13-Network Management and Monitoring Command Reference
HomeSupportSwitchesH3C S12500 Switch SeriesReference GuidesCommand ReferencesH3C S12500 Command References-Release1828P04-6W18213-Network Management and Monitoring Command Reference
08-Sampler Commands
08-Sampler Commands 58.68 KB
Sampler configuration commands
display sampler
Standalone mode:
display sampler [ sampler-name ] [ slot slot-number ] [ | { begin | exclude | include } regular-expression ]
IRF mode:
display sampler [ sampler-name ] [ chassis chassis-number slot slot-number ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
sampler-name: Specifies the sampler name, a case-insensitive string of 1 to 32 characters.
slot slot-number: Displays sampler information of the specified card. The slot-number argument specifies a card by its slot number. Use this option when your switch is operating in standalone (the default) mode.
chassis chassis-number slot slot-number: Specifies a card on an IRF member switch. The chassis-number argument represents the ID of the IRF member switch, and the slot-number argument represents the number of the slot that holds the card. You can display the member ID and slot number with the display device command. Use this option when your switch is operating in IRF mode. For more information about IRF, see IRF Configuration Guide.
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
Use display sampler to view configuration and running information about a sampler.
# Display the configuration and running information about the specified sampler.(Standalone mode.)
<Sysname> display sampler abc slot 1
Sampler name: abc
  Index: 1,  Mode: Fixed,  Packet-interval: 8
#  Display the configuration and running information about the specified sampler.(IRF mode.)
<Sysname> display sampler 256 chassis 1 slot 1
Sampler name: 256
Sampler name
Name of the sampler.
Index
Index number identifying a sampler.
Mode
Sampling mode, which can be fixed mode.
Packet-interval
Sampling rate.
sampler
sampler sampler-name mode fixed packet-interval rate
undo sampler sampler-name
View
Default level
2: System level
sampler-name: Assigns the name for the sampler, a case-insensitive string of 1 to 32 characters.
fixed: Specifies the fixed sampling mode, in which the first packet is selected per sampling.
packet-interval rate: Specifies the sampling rate, which equals the 2 to the power of rate. The value range is 1 to 10.
Use sampler to create a sampler. Up to eight samplers can be created on the switch.
Use undo sampler to delete a sampler.
Before deleting a sampler, remove the traffic mirroring or port mirroring that references the target sampler. Otherwise, the deleting of the sampler will fail. For more information about traffic mirroring, see ACL and QoS Configuration Guide. For more information about port mirroring, see Network Management and Monitoring Configuration Guide.
# Create a sampler with the name abc in fixed sampling mode. Set the sampling rate to 8, which means one packet out of 256 packets (2 to the power of 8) is sampled.
[Sysname] sampler abc mode fixed packet-interval 8
