- 13-Network Management and Monitoring Command Reference
- 01-System Maintenance and Debugging Commands
- 02-NQA Commands
- 03-NTP Commands
- 04-IPC Commands
- 05-SNMP Commands
- 06-RMON Commands
- 07-CWMP Commands
- 08-Sampler Commands
- 09-Mirroring Commands
- 10-Protocol Packet Statistics Commands
- 11-sFlow Commands
- 12-Information Center Commands
- 13-Packet Capture Commands
04-IPC Commands | 113.38 KB |
The display commands for the IPC feature display only information about active nodes.
"Local node" refers to the active MPU.
display ipc channel
display ipc channel { node node-id | self-node } [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
node node-id: Displays channel information for a node. The node-id argument takes a node number in the range of 0 to 174.
self-node: Displays channel information for the local node.
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
Use display ipc channel to display channel information for a node.
# Display channel information for node 6.
<Sysname> display ipc channel node 6
ChannelID Description
14 Prehistorical channel, NO.2
15 Prehistorical channel, NO.6
16 Prehistorical channel, NO.7
19 RPC channel
25 Prehistorical channel, NO.4
26 Prehistorical channel, NO.8
27 FIB4
32 Prehistorical channel, NO.3
33 Prehistorical channel, NO.11
34 Prehistorical channel, NO.9
35 IPC test channel
37 Prehistorical channel, NO.12
43 Prehistorical channel, NO.14
45 Prehistorical channel, NO.5
53 Prehistorical channel, NO.13
62 Prehistorical channel, NO.10
ChannelID |
Channel number, which has been predefined and assigned by the system. One channel number corresponds to one module. The display ipc channel command displays the numbers of the current active modules. |
Description, which is generated by the internal software of the switch, is used to describe the functions of a channel. For example, "FIB4" indicates that the channel is used for Layer 3 fast forwarding. "Prehistorical channel, NO.2" indicates that no description is defined for the channel, and the channel is the second channel established. |
display ipc link
display ipc link { node node-id | self-node } [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
node node-id: Displays the link status of the specified node, where the node-id argument represents the number of the specified node. The node-id argument is in the range of 0 to 174.
self-node: Displays the link status of the local node.
Use display ipc link to display the link status of the specified node.
# Display link status of the local node.
<Sysname> display ipc link self-node
Dst-NodeID LinkStatus
1 UP
2 DOWN
The output shows that:
· The connection between the local node and peer node 1 is up.
· The connection between the local node and peer node 2 is down.
Dst-NodeID |
Number of the peer node. |
LinkStatus |
Link status: · UP—The connection has been established. · DOWN—The connection has been terminated. |
display ipc multicast-group
display ipc multicast-group { node node-id | self-node } [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
node node-id: Displays the multicast group status of the specified node, where the node-id argument represents the number of the specified node. The node-id argument is in the range of 0 to 174.
self-node: Displays the multicast group status of the local node.
Use display ipc multicast-group to display multicast group information for the specified node.
# Display multicast group information for node 6.
<Sysname> display ipc multicast-group node 6
GroupID Status ChannelID
8 INUSE 12
GroupID |
Multicast group ID. |
Status |
Link status: · INUSE—The multicast group is in use. · DELETE—The multicast group is to be deleted. |
ChannelID |
Channel number. |
display ipc node
display ipc node [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use display ipc node to display node information.
# Display node information for the switch.
<Sysname> display ipc node
Self node ID: 0
Current active node ID: 0
Self node ID |
Number of the local node. |
Current active node ID |
List of the current active nodes. |
display ipc packet
display ipc packet { node node-id | self-node } [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
node node-id: Displays the packet statistics of the specified node, where the node-id argument represents the number of the specified node. The node-id argument is in the range of 0 to 174.
self-node: Displays the packet statistics of the local node.
Use display ipc packet to display the packet statistics of the specified node.
# Display the packet statistics of the local node.
<Sysname> display ipc packet self-node
ChannelID Sent-fragments Sent-packets Received-fragments Received-packets
11 828 810 819 810
13 0 0 0 0
14 5 3 5 5
15 0 0 0 0
16 0 0 0 0
17 50 50 37 35
19 0 0 0 0
Table 5 Command output
ChannelID |
Channel number. |
Sent-fragments |
Number of fragments sent. |
Sent-packets |
Number of packets sent. Whether a packet is fragmented depends on the interface MTU and the packet size in bytes. If the packet size is larger than the MTU, the packet is fragmented. If the packet size is smaller than or equal to the MTU, the packet is sent. |
Received-fragments |
Number of fragments successfully received. |
Received-packets |
Number of packets successfully received. If fragments are received on an interface, the system reassembles the fragments and sends a complete packet to the upper layer. |
display ipc performance
display ipc performance { node node-id | self-node } [ channel channel-id ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
node node-id: Displays the IPC performance statistics of the specified node, where the node-id argument represents the number of the specified node. The node-id argument is in the range of 0 to 174.
self-node: Displays the IPC performance statistics of the local node.
channel channel-id: Displays the IPC performance statistics of the specified channel, where the channel-id argument represents the channel number. The channel-id argument is in the range of 0 to 179.
Use display ipc performance to display IPC performance statistics.
If IPC performance statistics is enabled, the command displays the current IPC performance statistics. If IPC performance statistics is disabled, the command displays the IPC performance statistics collected before IPC performance statistics was disabled.
Related commands: ipc performance enable.
# Display the IPC performance statistics for node 6.
<Sysname> display ipc performance node 6
Peak: Peak rate (pps)
10Sec: Average rate in the last 10 seconds (pps)
1Min: Average rate in the last 1 minute (pps)
5Min: Average rate in the last 5 minutes (pps)
Total-Data: Total number of data (packets)
Statistics for packets sent successfully:
Peak 10Sec 1Min 5Min Total-Data
1 1 1 0 80
Statistics for packets received successfully:
1 1 1 0 82
Statistics for packets acknowledged:
1 1 1 0 78
Table 6 Command output
Peak |
Peak rate in pps (average rate is measured every 10 seconds, and the greatest average rate is taken as the peak rate). |
10Sec |
Average rate (in pps) for the past 10 seconds. |
1Min |
Average rate (in pps) for the past 1 minute. |
5Min |
Average rate (in pps) for the past 5 minutes. |
Total-Data |
Total amount of data collected from the time when IPC performance statistics was enabled to the time when this command was executed. |
display ipc queue
display ipc queue { node node-id | self-node } [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
node node-id: Displays the sending queue status of the specified node, where the node-id argument represents the number of the specified node. The node-id argument is in the range of 0 to 174.
self-node: Displays the sending queue status of the local node.
Use display ipc queue to display the sending queue status of the specified node.
# Display the sending queue status of the local node.
<Sysname> display ipc queue self-node
QueueType QueueID Dst-NodeID Length FullTimes Packet
UNICAST 0 0 4096 0 0
UNICAST 1 0 4096 0 0
UNICAST 2 0 4096 0 0
UNICAST 3 0 4096 0 0
UNICAST 0 1 4096 0 0
UNICAST 1 1 4096 0 0
UNICAST 2 1 4096 0 0
UNICAST 3 1 4096 0 0
MULTICAST 0 -- 4096 0 0
MULTICAST 1 -- 4096 0 0
MULTICAST 2 -- 512 0 0
MULTICAST 3 -- 512 0 0
MULTICAST 4 -- 512 0 0
MULTICAST 5 -- 512 0 0
MIXCAST 0 -- 2048 0 0
MIXCAST 1 -- 2048 0 0
Table 7 Command output
QueueType |
Queue type: · UNICAST—Unicast queue. · MULTICAST—Multicast (including broadcast) queue. · MIXCAST—Mixcast queue, which can accommodate unicast, multicast, and broadcast traffic. |
QueueID |
Queue number. |
Dst-NodeID |
Peer node number. If no peer node exists, two hyphens (--) are displayed. |
Length |
Queue length (number of packets that can be buffered). |
FullTimes |
Number of times the queue was full. |
Packet |
Total number of packets in the queue. |
ipc performance enable { node node-id | self-node } [ channel channel-id ]
undo ipc performance enable [ node node-id | self-node ] [ channel channel-id ]
View
Default level
1: Monitor level
node node-id: Enables IPC performance statistics for the specified node, where the node-id argument represents the number of the specified node. The node-id argument is in the range of 0 to 174.
self-node: Enables IPC performance statistics for the local node.
channel channel-id: Enables IPC performance statistics for the specified channel, where the channel-id argument represents the channel number. The channel-id argument is in the range of 0 to 179.
Use ipc performance enable to enable IPC performance statistics.
Use undo ipc performance to disable IPC performance statistics.
By default, IPC performance statistics is disabled.
After IPC performance statistics is disabled, the statistics data does not change. The display ipc performance command displays the statistics collected before IPC performance statistics was disabled.
# Enable IPC performance statistics for channel 18 on node 6.
<Sysname> ipc performance enable node 6 channel 18
reset ipc performance
reset ipc performance [ node node-id | self-node ] [ channel channel-id ]
View
Default level
1: Monitor level
node node-id: Clears the IPC performance statistics for the specified node, where the node-id argument represents the number of the specified node. The node-id argument is in the range of 0 to 174.
self-node: Clears the IPC performance statistics of the local node.
channel channel-id: Clears the IPC performance statistics for the specified channel, where channel-id represents the channel number. The channel-id argument is in the range of 0 to 179.
Use reset ipc performance to clear IPC performance statistics.
# Clear the IPC performance statistics for channel 18 on node 6.
<Sysname> reset ipc performance node 6 channel 18
