- 07-MPLS Configuration Examples
- 01-H3C_S7500E_HoVPN_Configuration_Examples
- 02-H3C_S7500E_MCE_Configuration_Examples
- 03-H3C_S7500E_MPLS_L2VPN_Configuration_Examples
- 04-H3C_S7500E_MPLS_L3VPN_Configuration_Examples
- 05-H3C_S7500E_MPLS_TE_Configuration_Examples
- 06-H3C_S7500E_MPLS_TE_Forwarding_Adjacency_Configuration_Examples
- 07-H3C_S7500E_Basic_MPLS_Configuration_Examples
- 08-H3C_S7500E_VPLS_Configuration_Examples
| 03-H3C_S7500E_MPLS_L2VPN_Configuration_Examples | 360.76 KB |
H3C S7500E MPLS L2VPN Configuration Examples
Copyright © 2015 Hangzhou H3C Technologies Co., Ltd. All rights reserved. No part of this manual may be reproduced or transmitted in any form or by any means without prior written consent of Hangzhou H3C Technologies Co., Ltd. The information in this document is subject to change without notice. |
Introduction
This document provides MPLS L2VPN configuration examples.
MPLS L2VPN is an MPLS-based Layer 2 VPN technology. It can transparently transmit Layer 2 data for different data link layer protocols over an MPLS network.
MPLS L2VPN can be implemented through the following PWs:
· CCC PWs.
· Static PWs.
· LDP PWs.
· BGP PWs.
This document assumes that you have basic knowledge of MPLS L2VPN.
Example: Configuring remote CCC connections
Network requirements
As shown in Figure 1, configure remote CCC connections between PE 1 and PE 2 to allow communication between the two sites as if they were in the same LAN. The same VLAN in different sites can communicate with each other.
Requirements analysis
To establish a remote CCC connection, specify the incoming and outgoing labels on the PEs, and create a static LSP for each direction of the connection on the P device. The outgoing label specified on a device must be the same as the incoming label specified on the next hop device as shown in Figure 2.
Figure 2 Incoming and outgoing label assignment
Software version used
This configuration example was created and verified on S7500E-CMW710-R7150.
Configuration procedures
1. Configure VLAN interfaces and enable basic MPLS on the interfaces:
# On PE 1, configure an LSR ID.
<PE1> system-view
[PE1] interface loopback 0
[PE1-LoopBack0] ip address 1.1.1.9 32
[PE1-LoopBack0] quit
[PE1] mpls lsr-id 1.1.1.9
# On PE 1, enable MPLS L2VPN globally.
[PE1] l2vpn enable
# On PE 1, create VLAN 2 and assign Ten-GigabitEthernet 1/0/2 to the VLAN.
[PE1] vlan 2
[PE1-vlan2] port Ten-GigabitEthernet 1/0/2
[PE1-vlan2] quit
# On PE 1, configure VLAN-interface 2 and enable MPLS on it.
[PE1] interface vlan-interface 2
[PE1-Vlan-interface2] ip address 10.1.1.1 24
[PE1-Vlan-interface2] mpls enable
[PE1-Vlan-interface2] quit
# On P, configure an LSR ID.
<P> system-view
[P] interface loopback 0
[P-LoopBack0] ip address 2.2.2.9 32
[P-LoopBack0] quit
[P] mpls lsr-id 2.2.2.9
# On P, create VLAN 3 and assign Ten-GigabitEthernet 1/0/1 to the VLAN.
[P] vlan3
[P-vlan3] port Ten-GigabitEthernet1/0/1
[P-vlan3] quit
# On P, configure VLAN-interface 3 and enable MPLS on it.
[P] interface vlan-interface 3
[P-Vlan-interface3] ip address 10.1.2.1 24
[P-Vlan-interface3] mpls enable
[P-Vlan-interface3] quit
# On P, create VLAN 2 and assign Ten-GigabitEthernet 1/0/2 to the VLAN.
[P] vlan2
[P-vlan2] port Ten-GigabitEthernet1/0/2
[P-vlan2] quit
# On P, configure VLAN-interface 2 and enable MPLS on it.
[P] interface vlan-interface 2
[P-Vlan-interface2] ip address 10.1.1.2 24
[P-Vlan-interface2] mpls enable
[P-Vlan-interface2] quit
# On PE 2, configure an LSR ID.
<PE2> system-view
[PE2] interface loopback 0
[PE2-LoopBack0] ip address 3.3.3.9 32
[PE2-LoopBack0] quit
[PE2] mpls lsr-id 3.3.3.9
# On PE 2, enable MPLS L2VPN globally.
[PE2] l2vpn enable
# On PE 2, create VLAN 3 and assign Ten-GigabitEthernet 1/0/2 to the VLAN.
[PE2] vlan 3
[PE2-vlan3] port Ten-GigabitEthernet 1/0/2
[PE2-vlan3] quit
# On PE 2, configure VLAN-interface 3 and enable MPLS on it.
[PE2] interface vlan-interface 3
[PE2-Vlan-interface3] ip address 10.1.2.2 24
[PE2-Vlan-interface3] mpls enable
[PE2-Vlan-interface3] quit
2. Configure remote CCC connections on PEs and configure static LSPs on P:
# On PE 1, create service instance 100 on Ten-GigabitEthernet 1/0/1 to match packets from VLAN 100.
[PE1] interface ten-gigabitethernet1/0/1
[PE1-Ten-GigabitEthernet1/0/1] service-instance 100
[PE1-Ten-GigabitEthernet1/0/1-srv100] encapsulation s-vid 100
[PE1-Ten-GigabitEthernet1/0/1-srv100] quit
# On PE 1, create service instance 101 on Ten-GigabitEthernet 1/0/1 to match packets from VLAN 101.
[PE1-Ten-GigabitEthernet1/0/1] service-instance 101
[PE1-Ten-GigabitEthernet1/0/1-srv101] encapsulation s-vid 101
[PE1-Ten-GigabitEthernet1/0/1-srv101] quit
# On PE 1, create cross-connect group vpna, and create remote CCC connection CCC that has incoming label 100, outgoing label 101, and next hop 10.1.1.2.
[PE1] xconnect-group vpna
[PE1-xcg-vpna] connection ccc
[PE1-xcg-vpna-ccc] ccc in-label 100 out-label 101 nexthop 10.1.1.2
# On PE 1, bind service instance 100 on Ten-GigabitEthernet 1/0/1 to the CCC connection.
[PE1-xcg-vpna-ccc] ac interface ten-gigabitethernet 1/0/1 service-instance 100
[PE1-xcg-vpna-ccc] quit
[PE1-xcg-vpna] quit
# On PE 1, create cross-connect group vpnb, and create remote CCC connection CCC that has incoming label 200, outgoing label 201, and next hop 10.1.1.2.
[PE1] xconnect-group vpnb
[PE1-xcg-vpnb] connection ccc
[PE1-xcg-vpnb-ccc] ccc in-label 200 out-label 201 nexthop 10.1.1.2
# On PE 1, bind service instance 101 on Ten-GigabitEthernet 1/0/1 to the CCC connection.
[PE1-xcg-vpnb-ccc] ac interface ten-gigabitethernet 1/0/1 service-instance 101
[PE1-xcg-vpnb-ccc] quit
[PE1-xcg-vpnb] quit
# On P, create a static LSP for forwarding packets of VLAN 100 from PE 1 to PE 2.
[P] static-lsp transit pe1-pe2-100 in-label 101 nexthop 10.1.2.2 out-label 110
# On P, create a static LSP for forwarding packets of VLAN 101 from PE 1 to PE 2.
[P] static-lsp transit pe1-pe2-101 in-label 201 nexthop 10.1.2.2 out-label 210
# On P, create a static LSP for forwarding packets of VLAN 100 from PE 2 to PE 1.
[P] static-lsp transit pe2-pe1-100 in-label 111 nexthop 10.1.1.1 out-label 100
# On P, create a static LSP for forwarding packets of VLAN 101 from PE 2 to PE 1.
[P] static-lsp transit pe2-pe1-101 in-label 211 nexthop 10.1.1.1 out-label 200
# On PE 2, create service instance 100 on Ten-GigabitEthernet 1/0/1 to match packets from VLAN 100.
[PE2] interface ten-gigabitethernet1/0/1
[PE2-Ten-GigabitEthernet1/0/1] service-instance 100
[PE2-Ten-GigabitEthernet1/0/1-srv100] encapsulation s-vid 100
[PE2-Ten-GigabitEthernet1/0/1-srv100] quit
# On PE 2, create service instance 101 on Ten-GigabitEthernet 1/0/1 to match packets from VLAN 101.
[PE2-Ten-GigabitEthernet1/0/1] service-instance 101
[PE2-Ten-GigabitEthernet1/0/1-srv101] encapsulation s-vid 101
[PE2-Ten-GigabitEthernet1/0/1-srv101] quit
[PE2-Ten-GigabitEthernet1/0/1] quit
# On PE 2, create cross-connect group vpna, and create remote CCC connection CCC that has incoming label 110, outgoing label 111, and next hop 10.1.2.1.
[PE2] xconnect-group vpna
[PE2-xcg-vpna] connection ccc
[PE2-xcg-vpna-ccc] ccc in-label 110 out-label 111 nexthop 10.1.2.1
# On PE 2, bind service instance 100 on Ten-GigabitEthernet 1/0/1 to the CCC connection.
[PE2-xcg-vpna-ccc] ac interface ten-gigabitethernet 1/0/1 service-instance 100
[PE2-xcg-vpna-ccc] quit
[PE2-xcg-vpna] quit
# On PE 2, create cross-connect group vpnb, and create remote CCC connection CCC that has incoming label 210, outgoing label 211, and next hop 10.1.2.1.
[PE2] xconnect-group vpnb
[PE2-xcg-vpnb] connection ccc
[PE2-xcg-vpnb-ccc] ccc in-label 210 out-label 211 nexthop 10.1.2.1
# On PE 2, bind service instance 101 on Ten-GigabitEthernet 1/0/1 to the CCC connection.
[PE2-xcg-vpnb-ccc] ac interface ten-gigabitethernet 1/0/1 service-instance 101
[PE2-xcg-vpnb-ccc] quit
[PE2-xcg-vpnb] quit
3. Allow CE access to PEs:
# On CE 1, configure Ten-GigabitEthernet 1/0/1 as a trunk port and assign the port to VLAN 100 and VLAN 101.
<CE1> system-view
[CE1] vlan 100 to 101
[CE1] interface Ten-GigabitEthernet 1/0/1
[CE1-Ten-GigabitEthernet1/0/1] port link-type trunk
[CE1-Ten-GigabitEthernet1/0/1] port trunk permit vlan 100 101
# On CE 2, configure Ten-GigabitEthernet 1/0/1 as a trunk port and assign the port to VLAN 100 and VLAN 101.
<CE2> system-view
[CE2] vlan 100 to 101
[CE2] interface Ten-GigabitEthernet 1/0/1
[CE2-Ten-GigabitEthernet1/0/1] port link-type trunk
[CE2-Ten-GigabitEthernet1/0/1] port trunk permit vlan 100 101
# Display L2VPN PW information on PE 1. The output shows that two remote CCC connections (identified by PW ID/Rmt Site "-" and Proto Static) have been established.
[PE1] display l2vpn pw
Flags: M - main, B - backup, H - hub link, S - spoke link, N - no split horizon
Total number of PWs: 2, 2 up, 0 blocked, 0 down, 0 defect
Xconnect-group Name: vpna
Peer PW ID/Rmt Site In/Out Label Proto Flag Link ID State
10.1.1.2 - 100/101 Static M 1 Up
Xconnect-group Name: vpnb
10.1.1.2 - 200/201 Static M 1 Up
# Display L2VPN PW information on PE 2. The output shows that two remote CCC connections have been established.
[PE2] display l2vpn pw
10.1.2.1 - 110/111 Static M 1 Up
10.1.2.1 - 210/211 Static M 1 Up
# Verify that Host A and Server can ping each other and hosts of VLAN 101 in different sites can ping each other. (Details not shown.)
Configuration files
· CE 1:
vlan 100 to 101
port link-mode bridge
port trunk permit vlan 100 to 101
· PE 1:
mpls lsr-id 1.1.1.9
vlan 2
l2vpn enable
interface LoopBack0
ip address 1.1.1.9 255.255.255.255
interface Vlan-interface2
mpls enable
port access vlan 2
xconnect-group vpna
connection ccc
ac interface Ten-GigabitEthernet1/0/1 service-instance 100
xconnect-group vpnb
connection ccc
ac interface Ten-GigabitEthernet1/0/1 service-instance 101
· P:
mpls lsr-id 2.2.2.9
vlan 2
vlan 3
interface LoopBack0
ip address 2.2.2.9 255.255.255.255
mpls enable
interface Vlan-interface3
ip address 10.1.2.1 255.255.255.0
mpls enable
port access vlan 3
port access vlan 2
· PE 2:
mpls lsr-id 3.3.3.9
vlan 3
l2vpn enable
interface LoopBack0
ip address 3.3.3.9 255.255.255.255
ip address 10.1.2.2 255.255.255.0
mpls enable
port access vlan 3
xconnect-group vpna
connection ccc
xconnect-group vpnb
connection ccc
· CE 2:
vlan 100 to 101
Example: Configuring static PWs
As shown in Figure 3, the MPLS network provides L2VPN services for two customers. Each customer has two fixed sites. Configure static PWs between PE 1 and PE 2 to allow communication between the sites of the same customer.
To use static PWs to implement MPLS L2VPN, configure two levels of labels:
· Inner labels—PW labels specified manually.
· Outer labels—Public tunnel labels dynamically generated by LDP in this example.
To ensure that a static PW can be successfully established for the sites of a customer, specify the incoming label on the local PE the same as the outgoing label on the remote PE.
1. Configure OSPF on the MPLS backbone to ensure IP connectivity within the backbone:
# On PE 1, configure an IP address for Loopback 0.
<PE1> system-view
[PE1] vlan 2
[PE1-vlan2] quit
# On PE 1, configure VLAN-interface 2.
# On PE 1, configure OSPF.
[PE1] ospf
[PE1-ospf-1] area 0
[PE1-ospf-1-area-0.0.0.0] network 10.1.1.0 0.0.0.255
[PE1-ospf-1-area-0.0.0.0] network 1.1.1.9 0.0.0.0
[PE1-ospf-1] quit
# On P, configure an IP address for Loopback 0.
<P> system-view
[P-LoopBack0] quit
[P] vlan 2
[P-vlan2] quit
# On P, configure VLAN-interface 2.
[P] vlan 3
[P-vlan3] quit
# On P, configure VLAN-interface 3.
# On P, configure OSPF.
[P] ospf
[P-ospf-1] area 0
[P-ospf-1-area-0.0.0.0] network 10.1.1.0 0.0.0.255
[P-ospf-1-area-0.0.0.0] network 10.1.2.0 0.0.0.255
[P-ospf-1-area-0.0.0.0] network 2.2.2.9 0.0.0.0
[P-ospf-1-area-0.0.0.0] quit
[P-ospf-1] quit
# On PE 2, configure an IP address for Loopback 0.
<PE2> system-view
[PE2] vlan 3
[PE2-vlan3] quit
# On PE 2, configure VLAN-interface 3.
# On PE 2, configure OSPF.
[PE2] ospf
[PE2-ospf-1] area 0
[PE2-ospf-1-area-0.0.0.0] network 10.1.2.0 0.0.0.255
[PE2-ospf-1-area-0.0.0.0] network 3.3.3.9 0.0.0.0
[PE2-ospf-1] quit
2. Configure basic MPLS and MPLS LDP on the MPLS backbone to establish LDP LSPs:
# On PE 1, enable LDP globally.
[PE1] mpls ldp
[PE1-ldp] quit
# On PE 1, enable MPLS and LDP on VLAN-interface 2.
[PE1-Vlan-interface2] mpls ldp enable
# On P, enable LDP globally.
[P] mpls ldp
[P-ldp] quit
# On P, enable MPLS and LDP on VLAN-interface 2.
[P-Vlan-interface2] mpls ldp enable
# On P, enable MPLS and LDP on VLAN-interface 3.
[P-Vlan-interface3] mpls ldp enable
# On PE 2, enable LDP globally.
[PE2] mpls ldp
[PE2-ldp] quit
# On PE 2, enable MPLS and LDP on VLAN-interface 3.
[PE2-Vlan-interface3] mpls ldp enable
3. Enable MPLS L2VPN and assign inner labels to customers:
[PE1] l2vpn enable
# On PE 1, create cross-connect group vpna, create cross-connect svc in the group, and bind service instance 100 on Ten-GigabitEthernet 1/0/1 to the cross-connect.
[PE1-xcg-vpna] connection svc
[PE1-xcg-vpna-svc] ac interface Ten-GigabitEthernet 1/0/1 service-instance 100
# On PE 1, create a static PW for the cross-connect to bind the AC to the PW.
[PE1-xcg-vpna-svc] peer 3.3.3.9 pw-id 100 in-label 101 out-label 100
[PE1-xcg-vpna-svc-3.3.3.9-100] quit
[PE1-xcg-vpna-svc] quit
[PE1-xcg-vpna] quit
# On PE 1, create service instance 200 on Ten-GigabitEthernet 1/0/4 to match packets from VLAN 200.
[PE1] interface ten-gigabitethernet1/0/4
[PE1-Ten-GigabitEthernet1/0/4] service-instance 200
[PE1-Ten-GigabitEthernet1/0/4-srv200] encapsulation s-vid 200
[PE1-Ten-GigabitEthernet1/0/4-srv200] quit
[PE1-Ten-GigabitEthernet1/0/4] quit
# On PE 1, create cross-connect group vpnb, create cross-connect svc in the group, and bind service instance 200 on Ten-GigabitEthernet 1/0/4 to the cross-connect.
[PE1-xcg-vpnb] connection svc
[PE1-xcg-vpnb-svc] ac interface Ten-GigabitEthernet 1/0/4 service-instance 200
[PE1-xcg-vpnb-svc] peer 3.3.3.9 pw-id 200 in-label 201 out-label 200
[PE1-xcg-vpnb-svc-3.3.3.9-200] quit
[PE1-xcg-vpnb-svc] quit
[PE1-xcg-vpnb] quit
[PE2] l2vpn enable
# On PE 2, create service instance 200 on Ten-GigabitEthernet 1/0/4 to match packets from VLAN 200.
[PE2] interface ten-gigabitethernet1/0/4
[PE2-Ten-GigabitEthernet1/0/4] service-instance 200
[PE2-Ten-GigabitEthernet1/0/4-srv200] encapsulation s-vid 200
[PE2-Ten-GigabitEthernet1/0/4-srv200] quit
[PE2-Ten-GigabitEthernet1/0/4] quit
# On PE 2, create cross-connect group vpna, create cross-connect svc in the group, and bind service instance 100 on Ten-GigabitEthernet 1/0/1 to the cross-connect.
[PE2-xcg-vpna] connection svc
[PE2-xcg-vpna-svc] ac interface Ten-GigabitEthernet 1/0/1 service-instance 100
# On PE 2, create a static PW for the cross-connect to bind the AC to the PW.
[PE2-xcg-vpna-svc] peer 1.1.1.9 pw-id 100 in-label 100 out-label 101
[PE2-xcg-vpna-svc-1.1.1.9-100] quit
[PE2-xcg-vpna-svc] quit
[PE2-xcg-vpna] quit
# On PE 2, create cross-connect group vpnb, create cross-connect svc in the group, and bind service instance 200 on Ten-GigabitEthernet 1/0/4 to the cross-connect.
[PE2-xcg-vpnb] connection svc
[PE2-xcg-vpnb-svc] ac interface Ten-GigabitEthernet 1/0/4 service-instance 200
[PE2-xcg-vpnb-svc] peer 1.1.1.9 pw-id 200 in-label 200 out-label 201
[PE2-xcg-vpnb-svc-1.1.1.9-200] quit
[PE2-xcg-vpnb-svc] quit
[PE2-xcg-vpnb] quit
4. Allow CE access to PEs:
# On CE 1, configure the interface connected to the PE to permit tagged packets from the customer VLAN.
<CE1> system-view
[CE1] vlan 100
[CE1-vlan100] quit
# Configure other CEs in the same way that CE 1 is configured. (Details not shown.)
# Display L2VPN PW information on PE 1. The output shows that two static PWs have been established.
Peer PW ID In/Out Label Proto Flag Link ID State
3.3.3.9 100 101/100 Static M 1 Up
3.3.3.9 200 201/200 Static M 1 Up
# Display L2VPN PW information on PE 2. The output shows that two static PWs have been established.
1.1.1.9 100 100/101 Static M 1 Up
1.1.1.9 200 200/201 Static M 1 Up
# Verify that the host and the server of the same customer in different sites can ping each other. (Details not shown.)
Configuration files
· CE 1:
vlan 100
· CE 2:
vlan 200
port trunk permit vlan 200
· CE 3:
vlan 100
· CE 4:
vlan 200
· PE 1:
ospf 1
area 0.0.0.0
mpls lsr-id 1.1.1.9
vlan 2
vlan 100
vlan 200
mpls ldp
l2vpn enable
interface LoopBack0
mpls enable
mpls ldp enable
port access vlan 2
interface Ten-GigabitEthernet1/0/4
xconnect-group vpna
connection svc
xconnect-group vpnb
connection svc
ac interface Ten-GigabitEthernet1/0/4 service-instance 200
· P:
ospf 1
area 0.0.0.0
mpls lsr-id 2.2.2.9
vlan 2 to 3
mpls ldp
interface LoopBack0
mpls enable
mpls ldp enable
mpls enable
mpls ldp enable
port access vlan 3
port access vlan 2
· PE 2:
ospf 1
area 0.0.0.0
mpls lsr-id 3.3.3.9
vlan 3
vlan 100
vlan 200
mpls ldp
l2vpn enable
interface LoopBack0
mpls enable
mpls ldp enable
port access vlan 3
xconnect-group vpna
connection svc
xconnect-group vpnb
connection svc
Example: Configuring LDP PWs
As shown in Figure 4, the MPLS network provides L2VPN services for a customer. Configure LDP PWs between PE 1 and PE 2 so the R&D and Marketing departments use different VPN connections to achieve data isolation.
To use LDP PWs to implement MPLS L2VPN, configure two levels of labels:
· Inner labels—PW labels dynamically generated by LDP.
To identify packets to be transported by MPLS L2VPN, configure service instances and match criteria on the CE-facing ports of PEs.
<PE1> system-view
[PE1] vlan 2
[PE1-vlan2] quit
# On PE 1, configure an IP address for VLAN-interface 2.
[PE1] ospf
[PE1-ospf-1] area 0
[PE1-ospf-1] quit
<P> system-view
[P-LoopBack0] quit
[P] vlan 2
[P-vlan2] quit
# On P, configure an IP address for VLAN-interface 2.
[P] vlan 3
[P-vlan3] quit
# On P, configure an IP address for VLAN-interface 3.
[P] ospf
[P-ospf-1] area 0
[P-ospf-1] quit
<PE2> system-view
[PE2] vlan 3
[PE2-vlan3] quit
# On PE 2, configure an IP address for VLAN-interface 3.
[PE2] ospf
[PE2-ospf-1] area 0
[PE2-ospf-1] quit
[PE1] mpls ldp
[PE1-ldp] quit
[P] mpls ldp
[P-ldp] quit
[PE2] mpls ldp
[PE2-ldp] quit
3. Configure a service instance for each department and bind the service instances to their respective VPN connections:
[PE1] l2vpn enable
# On PE 1, create service instance 200 on Ten-GigabitEthernet 1/0/1 to match packets from VLAN 200.
[PE1-Ten-GigabitEthernet1/0/1] service-instance 200
[PE1-Ten-GigabitEthernet1/0/1-srv200] encapsulation s-vid 200
[PE1-Ten-GigabitEthernet1/0/1-srv200] quit
# On PE 1, create cross-connect group vpna, create cross-connect ldp in the group, and bind service instance 100 on Ten-GigabitEthernet 1/0/1 to the cross-connect.
[PE1-xcg-vpna] connection ldp
[PE1-xcg-vpna-ldp] ac interface Ten-GigabitEthernet 1/0/1 service-instance 100
# On PE 1, create an LDP PW for the cross-connect to bind the AC to the PW.
[PE1-xcg-vpna-ldp] peer 3.3.3.9 pw-id 100
[PE1-xcg-vpna-ldp-3.3.3.9-100] quit
[PE1-xcg-vpna-ldp] quit
[PE1-xcg-vpna] quit
# On PE 1, create cross-connect group vpnb, create cross-connect ldp in the group, and bind service instance 200 on Ten-GigabitEthernet 1/0/1 to the cross-connect.
[PE1-xcg-vpnb] connection ldp
[PE1-xcg-vpnb-ldp] ac interface Ten-GigabitEthernet 1/0/1 service-instance 200
[PE1-xcg-vpnb-ldp] peer 3.3.3.9 pw-id 200
[PE1-xcg-vpnb-ldp-3.3.3.9-200] quit
[PE1-xcg-vpnb-ldp] quit
[PE1-xcg-vpnb] quit
[PE2] l2vpn enable
# On PE 2, create service instance 200 on Ten-GigabitEthernet 1/0/1 to match packets from VLAN 200.
[PE2-Ten-GigabitEthernet1/0/1] service-instance 200
[PE2-Ten-GigabitEthernet1/0/1-srv200] encapsulation s-vid 200
[PE2-Ten-GigabitEthernet1/0/1-srv200] quit
# On PE 2, create cross-connect group vpna, create cross-connect ldp in the group, and bind service instance 100 on Ten-GigabitEthernet 1/0/1 to the cross-connect.
[PE2-xcg-vpna] connection ldp
[PE2-xcg-vpna-ldp] ac interface Ten-GigabitEthernet 1/0/1 service-instance 100
# On PE 2, create an LDP PW for the cross-connect to bind the AC to the PW.
[PE2-xcg-vpna-ldp] peer 1.1.1.9 pw-id 100
[PE2-xcg-vpna-ldp-1.1.1.9-100] quit
[PE2-xcg-vpna-ldp] quit
[PE2-xcg-vpna] quit
# On PE 2, create cross-connect group vpnb, create cross-connect ldp in the group, and bind service instance 200 on Ten-GigabitEthernet 1/0/1 to the cross-connect.
[PE2-xcg-vpnb] connection ldp
[PE2-xcg-vpnb-ldp] ac interface Ten-GigabitEthernet 1/0/1 service-instance 200
[PE2-xcg-vpnb-ldp] peer 1.1.1.9 pw-id 200
[PE2-xcg-vpnb-ldp-1.1.1.9-200] quit
[PE2-xcg-vpnb-ldp] quit
[PE2-xcg-vpnb] quit
# On CE 1, configure the interface connected to the PE to permit tagged packets from the customer VLANs.
<CE1> system-view
[CE1] vlan 100
[CE1-vlan100] quit
[CE1] vlan 200
[CE1-vlan200] quit
[CE1-Ten-GigabitEthernet1/0/1] port trunk permit vlan 100 200
# Display L2VPN PW information on PE 1. The output shows that two LDP PWs have been established.
3.3.3.9 100 65663/65663 LDP M 1 Up
3.3.3.9 200 65662/65662 LDP M 1 Up
# Display L2VPN PW information on PE 2. The output shows that two LDP PWs have been established.
1.1.1.9 100 65663/65663 LDP M 1 Up
1.1.1.9 200 65662/65662 LDP M 1 Up
# Verify that the host and the server in the same VLAN can ping each other. (Details not shown.)
Configuration files
· CE 1 and CE 2:
vlan 100
vlan 200
· PE 1:
ospf 1
area 0.0.0.0
mpls lsr-id 1.1.1.9
vlan 2
mpls ldp
l2vpn enable
interface LoopBack0
mpls enable
mpls ldp enable
port access vlan 2
xconnect-group vpna
connection ldp
xconnect-group vpnb
connection ldp
ac interface Ten-GigabitEthernet1/0/1 service-instance 200
· P:
ospf 1
area 0.0.0.0
mpls lsr-id 2.2.2.9
vlan 2
vlan 3
mpls ldp
interface LoopBack0
mpls enable
mpls ldp enable
mpls enable
mpls ldp enable
port access vlan 3
port access vlan 2
· PE 2:
ospf 1
area 0.0.0.0
mpls lsr-id 3.3.3.9
vlan 3
mpls ldp
l2vpn enable
interface LoopBack0
mpls enable
mpls ldp enable
port access vlan 3
xconnect-group vpna
connection ldp
xconnect-group vpnb
connection ldp
Example: Configuring a BGP PW
As shown in Figure 5, a customer has two VPN sites and will add eight sites in the future. Configure a BGP PW between PE 1 and PE 2 to allow VPN communication between the two sites and reserve enough VPN resources for future extension.
To use BGP PWs to implement MPLS L2VPN, configure two levels of labels:
· Inner labels—PW labels dynamically generated by BGP.
To use BGP to transmit inner labels between PEs, create a service instance and an IBGP connection, and specify the peer PE as a BGP peer on each PE.
To simplify configuration required by future expansion of the customer network, set the maximum number of CEs in the VPN to 10.
<PE1> system-view
[PE1] vlan 2
[PE1-vlan2] quit
[PE1] ospf
[PE1-ospf-1] area 0
[PE1-ospf-1] quit
<P> system-view
[P-LoopBack0] quit
[P] vlan2
[P-vlan2] quit
[P] vlan3
[P-vlan3] quit
[P] ospf
[P-ospf-1] area 0
[P-ospf-1] quit
<PE2> system-view
[PE2] vlan 3
[PE2-vlan3] quit
[PE2] ospf
[PE2-ospf-1] area 0
[PE2-ospf-1] quit
# On PE 1, enable MPLS L2VPN and LDP globally.
[PE1] l2vpn enable
[PE1] mpls ldp
[PE1-ldp] quit
[P] mpls ldp
[P-ldp] quit
# On PE 2, enable MPLS L2VPN and LDP globally.
[PE2] l2vpn enable
[PE2] mpls ldp
[PE2-ldp] quit
3. Establish IBGP connections between PEs:
# On PE 1, establish an IBGP connection to PE 2.
[PE1] bgp 100
[PE1-bgp] peer 3.3.3.9 as-number 100
[PE1-bgp] peer 3.3.3.9 connect-interface loopback 0
# On PE 1, enable BGP to exchange L2VPN information with PE 2.
[PE1-bgp] address-family l2vpn
[PE1-bgp-l2vpn] peer 3.3.3.9 enable
[PE1-bgp-l2vpn] quit
[PE1-bgp] quit
# On PE 1, create cross-connect group vpna, create local site site 1, and create a BGP PW from site 1 to the remote site site 2.
[PE1-xcg-vpna] auto-discovery bgp
[PE1-xcg-vpna-auto] route-distinguisher 2:2
[PE1-xcg-vpna-auto] vpn-target 2:2 export-extcommunity
[PE1-xcg-vpna-auto] vpn-target 2:2 import-extcommunity
[PE1-xcg-vpna-auto] site 1 range 10 default-offset 0
[PE1-xcg-vpna-auto-1] connection remote-site-id 2
# On PE 1, bind service instance 100 on Ten-GigabitEthernet 1/0/1 to the PW.
[PE1-xcg-vpna-auto-1-2] ac interface Ten-GigabitEthernet 1/0/1 service-instance 100
[PE1-xcg-vpna-auto-1-2] return
# On PE 2, establish an IBGP connection to PE 1.
[PE2] bgp 100
[PE2-bgp] peer 1.1.1.9 as-number 100
[PE2-bgp] peer 1.1.1.9 connect-interface loopback 0
# On PE 2, enable BGP to exchange L2VPN information with PE 1.
[PE2-bgp] address-family l2vpn
[PE2-bgp-l2vpn] peer 1.1.1.9 enable
[PE2-bgp-l2vpn] quit
[PE2-bgp] quit
# On PE 2, create cross-connect group vpna, create local site site 2, and create a BGP PW from site 2 to the remote site site 1.
[PE2-xcg-vpna] auto-discovery bgp
[PE2-xcg-vpna-auto] route-distinguisher 2:2
[PE2-xcg-vpna-auto] vpn-target 2:2 export-extcommunity
[PE2-xcg-vpna-auto] vpn-target 2:2 import-extcommunity
[PE2-xcg-vpna-auto] site 2 range 10 default-offset 0
[PE2-xcg-vpna-auto-2] connection remote-site-id 1
# On PE 2, bind service instance 100 on Ten-GigabitEthernet 1/0/1 to the PW.
[PE2-xcg-vpna-auto-2-1] ac interface Ten-GigabitEthernet 1/0/1 service-instance 100
[PE2-xcg-vpna-auto-2-1] return
<CE1> system-view
[CE1] vlan 100
[CE1-vlan100] quit
# Display L2VPN PW information on PE 1. The output shows that a BGP PW has been established.
<PE1> display l2vpn pw
Total number of PWs: 1, 1 up, 0 blocked, 0 down, 0 defect
3.3.3.9 2 65538/65537 BGP M 1 Up
# Display L2VPN PW information on PE 2. The output shows that a BGP PW has been established.
<PE2> display l2vpn pw
1.1.1.9 1 65537/65538 BGP M 1 Up
# Verify that the host and the server can ping each other. (Details not shown.)
Configuration files
· CE 1 and CE 2:
vlan 100
port trunk permit vlan 1 100
· PE 1:
ospf 1
area 0.0.0.0
mpls lsr-id 1.1.1.9
vlan 2
mpls ldp
l2vpn enable
interface LoopBack0
mpls enable
mpls ldp enable
port access vlan 2
bgp 100
peer 3.3.3.9 connect-interface LoopBack0
peer 3.3.3.9 enable
xconnect-group vpna
auto-discovery bgp
· P:
ospf 1
area 0.0.0.0
mpls lsr-id 2.2.2.9
vlan 2
vlan 3
mpls ldp
interface LoopBack0
mpls enable
mpls ldp enable
mpls enable
mpls ldp enable
port access vlan 3
port access vlan 2
· PE 2:
ospf 1
area 0.0.0.0
mpls lsr-id 3.3.3.9
vlan 3
mpls ldp
l2vpn enable
interface LoopBack0
mpls enable
mpls ldp enable
port access vlan 3
bgp 100
peer 1.1.1.9 connect-interface LoopBack0
peer 1.1.1.9 enable
xconnect-group vpna
auto-discovery bgp
Related documentation
· H3C S7500E Switch Series MPLS Configuration Guide-Release 7150
· H3C S7500E Switch Series MPLS Command Reference -Release 7150
