03-Interface Command Reference
HomeSupportSwitchesS12500 SeriesReference GuidesCommand ReferencesH3C S12500 Command References-Release7374-6W73103-Interface Command Reference
02-Ethernet interface commands
02-Ethernet interface commands 257.52 KB
EB cards have the "EB" suffix in their marks, such as LST1GP48LEB1. The similar is true for EC, EF, FC, and FG cards.
You cannot create Layer 3 Ethernet interfaces or subinterfaces, or Layer 3 aggregate interfaces or subinterfaces when the system is operating in standard mode. For more information about switch's operating modes, see Fundamentals Configuration Guide.
Common Ethernet interface commands
bandwidth
Use bandwidth to configure the expected bandwidth of an interface.
bandwidth bandwidth-value
undo bandwidth
Ethernet interface view, Ethernet subinterface view
The expected bandwidth of an interface affects the link costs in OSPF, OSPFv3, and IS-IS. For more information, see Layer 3—IP Routing Configuration Guide.
# Set the expected bandwidth of interface GigabitEthernet 3/0/1 to 1000 kbps.
[Sysname] interface GigabitEthernet 3/0/1
[Sysname-GigabitEthernet3/0/1] bandwidth 1000
# Set the expected bandwidth of subinterface GigabitEthernet 3/0/1.1 to 1000 kbps.
[Sysname] interface GigabitEthernet 3/0/1.1
[Sysname-GigabitEthernet3/0/1.1] bandwidth 1000
speed
default
Use default to restore the default settings for an Ethernet interface or subinterface.
default
CAUTION
CAUTION:
The default command might interrupt ongoing network services. Make sure you are fully aware of the impacts of this command when you use it in a live network.
This command might fail to restore the default settings for some commands for reasons such as command dependencies and system restrictions. Use the display this command in interface view to identify these commands, and then use their undo forms or follow the command reference to restore their default settings. If your restoration attempt still fails, follow the error message instructions to resolve the problem.
# Restore the default settings for interface GigabitEthernet 3/0/1.
[Sysname-GigabitEthernet3/0/1] default
# Restore the default settings for subinterface GigabitEthernet 3/0/1.1.
[Sysname-GigabitEthernet3/0/1.1] default
description
Use description to change the description of an interface.
The description of an interface is the interface name plus Interface (for example, GigabitEthernet3/0/1 Interface).
text: Specifies the interface description, a case-sensitive string of 1 to 255 characters.
# Change the description of interface GigabitEthernet 3/0/1 to lanswitch-interface.
[Sysname-GigabitEthernet3/0/1] description lanswitch-interface
# Change the description of Ethernet subinterface GigabitEthernet 3/0/1.1 to l2-subinterface3/0/1.1.
[Sysname-GigabitEthernet3/0/1.1] description l2-subinterface3/0/1.1
display counters
Use display counters to display interface traffic statistics.
display counters { inbound | outbound } interface [ interface-type [ interface-number | interface-number.subnumber ] ]
inbound: Displays inbound traffic statistics.
outbound: Displays outbound traffic statistics.
interface-number.subnumber: Specifies a subinterface number, where interface-number is an interface number, and subnumber is the number of a subinterface created under the interface. The value range for the subnumber argument is 1 to 4094.
This command displays traffic statistics within a statistics polling interval specified by the flow-interval command.
To clear the Ethernet interface traffic statistics, use the reset counters interface command. For more information, see "reset counters interface."
If you do not specify an interface type, this command displays traffic statistics for all interfaces that have traffic counters.
If you specify an interface type but do not specify an interface number or subinterface number, this command displays traffic statistics for all interfaces of the specified type.
If you specify an interface type and an interface number or subinterface number, this command displays traffic statistics of the specified interface or subinterface.
# Display inbound traffic statistics for all GigabitEthernet interfaces.
<Sysname> display counters inbound interface GigabitEthernet
Interface            Total (pkts)    Broadcast (pkts)    Multicast (pkts)  Err (pkts)
GE3/0/1                      100                100                  0              0
GE3/0/1                        0                  0                  0              0
GE3/0/1                 Overflow           Overflow           Overflow       Overflow
GE3/0/1                        0                  0                  0              0
 Overflow: More than 14 digits (7 digits for column "Err").
       --: Not supported.
Abbreviated interface name.
Total (pkts)
Total number of packets received or sent through the interface.
Broadcast (pkts)
Total number of broadcast packets received or sent through the interface.
Multicast (pkts)
Total number of multicast packets received or sent through the interface.
Err (pkts)
Total number of error packets received or sent through the interface.
The command displays Overflow if any of the following cases applies:
·     The data length of an Err field value is greater than 7 decimal digits.
·     The data length of a non-Err field value is greater than 14 decimal digits.
--: Not supported
The statistical item is not supported.
·     flow-interval
·     reset counters interface
display counters rate
Use display counters rate to display traffic rate statistics of interfaces in up state over the last statistics polling interval.
display counters rate { inbound | outbound } interface [ interface-type [ interface-number | interface-number.subnumber ] ]
inbound: Displays inbound traffic rate statistics.
outbound: Displays outbound traffic rate statistics.
The statistics cover only interfaces in up state.
If you specify an interface type, this command displays traffic rate statistics for all up interfaces of the specified type over the last statistics polling interval.
If you do not specify an interface type, this command displays traffic rate statistics for all up interfaces that have traffic counters over the last statistics polling interval.
If you specify an interface which is always down over the last statistics polling interval, the system prompts that the interface does not support the command.
You can use the flow-interval command to set the statistics polling interval.
# Display the inbound traffic rate statistics for all GigabitEthernet interfaces.
<Sysname> display counters rate inbound interface gigabitethernet
Usage: Bandwidth utilization in percentage
Interface             Usage   Total (pps)    Broadcast (pps)    Multicast (pps)
GE3/0/1                 0%             0                 --                 --
GE3/0/3                 0%             0                 --                 --
GE3/0/6                 0%             0                 --                 --
Overflow: More than 14 digits.
       --: Not supported.
Usage
Bandwidth usage.
Total (pkts/sec)
Average rate (in pps) of receiving or sending packets during the statistics polling interval.
Broadcast (pkts/sec)
Average rate (in pps) of receiving or sending broadcast packets during the statistics polling interval.
Multicast (pkts/sec)
Average rate (in pps) of receiving or sending multicast packets during the statistics polling interval.
Overflow: more than 14 decimal digits
The command displays Overflow if the data length of a statistical item is greater than 14 decimal digits.
--: not supported
·     flow-interval
display ethernet statistics
Use display ethernet statistics to display the Ethernet module statistics.
In standalone mode:
display ethernet statistics slot slot-number
In IRF mode:
display ethernet statistics chassis chassis-number slot slot-number
slot slot-number: Displays the Ethernet module statistics on the specified card. The slot-number argument represents the number of the slot that houses the card. (In standalone mode.)
chassis chassis-number slot slot-number: Displays the Ethernet module statistics on the specified card of the specified IRF member device. The chassis-number argument represents the ID of the IRF member device. The slot-number argument represents the number of the slot that houses the card. (In IRF mode.)
# (In standalone mode.) Display the Ethernet module statistics on slot 2.
<Sysname> display ethernet statistics slot 2
ETH receive packet statistics:
    Totalnum        : 10447          ETHIINum     : 4459
    SNAPNum         : 0              RAWNum       : 0
    LLCNum          : 0              UnknownNum   : 0
    ForwardNum      : 4459           ARP          : 0
    MPLS            : 0              ISIS         : 0
    ISIS2           : 0              IP           : 0
    IPV6            : 0
ETH receive error statistics:
    NullPoint       : 0              ErrIfindex   : 0
    ErrIfcb         : 0              IfShut       : 0
    ErrAnalyse      : 5988           ErrSrcMAC    : 5988
    ErrHdrLen       : 0
ETH send packet statistics:
    L3OutNum        : 211            VLANOutNum   : 0
    FastOutNum      : 155            L2OutNum     : 0
ETH send error statistics:
    MbufRelayNum    : 0              NullMbuf     : 0
    ErrAdjFwd       : 0              ErrPrepend   : 0
    ErrHdrLen       : 0              ErrPad       : 0
    ErrQoSTrs       : 0              ErrVLANTrs   : 0
    ErrEncap        : 0              ErrTagVLAN   : 0
    IfShut          : 0              IfErr        : 0
# (In IRF mode.) Display the Ethernet module statistics on slot 1 of IRF member device 1.
<Sysname> display ethernet statistics chassis 1 slot 1
    MPLS            : 0              ISIS         : 0
    ISIS2           : 0              IP           : 0
    IPV6            : 0
    ErrHdrLen       : 0
Statistics about the Ethernet packets received on the Ethernet interface module.
Totalnum
Total number of received packets:
·     ETHIINum—Number of packets encapsulated by using Ethernet-II.
·     SNAPNum—Number of packets encapsulated by using SNAP.
·     RAWNum—Number of packets encapsulated by using RAW.
·     ISISNum—Number of packets encapsulated by using IS-IS.
·     LLCNum—Number of packets encapsulated by using LLC.
·     UnknownNum—Number of packets encapsulated by using unknown methods.
·     ForwardNum—Number of packets forwarded at Layer 2 or sent to the CPU.
·     ARP—Number of ARP packets.
·     MPLS—Number of MPLS packets.
·     ISIS—Number of IS-IS packets.
·     ISIS2—Number of large 802.3/802.2 frames encapsulated by using IS-IS.
·     IP—Number of IP packets.
·     IPv6—Number of IPv6 packets.
Statistics about the error Ethernet packets in the inbound direction on the Ethernet interface module. Errors might be included in packets or occur during the receiving process. The items include:
·     NullPoint—Number of packets that include null pointers.
·     ErrIfindex—Number of packets that include incorrect interface indexes.
·     ErrIfcb—Number of packets that include incorrect interface control blocks.
·     IfShut—Number of packets that are being received when the interface is shut down.
·     ErrAnalyse—Number of packets that include packet parsing errors.
·     ErrSrcMAC—Number of packets that include incorrect source MAC addresses.
·     ErrHdrLen—Number of packets that include header length errors.
Statistics about the Ethernet packets sent by the Ethernet interface module:
·     L3OutNum—Number of packets sent out of Layer 3 Ethernet interfaces.
·     VLANOutNum—Number of packets sent out of VLAN interfaces.
·     FastOutNum—Number of packets fast forwarded.
·     L2OutNum—Number of packets sent out of Layer 2 Ethernet interfaces.
·     MbufRelayNum—Number of packets transparently sent.
Statistics about the error Ethernet packets in the outbound direction on the Ethernet interface module:
·     NullMbuf—Number of packets with null pointers.
·     ErrAdjFwd—Number of packets with adjacency table errors.
·     ErrPrepend—Number of packets with extension errors.
·     ErrHdrLen—Number of packets with header length errors.
·     ErrPad—Number of packets with padding errors.
·     ErrQoSTrs—Number of packets that failed to be sent by QoS.
·     ErrVLANTrs—Number of packets that failed to be sent in VLANs.
·     ErrEncap—Number of packets that failed to be sent due to link header encapsulation failures.
·     ErrTagVLAN—Number of packets that failed to be sent due to VLAN tag encapsulation failures.
·     IfShut—Number of packets that are being sent when the interface is shut down.
·     IfErr—Number of packets with incorrect outgoing interfaces.
reset ethernet statistics
display interface
Use display interface to display Ethernet interface information.
display interface [ interface-type ] [ brief [ down ] ]
display interface [ interface-type [ interface-number | interface-number.subnumber ] ] [ brief [ description ] ]
down: Displays information about interfaces in the down state and the causes. If you do not specify this keyword, the command displays information about interfaces in all states.
description: Displays complete interface descriptions. If you do not specify this keyword, the command displays only the first 27 characters of interface descriptions.
If you do not specify an interface type, this command displays information about all interfaces.
If you specify an interface type but do not specify an interface number or subinterface number, this command displays information about all interfaces of that type.
If you specify both the interface type and interface number, this command displays information about the specified interface.
# Display information about Layer 3 interface GigabitEthernet 3/0/1.
<Sysname> display interface GigabitEthernet 3/0/1
Current state: DOWN
Line protocol state: DOWN
Description: GigabitEthernet3/0/1 Interface
Bandwidth: 1000000 kbps
Internet address: 10.1.1.2/24 (primary)
IP packet frame type: Ethernet II, hardware address: 7425-8a02-4d03
IPv6 packet frame type: Ethernet II, hardware address: 7425-8a02-4d03
Media type is twisted pair, Port hardware type is 1000_BASE_T
Port priority: 2
Loopback is not set
Unknown-speed mode, Unknown-duplex mode
 Peak input rate: 0 bytes/sec, at 2014-12-29 09:46:13
 Peak output rate: 0 bytes/sec, at 2014-12-29 09:46:13
 Last 300 second input: 0 packets/sec 0 bytes/sec -%
 Last 300 second output: 0 packets/sec 0 bytes/sec -%
 Input (total):  0 packets, 0 bytes
          0 unicasts, 0 broadcasts, 0 multicasts, - pauses
 Input (normal):  0 packets, 0 bytes
          - ignored, - parity errors
 Output (normal): 0 packets, 0 bytes
          - lost carrier, - no carrier
Current state
State of the interface:
·     Administratively DOWN—The Ethernet interface was shut down by using the shutdown command. The interface is administratively down.
·     DOWN—The Ethernet interface is administratively up but physically down. There might not be a physical link present or the link has failed.
·     UP—The Ethernet interface is both administratively and physically up.
Line protocol state
Link layer state of the interface. The state is determined through parameter negotiation on the link layer.
·     UP—The interface is up at the data link layer.
·     UP (spoofing)—The link layer protocol of an interface is UP, but its link is an on-demand link or not present at all. This attribute is typical of Null interfaces and loopback interfaces.
·     DOWN—The interface is down at the data link layer.
·     DOWN (DLDP DOWN)—The link layer protocol of the interface is down because DLDP detected that the link was unidirectional.
·     DOWN (LAGG DOWN)—The link layer protocol of the interface is down because the aggregate interface does not have Selected ports.
·     DOWN (OAM DOWN)—The link layer of the interface is down because OAM detected remote link failures.
·     DOWN (DLDP and LAGG DOWN)—The link layer of the interface is shut down by DLDP and LAGG.
·     DOWN (DLDP and OAM DOWN)—The link layer of the interface is shut down by DLDP and OAM.
·     DOWN (OAM and LAGG DOWN)—The link layer of the interface is shut down by OAM and LAGG.
·     DOWN (DLDP, OAM and LAGG DOWN)—The link layer of the interface is shut down by DLDP, OAM, and LAGG.
Bandwidth
Expected bandwidth of the interface.
Internet protocol processing:
Indicates that the interface cannot process IP packets.
Output queue (Urgent queue: Size/Length/Discards)
Output queue (the number of messages, the maximum number of messages allowed, and the number of dropped messages in the urgent queue).
Output queue (Protocol queue: Size/Length/Discards)
Output queue (the number of messages, the maximum number of messages allowed, and the number of dropped messages in the protocol queue).
Output queue (FIFO queuing: Size/Length/Discards)
Output queue (the number of messages, the maximum number of messages allowed, and the number of dropped messages in the FIFO queue).
Unknown-speed mode
The speed of the interface is unknown because the speed negotiation fails or the interface is physically disconnected.
Unknown-duplex mode
The duplex mode of the interface is unknown because the duplex mode negotiation fails or the interface is physically disconnected.
Time when the reset counters interface command was last used to clear the interface statistics. Never indicates the reset counters interface command has never been used on the interface since the device’s startup.
Last 300 seconds input rate
Average input rate over the last 300 seconds in Bps, bps, and pps.
Last 300 seconds output rate
Average output rate over the last 300 seconds in Bps, bps, and pps.
Input (total):  274955 packets, 26619800 bytes
52694 unicasts, 469 broadcasts, 221792 multicasts, - pauses
Inbound traffic statistics (in packets and bytes) for the interface. All inbound normal and abnormal packets and normal pause frames were counted.
Number of inbound unicast packets, number of inbound broadcasts, number of inbound multicasts, and number of inbound pause frames.
A hyphen (-) indicates that the statistical item is not supported.
Input (normal):  274955 packets, 26619800 bytes
52694 unicasts, 469 broadcasts, 221792 multicasts, 0 pauses
Inbound normal traffic and pause frame statistics (in packets and bytes) for the interface.
Number of inbound normal unicast packets, number of inbound normal broadcasts, number of inbound normal multicasts, and number of inbound normal pause frames.
input errors
Number of inbound error packets.
runts
Number of inbound frames shorter than 64 bytes, in correct format, and containing valid CRCs.
giants
Number of inbound frames larger than the maximum frame length supported on the interface.
·     For an Ethernet interface that does not permit jumbo frames, giants refer to frames larger than 1518 bytes (without VLAN tags) or 1522 bytes (with VLAN tags).
·     For an Ethernet interface that permits jumbo frames, giants refer to frames larger than the maximum length of Ethernet frames that are allowed to pass through, which is configured when you configure jumbo frame support on the interface.
throttles
Number of inbound packets that contained a non-integer number of bytes.
CRC
Total number of inbound frames that had a normal length, but contained CRC errors.
frame
Total number of inbound frames that contained CRC errors and a non-integer number of bytes.
overruns
Number of packets dropped because the input rate of the port exceeded the queuing capability.
aborts
Total number of illegal inbound packets:
·     Fragment frames—CRC error frames shorter than 64 bytes. The length can be an integral or non-integral value.
·     Jabber frames—CRC error frames greater than the maximum frame length supported on the Ethernet interface (with an integral or non-integral length).
¡ For an Ethernet interface that does not permit jumbo frames, jabber frames refer to CRC error frames greater than 1518 bytes (without VLAN tags) or 1522 bytes (with VLAN tags).
¡ For an Ethernet interface that permits jumbo frames, jabber frames refer to CRC error frames greater than the maximum length of Ethernet frames that are allowed to pass through the interface.
·     Symbol error frames—Frames that contained a minimum of one undefined symbol.
·     Unknown operation code frames—Non-pause MAC control frames.
·     Length error frames—Frames whose 802.3 length fields did not match the actual frame length (46 to 1500 bytes).
ignored
Number of inbound frames dropped because the receiving buffer of the port ran low.
parity errors
Total number of frames with parity errors.
Output (total): 275266 packets, 26640959 bytes
52980 unicasts, 488 broadcasts, 221798 multicasts, - pauses
Outbound traffic statistics (in packets and bytes) for the interface. All outbound normal and abnormal packets and normal pause frames were counted.
Number of outbound unicast packets, number of outbound broadcasts, number of outbound multicasts, and number of outbound pause frames.
Output (normal): 275266 packets, 26640959 bytes
52980 unicasts, 488 broadcasts, 221798 multicasts, 0 pauses
Outbound normal traffic and pause frame statistics (in packets and bytes) for the interface.
Number of outbound normal unicast packets, number of outbound normal broadcasts, number of outbound normal multicasts, and number of outbound normal pause frames.
output errors
Number of outbound error packets.
underruns
Number of packets dropped because the output rate of the interface exceeded the output queuing capability. This is a low-probability hardware anomaly.
buffer failures
Number of packets dropped because the transmitting buffer of the interface ran low.
aborts
Number of packets that failed to be transmitted, for example, because of Ethernet collisions.
deferred
Number of frames that the interface deferred to transmit because of detected collisions.
collisions
Number of frames that the interface stopped transmitting because Ethernet collisions were detected during transmission.
late collisions
Number of frames that the interface deferred to transmit after transmitting their first 512 bits because of detected collisions.
lost carrier
Number of carrier losses during transmission. This counter increases by one when a carrier is lost, and applies to serial WAN interfaces.
no carrier
Number of times that the port failed to detect the carrier when attempting to send frames. This counter increases by one when a port failed to detect the carrier, and applies to serial WAN interfaces.
Peak input rate
Peak rate of inbound traffic in Bps, and the time when the peak inbound traffic rate occurred.
Peak output rate
Peak rate of outbound traffic in Bps, and the time when the peak outbound traffic rate occurred.
# Display detailed information about Layer 2 interface GigabitEthernet 3/0/1.
Current state: DOWN
IP packet frame type: Ethernet II, hardware address: 000c-2963-b767
Bandwidth: 100000 kbps
Loopback is not set
Media type is twisted pair, port hardware type is 1000_BASE_T_AN_SFP
Flow-control is not enabled
Maximum frame length: 9216
Allow jumbo frames to pass
Broadcast max-ratio: 100%
Multicast max-ratio: 100%
Unicast max-ratio: 100%
PVID: 1
MDI type: automdix
Port link-type: Access
 Tagged VLANs:    None
 Untagged VLANs: 1
Port priority: 2
Last clearing of counters: 14:34:09 Tue 11/01/2011
 Peak input rate: 0 bytes/sec, at 2013-07-17 22:06:19
 Peak output rate: 0 bytes/sec, at 2013-07-17 22:06:19
          0 CRC, 0 frame, 0 overruns, 0 aborts
          0 ignored, 0 parity errors
 Output: 0 output errors, 0 underruns, 0 buffer failures
          0 lost carrier, 0 no carrier
Table 5 Command output
Current state
State of the Ethernet interface:
·     DOWN—The Ethernet interface is administratively up but physically down (possibly because no physical link is present or the link has failed).
Line protocol current state
Ethernet framing format. PKTFMT_ETHNT_2 indicates that the frames are encapsulated in Ethernet II framing format.
hardware address
MAC address of the interface.
Bandwidth
Loopback is set internal
An internal loopback test is running on the Ethernet interface.
Loopback is set external
An external loopback test is running on the Ethernet interface.
Loopback is not set
No loopback test is running on the Ethernet interface.
10Mbps-speed mode
The interface is operating at 10 Mbps.
100Mbps-speed mode
The interface is operating at 100 Mbps.
1000Mbps-speed mode
The interface is operating at 1000 Mbps.
10Gbps-speed mode
The interface is operating at 10 Gbps.
40Gbps-speed mode
The interface is operating at 40 Gbps.
100Gbps-speed mode
The interface is operating at 100 Gbps.
Unknown-speed mode
half-duplex mode
The interface is operating in half duplex mode.
full-duplex mode
The interface is operating in full duplex mode.
unknown-duplex mode
The interface is configured with the speed auto command.
Link speed type is force link
The interface is configured with a speed (for example, 10 Mbps or 100 Mbps) by using the speed command.
The interface is configured with the duplex auto command.
link duplex type is force link
The interface is configured with a duplex mode (for example, half or full) by using the duplex command.
Maximum Ethernet frame length allowed on the interface.
Allow jumbo frame to pass
The interface allows jumbo frames to pass through.
Broadcast MAX-
Broadcast storm suppression threshold in ratio, pps, or kbps. The unit of the threshold depends on your configuration.
Multicast MAX-
Multicast storm suppression threshold in ratio, pps, or kbps. The unit of the threshold depends on your configuration.
Unicast MAX-
Unicast storm suppression threshold in ratio, pps, or kbps. The unit of the threshold depends on your configuration.
PVID
Port VLAN ID (PVID) of the Ethernet interface.
MDI type
Cable type (depending on your configuration):
·     automdix.
·     mdi.
·     mdix.
Port link-type
Link type of the interface (depending on your configuration):
·     access.
·     trunk.
·     hybrid.
Tagged VLAN ID
VLANs for which the interface sends packets without removing VLAN tags.
Untagged VLAN ID
VLANs for which the interface sends packets after removing VLAN tags.
Port priority
Priority of the interface.
Time when the reset counters interface command was last used to clear statistics on the interface. Never indicates that the reset counters interface command was never used since the device was started.
Peak input rate
Peak output rate
Last 300 seconds input:  0 packets/sec 0 bytes/sec 0%
Last 300 seconds output:  0 packets/sec 0 bytes/sec 0%
Average rate of inbound and outbound traffic in the last 300 seconds, in pps and Bps, and the ratio of the actual rate to the maximum interface rate.
Input(total):  0 packets, 0 bytes
Input(normal):  0 packets, 0 bytes
input errors
Statistics of incoming error packets.
runts
giants
throttles
CRC
frame
overruns
aborts
ignored
parity errors
Output(total): 0 packets, 0 bytes
Output(normal): 0 packets, 0 bytes
output errors
Number of outbound packets with errors.
underruns
buffer failures
Number of packets dropped because the transmit buffer of the interface ran low.
aborts
deferred
collisions
late collisions
lost carrier
no carrier
# Display brief information about all interfaces.
Protocol: (s) – spoofing
GE3/0/0              UP   UP       10.1.1.2           Link to CoreRouter
GE3/0/1              DOWN DOWN     --
Loop0                UP   UP(s)    2.2.2.9
NULL0                UP   UP(s)    --
Vlan1                UP   DOWN     --
Vlan999              UP   UP       192.168.1.42
Speed: (a) - auto
GE3/0/2               DOWN auto    A      A    1
GE3/0/3               UP   100M(a) F(a)   A    1    aaaaaaaaaaaaaaaaaaaaaaaaaaa
GE3/0/4               DOWN auto    A      A    1
GE3/0/5               DOWN auto    A      A    1
GE3/0/6               UP   100M(a) F(a)   A    1
GE3/0/7               DOWN auto    A      A    1
GE3/0/8               UP   100M(a) F(a)   A    1
GE3/0/9               UP   100M(a) F(a)   A    999
# Display brief information about interface GigabitEthernet 3/0/3, including the complete interface description.
<Sysname> display interface GigabitEthernet 3/0/3 brief description
Speed: (a) - auto
GE3/0/3               UP   100M(a) F(a)   A    1    aaaaaaaaaaaaaaaaaaaaaaaaaaaaa
aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
# Display information about interfaces in DOWN state and the causes.
GE3/0/1               DOWN Not connected
GE3/0/2              DOWN Not connected
GE3/0/4              DOWN Not connected
GE3/0/5              DOWN Not connected
GE3/0/7              DOWN Not connected
Table 6 Command output
Brief information about Layer 3 interfaces.
·     ADM—The interface has been shut down by the network administrator. To recover its physical layer state, run the undo shutdown command.
·     Stby—The interface is a standby interface.
This field displays UP (s), where s represents the spoofing flag, when the following conditions exist:
·     The network layer protocol of an interface is UP.
·     Its link is an on-demand link or not present.
This attribute is typical of interface Null 0 and loopback interfaces.
Interface name.
Link
Physical link state of the interface:
·     UP—The link is up.
·     DOWN—The link is physically down.
·     ADM—The link has been administratively shut down. To recover its physical state, run the undo shutdown command.
Protocol
Link layer protocol state of the interface:
·     UP.
·     DOWN.
·     UP(s)—The link of the interface is an on-demand link or not present at all.
Primary IP
Main IP address of the interface. If the interface is not configured with an IP address, this field displays --.
Partial or complete interface description configured by using the description command:
·     If the description keyword is not specified in the display interface brief command, the field displays the first 27 characters of the interface description.
·     If the description keyword is specified in the display interface brief command, the field displays the complete interface description.
Brief information about Layer 2 interfaces.
Speed: (a) - auto
If the speed of an interface is automatically negotiated, its speed attribute includes the autonegotiation flag, indicated by the letter a in parentheses.
If the duplex mode of an interface is automatically negotiated, its duplex mode attribute includes the following options:
·     (a)/A—Autonegotiation.
·     H—Half negotiation.
·     F—Full negotiation.
Type: A - access; T - trunk; H – hybrid
Link type options for Ethernet interfaces.
Speed
Interface rate, in bps.
Duplex
Duplex mode of the interface:
·     A—Autonegotiation.
·     F—Full duplex.
·     F(a)—Autonegotiated full duplex.
·     H—Half duplex.
·     H(a)—Autonegotiated half duplex.
Link type of the interface:
·     A—Access.
·     H—Hybrid.
·     T—Trunk.
PVID
Port VLAN ID.
Cause
Causes for the physical state of an interface to be DOWN.
·     Administratively—The port is manually shut down by using the shutdown command. To restore the physical state of the interface, use the undo shutdown command.
·     DOWN ( Link-Aggregation interface down )—After an aggregate interface is shut down, the physical state of all member ports of the aggregate interface becomes DOWN. The cause is displayed as DOWN ( Link-Aggregation interface down ).
·     DOWN (Loopback detection down)—The port is shut down because the loopback detection module has detected loops.
·     DOWN ( Monitor-Link uplink down )—The port is shut down because the monitor link module has detected that the uplink is down.
·     IRF-link-down—When IRF detects that the IRF link is down on an MDC of a member device, the state of all physical interfaces except the excluded ports on the MDC of the member device is set to DOWN. The cause is displayed as IRF-link-down.
·     MAD ShutDown—After an IRF split, the state of all interfaces except the excluded ports in the IRF in recovery state is set to DOWN. The cause is displayed as MAD ShutDown.
·     Not connected—No physical connection exists (possibly because the network cable is disconnected or faulty).
·     Storm-Constrain—The port is shut down because the unknown unicast traffic, multicast traffic, or broadcast traffic exceeds the upper limit.
·     STP DOWN—The port is shut down by the STP BPDU guard function.
·     Port Security Disabled—The port is shut down by the intrusion detection mechanism because the port receives illegal packets.
·     Standby—The interface is a standby interface.
duplex
IMPORTANT
IMPORTANT:
100-GE interfaces do not support this command.
Use duplex to set the duplex mode for an Ethernet interface.
Use undo duplex to restore the default duplex mode of the Ethernet interface.
duplex { auto | full | half }
undo duplex
·     A 10-GE or 40-GE interface operates in full duplex mode.
·     A GE interface operates in autonegotiation mode.
auto: Configures the interface to autonegotiate the duplex mode with the peer.
full: Configures the interface to operate in full duplex mode. In this mode, the interface can receive and transmit packets at the same time.
half: Configures the interface to operate in half duplex mode. In this mode, the interface can only receive or transmit packets at a given time. This keyword is not supported in the current software version and is reserved for future support.
# Configure interface GigabitEthernet 3/0/1 to operate in full duplex mode.
[Sysname-GigabitEthernet3/0/1] duplex full
flag sdh
Use flag sdh to set the value for the overhead byte J0 or J1 in SDH frames when the 10-GE interface operates in WAN mode.
Use undo flag sdh to restore the default value of the J0 or J1 byte.
flag { j0 | j1 } sdh value
undo flag { j0 | j1 } sdh
The J0 and J1 bytes are padded with 0s.
Ten-GigabitEthernet interface view
j0: Specifies the Path Trace byte in the Regenerator Section Overhead.
j1: Specifies the Path Trace byte in the High-Order Path Overhead.
value: Specifies the value for the J0 or J1 byte, a string of 1 to 15 characters.
This command is effective only when the 10-GE interface is operating in WAN mode.
# Set the value of the J0 byte in SDH frames to Sysname on interface Ten-GigabitEthernet 3/0/1.
[Sysname] interface ten-gigabitethernet 3/0/1
[Sysname-Ten-GigabitEthernet3/0/1] port-mode wan
[Sysname-Ten-GigabitEthernet3/0/1] flag j0 sdh Sysname
port-mode
flow-control
IMPORTANT
IMPORTANT:
The flow-control command is mutually exclusive with the priority-flow-control command.
Use flow-control to enable generic flow control on an Ethernet interface.
Use undo flow-control to disable generic flow control on the Ethernet interface.
flow-control
undo flow-control
Generic flow control is disabled on an Ethernet interface.
With the flow-control command configured, an interface can both send and receive flow control frames:
·     When congested, the interface sends a flow control frame to its peer.
·     Upon receiving a flow control frame from the peer, the interface suspends sending packets.
# Enable TxRx mode generic flow control on the interface GigabitEthernet 3/0/1.
[Sysname-GigabitEthernet3/0/1] flow-control
flow-interval
Use flow-interval to set the interface statistics polling interval.
Use undo flow-interval to restore the default interval.
flow-interval interval
undo flow-interval
The interface statistics polling interval is 300 seconds.
interval: Sets the statistics polling interval, in seconds. The interval is in the range of 5 to 300 and must be a multiple of 5.
# Set the statistics polling interval to 100 seconds on GigabitEthernet 3/0/1.
[Sysname-GigabitEthernet3/0/1] flow-interval 100
interface
Use interface to enter interface or subinterface view.
When the interface-number.subnumber argument is specified and the subinterface identified by the argument does not exist, this command creates the subinterface and enters subinterface view.
# Enter GigabitEthernet 3/0/1 interface view.
# Create Ethernet subinterface GigabitEthernet 3/0/1.1 and enter GigabitEthernet 3/0/1.1 subinterface view.
jumboframe enable
Use jumboframe enable to allow jumbo frames within the specified length to pass through.
Use undo jumboframe enable to prevent jumbo frames from passing through.
jumboframe enable [ value ]
·     The Ethernet interfaces on the device allows jumbo frames within 9216 bytes to pass through.
·     The Ethernet interfaces on the LST1XP16LEB1 and LST1XP16LEC1 cards allow jumbo frames within 8164 bytes to pass through.
Layer 2 Ethernet interface view, Layer 3 Ethernet interface view
value: Sets the maximum length of Ethernet frames that are allowed to pass through. The value range for this argument is 1552 to 9216 bytes.
If you set the value argument multiple times, the most recent configuration takes effect.
# Enable jumbo frames to pass through GigabitEthernet 3/0/1.
[Sysname-GigabitEthernet3/0/1] jumboframe enable
link-delay
Use link-delay to set the physical state change suppression interval on an Ethernet interface.
Use undo link-delay to restore the default.
link-delay [msec] delay-time mode { up | updown }
undo link-delay
The suppression interval for both the link-up and link-down events on an Ethernet interface is 1 second.
msec: Enables the physical state change suppression time to be accurate to milliseconds. If you do not specify this keyword, the suppression time is accurate to seconds.
delay-time: Sets the physical state change suppression interval on the Ethernet interface. A value of 0 indicates that physical state changes are immediately reported to the CPU and are not suppressed.
·     If you do not specify the msec keyword, the value range for this argument is 0 to 30 seconds, and the value must be an integer. Values 11 through 30 are not supported in the current software version and are reserved for future support.
·     If you specify the msec keyword, the value range for this argument is 0 to 10000 milliseconds, and the value must be a multiple of 100.
mode up: Suppresses the link-up events.
mode updown: Suppresses both the link-up and link-down events.
With the link-delay [msec] delay-time mode up command configured:
·     When the interface comes up, the link-up event is not reported to the CPU unless the interface is still up when the suppression interval (delay-time) expires.
·     When the interface goes down, the link-down event is immediately reported.
With the link-delay [msec] delay-time mode updown command configured:
·     When the interface goes down, the link-down event is not reported to the CPU unless the interface is still down when the suppression interval (delay-time) expires.
On a port, if you configure the link-delay command multiple times, the most recent configuration takes effect.
Do not configure this command on a port with RRPP, MSTP, or Smart Link enabled.
When you configure the link-delay [msec] command on an Ethernet interface, the actual suppression interval is 0 to 100 milliseconds longer than the configured time. For example, if you configure the suppression interval as 100 milliseconds, the actual value is in the range of 100 to 200 milliseconds.
When you configure the link-delay command on an Ethernet interface, the actual suppression interval is 0 to 1 second longer than the configured time. For example, if you configure the suppression interval as 1 second, the actual value is 1 or 2 seconds.
# Set the link-up and link-down event suppression interval to 8 seconds on interface GigabitEthernet 3/0/1.
[Sysname-GigabitEthernet3/0/1] link-delay 8 mode updown
loopback
CAUTION
CAUTION:
After you enable loopback testing on an Ethernet interface, the interface does not forward data traffic.
Use loopback to enable loopback testing on an Ethernet interface.
Use undo loopback to disable loopback testing on an Ethernet interface.
undo loopback
Loopback testing is disabled on an Ethernet interface.
external: Enables external loopback testing on the Ethernet interface. This keyword is not supported in the current software version and is reserved for future support.
internal: Enables internal loopback testing on the Ethernet interface.
You cannot enable loopback testing on an administratively shut down interface (displayed as in ADM or Administratively DOWN state).
After you enable loopback testing on an interface, you cannot configure the speed, duplex, mdix-mode, port up-mode, and shutdown commands on the interface.
After you enable loopback testing on an Ethernet interface, the Ethernet interface switches to full duplex mode. After you disable loopback testing, the Ethernet interface restores to its duplex setting.
# Enable internal loopback testing on GigabitEthernet 3/0/1.
[Sysname-GigabitEthernet3/0/1] loopback internal
port link-mode
Use port link-mode to change the link mode of an Ethernet interface.
Use undo port link-mode to restore the default.
undo port link-mode
An Ethernet interface is operating in bridge mode as a Layer 2 Ethernet interface.
bridge: Specifies the Layer 2 mode.
route: Specifies the Layer 3 mode.
Interfaces operate differently depending on the hardware structure of interface cards.
·     Interfaces on EB cards can operate only as Layer 2 Ethernet interfaces.
·     Other interfaces can operate either as Layer 2 or Layer 3 Ethernet interfaces.
You can use commands to set the link mode to bridge or route.
After you change the link mode of an Ethernet interface, all the commands (except the shutdown command) on the Ethernet interface are restored to their defaults in the new link mode.
# Configure GigabitEthernet 3/0/1 to operate in Layer 2 mode.
[Sysname-GigabitEthernet3/0/1] port link-mode bridge
port-mode
Use port-mode to configure the operating mode for a 10-GE, 40-GE, or 100-GE interface.
Use undo port-mode to restore the default.
port-mode { lan | wan }
undo port-mode
A 10-GE, 40-GE, or 100-GE interface operates in LAN mode.
Interface view
lan: Configures the interface to operate in LAN mode. A port operating in this mode transmits Ethernet packets and connects an Ethernet network.
wan: Configures the interface to operate in WAN mode. A port operating in this mode transmits SDH packets and connects an SDH network. In addition, it supports point-to-point links only. 40-GE and 100-GE interfaces do not support the WAN mode.
# Configure the interface Ten-GigabitEthernet 3/0/1 to operate in WAN mode.
Use priority-flow-control to enable PFC on an Ethernet interface through automatic negotiation or forcibly.
Use undo priority-flow-control to disable PFC on the interface.
priority-flow-control { auto | enable }
PFC is disabled on Ethernet interfaces.
auto: Specifies PFC in auto mode. In this mode, the Ethernet interface automatically negotiates the PFC status with its peer.
enable: Forcibly enables PFC.
The state of the PFC function is co-determined by the PFC configurations on the local port and on the peer. In Table 7:
·     The first line lists the PFC configuration on the local port.
·     The first column lists the PFC configuration on the peer.
·     The Enabled and Disabled fields in the other cells are the two possible negotiation results.
Table 7 PFC configurations and negotiation results
Local (right)
Peer (below)
enable
auto
disable
enable
Enabled
Enabled.
Disabled
auto
Enabled
·     Enabled if negotiation succeeds.
·     Disabled if negotiation fails.
Disabled
disable
Disabled
Disabled.
Disabled
This command is mutually exclusive with the flow-control command.
This command is applicable only to these interface cards: LST1XP48LFD1, LST1XP48LFD2, LST1XP40RFD1, LST1XP40RFD2, LST1XP40RFG1, LST1XP40RFG2, LST1CP4RFD1, LST1CP4RFD2, LST1CP4RFG1, LST1CP4RFG2, LST1XP20RFD1, LST1XP20RFD2, LST1XLP16RFD1, and LST1XLP16RFD2.
When configuring PFC for interfaces on an LST1XLP16RFD1 or LST1XLP16RFD2 interface card, follow these restrictions and guidelines:
·     PFC is applicable to both the 40-GE interfaces and 10-GE breakout interfaces split from 40-GE interfaces.
·     The sixteen 40-GE interfaces on an interface card are divided into four groups by their numbers. Interfaces numbered 1 through 4 belong to one group, interfaces numbered 5 through 8 belong to another group, and so forth. H3C recommends not splitting all interfaces in a group into 10-GE breakout interfaces. If you split all interfaces in a group into 10-GE breakout interfaces, PFC is applicable to none of the 10-GE breakout interfaces.
Physical IRF ports do not support PFC. In IRF mode, do not enable PFC on physical IRF ports of IRF member devices. For more information, see Virtual Technologies Configuration Guides.
To disable PFC on an Ethernet interface, you must disable PFC for all 802.1p priorities first. You can disable PFC for all 802.1p priorities by using the undo priority-flow-control no-drop dot1p command in the interface view.
# Forcibly enable PFC on interface GigabitEthernet 3/0/1.
[Sysname-GigabitEthernet3/0/1] priority-flow-control enable
IMPORTANT
IMPORTANT:
Before configuring this command on an Ethernet interface, you must enable PFC on the interface first by using the priority-flow-control command.
Use priority-flow-control no-drop dot1p to enable PFC for 802.1p priorities on an Ethernet interface.
Use undo priority-flow-control no-drop dot1p to restore the default.
priority-flow-control no-drop dot1p dot1p-list
PFC is disabled for all 802.1p priorities.
dot1p-list: Specifies an 802.1p priority (or dot1p priority) list to identify flows that are subject to PFC (for example: 1,3-5). A hyphen (-) connects two numeric values, which together indicate a continuous value range. Different values or value ranges are separated with commas (,). You can configure up to 16 characters for this argument.
To map the 802.1p priorities to the local priorities, use the qos map-table command. For more information, see ACL and QoS Configuration Guide.
Before enabling PFC for an 802.1p priority, make sure the 802.1p priority is mapped to only one local priority.
In standalone mode, you cannot enable PFC for the 802.1p priority that has been mapped to local priority 0. In IRF mode, you cannot enable PFC for the 802.1p priority that has been mapped to local priority 0 or 7.
When network congestion occurs, the local device sends a PFC pause frame to the peer if both the local end and the peer end meet the following requirements:
·     Have PFC enabled.
·     Have the priority-flow-control no-drop dot1p command configured.
The peer stops sending packets carrying an 802.1p priority within the list specified by the dot1p-list argument until the congestion is removed.
# Forcibly enable PFC on interface GigabitEthernet 3/0/1, and enable PFC for 802.1p priority 5.
[Sysname-GigabitEthernet3/0/1] priority-flow-control no-drop dot1p 5
·     priority-flow-control
·     flow-control
Use reset counters interface to clear the Ethernet interface or subinterface statistics.
reset counters interface [ interface-type [ interface-number | interface-number.subnumber ] ]
interface-number.subnumber: Specifies a subinterface number, where interface-number is an interface number; subnumber is the number of a subinterface created under the interface. The value range for the subnumber argument is 1 to 4094.
Before collecting statistics for an interface within a specific time period, clear the previous statistics.
If you do not specify an interface type, this command clears statistics for all interfaces.
If you specify only the interface type, this command clears statistics for all interfaces of that type.
If you specify both the interface type and the interface or subinterface number, this command clears statistics for the specified interface or subinterface.
# Clear the statistics of GigabitEthernet 3/0/1.
<Sysname> reset counters interface GigabitEthernet 3/0/1
·     display interface
·     display counters interface
·     display counters rate interface
Use reset ethernet statistics to clear the Ethernet module statistics.
In standalone mode:
reset ethernet statistics slot slot-number
In IRF mode:
reset ethernet statistics chassis chassis-number slot slot-number
slot slot-number: Clears the Ethernet module statistics on the specified card. The slot-number argument represents the number of the slot that houses the card. (In standalone mode.)
chassis chassis-number slot slot-number: Clears the Ethernet module statistics on the specified card of the specified IRF member device. The chassis-number argument represents the ID of the IRF member device. The slot-number argument represents the number of the slot that houses the card. (In IRF mode.)
# (In standalone mode.) Clear the Ethernet module statistics on slot 6.
<Sysname> reset ethernet statistics slot 6
# (In IRF mode.) Clear the Ethernet module statistics on slot 1 of IRF member device 1.
<Sysname> reset ethernet statistics chassis 1 slot 1
shutdown
Use shutdown to shut down an Ethernet interface or subinterface.
Use undo shutdown to bring up an Ethernet interface or subinterface.
shutdown
An Ethernet interface is down, and an Ethernet subinterface is up.
You might need to shut down and then bring up an Ethernet interface to make some interface configurations take effect.
# Shut down and then bring up GigabitEthernet 3/0/1.
[Sysname-GigabitEthernet3/0/1] shutdown
[Sysname-GigabitEthernet3/0/1] undo shutdown
# Shut down and then bring up GigabitEthernet 3/0/1.1.
[Sysname-GigabitEthernet3/0/1.1] shutdown
[Sysname-GigabitEthernet3/0/1.1] undo shutdown
speed
Use speed to set the speed of an Ethernet interface.
Use undo speed to restore the default.
speed { 10 | 100 | 1000 | 10000 | 40000 | 100000 | auto }
undo speed
The speed of an Ethernet interface is autonegotiated.
10: Sets the interface speed to 10 Mbps. This keyword is applicable only to fiber ports using a transceiver module and copper ports.
100: Sets the interface speed to 100 Mbps. This keyword is applicable only to fiber ports using a transceiver module, 100/1000-Mbps transceiver module, or 100-Mbps transceiver module and copper ports.
1000: Sets the interface speed to 1000 Mbps. This keyword is applicable only to fiber ports using a 100/1000-Mbps transceiver module or 1000-Mbps transceiver module and copper ports.
10000: Sets the interface speed to 10000 Mbps.
40000: Sets the interface speed to 40000 Mbps.
100000: Sets the interface speed to 100000 Mbps.
auto: Enables the interface to negotiate a speed with its peer.
For an Ethernet copper port, use the speed command to set its speed to match the speed of the peer interface.
For a fiber port, use the speed command to set its speed to match the rate of a transceiver module.
The 10000 keyword is applicable only to 10-GE interfaces.
The 40000 keyword is applicable only to 16-port 40-GE interface cards.
The 100000 keyword is applicable only to 4-port 100-GE interface cards.
When you connect a 10-GE interface to a 100-Mbps interface through a transceiver module, you must set the speed of the 10-GE interface to 100 Mbps.
# Configure GigabitEthernet 3/0/1 to autonegotiate the speed.
[Sysname-GigabitEthernet3/0/1] speed auto
speed auto
using fortygige
IMPORTANT
IMPORTANT:
·     This command is not supported on non-default MDCs.
·     10-GE breakout interfaces split from a 40-GE interface on the default MDC can be assigned to non-default MDCs.
Use using fortygige to combine four 10-GE breakout interfaces that are split from a 40-GE interface into a 40-GE interface.
Use undo using fortygige to cancel the configuration.
using fortygige
A 40-GE interface is used as a single interface.
10-GE breakout interface view
If you need higher bandwidth, you can combine four 10-GE breakout interfaces that are split from a 40-GE interface into a 40-GE interface. To make this command take effect on the four 10-GE breakout interfaces, execute this command on only one of the 10-GE breakout interfaces.
After this command is successfully configured, you must reboot the device. The system deletes the four 10-GE breakout interface and creates the combined 40-GE interface.
Before rebooting a switch configured with this command, save the combining configuration even if the switch is an IRF member switch.
# Combine 10-GE breakout interfaces Ten-GigabitEthernet 1/0/16:1 through Ten-GigabitEthernet 1/0/16:4 into a 40-GE interface.
<System> system-view
[System] interface Ten-GigabitEthernet1/0/16:1
[System-Ten-GigabitEthernet1/0/16:1] using fortygige
The interfaces Ten-GigabitEthernet1/0/16:1 through Ten-GigabitEthernet1/0/16:4 will be deleted. Continue? [Y/N]:y
Reboot the line card to make the configuration take effect.
using tengige
using tengige
IMPORTANT
IMPORTANT:
Use using tengige to split a 40-GE interface into multiple 10-GE breakout interfaces.
Use undo using tengige to cancel the configuration.
using tengige
undo using tengige
A 40-GE interface is used as a single interface, and is not split.
40-GE interface view
To improve port density, reduce costs, and improve network flexibility, you can split a 40-GE interface into multiple 10-GE breakout interfaces. For example, you can split a 40-GE interface FortyGigE 1/0/49 into four 10-GE interfaces Ten-GigabitEthernet 1/0/49:1 through Ten-GigabitEthernet 1/0/49:4.
10-GE breakout interfaces support the same configuration and attributes as common 10-GE interfaces, except that they are numbered differently.
This command is applicable to 40-GE interfaces only on the LST1XLP16RFD1 and LST1XLP16RFD2 interface cards.
Before configuring this command for a fiber port, you must insert a 40-GE QSFP+ transceiver module into the fiber port.
You can split up to ten 40-GE interfaces into 10-GE breakout interfaces on each interface card.
After this command is successfully configured, you must reboot the device. The system deletes the 40-GE interface and creates the multiple 10-GE breakout interfaces.
Before rebooting a switch configured with this command, save the splitting configuration even if the switch is an IRF member switch.
The sixteen 40-GE interfaces on an LST1XLP16RFD1 or LST1XLP16RFD2 card are divided into four groups by their numbers. Interfaces numbered 1 through 4 belong to one group, interfaces numbered 5 through 8 belong to another group, and so forth. H3C recommends not splitting all interfaces in a group into 10-GE breakout interfaces. If you split all 40-GE interfaces in a group into 10-GE breakout interfaces, PFC is applicable to none of the 10-GE breakout interfaces.
# Split 40-GE interface FortyGigE 1/0/16 into four 10-GE breakout interfaces.
[System] interface FortyGigE 1/0/16
[System-FortyGigE1/0/16] using tengige
The interface FortyGigE1/0/16 will be deleted. Continue? [Y/N]:y
·     using fortygige
·     using hundredgige
Layer 2 Ethernet interface commands
broadcast-suppression
Use broadcast-suppression to enable broadcast suppression and set the broadcast suppression threshold.
Use undo broadcast-suppression to restore the default.
Ethernet interfaces do not suppress broadcast traffic.
ratio: Sets the broadcast suppression threshold as a percentage of the maximum interface rate. The value range for this argument is 0 to 100. The smaller the percentage, the less broadcast traffic is allowed to pass through. The parameter is not supported in the current software version and is reserved for future support.
pps max-pps: Specifies the maximum number of broadcast packets that the interface can forward per second. The value range for the max-pps argument (in pps) is 0 to 1.4881 × the maximum interface rate. For example, the value range for this argument is 0 to 1488100 on a GE interface and 0 to 59524000 on a 40-GE interface.
kbps max-kbps: Specifies the maximum number of kilobits of broadcast traffic that the Ethernet interface can forward per second. The value range for this argument (in kbps) is 0 to the maximum interface rate.
You can use the broadcast storm suppression function to limit the size of broadcast traffic on an interface. When the broadcast traffic on the interface exceeds this threshold, the system drops packets until the traffic drops below this threshold.
When you configure the suppression threshold in pps or kbps, the device might convert the configured value into a multiple of a certain step supported by the chip. As a result, the actual suppression threshold might be different from the configured one. To determine the suppression threshold that takes effect, see the prompts on the device.
# Set the broadcast suppression threshold to 10000 kbps on GigabitEthernet 3/0/1.
[Sysname-GigabitEthernet3/0/1] broadcast-suppression kbps 10000
·     multicast-suppression
·     unicast-suppression
mdix-mode
IMPORTANT
IMPORTANT:
Fiber ports do not support this command.
Use mdix-mode to configure the Medium Dependent Interface Cross-Over (MDIX) mode of an Ethernet interface.
Use undo mdix-mode to restore the default.
mdix-mode { automdix | mdi| mdix }
undo mdix-mode
Ethernet interfaces operate in automdix mode.
automdix: Specifies that the interface negotiates pin roles with its peer.
mdi: Specifies that pins 1 and 2 are transmit pins and pins 3 and 6 are receive pins.
mdix: Specifies that pins 1 and 2 are receive pins and pins 3 and 6 are transmit pins.
# Set GigabitEthernet 3/0/1 to operate in MDI mode.
[Sysname-GigabitEthernet3/0/1] mdix-mode mdi
Use multicast-suppression to enable multicast storm suppression and set the multicast storm suppression threshold.
Use undo multicast-suppression to restore the default.
Ethernet interfaces do not suppress multicast traffic.
ratio: Sets the multicast suppression threshold as a percentage of the maximum interface rate. The value range for this argument (in percentage) is 0 to 100. The smaller the percentage, the less multicast traffic is allowed to pass through. The parameter is not supported in the current software version and is reserved for future support.
pps max-pps: Specifies the maximum number of multicast packets that the interface can forward per second. The value range for the max-pps argument (in pps) is 0 to 1.4881 × the maximum interface rate. For example, the value range for this argument is 0 to 1488100 on a GE interface and 0 to 59524000 on a 40-GE interface.
kbps max-kbps: Specifies the maximum number of kilobits of multicast traffic that the Ethernet interface can forward per second. The value range for this argument (in kbps) is 0 to the maximum interface rate.
You can use the multicast storm suppression function to limit the size of multicast traffic on an interface. When the multicast traffic on the interface exceeds this threshold, the system drops packets until the traffic drops below this threshold.
# Set the multicast storm suppression threshold to 10000 kbps on GigabitEthernet 3/0/1.
[Sysname-GigabitEthernet3/0/1] multicast-suppression kbps 10000
·     broadcast-suppression
port connection-mode
Use port connection-mode to set the connection mode for an interface.
Use undo port connection-mode to restore the default.
port connection-mode { extend | normal }
An interface operates in normal connection mode.
extend: Sets the interface to operate in extend connection mode.
normal: Sets the interface to operate in normal connection mode.
To ensure the communication between the device and the card in an OAA network, configure the internal interface connecting them to operate in extend connection mode.
This command is applicable only to the internal interfaces on an LST1NSM1A1 card (OAP card). For more information about the internal interfaces on an LST1NSM1A1 card, see OAA Configuration Guide.
# Set interface Ten-GigabitEthernet 3/0/1 to operate in extend connection mode.
[Sysname] interface Ten-GigabitEthernet 3/0/1
[Sysname-Ten-GigabitEthernet3/0/1] port connection-mode extend
port up-mode
Use port up-mode to forcibly bring up a fiber port.
Use undo port up-mode to restore the default.
port up-mode
undo port up-mode
A fiber port is not forcibly brought up. The physical state of a fiber port depends on the physical state of the fibers.
You can use this command to forcibly bring up a fiber Ethernet port, and enable the port to forward packets unidirectionally over a single link. In this way, transmission links are well utilized.
A fiber port forcibly brought up stays physically up whether or not a transceiver module or fiber connections are present for the port.
Only 10-GE and 40-GE fiber ports operating in LAN mode and GE fiber ports support this command. Copper ports do not support this command.
To configure this command on a port, make sure the port is operating in bridge mode.
The port up-mode command is mutually exclusive with any of the shutdown, and loopback commands.
A fiber port forcibly brought up cannot correctly forward traffic if you install a fiber-to-copper converter, 100/1000-Mbps transceiver module, or 100-Mbps transceiver module into the port. To solve the problem, use the undo port up-mode command on the fiber port.
# Forcibly bring up the fiber port GigabitEthernet 3/0/1.
[Sysname] interface GigabitEthernet 3/0/1
[Sysname-GigabitEthernet3/0/1] port up-mode
speed auto
Use speed auto to set options for speed autonegotiation.
speed auto { 10 | 100 | 1000 } *
undo speed
The options for speed autonegotiation include 10, 100, and 1000.
100-Mbps or Gigabit Layer 2 Ethernet interface view
10: Sets 10 Mbps as an option for speed autonegotiation.
100: Sets 100 Mbps as an option for speed autonegotiation.
1000: Sets 1000 Mbps as an option for speed autonegotiation.
The speed command and the speed auto command supersede each other. The most recent command that you configure takes effect.
If you configure speed 100 after configuring speed auto 100 1000 on an interface, the interface speed is set to 100 Mbps by force without negotiation.
If you configure speed auto 100 1000 after configuring speed 100 on the interface, the interface negotiates with its peer. The negotiated speed is either 100 Mbps or 1000 Mbps.
Speed autonegotiation enables an Ethernet interface to negotiate with its peer for the highest speed that both ends support by default. You can narrow down the speed option list for negotiation. To avoid negotiation failure, make sure a minimum of one speed option is supported at both ends.
# Configure the port GigabitEthernet 3/0/1 to use 10 Mbps and 1000 Mbps for speed negotiation.
[Sysname-GigabitEthernet3/0/1] speed auto 10 1000
speed
unicast-suppression
Use unicast-suppression to enable unicast storm suppression and set the unicast storm suppression threshold.
Use undo unicast-suppression to restore the default.
Ethernet interfaces do not suppress unicast traffic.
ratio: Sets the unicast suppression threshold as a percentage of the maximum interface rate. The value range for this argument (in percentage) is 0 to 100. The smaller the percentage, the less unicast traffic is allowed to pass through.
pps max-pps: Specifies the maximum number of unicast packets that the interface can forward per second. The value range for the max-pps argument (in pps) is 0 to 1.4881 × the maximum interface rate. For example, the value range for the argument is 0 to 1488100 on a GE interface and 0 to 59524000 on a 40-GE interface.
kbps max-kbps: Specifies the maximum number of kilobits of unicast traffic that the Ethernet interface can forward per second. The value range for this argument (in kbps) is 0 to the maximum interface rate.
You can use the unicast storm suppression function to limit the size of unicast traffic on an interface. When the unicast traffic on the interface exceeds this threshold, the system discards packets until the unicast traffic drops below this threshold.
# Set the unicast storm suppression threshold to 10000 kbps on GigabitEthernet 3/0/1.
[Sysname-GigabitEthernet3/0/1] unicast-suppression kbps 10000
Layer 3 Ethernet interface or subinterface commands
mtu
Use mtu to set the MTU for an Ethernet interface or subinterface.
mtu size
undo mtu
The MTU of an Ethernet interface or subinterface is 1500 bytes.
Layer 3 Ethernet interface view, Layer 3 Ethernet subinterface view
size: Sets the maximum transmission unit (MTU) in the range of 64 to 9198 bytes.
As the MTU size decreases, the number of fragments grows. When you set the MTU for an interface, consider QoS queue lengths to prevent a too small MTU from causing packet drops in QoS queuing. For example, consider that the default FIFO queue length is 75. To achieve the best result, you can tune the MTU by using the mtu command or tune QoS queue lengths by using the qos fifo queue-length command. For more information about the qos fifo queue-length command, see ACL and QoS Command Reference.
# Set the MTU to 1430 bytes for Layer 3 Ethernet interface GigabitEthernet 3/0/1.
[Sysname-GigabitEthernet3/0/1] mtu 1430
# Set the MTU to 1400 bytes for Layer 3 Ethernet subinterface GigabitEthernet 3/0/1.1.
[Sysname] interface GigabitEthernet 3/0/1.1
[Sysname-GigabitEthernet3/0/1.1] mtu 1430
