11-Security Command Reference
HomeSupportSwitchesS12500 SeriesReference GuidesCommand ReferencesH3C S12500 Command References-Release1828P04-6W18211-Security Command Reference
14-URPF Commands
14-URPF Commands 46.77 KB
ip urpf strict
ip urpf strict [ link-check ]
undo ip urpf
View
Interface view
Default level
2: System level
link-check: Enables the link layer check.
Use ip urpf strict to enable strict URPF check on the interface.
Use undo ip urpf strict to restore the default.
By default, strict URPF check is disabled.
To pass strict URPF check, the source address and receiving interface of a packet must match the destination address and output interface of a FIB entry.
Strict URPF check can be configured only on the VLAN interfaces.
# Enable strict URPF check on VLAN-interface 2.
[Sysname-Vlan-interface2] ip urpf strict
