08-MPLS Configuration Guide
HomeSupportSwitchesS12500 SeriesConfigure & DeployConfiguration GuidesH3C S12500 Configuration Guides-Release7374-6W73108-MPLS Configuration Guide
04-MPLS TE configuration
04-MPLS TE configuration 583.52 KB
Configuring MPLS TE· 1
Overview·· 1
TE and MPLS TE· 1
MPLS TE basic concepts 1
Static CRLSP establishment 1
Dynamic CRLSP establishment 1
Traffic forwarding· 3
Make-before-break· 4
Route pinning· 5
Tunnel reoptimization· 5
Automatic bandwidth adjustment 5
CRLSP backup· 6
FRR· 6
DiffServ-aware TE· 7
Bidirectional MPLS TE tunnel 9
Protocols and standards 10
MPLS TE configuration task list 10
Enabling MPLS TE· 11
Configuring a tunnel interface· 12
Configuring DS-TE· 12
Configuring an MPLS TE tunnel to use a static CRLSP· 13
Configuring an MPLS TE tunnel to use a dynamic CRLSP· 13
Configuration task list 14
Configuring MPLS TE attributes for a link· 14
Advertising link TE attributes by using IGP TE extension· 15
Configuring MPLS TE tunnel constraints 16
Establishing an MPLS TE tunnel by using RSVP-TE· 18
Controlling CRLSP path selection· 18
Controlling MPLS TE tunnel setup· 20
Configuring traffic forwarding· 23
Configuring static routing to direct traffic to an MPLS TE tunnel 23
Configuring automatic route advertisement to direct traffic to an MPLS TE tunnel 23
Configuring a bidirectional MPLS TE tunnel 24
Configuring CRLSP backup· 25
Configuring MPLS TE FRR· 26
Enabling FRR· 26
Configuring a bypass tunnel on the PLR· 26
Configuring node fault detection· 30
Configuring the optimal bypass tunnel selection interval 31
Displaying and maintaining MPLS TE· 31
MPLS TE configuration examples 32
Establishing an MPLS TE tunnel over a static CRLSP· 32
Establishing an MPLS TE tunnel with RSVP-TE· 37
Establishing an inter-AS MPLS TE tunnel with RSVP-TE· 43
Bidirectional MPLS TE tunnel configuration example· 50
CRLSP backup configuration example· 57
Manual bypass tunnel for FRR configuration example· 60
Auto FRR configuration example· 66
IETF DS-TE configuration example· 73
Troubleshooting MPLS TE· 80
No TE LSA generated· 80
Overview
TE and MPLS TE
Network congestion can degrade the network backbone performance. It might occur when network resources are inadequate or when load distribution is unbalanced. Traffic engineering (TE) is intended to avoid the latter situation where partial congestion might occur because of improper resource allocation.
TE can make the best use of network resources and avoid uneven load distribution by the following:
·     Real-time monitoring of traffic and traffic load on network elements.
·     Dynamic tuning of traffic management attributes, routing parameters, and resources constraints.
MPLS TE combines the MPLS technology and traffic engineering. It reserves resources by establishing LSP tunnels along the specified paths, allowing traffic to bypass congested nodes to achieve appropriate load distribution.
With MPLS TE, a service provider can deploy traffic engineering on the existing MPLS backbone to provide various services and optimize network resources management.
·     CRLSP—Constraint-based Routed Label Switched Path. To establish a CRLSP, you must configure routing, and specify constrains, such as the bandwidth and explicit paths.
·     MPLS TE tunnel—A virtual point-to-point connection from the ingress node to the egress node. Typically, an MPLS TE tunnel consists of one CRLSP. To deploy CRLSP backup or transmit traffic over multiple paths, you need to establish multiple CRLSPs for one class of traffic. In this case, an MPLS TE tunnel consists of a set of CRLSPs. An MPLS TE tunnel is identified by an MPLS TE tunnel interface on the ingress node. When the outgoing interface of a traffic flow is an MPLS TE tunnel interface, the traffic flow is forwarded through the CRLSP of the MPLS TE tunnel.
A static CRLSP is established by manually specifying the incoming label, outgoing label, and other constraints on each hop along the path that the traffic travels. Static CRLSPs feature simple configuration, but they cannot automatically adapt to network changes.
For more information about static CRLSPs, see "Configuring a static CRLSP."
Dynamic CRLSPs are dynamically established as follows:
1.     An IGP advertises TE attributes for links.
2.     MPLS TE uses the CSPF algorithm to calculate the shortest path to the tunnel destination. The path must meet constraints such as bandwidth and explicit routing.
3.     A label distribution protocol (such as RSVP-TE) advertises labels to establish CRLSPs and reserves bandwidth resources on each node along the calculated path.
Dynamic CRLSPs adapt to network changes and support CRLSP backup and fast reroute, but they require complicated configurations.
Advertising TE attributes
MPLS TE uses extended link state IGPs, such as OSPF and IS-IS, to advertise TE attributes for links.
TE attributes include the maximum bandwidth, maximum reservable bandwidth, non-reserved bandwidth for each priority, and the link attribute. The IGP floods TE attributes on the network. Each node collects the TE attributes of all links on all routers within the local area or at the same level to build up a TE database (TEDB).
Calculating paths
Based on the TEDB, MPLS TE uses the Constraint-based Shortest Path First (CSPF) algorithm, an improved SPF algorithm, to calculate the shortest, TE constraints-compliant path to the tunnel destination.
CSPF first prunes TE constraints-incompliant links from the TEDB. Then it performs SPF calculation to identify the shortest path (a set of LSR addresses) to an egress. CSPF calculation is usually performed on the ingress node of an MPLS TE tunnel.
TE constraints include the bandwidth, affinity, setup and holding priorities, and explicit path. They are configured on the ingress node of an MPLS TE tunnel.
·     Bandwidth
Bandwidth constraints specify the class of service and the required bandwidth for the traffic to be forwarded along the MPLS TE tunnel. A link complies with the bandwidth constraints when the reservable bandwidth for the class type is greater than or equal to the bandwidth required by the class type.
·     Affinity
Affinity determines which links a tunnel can use. The affinity attribute and its mask, and the link attribute are all 32-bit long. A link is available for a tunnel if the link attribute meets the following requirements:
¡     The link attribute bits corresponding to the affinity attribute's 1 bits whose mask bits are 1 must have at least one bit set to 1.
¡     The link attribute bits corresponding to the affinity attribute's 0 bits whose mask bits are 1 must have no bit set to 1.
The link attribute bits corresponding to the 0 bits in the affinity mask are not checked.
For example, if the affinity attribute is 0xFFFFFFF0 and its mask is 0x0000FFFF, a link is available for the tunnel when its link attribute bits meet the following requirements:
¡     The highest 16 bits each can be 0 or 1 (no requirements).
¡     The 17th through 28th bits must have at least one bit whose value is 1.
¡     The lowest four bits must be 0.
·     Setup priority and holding priority
If MPLS TE cannot find a qualified path to set up an MPLS TE tunnel, it removes an existing MPLS TE tunnel and preempts its bandwidth.
MPLS TE uses the setup priority and holding priority to make preemption decisions. For a new MPLS TE tunnel to preempt an existing MPLS TE tunnel, the setup priority of the new tunnel must be higher than the holding priority of the existing tunnel. Both setup and holding priorities are in the range of 0 to 7. A smaller value indicates a higher priority.
To avoid flapping caused by improper preemptions, the setup priority value of a tunnel must be equal to or greater than the holding priority value.
·     Explicit path
Explicit path specifies the nodes to pass and the nodes to not pass for a tunnel.
Explicit paths include the following types:
¡     Strict explicit path—Among the nodes that the path must traverse, a node and its previous hop must be connected directly.
¡     Loose explicit path—Among the nodes that the path must traverse, a node and its previous hop can be connected indirectly.
Strict explicit path precisely specifies the path that an MPLS TE tunnel must traverse. Loose explicit path vaguely specifies the path that an MPLS TE tunnel must traverse. Strict explicit path and loose explicit path can be used together to specify that some nodes are directly connected and some nodes have other nodes in between.
Setting up a CRLSP through RSVP-TE
After calculating a path by using CSPF, MPLS TE uses a label distribution protocol to set up the CRLSP and reserves resources on each node of the path.
The device supports the label distribution protocol of RSVP-TE for MPLS TE. Resource Reservation Protocol (RSVP) reserves resources on each node along a path. Extended RSVP can support MPLS label distribution and allow resource reservation information to be transmitted with label bindings. This extended RSVP is called RSVP-TE.
For more information about RSVP, see "Configuring RSVP."
Traffic forwarding
After an MPLS TE tunnel is established, traffic is not forwarded on the tunnel automatically. You must direct the traffic to the tunnel by using one of the following methods.
Static routing
You can direct traffic to an MPLS TE tunnel by creating a static route that reaches the destination through the tunnel interface. This is the easiest way to implement MPLS TE tunnel forwarding. When the traffic to multiple networks is to be forwarded through the MPLS TE tunnel, you must configure multiple static routes, which are complicated to configure and difficult to maintain.
For more information about static routing, see Layer 3—IP Routing Configuration Guide.
Automatic route advertisement
You can also configure automatic route advertisement to forward traffic through an MPLS TE tunnel. Automatic route advertisement distributes the MPLS TE tunnel to the IGP (OSPF or IS-IS), so the MPLS TE tunnel can participate in IGP routing calculation. Automatic route advertisement is easy to configure and maintain.
Automatic route advertisement can be implemented by using the following methods:
·     IGP shortcut—Also known as AutoRoute Announce. It considers the MPLS TE tunnel as a link that directly connects the tunnel ingress node and the egress node. Only the ingress node uses the MPLS TE tunnel during IGP route calculation.
·     Forwarding adjacency—Considers the MPLS TE tunnel as a link that directly connects the tunnel ingress node and the egress node, and advertises the link to the network through an IGP. Every node in the network uses the MPLS TE tunnel during IGP route calculation.
Figure 1 IGP shortcut and forwarding adjacency diagram
As shown in Figure 1, an MPLS TE tunnel is present from Router D to Router C. IGP shortcut enables only the ingress node Router D to use the MPLS TE tunnel in the IGP route calculation. Router A cannot use this tunnel to reach Router C. With forwarding adjacency enabled, Router A can also know the existence of the MPLS TE tunnel. Router A can use this tunnel to transfer traffic to Router C by forwarding the traffic to Router D.
Make-before-break
Make-before-break is a mechanism to change an MPLS TE tunnel with minimum data loss and without using extra bandwidth.
In cases of tunnel reoptimization and automatic bandwidth adjustment, traffic forwarding is interrupted if the existing CRLSP is removed before a new CRLSP is established. The make-before-break mechanism makes sure that the existing CRLSP is removed after the new CRLSP is established and the traffic is switched to the new CRLSP. However, this wastes bandwidth resources if some links on the old and new CRLSPs are the same. This is because you need to reserve bandwidth on these links for the old and new CRLSPs separately. The make-before-break mechanism uses the SE resource reservation style to address this problem.
The resource reservation style refers to the style in which RSVP-TE reserves bandwidth resources during CRLSP establishment. The resource reservation style used by an MPLS TE tunnel is determined by the ingress node, and is advertised to other nodes through RSVP.
The device supports the following resource reservation styles:
·     FF—Fixed-filter, where resources are reserved for individual senders and cannot be shared among senders on the same session.
·     SE—Shared-explicit, where resources are reserved for senders on the same session and shared among them. SE is mainly used for make-before-break.
Figure 2 Diagram for make-before-break
As shown in Figure 2, a CRLSP with 30 M reserved bandwidth has been set up from Router A to Router D through the path Router A—Router B—Router C—Router D.
To increase the reserved bandwidth to 40 M, a new CRLSP must be set up through the path Router A—Router E—Router C—Router D. To achieve this purpose, RSVP-TE needs to reserve 30 M bandwidth for the old CRLSP and 40 M bandwidth for the new CRLSP on the link Router C—Router D. However, there is not enough bandwidth.
Using the make-before-break mechanism, the new CRLSP can share the bandwidth reserved for the old CRLSP. After the new CRLSP is set up, traffic is switched to the new CRLSP without service interruption, and then the old CRLSP is removed.
Route pinning
Route pinning enables CRLSPs to always use the original optimal path even if a new optimal route has been learned.
On a network where route changes frequently occur, you can use route pinning to avoid re-establishing CRLSPs upon route changes.
Tunnel reoptimization allows you to manually or dynamically trigger the ingress node to recalculate a path. If the ingress node recalculates a better path, it creates a new CRLSP, switches traffic from the old CRLSP to the new, and then deletes the old CRLSP.
MPLS TE uses the tunnel reoptimization function to implement dynamic CRLSP optimization. For example, if a link on the optimal path does not have enough reservable bandwidth, MPLS TE sets up the tunnel on another path. When the link has enough bandwidth, the tunnel optimization function can switch the MPLS TE tunnel to the optimal path.
Because users cannot estimate accurately how much traffic they need to transmit through a service provider network, the service provider should be able to do the following:
·     Create MPLS TE tunnels with the bandwidth initially requested by the users.
·     Automatically tune the bandwidth resources when user traffic increases.
MPLS TE uses the automatic bandwidth adjustment function to meet this requirement. After the automatic bandwidth adjustment is enabled, the device periodically samples the output rate of the tunnel and computes the average output rate within the sampling interval. When the auto bandwidth adjustment frequency timer expires, MPLS TE resizes the tunnel bandwidth to the maximum average output rate sampled during the adjustment time for new CRLSP establishment. If the new CRLSP is set up successfully, MPLS TE switches traffic to the new CRLSP and clears the old CRLSP.
You can use a command to limit the maximum and minimum bandwidth. If the tunnel bandwidth calculated by auto bandwidth adjustment is greater than the maximum bandwidth, MPLS TE uses the maximum bandwidth to set up the new CRLSP. If it is smaller than the minimum bandwidth, MPLS TE uses the minimum bandwidth to set up the new CRLSP.
CRLSP backup
CRLSP backup uses a CRLSP to back up a primary CRLSP. When the ingress detects that the primary CRLSP fails, it switches traffic to the backup CRLSP. When the primary CRLSP recovers, the ingress switches traffic back.
CRLSP backup has the following modes:
·     Hot standby—A backup CRLSP is created immediately after a primary CRLSP is created.
·     Ordinary—A backup CRLSP is created after the primary CRLSP fails.
FRR
Fast reroute (FRR) protects CRLSPs from link and node failures. FRR can implement 50-millisecond CRLSP failover.
After FRR is enabled for an MPLS TE tunnel, once a link or node fails on the primary CRLSP, FRR reroutes the traffic to a bypass tunnel. The ingress node attempts to set up a new CRLSP. After the new CRLSP is set up, traffic is forwarded on the new CRLSP.
CRLSP backup provides end-to-end path protection for a CRLSP without time limitation. FRR provides quick but temporary protection for a link or node on a CRLSP.
Basic concepts
·     Primary CRLSPProtected CRLSP.
·     Bypass tunnelAn MPLS TE tunnel used to protect a link or node of the primary CRLSP.
·     Point of local repair—A PLR is the ingress node of the bypass tunnel. It must be located on the primary CRLSP but must not be the egress node of the primary CRLSP.
·     Merge point—An MP is the egress node of the bypass tunnel. It must be located on the primary CRLSP but must not be the ingress node of the primary CRLSP.
Protection modes
FRR provides the following protection modes:
·     Link protection—The PLR and the MP are connected through a direct link and the primary CRLSP traverses this link. When the link fails, traffic is switched to the bypass tunnel. As shown in Figure 3, the primary CRLSP is Router ARouter BRouter CRouter D, and the bypass tunnel is Router BRouter FRouter C. This mode is also called next-hop (NHOP) protection.
Figure 3 FRR link protection
·     Node protection—The PLR and the MP are connected through a device and the primary CRLSP traverses this device. When the device fails, traffic is switched to the bypass tunnel. As shown in Figure 4, the primary CRLSP is Router ARouter BRouter CRouter DRouter E, and the bypass tunnel is Router BRouter FRouter D. Router C is the protected device. This mode is also called next-next-hop (NNHOP) protection.
Figure 4 FRR node protection
DiffServ-aware TE
DiffServ is a model that provides differentiated QoS guarantees based on class of service. MPLS TE is a traffic engineering solution that focuses on optimizing network resources allocation.
DiffServ-aware TE (DS-TE) combines DiffServ and TE to optimize network resources allocation on a per-service class basis. DS-TE defines different bandwidth constraints for class types. It maps each traffic class type to the CRLSP that is constraint-compliant for the class type.
The device supports these DS-TE modes:
·     Prestandard mode—H3C proprietary DS-TE.
·     IETF mode—Complies with RFC 4124, RFC 4125, and RFC 4127.
Basic concepts
·     CT—Class Type. DS-TE allocates link bandwidth, implements constraint-based routing, and performs admission control on a per class type basis. A given traffic flow belongs to the same CT on all links.
·     BC—Bandwidth Constraint. BC restricts the bandwidth for one or more CTs.
·     Bandwidth constraint model—Algorithm for implementing bandwidth constraints on different CTs. A BC model comprises two factors, the maximum number of BCs (MaxBC) and the mappings between BCs and CTs. DS-TE supports two BC models, Russian Dolls Model (RDM) and Maximum Allocation Model (MAM).
·     TE class—Defines a CT and a priority. The setup priority or holding priority of an MPLS TE tunnel for a CT must be the same as the priority of the TE class.
The prestandard and IETF modes of DS-TE have the following differences:
·     The prestandard mode supports two CTs (CT 0 and CT 1), eight priorities, and up to 16 TE classes. The IETF mode supports four CTs (CT 0 through CT 3), eight priorities, and up to eight TE classes.
·     The prestandard mode does not allow you to configure TE classes. The IETF mode allows for TE class configuration.
·     The prestandard mode supports only RDM. The IETF mode supports both RDM and MAM.
·     A device operating in prestandard mode cannot communicate with devices from some vendors. A device operating in IETF mode can communicate with devices from other vendors.
How DS-TE operates
A device takes the following steps to establish an MPLS TE tunnel for a CT:
1.     Determines the CT.
A device classifies traffic according to your configuration:
¡     When configuring a dynamic MPLS TE tunnel, you can use the mpls te bandwidth command on the tunnel interface to specify a CT for the traffic to be forwarded by the tunnel.
¡     When configuring a static MPLS TE tunnel, you can use the bandwidth keyword to specify a CT for the traffic to be forwarded along the tunnel.
2.     Checks whether bandwidth is enough for the CT.
You can use the mpls te max-reservable-bandwidth command on an interface to configure the bandwidth constraints of the interface. The device determines whether the bandwidth is enough to establish an MPLS TE tunnel for the CT.
The relation between BCs and CTs varies by BC model:
In RDM model, a BC constrains the total bandwidth of multiple CTs, as shown in Figure 5:
·     BC 2 is for CT 2. The total bandwidth for CT 2 cannot exceed BC 2.
·     BC 1 is for CT 2 and CT 1. The total bandwidth for CT 2 and CT 1 cannot exceed BC 1.
·     BC 0 is for CT 2, CT 1, and CT 0. The total bandwidth for CT 2, CT 1, and CT 0 cannot exceed BC 0. In this model, BC 0 equals the maximum reservable bandwidth of the link.
In cooperation with priority preemption, the RDM model can also implement bandwidth isolation between CTs. RDM is suitable for networks where traffic is unstable and traffic bursts might occur.
Figure 5 RDM bandwidth constraints model
In MAM model, a BC constrains the bandwidth for only one CT. This ensures bandwidth isolation among CTs no matter whether preemption is used or not. Compared with RDM, MAM is easier to configure. MAM is suitable for networks where traffic of each CT is stable and no traffic bursts occur. Figure 6 shows an example:
·     BC 0 is for CT 0. The bandwidth occupied by the traffic of CT 0 cannot exceed BC 0.
·     BC 1 is for CT 1. The bandwidth occupied by the traffic of CT 1 cannot exceed BC 1.
·     BC 2 is for CT 2. The bandwidth occupied by the traffic of CT 2 cannot exceed BC 2.
·     The total bandwidth occupied by CT 0, CT 1, and CT 2 cannot exceed the maximum reservable bandwidth.
Figure 6 MAM bandwidth constraints model
3.     Checks whether the CT and the LSP setup/holding priority match an existing TE class.
An MPLS TE tunnel can be established for the CT only when the following conditions are met:
¡     Every node along the tunnel has a TE class that matches the CT and the LSP setup priority.
¡     Every node along the tunnel has a TE class that matches the CT and the LSP holding priority.
MPLS Transport Profile (MPLS-TP) uses bidirectional MPLS TE tunnels to implement 1:1 and 1+1 protection switching and support in-band detection tools and signaling protocols such as OAM and PSC.
A bidirectional MPLS TE tunnel includes a pair of CRLSPs in opposite directions. It can be established in the following modes:
·     Co-routed modeUses the extended RSVP-TE protocol to establish a bidirectional MPLS TE tunnel. RSVP-TE uses a Path message to advertise the labels assigned by the upstream LSR to the downstream LSR. RSVP-TE uses a Resv message to advertise the labels assigned by the downstream LSR to the upstream LSR. During the delivery of the path message, a CRLSP in one direction is established. During the delivery of the Resv message, a CRLSP in the other direction is established. The CRLSPs of a bidirectional MPLS TE tunnel established in co-routed mode use the same path.
·     Associated modeIn this mode, you establish a bidirectional MPLS TE tunnel by binding two unidirectional CRLSPs in opposite directions. The two CRLSPs can be established in different modes and use different paths. For example, one CRLSP is established statically and the other CRLSP is established dynamically by RSVP-TE.
For more information about establishing MPLS TE tunnel through RSVP-TE, the Path message, and the Resv message, see "Configuring RSVP."
·     RFC 2702, Requirements for Traffic Engineering Over MPLS
·     RFC 3564, Requirements for Support of Differentiated Service-aware MPLS Traffic Engineering
·     RFC 3812, Multiprotocol Label Switching (MPLS) Traffic Engineering (TE) Management Information Base (MIB)
·     RFC 4124, Protocol Extensions for Support of Diffserv-aware MPLS Traffic Engineering
·     RFC 4125, Maximum Allocation Bandwidth Constraints Model for Diffserv-aware MPLS Traffic Engineering
·     RFC 4127, Russian Dolls Bandwidth Constraints Model for Diffserv-aware MPLS Traffic Engineering
·     ITU-T Recommendation Y.1720, Protection switching for MPLS networks
To configure an MPLS TE tunnel to use a static CRLSP, complete the following tasks:
1.     Enable MPLS TE on each node and interface that the MPLS TE tunnel traverses.
2.     Create a tunnel interface on the ingress node of the MPLS TE tunnel, and specify the tunnel destination address (the address of the egress node).
3.     Create a static CRLSP on each node that the MPLS TE tunnel traverses.
For information about creating a static CRLSP, see "Configuring a static CRLSP."
4.     On the ingress node of the MPLS TE tunnel, configure the tunnel interface to reference the created static CRLSP.
5.     On the ingress node of the MPLS TE tunnel, configure static routing or automatic route advertisement to direct traffic to the MPLS TE tunnel.
To configure an MPLS TE tunnel to use a CRLSP dynamically established by RSVP-TE, complete the following tasks:
1.     Enable MPLS TE and RSVP on each node and interface that the MPLS TE tunnel traverses.
For information about enabling RSVP, see "Configuring RSVP."
2.     Create a tunnel interface on the ingress node of the MPLS TE tunnel, specify the tunnel destination address (the address of the egress node), and configure the MPLS TE tunnel constraints (such as the tunnel bandwidth constraints and affinity) on the tunnel interface.
3.     Configure the link TE attributes (such as the maximum link bandwidth and link attribute) on each interface that the MPLS TE tunnel traverses.
4.     Configure an IGP on each node that the MPLS TE tunnel traverses, and configure the IGP to support MPLS TE. Then, the nodes can advertise the link TE attributes through the IGP.
5.     On the ingress node of the MPLS TE tunnel, configure RSVP-TE to establish a CRLSP based on the tunnel constraints and link TE attributes.
6.     On the ingress node of the MPLS TE tunnel, configure static routing or automatic route advertisement to direct traffic to the MPLS TE tunnel.
You can also configure other MPLS TE functions such as the DS-TE, automatic bandwidth adjustment, and FRR as needed.
To configure MPLS TE, perform the following tasks:
Tasks at a glance
(Required.) Enabling MPLS TE
(Required.) Configuring a tunnel interface
(Optional.) Configuring DS-TE
(Required.) Perform at least one of the following tasks to configure an MPLS TE tunnel:
·     Configuring an MPLS TE tunnel to use a static CRLSP
·     Configuring an MPLS TE tunnel to use a dynamic CRLSP
(Required.) Configuring traffic forwarding:
·     Configuring static routing to direct traffic to an MPLS TE tunnel
·     Configuring automatic route advertisement to direct traffic to an MPLS TE tunnel
(Optional.) Configuring a bidirectional MPLS TE tunnel
(Optional.) Configuring CRLSP backup
Only MPLS TE tunnels established by RSVP-TE support this configuration.
(Optional.) Configuring MPLS TE FRR
Enabling MPLS TE
Before you enable MPLS TE, perform the following tasks:
·     Configure static routing or IGP to ensure that all LSRs can reach each other.
·     Enable MPLS. For information about enabling MPLS, see "Configuring basic MPLS."
To enable MPLS TE:
Step
Remarks
N/A
1.     Enable MPLS TE and enter MPLS TE view.
mpls te
By default, MPLS TE is disabled.
2.     Return to system view.
N/A
3.     Enter interface view.
N/A
4.     Enable MPLS TE for the interface.
mpls te enable
By default, MPLS TE is disabled on an interface.
To configure an MPLS TE tunnel, you must create an MPLS TE tunnel interface and enter tunnel interface view. All MPLS TE tunnel attributes are configured in tunnel interface view. For more information about tunnel interfaces, see Layer 3—IP Services Configuration Guide.
Perform this task on the ingress node of the MPLS TE tunnel.
To configure a tunnel interface:
Step
Remarks
N/A
2.     Create an MPLS TE tunnel interface and enter tunnel interface view.
interface tunnel tunnel-number mode mpls-te
By default, no tunnel interface is created.
3.     Configure an IP address for the tunnel interface.
ip address ip-address { mask-length | mask }
By default, a tunnel interface does not have an IP address.
4.     Specify the tunnel destination address.
destination ip-address
By default, no tunnel destination address is specified.
Configuring DS-TE
DS-TE is configurable on any node that an MPLS TE tunnel traverses.
To configure DS-TE:
Step
Remarks
N/A
2.     Enter MPLS TE view.
mpls te
N/A
3.     (Optional.) Configure the DS-TE mode as IETF.
ds-te mode ietf
By default, the DS-TE mode is prestandard.
4.     (Optional.) Configure the BC model of IETF DS-TE as MAM.
ds-te bc-model mam
By default, the BC model of IETF DS-TE is RDM.
5.     Configure a TE class.
ds-te te-class te-class-index class-type class-type-number priority pri-number
The default TE classes for IETF mode are shown in Table 1.
In prestandard mode, you cannot configure TE classes.
Table 1 Default TE classes in IETF mode
TE Class
CT
Priority
0
0
7
1
1
7
2
2
7
3
3
7
4
0
0
5
1
0
6
2
0
7
3
0
To configure an MPLS TE tunnel to use a static CRLSP, perform the following tasks:
·     Establish the static CRLSP.
·     Specify the MPLS TE tunnel establishment mode as static.
·     Configure the MPLS TE tunnel to reference the static CRLSP.
Other configurations, such as tunnel constraints and IGP extension, are not needed.
To configure an MPLS TE tunnel to use a static CRLSP:
Step
Remarks
N/A
2.     Create a static CRLSP.
See "Configuring a static CRLSP."
N/A
3.     Enter MPLS TE tunnel interface view.
interface tunnel tunnel-number [ mode mpls-te ]
Execute this command on the ingress node.
4.     Specify the MPLS TE tunnel establishment mode as static.
mpls te signaling static
By default, MPLS TE uses RSVP-TE to establish a tunnel.
5.     Apply the static CRLSP to the tunnel interface.
mpls te static-cr-lsp lsp-name
By default, a tunnel does not reference any static CRLSP.
·     Configure MPLS TE attributes for the links.
·     Configure IGP TE extension to advertise link TE attributes, so as to generate a TEDB on each node.
·     Configure tunnel constraints.
·     Establish the CRLSP by using the signaling protocol RSVP-TE.
You must configure the IGP TE extension to form a TEDB. Otherwise, the path is created based on IGP routing rather than computed by CSPF.
To establish an MPLS TE tunnel by using a dynamic CRLSP:
Tasks at a glance
(Required.) Configuring MPLS TE attributes for a link
(Required.) Advertising link TE attributes by using IGP TE extension
(Required.) Configuring MPLS TE tunnel constraints
(Required.) Establishing an MPLS TE tunnel by using RSVP-TE
(Optional.) Controlling CRLSP path selection
(Optional.) Controlling MPLS TE tunnel setup
MPLS TE attributes for a link include the maximum link bandwidth, the maximum reservable bandwidth, and the link attribute.
Perform this task on each interface that the MPLS TE tunnel traverses.
To configure the link TE attributes:
Step
Remarks
N/A
2.     Enter interface view.
N/A
3.     Set the maximum link bandwidth for MPLS TE traffic.
mpls te max-link-bandwidth bandwidth-value
By default, the maximum link bandwidth for MPLS TE traffic is 0.
4.     Set the maximum reservable bandwidth.
·     Configure the maximum reservable bandwidth of the link (BC 0) and BC 1 in RDM model of the prestandard DS-TE:
mpls te max-reservable-bandwidth bandwidth-value [ bc1 bc1-bandwidth ]
·     Configure the maximum reservable bandwidth of the link and the BCs in MAM model of the IETF DS-TE:
mpls te max-reservable-bandwidth mam bandwidth-value { bc0 bc0-bandwidth | bc1 bc1-bandwidth | bc2 bc2-bandwidth | bc3 bc3-bandwidth } *
·     Configure the maximum reservable bandwidth of the link and the BCs in RDM model of the IETF DS-TE:
mpls te max-reservable-bandwidth rdm bandwidth-value [ bc1 bc1-bandwidth ] [ bc2 bc2-bandwidth ] [ bc3 bc3-bandwidth ]
Use one command according to the DS-TE mode and BC model configured in "Configuring DS-TE."
By default, the maximum reservable bandwidth of a link is 0 kbps and each BC is 0 kbps.
In RDM model, BC 0 is the maximum reservable bandwidth of a link.
5.     Set the link attribute.
mpls te link-attribute attribute-value
By default, the link attribute value is 0x00000000.
Both OSPF and IS-IS are extended to advertise link TE attributes. The extensions are called OSPF TE and IS-IS TE. If both OSPF TE and IS-IS TE are available, OSPF TE takes precedence.
Configuring OSPF TE
OSPF TE uses Type-10 opaque LSAs to carry the TE attributes for a link. Before you configure OSPF TE, you must enable opaque LSA advertisement and reception by using the opaque-capability enable command. For more information about opaque LSA advertisement and reception, see Layer 3—IP Routing Configuration Guide.
MPLS TE cannot reserve resources and distribute labels for an OSPF virtual link, and cannot establish a CRLSP through an OSPF virtual link. Therefore, make sure no virtual link exists in an OSPF area before you configure MPLS TE.
To configure OSPF TE:
Step
Remarks
N/A
2.     Enter OSPF view.
ospf [ process-id ]
N/A
3.     Enable opaque LSA advertisement and reception.
By default, opaque LSA advertisement and reception are enabled.
For more information about this command, see Layer 3—IP Routing Command Reference.
4.     Enter area view.
area area-id
N/A
5.     Enable MPLS TE for the OSPF area.
mpls te enable
By default, an OSPF area does not support MPLS TE.
Configuring IS-IS TE
IS-IS TE uses a sub-TLV of the extended IS reachability TLV (type 22) to carry TE attributes. Because the extended IS reachability TLV carries wide metrics, specify a wide metric-compatible metric style for the IS-IS process before enabling IS-IS TE. Available metric styles for IS-IS TE include wide, compatible, or wide-compatible. For more information about IS-IS, see Layer 3—IP Routing Configuration Guide.
Because of the following conditions, specify an MTU that is equal to or greater than 512 bytes on each IS-IS enabled interface for IS-IS LSPs to be flooded on the network:
·     The length of the extended IS reachability TLV might reach the maximum of 255 bytes.
·     The LSP header takes 27 bytes and the TLV header takes two bytes.
·     The LSP might also carry the authentication information.
To configure IS-IS TE:
Step
Remarks
N/A
2.     Create an IS-IS process and enter IS-IS view.
isis [ process-id ]
By default, no IS-IS process exists.
3.     Specify a metric style.
cost-style { wide | wide-compatible | compatible [ relax-spf-limit ] }
By default, only narrow metric style packets can be received and sent.
4.     Enable MPLS TE for the IS-IS process.
mpls te enable [ Level-1 | Level-2 ]
By default, an IS-IS process does not support MPLS TE.
5.     Specify the types of the sub-TLVs for carrying DS-TE parameters.
te-subtlv { bw-constraint value | unreserved-bw-sub-pool value } *
By default, the bw-constraint parameter is carried in sub-TLV 252, and the unreserved-bw-sub-pool parameter is carried in sub-TLV 251.
Configuring bandwidth constraints for an MPLS TE tunnel
Step
Remarks
6.     Enter system view.
N/A
7.     Enter MPLS TE tunnel interface view.
N/A
8.     Configure bandwidth required for the tunnel, and specify a CT for the tunnel's traffic.
mpls te bandwidth [ ct0 | ct1 | ct2 | ct3 ] bandwidth
By default, no bandwidth is assigned, and the class type is CT 0.
Configuring the affinity attribute for an MPLS TE tunnel
The associations between the link attribute and the affinity attribute might vary by vendor. To ensure the successful establishment of a tunnel between two devices from different vendors, correctly configure their respective link attribute and affinity attribute.
To configure the affinity attribute for an MPLS TE tunnel:
Step
Remarks
N/A
2.     Enter MPLS TE tunnel interface view.
N/A
3.     Set an affinity for the MPLS TE tunnel.
mpls te affinity-attribute attribute-value [ mask mask-value ]
By default, the affinity is 0x00000000, and the mask is 0x00000000. The default affinity matches all link attributes.
Configuring a setup priority and a holding priority for an MPLS TE tunnel
Step
Remarks
N/A
N/A
3.     Set a setup priority and a holding priority for the MPLS TE tunnel.
mpls te priority setup-priority [ hold-priority ]
By default, the setup priority and the holding priority are both 7 for an MPLS TE tunnel.
Configuring an explicit path for an MPLS TE tunnel
An explicit path is a set of nodes. The relationship between any two neighboring nodes on an explicit path can be either strict or loose.
·     Strict—The two nodes must be directly connected.
·     Loose—The two nodes can have devices in between.
When establishing an MPLS TE tunnel between areas or ASs, you must do the following:
·     Use a loose explicit path.
·     Specify the ABR or ASBR as the next hop of the path.
·     Make sure the tunnel's ingress node and the ABR or ASBR can reach each other.
To configure an explicit path for a MPLS TE tunnel:
Step
Remarks
N/A
2.     Create an explicit path and enter its view.
explicit-path path-name
By default, no explicit path exists on the device.
3.     Enable the explicit path.
undo disable
By default, an explicit path is enabled.
4.     Add or modify a node in the explicit path.
nexthop [ index index-number ] ip-address [ exclude | include [ loose | strict ] ]
By default, an explicit path does not include any node.
You can specify the include keyword to have the CRLSP traverse the specified node or the exclude keyword to have the CRLSP bypass the specified node.
5.     Return to system view.
N/A
6.     Enter MPLS TE tunnel interface view.
N/A
7.     Configure the MPLS TE tunnel interface to use the explicit path, and specify a preference value for the explicit path.
mpls te path preference value explicit-path path-name [ no-cspf ]
By default, MPLS TE uses the calculated path to establish a CRLSP.
Before you configure this task, you must use the rsvp command and the rsvp enable command to enable RSVP on all nodes and interfaces that the MPLS TE tunnel traverses.
To configure RSVP-TE to establish an MPLS TE tunnel:
Step
Remarks
N/A
N/A
3.     Configure MPLS TE to use RSVP-TE to establish the tunnel.
mpls te signaling rsvp-te
4.     Specify an explicit path for the MPLS TE tunnel, and specify the path preference value.
mpls te path preference value { dynamic | explicit-path path-name } [ no-cspf ]
Before performing the configuration tasks in this section, be aware of each configuration objective and its impact on your device.
MPLS TE uses CSPF to calculate a path according to the TEDB and constraints and sets up the CRLSP through RSVP-TE. MPLS TE provides measures that affect the CSPF calculation. You can use these measures to tune the path selection for CRLSP.
Configuring the metric type for path selection
Each MPLS TE link has two metrics: IGP metric and TE metric. By planning the two metrics, you can select different tunnels for different classes of traffic. For example, use the IGP metric to represent a link delay (a smaller IGP metric value indicates a lower link delay), and use the TE metric to represent a link bandwidth value (a smaller TE metric value indicates a bigger link bandwidth value).
You can establish two MPLS TE tunnels: Tunnel 1 for voice traffic and Tunnel 2 for video traffic. Configure Tunnel 1 to use IGP metrics for path selection, and configure Tunnel 2 to use TE metrics for path selection. As a result, the video service (with larger traffic) travels through the path that has larger bandwidth, and the voice traffic travels through the path that has lower delay.
To configure the metric type for tunnel path selection:
Step
Remarks
N/A
mpls te
N/A
3.     Specify the metric type to use when no metric type is explicitly configured for a tunnel.
path-metric-type { igp | te }
By default, a tunnel uses the TE metric for path selection.
Execute this command on the ingress node of an MPLS TE tunnel.
4.     Return to system view.
N/A
5.     Enter MPLS TE tunnel interface view.
N/A
6.     Specify the metric type for path selection.
mpls te path-metric-type { igp | te }
By default, no link metric type is specified and the one specified in MPLS TE view is used.
7.     Return to system view.
N/A
8.     Enter interface view.
N/A
9.     Assign a TE metric to the link.
mpls te metric value
By default, the link uses its IGP metric as the TE metric.
This command is available on every interface that the MPLS TE tunnel traverses.
Configuring route pinning
When route pinning is enabled, MPLS TE tunnel reoptimization and automatic bandwidth adjustment are not available.
Perform this task on the ingress node of an MPLS TE tunnel.
To configure route pinning:
Step
Remarks
N/A
N/A
3.     Enable route pinning.
mpls te route-pinning
By default, route pinning is disabled.
Configuring tunnel reoptimization
Tunnel reoptimization allows you to manually or dynamically trigger the ingress node to recalculate a path. If the ingress node recalculates a better path, it creates a new CRLSP, switches the traffic from the old CRLSP to the new CRLSP, and then deletes the old CRLSP.
To configure tunnel reoptimization:
Step
Remarks
N/A
N/A
3.     Enable tunnel reoptimization.
mpls te reoptimization [ frequency seconds ]
By default, tunnel reoptimization is disabled.
4.     Return to user view.
return
N/A
5.     (Optional.) Immediately reoptimize all MPLS TE tunnels that are enabled with the tunnel reoptimization function.
N/A
Configuring TE flooding thresholds and interval
When the bandwidth of an MPLS TE link changes, IGP floods the new bandwidth information, so the ingress node can use CSPF to recalculate the path.
To prevent such recalculations from consuming too many resources, you can configure IGP to flood only significant bandwidth changes by setting the following flooding thresholds:
·     Up threshold—When the percentage of the reservable-bandwidth increase to the maximum reservable bandwidth reaches the threshold, IGP floods the TE information.
·     Down threshold—When the percentage of the reservable-bandwidth decrease to the maximum reservable bandwidth reaches the threshold, IGP floods the TE information.
You can also configure the flooding interval at which bandwidth changes that cannot trigger immediate flooding are flooded.
This task can be performed on all nodes that the MPLS TE tunnel traverses.
To configure TE flooding thresholds and the flooding interval:
Step
Remarks
N/A
N/A
3.     Set the up/down threshold.
mpls te bandwidth change thresholds { down | up } percent
By default, the up/down threshold is 10% of the link reservable bandwidth.
N/A
5.     Enter MPLS TE view.
mpls te
N/A
6.     Set the flooding interval.
link-management periodic-flooding timer interval
By default, the flooding interval is 180 seconds.
Perform the tasks in this section on the ingress node of the MPLS TE tunnel.
Enabling route and label recording
Perform this task to record the nodes that an MPLS TE tunnel traverses and the label assigned by each node. The recorded information helps you know about the path used by the MPLS TE tunnel and the label distribution information, and when the tunnel fails, it helps you locate the fault.
To enable route and label recording:
Step
Remarks
N/A
N/A
3.     Record routes or record both routes and labels.
·     To record routes:
mpls te record-route
·     To record both routes and labels:
mpls te record-route label
By default, both route recording and label recording are disabled.
Enabling loop detection
Enabling loop detection also enables the route recording function, regardless of whether you have configured the mpls te record-route command. Loop detection enables each node of the tunnel to detect whether a loop has occurred according to the recorded route information.
To enable loop detection:
Step
Remarks
N/A
N/A
3.     Enable loop detection.
mpls te loop-detection
By default, loop detection is disabled.
Configuring tunnel setup retry
If the ingress node fails to establish an MPLS TE tunnel, it waits for the retry interval, and then tries to set up the tunnel again. It repeats this process until the tunnel is established or until the number of attempts reaches the maximum. If the tunnel cannot be established when the number of attempts reaches the maximum, the ingress waits for a longer period and then repeats the previous process.
To configure tunnel setup retry:
Step
Remarks
N/A
N/A
3.     Set the maximum number of tunnel setup attempts.
mpls te retry times
By default, the maximum number of attempts is 3.
4.     Set the retry interval.
mpls te timer retry seconds
By default, the retry interval is 2 seconds.
Configuring automatic bandwidth adjustment
Step
Remarks
N/A
mpls te
N/A
3.     Enable automatic bandwidth adjustment globally, and configure the output rate sampling interval.
auto-bandwidth enable [ sample-interval seconds ]
By default, the global auto bandwidth adjustment is disabled.
The sampling interval configured in MPLS TE view applies to all MPLS TE tunnels. The output rates of all MPLS TE tunnels are recorded every sampling interval to calculate the actual average bandwidth of each MPLS TE tunnel in one sampling interval.
4.     Enter MPLS TE tunnel interface view.
N/A
5.     Enable automatic bandwidth adjustment or output rate sampling for the MPLS TE tunnel.
·     To enable automatic bandwidth adjustment:
mpls te auto-bandwidth adjustment [ frequency seconds ] [ max-bw max-bandwidth | min-bw min-bandwidth ] *
·     To enable output rate sampling:
mpls te auto-bandwidth collect-bw [ frequency seconds ]
By default, automatic bandwidth adjustment and output rate sampling are disabled for an MPLS TE tunnel.
6.     Return to user view.
return
N/A
7.     (Optional.) Reset the automatic bandwidth adjustment.
reset mpls te auto-bandwidth-adjustment timers
After this command is executed, the system clears the output rate sampling information and the remaining time to the next bandwidth adjustment to start a new output rate sampling and bandwidth adjustment.
Configuring RSVP resource reservation style
Step
Remarks
N/A
N/A
3.     Configure the resources reservation style for the tunnel.
mpls te resv-style { ff | se }
By default, the resource reservation style is SE.
In current MPLS TE applications, tunnels are established usually by using the make-before-break mechanism. Therefore, H3C recommends that you use the SE style.
Step
Remarks
N/A
2.     Configure a static route to direct traffic to an MPLS TE tunnel.
See Layer 3—IP Routing Command Reference.
By default, no static route exists on the device.
The interface specified in this command must be an MPLS TE tunnel interface in load sharing mode.
You can use either IGP shortcut or forwarding adjacency to implement automatic route advertisement. When you use IGP shortcut, you can specify a metric for the TE tunnel. If you assign an absolute metric, the metric is directly used as the MPLS TE tunnel's metric. If you assign a relative metric, the MPLS TE tunnel's metric is the assigned metric plus the IGP link metric.
Before configuring automatic route advertisement, perform the following tasks:
·     Enable OSPF or IS-IS on the tunnel interface to advertise the tunnel interface address to OSPF or IS-IS.
·     Enable MPLS TE for an OSPF area or an IS-IS process by executing the mpls te enable command in OSPF area view or IS-IS view.
Follow these restrictions and guidelines when you configure automatic route advertisement:
·     The destination address of the MPLS TE tunnel can be the LSR ID of the egress node or the primary IP address of an interface on the egress node. H3C recommends configuring the destination address of the MPLS TE tunnel as the LSR ID of the egress node.
·     If you configure the tunnel destination address as the primary IP address of an interface on the egress node, you must enable MPLS TE, and configure OSPF or IS-IS on that interface. This makes sure the primary IP address of the interface can be advertised to its peer.
·     The route to the tunnel interface address and the route to the tunnel destination must be in the same OSPF area or at the same IS-IS level.
Configuring IGP shortcut
Step
Remarks
N/A
N/A
3.     Enable IGP shortcut.
mpls te igp shortcut [ isis | ospf ]
By default, IGP shortcut is disabled.
If no IGP is specified, both OSPF and IS-IS will include the MPLS TE tunnel in route calculation.
4.     Assign a metric to the MPLS TE tunnel.
mpls te igp metric { absolute value | relative value }
By default, the metric of an MPLS TE tunnel equals its IGP metric.
Configuring forwarding adjacency
To use forwarding adjacency, you must establish two MPLS TE tunnels in opposite directions between two nodes, and configure forwarding adjacency on both the nodes.
To configure forwarding adjacency:
Step
Remarks
N/A
N/A
3.     Enable forwarding adjacency.
mpls te igp advertise [ hold-time value ]
By default, forwarding adjacency is disabled.
Before you create a bidirectional MPLS TE tunnel, perform the following tasks:
·     Disable the PHP function on both ends of the tunnel.
·     To set up a bidirectional MPLS TE tunnel in co-routed mode, you must specify the signaling protocol as RSVP-TE.
To create a bidirectional MPLS TE tunnel, create an MPLS TE tunnel interface on both ends of the tunnel and enable the bidirectional tunnel function on the tunnel interfaces:
·     For a co-routed bidirectional tunnel, configure one end of the tunnel as the active end and the other end as the passive end, and specify the reverse CRLSP at the passive end.
·     For an associated bidirectional tunnel, specify a reverse CRLSP at both ends of the tunnel.
To configure the active end of a co-routed bidirectional MPLS TE tunnel:
Step
Remarks
N/A
N/A
3.     Configure a co-routed bidirectional MPLS TE tunnel and specify the local end as the active end of the tunnel.
mpls te bidirectional co-routed active
By default, no bidirectional tunnel is configured, and tunnels established on the tunnel interface are unidirectional MPLS TE tunnels.
To configure the passive end of a co-routed bidirectional MPLS TE tunnel:
Step
Remarks
N/A
N/A
3.     Configure a co-routed bidirectional MPLS TE tunnel and specify the local end as the passive end of the tunnel.
mpls te bidirectional co-routed passive reverse-lsp lsr-id ingress-lsr-id tunnel-id tunnel-id
To configure an associated bidirectional MPLS TE tunnel:
Step
Remarks
N/A
N/A
3.     Configure an associated bidirectional MPLS TE tunnel.
mpls te bidirectional associated reverse-lsp { lsp-name lsp-name | lsr-id ingress-lsr-id tunnel-id tunnel-id } }
CRLSP backup provides end-to-end CRLSP protection. Only MPLS TE tunnels established through RSVP-TE support CRLSP backup.
To configure CRLSP backup:
Step
Remarks
N/A
N/A
3.     Enable CRLSP backup and specify the backup mode.
mpls te backup { hot-standby | ordinary }
By default, tunnel backup is disabled.
4.     Specify a path for the primary CRLSP and set the preference of the path.
By default, MPLS TE uses the dynamically calculated path to set up the primary CRLSP.
5.     Specify a path for the backup CRLSP and set the preference of the path.
mpls te backup-path preference value { dynamic | explicit-path path-name } [ no-cspf ]
By default, MPLS TE uses the dynamically calculated path to set up the backup CRLSP.
MPLS TE FRR provides temporary link or node protection on a CRLSP. When you configure FRR, follow these restrictions and guidelines:
·     Do not configure both FRR and RSVP authentication on the same interface.
·     Only MPLS TE tunnels established through RSVP-TE support FRR.
Enabling FRR
Perform this task on the ingress node of a primary CRLSP.
To enable FRR:
Step
Remarks
N/A
2.     Enter tunnel interface view of the primary CRLSP.
N/A
3.     Enable FRR.
mpls te fast-reroute [ bandwidth ]
By default, FRR is disabled.
If you specify the bandwidth keyword, the primary CRLSP must have bandwidth protection.
Overview
To configure FRR, you must configure bypass tunnels for primary CRLSPs on the PLR.
To configure bypass tunnels on the PLR, you can use the following methods:
·     Manually configuring a bypass tunnel on the PLR—Create an MPLS TE tunnel on the PLR, and configure the tunnel as a bypass tunnel for a primary CRLSP. You need to specify the bandwidth and CT that the bypass tunnel can protect, and bind the bypass tunnel to the egress interface of the primary CRLSP.
You can configure up to three bypass tunnels for a primary CRLSP.
·     Configuring the PLR to set up bypass tunnels automatically—Configure the automatic bypass tunnel setup function (also referred to as the auto FRR function) on the PLR. The PLR automatically sets up two bypass tunnels for each of its primary CRLSPs: one in link protection mode and the other in node protection mode. Automatically created bypass tunnels can be used to protect any type of CT, but they cannot provide bandwidth protection.
A primary tunnel can have both manually configured and automatically created bypass tunnels. The PLR will select one bypass tunnel to protect the primary CRLSP. The selected bypass tunnel is bound to the primary CRLSP.
Manually created bypass tunnels take precedence over automatically created bypass tunnels. An automatically created bypass tunnel in node protection mode takes precedence over an automatically created bypass tunnel in link protection mode. Among manually created bypass tunnels, the PLR selects the bypass tunnel for protecting the primary CRLSP by following these rules:
1.     Selects a bypass tunnel according to the principles, as shown in Table 2.
2.     Prefers the bypass tunnel in node protection mode over the one in link protection mode.
3.     Prefers the bypass tunnel with a smaller ID over the one with a bigger tunnel ID.
Table 2 FRR protection principles
Bandwidth required by primary CRLSP
Primary CRLSP requires bandwidth protection or not
Bypass tunnel providing bandwidth protection
Bypass tunnel providing no bandwidth protection
0
Yes
The primary CRLSP cannot be bound to the bypass tunnel.
The primary CRLSP can be bound to the bypass tunnel if CT 0 or no CT is specified for the bypass tunnel.
After binding, the RRO message does not carry the bandwidth protection flag. The bypass tunnel does not provide bandwidth protection for the primary CRLSP, and performs best-effort forwarding for traffic of the primary CRLSP.
No
None-zero
Yes
The primary CRLSP can be bound to the bypass tunnel when all the following conditions are met:
·     The bandwidth that the bypass tunnel can protect is no less than the bandwidth required by the primary CRLSP.
·     There is not a CT specified for the bypass tunnel, or the specified CT is the same as that specified for the primary CRLSP.
After binding, the RRO message carries the bandwidth protection flag, and the bypass tunnel provides bandwidth protection for the primary CRLSP.
The primary CRLSP prefers bypass tunnels that provide bandwidth protection over those providing no bandwidth protection.
The primary CRLSP can be bound to the bypass tunnel when one of the following conditions is met:
·     No CT is specified for the bypass tunnel.
·     The specified CT is the same as that specified for the primary CRLSP.
This bypass tunnel is selected only when no bypass tunnel that provides bandwidth protection can be bound to the primary CRLSP.
Non-zero
No
·     No CT that the bypass tunnel can protect is specified, or the specified CT is the same as that of the traffic on the primary CRLSP.
After binding, the RRO message carries the bandwidth protection flag.
This bypass tunnel is selected only when no bypass tunnel that does not provide bandwidth protection can be bound to the primary CRLSP.
·     The specified CT is the same as that of the traffic on the primary CRLSP.
The primary CRLSP prefers bypass tunnels that does not provide bandwidth protection over those providing bandwidth protection.
When you configure a bypass tunnel on the PLR, follow these restrictions and guidelines:
·     Use bypass tunnels to protect only critical interfaces or links when bandwidth is insufficient. Bypass tunnels are pre-established and require extra bandwidth.
·     Make sure the bandwidth assigned to the bypass tunnel is no less than the total bandwidth needed by all primary CRLSPs to be protected by the bypass tunnel. Otherwise, some primary CRLSPs might not be protected by the bypass tunnel.
·     A bypass tunnel typically does not forward data when the primary CRLSP operates correctly. For a bypass tunnel to also forward data during tunnel protection, you must assign adequate bandwidth to the bypass tunnel.
·     A bypass tunnel cannot be used for services such as VPN.
·     You cannot configure FRR for a bypass tunnel. A bypass tunnel cannot act as a primary CRLSP.
·     Make sure the protected node or interface is not on the bypass tunnel.
·     After you associate a primary CRLSP that does not require bandwidth protection with a bypass tunnel that provides bandwidth protection, the primary CRLSP occupies the bandwidth that the bypass tunnel protects. The bandwidth is protected on a first-come-first-served basis. The primary CRLSP that needs bandwidth protection cannot preempt the one that does not need bandwidth protection.
·     After an FRR, the primary CRLSP will be down if you modify the bandwidth that the bypass tunnel can protect and your modification results in one of the following:
¡     The CT type changes.
¡     The bypass tunnel cannot protect adequate bandwidth as configured.
¡     FRR protection type (whether or not to provide bandwidth protection for the primary CRLSP) changes.
The bypass tunnel setup method is the same as a normal MPLS TE tunnel. This section describes only FRR-related configurations.
To configure a bypass tunnel on the PLR:
Step
Remarks
N/A
2.     Enter tunnel interface view of the bypass tunnel.
N/A
3.     Specify the destination address of the bypass tunnel.
The bypass tunnel destination address is the LSR ID of the MP.
4.     Configure the bandwidth and the CT to be protected by the bypass tunnel.
mpls te backup bandwidth [ ct0 | ct1 | ct2 | ct3 ] { bandwidth | un-limited }
By default, the bandwidth and the CT to be protected by the bypass tunnel are not specified.
N/A
6.     Enter interface view of the egress interface of a primary CRLSP.
N/A
7.     Specify a bypass tunnel for the protected interface (the current interface).
mpls te fast-reroute bypass-tunnel tunnel tunnel-number
By default, no bypass tunnel is specified for an interface.
Automatically setting up bypass tunnels
With auto FRR, if the PLR is the penultimate node of a primary CRLSP, the PLR does not create a node-protection bypass tunnel for the primary CRLSP.
An automatically created bypass tunnel can protect multiple primary CRLSPs. A bypass tunnel is unused when the bypass tunnel is not bound to any primary CRLSP. When a bypass tunnel is unused for the period of time configured by the timers removal unused command, MPLS TE removes the bypass tunnel.
To configure auto FRR on the PLR:
Step
Remarks
N/A
mpls te
N/A
3.     Enable the auto FRR function globally.
auto-tunnel backup
By default, the auto FRR function is disabled globally.
4.     Specify an interface number range for the automatically created bypass tunnels.
tunnel-number min min-number max max-number
By default, no interface number range is specified, and the PLR cannot set up a bypass tunnel automatically.
5.     (Optional.) Configure the PLR to create only link-protection bypass tunnels.
nhop-only
By default, the PLR automatically creates both a link-protection and a node-protection bypass tunnel for each of its primary CRLSPs.
Execution of this command deletes all existing node-protection bypass tunnels automatically created for MPLS TE auto FRR.
6.     (Optional.) Set a removal timer for unused bypass tunnels.
timers removal unused seconds
By default, a bypass tunnel is removed after it is unused for 3600 seconds.
7.     (Optional.) Return to system view.
N/A
8.     (Optional.) Enter interface view.
N/A
9.     (Optional.) Disable the auto FRR function on the interface.
mpls te auto-tunnel backup disable
By default, the auto FRR function is enabled on all RSVP-enabled interfaces after it is enabled globally.
Execution of this command deletes all existing bypass tunnels automatically created on the interface for MPLS TE auto FRR.
Perform this task to configure the RSVP hello mechanism or BFD on the PLR and the protected node to detect the node faults caused by signaling protocol faults. FRR does not need to use the RSVP hello mechanism or BFD to detect the node faults caused by the link faults between the PLR and the protected node.
You do not need to perform this task for FRR link protection.
To configure node fault detection:
Step
Remarks
N/A
On the PLR, enter the view of the interface connected to the protected node.
On the protected node, enter the view of the interface connected to the PLR.
3.     Configure node fault detection.
·     (Method 1) Enable RSVP hello extension on the interface:
rsvp hello enable
·     (Method 2) Enable BFD on the interface:
rsvp bfd enable
By default, RSVP hello extension is disabled, and BFD is not configured.
For more information about the rsvp hello enable command and the rsvp bfd enable command, see "Configuring RSVP."
If you have specified multiple bypass tunnels for a primary CRLSP, MPLS TE selects an optimal bypass tunnel to protect the primary CRLSP. Sometimes, a bypass tunnel might become better than the current optimal bypass tunnel because, for example, the reservable bandwidth changes. Therefore, MPLS TE needs to poll the bypass tunnels periodically to update the optimal bypass tunnel.
Perform this task on the PLR to configure the interval for selecting an optimal bypass tunnel:
Step
Remarks
N/A
mpls te
N/A
3.     Set the interval for selecting an optimal bypass tunnel.
fast-reroute timer interval
By default, the interval is 300 seconds.
Display information about explicit paths.
display explicit-path [ path-name ]
Display link and node information in an IS-IS TEDB.
display isis mpls te advertisement [ [ level-1 | level-2 ] | [ originate-system system-id | local ] | verbose ] * [ process-id ]
Display sub-TLV information for IS-IS TE.
display isis mpls te configured-sub-tlvs [ process-id ]
Display network information in an IS-IS TEDB.
display isis mpls te network [ [ level-1 | level-2 ] | local | lsp-id lsp-id ]* [ process-id ]
Display IS-IS tunnel interface information.
display isis mpls te tunnel [ level-1 | level-2 ] [ process-id ]
Display DS-TE information.
display mpls te ds-te
Display bandwidth information on MPLS TE-enabled interfaces.
display mpls te link-management bandwidth-allocation [ interface interface-type interface-number ]
Display MPLS TEDB information.
display mpls te tedb { { isis { level-1 | level-2 } | ospf area area-id } | link ip-address | network | node [ local | mpls-lsr-id ] | summary }
Display information about MPLS TE tunnel interfaces.
display mpls te tunnel-interface [ tunnel number ]
Display link and node information in an OSPF TEDB.
display ospf [ process-id ] [ area area-id ] mpls te advertisement [ originate-router advertising-router-id | self-originate ]
Display network information in an OSPF TEDB.
display ospf [ process-id ] [ area area-id ] mpls te network [ originate-router advertising-router-id | self-originate ]
Display OSPF tunnel interface information.
display ospf [ process-id ] [ area area-id ] mpls te tunnel
Reset the automatic bandwidth adjustment function.
MPLS TE configuration examples
Establishing an MPLS TE tunnel over a static CRLSP
Network requirements
Switch A, Switch B, and Switch C run IS-IS.
Establish an MPLS TE tunnel over a static CRLSP from Switch A to Switch C.
The MPLS TE tunnel requires a bandwidth of 2000 kbps. The maximum bandwidth of the link that the tunnel traverses is 10000 kbps. The maximum reservable bandwidth of the link is 5000 kbps.
Figure 7 Network diagram
Configuration procedure
1.     Configure IP addresses and masks for interfaces. (Details not shown.)
2.     Configure IS-IS to advertise interface addresses, including the loopback interface address:
# Configure Switch A.
[SwitchA] isis 1
[SwitchA-isis-1] network-entity 00.0005.0000.0000.0001.00
[SwitchA-isis-1] quit
[SwitchA-Vlan-interface1] isis enable 1
[SwitchA-LoopBack0] isis enable 1
[SwitchA-LoopBack0] quit
# Configure Switch B.
[SwitchB] isis 1
[SwitchB-isis-1] network-entity 00.0005.0000.0000.0002.00
[SwitchB-isis-1] quit
[SwitchB] interface vlan-interface 1
[SwitchB-Vlan-interface1] isis enable 1
[SwitchB-Vlan-interface1] quit
[SwitchB-Vlan-interface2] isis enable 1
[SwitchB-LoopBack0] isis enable 1
[SwitchB-LoopBack0] quit
# Configure Switch C.
[SwitchC] isis 1
[SwitchC-isis-1] network-entity 00.0005.0000.0000.0003.00
[SwitchC-isis-1] quit
[SwitchC-Vlan-interface2] isis enable 1
[SwitchC-LoopBack0] isis enable 1
[SwitchC-LoopBack0] quit
# Execute the display ip routing-table command on each switch to verify that the switches have learned the routes to one another, including the routes to the loopback interfaces. (Details not shown.)
3.     Configure an LSR ID, and enable MPLS and MPLS TE:
[SwitchA] mpls lsr-id 1.1.1.1
[SwitchA] mpls te
[SwitchA-te] quit
[SwitchA-Vlan-interface1] mpls enable
[SwitchA-Vlan-interface1] mpls te enable
[SwitchB] mpls lsr-id 2.2.2.2
[SwitchB] mpls te
[SwitchB-te] quit
[SwitchB-Vlan-interface1] mpls enable
[SwitchB-Vlan-interface1] mpls te enable
[SwitchB-Vlan-interface2] mpls te enable
[SwitchC] mpls lsr-id 3.3.3.3
[SwitchC] mpls te
[SwitchC-te] quit
[SwitchC-Vlan-interface2] mpls enable
[SwitchC-Vlan-interface2] mpls te enable
4.     Configure MPLS TE attributes of links:
# Set the maximum link bandwidth and maximum reservable bandwidth on Switch A.
[SwitchA-Vlan-interface1] mpls te max-link-bandwidth 10000
[SwitchA-Vlan-interface1] mpls te max-reservable-bandwidth 5000
# Set the maximum link bandwidth and maximum reservable bandwidth on Switch B.
[SwitchB-Vlan-interface1] mpls te max-link-bandwidth 10000
[SwitchB-Vlan-interface1] mpls te max-reservable-bandwidth 5000
[SwitchB-Vlan-interface2] mpls te max-link-bandwidth 10000
[SwitchB-Vlan-interface2] mpls te max-reservable-bandwidth 5000
# Set the maximum link bandwidth and maximum reservable bandwidth on Switch C.
[SwitchC-Vlan-interface2] mpls te max-link-bandwidth 10000
[SwitchC-Vlan-interface2] mpls te max-reservable-bandwidth 5000
5.     Configure an MPLS TE tunnel on Switch A:
# Configure MPLS TE tunnel interface Tunnel 0.
[SwitchA] interface tunnel 0 mode mpls-te
[SwitchA-Tunnel0] ip address 6.1.1.1 255.255.255.0
# Specify the tunnel destination address as the LSR ID of Switch C.
[SwitchA-Tunnel0] destination 3.3.3.3
# Configure MPLS TE to use a static CRLSP to establish the tunnel.
[SwitchA-Tunnel0] mpls te signaling static
[SwitchA-Tunnel0] quit
6.     Create a static CRLSP:
# Configure Switch A as the ingress node of the static CRLSP, and specify the next hop address as 2.1.1.2, outgoing label as 20, and bandwidth for the tunnel as 2000 kbps.
[SwitchA] static-cr-lsp ingress static-cr-lsp-1 nexthop 2.1.1.2 out-label 20 bandwidth 2000
# On Switch A, configure tunnel 0 to reference the static CRLSP static-cr-lsp-1.
[SwitchA] interface Tunnel0
[SwitchA-Tunnel0] mpls te static-cr-lsp static-cr-lsp-1
# Configure Switch B as the transit node of the static CRLSP, and specify the incoming label as 20, next hop address as 3.2.1.2, outgoing label as 30, and bandwidth for the tunnel as 2000 kbps.
[SwitchB] static-cr-lsp transit static-cr-lsp-1 in-label 20 nexthop 3.2.1.2 out-label 30 bandwidth 2000
# Configure Switch C as the egress node of the static CRLSP, and specify the incoming label as 30.
[SwitchC] static-cr-lsp egress static-cr-lsp-1 in-label 30
7.     Configure a static route on Switch A to direct traffic destined for subnet 3.2.1.0/24 to MPLS TE tunnel 0.
[SwitchA] ip route-static 3.2.1.2 24 tunnel 0 preference 1
# Execute the display interface tunnel command on Switch A. The output shows that the tunnel interface is up.
[SwitchA] display interface tunnel
Tunnel0
Current state: UP
Line protocol state: UP
Bandwidth: 64kbps
Maximum Transmit Unit: 1496
Internet Address is 6.1.1.1/24 Primary
Tunnel source unknown, destination 3.3.3.3
Tunnel TTL 255
# Execute the display mpls te tunnel-interface command on Switch A to display detailed information about the MPLS TE tunnel.
[SwitchA] display mpls te tunnel-interface
Tunnel Name            : Tunnel 0
Tunnel State           : Up (Main CRLSP up)
Tunnel Attributes      :
  LSP ID               : 1               Tunnel ID            : 0
  Admin State          : Normal
  Ingress LSR ID       : 1.1.1.1         Egress LSR ID        : 3.3.3.3
  Signaling            : Static          Static CRLSP Name    : static-cr-lsp-1
  Resv Style           : -
  Tunnel mode          : -
  Reverse-LSP name     : -
  Reverse-LSP LSR ID   : -               Reverse-LSP Tunnel ID: -
  Class Type           : -               Tunnel Bandwidth     : -
  Reserved Bandwidth   : -
  Setup Priority       : 0               Holding Priority     : 0
  Affinity Attr/Mask   : -/-
  Explicit Path        : -
  Backup Explicit Path : -
  Metric Type          : TE
  Record Route         : -               Record Label         : -
  FRR Flag             : -               Bandwidth Protection : -
  Backup Bandwidth Flag: -               Backup Bandwidth Type: -
  Backup Bandwidth     : -
  Bypass Tunnel        : -               Auto Created         : -
  Route Pinning        : -
  Retry Limit          : 3               Retry Interval       : 2 sec
  Reoptimization       : -               Reoptimization Freq  : -
  Backup Type          : -               Backup LSP ID        : -
  Auto Bandwidth       : -               Auto Bandwidth Freq  : -
  Min Bandwidth        : -               Max Bandwidth        : -
  Collected Bandwidth  : -
# Execute the display mpls lsp command or the display mpls static-cr-lsp command on each switch to display static CRLSP information.
[SwitchA] display mpls lsp
FEC                         Proto    In/Out Label    Interface/Out NHLFE
1.1.1.1/0/1                 StaticCR -/20            Vlan1
2.1.1.2                     Local    -/-             Vlan1
[SwitchB] display mpls lsp
-                           StaticCR 20/30           Vlan2
3.2.1.2                     Local    -/-             Vlan2
[SwitchC] display mpls lsp
-                           StaticCR 30/-            -
[SwitchA] display mpls static-cr-lsp
Name            LSR Type    In/Out Label   Out Interface        State
static-cr-lsp-1 Ingress     Null/20        Vlan1                Up
[SwitchB] display mpls static-cr-lsp
static-cr-lsp-1 Transit     20/30          Vlan2                Up
[SwitchC] display mpls static-cr-lsp
static-cr-lsp1  Egress      30/Null        -                    Up
# Execute the display ip routing-table command on Switch A. The output shows a static route entry with interface Tunnel 0 as the output interface. (Details not shown.)
Establishing an MPLS TE tunnel with RSVP-TE
Switch A, Switch B, Switch C, and Switch D run IS-IS and all of them are Level-2 switches.
Use RSVP-TE to create an MPLS TE tunnel from Switch A to Switch D. The MPLS TE tunnel requires a bandwidth of 2000 kbps.
The maximum bandwidth of the link that the tunnel traverses is 10000 kbps and the maximum reservable bandwidth of the link is 5000 kbps.
Figure 8 Network diagram
Table 3 Interface and IP address assignment
Device
IP address
Device
IP address
Switch A
Loop0
1.1.1.9/32
Switch D
Loop0
4.4.4.9/32
Vlan-int1
10.1.1.1/24
Vlan-int3
30.1.1.2/24
Switch B
Loop0
2.2.2.9/32
Switch C
Loop0
3.3.3.9/32
Vlan-int1
10.1.1.2/24
Vlan-int3
30.1.1.1/24
Vlan-int2
20.1.1.1/24
Vlan-int2
20.1.1.2/24
[SwitchA] isis 1
[SwitchA-Vlan-interface1] isis circuit-level level-2
[SwitchA-LoopBack0] isis circuit-level level-2
[SwitchB] isis 1
[SwitchB-Vlan-interface1] isis circuit-level level-2
[SwitchB-Vlan-interface2] isis circuit-level level-2
[SwitchB-LoopBack0] isis circuit-level level-2
[SwitchC] isis 1
[SwitchC-Vlan-interface3] isis enable 1
[SwitchC-Vlan-interface3] isis circuit-level level-2
[SwitchC-Vlan-interface2] isis circuit-level level-2
[SwitchC-LoopBack0] isis circuit-level level-2
# Configure Switch D.
<SwitchD> system-view
[SwitchD] isis 1
[SwitchD-isis-1] network-entity 00.0005.0000.0000.0004.00
[SwitchD-isis-1] quit
[SwitchD] interface vlan-interface 3
[SwitchD-Vlan-interface3] isis enable 1
[SwitchD-Vlan-interface3] isis circuit-level level-2
[SwitchD-Vlan-interface3] quit
[SwitchD] interface loopback 0
[SwitchD-LoopBack0] isis enable 1
[SwitchD-LoopBack0] isis circuit-level level-2
[SwitchD-LoopBack0] quit
3.     Configure an LSR ID, and enable MPLS, MPLS TE, and RSVP-TE:
[SwitchA] mpls lsr-id 1.1.1.9
[SwitchA] mpls te
[SwitchA-te] quit
[SwitchA] rsvp
[SwitchA-rsvp] quit
[SwitchA-Vlan-interface1] rsvp enable
[SwitchB] mpls lsr-id 2.2.2.9
[SwitchB] mpls te
[SwitchB-te] quit
[SwitchB] rsvp
[SwitchB-rsvp] quit
[SwitchB-Vlan-interface1] rsvp enable
[SwitchB-Vlan-interface2] rsvp enable
[SwitchC] mpls lsr-id 3.3.3.9
[SwitchC] mpls te
[SwitchC-te] quit
[SwitchC] rsvp
[SwitchC-rsvp] quit
[SwitchC-Vlan-interface3] mpls te enable
[SwitchC-Vlan-interface3] rsvp enable
[SwitchC-Vlan-interface2] rsvp enable
[SwitchD] mpls lsr-id 4.4.4.9
[SwitchD] mpls te
[SwitchD-te] quit
[SwitchD] rsvp
[SwitchD-rsvp] quit
[SwitchD-Vlan-interface3] mpls enable
[SwitchD-Vlan-interface3] mpls te enable
[SwitchD-Vlan-interface3] rsvp enable
4.     Configure IS-IS TE:
[SwitchA] isis 1
[SwitchA-isis-1] cost-style wide
[SwitchA-isis-1] mpls te enable level-2
[SwitchB] isis 1
[SwitchB-isis-1] cost-style wide
[SwitchB-isis-1] mpls te enable level-2
[SwitchC] isis 1
[SwitchC-isis-1] cost-style wide
[SwitchC-isis-1] mpls te enable level-2
[SwitchD] isis 1
[SwitchD-isis-1] cost-style wide
[SwitchD-isis-1] mpls te enable level-2
5.     Configure MPLS TE attributes of links:
[SwitchC-Vlan-interface3] mpls te max-link-bandwidth 10000
[SwitchC-Vlan-interface3] mpls te max-reservable-bandwidth 5000
# Set the maximum link bandwidth and maximum reservable bandwidth on Switch D.
[SwitchD-Vlan-interface3] mpls te max-link-bandwidth 10000
[SwitchD-Vlan-interface3] mpls te max-reservable-bandwidth 5000
6.     Configure an MPLS TE tunnel on Switch A:
# Configure MPLS TE tunnel interface Tunnel 1.
[SwitchA] interface tunnel 1 mode mpls-te
[SwitchA-Tunnel1] ip address 7.1.1.1 255.255.255.0
# Specify the tunnel destination address as the LSR ID of Switch D.
[SwitchA-Tunnel1] destination 4.4.4.9
# Configure MPLS TE to use RSVP-TE to establish the tunnel.
[SwitchA-Tunnel1] mpls te signaling rsvp-te
# Assign 2000 kbps bandwidth to the tunnel.
[SwitchA-Tunnel1] mpls te bandwidth 2000
[SwitchA-Tunnel1] quit
7.     Configure a static route on Switch A to direct the traffic destined for subnet 30.1.1.0/24 to MPLS TE tunnel 1.
[SwitchA] ip route-static 30.1.1.2 24 tunnel 1 preference 1
Tunnel1 current state: UP
The Maximum Transmit Unit is 64000
Internet Address is 7.1.1.1/24 Primary
Tunnel source unknown, destination 4.4.4.9
Tunnel bandwidth 64 (kbps)
Tunnel TTL 255
    Last 300 seconds output rate: 6 bytes/sec, 48 bits/sec, 0 packets/sec
    0 packets input, 0 bytes, 0 drops
    177 packets output, 11428 bytes, 0 drops
Tunnel Name            : Tunnel 1
Tunnel State           : Up (Main CRLSP up, Shared-resource CRLSP down)
Tunnel Attributes      :
  LSP ID               : 23331           Tunnel ID            : 1
  Ingress LSR ID       : 1.1.1.9         Egress LSR ID        : 4.4.4.9
  Signaling            : RSVP-TE         Static CRLSP Name    : -
  Resv Style           : SE
  Tunnel mode          : -
  Class Type           : CT0             Tunnel Bandwidth     : 2000 kbps
  Reserved Bandwidth   : 2000 kbps
  Setup Priority       : 7               Holding Priority     : 7
  Affinity Attr/Mask   : 0/0
  Explicit Path        : -
  Metric Type          : TE
  Record Route         : Disabled        Record Label         : Disabled
  FRR Flag             : Disabled        Bandwidth Protection : Disabled
  Backup Bandwidth Flag: Disabled        Backup Bandwidth Type: -
  Bypass Tunnel        : No               Auto Created         : No
  Route Pinning        : Disabled
  Retry Limit          : 10              Retry Interval       : 2 sec
  Reoptimization       : Disabled        Reoptimization Freq  : -
  Backup Type          : None            Backup LSP ID        : -
  Auto Bandwidth       : Disabled        Auto Bandwidth Freq  : -
# Execute the display ip routing-table command on Switch A. The output shows a static route entry with interface Tunnel 1 as the output interface. (Details not shown.)
Establishing an inter-AS MPLS TE tunnel with RSVP-TE
Switch A and Switch B are in AS 100. Switch C and Switch D are in AS 200. AS 100 and AS 200 use OSPF as the IGP.
Establish an EBGP connection between ASBRs Switch B and Switch C. Redistribute BGP routes into OSPF and OSPF routes into BGP, so that a route is available between AS 100 and AS 200.
Establish an MPLS TE tunnel from Switch A to Switch D. The tunnel requires a bandwidth of 2000 kbps. The maximum bandwidth of the link that the tunnel traverses is 10000 kbps and the maximum reservable bandwidth of the link is 5000 kbps.
Figure 9 Network diagram
Table 4 Interface and IP address assignment
Device
IP address
Device
IP address
Switch A
Loop0
1.1.1.9/32
Switch D
Loop0
4.4.4.9/32
Vlan-int1
10.1.1.1/24
Vlan-int3
30.1.1.2/24
Switch B
Loop0
2.2.2.9/32
Switch C
Loop0
3.3.3.9/32
Vlan-int1
10.1.1.2/24
Vlan-int3
30.1.1.1/24
Vlan-int2
20.1.1.1/24
Vlan-int2
20.1.1.2/24
2.     Configure OSPF to advertise routes within the ASs, and redistribute the direct and BGP routes into OSPF on Switch B and Switch C:
[SwitchA] ospf
[SwitchA-ospf-1] area 0
[SwitchA-ospf-1-area-0.0.0.0] network 1.1.1.9 0.0.0.0
[SwitchA-ospf-1] quit
[SwitchB] ospf
[SwitchB-ospf-1] import-route direct
[SwitchB-ospf-1] area 0
[SwitchB-ospf-1-area-0.0.0.0] network 2.2.2.9 0.0.0.0
[SwitchB-ospf-1] quit
[SwitchC] ospf
[SwitchC-ospf-1] import-route bgp
[SwitchC-ospf-1] area 0
[SwitchC-ospf-1-area-0.0.0.0] network 30.1.1.0 0.0.0.255
[SwitchC-ospf-1-area-0.0.0.0] network 3.3.3.9 0.0.0.0
[SwitchC-ospf-1] quit
[SwitchD] ospf
[SwitchD-ospf-1] area 0
[SwitchD-ospf-1-area-0.0.0.0] network 30.1.1.0 0.0.0.255
[SwitchD-ospf-1-area-0.0.0.0] network 4.4.4.9 0.0.0.0
[SwitchD-ospf-1] quit
# Verify that the switches have learned the routes to one another, including the routes to the loopback interfaces. This example uses Switch A.
Destinations : 6        Routes : 6
Destination/Mask   Proto   Pre Cost        NextHop         Interface
1.1.1.9/32         Direct  0   0           127.0.0.1       InLoop0
2.2.2.9/32         O_INTRA 10  1           10.1.1.2        Vlan1
10.1.1.0/24        Direct  0   0           10.1.1.1        Vlan1
10.1.1.1/32        Direct  0   0           127.0.0.1       InLoop0
127.0.0.0/8        Direct  0   0           127.0.0.1       InLoop0
127.0.0.1/32       Direct  0   0           127.0.0.1       InLoop0
3.     Configure BGP on Switch B and Switch C to ensure that the ASs can communicate with each other:
[SwitchB] bgp 100
[SwitchB-bgp] peer 20.1.1.2 as-number 200
[SwitchB-bgp] address-family ipv4 unicast
[SwitchB-bgp-ipv4] peer 20.1.1.2 enable
[SwitchB-bgp-ipv4] import-route ospf
[SwitchB-bgp-ipv4] import-route direct
[SwitchB-bgp-ipv4] quit
[SwitchB-bgp] quit
[SwitchC] bgp 200
[SwitchC-bgp] peer 20.1.1.1 as-number 100
[SwitchC-bgp] address-family ipv4 unicast
[SwitchC-bgp-ipv4] peer 20.1.1.1 enable
[SwitchC-bgp-ipv4] import-route ospf
[SwitchC-bgp-ipv4] import-route direct
[SwitchC-bgp-ipv4] quit
[SwitchC-bgp] quit
# Verify that the switches have learned AS-external routes. This example uses Switch A.
Destinations : 10       Routes : 10
3.3.3.9/32         O_ASE   150 1           10.1.1.2        Vlan1
4.4.4.9/32         O_ASE   150 1           10.1.1.2        Vlan1
20.1.1.0/24        O_ASE   150 1           10.1.1.2        Vlan1
30.1.1.0/24        O_ASE   150 1           10.1.1.2        Vlan1
4.     Configure an LSR ID, and enable MPLS, MPLS TE, and RSVP-TE:
[SwitchA] mpls te
[SwitchA-te] quit
[SwitchA] rsvp
[SwitchA-rsvp] quit
[SwitchB] mpls te
[SwitchB-te] quit
[SwitchB] rsvp
[SwitchB-rsvp] quit
[SwitchC] mpls te
[SwitchC-te] quit
[SwitchC] rsvp
[SwitchC-rsvp] quit
[SwitchD] mpls te
[SwitchD-te] quit
[SwitchD] rsvp
[SwitchD-rsvp] quit
5.     Configure OSPF TE:
[SwitchA] ospf
[SwitchA-ospf-1] opaque-capability enable
[SwitchA-ospf-1-area-0.0.0.0] mpls te enable
[SwitchB] ospf
[SwitchB-ospf-1] opaque-capability enable
[SwitchB-ospf-1-area-0.0.0.0] mpls te enable
[SwitchC] ospf
[SwitchC-ospf-1] opaque-capability enable
[SwitchC-ospf-1-area-0.0.0.0] mpls te enable
[SwitchD] ospf
[SwitchD-ospf-1] opaque-capability enable
[SwitchD-ospf-1-area-0.0.0.0] mpls te enable
6.     Configure an explicit route on Switch A. Specify Switch B and Switch D as loose nodes, and Switch C as a strict node.
[SwitchA] explicit-path atod
[SwitchA-explicit-path-atod] nexthop 10.1.1.2 include loose
[SwitchA-explicit-path-atod] nexthop 20.1.1.2 include strict
[SwitchA-explicit-path-atod] nexthop 30.1.1.2 include loose
[SwitchA-explicit-path-atod] quit
7.     Configure MPLS TE attributes of links:
8.     Configure an MPLS TE tunnel on Switch A:
# Configure the MPLS TE tunnel interface Tunnel 1.
# Specify the explicit path atod for the tunnel.
[SwitchA-Tunnel1] mpls te path preference 5 explicit-path atod
9.     Configure a static route on Switch A to direct the traffic destined for subnet 30.1.1.0/24 to MPLS TE tunnel 1.
[SwitchA] display interface tunnel 1
Tunnel TTL 255
    3077 packets output, 197028 bytes, 0 drops
Tunnel Attributes      :
  LSP ID               : 23549           Tunnel ID            : 1
  Resv Style           : SE
  Tunnel mode          : -
  Explicit Path        : atod
  Metric Type          : TE
# Execute the display ip routing-table command on Switch A. The output shows a static route entry with interface Tunnel1 as the output interface.
Destinations : 14       Routes : 14
7.1.1.0/24         Direct  0   0           7.1.1.1         Tun1
7.1.1.1/32         Direct  0   0           127.0.0.1       InLoop0
30.1.1.0/24        Static  1   0           7.1.1.1         Tun1
Bidirectional MPLS TE tunnel configuration example
Switch A, Switch B, Switch C, and Switch D all run IS-IS and they are all level-2 switches.
Use RSVP-TE to establish a bidirectional MPLS TE tunnel between Switch A and Switch D.
Figure 10 Network diagram
Table 5 Interface and IP address assignment
Device
IP address
Device
IP address
Switch A
Loop0
1.1.1.9/32
Switch D
Loop0
4.4.4.9/32
Vlan-int1
10.1.1.1/24
Vlan-int3
30.1.1.2/24
Switch B
Loop0
2.2.2.9/32
Switch C
Loop0
3.3.3.9/32
Vlan-int1
10.1.1.2/24
Vlan-int3
30.1.1.1/24
Vlan-int2
20.1.1.1/24
Vlan-int2
20.1.1.2/24
2.     Configure IS-IS to advertise interface addresses, including the loopback interface address.
For more information, see "Establishing an MPLS TE tunnel with RSVP-TE."
3.     Configure an LSR ID, and enable MPLS, MPLS TE, and RSVP-TE on each switch:
[SwitchA] mpls te
[SwitchA-te] quit
[SwitchA] rsvp
[SwitchA-rsvp] quit
[SwitchB] mpls te
[SwitchB-te] quit
[SwitchB] rsvp
[SwitchB-rsvp] quit
[SwitchC] mpls te
[SwitchC-te] quit
[SwitchC] rsvp
[SwitchC-rsvp] quit
[SwitchD] mpls te
[SwitchD-te] quit
[SwitchD] rsvp
[SwitchD-rsvp] quit
[SwitchA] isis 1
[SwitchB] isis 1
[SwitchC] isis 1
[SwitchD] isis 1
5.     Configure a co-routed bidirectional MPLS TE tunnel:
# Configure Switch A as the active end of the co-routed bidirectional tunnel.
[SwitchA-Tunnel1] mpls te resv-style ff
[SwitchA-Tunnel1] mpls te bidirectional co-routed active
# Configure Switch D as the passive end of the co-routed bidirectional tunnel.
[SwitchD] interface tunnel 4 mode mpls-te
[SwitchD-Tunnel4] ip address 8.1.1.1 255.255.255.0
[SwitchD-Tunnel4] destination 1.1.1.9
[SwitchD-Tunnel4] mpls te signaling rsvp-te
[SwitchD-Tunnel4] mpls te resv-style ff
[SwitchD-Tunnel4] mpls te bidirectional co-routed passive reverse-lsp lsr-id 1.1.1.9 tunnel-id 1
[SwitchD-Tunnel4] quit
    0 packets output, 0 bytes, 0 drops
Tunnel State           : Up (Main CRLSP up, Reverse CRLSP up)
Tunnel Attributes      :
  LSP ID               : 30478           Tunnel ID            : 1
  Resv Style           : FF
  Tunnel mode          : Co-routed, active
  Class Type           : CT0             Tunnel Bandwidth     : 0 kbps
  Reserved Bandwidth   : 0 kbps
  Explicit Path        : -
  Metric Type          : TE
# Execute the display mpls lsp verbose command on Switch A to display detailed information about the bidirectional MPLS TE tunnel.
[SwitchA] display mpls lsp verbose
Destination  : 4.4.4.9
FEC          : 1.1.1.9/1/30478
Protocol     : RSVP
LSR Type     : Ingress
Service      : -
NHLFE ID     : 1027
State        : Active
Out-Label    : 1149
Nexthop      : 10.1.1.2
Out-Interface: vlan1
Protocol     : RSVP
LSR Type     : Egress
Service      : -
In-Label     : 3
State        : Active
Nexthop      : 127.0.0.1
Out-Interface: -
Destination  : 10.1.1.2
FEC          : 10.1.1.2
Protocol     : Local
LSR Type     : Ingress
Service      : -
NHLFE ID     : 1026
State        : Active
Nexthop      : 10.1.1.2
# Execute the display interface tunnel command on Switch D. The output shows that the tunnel interface is up.
[SwitchD] display interface tunnel
Tunnel4 current state: UP
Description: Tunnel8 Interface
Internet Address is 8.1.1.1/24 Primary
Tunnel source unknown, destination 1.1.1.9
Tunnel TTL 255
# Execute the display mpls te tunnel-interface command on Switch D to display detailed information about the MPLS TE tunnel.
[SwitchD] display mpls te tunnel-interface
Tunnel Name            : Tunnel 4
Tunnel Attributes      :
  LSP ID               : -               Tunnel ID            : 8
  Ingress LSR ID       : -               Egress LSR ID        : -
  Resv Style           : FF
  Tunnel mode          : Co-routed, passive
  Reverse-LSP LSR ID   : 1.1.1.9         Reverse-LSP Tunnel ID: 1
  Setup Priority       : -               Holding Priority     : -
  Explicit Path        : -
  Metric Type          : -
  Bypass Tunnel        : -              Auto Created         : No
  Route Pinning        : -
  Retry Limit          : -               Retry Interval       : -
# Execute the display mpls lsp verbose command on Switch D to display detailed information about the bidirectional MPLS TE tunnel.
[SwitchD] display mpls lsp verbose
Protocol     : RSVP
LSR Type     : Egress
Service      : -
In-Label     : 3
State        : Active
Nexthop      : 127.0.0.1
Out-Interface: -
Protocol     : RSVP
LSR Type     : Ingress
Service      : -
NHLFE ID     : 1025
State        : Active
Out-Label    : 1150
Nexthop      : 30.1.1.1
Out-Interface: vlan3
Destination  : 30.1.1.1
FEC          : 30.1.1.1
Protocol     : Local
LSR Type     : Ingress
Service      : -
NHLFE ID     : 1024
State        : Active
Nexthop      : 30.1.1.1
CRLSP backup configuration example
Switch A, Switch B, Switch C, and Switch D run IS-IS.
Use RSVP-TE to establish an MPLS TE tunnel from Switch A to Switch C. Enable CRLSP hot backup for the tunnel to simultaneously establish a primary CRLSP and a backup CRLSP. When the primary CRLSP fails, traffic is switched to the backup CRLSP.
Figure 11 Network diagram
Device
IP address
Device
IP address
Switch A
Loop0
1.1.1.9/32
Switch D
Loop0
4.4.4.9/32
Vlan-int1
10.1.1.1/24
Vlan-int4
30.1.1.2/24
Vlan-int4
30.1.1.1/24
Vlan-int3
40.1.1.1/24
Switch B
Loop0
2.2.2.9/32
Switch C
Loop0
3.3.3.9/32
Vlan-int1
10.1.1.2/24
Vlan-int2
20.1.1.2/24
Vlan-int2
20.1.1.1/24
Vlan-int3
40.1.1.2/24
Before configuration, disable the spanning tree feature globally or map each VLAN to an MSTI.
2.     Configure IS-IS to advertise interface addresses, including the loopback interface address. (Details not shown.)
[SwitchA] mpls te
[SwitchA-te] quit
[SwitchA] rsvp
[SwitchA-rsvp] quit
[SwitchA] interface vlan-interface 4
[SwitchA-Vlan-interface4] mpls enable
[SwitchA-Vlan-interface4] mpls te enable
[SwitchA-Vlan-interface4] rsvp enable
[SwitchA-Vlan-interface4] quit
# Configure Switch B, Switch C, and Switch D in the same way that Switch A is configured. (Details not shown.)
4.     Configure an MPLS TE tunnel on Switch A:
# Configure the MPLS TE tunnel interface Tunnel 3.
[SwitchA] interface tunnel 3 mode mpls-te
[SwitchA-Tunnel3] ip address 9.1.1.1 24
[SwitchA-Tunnel3] destination 3.3.3.9
[SwitchA-Tunnel3] mpls te signaling rsvp-te
# Enable CRLSP hot backup for the tunnel.
[SwitchA-Tunnel3] mpls te backup hot-standby
[SwitchA-Tunnel3] quit
5.     Configure a static route on Switch A to direct the traffic destined for subnet 20.1.1.0/24 to MPLS TE tunnel 3.
[SwitchA] ip route-static 20.1.1.2 24 tunnel 3 preference 1
# Execute the display interface tunnel command on Switch A. The output shows that the tunnel interface Tunnel 3 is up.
Tunnel3 current state: UP
Description: Tunnel3 Interface
Internet Address is 9.1.1.1/24 Primary
Tunnel source unknown, destination 3.3.3.9
Tunnel TTL 255
    Last 300 seconds output rate: 1802 bytes/sec, 14416 bits/sec, 0 packets/sec
    351 packets output, 3105652 bytes, 0 drops
# Execute the display mpls lsp command on Switch A. The output shows that two CRLSPs exist on the switch, one with the output interface VLAN-interface 1 and the other with the output interface VLAN-interface 4.
1.1.1.9/3/30106             RSVP     -/1137          Vlan1
1.1.1.9/3/30107             RSVP     -/1150          Vlan4
10.1.1.2                    Local    -/-             Vlan1
30.1.1.2                    Local    -/-             Vlan4
# Execute the display rsvp lsp verbose command on Switch A to display the paths used by the two CRLSPs.
[SwitchA] display rsvp lsp verbose
Tunnel name: SwitchA_t3
Destination: 3.3.3.9                      Source: 1.1.1.9
Tunnel ID: 3                              LSP ID: 30106
LSR type: Ingress                         Direction: Unidirectional
Setup priority: 7                         Holding priority: 7
In-Label: -                               Out-Label: 1137
In-Interface: -                           Out-Interface: GE1/0/1
Nexthop: 10.1.1.2                         Exclude-any: 0
Include-Any: 0                            Include-all: 0
Mean rate (CIR): 0 kbps                   Mean burst size (CBS): 1000.00 bytes
Path MTU: 1500                            Class type: CT0
RRO number: 6
  10.1.1.1/32        Flag: 0x00 (No FRR)
  10.1.1.2/32        Flag: 0x00 (No FRR)
  2.2.2.9/32         Flag: 0x20 (No FRR/Node-ID)
  20.1.1.1/32        Flag: 0x00 (No FRR)
  20.1.1.2/32        Flag: 0x00 (No FRR)
  3.3.3.9/32         Flag: 0x20 (No FRR/Node-ID)
Fast Reroute protection: None
Tunnel name: Tunnel3
Tunnel ID: 3                              LSP ID: 30107
In-Label: -                               Out-Label: 1150
In-Interface: -                           Out-Interface: Vlan4
Nexthop: 30.1.1.2                         Exclude-any: 0
RRO number: 6
  30.1.1.1/32        Flag: 0x00 (No FRR)
  30.1.1.2/32        Flag: 0x00 (No FRR)
  4.4.4.9/32         Flag: 0x20 (No FRR/Node-ID)
  40.1.1.1/32        Flag: 0x00 (No FRR)
  40.1.1.2/32        Flag: 0x00 (No FRR)
# Tracert the tunnel destination 3.3.3.9. The output shows that the used CRLSP is the one that traverses Switch B.
[SwitchA] tracert –a 1.1.1.9 3.3.3.9
traceroute to 3.3.3.9 (3.3.3.9) from 1.1.1.9, 30 hops at most, 40 bytes each pac
ket, press CTRL_C to break
 1 10.1.1.2 (10.1.1.2)  1.000 ms  1.000 ms  1.000 ms
 2 * * *
# Shut down interface VLAN-interface 2 on Switch B, and then tracert the tunnel destination. The output shows that packets are forwarded on the CRLSP that traverses Switch D.
 1  30.1.1.2 (30.1.1.2)  3.000 ms  7.000 ms  3.000 ms
 2  * * *
# Execute the display mpls lsp command on Switch A. The output shows that only one CRLSP exists on the switch.
1.1.1.9/3/48984             RSVP     -/1150          Vlan4
# Execute the display ip routing-table command on Switch A. The output shows a static route entry with interface Tunnel 3 as the output interface. (Details not shown.)
Manual bypass tunnel for FRR configuration example
On the primary CRLSP Switch A—Switch B—Switch C—Switch D, use FRR to protect the link Switch B—Switch C.
Use RSVP-TE to establish the primary CRLSP and bypass tunnel of the MPLS TE tunnel based on the constraints of the explicit paths. The bypass tunnel uses path Switch B—Switch E—Switch C. Switch B is the PLR and Switch C is the MP.
Configure BFD for RSVP-TE between Switch B and Switch C. When the link between Switch B and Switch C fails, BFD can detect the failure quickly and notify RSVP-TE of the failure, so RSVP-TE can switch traffic to the bypass tunnel.
Figure 12 Network diagram
Table 7 Interface and IP address assignment
Device
IP address
Device
IP address
Switch A
Loop0
1.1.1.1/32
Switch E
Loop0
5.5.5.5/32
Vlan-int1
2.1.1.1/24
Vlan-int4
3.2.1.2/24
Switch B
Loop0
2.2.2.2/32
Vlan-int5
3.3.1.1/24
Vlan-int1
2.1.1.2/24
Switch C
Loop0
3.3.3.3/32
Vlan-int2
3.1.1.1/24
Vlan-int3
4.1.1.1/24
Vlan-int4
3.2.1.1/24
Vlan-int2
3.1.1.2/24
Switch D
Loop0
4.4.4.4/32
Vlan-int5
3.3.1.2/24
Vlan-int3
4.1.1.2/24
3.     Configure an LSR ID, and enable MPLS, MPLS TE, and RSVP-TE on each switch. Enable BFD for RSVP-TE on Switch B and Switch C:
[SwitchA] mpls te
[SwitchA-te] quit
[SwitchA] rsvp
[SwitchA-rsvp] quit
[SwitchB] mpls te
[SwitchB-te] quit
[SwitchB] rsvp
[SwitchB-rsvp] quit
[SwitchB-Vlan-interface2] rsvp bfd enable
[SwitchB] interface vlan-interface 4
[SwitchB-Vlan-interface4] mpls enable
[SwitchB-Vlan-interface4] mpls te enable
[SwitchB-Vlan-interface4] rsvp enable
[SwitchB-Vlan-interface4] quit
# Configure Switch C in the same way that Switch B is configured. Configure Switch D and Switch E in the same way that Switch A is configured. (Details not shown.)
4.     Configure an MPLS TE tunnel on Switch A, the ingress node of the primary CRLSP:
# Configure an explicit path for the primary CRLSP.
[SwitchA] explicit-path pri-path
[SwitchA-explicit-path-pri-path] nexthop 2.1.1.2
[SwitchA-explicit-path-pri-path] nexthop 3.1.1.2
[SwitchA-explicit-path-pri-path] nexthop 4.1.1.2
[SwitchA-explicit-path-pri-path] nexthop 4.4.4.4
[SwitchA-explicit-path-pri-path] quit
# Create MPLS TE tunnel interface Tunnel 4 for the primary CRLSP.
[SwitchA] interface tunnel 4 mode mpls-te
[SwitchA-Tunnel4] ip address 10.1.1.1 255.255.255.0
[SwitchA-Tunnel4] destination 4.4.4.4
# Specify the tunnel signaling protocol as RSVP-TE.
[SwitchA-Tunnel4] mpls te signaling rsvp-te
# Specify the explicit path to be used as pri-path.
[SwitchA-Tunnel4] mpls te path preference 1 explicit-path pri-path
# Enable FRR for the MPLS TE tunnel.
[SwitchA-Tunnel4] mpls te fast-reroute
[SwitchA-Tunnel4] quit
# Execute the display interface tunnel command on Switch A. The output shows that the tunnel interface Tunnel 4 is up.
Tunnel TTL 255
    Last 300 seconds output rate: 1911 bytes/sec, 15288 bits/sec, 0 packets/sec
    1526 packets output, 22356852 bytes, 0 drops
Tunnel Attributes      :
  LSP ID               : 48960           Tunnel ID            : 4
  Resv Style           : SE
  Tunnel mode          : -
  Explicit Path        : pri-path
  Metric Type          : TE
  Record Route         : Enabled         Record Label         : Enabled
  FRR Flag             : Enabled         Bandwidth Protection : Disabled
5.     Configure a bypass tunnel on Switch B (the PLR):
# Configure an explicit path for the bypass tunnel.
[SwitchB] explicit-path by-path
[SwitchB-explicit-path-by-path] nexthop 3.2.1.2
[SwitchB-explicit-path-by-path] nexthop 3.3.1.2
[SwitchB-explicit-path-by-path] nexthop 3.3.3.3
[SwitchB-explicit-path-by-path] quit
# Create MPLS TE tunnel interface Tunnel 5 for the bypass tunnel.
[SwitchB] interface tunnel 5 mode mpls-te
[SwitchB-Tunnel5] ip address 11.1.1.1 255.255.255.0
# Specify the tunnel destination address as LSR ID of Switch C.
[SwitchB-Tunnel5] destination 3.3.3.3
[SwitchB-Tunnel5] mpls te signaling rsvp-te
# Specify the explicit path to be used as by-path.
[SwitchB-Tunnel5] mpls te path preference 1 explicit-path by-path
# Configure the bandwidth that the bypass tunnel can protect.
[SwitchB-Tunnel5] mpls te backup bandwidth un-limited
[SwitchB-Tunnel5] quit
# Bind the bypass tunnel to the protected interface.
[SwitchB-Vlan-interface2] mpls te fast-reroute bypass-tunnel tunnel 5
# Execute the display interface tunnel command on Switch B to verify that the tunnel interface Tunnel 5 is up. (Details not shown.)
6.     Configure a static route on Switch A to direct the traffic destined for subnet 4.1.1.0/24 to MPLS TE tunnel 4.
[SwitchA] ip route-static 4.1.1.2 24 tunnel 4 preference 1
# Execute the display mpls lsp command on each switch. The output shows the LSP entries. Switch B and Switch C each have two CRLSPs. The bypass tunnel backs up the primary CRLSP.
1.1.1.1/4/61400             RSVP     -/1245          Vlan1
1.1.1.1/4/614000            RSVP     1245/3          Vlan2
Backup                               1245/3          Tun5
2.2.2.2/5/30914             RSVP     -/1150          Vlan2
3.2.1.2                     Local    -/-             Vlan4
3.1.1.2                     Local    -/-             Vlan2
[SwitchE] display mpls lsp
2.2.2.2/5/30914             RSVP     1150/3          Vlan5
3.3.1.2                     Local    -/-             Vlan5
# Shut down the protected interface VLAN-interface 2 on the PLR (Switch B).
[SwitchB-Vlan-interface2] shutdown
# Execute the display interface tunnel 4 command on Switch A to display information about the primary CRLSP. The output shows that the tunnel interface is still up. (Details not shown.)
# Execute the display mpls te tunnel-interface command on Switch A to display detailed information about the tunnel interface.
Tunnel State           : Up (Main CRLSP up, Shared-resource CRLSP being set up)
Tunnel Attributes      :
  LSP ID               : 18753           Tunnel ID            : 4
  Resv Style           : SE
  Tunnel mode          : -
  Metric Type          : TE
If you execute the display mpls te tunnel-interface command immediately after an FRR, you can see two CRLSPs in up state. This is because FRR uses the make-before-break mechanism to set up a new LSP, and the old LSP is deleted after the new one has been established for a while.
# Execute the display mpls lsp command on Switch B. The output shows that the bypass tunnel is in use.
1.1.1.1/4/61400             RSVP     1136/3          Tun5
2.2.2.2/5/30914             RSVP     -/1149          Vlan4
# On the PLR, configure the interval for selecting an optimal bypass tunnel as 5 seconds.
[SwitchB] mpls te
[SwitchB-te] fast-reroute timer 5
[SwitchB-te] quit
# On the PLR, bring up the protected interface VLAN-interface 2.
[SwitchB-Vlan-interface2] undo shutdown
# Execute the display interface tunnel 4 command on Switch A to display information about the primary CRLSP. The output shows that the tunnel interface is in up state. (Details not shown.)
# Wait for about 5 seconds, execute the display mpls lsp verbose command on Switch B. The output shows that Tunnel 5 is bound to interface VLAN-interface 2 but not in use. (Details not shown.)
# Execute the display ip routing-table command on Switch A. The output shows a static route entry with interface Tunnel 4 as the output interface. (Details not shown.)
Auto FRR configuration example
Use RSVP-TE to set up a primary CRLSP that explicitly uses path Switch A—Switch B—Switch C—Switch D.
Configure auto FRR on Switch B to automatically set up bypass tunnels for the primary CRLSP.
Figure 13 Network diagram
Table 8 Interface and IP address assignment
Device
IP address
Device
IP address
Switch A
Loop0
1.1.1.1/32
Switch E
Loop0
5.5.5.5/32
Vlan-int1
2.1.1.1/24
Vlan-int4
3.2.1.2/24
Switch B
Loop0
2.2.2.2/32
Vlan-int5
3.4.1.1/24
Vlan-int1
2.1.1.2/24
Switch C
Loop0
3.3.3.3/32
Vlan-int2
3.1.1.1/24
Vlan-int3
4.1.1.1/24
Vlan-int4
3.2.1.1/24
Vlan-int2
3.1.1.2/24
Vlan-int6
3.3.1.1/24
Vlan-int5
3.4.1.2/24
Switch D
Loop0
4.4.4.4/32
Switch F
Loop0
6.6.6.6/32
Vlan-int3
4.1.1.2/24
Vlan-int6
3.3.1.2/24
Vlan-int7
4.2.1.2/24
Vlan-int7
4.2.1.1/24
[SwitchA] mpls te
[SwitchA-te] quit
[SwitchA] rsvp
[SwitchA-rsvp] quit
[SwitchB] mpls te
[SwitchB-te] quit
[SwitchB] rsvp
[SwitchB-rsvp] quit
[SwitchB] interface vlan-interface 6
[SwitchB-Vlan-interface6] mpls enable
[SwitchB-Vlan-interface6] mpls te enable
[SwitchB-Vlan-interface6] rsvp enable
[SwitchB-Vlan-interface6] quit
# Configure Switch C in the same way that Switch B is configured. Configure Switch D, Switch E, and Switch F in the same way that Switch A is configured. (Details not shown.)
# Configure an explicit path named pri-path for the primary CRLSP.
# Configure an MPLS TE tunnel.
[SwitchA-Tunnel1] ip address 10.1.1.1 255.255.255.0
[SwitchA-Tunnel1] destination 4.4.4.4
# Specify the explicit path as pri-path.
[SwitchA-Tunnel1] mpls te path preference 1 explicit-path pri-path
[SwitchA-Tunnel1] mpls te fast-reroute
# Execute the display interface tunnel command on Switch A. The output shows that the MPLS TE interface Tunnel1 is up.
Internet Address is 10.1.1.1/24 Primary
Tunnel source unknown, destination 4.4.4.4
Tunnel TTL 255
# Execute the display mpls te tunnel-interface command on Switch A to display detailed information about the MPLS TE tunnel interface.
Tunnel Attributes      :
  LSP ID               : 16802           Tunnel ID            : 1
  Ingress LSR ID       : 2.2.2.2         Egress LSR ID        : 4.4.4.4
  Resv Style           : SE
  Tunnel mode          : -
  Explicit Path        : exp1
  Metric Type          : TE
5.     Configure auto FRR on Switch B (the PLR):
# Enable the automatic bypass tunnel setup function globally.
[SwitchB] mpls te
[SwitchB-te] auto-tunnel backup
# Specify interface numbers 50 to 100 for the automatically created bypass tunnels.
[SwitchB-te-auto-bk] tunnel-number min 50 max 100
[SwitchB-te-auto-bk] quit
# Execute the display interface tunnel brief on Switch B. The output shows that two tunnels have been created automatically.
[SwitchB] display interface tunnel brief
Brief information on interface(s) under route mode:
Protocol: (s) - spoofing
Interface            Link Protocol Main IP         Description
Tun50                 UP    UP        --
Tun51                 UP    UP        --
# Execute the display mpls te tunnel-interface command on Switch B to display information about Tunnel 50 and Tunnel 51. The output shows that Tunnel 50 and Tunnel 51 are automatically created bypass tunnels. Tunnel 50 is a node-protection bypass tunnel (egress LSR ID is 4.4.4.4, the LSR ID of Switch D). Tunnel 51 is a link-protection bypass tunnel (egress LSR ID is 3.3.3.3, the LSR ID of Switch C).
[SwitchB] display mpls te tunnel-interface tunnel 50
Tunnel Name            : Tunnel 50
Tunnel Attributes      :
  LSP ID               : 16802           Tunnel ID            : 50
  Resv Style           : SE
  Tunnel mode          : -
  Explicit Path        : -
  Metric Type          : TE
  Record Route         : Enabled         Record Label         : Disabled
  Bypass Tunnel        : Yes             Auto Created         : Yes
[SwitchB] display mpls te tunnel-interface tunnel 51
Tunnel Name            : Tunnel 51
Tunnel Attributes      :
  LSP ID               : 16802           Tunnel ID            : 51
  Ingress LSR ID       : 2.2.2.2         Egress LSR ID        : 3.3.3.3
  Resv Style           : SE
  Tunnel mode          : -
  Explicit Path        : -
  Metric Type          : TE
# Execute the display mpls lsp command on Switch B. The output shows that the current bypass tunnel that protects the primary CRLSP is Tunnel 50.
2.2.2.2/51/16802            RSVP     -/3             Vlan4
2.2.2.2/1/16802             RSVP     -/1151          Vlan2
Backup                               -/3             Tun50
2.2.2.2/50/16802            RSVP     -/3             Vlan6
3.2.1.2                     Local    -/-             Vlan6
3.3.1.2                     Local    -/-             Vlan6
# Execute the display rsvp lsp verbose command on Switch A to display detailed information about MPLS TE tunnel 1, the tunnel for the primary CRLSP. The output shows that Tunnel1 is protected by the bypass tunnel Tunnel 50, and the protected node is 3.1.1.1.
[SwitchA] display rsvp lsp tunnel-id 1 verbose
Tunnel name: Tunnel1
Destination: 4.4.4.4                      Source: 1.1.1.1
Tunnel ID: 1                              LSP ID: 16802
In-Interface: -                           Out-Interface: Vlan1
Nexthop: 2.1.1.2                          Exclude-any: 0
Average bitrate: 0 kbps                   Maximum burst: 1000.00 bytes
RRO number: 12
  2.1.1.1/32         Flag: 0x00 (No FRR)
  2.1.1.2/32         Flag: 0x00 (No FRR)
  1150               Flag: 0x01 (Global label)
  2.2.2.2/32         Flag: 0x20 (No FRR/Node-ID)
  3.1.1.1/32         Flag: 0x09 (FRR Avail/Node-Prot)
  3.1.1.2/32         Flag: 0x00 (No FRR)
  1151               Flag: 0x01 (Global label)
  3.3.3.3/32         Flag: 0x20 (No FRR/Node-ID)
  4.1.1.1/32         Flag: 0x00 (No FRR)
  4.1.1.2/32         Flag: 0x00 (No FRR)
  3                  Flag: 0x01 (Global label)
  4.4.4.4/32         Flag: 0x20 (No FRR/Node-ID)
Fast Reroute protection: Ready
  FRR inner label: 3           Bypass tunnel: Tunnel50
IETF DS-TE configuration example
Use RSVP-TE to create a TE tunnel from Switch A to Switch D. Traffic of the tunnel belongs to CT 2, and the tunnel needs a bandwidth of 4000 kbps.
The maximum bandwidth of the link that the tunnel traverses is 10000 kbps and the maximum reservable bandwidth of the link is 10000 kbps. BC 1, BC 2, and BC 3 are 8000 kbps, 5000 kbps, and 2000 kbps.
Figure 14 Network diagram
Table 9 Interface and IP address assignment
Device
IP address
Device
IP address
Switch A
Loop0
1.1.1.9/32
Switch D
Loop0
4.4.4.9/32
Vlan-int1
10.1.1.1/24
Vlan-int3
30.1.1.2/24
Switch B
Loop0
2.2.2.9/32
Switch C
Loop0
3.3.3.9/32
Vlan-int1
10.1.1.2/24
Vlan-int3
30.1.1.1/24
Vlan-int2
20.1.1.1/24
Vlan-int2
20.1.1.2/24
[SwitchA] isis 1
[SwitchB] isis 1
[SwitchC] isis 1
[SwitchD] isis 1
2.2.2.9/32         IS_L1   15  10          10.1.1.2        Vlan1
3.3.3.9/32         IS_L1   15  20          10.1.1.2        Vlan1
4.4.4.9/32         IS_L1   15  30          10.1.1.2        Vlan1
20.1.1.0/24        IS_L1   15  20          10.1.1.2        Vlan1
30.1.1.0/24        IS_L1   15  30          10.1.1.2        Vlan1
3.     Configure an LSR ID, enable MPLS, MPLS TE, and RSVP-TE, and configure the DS-TE mode as IETF:
[SwitchA] mpls te
[SwitchA-te] ds-te mode ietf
[SwitchA-te] quit
[SwitchA] rsvp
[SwitchA-rsvp] quit
[SwitchB] mpls te
[SwitchB-te] ds-te mode ietf
[SwitchB-te] quit
[SwitchB] rsvp
[SwitchB-rsvp] quit
[SwitchC] mpls te
[SwitchC-te] ds-te mode ietf
[SwitchC-te] quit
[SwitchC] rsvp
[SwitchC-rsvp] quit
[SwitchD] mpls te
[SwitchD-te] ds-te mode ietf
[SwitchD-te] quit
[SwitchD] rsvp
[SwitchD-rsvp] quit
[SwitchA] isis 1
[SwitchB] isis 1
[SwitchC] isis 1
[SwitchD] isis 1
# Set the maximum bandwidth, maximum reservable bandwidth, and bandwidth constraints on Switch A.
[SwitchA-Vlan-interface1] mpls te max-reservable-bandwidth rdm 10000 bc1 8000 bc2 5000 bc3 2000
# Set the maximum bandwidth, maximum reservable bandwidth, and bandwidth constraints on Switch B.
[SwitchB-Vlan-interface1] mpls te max-reservable-bandwidth rdm 10000 bc1 8000 bc2 5000 bc3 2000
[SwitchB-Vlan-interface2] mpls te max-reservable-bandwidth rdm 10000 bc1 8000 bc2 5000 bc3 2000
# Set the maximum bandwidth, maximum reservable bandwidth, and bandwidth constraints on Switch C.
[SwitchC-Vlan-interface3] mpls te max-reservable-bandwidth rdm 10000 bc1 8000 bc2 5000 bc3 2000
[SwitchC-Vlan-interface2] mpls te max-reservable-bandwidth rdm 10000 bc1 8000 bc2 5000 bc3 2000
# Set the maximum bandwidth, maximum reservable bandwidth, and bandwidth constraints on Switch D.
[SwitchD-Vlan-interface3] mpls te max-reservable-bandwidth rdm 10000 bc1 8000 bc2 5000 bc3 2000
# Create the MPLS TE tunnel interface Tunnel 1.
[SwitchA] interface Tunnel 1 mode mpls-te
# Assign 4000 kbps bandwidth to CT 2 for the tunnel.
[SwitchA-Tunnel1] mpls te bandwidth ct2 4000
# Set the tunnel setup priority and holding priority both to 0.
[SwitchA-Tunnel1] mpls te priority 0
Tunnel TTL 255
    0 packets input,  0 bytes 0 drop    0 packets output,  0 bytes 0 drop
Tunnel Attributes      :
  LSP ID               : 36882           Tunnel ID            : 1
  Resv Style           : SE
  Tunnel mode          : -
  Class Type           : CT2             Tunnel Bandwidth     : 4000 kbps
  Reserved Bandwidth   : 4000 kbps
  Explicit Path        : -
  Metric Type          : TE
# Execute the display mpls te link-management bandwidth-allocation command on Switch A to display bandwidth information on interface VLAN-interface 1.
[SwitchA] display mpls te link-management bandwidth-allocation interface vlan-interface 1
Interface:  Vlan-interface1
  Max Link Bandwidth                          : 10000 kbps
  Max Reservable Bandwidth of Prestandard RDM : 0 kbps
  Max Reservable Bandwidth of IETF RDM        : 10000 kbps
  Max Reservable Bandwidth of IETF MAM        : 0 kbps
  Allocated Bandwidth-Item Count  : 1
  Allocated Bandwidth             : 0 kbps
  Physical Link Status            : Up
  BC  Prestandard RDM(kbps)  IETF RDM(kbps)       IETF MAM(kbps)
  0   0                      10000                0
  1   0                      8000                 0
  2   -                      5000                 0
  3   -                      2000                 0
  TE Class    Class Type    Priority   BW Reserved(kbps)  BW Available(kbps)
  0           0             0          0                  0
  1           0             1          0                  0
  2           0             2          0                  0
  3           0             3          0                  0
  4           0             4          0                  0
  5           0             5          0                  0
  6           0             6          0                  0
  7           0             7          0                  0
  8           1             0          0                  0
  9           1             1          0                  0
  10          1             2          0                  0
  11          1             3          0                  0
  12          1             4          0                  0
  13          1             5          0                  0
  14          1             6          0                  0
  15          1             7          0                  0
Troubleshooting MPLS TE
No TE LSA generated
Symptom
OSPF TE is configured but no TE LSAs can be generated to describe MPLS TE attributes.
Analysis
For TE LSAs to be generated, at least one OSPF neighbor must reach FULL state.
Solution
1.     To resolve the problem:
a.     Use the display current-configuration command to verify that MPLS TE is configured on involved interfaces.
b.     Use the debugging ospf mpls-te command to verify that OSPF can receive the TE LINK establishment message.
c.     Use the display ospf peer command to verify that OSPF neighbors are established correctly.
2.     If the problem persists, contact H3C Support.
