- 07-Layer 3 - IP Routing Configuration Guide
- 01-Basic IP Routing Configuration
- 02-Static Routing Configuration
- 03-RIP Configuration
- 04-OSPF Configuration
- 05-IS-IS Configuration
- 06-BGP Configuration
- 07-Policy-Based Routing Configuration
- 08-Guard Route Configuration
- 09-IPv6 Static Routing Configuration
- 10-RIPng Configuration
- 11-OSPFv3 Configuration
- 12-IPv6 IS-IS Configuration
- 13-IPv6 BGP Configuration
- 14-IPv6 Policy-Based Routing Configuration
- 15-Routing Policy Configuration
- 16-Tunnel End Packets Policy Routing Configuration
| 02-Static Routing Configuration | 203.35 KB |
Configuring BFD for static routes
Displaying and maintaining static routes
Static route configuration examples
Basic static route configuration example
BFD for static routes configuration example (direct next hop)
BFD for static routes configuration example (indirect next hop)
Static route FRR configuration example
Static routes are manually configured. If a network's topology is simple, you only need to configure static routes for the network to work correctly.
Static routes cannot adapt to network topology changes. If a fault or a topological change occurs in the network, the network administrator must modify the static routes manually.
Configuring a static route
Before you configure a static route, complete the following tasks:
· Configure the physical parameters for related interfaces.
· Configure the link-layer attributes for related interfaces.
· Configure the IP addresses for related interfaces.
Follow these guidelines when you configure a static route:
· The next hop address of a static route cannot be the IP address of a local interface. Otherwise, the static route does not take effect.
· You can associate track entry with a static route to monitor the reachability of the next hops. For more information about Track, see High Availability Configuration Guide.
To configure a static route:
Step |
Command |
Remarks |
1. Enter system view. |
system-view |
N/A |
2. Configure a static route. |
· Method 1: · Method 2: |
Use either method. By default, no static route is configured. |
3. Configure the default preference for static routes. |
ip route-static default-preference default-preference-value |
Optional. 60 by default. |
4. Delete all static routes, including the default route. |
delete [ vpn-instance vpn-instance-name ] static-routes all |
Optional. To delete one static route, use the undo ip route-static command. |
Bidirectional forwarding detection (BFD) provides a general-purpose, standard, medium-, and protocol-independent fast failure detection mechanism. It can uniformly and quickly detect the failures of the bidirectional forwarding paths between two routers for protocols, such as routing protocols and Multiprotocol Label Switching (MPLS). For more information about BFD, see High Availability Configuration Guide.
BFD control mode
To use BFD bidirectional control detection between two devices, enable BFD control mode for each device's static route destined to the peer.
To configure a static route and enable BFD control mode for it, specify an output interface and a direct next hop, or specify an indirect next hop and a specific BFD packet source address for the static route.
To configure BFD control mode for a static route (direct next hop):
Step |
Command |
Remarks |
system-view |
N/A |
2. Configure BFD control mode for a static route. |
Use either method. |
To configure BFD control mode for a static route (indirect next hop):
Step |
Command |
Remarks |
system-view |
N/A |
BFD echo mode
With BFD echo mode enabled for a static route, the local switch sends BFD echo packets to the peer, which loops it back to test the link.
Follow these guidelines when you configure BFD echo mode for static routes:
· Enabling BFD for a flapping route could worsen the situation.
· Do not use BFD for a static route with the output interface in spoofing state.
· BFD can be used for static routes with direct next hops rather than indirect next hops.
· A BFD session is established at only one end when the echo mode is used.
· For the echo and control mode, the switch does not support BFD detection on tunnel interfaces.
To configure BFD echo mode for static routes:
Step |
Command |
Remarks |
system-view |
N/A |
2. Configure the source address of echo packets. |
bfd echo-source-ip ip-address |
Not configured by default. For more information about this command, see High Availability Command Reference. |
3. Enable BFD echo mode for static routes. |
Configuring static route FRR
A link or router failure on a path can cause packet loss and even routing loop. Static route fast reroute (FRR) enables fast rerouting to minimize the impact of link or node failures.
As shown in Figure 1, upon a link failure, FRR designates a backup next hop by using a routing policy for routes matching the specified criteria. Packets are directed to the backup next hop to avoid traffic interruption.
Configuration prerequisites
Create a routing policy to be referenced by FRR and use the apply fast-reroute backup-interface command to specify a backup next hop in a routing policy. For more information about the command and routing policy configurations, see "Configuring routing policies."
Configuration guidelines
· Static route FRR takes effect only for static routes that have both the output interface and next hop specified.
· Do not use FRR and BFD at the same time.
Configuration procedure
To configure static route FRR:
Step |
Command |
Remarks |
system-view |
N/A |
1. Configure the source address of BFD echo packets. |
2. Configure static route FRR. |
ip route-static [ vpn-instance vpn-instance-name ] fast-reroute route-policy route-policy-name |
Not configured by default. |
Task |
Command |
Remarks |
Display static route information. |
display ip routing-table protocol static [ inactive | verbose ] [ | { begin | exclude | include } regular-expression ] |
Available in any view. |
Delete all static routes. |
Available in system view. |
By default, Ethernet, VLAN, and aggregate interfaces are down. Before configuring these interfaces, bring them up by using the undo shutdown command.
Network requirements
Configure static routes in Figure 2 for interconnections between any two hosts.
1. Configure IP addresses for interfaces. (Details not shown.)
2. Configure static routes:
# Configure a default route on Switch A.
[SwitchA] ip route-static 0.0.0.0 0.0.0.0 1.1.4.2
# Configure two static routes on Switch B.
[SwitchB] ip route-static 1.1.2.0 255.255.255.0 1.1.4.1
[SwitchB] ip route-static 1.1.3.0 255.255.255.0 1.1.5.6
# Configure a default route on Switch C.
[SwitchC] ip route-static 0.0.0.0 0.0.0.0 1.1.5.5
3. Configure the default gateways of host A, host B, and host C as 1.1.2.3, 1.1.6.1, and 1.1.3.1. (Details not shown.)
4. Verify the configuration:
# Display the IP routing table on Switch A.
Routing Tables: Public
Destinations : 7 Routes : 7
0.0.0.0/0 Static 60 0 1.1.4.2 Vlan500
1.1.2.0/24 Direct 0 0 1.1.2.3 Vlan300
1.1.2.3/32 Direct 0 0 127.0.0.1 InLoop0
1.1.4.0/30 Direct 0 0 1.1.4.1 Vlan500
1.1.4.1/32 Direct 0 0 127.0.0.1 InLoop0
# Display the IP routing table on Switch B.
[SwitchB] display ip routing-table
Destinations : 10 Routes : 10
1.1.2.0/24 Static 60 0 1.1.4.1 Vlan500
1.1.3.0/24 Static 60 0 1.1.5.6 Vlan600
1.1.4.0/30 Direct 0 0 1.1.4.2 Vlan500
1.1.4.2/32 Direct 0 0 127.0.0.1 InLoop0
1.1.5.0/30 Direct 0 0 1.1.5.5 Vlan600
1.1.5.5/32 Direct 0 0 127.0.0.1 InLoop0
1.1.6.0/24 Direct 0 0 1.1.6.1 Vlan100
1.1.6.1/32 Direct 0 0 127.0.0.1 InLoop0
# Use the ping command on Host B to test reachability to Host A (Windows XP runs on the two hosts).
C:\Documents and Settings\Administrator>ping 1.1.2.2
Pinging 1.1.2.2 with 32 bytes of data:
Reply from 1.1.2.2: bytes=32 time=1ms TTL=126
Ping statistics for 1.1.2.2:
# Use the tracert command on Host B to test reachability to Host A.
C:\Documents and Settings\Administrator>tracert 1.1.2.2
Tracing route to 1.1.2.2 over a maximum of 30 hops
1 <1 ms <1 ms <1 ms 1.1.6.1
2 <1 ms <1 ms <1 ms 1.1.4.1
3 1 ms <1 ms <1 ms 1.1.2.2
Trace complete.
As shown in Figure 3, configure a static route to subnet 120.1.1.0/24 on Switch A and configure a static route to subnet 121.1.1.0/24 on Switch B. Enable BFD for both routes so that when the link between Switch A and Switch B through the Layer 2 switch fails, BFD can detect the failure immediately and Switch A and Switch B can communicate through Switch C.
Device |
IP address |
Device |
IP address |
Switch A |
Vlan-int10 |
12.1.1.1/24 |
Switch B |
Vlan-int10 |
12.1.1.2/24 |
Vlan-int11 |
10.1.1.102/24 |
Vlan-int13 |
13.1.1.1/24 |
Switch C |
Vlan-int11 |
10.1.1.100/24 |
Vlan-int13 |
13.1.1.2/24 |
1. Configure IP addresses for the interfaces. (Details not shown.)
2. Configure static routes and BFD:
# Configure static routes on Switch A and enable BFD control mode for the static route that traverses the Layer 2 switch.
[SwitchA] interface vlan-interface10
[SwitchA-vlan-interface10] bfd min-transmit-interval 500
[SwitchA-vlan-interface10] bfd min-receive-interval 500
[SwitchA-vlan-interface10] bfd detect-multiplier 9
[SwitchA-vlan-interface10] quit
[SwitchA] ip route-static 120.1.1.0 24 vlan-interface 10 12.1.1.2 bfd control-packet
[SwitchA] ip route-static 120.1.1.0 24 vlan-interface 11 10.1.1.100 preference 65
[SwitchA] quit
# Configure static routes on Switch B and enable BFD control mode for the static route that traverses the Layer 2 switch.
[SwitchB] interface vlan-interface10
[SwitchB-vlan-interface10] bfd min-transmit-interval 500
[SwitchB-vlan-interface10] bfd min-receive-interval 500
[SwitchB-vlan-interface10] bfd detect-multiplier 9
[SwitchB-vlan-interface10]] quit
[SwitchB] ip route-static 121.1.1.0 24 vlan-interface 10 12.1.1.1 bfd control-packet
[SwitchB] ip route-static 121.1.1.0 24 vlan-interface 13 13.1.1.2 preference 65
[SwitchB] quit
3. Verify the configuration:
# Display BFD sessions on Switch A.
<SwitchA> display bfd session
Total Session Num: 1 Init Mode: Active
Session Working Under Ctrl Mode:
4/7 12.1.1.1 12.1.1.2 Up 2000ms Vlan10
# Display static routes on Switch A.
<SwitchA> display ip routing-table protocol static
Public Routing Table : Static
Summary Count : 2
Static Routing table Status : <Active>
Summary Count : 1
120.1.1.0/24 Static 60 0 12.1.1.2 Vlan10
Direct Routing table Status : <Inactive>
Summary Count : 1
120.1.1.0/24 Static 65 0 10.1.1.100 Vlan11
The output shows that Switch A communicates with Switch B through VLAN-interface 10. Then the link over VLAN-interface 10 fails.
# Enable BFD debugging.
<SwitchA> debugging bfd event
<SwitchA> debugging bfd scm
<SwitchA> terminal debugging
%Jul 27 10:18:18:672 2007 SwitchA BFD/4/LOG:Sess[12.1.1.1/12.1.1.2, Vlan10,Ctrl], Sta: UP->DOWN, Diag: 1
*Jul 27 10:18:18:672 2007 SwitchA BFD/7/EVENT:Send sess-down Msg, [Src:12.1.1.1,Dst:12.1.1.2, Vlan10,Ctrl], instance:0, protocol:STATIC
*Jul 27 10:18:19:172 2007 SwitchA BFD/7/EVENT:Receive Delete-sess, [Src:12.1.1.1,Dst:12.1.1.2, Vlan10,Ctrl], Direct, Instance:0x0, Proto:STATIC
*Jul 27 10:18:19:172 2007 SwitchA BFD/7/EVENT:Notify driver to stop receiving bf
The output shows that Switch A can quickly detect the failure.
# Display static routes on Switch A again.
Summary Count : 2
Summary Count : 1
Static Routing table Status : <Inactive>
Summary Count : 1
The output shows that Switch A communicates with Switch B through VLAN-interface 11.
As shown in Figure 4, Switch A has a route to interface Loopback 1 (2.2.2.9/32) on Switch B, with output interface VLAN-interface 10. Switch B has a route to interface Loopback 1 (1.1.1.9/32) on Switch A, with output interface VLAN-interface 12. Switch D has a route to 1.1.1.9/32, with output interface VLAN-interface 10, and a route to 2.2.2.9/32, with output interface VLAN-interface 12.
Configure a static route to subnet 120.1.1.0/24 on Switch A and configure a static route to subnet 121.1.1.0/24 on Switch B. Enable BFD for both routes so that when the link between Switch A and Switch B through Switch D fails, BFD can detect the failure immediately and Switch A and Switch B can communicate through Switch C.
Device |
IP address |
Device |
IP address |
Switch A |
Vlan-int10 |
12.1.1.1/24 |
Switch B |
Vlan-int12 |
11.1.1.1/24 |
Vlan-int11 |
10.1.1.102/24 |
Vlan-int13 |
13.1.1.1/24 |
Loop1 |
1.1.1.9/32 |
Loop1 |
2.2.2.9/32 |
Switch C |
Vlan-int11 |
10.1.1.100/24 |
Switch D |
Vlan-int10 |
12.1.1.2/24 |
Vlan-int13 |
13.1.1.2/24 |
Vlan-int12 |
11.1.1.2/24 |
# Configure static routes on Switch A and enable BFD control mode for the static route that traverse Switch D.
[SwitchA] interface loopback 1
[SwitchA-LoopBack1] bfd min-transmit-interval 500
[SwitchA-LoopBack1] bfd min-receive-interval 500
[SwitchA-LoopBack1] bfd detect-multiplier 9
[SwitchA-LoopBack1] quit
[SwitchA] ip route-static 120.1.1.0 24 2.2.2.9 bfd control-packet bfd-source 1.1.1.9
[SwitchA] quit
# Configure static routes on Switch B and enable BFD control mode for the static route that traverses Switch D.
[SwitchB] interface loopback 1
[SwitchB-LoopBack1] bfd min-transmit-interval 500
[SwitchB-LoopBack1] bfd min-receive-interval 500
[SwitchB-LoopBack1] bfd detect-multiplier 9
[SwitchB-LoopBack1] quit
[SwitchB] ip route-static 121.1.1.0 24 1.1.1.9 bfd control-packet bfd-source 2.2.2.9
[SwitchB] quit
Total session number: 1 Up session number: 0 Init mode: Active
IPv4 session working under Ctrl mode:
4/7 1.1.1.9 2.2.2.9 Up 2000ms Loop1
Summary Count : 2
Summary Count : 1
120.1.1.0/24 Static 60 0 2.2.2.9 Vlan10
Summary Count : 1
The output shows that Switch A and Switch B communicates through VLAN-interface 10. Then the link over VLAN-interface 10 fails.
%Oct 10 10:18:18:672 2010 SwitchA BFD/4/LOG:Sess[1.1.1.9/2.2.2.9, Loop1,Ctrl], Sta: UP->DOWN, Diag: 1
* Oct 10 10:18:18:672 2010 SwitchA BFD/7/EVENT:Send sess-down Msg, [Src:1.1.1.9,Dst:2.2.2.9, Loop1,Ctrl], instance:0, protocol:STATIC
Summary Count : 2
Summary Count : 1
Summary Count : 1
Figure 5 shows that Switch S, Switch A, and Switch D are interconnected through static routes. Configure static route FRR so that when Link A between Switch S and Switch D fails, traffic can be switched to Link B immediately.
Configure static routes on Switch S, Switch A, and Switch D so that Switch S can reach Loopback 0 on Switch D and Switch D can reach Loopback 0 on Switch S.
# Configure a static route on Switch S.
<SwitchS> system-view
[SwitchS] ip route-static 4.4.4.4 32 vlan-interface 200 13.13.13.2
# Configure a static route on Switch D.
<SwitchD> system-view
[SwitchD] ip route-static 1.1.1.1 32 vlan-interface 200 13.13.13.1
# Configure a static route on Switch A.
[SwitchA] ip route-static 4.4.4.4 32 vlan-interface 101 24.24.24.4
[SwitchA] ip route-static 1.1.1.1 32 vlan-interface 100 12.12.12.1
3. Configure static route FRR:
# Configure Switch S.
[SwitchS] bfd echo-source-ip 1.1.1.1
[SwitchS] ip ip-prefix abc index 10 permit 4.4.4.4 32
[SwitchS] route-policy frr permit node 10
[SwitchS-route-policy] if-match ip-prefix abc
[SwitchS-route-policy] apply fast-reroute backup-interface vlan-interface 100 backup-nexthop 12.12.12.2
[SwitchS-route-policy] quit
[SwitchS] ip route-static fast-reroute route-policy frr
# Configure Switch D.
[SwitchD] bfd echo-source-ip 4.4.4.4
[SwitchD] ip ip-prefix abc index 10 permit 1.1.1.1 32
[SwitchD-route-policy] if-match ip-prefix abc
[SwitchD-route-policy] apply fast-reroute backup-interface vlan-interface 101 backup-nexthop 24.24.24.2
[SwitchD-route-policy] quit
[SwitchD] ip route-static fast-reroute route-policy frr
# Display route 4.4.4.4/32 on Switch S to view the backup next hop information.
[SwitchS] display ip routing-table 4.4.4.4 verbose
Routing Table : Public
Summary Count : 2
Destination: 4.4.4.4/32
Protocol: Static Process ID: 0
Preference: 60 Cost: 0
IpPrecedence: QosLcID:
NextHop: 13.13.13.2 Interface: vlan 200
BkNextHop: 12.12.12.2 BkInterface: vlan 100
RelyNextHop: 0.0.0.0 Neighbor : 0.0.0.0
Tunnel ID: 0x0 Label: NULL
BKTunnel ID: 0x0 BKLabel: NULL
State: Active Adv Age: 00h01m27s
Tag: 0
# Display route 1.1.1.1/32 on Switch D to view the backup next hop information.
[SwitchD] display ip routing-table 1.1.1.1 verbose
Summary Count : 2
Destination: 1.1.1.1/32
NextHop: 13.13.13.1 Interface: vlan 200
BkNextHop: 24.24.24.2 BkInterface: vlan 101
Tag: 0
A default route is used to forward packets that match no entry in the routing table.
Without a default route, a packet that does not match any routing entries is discarded and an ICMP destination-unreachable packet is sent to the source.
A default route can be configured in either of the following ways:
· The network administrator can configure a default route with both destination and mask being 0.0.0.0. For more information, see Configuring a static route.
· Some dynamic routing protocols, such as OSPF, RIP, and IS-IS, can generate a default route. For example, an upstream router running OSPF can generate a default route and advertise it to other routers, which install the default route with the next hop being the upstream router. For more information, see configuration guides of relevant routing protocols.
