11-Security Command Reference
HomeSupportSwitchesS12500 SeriesReference GuidesCommand ReferencesH3C S12500 Command References-Release1828P04-6W18211-Security Command Reference
18-Attack Detection and Protection Commands
18-Attack Detection and Protection Commands 37.81 KB
attack-defense tcp fragment enable
Use attack-defense tcp fragment enable to enable TCP fragment attack protection.
Use undo attack-defense tcp fragment enable to disable TCP fragment attack protection.
TCP fragment attack protection is enabled.
Default command level
2: System level
This command enables the device to drop attack TCP fragments to prevent TCP fragment attacks.
# Enable TCP fragment attack protection.
<Sysname> System-view
[Sysname] attack-defense tcp fragment enable
