01-Fundamentals Configuration Examples
HomeSupportSwitchesH3C S12500 Switch SeriesConfigure & DeployConfiguration ExamplesH3C S12500 Typical Configuration Example-R7328P02-6W10001-Fundamentals Configuration Examples
03-H3C S12500 ISSU Examples
03-H3C S12500 ISSU Examples 170.21 KB
Introduction
This document provides examples for compatible ISSU and incompatible ISSU.
Before performing an ISSU, use the display version comp-matrix command to view the ISSU method in the Upgrade Way field. Table 1 shows a matrix of ISSU types and ISSU methods.
Table 1 Matrix of ISSU types and ISSU methods
ISSU type
ISSU method displayed in Upgrade Way
Compatible
·     Service Upgrade
·     File Upgrade
·     ISSU Reboot
·     Reboot
Incompatible
Incompatible upgrade
The examples in this document were created and verified in a lab environment, and all the devices were started with the factory default configuration. When you are working on a live network, make sure you understand the potential impact of every command on your network.
This document assumes that you have basic knowledge of ISSU.
General configuration restrictions and guidelines
To ensure a successful ISSU, complete the following tasks before performing an ISSU:
·     Identify availability of ISSU:
¡     Read the software release notes to identify support of the device for ISSU.
¡     To perform sequential upgrade for switching fabrics, make sure the device has a minimum of two switching fabric modules.
¡     To perform an ISSU reboot upgrade, make sure the device does not have interface cards with 512 MB of memory.
·     Verify the device operating status:
¡     Use the display device command to verify that no cards are in Fault state.
¡     Use the display mdc command to verify that all MDCs are in active state.
·     Use the dir command to verify that the MPUs have sufficient storage space for the upgrade images. If the storage space is not sufficient, delete unused files.
·     For service continuity during ISSU, configure the following feature settings:
Feature
Setting requirements
GR/NSR
Enable GR or NSR for protocols including LDP, RSVP, OSPF, ISIS, BGP, and FSPF.
BFD
Disable BFD for protocols including LDP, RSVP, OSPF, ISIS, RIP, BGP, VRRP, and NQA.
Ethernet link aggregation
Use the long LACP timeout interval (the lacp period short command is not configured) on all member ports in dynamic aggregation groups.
IRF
Configure IRF bridge MAC persistence as follows:
·     Compatible upgradeConfigure the irf mac-address persistent timer or irf mac-address persistent always command.
·     Incompatible upgradeConfigure the irf mac-address persistent always command if the bridge MAC address is the MAC address of the device for which you want to execute the issu load command.
·     Log in to the device through the console port.
If you use Telnet or SSH, you might be disconnected from the device before the ISSU is completed.
During an ISSU, follow these restrictions and guidelines:
·     In a multiuser environment, make sure no other administrators access the device while you are performing the ISSU.
·     Do not perform any of the following tasks during an ISSU:
¡     Reboot, add, or remove cards.
¡     Execute commands that are irrelevant to the ISSU.
¡     Modify, delete, or rename image files.
Example: Performing a compatible ISSU (in standalone mode)
Network requirements
As shown inFigure 1, the device and the TFTP server can reach each other. The device has two MPUs: active MPU in slot 0 and standby MPU in slot 1.
Perform a compatible ISSU on the device to upgrade the HTTP feature from r0201 to r0202.
Figure 1 Network diagram
Software version used
This configuration example was created and verified on S12500-CMW710-R7328P02.
When you perform a compatible ISSU, follow these restrictions and guidelines:
·     You only need to download images to the active MPU. The system prompts whether to copy the images to the standby MPU during the upgrade.
·     To ensure service continuity, upgrade the standby MPU prior to the active MPU.
Configuration procedures
# Download the new image file http-r0202.bin from the TFTP server.
<Device> tftp 2.2.2.2 get http-r0202.bin
  % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                 Dload  Upload   Total   Spent    Left  Speed
100  256k  100  256k    0     0   764k      0 --:--:-- --:--:-- --:--:--  810k
# Display active software images.
<Device> display install active
Active packages on slot0:
  flash:/boot-r2111.bin
  flash:/system-r2111.bin
  flash:/http-r0201.bin
Active packages on slot 1:
Active packages on slot 2:
Active packages on slot 3:
# Display version compatibility information and identify the ISSU method.
<Device> display version comp-matrix file feature flash:/http-r0202.bin
Feature image: flash:/http-r0202.bin
  Version:
  7.1.045-r0202
  Version Compatibility List:
  7.1.045-r0201
  7.1.045-r0202
  Version Dependency System List:
  7.1.045-r0201
  7.1.045-r0202
  Slot                        Upgrade Way
  0                           File Upgrade
  0.1                         File Upgrade
  1                           File Upgrade
  1.1                         File Upgrade
  2                           File Upgrade
  3                           File Upgrade
Influenced service according to following table on slot 0:
         HTTP
Influenced service according to following table on slot 1:
         HTTP
The output shows that the running version r0201 is in the version compatibility list. A file upgrade is recommended. The HTTP module will be rebooted during the ISSU.
# Set the automatic rollback timer to 120 minutes (the default is 45 minutes).
[Device] issu rollback-timer 120
<Device> quit
# Upgrade the HTTP image for the standby MPU.
<Device> issu load file feature flash:/http-r0202.bin slot 1
This operation will delete the rollback point information and ISSU log information
for the previous upgrade and get unsaved configuration lost. Continue? [Y/N]:y
  Running Version             New Version
  Alpha 0201                  Alpha 0202
  Slot                        Upgrade Way
  1                           File Upgrade
  1.1                        File Upgrade
Upgrading software images to compatible versions. Continue? [Y/N]: y
# Verify that the upgrade operation is completed on the standby MPU (ISSU status is loaded).
<Device> display issu state
ISSU state: loaded
Compatibility: Compatible
Work state: Normal
Upgrade method: Card by card
Upgraded slot: None
Current upgrading slot: None
  slot 1
Previous version list:
Upgrade version list:
# Perform an active/standby switchover.
<Device> issu run switchover
  Slot                        Upgrade Way
  0                           Active standby process switchover
  0.1                         Active standby process switchover
# Upgrade the original active MPU.
<Device> issu commit slot 0
  Slot                        Upgrade Way
  0                           Service Upgrade
  0.1                         File Upgrade
# Verify that the ISSU process is completed (the ISSU status is Init).
ISSU state: Init
Work state: Normal
Upgraded slot: None
Current version list:
Current software images:
# Verify that the HTTP feature has been upgraded to r0202.
Active packages on slot 0:
Configuration files
The system does not save the commands used in the configuration procedures to a configuration file.
Example: Performing an incompatible ISSU (in standalone mode)
As shown in Figure 2, the device and the TFTP server can reach each other. The device has two MPUs: active MPU in slot 0 and standby MPU in slot 1.
Perform an incompatible ISSU on the device to upgrade the HTTP feature from r0201 to r0202.
Figure 2 Network diagram
When you perform the incompatible ISSU, follow these restrictions and guidelines:
  Version:
  7.1.045-r0202
  Version compatibility list:
  7.1.045-r0202
  Version dependency system list:
  7.1.045-r0201
  7.1.045-r0202
Incompatible upgrade.
The output shows that the two versions are incompatible (the running version r0201 is not in the version compatibility list). The upgraded MPU will reboot to use the new image.
This operation will delete the rollback point information and ISSU log information for the previous upgrade and get unsaved configuration lost. Continue? [Y/N]:y
  Slot                        Upgrade Way
  1                           Reboot
  1.1                         Reboot
Upgrading software images to incompatible versions. Continue? [Y/N]: y
ISSU state: loaded
Compatibility: Incompatible
Work state: Normal
Upgraded slot: None
  slot 1
# Upgrade the HTTP image for the active MPU.
  Slot                        Upgrade Way
  0                           Reboot
  0.1                         Reboot
ISSU state: Init
Work state: Normal
Upgraded slot: None
Configuration files
Example: Performing a compatible ISSU (in IRF mode)
As shown in Figure 3, the two-chassis IRF fabric and the TFTP server can reach each other. Each IRF member has one MPU in slot 0 and one MPU in slot 1. The MPU in slot 0 of the master is the global active MPU.
Perform a compatible ISSU on the IRF to upgrade the boot and system images from R2111 to R2112.
Figure 3 Network diagram
When you perform the compatible ISSU, follow these restrictions and guidelines:
·     You only need to download images to the global active MPU. The system prompts whether to copy the images to the global standby MPUs during the upgrade.
·     To ensure service continuity, upgrade the subordinate member prior to the master. On a dual-MPU single-chassis IRF fabric, upgrade the standby MPU prior to the active MPU.
# Download the new image file test.ipe from the TFTP server to the master. The file includes the boot image file boot-R2112.bin and the system image file system-R2112.bin.
<Master> tftp 2.2.2.2 get test.ipe
# Display current software images.
<Master> display install active
Active packages on chassis 1 slot 0:
  flash:/BOOT-R2111.bin
  flash:/SYSTEM-R2111.bin
Active packages on chassis 1 slot 0.1:
Active packages on chassis 1 slot 1:
Active packages on chassis 1 slot 1.1:
Active packages on chassis 2 slot 0:
Active packages on chassis 2 slot 0.1:
Active packages on chassis 2 slot 1:
Active packages on chassis 2 slot 1.1:
<Master> display version comp-matrix file ipe flash:/test.ipe
Verifying image file.......Done.
Boot image: BOOT-R2112.bin
  Version:
  7.1.045P99
System image: SYSTEM-R2112.bin
  Version:
  7.1.045-R2112
  7.1.045-R2112
  7.1.045-R2111
  Version dependency boot list:
  7.1.045P99
  1         0                 Service Upgrade
  1         0.1               ISSU Reboot
  1         1                 Service Upgrade
  1         1.1               ISSU Reboot
  2         0                 Service Upgrade
  2         0.1               ISSU Reboot
  2         1                 Service Upgrade
  2         1.1               ISSU Reboot
The output shows that the two versions are compatible and the ISSU reboot method is recommended.
# Set the rollback timer to 120 minutes (the default is 45 minutes).
<Master> system-view
[Master] issu rollback-timer 120
<Master> quit
# Upgrade the subordinate member.
<Master> issu load file ipe flash:/test.ipe chassis 2
This operation will delete the rollback point information for the previous upgra
de and maybe get unsaved configuration lost. Continue? [Y/N]:y
flash:/BOOT-R2112.bin already exists on chassis 2
flash:/SYSTEM-R2112.bin already exists on chassis 2
Decompressing file BOOT-R2112.bin to flash:/BOOT-R2112.b
in...........................................Done.
Decompressing file SYSTEM-R2112.bin to flash:/SYSTEM-R211
2.bin...........................................................................
  Release 2111P01             Feature com
  Chassis   Slot              Upgrade Way
  2         0                 Service Upgrade
  2         0.1               ISSU Reboot
  2         1                 Service Upgrade
  2         1.1               ISSU Reboot
# After the subordinate member restarts up, verify that the upgrade operation is completed on the member (ISSU status is Loaded).
<Master> display issu state
ISSU state: Loaded
Work state: Normal
Upgrade method: Chassis by chassis
Upgraded chassis:
  chassis 1
Current upgrading chassis: None
  boot: 7.1.045P22, Release 2111P01
  system: 7.1.045, Release 2111P01
Previous software images:
  boot: 7.1.045P99, Feature com
  system: 7.1.045, Feature com
Upgrade software images:
# Perform a master/subordinate switchover.
<Master> issu run switchover
  Chassis   Slot              Switchover Way
  1         0                 Active standby process switchover
  1         0.1               Active standby process switchover
# Verify that the switchover operation is completed (the ISSU status is Switchover).
ISSU state: Switchover
Work state: Normal
Upgraded chassis:
  chassis 1
# Upgrade the original master.
<Master> issu commit chassis 1
flash:/BOOT-R2112.bin already exists on chassis 1
flash:/SYSTEM-R2112.bin already exists on chassis 1
Decompressing file SYSTEM-R2112.bin to flash:/SYSTEM-R2112
  1         0                 Service Upgrade
  1         0.1               ISSU Reboot
  1         1                 Service Upgrade
  1         1.1               ISSU Reboot
ISSU state: Init
Work state: Normal
Upgraded chassis: None
# Verify that the boot and system images have been upgraded to R2112.
Configuration files
Example: Performing an incompatible ISSU (in IRF mode)
As shown in Figure 4, the two-chassis IRF fabric and the TFTP server can reach each other. Each IRF member has one MPU in slot 0 and one MPU in slot 1. The MPU in slot 0 of the master is the global active MPU.
Perform an incompatible ISSU on the IRF to upgrade the boot and system images from R2111 to R2112.
Figure 4 Network diagram
<Device> tftp 2.2.2.2 get test.ipe
<Master> display boot-loader
Verifying image file........Done.
  Version:
  7.1.045P99
  Version:
  7.1.045-R2112
  7.1.045-R2112
  7.1.045P99
The output shows that the two versions are incompatible and a reboot is required during the ISSU.
flash:/BOOT-com.bin already exists on chassis 2
flash:/SYSTEM-com.bin already exists on chassis 2
  2         0                 Reboot
  2         0.1               Reboot
  2         1                 Reboot
  2         1.1               Reboot
ISSU state: Loaded
Work state: Normal
Upgraded chassis:
  chassis 1
# Perform a master/subordinate switchover to complete the ISSU process.
  1         1                 Active standby process switchover
  1         1.1               Active standby process switchover
ISSU state: Init
Work state: Normal
 Configuration files
Related documentation
·     H3C S12500 Routing Switch Series Fundamentals Command References Release 7328
·     H3C S12500 Routing Switch Series Fundamentals Configuration Guides Release 7328
