12-High Availability Command Reference
HomeSupportSwitchesS9500E SeriesReference GuidesCommand ReferencesH3C S9500E Command References-Release1828P04-6W18212-High Availability Command Reference
08-Monitor Link Commands
08-Monitor Link Commands 73.81 KB
Monitor Link configuration commands
display monitor-link group
display monitor-link group { group-id | all } [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
group-id: Specifies the monitor link group ID in the range of 1 to 24.
all: Displays information about all monitor link groups.
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
Use display monitor-link group to display information about the specified or all monitor link groups.
# Display information about monitor link group 1.
<Sysname> display monitor-link group 1
Monitor link group 1 information:
 Group status: DOWN
 Last-up-time: 16:37:20 2009/4/21
 Last-down-time: 16:38:26 2009/4/21
 Member                    Role     Status
 GigabitEthernet3/0/2      UPLINK   DOWN
 GigabitEthernet3/0/3      DOWNLINK DOWN
 GigabitEthernet3/0/6      DOWNLINK DOWN
Information about monitor link group 1.
Group status
Monitor link group state: up or down.
Last-up-time
Last time when the monitor link group was up.
Last-down-time
Last time when the monitor link group was down.
Member
Member ports of the monitor link group.
Role
Port role: uplink port or downlink port.
Status
Member link state: up or down.
monitor-link group
monitor-link group group-id
undo monitor-link group group-id
View
Default level
2: System level
Use monitor-link group to create a monitor link group and enter monitor link group view. If the specified monitor link group already exists, you enter monitor link group view directly.
Use undo monitor-link group to remove a monitor link group.
You cannot remove a monitor link group that contains member ports.
Related commands: port monitor-link group and port.
# Create monitor link group 1 and enter the view of monitor link group 1.
[Sysname] monitor-link group 1
[Sysname-mtlk-group1]
port
port interface-type interface-number { uplink | downlink }
undo port interface-type interface-number
View
Monitor link group view
Default level
2: System level
interface-type interface-number: Specifies a port by its type and number.
uplink: Specifies an uplink port.
downlink: Specifies a downlink port. This keyword is not supported by RPR logical interfaces.
Use port to assign a port to the monitor link group.
Use undo port to remove a port from the monitor link group.
You can assign Layer 2 Ethernet ports, Layer 2 aggregate interfaces, or RPR logical interfaces to a monitor link group as member ports. RPR logical interfaces can only be configured as uplink ports.
A port can be assigned to only one monitor link group.
Alternatively, you can assign a port to a monitor link group by using the port monitor-link group command in Layer 2 Ethernet interface view, Layer 2 aggregate interface view, or RPR logical interface view.
Related commands: port monitor-link group.
# Create monitor link group 1, and configure GigabitEthernet 4/0/1 as an uplink port and GigabitEthernet 4/0/2 as a downlink port for monitor link group 1.
[Sysname-mtlk-group1] port GigabitEthernet 4/0/1 uplink
[Sysname-mtlk-group1] port GigabitEthernet 4/0/2 downlink
port monitor-link group group-id { uplink | downlink }
undo port monitor-link group group-id
View
Layer 2 Ethernet interface view, Layer 2 aggregate interface view, RPR logical interface view
Default level
2: System level
Use port monitor-link group to assign the current port to a monitor link group as a member port.
Use undo port monitor-link group to remove the current port from a monitor link group.
·     A port can be assigned to only one monitor link group.
·     RPR logical interfaces can only be configured as uplink ports.
·     Alternatively, you can assign a port to a monitor link group with the port command in monitor link group view.
Related commands: port.
[Sysname-mtlk-group1] quit
[Sysname] interface GigabitEthernet 4/0/1
[Sysname-GigabitEthernet4/0/1] port monitor-link group 1 uplink
[Sysname] interface GigabitEthernet 4/0/2
[Sysname-GigabitEthernet4/0/2] port monitor-link group 1 downlink
