10-ACL and QoS Configuration Guide
HomeSupportSwitchesS12500 SeriesConfigure & DeployConfiguration GuidesH3C S12500 Configuration Guides-Release1828P04-6W18210-ACL and QoS Configuration Guide
02-QoS Configuration
02-QoS Configuration 719.97 KB
QoS overview·· 1
Introduction to QoS· 1
QoS service models 1
Best-effort service model 1
IntServ model 1
DiffServ model 1
QoS techniques overview·· 2
Deploying QoS in a network· 2
QoS processing flow in a device· 2
QoS configuration approaches 4
QoS configuration approach overview·· 4
MQC approach· 4
Non-MQC approach· 4
Configuring a QoS policy· 4
Defining a class 5
Defining a traffic behavior 5
Defining a policy· 6
Applying the QoS policy· 6
Displaying and maintaining QoS policies 9
Configuring priority mapping· 11
Overview·· 11
Introduction to priority mapping· 11
Introduction to priorities 11
Priority mapping tables 11
Priority mapping configuration tasks 12
Configuring priority mapping· 12
Configuring a priority mapping table· 12
Configuring a port to trust packet priority for priority mapping· 14
Changing the port priority of an interface· 15
Configuring primap· 15
Displaying and maintaining priority mapping· 17
Priority mapping configuration example· 17
Network requirements 17
Configuration procedure· 18
Configuring traffic policing and traffic shaping· 19
Overview·· 19
Traffic evaluation and token buckets 19
Traffic policing· 20
Traffic shaping· 21
Configuring traffic policing· 22
Configuring GTS· 22
Displaying and maintaining traffic policing and GTS· 23
Configuring hardware congestion management 24
Overview·· 24
Causes, impacts, and countermeasures 24
Congestion management techniques 24
Hardware congestion management configuration approaches 27
Configuring per-queue hardware congestion management 28
Configuring SP queuing· 28
Configuring WFQ queuing· 28
Configuring hardware congestion management with queue scheduling profiles 30
Introduction to queue scheduling profile· 30
Configuring a queue scheduling profile· 30
Displaying and maintaining queue scheduling profiles 31
Queue scheduling profile configuration example· 31
Configuring congestion avoidance· 33
Overview·· 33
Configuring WRED on an interface· 33
Configuration procedure· 33
Configuration example· 34
Displaying and maintaining WRED·· 34
Configuring traffic filtering· 35
Configuration procedure· 35
Traffic filtering configuration restrictions 36
Traffic filtering configuration example· 36
Network requirements 36
Configuration procedure· 37
Configuring protocol packet rate limiting· 38
Overview·· 38
Configuration procedure· 38
Protocol packet rate limiting configuration example· 39
Network requirements 39
Configuration procedures 39
Configuring priority marking· 41
Overview·· 41
Configuration procedure· 41
Priority marking configuration example· 42
Network requirements 42
Configuration procedure· 42
Configuring traffic redirecting· 45
Overview·· 45
Configuration restrictions and guidelines 45
Configuration procedure· 46
Traffic redirecting configuration example· 46
Network requirements 46
Configuration procedure· 47
Configuring global CAR· 49
Overview·· 49
Configuring aggregate CAR· 49
Configuration procedure· 49
Configuration example· 49
Configuring class-based accounting· 51
Overview·· 51
Configuration procedure· 51
Displaying and maintaining class-based accounting· 51
Class-based accounting configuration example· 52
Network requirements 52
Configuration procedure· 52
Configuring traffic accounting· 54
Overview·· 54
Configuration procedure· 54
Displaying and maintaining traffic accounting· 54
Configuring enhanced QoS· 1
Configuring the QoS pipe mode· 2
Overview·· 2
Configuration procedure· 2
Appendix· 3
Appendix A Acronym·· 3
Appendix B Default priority mapping tables 4
Introduction to priority mapping tables 4
Introduction to colored priority mapping tables 6
Appendix C Introduction to packet precedences 9
IP precedence and DSCP values 9
802.1p priority· 10
EXP values 11
Introduction to QoS
In data communications, Quality of Service (QoS) is the ability of a network to provide differentiated service guarantees for diversified traffic in terms of bandwidth, delay, jitter, and drop rate.
Network resources are scarce. The contention for resources requires that QoS prioritize important traffic flows over trivial ones. For example, when bandwidth is fixed, more bandwidth for one traffic flow means less bandwidth for the other traffic flows. When making a QoS scheme, you must consider the characteristics of various applications to balance the interests of diversified users and to utilize network resources.
The following section describes some typical QoS service models and widely used, mature QoS techniques.
QoS service models
Best effort is a single-service model and also the simplest service model. In the best-effort service model, the network does its best to deliver packets, but does not guarantee delay or reliability.
The best-effort service model is the default model in the Internet and applies to most network applications. It uses the first in first out (FIFO) queuing mechanism.
IntServ model
The integrated service (IntServ) model is a multiple-service model that can accommodate diverse QoS requirements. It provides the most granularly differentiated QoS by identifying and guaranteeing definite QoS for each data flow.
In the IntServ model, an application must request service from the network before it sends data. IntServ signals the service request with the Resource Reservation Protocol (RSVP). All nodes receiving the request reserve resources as requested and maintain state information for the application flow.
The IntServ model demands high storage and processing capabilities because it requires all nodes along the transmission path to maintain resource state information for each flow. The model is suitable for small-sized or edge networks, but not large-sized networks, for example, the core layer of the Internet, where billions of flows are present. For more information about RSVP, see MPLS Configuration Guide.
DiffServ model
The differentiated service (DiffServ) model is a multiple-service model that can meet diverse QoS requirements. It is easy to implement and extend. DiffServ does not signal the network to reserve resources before sending data, as IntServ does.
All QoS techniques in this document are based on the DiffServ model.
The QoS techniques include traffic classification, traffic policing, traffic shaping, line rate, congestion management, and congestion avoidance. The following sections briefly introduce these QoS techniques.
Figure 1 Position of the QoS techniques in a network
As shown in Figure 1, traffic classification, traffic shaping, traffic policing, congestion management, and congestion avoidance mainly implement the following functions:
·     Traffic classification uses certain match criteria to assign packets with the same characteristics to a class. Based on classes, you can provide differentiated services.
·     Traffic policing polices flows entering or leaving a device, and imposes penalties on traffic flows that exceed the pre-set threshold to prevent aggressive use of network resources. You can apply traffic policing to both incoming and outgoing traffic of a port.
·     Traffic shaping proactively adapts the output rate of traffic to the network resources available on the downstream device to eliminate packet drops. Traffic shaping usually applies to the outgoing traffic of a port.
·     Congestion management provides a resource scheduling policy to determine the packet forwarding sequence when congestion occurs. Congestion management usually applies to the outgoing traffic of a port.
·     Congestion avoidance monitors the network resource usage, and is usually applied to the outgoing traffic of a port. When congestion worsens, congestion avoidance reduces the queue length by dropping packets.
Figure 2 briefly describes how the QoS module processes traffic:
1.     Traffic classifier identifies and classifies traffic for subsequent QoS actions.
2.     The QoS module takes various QoS actions on classified traffic as configured, depending on the traffic processing phase and network status. For example, you can configure the QoS module to perform traffic policing for incoming traffic, traffic shaping for outgoing traffic, congestion avoidance before congestion occurs, and congestion management when congestion occurs.
Figure 2 QoS processing flow
You can configure QoS in these approaches:
·     MQC approach
·     Non-MQC approach
Some features support both approaches, but some support only one.
MQC approach
In the modular QoS configuration (MQC) approach, you configure QoS service parameters by using QoS policies. A QoS policy defines the shaping, policing, or other QoS actions to take on different classes of traffic. It is a set of class-behavior associations.
A class is a set of match criteria for identifying traffic, and it uses the AND or OR operator:
·     If the operator is AND, a packet must match all the criteria to match the class.
·     If the operator is OR, a packet matches the class if it matches any of the criteria in the class.
A traffic behavior defines a set of QoS actions to take on packets, such as priority marking and redirect.
By associating a traffic behavior with a class in a QoS policy, you apply the specific set of QoS actions to the class of traffic.
Non-MQC approach
In the non-MQC approach, you configure QoS service parameters without using a QoS policy. For example, you can use the line rate feature to set a rate limit on an interface without using a QoS policy.
Figure 3 shows how to configure a QoS policy.
Figure 3 QoS policy configuration procedure
Defining a class
Step
Remarks
N/A
2.     Create a class and enter class view.
traffic classifier tcl-name [ operator { and | or } ]
By default, the operator of a class is AND.
The operator of a class can be AND or OR.
·     ANDA packet is assigned to a class only when the packet matches all the criteria in the class. Using AND as the operator in a class, you must make sure no conflict exists between the if-match clauses or the parameters in each if-match clause, and you can configure only one ACL for the class.
·     ORA packet is assigned to a class if it matches any of the criteria in the class.
3.     Configure match criteria.
if-match match-criteria
For more information, see the if-match command in ACL and QoS Command Reference.
A traffic behavior is a set of QoS actions (such as traffic filtering, shaping, policing, and priority marking) to take on a class of traffic.
To define a traffic behavior:
Step
Remarks
N/A
2.     Create a traffic behavior and enter traffic behavior view.
N/A
3.     Configure actions in the traffic behavior.
See the subsequent chapters, depending on the purpose of the traffic behavior: traffic policing, traffic filtering, traffic redirecting, priority marking, traffic accounting, and so on.
Defining a policy
You associate a behavior with a class in a QoS policy to perform the actions defined in the behavior for the class of packets.
To associate a class with a behavior in a policy:
Step
Remarks
N/A
2.     Create a policy and enter policy view.
qos policy policy-name
N/A
3.     Associate a class with a behavior in the policy.
classifier tcl-name behavior behavior-name
Repeat this step to create more class-behavior associations.
IMPORTANT
IMPORTANT:
When an ACL is referenced by a QoS policy for traffic classification, the deny action in an ACL rule means not to execute the behavior of the corresponding class-behavior association, and the permit action in an ACL rule means to execute the behavior of the corresponding class-behavior association.
You can apply a QoS policy to the following destinations:
·     An interface—The policy takes effect on the traffic sent or received on the interface.
·     A VLAN—The policy takes effect on the traffic sent or received on all ports in the VLAN.
·     Globally—The policy takes effect on the traffic sent or received on all ports.
·     Control plane—The policy takes effect on the traffic sent on the control plane.
·     You can apply a QoS policy to the control plane of only an Ethernet interface card.
·     You can modify classes, behaviors, and class-behavior associations in a QoS policy even after it is applied. If a class references an ACL for traffic classification, you can delete or modify the ACL (such as add rules to, delete rules from, and modify rules of the ACL).
·     Global QoS policies, interface QoS policies, and VLAN QoS policies are in the descending order of priority when being used to match packets.
·     Global QoS policies and VLAN QoS policies will be applied to all interface cards. If the hardware resources of an interface card are insufficient, applying a global or VLAN-based QoS policy will fail on the interface card. In this case, the system does not automatically roll back the QoS policy configuration already applied to the main processing unit or other interface cards. To ensure consistency, you must manually remove the QoS policy configuration applied to them. Do the same procedure if a global or VLAN-based QoS policy fails to update on an interface card after being dynamically modified.
Applying the QoS policy to an interface
A policy can be applied to multiple interfaces, but only one policy can be applied in one direction (inbound or outbound) of an interface.
When you apply a QoS policy to an interface, follow these guidelines:
·     You can apply QoS policies to all physical interfaces but X.25- or LAPB-enabled interfaces.
·     The QoS policy applied to the outgoing traffic on an interface does not regulate local packets, which are critical protocol packets sent by the local system for operation maintenance. The most common local packets include link maintenance, routing (IS-IS, BGP, and OSPF for example), RIP, LDP, RSVP, and SSH packets.
To apply the QoS policy to an interface:
Step
Remarks
N/A
2.     Enter interface view or port group view.
·     Enter interface view:
·     Enter port group view:
port-group manual port-group-name
Use either command.
Settings in interface view take effect on the current interface. Settings in port group view take effect on all ports in the port group.
3.     Apply the policy to the interface or port group.
N/A
Applying the QoS policy to a VLAN
You can apply a QoS policy to a VLAN to regulate traffic of the VLAN.
To apply the QoS policy to a VLAN:
Step
2.     Apply the QoS policy to VLANs.
·     QoS policies cannot be applied to dynamic VLANs, for example, VLANs created by GVRP.
·     VLAN QoS policies are applied globally to all interface cards. If the hardware resources of an interface card are insufficient, applying a QoS policy to VLANs will fail on the interface card. The system does not automatically roll back the QoS policy configuration already applied to the main processing unit or other interface cards. To ensure consistency, use the undo qos vlan-policy vlan command to manually remove the QoS policy configuration applied to them.
Applying the QoS policy globally
You can apply a QoS policy globally to the inbound or outbound direction of all ports.
To apply the QoS policy globally:
Step
2.     Apply the QoS policy globally.
If the hardware resources of an interface card are insufficient, applying a QoS policy globally will fail on the interface card. The system does not automatically roll back the QoS policy configuration already applied to the main processing unit or other interface cards. To ensure consistency, you must use the undo qos apply policy global command to manually remove the QoS policy configuration applied to them.
Applying the QoS policy to the control plane
When you apply the QoS policy to the control plane, follow these restrictions and guidelines:
·     By default, the switch is configured with pre-defined control plane policies, which take effect on the control planes by default. A pre-defined control plane QoS policy uses the system-index to identify the type of packets sent to the control plane. You can reference system-indexes in if-match commands in class view for traffic classification and then re-configure traffic behaviors for these classes as required. You can use the display qos policy control-plane pre-defined command to display them.
·     When you apply a QoS policy to the control plane of the slot where the IRF port resides, if a class in the QoS policy uses an Ethernet frame header ACL configured with rule permit to match all packets, do not configure car cir or filter deny in the behavior associated with the class. Otherwise, the IRF might split, and the switch cannot work correctly.
The packets entering a device can be processed by the data plane or the control plane.
·     The units at the data plane are responsible for receiving, transmitting, and switching (forwarding) packets, such as various dedicated forwarding chips. They deliver super processing speeds and throughput.
·     The units at the control plane are processing units running most routing and switching protocols and responsible for protocol packet resolution and calculation, such as CPUs. Compared with data plane units, they allow for great packet processing flexibility but have lower throughput.
When the data plane receives packets that it cannot recognize or process, it transmits them to the control plane. If the transmission rate exceeds the processing capability of the control plane, which very likely occurs at times of DoS attacks, the control plane will be busy handling undesired packets and fail to handle packets correctly or timely. As a result, protocol performance is affected.
To address this problem, apply a QoS policy to the control plane to take QoS actions such as traffic filtering or rate limiting on inbound traffic, ensuring that the control plane can receive, transmit, and process packets properly.
To apply the QoS policy to the control plane:
Step
2.     Enter control plane view.
·     In standalone mode:
·     In IRF mode:
control-plane chassis chassis-number slot slot-number
3.     Apply the QoS policy to the control plane.
Remarks
Display traffic class configuration.
display traffic classifier user-defined [ tcl-name ] [ | { begin | exclude | include } regular-expression ]
Available in any view.
Display traffic behavior configuration.
display traffic behavior user-defined [ behavior-name ] [ | { begin | exclude | include } regular-expression ]
Display user-defined QoS policy configuration.
display qos policy user-defined [ policy-name [ classifier tcl-name ] ] [ | { begin | exclude | include } regular-expression ]
Display QoS policy configuration on the specified or all interfaces.
display qos policy interface [ interface-type interface-number ] [ inbound | outbound ] [ | { begin | exclude | include } regular-expression ]
Display VLAN QoS policy configuration (in standalone mode).
display qos vlan-policy { name policy-name | vlan vlan-id } [ slot slot-number ] [ inbound | outbound ] [ | { begin | exclude | include } regular-expression ]
Display VLAN QoS policy configuration (in IRF mode).
display qos vlan-policy { name policy-name | vlan [ vlan-id ] } [ chassis chassis-number slot slot-number ] [ inbound | outbound ] [ | { begin | exclude | include } regular-expression ]
Display information about QoS policies applied globally (in standalone mode).
display qos policy global [ slot slot-number ] [ inbound | outbound ] [ | { begin | exclude | include } regular-expression ]
Display information about QoS policies applied globally (in IRF mode).
display qos policy global [ chassis chassis-number slot slot-number ] [ inbound | outbound ] [ | { begin | exclude | include } regular-expression ]
Display information about QoS policies applied to a control plane on (in standalone mode).
display qos policy control-plane slot slot-number  [ inbound ] [ | { begin | exclude | include } regular-expression ]
Display information about pre-defined QoS policies applied to the control plane (in IRF mode).
display qos policy control-plane chassis chassis-number slot slot-number [ inbound ] [ | { begin | exclude | include } regular-expression ]
Display information about pre-defined QoS policies applied to a control plane (in standalone mode).
display qos policy control-plane pre-defined slot slot-number [ | { begin | exclude | include } regular-expression ]
Display information about pre-defined QoS policies applied to a control plane (in IRF mode).
display qos policy control-plane pre-defined chassis chassis-number slot slot-number [ | { begin | exclude | include } regular-expression ]
Clear VLAN QoS policy statistics.
Available in user view.
Clear the statistics for a QoS policy applied globally.
Clear the statistics for the QoS policy applied to a control plane (in standalone mode).
reset qos policy control-plane slot slot-number  [ inbound ]
Clear the statistics for the QoS policy applied to a control plane (in IRF mode).
reset qos policy control-plane chassis chassis-number slot slot-number [ inbound ]
To clear statistics for an interface, use the reset counters interface command. For more information about the reset counters interface command, see Interface Command Reference.
Overview
When a packet arrives, a device assigns a set of QoS priority parameters to the packet based on a certain priority field carried in the packet or the port priority of the incoming port, depending on your configuration. This process is called "priority mapping". During this process, the device can modify the priority of the packet depending on device status. The set of QoS priority parameters decides the scheduling priority and forwarding priority of the packet.
Priority mapping is implemented with priority mapping tables and involves priorities such as 802.11e priority, 802.1p priority, DSCP, EXP, IP precedence, local precedence, and drop precedence.
Priorities include the following types: priorities carried in packets, and priorities locally assigned for scheduling only.
The packet carried priorities include 802.1p priority, DSCP precedence, IP precedence, EXP, and so on. These priorities have global significance and affect the forwarding priority of packets across the network. For more information about these priorities, see "Appendix."
The locally assigned priorities have only local significance. They are assigned by the device for scheduling only. These priorities include the local precedence, drop precedence, and user precedence, as follows.
·     Local precedence is used for queuing. A local precedence value corresponds to an output queue. A packet with higher local precedence is assigned to a higher priority output queue to be preferentially scheduled.
·     Drop precedence is used for making packet drop decisions. Packets with the highest drop precedence are dropped preferentially.
·     User precedence is the precedence that the device automatically extracts from a certain priority field of the packet according to its forwarding path. The user precedence represents the 802.1p precedence for Layer-2 packets, the IP precedence for Layer-3 packets, and the EXP precedence for MPLS packets.
The device provides various types of priority mapping tables, or rather, priority mappings. By looking up a priority mapping table, the device decides which priority value is to assign to a packet for subsequent packet processing.
The default priority mapping tables (as shown in Appendix B Default priority mapping tables) are available for priority mapping. They are adequate in most cases. If a default priority mapping table cannot meet your requirements, you can modify the priority mapping table as required.
You can configure priority mapping in any of the following approaches:
·     Configuring priority trust mode.
In this approach, you can configure a port to look up a certain priority, 802.1p for example, in incoming packets, in the priority mapping tables. If no packet priority is trusted, the port priority of the incoming port is used.
·     Changing port priority.
By default, all ports are assigned the port priority of zero. By changing the port priority of a port, you change the priority of the incoming packets on the port.
·     Configuring a QoS policy containing the priority mapping (simply called "primap") action with the primap command.
Perform these tasks to configure priority mapping:
Remarks
Optional.
Optional.
Optional.
Configuring primap
Optional.
Configuring an uncolored priority mapping table
The device provides the following types of uncolored priority mapping table.
·     dot1p-dot1p—802.1p-to-802.1p mapping table.
·     dot1p-dp—802.1p-to-drop mapping table.
·     dot1p-dscp—802.1p-to-DSCP mapping table.
·     dot1p-exp—802.1p-to-EXP mapping table.
·     dot1p-lp—802.1p-to-local mapping table.
·     dscp-dot1p—DSCP-to-802.1p mapping table, which applies to only IP packets.
·     dscp-dp—DSCP-to-drop mapping table, which applies to only IP packets.
·     dscp-dscp—DSCP-to-DSCP mapping table, which applies to only IP packets.
·     dscp-exp—DSCP-to-EXP mapping table.
·     dscp-lp—DSCP-to-local mapping table, which applies to only IP packets.
·     exp-dot1p—EXP-to-802.1p mapping table.
·     exp-dp—EXP-to-drop mapping table.
·     exp-dscp—EXP-to-DSCP mapping table.
·     exp-lp—EXP-to-local mapping table.
·     up-dp—User-to-drop mapping table.
·     up-fc—User-to-forwarding-class mapping table.
·     up-lp—User-to-local mapping table.
·     up-rpr—User-to-RPR mapping table.
·     up-up—User-to-user mapping table.
To configure an uncolored priority mapping table:
Step
Remarks
N/A
2.     Enter priority mapping table view.
qos map-table { { inbound { dot1p-dot1p | dot1p-dp | dot1p-dscp | dot1p-exp | dot1p-lp | dscp-dot1p | dscp-dp | dscp-dscp | dscp-exp | dscp-lp | exp-dot1p | exp-dp | exp-dscp | exp-lp | up-lp | up-up } } | { outbound { up-lp | up-dp | up-fc | up-rpr } } }
N/A
3.     Configure the priority mapping table.
Newly configured mappings overwrite the old ones.
Configuring a colored priority mapping table
Packets processed by CAR are colored green, yellow, or red. To perform priority mapping for packets in different colors, the device provides the following colored priority mapping tables.
·     dscp-dot1p—DSCP-to-802.1p mapping table.
·     dscp-dp—DSCP-to-drop priority mapping table.
·     dscp-dscp—DSCP-to-DSCP mapping table.
·     dscp-lp—DSCP-to-local mapping table.
·     exp-exp—EXP-to-EXP mapping table.
·     up-dscp—User-to-DSCP mapping table.
To configure a colored priority mapping table:
Step
Remarks
N/A
2.     Enter colored priority mapping table view.
qos map-table color { green | yellow | red } { inbound { dot1p-dot1p | dot1p-dp | dot1p-dscp | dot1p-exp | dot1p-lp | dscp-dot1p | dscp-dp | dscp-dscp | dscp-exp | dscp-lp | exp-dot1p | exp-dp | exp-dscp | exp-exp | exp-lp } | outbound  { dot1p-dot1p | dot1p-dscp | dot1p-exp | dscp-dot1p | dscp-dscp | dscp-exp | exp-dot1p | exp-dscp | exp-exp } | up-dscp }
N/A
3.     Configure the colored priority mapping table.
You can configure the device to trust a particular priority field carried in packets for priority mapping on ports or globally.
When you configure the trusted packet priority type on an interface or port group, use the following available keywords:
·     auto—Automatically selects the priority of each received packet according to packet type for mapping.
For Layer 2 packets, 802.1p priority is used; for Layer 3 packets, IP precedence is used; for MPLS packets, EXP is used.
·     dot1p—Uses the 802.1p priority of received packets for mapping.
·     dscp—Uses the DSCP precedence of received IP packets for mapping.
·     exp—Uses the EXP value of received MPLS packets for mapping.
To configure the trusted packet priority type on an interface or port group:
Step
Remarks
N/A
Use either command.
Settings in Ethernet interface view take effect on the current interface. Settings in port group view take effect on all ports in the port group.
3.     Configure the trusted packet priority type for the interface.
qos trust { auto | dot1p | dscp | exp } [ override ]
By default, the port priority is trusted for priority mapping.
If an interface does not trust any packet priority, the device uses its port priority to look for the set of priority parameters for the incoming packets. By changing port priority, you can prioritize traffic received on different interfaces.
To change the port priority of an interface:
Step
Remarks
N/A
Use either command.
Settings in interface view (Ethernet or WLAN-ESS) take effect on the current interface. Settings in port group view take effect on all ports in the port group.
3.     Set the port priority of the interface.
qos priority { dot1p | dp | dscp | exp | lp } priority-value
The default is 2 for local precedence and 0 for drop precedence. The other priorities do not have defaults.
Configuring primap
By configuring a primap behavior and associating it with a traffic class, you can re-assign priority parameters for the traffic class according to the specified priority mapping table.
Configuring uncolored primap
Step
4.     Return to system view.
5.     Create a traffic behavior and enter traffic behavior view.
6.     Configure the action of assigning priority values to packets using a specified priority mapping table.
primap pre-defined dscp-dscp
7.     Return to system view.
8.     Create a policy and enter policy view.
9.     Associate the traffic behavior with the class.
10.     Return to system view.
11.     Apply the QoS policy.
·     Applying the QoS policy to an interface
·     Applying the QoS policy to a VLAN
·     Applying the QoS policy globally
Configuring colored primap
Step
Remarks
N/A
N/A
N/A
N/A
N/A
6.     Configure a CAR action.
car cir committed-information-rate [ cbs committed-burst-size [ ebs excess-burst-size ] ] [ pir peak-information-rate ] [ red action ]
N/A
7.     Configure the action of assigning priority values to packets using a specified colored priority mapping table.
primap pre-defined color { dot1p-dot1p | dot1p-exp | dot1p-dp | dot1p-dscp | dot1p-lp | dscp-dot1p | dscp-dp | dscp-dscp | dscp-exp | dscp-lp | exp-dot1p | exp-dp | exp-dscp | exp-exp | exp-lp | up-dscp }
N/A
8.     Configure the action of assigning drop precedence to packets according to packet color.
primap color-map-dp
Optional.
The packet color-to-drop precedence mappings are fixed to red to 2, yellow to 1, and green to 0.
This action can be used only in the inbound direction.
9.     Return to system view.
N/A
10.     Create a policy and enter policy view.
N/A
11.     Associate the traffic behavior with the class.
N/A
12.     Return to system view.
N/A
13.     Apply the QoS policy.
Choose one application destination as needed.
Remarks
Display priority mapping table configuration.
display qos map-table [ inbound { dot1p-dot1p | dot1p-dp | dot1p-dscp | dot1p-exp | dot1p-lp | dscp-dot1p| dscp-dp | dscp-dscp | dscp-exp | dscp-lp | exp-dot1p | exp-dp | exp-dscp | exp-lp | up-lp | up-up } | outbound { up-dp | up-fc | up-lp | up-rpr } ] [ dot1p-dot1p | dot1p-dp | dot1p-dscp | dot1p-exp | dot1p-lp | dscp-dot1p| dscp-dp | dscp-dscp | dscp-exp | dscp-lp | exp-dot1p | exp-dp | exp-dscp | exp-lp | up-dp | up-fc | up-lp | up-rpr | up-up ] [ | { begin | exclude | include } regular-expression ]
Display colored priority mapping table configuration.
display qos map-table color [ [ green | yellow | red ] [ inbound [ dot1p-dot1p | dot1p-dp | dot1p-dscp | dot1p-exp | dot1p-lp | dscp-dot1p | dscp-dp | dscp-dscp | dscp-exp | dscp-lp | exp-dot1p | exp-dp | exp-dscp | exp-exp | exp-lp ] | outbound [ dot1p-dot1p | dot1p-dscp | dot1p-exp | dscp-dot1p | dscp-dscp | dscp-exp | exp-dot1p | exp-dscp | exp-exp ] ] | up-dscp ] [ | { begin | exclude | include } regular-expression ]
Display the trusted packet priority type on a port.
display qos trust interface [ interface-type interface-number ] [ | { begin | exclude | include } regular-expression ]
As shown in Figure 4, different departments of a company assigned to different VLANs are interconnected on the intranet through the ports of Switch.
Configure priority mapping, so that Switch enqueues packets based on the 802.1p priority of packets.
The priority mapping table is user-defined.
Figure 4 Network diagram
# Enter system view.
<Switch> system-view
# Enter inbound dot1p-lp priority mapping table view and modify the priority mapping table parameters.
[Switch] qos map-table inbound dot1p-lp
[Switch-maptbl-in-dot1p-lp] import 0 1 export 0
[Switch-maptbl-in-dot1p-lp] import 2 3 export 1
[Switch-maptbl-in-dot1p-lp] import 4 5 export 2
[Switch-maptbl-in-dot1p-lp] import 6 7 export 3
[Switch-maptbl-in-dot1p-lp] quit
# Configure GigabitEthernet 3/0/1 to trust the 802.1p priority.
[Switch] interface gigabitethernet 3/0/1
[Switch-GigabitEthernet3/0/1] qos trust dot1p
[Switch-GigabitEthernet3/0/1] quit
# Configure GigabitEthernet 3/0/2 to trust the 802.1p priority.
[Switch] interface gigabitethernet 3/0/2
[Switch-GigabitEthernet3/0/2] qos trust dot1p
[Switch-GigabitEthernet3/0/2] quit
# Configure GigabitEthernet3/0/3 to trust the 802.1p priority.
[Switch] interface gigabitethernet 3/0/3
[Switch-GigabitEthernet3/0/3] qos trust dot1p
[Switch-GigabitEthernet3/0/3] quit
# Configure GigabitEthernet3/0/4 to trust the 802.1p priority.
[Switch] interface gigabitethernet 3/0/4
[Switch-GigabitEthernet3/0/4] qos trust dot1p
Overview
Traffic policing and traffic shaping are QoS techniques that help assign network resources, such as bandwidth. They increase network performance and user satisfaction. For example, you can configure a flow to use only the resources committed to it in a certain time range. This avoids network congestion caused by burst traffic.
Traffic policing and generic traffic shaping (GTS) limit the traffic rate and resource usage according to traffic specifications. Once a particular flow exceeds its specifications, such as bandwidth, it is shaped or policed to make sure it conforms to the specifications. You can use token buckets for evaluating traffic specifications.
Token bucket features
A token bucket is analogous to a container that holds a certain number of tokens. Each token represents a certain forwarding capacity. The system puts tokens into the bucket at a constant rate. When the token bucket is full, the extra tokens cause the token bucket to overflow.
Evaluating traffic with the token bucket
A token bucket mechanism evaluates traffic by looking at the number of tokens in the bucket. If the number of tokens in the bucket is enough for forwarding the packets, the traffic conforms to the specification, and is called "conforming traffic." Otherwise, the traffic does not conform to the specification, and is called "excess traffic."
A token bucket has the following configurable parameters:
·     Mean rate at which tokens are put into the bucket, which is the permitted average rate of traffic. It is usually set to the committed information rate (CIR).
·     Burst size or the capacity of the token bucket. It is the maximum traffic size permitted in each burst. It is usually set to the committed burst size (CBS). The set burst size must be greater than the maximum packet size.
Each arriving packet is evaluated. In each evaluation, if the number of tokens in the bucket is enough, the traffic conforms to the specification and the tokens for forwarding the packet are taken away; if the number of tokens in the bucket is not enough, the traffic is excessive.
Complicated evaluation
You can set two token buckets, bucket C and bucket E, to evaluate traffic in a more complicated environment and achieve more policing flexibility. For example, traffic policing uses the following parameters:
·     CIR—Rate at which tokens are put into bucket C. It sets the average packet transmission or forwarding rate allowed by bucket C.
·     CBS—Size of bucket C, which specifies the transient burst of traffic that bucket C can forward.
·     Peak information rate (PIR)—Rate at which tokens are put into bucket E, which specifies the average packet transmission or forwarding rate allowed by bucket E.
·     Excess burst size (EBS)—Size of bucket E, which specifies the transient burst of traffic that bucket E can forward.
CBS is implemented with bucket C, and EBS with bucket E. In each evaluation, packets are measured against the following bucket scenarios:
·     If bucket C has enough tokens, packets are colored green.
·     If bucket C does not have enough tokens but bucket E has enough tokens, packets are colored yellow.
·     If neither bucket C nor bucket E has sufficient tokens, packets are colored red.
Traffic policing
A typical application of traffic policing is to supervise the specification of certain traffic entering a network and limit it within a reasonable range, or to "discipline" the extra traffic to prevent aggressive use of network resources by a certain application. For example, you can limit bandwidth for HTTP packets to less than 50% of the total. If the traffic of a certain session exceeds the limit, traffic policing can drop the packets or reset the IP precedence of the packets. Figure 5 shows an example of policing outbound traffic on an interface.
Figure 5 Traffic policing
Traffic policing is widely used in policing traffic entering the networks of internet service providers (ISPs). It can classify the policed traffic and take pre-defined policing actions on each packet depending on the evaluation result:
·     Forwarding the packet if the evaluation result is "conforming."
·     Dropping the packet if the evaluation result is "excess."
·     Forwarding the packet with its IP precedence re-marked if the evaluation result is "conforming."
·     Delivering the packet to next-level traffic policing with its IP precedence re-marked if the evaluation result is "conforming."
·     Entering the next-level policing (you can set multiple traffic policing levels each focused on specific objects).
Traffic policing supports policing the inbound traffic and the outbound traffic.
Traffic shaping
Traffic shaping limits the outbound traffic rate by buffering exceeding traffic. You can use traffic shaping to adapt the traffic output rate on a device to the input traffic rate of its connected device to avoid packet loss.
The difference between traffic policing and GTS is that packets to be dropped with traffic policing are retained in a buffer or queue with GTS, as shown in Figure 6. When enough tokens are in the token bucket, the buffered packets are sent at an even rate. Traffic shaping might result in additional delay and traffic policing does not.
Figure 6 GTS
For example, in Figure 7, Router B performs traffic policing on packets from Router A and drops packets exceeding the limit. To avoid packet loss, you can perform traffic shaping on the outgoing interface of Router A so packets exceeding the limit are cached in Router A. Once resources are released, traffic shaping takes out the cached packets and sends them out.
Figure 7 GTS application
Traffic shaping supports shaping only the outbound traffic.
The switch implements color-aware CAR in traffic policing. For information about the color-aware mode, see RFC 2697.
To configure traffic policing:
Step
5.     Create a behavior and enter behavior view.
6.     Configure a traffic policing action.
9.     Associate the class with the traffic behavior in the QoS policy.
·     Applying the QoS policy to the control plane
Configuring GTS
IMPORTANT:
·     GTS for software forwarding does not support IPv6.
·     Do not configure GTS on a main interface and its subinterfaces at the same time.
You can configure the following types of GTS:
·     Queue-based GTS—configuring GTS parameters for packets of a certain queue.
·     GTS for all traffic—configuring GTS parameters for all traffic.
Configuring queue-based GTS
Step
Remarks
N/A
port-group manual
port-group-name
Use either command.
3.     Configure GTS for a queue.
qos gts queue queue-number cir committed-information-rate [ cbs committed-burst-size
N/A
Configuring GTS for all traffic
Step
Remarks
N/A
port-group manual
port-group-name
Use either command.
3.     Configure GTS on the interface or port group.
qos gts any cir committed-information-rate [ cbs committed-burst-size  ]
N/A
Remarks
Display CAR resources usage (in standalone mode).
display car resource [ slot slot-number ] [ | { begin | exclude | include } regular-expression ]
Display CAR resources usage (in IRF mode).
display car resource [ chassis chassis-number slot slot-number ] [ | { begin | exclude | include } regular-expression ]
Display interface GTS configuration information.
display qos gts interface [ interface-type interface-number ] [ | { begin | exclude | include } regular-expression ]
Overview
Network congestion degrades service quality on a traditional network. Congestion is a situation where the forwarding rate decreases due to insufficient resources, resulting in extra delay.
Congestion is more likely to occur in complex packet switching circumstances. Figure 8 shows two common cases:
Figure 8 Traffic congestion causes
Congestion can bring the following negative results:
·     Increased delay and jitter during packet transmission
·     Decreased network throughput and resource use efficiency
·     Network resource (memory in particular) exhaustion and even system breakdown
Congestion is unavoidable in switched networks and multi-user application environments. To improve the service performance of your network, you must take some proper measures to address the congestion issues.
The key to congestion management is how to define a dispatching policy for resources to decide the order of forwarding packets when congestion occurs.
Congestion management uses queuing and scheduling algorithms to classify and sort traffic leaving a port. Each queuing algorithm addresses a particular network traffic problem, and has a different impact on bandwidth resource assignment, delay, and jitter.
Queue scheduling processes packets by their priorities, preferentially forwarding high-priority packets. This section describes in detail Strict Priority (SP) queuing, Weighted Round Robin (WRR) queuing, and Weighted Fair Queuing (WFQ).
SP queuing
SP queuing is designed for mission-critical applications, which require preferential service to reduce the response delay when congestion occurs.
Figure 9 SP queuing
As shown in Figure 9, SP queuing classifies eight queues on a port into eight classes, numbered 7 to 0 in descending priority order.
SP queuing schedules the eight queues in the descending order of priority. It sends packets in the queue with the highest priority first. When the queue with the highest priority is empty, it sends packets in the queue with the second highest priority, and so on. You can assign mission-critical packets to the high priority queue to make sure they are always served first and common service packets to the low priority queues and transmitted when the high priority queues are empty.
The disadvantage of SP queuing is that packets in the lower priority queues cannot be transmitted if packets exist in the higher priority queues. This might cause lower priority traffic to starve to death.
WRR queuing
WRR queuing schedules all the queues in turn to make sure every queue is be served for a certain time, as shown in Figure 10.
Figure 10 WRR queuing
Assume a port provides eight output queues. WRR assigns each queue a weight value (represented by w7, w6, w5, w4, w3, w2, w1, or w0) to decide the proportion of resources assigned to the queue. On a 100 Mbps port, you can configure the weight values of WRR queuing to 50, 30, 10, 10, 50, 30, 10, and 10 (corresponding to w7, w6, w5, w4, w3, w2, w1, and w0). In this way, the queue with the lowest priority can get a minimum of 5 Mbps of bandwidth. WRR avoids the disadvantage of SP queuing that packets in low-priority queues might fail to be served for a long time.
Another advantage of WRR queuing is that when the queues are scheduled in turn, the service time for each queue is not fixed. If a queue is empty, the next queue will be scheduled immediately. This improves bandwidth resource use efficiency.
WRR queuing includes the following types:
·     Basic WRR queuingContains multiple queues. You can configure the weight, percentage (or byte count) for each queue and WRR schedules these queues based on the user-defined parameters in a round robin manner.
·     Group-based WRR queuingAll the queues are scheduled by WRR. You can assign the output queues to WRR priority queue group 1 and WRR priority queue group 2. Round robin queue scheduling is performed for the group which has the highest-numbered queue. If the group is empty, round robin queue scheduling is performed for the other group.
WFQ queuing
Figure 11 WFQ queuing
WFQ is similar to WRR. They both support scheduling weights in queue length. The difference is that WFQ enables you to set guaranteed bandwidth that a WFQ queue can get during congestion.
To configure hardware congestion management, you can use one of the following methods:
·     Configure queue scheduling for each queue in interface view or port group view.
·     Configure a queue scheduling profile, as described in hardware congestion management with queue scheduling profiles.
Complete the following tasks to achieve hardware congestion management:
Remarks
Configuring per-queue hardware congestion management:
·     Configuring SP queuing
·     Configuring WFQ queuing
Optional.
Optional.
Step
Remarks
N/A
interface
Use either command.
3.     Configure SP queuing.
qos sp
The default queuing algorithm on an interface is SP queuing.
4.     Display SP queuing configuration.
display qos sp interface [ interface-type interface-number ] [ | { begin | exclude | include } regular-expression ]
Optional.
1.     Network requirements
Configure GigabitEthernet 3/0/1 to use SP queuing.
2.     Configuration procedure
# Enter system view
# Configure GigabitEthernet 3/0/1 to use SP queuing.
[Sysname] interface GigabitEthernet 3/0/1
[Sysname-GigabitEthernet3/0/1] qos sp
To configure a WFQ queue:
Step
Remarks
N/A
Use either command.
3.     Enable WFQ queuing.
qos wfq
After WFQ queuing is enabled, all queues of an interface are scheduled by WFQ, and have a default scheduling weight of 1 and a default minimum guaranteed bandwidth of 40 kbps.
4.     Specify a scheduling weight for a WFQ queue.
qos wfq queue-id weight schedule-value
Optional.
5.     Configure the minimum guaranteed bandwidth for a WFQ queue.
Optional.
6.     Display WFQ queuing configuration.
display qos wfq interface [ interface-type interface-number ] [ | { begin | exclude | include } regular-expression ]
Optional.
Assign the scheduling weights 1, 5, 10, 20, and 10 to WFQ queues 1, 3, 4, 5, and 6, respectively.
# Configure WFQ queues on GigabitEthernet 3/0/1.
[Sysname-GigabitEthernet3/0/1] qos wfq
[Sysname-GigabitEthernet3/0/1] qos wfq 1 weight 1
[Sysname-GigabitEthernet3/0/1] qos wfq 3 weight 5
[Sysname-GigabitEthernet3/0/1] qos wfq 4 weight 10
[Sysname-GigabitEthernet3/0/1] qos wfq 5 weight 20
[Sysname-GigabitEthernet3/0/1] qos wfq 6 weight 10
In a queue scheduling profile, you can configure scheduling parameters for each queue. By applying the queue scheduling profile to an interface, you can implement congestion management on the interface. You can modify the scheduling parameters in a queue scheduling profile already applied to an interface.
Queue scheduling profiles support the following queue scheduling algorithms: SP and WRR. In a queue scheduling profile, you can configure either of the two queue scheduling algorithms or a mix of them. When both scheduling algorithms are configured, SP queues and WRR groups are scheduled in the descending order of queue ID. In a WRR priority group, queues are scheduled based on their weights. If SP and WRR are configured in a queue scheduling profile, the scheduling order is as shown in Figure 12.
Figure 12 Queue scheduling profile configured with both SP and WRR
·     Queue 7 is of the highest priority. Its packets are sent preferentially.
·     Queue 6 is of second highest priority. Packets in queue 6 are sent when queue 7 is empty.
·     Queue 3, queue 4, and queue 5 are scheduled according to their weights. When both queue 6 and queue 7 are empty, WRR group 0 is scheduled.
·     Queue 1 and queue 2 are scheduled according to their weights. WRR group 1 is scheduled when queue 7, queue 6, queue 5, queue 4, and queue 3 are all empty.
·     Queue 0 is of the lowest priority, and it is scheduled when all the other queues are empty.
To configure a queue scheduling profile, create the queue scheduling profile first, and then enter the queue scheduling profile view to configure its queue scheduling parameters. At last, apply the queue scheduling profile to the specified interface.
To configure a queue scheduling profile:
Step
Remarks
N/A
2.     Create a queue scheduling profile and enter queue scheduling profile view.
qos qmprofile profile-name
N/A
3.     Configure queue scheduling parameters.
·     Configure a queue to use SP:
queue queue-id sp
·     Configure a queue to use WRR:
queue queue-id wrr group group-id weight weight-value
One queue can use only one queue scheduling algorithm.
In a queue scheduling profile, you can configure different queue scheduling algorithms for different queues.
By default, each queue uses the SP queue scheduling.
N/A
5.     Enter interface view or port group view.
Use either command.
Configured in interface view, the setting takes effect on the current interface only. Configured in port group view, the setting takes effect on all ports in the port group.
6.     Apply the queue scheduling profile to the interface or port group.
N/A
IMPORTANT:
·     Only one queue scheduling profile can be applied to an interface.
·     To guarantee accurate scheduling, make sure the queues in a WRR group have consecutive numbers.
Remarks
Display the configuration of the specified or all queue scheduling profiles.
display qos qmprofile configuration [ profile-name ] [ | { begin | exclude | include } regular-expression ]
Display the queue scheduling profiles already applied to interfaces.
display qos qmprofile interface [ interface-type interface-number ] [ | { begin | exclude | include } regular-expression ]
Configure a queue scheduling profile to meet the following requirements on interface GigabitEthernet 3/0/1:
·     Queue 7 is of the highest priority, and its packets are sent preferentially.
·     Queue 4, queue 5, and queue 6 are in WRR group 1 and scheduled according to their weights, which are 1, 5, and 10. When queue 7 is empty, WRR group 0 is scheduled.
·     Queue 1, queue 2, and queue 3 are in WRR group 2 and scheduled according to their weights, which are 1, 10, and 20. When queue 4, queue 5, queue 6, and queue 7 are all empty, WRR group 1 is scheduled.
·     Queue 0 is of the lowest priority. Queue 0 is scheduled when all the other queues are empty.
# Create queue scheduling profile qm1.
[Sysname] qos qmprofile qm1
[Sysname-qmprofile-qm1]
# Configure queue 7 to use SP queuing.
[Sysname-qmprofile-qm1] queue 7 sp
# Assign queue 4, queue 5, and queue 6 to WRR group 0, with the weight of 1, 5, and 10.
[Sysname-qmprofile-qm1] queue 4 wrr group 1 weight 1
[Sysname-qmprofile-qm1] queue 5 wrr group 1 weight 5
[Sysname-qmprofile-qm1] queue 6 wrr group 1 weight 10
# Assign queue 1, queue 2, and queue 3 to WRR group 1, with the weight of 1, 10, and 20.
[Sysname-qmprofile-qm1] queue 1 wrr group 2 weight 1
[Sysname-qmprofile-qm1] queue 2 wrr group 2 weight 10
[Sysname-qmprofile-qm1] queue 3 wrr group 2 weight 20
# Configure queue 0 to use SP queuing.
[Sysname-qmprofile-qm1] queue 0 sp
[Sysname-qmprofile-qm1] quit
# Apply queue scheduling profile qm1 to interface GigabitEthernet 3/0/1.
[Sysname] interface gigabitethernet 3/0/1
[Sysname-GigabitEthernet3/0/1] qos apply qmprofile qm1
After the configuration is completed, interface GigabitEthernet 3/0/1 performs queue scheduling as specified in queue scheduling profile qm1.
Overview
Avoiding congestion before it occurs is a proactive approach to improving network performance. As a flow control mechanism, congestion avoidance actively monitors network resources (such as queues and memory buffers), and drops packets when congestion is expected to occur or deteriorate.
Compared with end-to-end flow control, this flow control mechanism controls the load of more flows in a device. When dropping packets from a source end, it cooperates with the flow control mechanism (such as TCP flow control) at the source end to regulate the network traffic size. The combination of the local packet drop policy and the source-end flow control mechanism helps maximize throughput and network use efficiency and minimize packet loss and delay.
Tail drop
Congestion management techniques drop all packets that are arriving at a full queue. This tail drop mechanism results in global TCP synchronization. If packets from multiple TCP connections are dropped, these TCP connections go into the state of congestion avoidance and slow start to reduce traffic, but traffic peak occurs later. Consequently, the network traffic jitters all the time.
RED and WRED
You can use random early detection (RED) or weighted random early detection (WRED) to avoid global TCP synchronization.
Both RED and WRED avoid global TCP synchronization by randomly dropping packets. When the sending rates of some TCP sessions slow down after their packets are dropped, other TCP sessions remain at high sending rates. Link bandwidth is efficiently used, because TCP sessions at high sending rates always exist.
The RED or WRED algorithm sets an upper threshold and lower threshold for each queue, and processes the packets in a queue as follows:
·     When the queue size is shorter than the lower threshold, no packet is dropped;
·     When the queue size reaches the upper threshold, all subsequent packets are dropped;
·     When the queue size is between the lower threshold and the upper threshold, the received packets are dropped at random. The drop probability in a queue increases along with the queue size under the maximum drop probability.
WRED uses differentiated drop policies for different IP precedence values. Packets with a lower IP precedence are more likely to be dropped.
To configure WRED on an interface:
Step
Remarks
N/A
Use either command.
3.     Enable WRED.
qos wred enable
N/A
Enable WRED on interface GigabitEthernet 3/0/1.
# Enter interface view.
# Enable WRED.
[Sysname-GigabitEthernet3/0/1] qos wred enable
Remarks
Display WRED configuration information on the interface or all interfaces.
display qos wred interface [ interface-type interface-number ] [ | { begin | exclude | include } regular-expression ]
You can filter in or filter out a class of traffic by associating the class with a traffic filtering action. For example, you can filter packets sourced from a specific IP address according to network status.
To configure traffic filtering:
Step
Remarks
N/A
N/A
N/A
N/A
N/A
6.     Configure the traffic filtering action.
filter { deny | permit }
·     deny: Drops packets.
·     permit: Permits packets to pass through.
N/A
N/A
N/A
N/A
12.     Display the traffic filtering configuration.
Optional.
With filter deny configured for a traffic behavior, the other actions (except class-based accounting) in the traffic behavior do not take effect. Whether traffic filtering can work with class-based accounting depends on your card model: the two commands are mutually exclusive on an Ethernet interface card, and the two commands can co-exist on an interface subcard.
Actions supported in the inbound direction and configuration restrictions
·     filter permit conflicts with filter deny and redirect cpu.
·     filter deny can work with only accounting.
·     redirect next-hop conflicts with filter deny.
·     redirect cpu conflicts with all other actions.
·     redirect interface conflicts with filter deny and mirror-to cpu. For more information about traffic mirroring, see Network Management and Monitoring Configuration Guide.
·     car conflicts with filter deny and redirect cpu.
·     accounting conflicts with redirect cpu.
·     remark dscp/exp/dot1p/lp/dp conflicts with filter deny, redirect cpu, and primap pre-defined color.
·     primap conflicts with filter deny, redirect cpu, and remark dscp/exp/dot1p/lp/dp.
Actions supported in the outbound direction and configuration restrictions
·     filter permit conflicts with filter deny.
·     filter deny conflicts with all other actions.
·     car conflicts with filter deny.
·     accounting conflicts with filter deny.
·     remark dscp/dot1p/exp conflicts with filter deny and marking dscp/dot1p/exp with the primap pre-defined color action.
·     Marking dscp/dot1p/exp with the primap pre-defined color action conflicts with filter deny and remark dscp/dot1p/exp.
IMPORTANT:
By default, Ethernet, VLAN, and aggregate interfaces are down. To configure traffic filtering for any of them, use the undo shutdown command on the interface to bring it up first.
As shown in Figure 13, Host is connected to GigabitEthernet 3/0/1 of Device.
Configure traffic filtering to filter the packets with source port not being 21 and received on GigabitEthernet 3/0/1.
Figure 13 Network diagram
# Create advanced ACL 3000, and configure a rule to match packets whose source port number is not 21.
[DeviceA] acl number 3000
[DeviceA-acl-adv-3000] rule 0 permit tcp source-port neq 21
[DeviceA-acl-adv-3000] quit
# Create a class named classifier_1, and use ACL 3000 as the match criterion in the class.
[DeviceA] traffic classifier classifier_1
[DeviceA-classifier-classifier_1] if-match acl 3000
[DeviceA-classifier-classifier_1] quit
# Create a behavior named behavior_1, and configure the traffic filtering action to drop packets.
[DeviceA] traffic behavior behavior_1
[DeviceA-behavior-behavior_1] filter deny
[DeviceA-behavior-behavior_1] quit
# Create a policy named policy, and associate class classifier_1 with behavior behavior_1 in the policy.
[DeviceA] qos policy policy
[DeviceA-qospolicy-policy] classifier classifier_1 behavior behavior_1
[DeviceA-qospolicy-policy] quit
# Apply the policy named policy to the incoming traffic of GigabitEthernet 3/0/1.
[DeviceA] interface GigabitEthernet 3/0/1
[DeviceA-GigabitEthernet3/0/1] qos apply policy policy inbound
Overview
The protocol packets in the network are sent to the CPU for processing. The protocol packet processing rate of a CPU is limited. When plenty of protocol packets are sent to the CPU for processing at the same time, the CPU might be completely occupied by the protocol packets and cannot process other tasks. As a result, the device is paralyzed. The protocol packet rate limiting function limits the rate of protocol packets sent to the CPU, and guarantees the normal operation of the CPU.
To configure protocol packet rate limiting:
Step
Remarks
N/A
N/A
N/A
N/A
N/A
6.     Configure protocol packet rate limiting.
packet-rate value
The value argument is in pps.
N/A
N/A
N/A
N/A
11.     Apply the QoS policy to the control plane.
N/A
12.     Display the protocol packet rate limiting configuration.
Optional.
As shown in Figure 14, multiple hosts are connected to Device through switches.
Configure protocol packet rate limiting to limit the rate of DHCP snooping protocol packet sent to the CPU of the card in slot 3 of Device to 500 pps.
Figure 14 Network diagram
# Create class classifier_1, and configure the class to match system-index 19, which represents DHCP snooping protocol packets. You can use the display qos policy control-plane pre-defined command to see that system index 19 matches DHCP snooping protocol packets.
[Device-classifier-classifier_1] if-match system-index 19
# Create behavior behavior_1, and configure the behavior to limit the packet rate to 500 pps.
[Device-behavior-behavior_1] packet-rate 500
[Device] qos policy policy
[Device-qospolicy-policy] classifier classifier_1 behavior behavior_1
[Device-qospolicy-policy] quit
# Apply the QoS policy to the incoming traffic of the control plane of the card in slot 3.
[Device] control-plane slot 3
[Device-cp-slot3] qos apply policy policy inbound
[Device-cp-slot3] quit
Overview
Priority marking sets the priority fields or flag bits of packets to modify the priority of traffic. For example, you can use priority marking to set IP precedence or DSCP for a class of IP traffic to change its transmission priority in the network.
To configure priority marking, you can associate a class with a behavior configured with the priority marking action to set the priority fields or flag bits of the class of packets.
To configure priority marking:
Step
Remarks
N/A
N/A
N/A
N/A
N/A
6.     Set the DSCP value for packets.
remark dscp dscp-value
Optional.
7.     Set the 802.1p priority for packets.
remark dot1p 8021p
Optional.
8.     Set the drop precedence for packets.
remark drop-precedence drop-precedence-value
Optional.
Applicable to only the outbound direction.
9.     Set the local precedence for packets.
remark local-precedence local-precedence
Optional.
N/A
11.     Create a policy and enter policy view.
N/A
12.     Associate the class with the traffic behavior in the QoS policy.
N/A
13.     Return to system view.
N/A
14.     Apply the QoS policy.
15.     Display the priority marking configuration.
Optional.
As shown in Figure 15, the enterprise network of a company interconnects hosts with servers through Device. The network is described as follows:
·     Host A and Host B are connected to GigabitEthernet 3/0/1 of Device.
·     The data server, mail server, and file server are connected to GigabitEthernet 3/0/1 of Device.
Configure priority marking on Device to meet the following requirements:
Traffic source
Destination
Processing priority
Host A, B
Data server
High
Host A, B
Mail server
Medium
Host A, B
File server
Low
Figure 15 Network diagram
# Create advanced ACL 3000, and configure a rule to match packets with destination IP address 192.168.0.1.
[Device] acl number 3000
[Device-acl-adv-3000] rule permit ip destination 192.168.0.1 0
[Device-acl-adv-3000] quit
# Create advanced ACL 3001, and configure a rule to match packets with destination IP address 192.168.0.2.
[Device] acl number 3001
[Device-acl-adv-3001] rule permit ip destination 192.168.0.2 0
[Device-acl-adv-3001] quit
# Create advanced ACL 3002, and configure a rule to match packets with destination IP address 192.168.0.3.
[Device] acl number 3002
[Device-acl-adv-3002] rule permit ip destination 192.168.0.3 0
[Device-acl-adv-3002] quit
# Create a class named classifier_dbserver, and use ACL 3000 as the match criterion in the class.
[Device] traffic classifier classifier_dbserver
[Device-classifier-classifier_dbserver] if-match acl 3000
[Device-classifier-classifier_dbserver] quit
# Create a class named classifier_mserver, and use ACL 3001 as the match criterion in the class.
[Device] traffic classifier classifier_mserver
[Device-classifier-classifier_mserver] if-match acl 3001
[Device-classifier-classifier_mserver] quit
# Create a class named classifier_fserver, and use ACL 3002 as the match criterion in the class.
[Device] traffic classifier classifier_fserver
[Device-classifier-classifier_fserver] if-match acl 3002
[Device-classifier-classifier_fserver] quit
# Create a behavior named behavior_dbserver, and configure the action of setting the local precedence value to 4.
[Device] traffic behavior behavior_dbserver
[Device-behavior-behavior_dbserver] remark local-precedence 4
[Device-behavior-behavior_dbserver] quit
# Create a behavior named behavior_mserver, and configure the action of setting the local precedence value to 3.
[Device] traffic behavior behavior_mserver
[Device-behavior-behavior_mserver] remark local-precedence 3
[Device-behavior-behavior_mserver] quit
# Create a behavior named behavior_fserver, and configure the action of setting the local precedence value to 2.
[Device] traffic behavior behavior_fserver
[Device-behavior-behavior_fserver] remark local-precedence 2
[Device-behavior-behavior_fserver] quit
# Create a policy named policy_server, and associate classes with behaviors in the policy.
[Device] qos policy policy_server
[Device-qospolicy-policy_server] classifier classifier_dbserver behavior behavior_dbserver
[Device-qospolicy-policy_server] classifier classifier_mserver behavior behavior_mserver
[Device-qospolicy-policy_server] classifier classifier_fserver behavior behavior_fserver
[Device-qospolicy-policy_server] quit
# Apply the policy named policy_server to the incoming traffic of GigabitEthernet 3/0/1.
[Device] interface GigabitEthernet 3/0/1
[Device-GigabitEthernet3/0/1] qos apply policy policy_server inbound
[Device-GigabitEthernet3/0/1] quit
Overview
Traffic redirecting is the action of redirecting the packets matching the specific match criteria to a certain location for processing.
The following redirect actions are supported:
·     Redirecting traffic to the CPURedirects packets that require processing by the CPU to the CPU.
·     Redirecting traffic to an interfaceRedirects packets that require processing by an interface to the interface. This action applies to only Layer 2 packets, and the target interface must be a Layer 2 interface.
·     Redirecting traffic to the next hopRedirects packets that require processing by an interface to the interface. This action only applies to Layer 3 packets.
When you configure traffic redirecting, follow these guidelines:
·     The actions of redirecting traffic to the CPU, redirecting traffic to an interface, and redirecting traffic to the next hop are mutually exclusive with each other in the same traffic behavior.
·     If you specify a next hop as the redirect destination, make sure the traffic identified by match criteria has the same IP version as the IP address of the next hop. For example, if the next hop is an IPv4 node, avoid using an IPv6 ACL for classification.
·     The default of the fail-action keyword, if supported, is forward.
·     You can use the display traffic behavior user-defined [ behavior-name ] [ | { begin | exclude | include } regular-expression ] command to view the traffic redirecting configuration.
·     In IRF mode, the switch does not support redirecting traffic to an aggregate interface.
·     Different from looking up the routing table based on the destination address of an IP packet, the policy-based routing (the action of redirecting traffic to the next hop) can flexibly select routes for traffic based on source IP address, and so on. The policy-based routing takes precedence over common routing. A packet is forwarded according to common routing if it does not match the policy-based routing configuration.
·     On a switch operating in IRF mode, when you configure cross-switch traffic redirecting to a port of an OAA card, make sure the port of the OAA card is in VLAN 1.
·     In standalone mode, the switch does not support redirecting traffic to an aggregate interface on an LST1IPS2A1 card.
·     In IRF mode, the switch does not support redirecting traffic to the second internal port on an LST1IPS2A1 card on another member device.
·     To redirect traffic correctly to an internal port on an LST1IPS2A1 card by using a QoS policy, you must perform the following tasks:
¡     Assign the two internal ports to an aggregation group.
¡     Set the minimum number of Selected ports in the aggregation group to 2.
Additionally, do not assign any other interface to the aggregation group.
To configure traffic redirecting:
Step
Remarks
N/A
N/A
N/A
N/A
N/A
6.     Configure a traffic redirecting action.
redirect { cpu | interface interface-type interface-number [ vlan vlan-id ] | next-hop { ipv4-add1 [ ipv4-add2 ] | ipv6-add1 [ interface-type interface-number ] [ ipv6-add2 [ interface-type interface-number ] ] } [ fail-action { discard | forward } ] }
Optional.
N/A
N/A
N/A
N/A
Traffic redirecting configuration example
IMPORTANT:
By default, Ethernet, VLAN, and aggregate interfaces are down. To configure traffic redirecting for any of them, use the undo shutdown command on the interface to bring it up first.
As shown in Figure 16, the network is described as follows:
·     Device A is connected to Device through two links. At the same time, Device A and Device B are each connected to other devices.
·     GigabitEthernet 3/0/2 of Device A and GigabitEthernet 3/0/2 of Device B belong to VLAN 200.
·     GigabitEthernet 3/0/3 of Device A and GigabitEthernet 3/0/3 of Device B belong to VLAN 201.
·     On Device A, the IP address of VLAN-interface 200 is 200.1.1.1/24, and that of VLAN-interface 201 is 201.1.1.1/24.
·     On Device B, the IP address of VLAN-interface 200 is 200.1.1.2/24, and that of VLAN-interface 201 is 201.1.1.2/24.
Configure the actions of redirecting traffic to the next hop to implement policy-based routing and meet the following requirements:
·     Packets with source IP address 2.1.1.1 received on GigabitEthernet 3/0/1 of Device A are forwarded to IP address 200.1.1.2.
·     Packets with source IP address 2.1.1.2 received on GigabitEthernet 3/0/1 of Device A are forwarded to IP address 201.1.1.2.
·     Other packets received on GigabitEthernet 3/0/1 of Device A are forwarded according to the routing table.
Figure 16 Network diagram
# Create basic ACL 2000, and configure a rule to match packets with source IP address 2.1.1.1.
[DeviceA] acl number 2000
[DeviceA-acl-basic-2000] rule permit source 2.1.1.1 0
[DeviceA-acl-basic-2000] quit
# Create basic ACL 2001, and configure a rule to match packets with source IP address 2.1.1.2.
[DeviceA] acl number 2001
[DeviceA-acl-basic-2001] rule permit source 2.1.1.2 0
[DeviceA-acl-basic-2001] quit
# Create a class named classifier_1, and use ACL 2000 as the match criterion in the class.
[DeviceA-classifier-classifier_1] if-match acl 2000
# Create a class named classifier_2, and use ACL 2001 as the match criterion in the class.
[DeviceA] traffic classifier classifier_2
[DeviceA-classifier-classifier_2] if-match acl 2001
[DeviceA-classifier-classifier_2] quit
# Create a behavior named behavior_1, and configure the action of redirecting traffic to the next hop 200.1.1.2.
[DeviceA-behavior-behavior_1] redirect next-hop 200.1.1.2
# Create a behavior named behavior_2, and configure the action of redirecting traffic to the next hop 200.1.1.2.
[DeviceA] traffic behavior behavior_2
[DeviceA-behavior-behavior_2] redirect next-hop 201.1.1.2
[DeviceA-behavior-behavior_2] quit
# Create a policy named policy, associate class classifier_1 with behavior behavior_1, and associate class classifier_2 with behavior behavior_2 in the policy.
[DeviceA-qospolicy-policy] classifier classifier_2 behavior behavior_2
# Apply the policy named policy to the incoming traffic of GigabitEthernet 3/01.
[DeviceA-GigabitEthernet 3/0/1] qos apply policy policy inbound
Overview
Global committed access rate (CAR) is an approach to policing traffic flows globally. It adds flexibility to common CAR where traffic policing is performed only on a per-class or per-interface basis. In this approach, CAR actions are created in system view and each can be referenced to police multiple traffic flows as a whole. Only aggregate CAR is supported.
An aggregate CAR action is created globally and can be directly applied to interfaces or referenced in the traffic behaviors associated with different traffic classes to police multiple traffic flows as a whole. The total rate of the traffic flows must conform to the traffic policing specifications set in the aggregate CAR action.
Configuring aggregate CAR
To configure aggregate CAR:
Step
Remarks
N/A
2.     Configure an aggregate CAR action.
qos car car-name aggregative cir committed-information-rate [ cbs committed-burst-size [ ebs excess-burst-size ] ] [ pir peek-information-rate ] [ red action ]
N/A
3.     Enter behavior view.
N/A
4.     Reference the aggregate CAR in the traffic behavior.
car name car-name
N/A
5.     Display the traffic behavior configuration information.
Optional.
6.     Display the configuration and statistics for the specified aggregate CAR.
display qos car name [ car-name ] [ | { begin | exclude | include } regular-expression ]
Optional.
Configuration example
# Create an aggregate CAR action named aggcar-1, and configure the following parameters for it: CIR 200, CBS 2000, and dropping red packets. Reference aggregate CAR aggcar-1 in behavior be1.
[Sysname] qos car aggcar-1 aggregative cir 200 cbs 2000 red discard
Overview
Class-based accounting collects statistics (in packets or bytes) on a per-traffic class basis. For example, you can define the action to collect statistics for traffic sourced from a certain IP address. By analyzing the statistics, you can determine whether anomalies have occurred and what action to take.
Step
Remarks
N/A
2.     Create a class and enter class view.
traffic classifier tcl-name [ operator { and | or } ]
N/A
3.     Configure match criteria.
if-match match-criteria
N/A
N/A
N/A
6.     Configure the accounting action.
accounting { byte | packet }
Optional.
·     byte: Counts traffic in bytes.
·     packet: Counts traffic in packets.
N/A
qos policy policy-name
N/A
classifier tcl-name behavior behavior-name
N/A
N/A
Displaying and maintaining class-based accounting
To verify the class-based accounting configuration, use the display qos policy command in any view to display the traffic statistics collected after the configuration is complete.
Class-based accounting configuration example
IMPORTANT
IMPORTANT:
As shown in Figure 17, Host is connected to GigabitEthernet 3/0/1 of Device.
Configure class-based accounting to collect statistics for traffic sourced from 1.1.1.1/24 and received on GigabitEthernet 3/0/1.
Figure 17 Network diagram
# Create basic ACL 2000, and configure a rule to match packets with source IP address 1.1.1.1.
[DeviceA-acl-basic-2000] rule permit source 1.1.1.1 0
# Create a behavior named behavior_1, and configure the traffic accounting action.
[DeviceA-behavior-behavior_1] accounting
[DeviceA-GigabitEthernet3/0/1] quit
# Display traffic statistics to verify the configuration.
[DeviceA] display qos policy interface GigabitEthernet 3/0/1
  Interface: GigabitEthernet3/0/1
  Direction: Inbound
  Policy: policy
   Classifier: classifier_1
     Operator: AND
     Rule(s) : If-match acl 2000
     Behavior: behavior_1
      Accounting Enable:
        28529 (Packets)
Overview
A device provides two counters to collect outbound and inbound traffic statistics.
You can configure each counter to collect statistics for traffic on a card, or traffic identified by any combination of interface, VLAN, local precedence, and drop precedence.
You can enable the two counters at the same time. They collect statistics independently.
The difference between class-based accounting and traffic accounting lies in that traffic accounting collects statistics according to system-defined statistics collecting rules and class-based accounting collects statistics for user-defined traffic classes.
Step
Remarks
N/A
2.     Enable traffic accounting and specify the type of traffic.
qos traffic-counter
{ inbound | outbound } { counter0 | counter1 } slot slot-number [ interface interface-type interface-number | vlan vlan-id | drop-priority dp-value ] *
·     In IRF mode:
qos traffic-counter
{ inbound | outbound } { counter0 | counter1 } chassis chassis-number slot slot-number [ interface interface-type interface-number | vlan vlan-id | drop-priority dp-value ] *
By default, traffic accounting is disabled.
The drop-priority keyword applies only in the outbound direction.
Displaying and maintaining traffic accounting
Remarks
Display traffic statistics collected by the traffic accounting function in standalone mode.
display qos traffic-counter { inbound | outbound } { counter0 | counter1 } slot slot-number [ | { begin | exclude | include } regular-expression ]
Display traffic statistics collected by the traffic accounting function in IRF mode.
display qos traffic-counter { inbound | outbound } { counter0 | counter1 } chassis chassis-number slot slot-number [ | { begin | exclude | include } regular-expression ]
Clear the traffic statistics collected by a counter of the traffic accounting function in standalone mode.
reset qos traffic-counter { inbound | outbound } { counter0 | counter1 } slot slot-number
Clear the traffic statistics collected by a counter of the traffic accounting function in IRF mode.
reset qos traffic-counter { inbound | outbound } { counter0 | counter1 } chassis chassis-number slot slot-number
The switch can provide more granular QoS scheduling when it is operating in enhanced QoS mode. You can disable enhanced QoS to improve the packet processing speed and reduce the forwarding delay.
To configure enhanced QoS:
Step
Remarks
N/A
2.     Enable or disable enhanced QoS.
enhanced-qos enable
Optional.
By default, enhanced QoS is enabled.
Overview
Suppose a device is not configured with the QoS pipe mode and the device performs any of the following roles:
·     A backbone core bridge (BCB) in a MAC-in-MAC network.
·     An egress provider edge (PE) in an MPLS L2VPN network.
·     An egress PE in an MPLS L3VPN network.
·     An egress PE in a VPLS network.
If the device receives a packet carrying the DSCP field, the device changes the DSCP value to 0, and then forwards the packet to downstream devices. If a downstream device is configured with priority mapping, the downstream device will map the DSCP value of the IP packet to packet scheduling priority values (such as local precedence, drop precedence, and user precedence), and effectively, thoroughly control the forwarding and scheduling priority of the packet. As a result, if the DSCP value of the packet is changed, the forwarding and scheduling of the IP packet on the downstream devices are affected, or even the packet might be dropped.
With the QoS pipe mode configured, packets can pass through any of the networks mentioned above and keep their DSCP values unchanged. As a result, the forwarding and scheduling of the IP packets on the downstream devices are not affected.
For more information about MAC-in-MAC, see Layer 2—LAN Switching Configuration Guide. For more information about MPLS L2VPN, MPLS L3VPN, and VPLS, see MPLS Configuration Guide.
To configure the QoS pipe mode:
Step
Remarks
1.     Enter system view
N/A
2.     Configure the QoS pipe mode
qos pipe-mode
By default, the QoS pipe mode is not configured.
Appendix A Acronym
Table 1 Appendix A Acronym
Acronym
Full spelling
AF
Assured Forwarding
BE
Best Effort
CAR
Committed Access Rate
CBS
Committed Burst Size
CBQ
Class Based Queuing
CBWFQ
Class Based Weighted Fair Queuing
CE
Customer Edge
CIR
Committed Information Rate
CQ
Custom Queuing
DAR
Deeper Application Recognition
DiffServ
Differentiated Service
DSCP
Differentiated Services Codepoint
EACL
Enhanced ACL
EBS
Excess Burst Size
EF
Expedited Forwarding
FEC
Forwarding Equivalence Class
FIFO
First in First out
GTS
Generic Traffic Shaping
IntServ
Integrated Service
ISP
Internet Service Provider
LFI
Link Fragmentation & Interleaving
LLQ
Low Latency Queuing
LSP
Label Switched Path
MPLS
Multiprotocol Label Switching
PE
Provider Edge
PHB
Per-hop Behavior
PIR
Peak Information Rate
PQ
Priority Queuing
QoS
Quality of Service
QPPB
QoS Policy Propagation Through the Border Gateway Protocol
RED
Random Early Detection
RSVP
Resource Reservation Protocol
RTP
Real-time Transport Protocol
SLA
Service Level Agreement
TE
Traffic Engineering
ToS
Type of Service
TP
Traffic Policing
TS
Traffic Shaping
VoIP
Voice over IP
VPN
Virtual Private Network
WFQ
WRED
Weighted Random Early Detection
Introduction to priority mapping tables
The switch provides various types of priority mapping table, as listed below.
Table 2 The default dot1p-lp, dot1p-dp, dot1p-dscp, and dot1p-exp mappings
Input priority value
dot1p-lp mapping
dot1p-dp mapping
dot1p-dscp mapping
dot1p-exp mapping
0
2
0
0
0
1
0
0
8
1
2
1
0
16
2
3
3
0
24
3
4
4
0
32
4
5
5
0
40
5
6
6
0
48
6
7
7
0
56
7
Table 3 The default dscp-lp, dscp-dp, dscp-dot1p, and dscp-exp mappings
dscp-lp mapping
dscp-dp mapping
dscp-dot1p mapping
dscp-exp mapping
0 to 7
0
0
0
0
8 to 15
1
0
1
1
16 to 23
2
0
2
2
24 to 31
3
0
3
3
32 to 39
4
0
4
4
40 to 47
5
0
5
5
48 to 55
6
0
6
6
56 to 63
7
0
7
7
Table 4 The default exp-dscp, exp-dp, exp-dot1p, and exp-lp mappings
exp-dscp mapping
exp-dp mapping
exp-dot1p mapping
exp-lp mapping
0
0
0
0
0
1
8
0
1
1
2
16
0
2
2
3
24
0
3
3
4
32
0
4
4
5
40
0
5
5
6
48
0
6
6
7
56
0
7
7
Table 5 The default up-dp, up-lp, up-up, and up-rpr mappings
up-dp mapping
up-lp mapping
up-up mapping
up-rpr mapping
0
0
0
0
0
1
0
1
1
0
2
0
2
2
1
3
0
3
3
1
4
0
4
4
2
5
0
5
5
2
6
0
6
6
2
7
0
7
7
2
Introduction to colored priority mapping tables
Packets processed by CAR are colored green, yellow, or red. To perform priority mapping for packets in different colors, the switch provides multiple colored priority mapping tables, as described in subsections.
dot1p-dot1p mapping
The output value equals the input value in all conditions.
dot1p-dp mapping
Table 6 The default dot1p-dp mapping table
Input value
dot1p-dp mapping (inbound)
green
yellow
red
0 to 7
0
1
2
dot1p-dscp
The output value equals the input value multiplied by 8 in all conditions.
dot1p-exp
dot1p-lp
Table 7 The default dot1p-lp mapping table
Input value
dot1p-lp mapping (inbound)
green
yellow
red
0
2
2
2
1
0
0
0
2
1
1
1
3
3
3
3
4
4
4
4
5
5
5
5
6
6
6
6
7
7
7
7
dscp-dot1p
Table 8 The default dscp-dot1p mapping table
Input value
dscp-dot1p mapping
green
yellow
red
0 to 7
0
0
0
8 to 15
1
1
1
16 to 23
2
2
2
24 to 31
3
3
3
32 to 39
4
4
4
40 to 47
5
5
5
48 to 55
6
6
6
56 to 63
7
7
7
dscp-dp
Table 9 The default dscp-dp mapping table
Input value
dscp-dp mapping (inbound)
green
yellow
red
0 to 63
0
1
2
dscp-dscp
dscp-exp
Table 10 The default dscp-exp mapping table
Input value
dscp-exp mapping
green
yellow
red
0 to 7
0
0
0
8 to 15
1
1
1
16 to 23
2
2
2
24 to 31
3
3
3
32 to 39
4
4
4
40 to 47
5
5
5
48 to 55
6
6
6
56 to 63
7
7
7
dscp-lp
Table 11 The default dscp-lp mapping table
Input value
dscp-lp mapping (inbound)
green
yellow
red
0–7
0
0
0
8–15
1
1
1
16–23
2
2
2
24–31
3
3
3
32–39
4
4
4
40–47
5
5
5
48–55
6
6
6
56–63
7
7
7
exp-dot1p
exp-dp
Table 12 The default exp-dp mapping table
Input value
exp-dp mapping (inbound)
green
yellow
red
0 to 7
0
1
2
exp-dscp
exp-exp
exp-lp
up-dscp
Table 13 The default up-dscp mapping table for green, yellow, and red packets
up-dscp mapping
up
dscp
0
0
1
8
2
16
3
24
4
32
5
40
6
48
7
56
·     The mappings described in this section apply to both directions unless otherwise specified.
·     The priority used for colored priority mapping table lookup depends on the configuration of trusted priority on the port and the priority re-marking result.
Appendix C Introduction to packet precedences
IP precedence and DSCP values
Figure 18 ToS and DS fields
As shown in Figure 18, the ToS field in the IP header contains 8 bits. The first 3 bits (0 to 2) represent IP precedence from 0 to 7. According to RFC 2474, the ToS field is redefined as the differentiated services (DS) field, where a DSCP value is represented by the first 6 bits (0 to 5) and is in the range 0 to 63. The remaining 2 bits (6 and 7) are reserved.
Table 14 IP precedence
IP precedence (decimal)
IP precedence (binary)
0
000
Routine
1
001
priority
2
010
immediate
3
011
flash
4
100
flash-override
5
101
critical
6
110
internet
7
111
network
Table 15 DSCP values
DSCP value (decimal)
DSCP value (binary)
46
101110
ef
10
001010
af11
12
001100
af12
14
001110
af13
18
010010
af21
20
010100
af22
22
010110
af23
26
011010
af31
28
011100
af32
30
011110
af33
34
100010
af41
36
100100
af42
38
100110
af43
8
001000
cs1
16
010000
cs2
24
011000
cs3
32
100000
cs4
40
101000
cs5
48
110000
cs6
56
111000
cs7
0
000000
be (default)
802.1p priority
802.1p priority lies in the Layer 2 header and applies to occasions where Layer 3 header analysis is not needed and QoS must be assured at Layer 2.
Figure 19 An Ethernet frame with an 802.1Q tag header
As shown in Figure 19, the 4-byte 802.1Q tag header consists of the tag protocol identifier (TPID, 2 bytes in length), whose value is 0x8100, and the tag control information (TCI, 2 bytes in length). Figure 20 shows the format of the 802.1Q tag header. The Priority field in the 802.1Q tag header is called the "802.1p priority", because its use is defined in IEEE 802.1p. Table 16 shows the values for 802.1p priority.
Figure 20 802.1Q tag header
Table 16 Description on 802.1p priority
802.1p priority (decimal)
802.1p priority (binary)
0
000
best-effort
1
001
background
2
010
spare
3
011
excellent-effort
4
100
controlled-load
5
101
video
6
110
voice
7
111
network-management
EXP values
The EXP field is in MPLS labels for MPLS QoS purposes.
Figure 21 MPLS label structure
As shown in Figure 21, the EXP field is 3 bits long and is in the range of 0 to 7.
