05-Layer 3 - IP Services Configuration Guide
HomeSupportSwitchesS12500 SeriesConfigure & DeployConfiguration GuidesH3C S12500 Configuration Guides-Release7374-6W73105-Layer 3 - IP Services Configuration Guide
04-DNS configuration
04-DNS configuration 458.87 KB
Configuring DNS· 1
Overview·· 1
Static domain name resolution· 1
Dynamic domain name resolution· 1
DNS proxy· 2
DNS spoofing· 3
DNS configuration task list 4
Configuring the IPv4 DNS client 5
Configuring static domain name resolution· 5
Configuring dynamic domain name resolution· 5
Configuring the IPv6 DNS client 6
Configuring static domain name resolution· 6
Configuring dynamic domain name resolution· 7
Configuring the DNS proxy· 8
Configuring DNS spoofing· 8
Specifying the source interface for DNS packets 9
Configuring the DNS trusted interface· 9
Setting the DSCP value for outgoing DNS packets 10
Displaying and maintaining IPv4 DNS· 10
IPv4 DNS configuration examples 10
Static domain name resolution configuration example· 11
Dynamic domain name resolution configuration example· 11
DNS proxy configuration example· 14
IPv6 DNS configuration examples 15
Static domain name resolution configuration example· 15
Dynamic domain name resolution configuration example· 16
DNS proxy configuration example· 21
Troubleshooting IPv4 DNS configuration· 22
Symptom·· 22
Solution· 22
Troubleshooting IPv6 DNS configuration· 22
Symptom·· 22
Solution· 22
Configuring DDNS· 24
Overview·· 24
DDNS application· 24
DDNS client configuration task list 25
Configuring a DDNS policy· 25
Configuration prerequisites 26
Configuration procedure· 26
Applying the DDNS policy to an interface· 27
Setting the DSCP value for outgoing DDNS packets 28
Displaying DDNS· 28
DDNS configuration examples 28
DDNS configuration example with www.3322.org· 28
DDNS configuration example with PeanutHull server 30
Overview
Domain Name System (DNS) is a distributed database used by TCP/IP applications to translate domain names into IP addresses. With DNS, you can use easy-to-remember domain names in some applications and let the DNS server translate them into correct IP addresses. The domain name-to-IP address mapping is called a DNS entry.
DNS services can be static or dynamic. After a user specifies a name, the device checks the static name resolution table for an IP address. If no IP address is available, it contacts the DNS server for dynamic name resolution, which takes more time than static name resolution. To improve efficiency, you can put frequently queried name-to-IP address mappings in the local static name resolution table.
Static domain name resolution means manually creating mappings between domain names and IP addresses. For example, you can create a static DNS mapping for a device so that you can Telnet to the device by using the domain name.
Resolution process
1.     A user program sends a name query to the resolver of the DNS client.
2.     The DNS resolver looks up the local domain name cache for a match. If the resolver finds a match, it sends the corresponding IP address back. If not, it sends a query to the DNS server.
3.     The DNS server looks up the corresponding IP address of the domain name in its DNS database. If no match is found, the server sends a query to other DNS servers. This process continues until a result, whether successful or not, is returned.
4.     After receiving a response from the DNS server, the DNS client returns the resolution result to the user program.
Figure 1 Dynamic domain name resolution
Figure 1 shows the relationship between the user program, DNS client, and DNS server.
The DNS client is made up of the resolver and cache. The user program and DNS client can run on the same device or different devices, but the DNS server and the DNS client usually run on different devices.
Dynamic domain name resolution allows the DNS client to store latest DNS entries in the dynamic domain name cache. The DNS client does not need to send a request to the DNS server for a repeated query within the aging time. To make sure the entries from the DNS server are up to date, a DNS entry is removed when its aging timer expires. The DNS server determines how long a mapping is valid, and the DNS client obtains the aging information from DNS responses.
DNS suffixes
You can configure a domain name suffix list so that the resolver can use the list to supply the missing part of an incomplete name.
For example, you can configure com as the suffix for aabbcc.com. The user only needs to enter aabbcc to obtain the IP address of aabbcc.com because the resolver adds the suffix and delimiter before passing the name to the DNS server.
The name resolver handles the queries based on the domain names that the user enters:
·     If the user enters a domain name without a dot (.) (for example, aabbcc), the resolver considers the domain name a host name and adds a DNS suffix before performing the query operation. If no match is found for the domain names with any configured suffix, the resolver uses the user entered domain name (for example, aabbcc) to query the IP address.
·     If the user enters a domain name with a dot (.) among the letters (for example, www.aabbcc), the resolver directly uses this domain name for the query operation. If the query fails, the resolver adds a DNS suffix for another query operation.
·     If the user enters a domain name with a dot (.) at the end (for example, aabbcc.com.), the resolver considers the domain name an FQDN and returns the successful or failed query result. The dot at the end of the domain name is considered a terminating symbol.
The device supports static and dynamic DNS client services.
If an alias is configured for a domain name on the DNS server, the device can resolve the alias into the IP address of the host.
DNS proxy
As shown in Figure 2, the DNS proxy performs the following operations:
·     Forwards the request from the DNS client to the designated DNS server.
·     Conveys the reply from the DNS server to the client.
The DNS proxy simplifies network management. When the DNS server address is changed, you can change the configuration only on the DNS proxy instead of on each DNS client.
Figure 2 DNS proxy application
A DNS proxy operates as follows:
1.     A DNS client considers the DNS proxy as the DNS server, and sends a DNS request to the DNS proxy. The destination address of the request is the IP address of the DNS proxy.
2.     The DNS proxy searches the local static domain name resolution table and dynamic domain name resolution cache after receiving the request. If the requested information is found, the DNS proxy returns a DNS reply to the client.
3.     If the requested information is not found, the DNS proxy sends the request to the designated DNS server for domain name resolution.
4.     After receiving a reply from the DNS server, the DNS proxy records the IP address-to-domain name mapping and forwards the reply to the DNS client.
If no DNS server is designated or no route is available to the designated DNS server, the DNS proxy does not forward DNS requests.
DNS spoofing
DNS spoofing is applied to the dial-up network, as shown in Figure 3.
·     The device connects to a PSTN/ISDN network through a dial-up interface. The device triggers the establishment of a dial-up connection only when packets are to be forwarded through the dial-up interface.
·     The device acts as a DNS proxy and is specified as a DNS server on the hosts. After the dial-up connection is established through the dial-up interface, the device dynamically obtains the DNS server address through DHCP or other autoconfiguration mechanisms.
Figure 3 DNS spoofing application
The DNS proxy does not have the DNS server address or cannot reach the DNS server after startup. A host accesses the HTTP server in the following steps:
1.     The host sends a DNS request to the device to resolve the domain name of the HTTP server into an IP address.
2.     Upon receiving the request, the device searches the local static and dynamic DNS entries for a match. Because no match is found, the device spoofs the host by replying a configured IP address. The device must have a route to the IP address with the dial-up interface as the output interface.
The IP address configured for DNS spoofing is not the actual IP address of the requested domain name. Therefore, the TTL field in the DNS reply is set to 0. When the DNS client receives the reply, it creates a DNS entry and ages it out immediately.
3.     Upon receiving the reply, the host sends an HTTP request to the replied IP address.
4.     When forwarding the HTTP request through the dial-up interface, the device performs the following operations:
¡     Establishes a dial-up connection with the network.
¡     Dynamically obtains the DNS server address through DHCP or another autoconfiguration mechanism.
5.     Because the DNS entry ages out immediately upon creation, the host sends a DNS request to the device again to resolve the HTTP server domain name into an IP address.
6.     The device operates the same as a DNS proxy. For more information, see "DNS proxy."
7.     After obtaining the IP address of the HTTP server, the host can access the HTTP server.
Without DNS spoofing, the device forwards the DNS requests from the host to the DNS server if it cannot find a matching local DNS entry. However, the device cannot obtain the DNS server address, because no dial-up connection is established. Therefore, the device cannot forward or answer the requests from the client. DNS resolution fails, and the client cannot access the HTTP server.
Tasks at a glance
Perform one of the following tasks:
·     Configuring the IPv4 DNS client
·     Configuring the IPv6 DNS client
(Optional.) Configuring the DNS proxy
(Optional.) Configuring DNS spoofing
(Optional.) Specifying the source interface for DNS packets
(Optional.) Configuring the DNS trusted interface
(Optional.) Setting the DSCP value for outgoing DNS packets
Static domain name resolution allows applications such as Telnet to contact hosts by using host names instead of IPv4 addresses.
Follow these guidelines when you configure static domain name resolution:
·     On the public network or a VPN, each host name maps to only one IPv4 address. The most recent configuration for a host name takes effect.
·     You can configure the following:
¡     IPv4 DNS entries for the public network and up to 1024 VPNs.
¡     A maximum of 1024 IPv4 DNS entries for the public network or each VPN.
To configure static domain name resolution:
Step
Remarks
N/A
2.     Configure a mapping between a host name and an IPv4 address.
ip host host-name ip-address [ vpn-instance vpn-instance-name ]
By default, no mapping between a host name and an IPv4 address is configured.
To use dynamic domain name resolution, configure DNS servers so that DNS queries can be sent to a correct server for resolution. A DNS server manually configured takes precedence over the one dynamically obtained through DHCP, and a DNS server configured earlier takes precedence. A name query is first sent to the DNS server that has the highest priority. If no reply is received, it is sent to the DNS server that has the second highest priority, and so on.
In addition, you can configure a DNS suffix that the system automatically adds to the provided domain name for resolution. A DNS suffix manually configured takes precedence over the one dynamically obtained through DHCP, and a DNS suffix configured earlier takes precedence. The DNS resolver first uses the suffix that has the highest priority. If the name resolution fails, the DNS resolver uses the suffix that has the second highest priority, and so on.
Configuration guidelines
Follow these guidelines when you configure dynamic domain name resolution:
·     You can specify DNS server IPv4 addresses as follows:
¡     Specify DNS server IPv4 addresses for the public network and up to 1024 VPNs.
¡     Specify a maximum of six DNS server IPv4 addresses for the public network or each VPN.
·     You can specify DNS server IPv6 addresses as follows:
¡     Specify DNS server IPv6 addresses for the public network and up to 1024 VPNs.
¡     Specify a maximum of six DNS server IPv6 addresses for the public network or each VPN.
An IPv4 name query is first sent to the DNS server IPv4 addresses. If no reply is received, it is sent to the DNS server IPv6 addresses.
·     You can specify DNS suffixes as follows:
¡     Specify DNS suffixes for the public network and up to 1024 VPNs.
¡     Specify a maximum of 16 DNS suffixes for the public network or each VPN.
To configure dynamic domain name resolution:
Step
Remarks
N/A
2.     Specify a DNS server IP address.
·     Specify a DNS server IPv4 address:
dns server
·     Specify a DNS server IPv6 address:
ipv6 dns server
ipv6-address [ interface-type interface-number ] [ vpn-instance vpn-instance-name ]
Use at least one command.
By default, no DNS server IP address is specified.
3.     (Optional.) Configure a DNS suffix.
dns domain domain-name [ vpn-instance vpn-instance-name ]
By default, no DNS suffix is configured and only the provided domain name is resolved.
Static domain name resolution allows applications such as Telnet to contact hosts by using host names instead of IPv6 addresses.
·     For the public network or a VPN, each host name maps to only one IPv6 address. The last configuration for a host name takes effect.
¡     IPv6 DNS entries for the public network and up to 1024 VPNs.
¡     A maximum of 1024 IPv6 DNS entries for the public network or each VPN.
Step
Remarks
N/A
2.     Configure a mapping between a host name and an IPv6 address.
ipv6 host host-name ipv6-address [ vpn-instance vpn-instance-name ]
By default, no mapping between a host name and an IPv6 address is configured.
To send DNS queries to a correct server for resolution, you must enable dynamic domain name resolution and configure DNS servers. A DNS server manually configured takes precedence over the one dynamically obtained through DHCP, and a DNS server configured earlier takes precedence. A name query is first sent to the DNS server that has the highest priority. If no reply is received, it is sent to the DNS server that has the second highest priority, and so on.
An IPv6 name query is first sent to the IPv6 DNS servers. If no reply is received, it is sent to the IPv4 DNS servers.
Step
Remarks
N/A
dns server ip-address [ vpn-instance vpn-instance-name ]
ipv6 dns server ipv6-address [ interface-type interface-number ] [ vpn-instance vpn-instance-name ]
By default, no DNS suffix is configured. Only the provided domain name is resolved.
You can specify multiple DNS servers. The DNS proxy forwards a request to the DNS server that has the highest priority. If having not received a reply, it forwards the request to a DNS server that has the second highest priority, and so on.
A DNS proxy forwards an IPv4 name query first to IPv4 DNS servers, and if no reply is received, it forwards the request to IPv6 DNS servers. The DNS proxy forwards an IPv6 name query first to IPv6 DNS servers, and if no reply is received, it forwards the request to IPv4 DNS servers.
To configure the DNS proxy:
Step
Remarks
N/A
2.     Enable DNS proxy.
dns proxy enable
By default, DNS proxy is disabled.
3.     Specify a DNS server IP address.
dns server
DNS spoofing is effective only when:
·     The DNS proxy is enabled on the device.
·     No DNS server or route to any DNS server is specified on the device.
Follow these guidelines when you configure DNS spoofing:
·     You can configure only one replied IPv4 address and one replied IPv6 address for the public network or a VPN. If you use the command multiple times, the most recent configuration takes effect.
·     You can configure DNS spoofing for the public network and a maximum of 1024 VPNs.
To configure DNS spoofing:
Step
Remarks
N/A
dns proxy enable
3.     Enable DNS spoofing and specify the translated IP address.
·     Specify a translated IPv4 address:
dns spoofing
·     Specify a translated IPv6 address:
ipv6 dns spoofing ipv6-address [ vpn-instance vpn-instance-name ]
By default, no translated IP address is specified.
This task enables the device to always use the primary IP address of the specified source interface as the source IP address of outgoing DNS packets. This feature applies to scenarios in which the DNS server responds only to DNS requests sourced from a specific IP address. If no IP address is configured on the source interface, no DNS packets can be sent out.
When sending an IPv6 DNS request, the device follows the method defined in RFC 3484 to select an IPv6 address of the source interface.
You can configure only one source interface on the public network or a VPN. You can configure the source interface for the public network and a maximum of 1024 VPNs.
To specify the source interface for DNS packets:
Step
Remarks
N/A
2.     Specify the source interface for DNS packets.
dns source-interface interface-type interface-number [ vpn-instance vpn-instance-name ]
By default, no source interface for DNS packets is specified.
If you execute the command multiple times, the most recent configuration takes effect.
If you specify the vpn-instance vpn-instance-name option, make sure the source interface is on the specified VPN.
By default, an interface obtains DNS suffix and domain name server information from DHCP. The network attacker might act as the DHCP server to assign wrong DNS suffix and domain name server address to the device. As a result, the device fails to get the resolved IP address or might get the wrong IP address. With the DNS trusted interface specified, the device only uses the DNS suffix and domain name server information obtained through the trusted interface to avoid attack.
To configure the DNS trusted interface:
Step
Remarks
N/A
2.     Specify the DNS trusted interface.
dns trust-interface interface-type interface-number
By default, no DNS trusted interface is specified.
You can configure up to 128 DNS trusted interfaces.
The DSCP value of a packet specifies the priority level of the packet and affects the transmission priority of the packet. A bigger DSCP value represents a higher priority.
To specify the DSCP value for outgoing DNS packets:
Step
Remarks
N/A
2.     Specify the DSCP value for outgoing DNS packets.
·     DSCP value for IPv4 DNS packets:
dns dscp
dscp-value
·     DSCP value for IPv6 DNS packets:
ipv6 dns dscp
dscp-value
By default, the DSCP value for outgoing DNS packets is 0.
The configuration is available on DNS clients and DNS proxy devices.
Display the domain name resolution table.
display dns host [ ip | ipv6 ] [ vpn-instance vpn-instance-name ]
Display IPv4 DNS server information.
display dns server [ dynamic ] [ vpn-instance vpn-instance-name ]
Display IPv6 DNS server information.
display ipv6 dns server [ dynamic ] [ vpn-instance vpn-instance-name ]
Display DNS suffixes.
display dns domain [ dynamic ] [ vpn-instance vpn-instance-name ]
Clear information about the dynamic domain name cache.
reset dns host [ ip | ipv6 ] [ vpn-instance vpn-instance-name ]
By default, Ethernet, VLAN, and aggregate interfaces are shut down. You must use the undo shutdown command to bring them up. The examples assume that all these interfaces are already up.
Network requirements
As shown in Figure 4, the device wants to access the host by using an easy-to-remember domain name rather than an IP address.
Configure static domain name resolution on the device so that the device can use the domain name host.com to access the host whose IP address is 10.1.1.2.
Figure 4 Network diagram
# Configure a mapping between host name host.com and IP address 10.1.1.2.
[Sysname] ip host host.com 10.1.1.2
# Use the ping host.com command to verify that the device can use static domain name resolution to resolve domain name host.com into IP address 10.1.1.2.
[Sysname] ping host.com
Ping host.com (10.1.1.2): 56 data bytes, press CTRL_C to break
56 bytes from 10.1.1.2: icmp_seq=0 ttl=255 time=1.000 ms
56 bytes from 10.1.1.2: icmp_seq=1 ttl=255 time=1.000 ms
56 bytes from 10.1.1.2: icmp_seq=2 ttl=255 time=1.000 ms
56 bytes from 10.1.1.2: icmp_seq=3 ttl=255 time=1.000 ms
56 bytes from 10.1.1.2: icmp_seq=4 ttl=255 time=2.000 ms
--- Ping statistics for host.com ---
round-trip min/avg/max/std-dev = 1.000/1.200/2.000/0.400 ms
As shown in Figure 5, the device wants to do the following:
·     Access the host by using an easy-to-remember domain name rather than an IP address.
·     Ask the DNS server on the network for an IP address by using dynamic domain name resolution.
The IP address of the DNS server is 2.1.1.2/16 and the DNS server has a com domain, which stores the mapping between domain name host and IP address 3.1.1.1/16.
Configure dynamic DNS and the DNS suffix com on the device that acts as a DNS client. The device can then use the domain name host to access the host with the domain name host.com and the IP address 3.1.1.1/16.
Figure 5 Network diagram
Before performing the following configuration, make sure that:
·     The device and the host can reach each other.
·     The IP addresses of the interfaces are configured as shown in Figure 5.
1.     Configure the DNS server:
The configuration might vary by DNS server. The following configuration is performed on a PC running Windows Server 2000.
a.     Select Start > Programs > Administrative Tools > DNS.
The DNS server configuration page appears, as shown in Figure 6.
b.     Right-click Forward Lookup Zones, select New Zone, and then follow the wizard to create a new zone named com.
Figure 6 Creating a zone
c.     On the DNS server configuration page, right-click zone com, and select New Host.
Figure 7 Adding a host
d.     On the page that appears, enter host name host and IP address 3.1.1.1.
e.     Click Add Host.
The mapping between the IP address and host name is created.
Figure 8 Adding a mapping between domain name and IP address
2.     Configure the DNS client:
# Specify the DNS server 2.1.1.2.
[Sysname] dns server 2.1.1.2
# Specify com as the name suffix.
[Sysname] dns domain com
# Use the ping host command on the device to verify that the communication between the device and the host is normal and that the translated destination IP address is 3.1.1.1.
[Sysname] ping host
Ping host.com (3.1.1.1): 56 data bytes, press CTRL_C to break
56 bytes from 3.1.1.1: icmp_seq=0 ttl=255 time=1.000 ms
56 bytes from 3.1.1.1: icmp_seq=1 ttl=255 time=1.000 ms
56 bytes from 3.1.1.1: icmp_seq=2 ttl=255 time=1.000 ms
56 bytes from 3.1.1.1: icmp_seq=3 ttl=255 time=1.000 ms
56 bytes from 3.1.1.1: icmp_seq=4 ttl=255 time=2.000 ms
--- Ping statistics for host ---
When the IP address of the DNS server changes, you must configure the new IPv6 address of the DNS server on each device on the LAN. To simplify network management, you can use DNS proxy.
As shown in Figure 9:
·     Specify Device A as the DNS server of Device B (the DNS client). Device A acts as a DNS proxy. The IPv6 address of the real DNS server is 4.1.1.1.
·     Configure the IP address of the DNS proxy on Device B. DNS requests of Device B are forwarded to the real DNS server through the DNS proxy.
Figure 9 Network diagram
Before performing the following configuration, ,make sure that:
·     Device A, the DNS server, and the host can reach each other.
·     The IPv6 addresses of the interfaces are configured as shown in Figure 9.
The configuration might vary by DNS server. When a PC running Windows Server 2000 acts as the DNS server, see "Dynamic domain name resolution configuration example" for configuration information.
2.     Configure the DNS proxy:
# Specify the DNS server 4.1.1.1.
[DeviceA] dns server 4.1.1.1
# Enable DNS proxy.
[DeviceA] dns proxy enable
3.     Configure the DNS client:
[DeviceB] dns server 2.1.1.2
# Use the ping host.com command on Device B to verify the connection between the device and the host is normal and that the translated destination IP address is 3.1.1.1.
[DeviceB] ping host.com
As shown in Figure 10, the device wants to access the host by using an easy-to-remember domain name rather than an IPv6 address. Configure static domain name resolution on the device so that the device can use the domain name host.com to access the host whose IPv6 address is 1::2.
Figure 10 Network diagram
# Configure a mapping between host name host.com and IPv6 address 1::2.
[Device] ipv6 host host.com 1::2
# Use the ping ipv6 host.com command to verify that the device can use static domain name resolution to resolve domain name host.com into IPv6 address 1::2.
[Sysname] ping ipv6 host.com
Ping6(56 data bytes) 1::1 --> 1::2, press CTRL_C to break
56 bytes from 1::2, icmp_seq=0 hlim=128 time=1.000 ms
56 bytes from 1::2, icmp_seq=1 hlim=128 time=0.000 ms
56 bytes from 1::2, icmp_seq=2 hlim=128 time=1.000 ms
56 bytes from 1::2, icmp_seq=3 hlim=128 time=1.000 ms
56 bytes from 1::2, icmp_seq=4 hlim=128 time=0.000 ms
--- Ping6 statistics for host.com ---
round-trip min/avg/max/std-dev = 0.000/0.600/1.000/0.490 ms
As shown in Figure 11, the device wants to access the host by using an easy-to-remember domain name rather than an IPv6 address. The IPv6 address of the DNS server is 2::2/64. The server has a com domain, which stores the mapping between domain name host and IPv6 address 1::1/64.
Configure dynamic DNS and the DNS suffix com on the device that acts as a DNS client. The device can then use domain name host to access the host with the domain name host.com and the IPv6 address 1::1/64.
Figure 11 Network diagram
·     The IPv6 addresses of the interfaces are configured as shown in Figure 11.
The configuration might vary by DNS server. The following configuration is performed on a PC running Windows Server 2003. Make sure that the DNS server supports IPv6 DNS so that the server can process IPv6 DNS packets and the interfaces of the DNS server can forward IPv6 packets.
The DNS server configuration page appears, as shown in Figure 12.
Figure 12 Creating a zone
1-1
c.     On the DNS server configuration page, right-click zone com, and select Other New Records.
Figure 13 Creating a record
2-2
d.     On the page that appears, select IPv6 Host (AAAA) as the resource record type.
Figure 14 Selecting the resource record type
3
e.     Type host name host and IPv6 address 1::1.
f.     Click OK.
The mapping between the IPv6 address and host name is created.
Figure 15 Adding a mapping between domain name and IPv6 address
4
# Specify the DNS server 2::2.
[Device] ipv6 dns server 2::2
# Configure com as the DNS suffix.
[Device] dns domain com
# Use the ping ipv6 host command on the device to verify that the communication between the device and the host is normal and that the translated destination IP address is 1::1.
[Device] ping ipv6 host
Ping6(56 data bytes) 3::1 --> 1::1, press CTRL_C to break
56 bytes from 1::1, icmp_seq=0 hlim=128 time=1.000 ms
56 bytes from 1::1, icmp_seq=1 hlim=128 time=0.000 ms
56 bytes from 1::1, icmp_seq=2 hlim=128 time=1.000 ms
56 bytes from 1::1, icmp_seq=3 hlim=128 time=1.000 ms
56 bytes from 1::1, icmp_seq=4 hlim=128 time=0.000 ms
--- Ping6 statistics for host ---
When the IP address of the DNS server changes, you must configure the new IP address of the DNS server on each device on the LAN. To simplify network management, you can use DNS proxy.
As shown in Figure 16:
·     Specify Device A as the DNS server of Device B (the DNS client). Device A acts as a DNS proxy. The IP address of the real DNS server is 4000::1.
Figure 16 Network diagram
Before performing the following configuration, make sure that;
·     Device A, the DNS server, and the host are reachable to each other.
·     The IP addresses of the interfaces are configured as shown in Figure 16.
This configuration might vary by DNS server. When a PC running Windows Server 2003 acts as the DNS server, see "Dynamic domain name resolution configuration example" for configuration information.
# Specify the DNS server 4000::1.
[DeviceA] ipv6 dns server 4000::1
# Enable DNS proxy.
# Specify the DNS server 2000::2.
[DeviceB] ipv6 dns server 2000::2
# Use the ping host.com command on Device B to verify that the connection between the device and the host is normal and that the translated destination IP address is 3000::1.
Ping6(56 data bytes) 2000::1 --> 3000::1, press CTRL_C to break
56 bytes from 3000::1, icmp_seq=0 hlim=128 time=1.000 ms
56 bytes from 3000::1, icmp_seq=1 hlim=128 time=0.000 ms
56 bytes from 3000::1, icmp_seq=2 hlim=128 time=1.000 ms
56 bytes from 3000::1, icmp_seq=3 hlim=128 time=1.000 ms
56 bytes from 3000::1, icmp_seq=4 hlim=128 time=0.000 ms
Symptom
After enabling dynamic domain name resolution, the user cannot get the correct IP address.
Solution
1.     Use the display dns host ip command to verify that the specified domain name is in the cache.
2.     If the specified domain name does not exist, check that the DNS client can communicate with the DNS server.
3.     If the specified domain name is in the cache, but the IP address is incorrect, check that the DNS client has the correct IP address of the DNS server.
4.     Verify that the mapping between the domain name and IP address is correct on the DNS server.
Symptom
After enabling dynamic domain name resolution, the user cannot get the correct IPv6 address.
Solution
1.     Use the display dns host ipv6 command to verify that the specified domain name is in the cache.
2.     If the specified domain name does not exist, check that dynamic domain name resolution is enabled, and that the DNS client can communicate with the DNS server.
3.     If the specified domain name is in the cache, but the IPv6 address is incorrect, check that the DNS client has the correct IPv6 address of the DNS server.
4.     Verify that the mapping between the domain name and IPv6 address is correct on the DNS server.
Overview
DNS provides only the static mappings between domain names and IP addresses. When the IP address of a node changes, your access to the node fails.
Dynamic Domain Name System (DDNS) can dynamically update the mappings between domain names and IP addresses for DNS servers to direct you to the latest IP address mapping to a domain name.
DDNS is supported only by IPv4 DNS, and is used to update the mappings between domain names and IPv4 addresses.
DDNS application
As shown in Figure 17, DDNS works on the client-server model.
·     DDNS clientA device that needs to update the mapping between its domain name and its IP address dynamically on the DNS server when its IP address changes. An Internet user typically accesses an application layer server such as an HTTP server or an FTP server by using the server's domain name. When its IP address changes, the application layer server runs as a DDNS client. It sends a request to the DDNS server for updating the mapping between its domain name and its IP address.
·     DDNS serverInforms the DNS server of latest mappings. When receiving the mapping update request from a DDNS client, the DDNS server tells the DNS server to re-map the domain name and the IP address of the DDNS client. Therefore, the Internet users can use the same domain name to access the DDNS client even if the IP address of the DDNS client has changed.
Figure 17 DDNS application
With the DDNS client configured, a device can dynamically update the latest mapping between its domain name and IP address on the DNS server through DDNS servers.
The DDNS update process does not have a unified standard but varies by DDNS server that the DDNS client contacts.
Tasks at a glance
(Required.) Configuring a DDNS policy
(Required.) Applying the DDNS policy to an interface
(Optional.) Setting the DSCP value for outgoing DDNS packets
A DDNS policy contains the DDNS server address, port number, login ID, password, time interval, associated SSL client policy, and update time interval. After creating a DDNS policy, you can apply it to multiple interfaces to simplify DDNS configuration.
The URL addresses configured for update requests vary by DDNS server.
Table 1 Common URL addresses
DDNS server
URL addresses for DDNS update requests
www.3322.org
http://members.3322.org/dyndns/update?system=dyndns&hostname=<h>&myip=<a>
DYNDNS
http://members.dyndns.org/nic/update?system=dyndns&hostname=<h>&myip=<a>
DYNS
http://www.dyns.cx/postscript.php?host=<h>&ip=<a>
ZONEEDIT
http://dynamic.zoneedit.com/auth/dynamic.html?host=<h>&dnsto=<a>
TZO
http://cgi.tzo.com/webclient/signedon.html?TZOName=<h>IPAddress=<a>
EASYDNS
http://members.easydns.com/dyn/ez-ipupdate.php?action=edit&myip=<a>&host_id=<h>
HEIPV6TB
http://dyn.dns.he.net/nic/update?hostname=<h>&myip=<a>
CHANGE-IP
http://nic.changeip.com/nic/update?hostname=<h>&offline=1
NO-IP
http://dynupdate.no-ip.com/nic/update?hostname=<h>&myip=<a>
DHS
http://members.dhs.org/nic/hosts?domain=dyn.dhs.org&hostname=<h>&hostscmd=edit&hostscmdstage=2&type=1&ip=<a>
HP
https://server-name/nic/update?group=group-name&myip=<a>
ODS
ods://update.ods.org
GNUDIP
gnudip://server-name
PeanutHull
oray://phservice2.oray.net
The URL address does not include a username or password. To configure the username and password, use the username command and the password command.
HP and GNUDIP are common DDNS update protocols. The server-name parameter is the domain name or IP address of the service provider's server using one of the update protocols.
The URL address for an update request can start with:
·     http://The HTTP-based DDNS server.
·     https://The HTTPS-based DDNS server.
·     ods://The TCP-based ODS server.
·     gnudip://The TCP-based GNUDIP server.
·     oray://The TCP-based DDNS server.
The domain names of DDNS servers are members.3322.org and phservice2.oray.net. The domain names of PeanutHull DDNS servers can be phservice2.oray.net, phddns60.oray.net, client.oray.net, ph031.oray.net, and so on. Determine the domain name in the URL according to the actual situation.
The port number in the URL address is optional. If no port is specified, the system uses the default port numbers: port 80 for HTTP, port 443 for HTTPS, and port 6060 for PeanutHull DDNS server.
The system automatically does the following:
·     Fills <h> with the FQDN upon a DDNS policy application to the interface.
·     Fills <a> with the primary IP address of the interface to which the DDNS policy is applied.
You can also manually specify an FQDN and an IP address in <h> and <a>. In this case, the FQDN specified upon the DDNS policy application does not take effect. You are not encouraged to manually change the <h> and <a> because your configuration might be incorrect. For more information about applying DDNS policies, see "Applying the DDNS policy to an interface."
No FQDN or IP address can be specified in the URL address for update requests sent to the PeanutHull DDNS server. You can specify the FQDN when applying the DDNS policy to an interface. The IP address is the primary IP address of the interface to which the DDNS policy is applied.
TIP:
The FQDN is the only identifier of a node on the network. An FQDN consists of a local host name and a parent domain name, and can be translated into an IP address.
Visit the website of a DDNS service provider, register an account, and apply for a domain name for the DDNS client. When the DDNS client updates the mapping between the domain name and the IP address through the DDNS server, the DDNS server checks the following:
·     Whether the account information is correct.
·     Whether the domain name to be updated belongs to the account.
To configure a DDNS policy:
Step
Remarks
N/A
2.     Create a DDNS policy and enter its view.
ddns policy policy-name
By default, no DDNS policy is created.
3.     Specify a URL address for DDNS update requests.
url request-url
By default, no URL address is specified for DDNS update requests.
4.     Specify the username to be included in the URL address.
username username
By default, no username is specified.
5.     Specify the password to be included in the URL address.
password { cipher | simple } password
By default, no password is specified.
6.     (Optional.) Specify the parameter transmission method for sending DDNS update requests to HTTP/HTTPS-based DDNS servers.
method { http-get | http-post }
By default, http-get is used.
Use the method http-post command to specify the POST method for DDNS update with a DHS server.
7.     (Optional.) Associate an SSL client policy with the DDNS policy.
ssl-client-policy policy-name
By default, no SSL client policy is associated with the DDNS policy.
This step is only effective and a must for HTTP-based DDNS update requests. For SSL client policy configuration, see Security Configuration Guide.
8.     (Optional.) Specify the interval for sending update requests.
interval days [ hours [ minutes ] ]
By default, the time interval is one hour.
After you apply the DDNS policy to an interface and specify the FQDN for update, the DDNS client sends requests to the DDNS server to update the mapping between the domain name and the primary IP address of the interface at the specified interval.
Before you apply a DDNS policy to an interface, complete the following tasks:
·     Specify the primary IP address of the interface and make sure the DDNS server and the interface can reach each other.
·     Configure static or dynamic domain name resolution to translate the domain name of the DDNS server into the IPv4 address. For more information, see "Configuring the IPv4 DNS client."
To apply the DDNS policy to an interface:
Step
Remarks
N/A
2.     Enter interface view.
N/A
3.     Apply the DDNS policy to the interface to update the mapping between the specified FQDN and the primary IP address of the interface, and enable DDNS update.
ddns apply policy policy-name [ fqdn domain-name ]
By default, no DDNS policy is applied to the interface, no FQDN is specified for update, and DDNS update is disabled.
The fqdn domain-name option must be specified for all DDNS servers except the PeanutHull DDNS server.
If no FQDN is specified for the PeanutHull DDNS server, the DDNS server updates all domain names of the DDNS client account. If an FQDN is specified, the DDNS server updates only the mapping between the specified FQDN and the primary IP address.
To specify the DSCP value for outgoing DDNS packets:
Step
Remarks
4.     Enter system view.
N/A
5.     Specify the DSCP value for outgoing DDNS packets.
ddns dscp dscp-value
By default, the DSCP value for outgoing DDNS packets is 0.
Displaying DDNS
Display information about the DDNS policy.
display ddns policy [ policy-name ]
As shown in Figure 18, Switch is a Web server with the domain name whatever.3322.org.
Switch acquires the IP address through DHCP. Through DDNS service provided by www.3322.org, Switch informs the DNS server of the latest mapping between its domain name and IP address. Switch uses the DNS server to translate www.3322.org into the corresponding IP address.
Figure 18 Network diagram
Before configuring DDNS on Switch, perform the following tasks:
·     Register with username steven and password nevets at http://www.3322.org/.
·     Add Switch's host name-to-IP address mapping to the DNS server.
·     Make sure the devices can reach each other.
# Create a DDNS policy named 3322.org, and enter its view.
<Switch> system-view
[Switch] ddns policy 3322.org
# Specify for DDNS update requests the URL address with the login ID steven and plaintext password nevets.
[Switch-ddns-policy-3322.org] url http://members.3322.org/dyndns/update?system=dyndns&hostname=<h>&myip=<a>
[Switch-ddns-policy-3322.org] username steven
[Switch-ddns-policy-3322.org] password simple nevets
# Set the interval for sending DDNS update requests to 15 minutes.
[Switch-ddns-policy-3322.org] interval 0 0 15
[Switch-ddns-policy-3322.org] quit
# Specify the IP address of the DNS server as 1.1.1.1.
[Switch] dns server 1.1.1.1
# Apply DDNS policy 3322.org to VLAN-interface 2 to enable DDNS update and dynamically update the mapping between domain name whatever.3322.org and the primary IP address of VLAN-interface 2.
[Switch-Vlan-interface2] ddns apply policy 3322.org fqdn whatever.3322.org
After the preceding configuration is completed, Switch notifies the DNS server of its new domain name-to-IP address mapping through the DDNS server provided by www.3322.org, whenever the IP address of Switch changes. Therefore, Switch can always provide Web service at whatever.3322.org.
As shown in Figure 19, Switch is a Web server with domain name whatever.gicp.cn.
Switch acquires the IP address through DHCP. Through the PeanutHull server, Switch informs the DNS server of the latest mapping between its domain name and IP address. The IP address of the DNS server is 1.1.1.1. Switch uses the DNS server to translate www.oray.cn into the corresponding IP address.
Figure 19 Network diagram
·     Register with username steven and password nevets at http://www.oray.cn/.
# Create a DDNS policy named oray.cn and enter its view.
[Switch] ddns policy oray.cn
[Switch-ddns-policy-oray.cn] url oray://phservice2.oray.net
# Set the DDNS update request interval to 12 minutes.
[Switch-ddns-policy-oray.cn] interval 0 0 12
[Switch-ddns-policy-oray.cn] quit
# Apply the DDNS policy oray.cn to VLAN-interface 2 to enable DDNS update and to dynamically update the mapping between whatever.gicp.cn and the primary IP address of VLAN-interface 2.
[Switch-Vlan-interface2] ddns apply policy oray.cn fqdn whatever.gicp.cn
After the preceding configuration is completed, Switch notifies the DNS server of its new domain name-to-IP address mapping through the PeanutHull server, whenever the IP address of Switch changes. Therefore, Switch can always provide Web service at whatever.gicp.cn.
