08-MPLS Command Reference
HomeSupportSwitchesS12500 SeriesReference GuidesCommand ReferencesH3C S12500 Command References-Release7374-6W73108-MPLS Command Reference
08-MPLS L2VPN commands
08-MPLS L2VPN commands 153.29 KB
MPLS L2VPN commands
ac interface
Use ac interface to bind an AC to a cross-connect.
Use undo ac interface to remove the binding.
ac interface interface-type interface-number [ service-instance instance-id ] [ access-mode { ethernet | vlan } ]
undo ac interface interface-type interface-number [ service-instance instance-id ]
No AC is bound to a cross-connect.
Cross-connect view
interface-type interface-number: Specifies an interface.
service-instance instance-id: Specifies an Ethernet service instance by its ID in the range of 1 to 4096.
access-mode: Specifies the access mode. By default, the access mode is VLAN for a Layer 3 Ethernet subinterface, a VLAN interface, or an Ethernet service instance, and the access mode is Ethernet for other interfaces.
ethernet: Specifies the Ethernet access mode.
vlan: Specifies the VLAN access mode.
An AC can be a Layer 3 interface or an Ethernet service instance on a Layer 2 Ethernet interface.
After you bind a Layer 3 interface or an Ethernet service instance to a cross-connect, packets received from the interface or those matching the Ethernet service instance are forwarded to the bound PW or another AC.
The access mode determines how the PE treats the VLAN tag in Ethernet frames received from the AC. It also determines how the PE forwards Ethernet frames to the AC.
·     VLAN access mode—Ethernet frames received from the AC must carry a VLAN tag in the Ethernet header. The PE treats the VLAN tag as a P-tag assigned by the service provider. Ethernet frames sent to the AC must also carry the P-tag.
·     Ethernet access mode—If Ethernet frames from the AC have a VLAN tag in the header, the PE treats it as a U-tag and ignores it. Ethernet frames sent to the AC do not carry the P-tag.
The Ethernet service instance specified in this command must have match criteria configured by encapsulation.
# Configure Ethernet service instance 200 on the Layer 2 interface GigabitEthernet 3/0/1 to match packets with an outer VLAN tag of 200, and bind the Ethernet service instance to the cross-connect actopw in the cross-connect group vpn1.
[Sysname] interface GigabitEthernet 3/0/1
[Sysname-GigabitEthernet3/0/1] service-instance 200
[Sysname-GigabitEthernet3/0/1-srv200] encapsulation s-vid 200
[Sysname-GigabitEthernet3/0/1-srv200] quit
[Sysname-GigabitEthernet3/0/1] quit
[Sysname] xconnect-group vpn1
[Sysname-xcg-vpn1] connection actopw
[Sysname-xcg-vpn1-actopw] ac interface GigabitEthernet 3/0/1 service-instance 200
·     connection
·     display l2vpn interface
·     display l2vpn service-instance
·     encapsulation
·     pw-type
connection
Use connection to create a cross-connect and enter cross-connect view. If the specified cross-connect has been created, this command places you into cross-connect view.
Use undo connection to remove a cross-connect.
connection connection-name
undo connection connection-name
No cross-connect is created.
Cross-connect group view
connection-name: Specifies the name of the cross-connect, a case-sensitive string of 1 to 20 characters, excluding hyphens.
A cross-connect is a point-to-point connection. You can perform the following operations in cross-connect view:
·     Execute ac interface and peer to connect an AC to a PW, so the PE can forward packets between the AC and the PW.
·     Execute ac interface twice to connect two ACs, so the PE can forward packets between the two ACs.
·     Execute peer twice to connect two PWs to form a multi-segment PW.
# Create cross-connect ac2pw for cross-connect group vpn1 and enter cross-connect view.
[Sysname-xcg-vpn1] connection ac2pw
[Sysname-xcg-vpn1-ac2pw]
description
Use description to configure a description for a cross-connect group.
Use undo description to remove the description of a cross-connect group.
No description is configured for a cross-connect group.
text: Configures a description, a case-sensitive string of 1 to 80 characters.
# Configure a description of vpws for vpn2 for the cross-connect group vpn2.
[Sysname] xconnect-group vpn2
[Sysname-xcg-vpn2] description vpws for vpn2
display l2vpn xconnect-group
display l2vpn ldp
Use display l2vpn ldp to display LDP PW label information.
display l2vpn ldp [ peer ip-address [ pw-id pw-id ] | xconnect-group group-name ] [ verbose ]
peer ip-address: Displays LDP PW label information advertised by the specified peer PE. The ip-address argument specifies the LSR ID of the peer PE. If you do not specify a peer PE, this command displays LDP PW label information advertised by all peer PEs.
pw-id pw-id: Displays LDP PW label information for the PW specified by its PW ID. The PW ID is in the range of 1 to 4294967295. If you specify peer ip-address without this option, the command displays all LDP PW label information advertised by the peer PE.
xconnect-group group-name: Displays LDP PW label information for the cross-connect group specified by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a cross-connect group, this command displays LDP PW label information for all cross-connect groups.
verbose: Displays detailed information. If you do not specify this keyword, the command displays brief information.
# Display brief information about all LDP PW labels.
<Sysname> display l2vpn ldp
Total number of LDP PWs: 1, 1 up, 0 down
Peer            PW ID/VPLS ID         In/Out Label    State Owner
192.2.2.2       1000                  65563/65562     Up    vpn1
PW ID/VPLS ID
This field displays the PW ID for FEC 128, and displays the VPLS ID of the PE for FEC 129. The device supports only FEC 128.
Owner
Cross-connect group of the PW.
# Display detailed information about all LDP PW labels.
<Sysname> display l2vpn ldp verbose
Peer: 192.2.2.2        PW ID: 1000
  Xconnect-group: vpn1
  Connection    : ldp
  PW State      : Up
  PW Status Communication: Notification method
  PW ID FEC (Local/Remote):
    PW Type     : VLAN/VLAN
    Group ID    : 0/0
    Label       : 65563/65562
    Control Word: Disabled/Disabled
    VCCV CC Type: -/-
    VCCV CV Type: -/-
    MTU         : 1500/1500
    PW Status   : PW forwarding/PW forwarding
Xconnect-group
Connection
Cross-connect of the PW.
PW state communicate:
·     Notification method—Uses notifications to communicate PW states.
·     Label withdraw method—Assigns a PW label to the PW when the AC is up and withdraws the PW label when the AC goes down.
VCCV CC Type
VCCV CC type:
·     Control-Word—PWE3 Control Word with 0001b as first nibble.
·     Router-Alert—MPLS Router Alert Label.
·     TTL—MPLS PW Label with TTL=1.
For information about VCCV, see MPLS Configuration Guide.
VCCV CV Type
VCCV CV type:
·     LSP Ping—Uses MPLS LSP ping to verify PW connectivity.
·     BFD—Uses BFD to verify PW connectivity. BFD packets use IP/UDP encapsulation (with IP/UDP Headers).
·     Raw-BFD—Uses BFD to verify PW connectivity. BFD packets use PW-ACH encapsulation (without IP/UDP Headers).
display l2vpn forwarding
Use display l2vpn forwarding to display cross-connect forwarding information.
In standalone mode:
display l2vpn forwarding { ac | pw } [ xconnect-group group-name ] [ slot slot-number ] [ verbose ]
In IRF mode:
display l2vpn forwarding { ac | pw } [ xconnect-group group-name ] [ chassis chassis-number slot slot-number ] [ verbose ]
ac: Displays AC forwarding information.
pw: Displays PW forwarding information.
xconnect-group group-name: Displays forwarding information for the cross-connect group specified by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a group, this command displays forwarding information for all cross-connect groups.
slot slot-number: Displays cross-connect forwarding information on the specified card. If you do not specify a card, this command displays cross-connect forwarding information on the active MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Displays cross-connect forwarding information for a card on an IRF member device. The chassis-number argument specifies the ID of the IRF member device and the slot-number argument specifies the slot number of the card. If you do not specify this option, the command displays cross-connect forwarding information for the active MPU of the master device. (In IRF mode.)
# Display brief AC forwarding information for all cross-connect groups.
<Sysname> display l2vpn forwarding ac
Total number of cross-connections: 3
Total number of ACs: 3
AC                               Xconnect-group                  Link ID
GE3/0/5 srv1                     vpn1                            0
GE3/0/5 srv2                     vpn2                            1
GE3/0/6                          vpn3                            0
Total number of cross-connects, including cross-connects not bound with any AC.
AC
AC type:
·     Layer 3 interface such as GE3/0/6.
·     Ethernet service instance on a Layer 2 interface, such as GE3/0/5 srv1.
# Display detailed AC forwarding information for all cross-connect groups.
<Sysname> display l2vpn forwarding ac verbose
Xconnect-group: vpws1
 Connection: actopw
  Interface: GE3/0/3   Service Instance: 1
    Link ID      : 1
    Access Mode  : VLAN
    Encapsulation: s-vid 1 to 16
 Connection: actoac
  Interface: Vlan13
    Link ID      : 0
    Access Mode  : VLAN
  Interface: GE3/0/3   Service Instance: 4
    Link ID      : 1
    Access Mode  : VLAN
    Encapsulation: untagged
Xconnect-group
Cross-connect group name.
Connection
Cross-connect name.
Service Instance
The field is available only when the AC is an Ethernet service instance on a Layer 2 Ethernet interface.
Access Mode
AC access mode:
·     VLAN.
·     Ethernet.
Encapsulation
Match criterion of the Ethernet service instance. This field is displayed only when the AC type is Ethernet service instance on a Layer 2 interface.
# Display brief PW forwarding information for all cross-connect groups.
<Sysname> display l2vpn forwarding pw
Total number of cross-connections: 1
Total number of PWs: 2, 2 up, 0 blocked, 0 down
Xconnect-group                  In/Out Label    NID        Link ID    State
vpn1                            1279/1151       1025       0          Up
vpn1                            1278/1151       1027       1          Up
Table 5 Command output
Total number of cross-connects, including those not bound with any PW.
NID
NHLFE ID for the public tunnel that carries the PW.
If equal-cost tunnels are available, this field displays multiple NIDs.
If no tunnel is available, this field displays None.
PW state: Up, Down, Blocked, or BFD Defect.
Blocked indicates that the PW is a backup PW. BFD Defect indicates BFD has detected a defect on the PW.
# Display detailed PW forwarding information for all cross-connect groups.
<Sysname> display l2vpn forwarding pw verbose
 Connection: ldp
  Link ID: 0
    PW Type         : VLAN                  PW State : Up
    In Label        : 1279                  Out Label: 1151
    MTU             : 1500
    PW Attributes   : Main
    VCCV CC         : Router-Alert
    VCCV BFD        : Fault Detection with BFD
    Tunnel Group ID : 0x60000000
    Tunnel NHLFE IDs: 1025
  Link ID: 1
    In Label        : 1278                  Out Label: 1151
    MTU             : 1500
    Tunnel Group ID : 0x160000001
    Tunnel NHLFE IDs: 1027
Table 6 Command output
PW State
PW Attributes
PW attribute:
·     Main—The PW is the primary PW.
·     Backup—The PW is the backup PW.
VCCV CC
VCCV CC type:
·     Control word.
·     Route alert.
·     TTL.
VCCV BFD
VCCV BFD type:
·     Fault Detection with BFD. BFD packets use IP/UDP encapsulation (with IP/UDP Headers).
·     Fault Detection with Raw-BFD. BFD packets use PW-ACH encapsulation (without IP/UDP Headers).
Tunnel Group ID
ID of the tunnel group for the PW.
Tunnel NHLFE IDs
NHLFE IDs of the public tunnels that carry the PW.
If equal-cost tunnels are available, this field displays multiple tunnel NHLFE IDs.
Use display l2vpn interface to display L2VPN information for Layer 3 interfaces bound to cross-connects.
display l2vpn interface [ xconnect-group group-name | interface-type interface-number ]
xconnect-group group-name: Displays L2VPN information for Layer 3 interfaces bound to cross-connects in the cross-connect group specified by its name, a case-sensitive string of 1 to 31 characters.
interface-type interface-number: Displays L2VPN information for the specified interface.
If you do not specify any parameters, this command displays L2VPN information for all Layer 3 interfaces bound to cross-connects.
The command does not display L2VPN information for Ethernet service instances. To display this information, execute the display l2vpn service-instance command.
# Display L2VPN information for all Layer 3 interfaces bound to cross-connects.
<Sysname> display l2vpn interface
Total number of interfaces: 2, 2 up, 0 down
Interface                Owner                           Link ID   State    Type
Vlan10                   vpws1                           0         Up       VPWS
Vlan11                   vpws2                           0         Up       VPWS
Table 7 Command output
Owner
Link ID
Link ID of the AC.
L2VPN type: VPLS or VPWS.
display l2vpn pw
Use display l2vpn pw to display PW information.
display l2vpn pw [ xconnect-group group-name ] [ protocol { bgp | ldp | static } ] [ verbose ]
xconnect-group group-name: Displays PW information for the cross-connect group specified by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a group, this command displays L2VPN PW information for all cross-connect groups.
protocol: Displays L2VPN PW information established by a protocol. If you do not specify a protocol, this command displays L2VPN PW information established by all protocols.
bgp: Displays BGP PW information. This keyword is not supported in the current software version, and is reserved for future support.
ldp: Displays LDP PW information.
static: Displays static PW information.
If you do not specify ldp or static, this command displays both LDP PW and static PW information.
# Display all PW information.
<Sysname> display l2vpn pw
Flags: M - main, B - backup, H - hub link, S - spoke link, N - no split horizon
Total number of PWs: 2, 2 up, 0 blocked, 0 down, 0 defect
Xconnect-group Name: ldp
Peer            PW ID/Rmt Site    In/Out Label    Proto   Flag  Link ID  State
192.3.3.3       1000              65663/65662     LDP     M     0        Up
Table 8 Command output
Flag
PW flag:
·     M—Primary PW.
·     B—Backup PW.
PW ID/Rmt Site
PW ID.
Proto
Protocol that established the PW, LDP or Static.
Link ID
Link ID of the PW.
PW state: Up, Down, Blocked, or Defect.
Blocked indicates that the PW is a backup PW. Defect indicates BFD has detected a defect on the PW.
# Display detailed information about all PWs.
<Sysname> display l2vpn pw verbose
 Connection Name: ldp
  Peer: 192.3.3.3        PW ID: 500
    Signaling Protocol  : LDP
    Link ID             : 0          PW State : Up
    In Label            : 65663      Out Label: 65662
    MTU                 : 1500
    VCCV CC             : -
    VCCV BFD            : -
    Tunnel Group ID     : 0x800000160000000
    Tunnel NHLFE IDs    : 1026
Table 9 Command output
Xconnect-group Name
Connection
Cross-connect name, which is displayed for LDP and static PWs.
Peer
IP address of the peer PE of the PW.
PW State
Wait to Restore Time
Wait time to switch traffic from the backup PW to the primary PW when the primary PW recovers, in seconds. If the switchover is disabled, this field displays Infinite.
This field is available when both primary and backup PW exist, and is displayed only for the primary PW.
Remaining Time
Remaining wait time for traffic switchover, in seconds.
PW Attributes
PW attribute:
·     Main—Primary PW.
·     Backup—Backup PW.
VCCV CC
VCCV CC type:
·     Control word.
·     Route alert.
·     TTL.
VCCV BFD
VCCV BFD type:
Tunnel Group ID
Tunnel NHLFE IDs
display l2vpn pw-class
Use display l2vpn pw-class to display PW class information.
display l2vpn pw-class [ class-name ]
class-name: Displays information about the PW class specified by its name, a case-sensitive string of 1 to 19 characters. If you do not specify a PW class, this command displays information about all PW classes.
# Display information about all PW classes.
<Sysname> display l2vpn pw-class
Total number of PW classes: 2
PW Class Name       PW Type              Control Word   VCCV CC        VCCV BFD
pw1                 Ethernet             Disabled       Control-Word   Raw-BFD
pw2                 VLAN                 Disabled       Router-Alert   BFD
Table 10 Command output
VCCV CC
VCCV CC type: Control-Word, Route-Alert, or TTL.
VCCV BFD
VCCV BFD type:
pw-class
Use display l2vpn service-instance to display Ethernet service instance information.
interface interface-type interface-number: Displays Ethernet service instance information for the specified Layer 2 Ethernet interface. If you do not specify an interface, this command displays Ethernet service instance information for all Layer 2 Ethernet interfaces.
service-instance instance-id: Displays information about the Ethernet service instance specified by its ID. The instance ID is in the range of 1 to 4096. If you specify interface interface-type interface-number without this option, the command displays information about all Ethernet service instances on the specified Layer 2 Ethernet interface.
# Display brief information about all Ethernet service instances.
<Sysname> display l2vpn service-instance
Total number of service-instances: 5, 5 up, 0 down
Total number of ACs: 4, 4 up, 0 down
Interface                SrvID Owner                           LinkID State Type
GE3/0/3                  1     vpws1                           1      Up    VPWS
GE3/0/3                  2     vpws2                           1      Up    VPWS
GE3/0/3                  3     vpws3                           1      Up    VPWS
GE3/0/3                  4     vpws4                           1      Up    VPWS
GE3/0/3                  5                                            Up
Table 11 Command output
SrvID
Ethernet service instance ID.
Owner
Name of the cross-connect group bound to the Ethernet service instance. If no cross-connect group is bound, this field is blank.
# Display detailed information about all Ethernet service instances on the Layer 2 Ethernet interface GigabitEthernet 3/0/1.
<Sysname> display l2vpn service-instance interface GigabitEthernet 3/0/1 verbose
Interface: GE3/0/1
  Service Instance: 1
    Encapsulation : s-vid 1 to 16
    Connection    : actopw
    Link ID       : 1
    State         : Up
  Service Instance: 2
    Encapsulation : s-vid 1001 to 1002 1015 to 1016
                    only-tagged
    Xconnect-group: vpws2
    Connection    : pwtopw
    Link ID       : 1
    State         : Up
Table 12 Command output
Encapsulation
Match criteria of the Ethernet service instance. If no match criteria are configured, the field is blank.
Xconnect-group
Connection
Name of the cross-connect bound to the Ethernet service instance.
service-instance
Use display l2vpn xconnect-group to display cross-connect group information.
display l2vpn xconnect-group [ name group-name ] [ verbose ]
name group-name: Displays information about the cross-connect group specified by its name, a case-sensitive sting of 1 to 31 characters. If you do not specify a group, this command displays information about all cross-connect groups.
# Display brief information about all cross-connect groups.
<Sysname> display l2vpn xconnect-group
Total number of cross-connections: 3, 0 up, 3 down, 0 admin down
Xconnect-group Name             Connection ID   MTU    State
abc                             0               1500   Down
vpn1                            2               1500   Down
vpn2                            1               1500   Down
Table 13 Command output
Connection ID
Cross-connect ID.
Cross-connect group state: Up, Down, or Admin down. Admin down indicates the cross-connect group has been shut down by using the shutdown command.
# Display detailed information about all cross-connect groups.
<Sysname> display l2vpn xconnect-group verbose
 Description   : ldp-pw
 Connection Name   : ldp
  Connection ID    : 1
  State            : Down
  MTU              : 1500
  LDP PWs:
    Peer            PW ID            Link ID    State
    192.3.3.3       200              1          Down
  ACs:
    AC                               Link ID    State
    GE5/0/24 srv100                  0          Up
Table 14 Command output
Xconnect-group Name
Description for the cross-connect group. If no description is configured, this field is not displayed.
Connection Name
Cross-connect name.
Connection ID
Cross-connect ID.
AC
AC type:
·     Layer 3 interface such as GE3/0/4.
·     Ethernet service instance on a Layer 2 interface, such as GE3/0/3 srv1.
xconnect-group
encapsulation
Use encapsulation to configure a packet match criterion for an Ethernet service instance.
Use undo encapsulation to remove a packet match criterion from an Ethernet service instance.
encapsulation s-vid vlan-id [ only-tagged ]
encapsulation { default | tagged | untagged }
undo encapsulation
No packet match criterion is configured for an Ethernet service instance.
Ethernet service instance view
s-vid vlan-id: Matches packets with a specific outer VLAN ID. The vlan-id argument specifies a VLAN ID in the range of 1 to 4094.
only-tagged: Matches tagged packets. If the outer VLAN is not the PVID, the matching result does not differ, whether or not you specify the only-tagged keyword. If the outer VLAN is the PVID, the matching result depends on whether or not the only-tagged keyword is specified.
·     To match only PVID-tagged packets, specify the only-tagged keyword.
·     To match both untagged packets and PVID-tagged packets, do not specify the only-tagged keyword.
default: Matches packets that do not match any other Ethernet service instances on the interface. On an interface, you can configure this criterion only in one Ethernet service instance. The Ethernet service instance matches any packets if it is the only instance on the interface.
untagged: Matches any packets that do not have a VLAN tag.
An Ethernet service instance can contain only one match criterion. To change the match criterion, you must remove the original criterion first. When you remove the match criterion in an Ethernet service instance, the mapping between the Ethernet service instance and the cross-connect is removed automatically.
The encapsulation { default | tagged | untagged } command is not available for MPLS L2VPN.
# Configure Ethernet service instance 1 on GigabitEthernet 3/0/1 to match packets that have an outer VLAN ID of 111.
[Sysname-GigabitEthernet3/0/1] service-instance 1
[Sysname-GigabitEthernet3/0/1-srv1] encapsulation s-vid 111
l2vpn enable
Use l2vpn enable to enable L2VPN.
Use undo l2vpn enable to disable L2VPN.
l2vpn enable
undo l2vpn enable
L2VPN is disabled.
You must enable L2VPN before configuring other L2VPN settings.
# Enable L2VPN.
[Sysname] l2vpn enable
mtu
Use mtu to set an MTU for PWs established on a cross-connect.
mtu mtu
undo mtu
A PW has an MTU of 1500 bytes.
Cross-connect view
mtu: Specifies an MTU value in the range of 328 to 65535.
The PEs at the two ends of an LDP PW must have the same MTU. Otherwise, the PW cannot come up.
The MTU specifies the maximum packet length, including the control word, PW label, and network layer packet.
For an MTU setting to take effect on an interface, you must execute the shutdown command and then the undo shutdown command on the interface.
# Set the MTU to 1400 bytes for the cross-connect ac2pw in the cross-connect group vpn1.
[Sysname-xcg-vpn1-ac2pw] mtu 1400
peer
Use peer to configure a PW for a cross-connect and enter cross-connect PW view. If the specified PW has been created, this command places you into cross-connect PW view.
Use undo peer to delete a PW for a cross-connect.
peer ip-address pw-id pw-id [ in-label label-value out-label label-value ] [ pw-class class-name | tunnel-policy tunnel-policy-name ] *
undo peer ip-address pw-id pw-id
No PW is configured for a cross-connect.
Cross-connect view
ip-address: Specifies the LSR ID of the peer PE.
pw-id pw-id: Specifies a PW ID for the PW, in the range of 1 to 4294967295.
in-label label-value: Specifies the incoming label of the PW, in the range of 16 to 1023.
out-label label-value: Specifies the outgoing label of the PW, in the range of 16 to 1023.
pw-class class-name: Specifies a PW class by its name, a case-sensitive string of 1 to 19 characters. You can specify a PW class to configure the PW type and control word. If you do not specify a PW class, the PW type is determined by the interface type. The control word feature is not supported for PW types that do not require using control word.
tunnel-policy tunnel-policy-name: Specifies a tunnel policy by its name, a case-sensitive string of 1 to 19 characters. If you do not specify a tunnel policy, the default tunnel policy is used.
To create a static PW, you must specify the incoming and outgoing labels. To enter the view of an existing static PW, you do not need to specify the incoming and outgoing labels.
If you do not specify the incoming and outgoing labels when you create a new PW, LDP is used to create the PW.
The PW ID for a PW must be the same on the PEs at the ends of the PW.
The LSR ID of the peer PE and the PW ID uniquely identify a PW, and must not both be the same as those of any VPLS PW or PW bound to a cross-connect.
A static PW must have a different incoming label than an existing static LSP or static CRLSP. If they are the same, the static PW is not available, even if you change the incoming label of the static LSP or the static CRLSP. To make the static PW available, delete the static PW, and reconfigure it with an unused incoming label.
# Configure an LDP PW destined to 4.4.4.4 for the cross-connect pw2pw in the cross-connect group vpn1 and enter cross-connect PW view. The PW ID is 200.
[Sysname-xcg-vpn1] connection pw2pw
[Sysname-xcg-vpn1-pw2pw] peer 4.4.4.4 pw-id 200
[Sysname-xcg-vpn1-pw2pw-4.4.4.4-200]
# Configure a static PW destined to 5.5.5.5 for the cross-connect pw2pw in the cross-connect group vpn1 and enter cross-connect PW view. The static PW has an ID of 200, an incoming label of 100, and an outgoing label of 200.
[Sysname-xcg-vpn1-pw2pw] peer 5.5.5.5 pw-id 200 in-label 100 out-label 200
[Sysname-xcg-vpn1-pw2pw-5.5.5.5-200]
·     display l2vpn ldp
·     display l2vpn pw
·     pw-class
·     tunnel-policy
pw-class
Use pw-class to create a PW class and enter PW class view.
Use undo pw-class to delete a PW class.
pw-class class-name
undo pw-class class-name
No PW class is created.
class-name: Specifies the name of the PW class, a case-sensitive string of 1 to 19 characters.
In PW class view, you can configure PW attributes such as the PW type and control word. PWs with the same attributes can use the same PW class to simplify configuration.
# Create a PW class named pw100 and enter PW view.
[Sysname] pw-class pw100
[Sysname-pw-pw100]
·     display l2vpn pw-class
·     pw-type
pw-type
Use pw-type to specify a PW type for a PW class.
Use undo pw-type to restore the default.
pw-type { ethernet | vlan }
undo pw-type
The PW type is VLAN.
PW class view
ethernet: Specifies the PW type as Ethernet.
vlan: Specifies the PW type as VLAN.
This command takes effect only when the AC type is Ethernet.
Packets are forwarded between the AC and PW as follows according to the PW type:
·     Ethernet—P-tag is not transferred on a PW.
¡     For a packet from a CE:
-     If the packet contains a P-tag, the PE removes the P-tag, and adds a PW label and an outer tag into the packet before forwarding it.
-     If the packet contains no P-tag, the PE directly adds a PW label and an outer tag into the packet before forwarding it.
¡     For a packet to a CE:
-     If the access mode is configured as VLAN by using the ac interface command, the PE adds a P-tag into the packet before sending it to the CE.
-     If the access mode is configured as Ethernet by using the ac interface command, the PE directly sends the packet to the CE.
You cannot rewrite or remove existing tags.
·     VLAN—Packets transmitted over a PW must carry a P-tag.
-     If the peer PE does not require the ingress to rewrite the P-tag, the PE keeps the P-tag unchanged for the packet, and then encapsulates the packet. If the packet contains no P-tag, the PE adds a null label (the label value is 0) into the packet, and then encapsulates the packet.
-     If the peer PE requires the ingress to rewrite the P-tag, the PE changes the P-tag to the expected VLAN tag (the tag value might be 0), and then adds a PW label and an outer tag into the packet. If the packet contains no P-tag, the PE adds a VLAN tag expected by the peer PE (the tag value might be 0), and then adds a PW label and an outer tag into the packet.
-     If the access mode is configured as VLAN by using the ac interface command, the PE rewrites or retains the P-tag before forwarding the packet.
-     If the access mode is configured as Ethernet by using the ac interface command, the PE removes the P-tag before forwarding the packet.
# Configure the PW type as Ethernet.
[Sysname-pw-pw100] pw-type ethernet
·     ac-interface
service-instance
Use service-instance to create an Ethernet service instance on a Layer 2 Ethernet interface and enter Ethernet service instance view.
Use undo service-instance to delete an Ethernet service instance on a Layer 2 Ethernet interface.
undo service-instance instance-id
No Ethernet service instance is created on a Layer 2 Ethernet interface.
instance-id: Specifies the ID of the Ethernet service instance, in the range of 1 to 4096.
# Create Ethernet service instance 1 on the Layer 2 Ethernet interface GigabitEthernet 3/0/1 and enter Ethernet service instance 1 view.
shutdown
Use shutdown to disable a cross-connect group.
Use undo shutdown to restore the default.
shutdown
A cross-connect group is enabled.
After you disable a cross-connect group, all cross-connects in the group cannot provide L2VPN services.
Use the shutdown command when you want to temporarily disable L2VPN (for example, to modify a cross-connect group). After the modification, use the undo shutdown command to enable the cross-connect group. This will provide L2VPN services using the new settings.
# Disable the cross-connect group vpn2.
[Sysname-xcg-vpn2] shutdown
xconnect-group
Use xconnect-group to create a cross-connect group and enter cross-connect group view. If the specified group has been created, this command places you into cross-connect group view.
Use undo xconnect-group to delete a cross-connect group.
undo xconnect-group group-name
No cross-connect group is created.
group-name: Specifies the name of the cross-connect group, a case-sensitive string of 1 to 31 characters excluding hyphens.
L2VPN can create multiple LDP and static PWs for a cross-connect group.
# Create a cross-connect group named vpn1 and enter cross-connect group view.
[Sysname-xcg-vpn1]
