11-Network Management and Monitoring Configuration Examples
HomeSupportSwitchesS7500E SeriesConfigure & DeployConfiguration ExamplesH3C S7500E Switch Series Configuration Examples-Release7150-6W10011-Network Management and Monitoring Configuration Examples
07-H3C_S7500E_sFlow_Configuration_Examples
07-H3C_S7500E_sFlow_Configuration_Examples 141.2 KB
H3C S7500E sFlow Configuration Examples
H3C_彩色.emf
Introduction
This document provides sFlow configuration examples.
This document assumes that you have basic knowledge of sFlow.
When you configure sFlow, follow these restrictions and guidelines:
·     You can specify only the random sampling mode (the default).
·     For the remote sFlow collector to receive sFlow packets, the IP address of the sFlow collector specified on the sFlow agent must be the same with that of the remote sFlow collector.
·     If the number of packets sampled by an interface is too much in a heavy traffic network, increase the flow sampling interval. If an interface samples insufficient packets in a light traffic network, decrease the flow sampling interval.
·     If an interface collects data too frequently in a heavy traffic network, increase the counter sampling interval. If the sampling statistics is not accurate in a light traffic network, decrease the counter sampling interval.
Example: Configuring sFlow
Network requirements
As shown in Figure 1, perform the following tasks:
·     Configure flow sampling to sample packets on Device A and Device B.
·     Configure counter sampling to periodically collect the counter information on Device A and Device B.
Figure 1 Network diagram
Requirements analysis
To obtain interface counter information and packet information, you must configure both flow sampling and counter sampling.
Software version used
This configuration example was created and verified on S7500E-CMW710-R7150.
Configuration procedures
Configuring Device A
# Create VLAN 10. Assign GigabitEthernet 3/0/1 through GigabitEthernet 3/0/3 to VLAN 10.
[DeviceA] vlan 10
[DeviceA-vlan10] port GigabitEthernet 3/0/1 to GigabitEthernet 3/0/3
[DeviceA-vlan10] quit
# Assign an IP address to VLAN-interface 10.
[DeviceA-Vlan-interface10] ip address 10.1.1.1 255.255.255.0
# Assign IP addresses to other interfaces. (Details not shown.)
# Assign an IP address to the sFlow agent.
[DeviceA] sflow agent ip 10.1.1.1
# Specify the sFlow collector ID as 1, IP address as 30.1.1.2, and port number as 5000.
[DeviceA] sflow collector 1 ip 30.1.1.2 port 5000
# Enable counter sampling and set the counter sampling interval to 120 seconds on GigabitEthernet 3/0/1.
[DeviceA] interface gigabitethernet 3/0/1
[DeviceA-GigabitEthernet3/0/1] sflow counter interval 120
# Specify sFlow collector 1 for counter sampling on GigabitEthernet 3/0/1.
[DeviceA-GigabitEthernet3/0/1] sflow counter collector 1
[DeviceA-GigabitEthernet3/0/1] quit
# Enable counter sampling and set the counter sampling interval to 120 seconds on GigabitEthernet 3/0/2.
[DeviceA] interface gigabitethernet 3/0/2
[DeviceA-GigabitEthernet3/0/2] sflow counter interval 120
# Specify sFlow collector 1 for counter sampling on GigabitEthernet 3/0/2.
[DeviceA-GigabitEthernet3/0/2] sflow counter collector 1
[DeviceA-GigabitEthernet3/0/2] quit
# Enable flow sampling and set the sampling interval to 100000 on GigabitEthernet 3/0/1.
[DeviceA-GigabitEthernet3/0/1] sflow sampling-rate 100000
# Specify sFlow collector 1 for flow sampling on GigabitEthernet 3/0/1.
[DeviceA-GigabitEthernet3/0/1] sflow flow collector 1
# Enable flow sampling and set the sampling interval to 100000 on GigabitEthernet 3/0/2.
[DeviceA-GigabitEthernet3/0/2] sflow sampling-rate 100000
# Specify sFlow collector 1 for flow sampling on GigabitEthernet 3/0/2.
[DeviceA-GigabitEthernet3/0/2] sflow flow collector 1
Configuring Device B
# Create VLAN 20. Assign GigabitEthernet 3/0/1 and GigabitEthernet 3/0/2 to VLAN 20.
[DeviceB] vlan 20
[DeviceB-vlan20] port GigabitEthernet 3/0/1 to GigabitEthernet 3/0/2
[DeviceB-vlan20] quit
# Assign an IP address to VLAN-interface 20.
[DeviceB] interface vlan-interface 20
[DeviceB-Vlan-interface20] ip address 20.1.1.1 255.255.255.0
[DeviceB-Vlan-interface20] quit
[DeviceB] sflow agent ip 20.1.1.1
[DeviceB] sflow collector 1 ip 30.1.1.2 port 5000
# Enable counter sampling and set the counter sampling interval to 30 seconds on GigabitEthernet 3/0/1.
[DeviceB] interface gigabitethernet 3/0/1
[DeviceB-GigabitEthernet3/0/1] sflow counter interval 30
[DeviceB-GigabitEthernet3/0/1] sflow counter collector 1
# Enable flow sampling and set the sampling interval to 20000 on GigabitEthernet 3/0/1.
[DeviceB-GigabitEthernet3/0/1] sflow sampling-rate 20000
[DeviceB-GigabitEthernet3/0/1] sflow flow collector 1
[DeviceB-GigabitEthernet3/0/1] quit
# Verify the following items on Device A:
·     GigabitEthernet 3/0/1 and GigabitEthernet 3/0/2 enabled with sFlow are active.
·     The counter sampling interval is 120 seconds.
·     The flow sampling interval is 100000.
[DeviceA] display sflow
sFlow datagram version: 5
Global information:
Agent IP: 10.1.1.1(CLI)
Source address:
Collector information:
ID    IP              Port  Aging      Size VPN-instance Description
1     30.1.1.2         5000  N/A        1400              CLI Collector
Port information:
Interface      CID   Interval(s) FID   MaxHLen Rate       Mode          Status
GE3/0/1        1     120         1     128     100000     Random        Active
GE3/0/2        1     120         1     128     100000     Random        Active
Configuration files
·     Device A:
vlan 10
interface Vlan-interface10
 sflow collector 1 ip 30.1.1.2 port 5000 description "CLI Collector"
interface GigabitEthernet3/0/1
 port link-mode bridge
 port access vlan 10
interface GigabitEthernet3/0/2
 port access vlan 10
interface GigabitEthernet3/0/3
 port access vlan 10
·     Device B:
vlan 20
interface Vlan-interface20
 port access vlan 20
 port access vlan 20
Related documentation
·     H3C S7500E Switch Series Network Management and Monitoring Configuration Guide-Release 7150
·     H3C S7500E Switch Series Network Management and Monitoring Command Reference-Release 7150
