric. The command also brings up all network ports that were shut down by MAD. After you repair the IRF link, the two parts merge into a unified IRF fabric.
Figure 14 Active IRF fabric fails before the IRF link is recovered
To manually recover an inactive IRF fabric:
Step
2.     Recover the inactive IRF fabric.
mad restore
After the IRF fabric is recovered, all ports that have been shut down by MAD come up automatically.
To remove an expansion interface card that provides IRF physical interfaces:
1.     Perform one of the following tasks to eliminate temporary packet loss:
?     Remove cables from the IRF physical interfaces on the card.
?     Shut down the IRF physical interfaces on the card by using the shutdown command.
2.     Remove the card.
To replace the old card with a different model replacement card:
1.     Shut down the IRF physical interfaces on the old card by using the shutdown command.
2.     Remove the IRF port bindings that contain the physical interfaces.
3.     Remove the old card, and then install the replacement card.
4.     Verify that the replacement card has been correctly installed by using the display device command.
5.     Reconfigure the IRF port bindings, as described in "Binding physical interfaces to IRF ports."
6.     Activate the IRF port settings by using the irf-port-configuration active command.
You may skip this step if the the IRF port is in UP state when you add bindings.
To replace the old card with the same model replacement card:
2.     Remove the old card, and then install the replacement card.
3.     Verify that the replacement card has been correctly installed by using the display device command.
4.     Bring up the physical interfaces by using the undo shutdown command after the interface card completes startup.
Display information about all IRF members.
display irf
Display the IRF fabric topology.
display irf topology
Display IRF link information.
display irf link
Display IRF configuration.
display irf configuration
Display the load sharing mode for IRF links.
display irf-port load-sharing mode [ irf-port [ member-id/port-number ] ]
Display MAD configuration.
display mad [ verbose ]
This section provides IRF configuration examples for IRF fabrics that use different MAD mechanisms.
Network requirements
As shown in Figure 15, set up a four-chassis IRF fabric at the access layer of the enterprise network.
Configure LACP MAD on the multichassis aggregation to Device E, an H3C device that supports extended LACP.
Figure 15 Network diagram
1.     Configure Device A:
# Shut down the physical interfaces used for IRF links. This example uses FortyGigE 1/1/1 to FortyGigE 1/1/4 for IRF links.
[Sysname] interface range FortyGigE 1/1/1 to FortyGigE 1/1/4
[Sysname-if-range] shutdown
[Sysname-if-range] quit
# Bind FortyGigE 1/1/1 and FortyGigE 1/1/2 to IRF-port 1/1.
[Sysname] irf-port 1/1
[Sysname-irf-port1/1] port group interface FortyGigE 1/1/1
[Sysname-irf-port1/1] port group interface FortyGigE 1/1/2
[Sysname-irf-port1/1] quit
# Bind FortyGigE 1/1/3 and FortyGigE 1/1/4 to IRF-port 1/2.
[Sysname] irf-port 1/2
[Sysname-irf-port1/2] port group interface FortyGigE 1/1/3
[Sysname-irf-port1/2] port group interface FortyGigE 1/1/4
[Sysname-irf-port1/2] quit
# Bring up the SFP+ ports and save the configuration.
[Sysname-if-range] undo shutdown
[Sysname] save
# Activate the IRF port configuration.
[Sysname] irf-port-configuration active
2.     Configure Device B:
# Change the member ID of Device B to 2 and reboot the device to validate the change.
[Sysname] irf member 1 renumber 2
Renumbering the member ID may result in configuration change or loss. Continue? [Y/N]:y
[Sysname] quit
<Sysname> reboot
# Connect Device B to Device A as shown in Figure 15, and log in to Device B. This example uses FortyGigE 2/1/1 to FortyGigE 2/1/4 for IRF links.
# Shut down the physical interfaces.
[Sysname] interface range FortyGigE 2/1/1 to FortyGigE 2/1/4
# Bind FortyGigE 2/1/1 and FortyGigE 2/1/2 to IRF-port 2/1.
[Sysname] irf-port 2/1
[Sysname-irf-port2/1] port group interface FortyGigE 2/1/1
[Sysname-irf-port2/1] port group interface FortyGigE 2/1/2
[Sysname-irf-port2/1] quit
# Bind FortyGigE 2/1/3 and FortyGigE 2/1/4 to IRF-port 2/2.
[Sysname] irf-port 2/2
[Sysname-irf-port2/2] port group interface FortyGigE 2/1/3
[Sysname-irf-port2/2] port group interface FortyGigE 2/1/4
[Sysname-irf-port2/2] quit
# Bring up the QSFP+ ports and save the configuration.
[Sysname] save
The two devices perform master election, and the one that has lost the election reboots to form an IRF fabric with the master.
3.     Configure Device C:
# Change the member ID of Device C to 3 and reboot the device to validate the change.
[Sysname] irf member 1 renumber 3
[Sysname] quit
<Sysname> reboot
# Connect Device C to Device A as shown in Figure 15, and log in to Device C. This example uses FortyGigE 3/1/1 to FortyGigE 3/1/4 for IRF links.
[Sysname] interface range FortyGigE 3/1/1 to FortyGigE 3/1/4
# Bind FortyGigE 3/1/1 and FortyGigE 3/1/2 to IRF-port 3/1.
[Sysname] irf-port 3/1
[Sysname-irf-port3/1] port group interface FortyGigE 3/1/1
[Sysname-irf-port3/1] port group interface FortyGigE 3/1/2
[Sysname-irf-port3/1] quit
# Bind FortyGigE 3/1/3 and FortyGigE 3/1/4 to IRF-port 3/2.
[Sysname] irf-port 3/2
[Sysname-irf-port3/2] port group interface FortyGigE 3/1/3
[Sysname-irf-port3/2] port group interface FortyGigE 3/1/4
[Sysname-irf-port3/2] quit
[Sysname] save
Device C reboots to join the IRF fabric.
4.     Configure Device D:
# Change the member ID of Device D to 4 and reboot the device to validate the change.
[Sysname] irf member 1 renumber 4
[Sysname] quit
<Sysname> reboot
# Connect Device D to Device B and Device C as shown in Figure 15, and log in to Device D. This example uses FortyGigE 4/1/1 to FortyGigE 4/1/4 for IRF links.
[Sysname] interface range FortyGigE 4/1/1 to FortyGigE 4/1/4
# Bind FortyGigE 4/1/1 and FortyGigE 4/1/2 to IRF-port 4/1.
[Sysname] irf-port 4/1
[Sysname-irf-port4/1] port group interface FortyGigE 4/1/1
[Sysname-irf-port4/1] port group interface FortyGigE 4/1/2
[Sysname-irf-port4/1] quit
# Bind FortyGigE 4/1/3 and FortyGigE 4/1/4 to IRF-port 4/2.
[Sysname] irf-port 4/2
[Sysname-irf-port4/2] port group interface FortyGigE 4/1/3
[Sysname-irf-port4/2] port group interface FortyGigE 4/1/4
[Sysname-irf-port4/2] quit
[Sysname] save
Device D reboots to join the IRF fabric. A four-chassis IRF fabric is formed.
5.     Configure LACP MAD on the IRF fabric:
# Set the domain ID of the IRF fabric to 1.
[Sysname] irf domain 1
# Create a dynamic aggregate interface and enable LACP MAD.
[Sysname] interface bridge-aggregation 2
[Sysname-Bridge-Aggregation2] link-aggregation mode dynamic
[Sysname-Bridge-Aggregation2] mad enable
[Current domain is: 1]:
 The assigned  domain ID is: 1
 Info: MAD LACP only enable on dynamic aggregation interface.
[Sysname-Bridge-Aggregation2] quit
# Assign FortyGigE 1/1/5, FortyGigE 2/1/5, FortyGigE 3/1/5, and FortyGigE 4/1/5 to the aggregate interface.
[Sysname] interface range FortyGigE 1/1/5 FortyGigE 2/1/5 FortyGigE 3/1/5 FortyGigE 4/1/5
[Sysname-if-range] port link-aggregation group 2
6.     Configure Device E as the intermediate device:
CAUTION:
If the intermediate device is also an IRF fabric, assign the two IRF fabrics different domain IDs for correct split detection. False detection causes IRF split.
# Create a dynamic aggregate interface.
# Assign FortyGigE 1/1/1, FortyGigE 1/1/2, FortyGigE 1/1/3, and FortyGigE 1/1/4 to the aggregate interface.
BFD MAD-enabled IRF configuration example
As shown in Figure 16, set up a four-chassis IRF fabric at the core layer of the enterprise network.
·     Configure BFD MAD in the IRF fabric and set up BFD MAD links between each member device and the intermediate device.
·     Disable the spanning tree feature on the ports used for BFD MAD, because the two features conflict with each other.
Figure 16 Network diagram
Configuration procedure
[Sysname] save
[Sysname] quit
<Sysname> reboot
# Connect Device B to Device A as shown in Figure 16, and log in to Device B. This example uses FortyGigE 2/1/1 to FortyGigE 2/1/4 for IRF links.
[Sysname] save
[Sysname] quit
<Sysname> reboot
# Connect Device C to Device A as shown in Figure 16, and log in to Device C. This example uses FortyGigE 3/1/1 to FortyGigE 3/1/4 for IRF links.
[Sysname] save
[Sysname] quit
<Sysname> reboot
# Connect Device D to Device B and Device C as shown in Figure 16, and log in to Device D. This example uses FortyGigE 4/1/1 to FortyGigE 4/1/4 for IRF links.
[Sysname] save
5.     Configure BFD MAD on the IRF fabric:
# Create VLAN 3, and add FortyGigE 1/1/5, FortyGigE 2/1/5, FortyGigE 3/1/5, and FortyGigE 4/1/5 to VLAN 3.
[Sysname] vlan 3
[Sysname-vlan3] port FortyGigE 1/1/5 FortyGigE 2/1/5 FortyGigE 3/1/5 FortyGigE 4/1/5
[Sysname-vlan3] quit
# Create VLAN-interface 3, and configure a MAD IP address for each member device on the VLAN interface.
[Sysname] interface vlan-interface 3
[Sysname-Vlan-interface3] mad bfd enable
[Sysname-Vlan-interface3] mad ip address 192.168.2.1 24 member 1
[Sysname-Vlan-interface3] mad ip address 192.168.2.2 24 member 2
[Sysname-Vlan-interface3] mad ip address 192.168.2.3 24 member 3
[Sysname-Vlan-interface3] mad ip address 192.168.2.4 24 member 4
[Sysname-Vlan-interface3] quit
# Disable the spanning tree feature on FortyGigE 1/1/5, FortyGigE 2/1/5, FortyGigE 3/1/5, and FortyGigE 4/1/5.
[Sysname-if-range] undo stp enable
CAUTION
CAUTION:
# Create VLAN 3, and assign FortyGigE 1/1/1, FortyGigE 1/1/2, FortyGigE 1/1/3, and FortyGigE 1/1/4 to VLAN 3 for forwarding BFD MAD packets.
<DeviceE> system-view
[DeviceE] vlan 3
[DeviceE-vlan3] port FortyGigE 1/1/1 to FortyGigE 1/1/4
[DeviceE-vlan3] quit
ARP MAD-enabled IRF configuration example
As shown in Figure 17, set up a four-chassis IRF fabric in the enterprise network.
·     Configure ARP MAD in the IRF fabric and use the links connected to Device E for transmitting ARP MAD packets.
·     To prevent loops, run the spanning tree feature between Device E and the IRF fabric.
Figure 17 Network diagram
[Sysname] save
[Sysname] quit
<Sysname> reboot
# Connect Device B to Device A as shown in Figure 17, and log in to Device B. This example uses FortyGigE 2/1/1 to FortyGigE 2/1/4 for IRF links.
[Sysname] save
[Sysname] quit
<Sysname> reboot
# Connect Device C to Device A as shown in Figure 17, and log in to Device C. This example uses FortyGigE 3/1/1 to FortyGigE 3/1/4 for IRF links.
[Sysname] save
[Sysname] quit
<Sysname> reboot
# Connect Device D to Device B and Device C as shown in Figure 17, and log in to Device D. This example uses FortyGigE 4/1/1 to FortyGigE 4/1/4 for IRF links.
[Sysname] save
5.     Configure ARP MAD on the IRF fabric:
# Enable the spanning tree feature globally. Map the ARP MAD VLAN to MSTI 1 in the MST region.
[Sysname] stp global enable
[Sysname-mst-region] region-name arpmad
[Sysname-mst-region] instance 1 vlan 3
[Sysname-mst-region] quit
# Configure the IRF fabric to change its bridge MAC address as soon as the address owner leaves.
[Sysname] undo irf mac-address persistent
# Create VLAN 3, and assign FortyGigE 1/1/5, FortyGigE 2/1/5, FortyGigE 3/1/5, and FortyGigE 4/1/5 to VLAN 3.
[Sysname] vlan 3
# Create VLAN-interface 3, assign it an IP address, and enable ARP MAD on the interface.
[Sysname-Vlan-interface3] ip address 192.168.2.1 24
[Sysname-Vlan-interface3] mad arp enable
CAUTION:
If the intermediate device is also in an IRF fabric, assign the two IRF fabrics different domain IDs for correct split detection. False detection causes IRF split.
[DeviceE] stp global enable
[DeviceC-mst-region] region-name arpmad
[DeviceC-mst-region] instance 1 vlan 3
[DeviceC-mst-region] quit
# Create VLAN 3, and assign ports FortyGigE 1/1/1, FortyGigE 1/1/2, FortyGigE 1/1/3, and FortyGigE 1/1/4 to VLAN 3 for forwarding ARP MAD packets.
[DeviceE] vlan 3
ND MAD-enabled IRF configuration example
As shown in Figure 18, set up a four-chassis IRF fabric in the IPv6 enterprise network.
·     Configure ND MAD in the IRF fabric and use the links connected to Device E for transmitting ND MAD packets.
Figure 18 Network diagram
[Sysname] save
[Sysname] quit
<Sysname> reboot
# Connect Device B to Device A as shown in Figure 18, and log in to Device B. This example uses FortyGigE 2/1/1 to FortyGigE 2/1/4 for IRF links.
[Sysname] save
[Sysname] quit
<Sysname> reboot
# Connect Device C to Device A as shown in Figure 18, and log in to Device C. This example uses FortyGigE 3/1/1 to FortyGigE 3/1/4 for IRF links.
[Sysname] save
[Sysname] quit
<Sysname> reboot
# Connect Device D to Device B and Device C as shown in Figure 18, and log in to Device D. This example uses FortyGigE 4/1/1 to FortyGigE 4/1/4 for IRF links.
[Sysname] save
5.     Configure ND MAD on the IRF fabric:
# Enable the spanning tree feature globally. Map the ND MAD VLAN to MSTI 1 in the MST region.
[Sysname-mst-region] region-name ndmad
[Sysname] vlan 3
# Create VLAN-interface 3, assign it an IPv6 address, and enable ND MAD on the interface.
[Sysname-Vlan-interface3] ipv6 address 2001::1 64
[Sysname-Vlan-interface3] mad nd enable
CAUTION:
[DeviceC-mst-region] region-name ndmad
# Create VLAN 3, and add ports FortyGigE 1/1/1, FortyGigE 1/1/2, FortyGigE 1/1/3, and FortyGigE 1/1/4 to VLAN 3 for forwarding ND MAD packets.
[DeviceE] vlan 3
