12-High Availability Command Reference
HomeSupportSwitchesS9500E SeriesReference GuidesCommand ReferencesH3C S9500E Command References-Release1828P04-6W18212-High Availability Command Reference
03-CFD Commands
03-CFD Commands 219.42 KB
CFD configuration commands
cfd ais enable
cfd ais enable
undo cfd ais enable
View
Default level
2: System level
None
Use cfd ais enable to enable AIS.
Use undo cfd ais enable to disable AIS.
By default, AIS is disabled.
# Enable AIS.
[Sysname] cfd ais enable
cfd ais level
cfd ais level level-value service-instance instance-id
undo cfd ais level level-value service-instance instance-id
View
Default level
2: System level
level level-value: Specifies the AIS frame transmission level in the range of 1 to 7.
service-instance instance-id: Specifies a service instance by its ID in the range of 1 to 32767.
Use cfd ais level to configure the AIS frame transmission level in the specified service instance.
Use undo cfd ais level to restore the default.
By default, no AIS frame transmission level is configured for a service instance.
If no AIS frame transmission level is configured for a service instance, the MEPs in the service instance cannot send AIS frames.
Regardless of the value of the level-value argument, the undo cfd ais level command restores the AIS frame transmission level to an invalid value.
# Configure the AIS frame transmission level as 3 in service instance 1.
[Sysname] cfd ais level 3 service-instance 1
cfd ais period
cfd ais period period-value service-instance instance-id
undo cfd ais period period-value service-instance instance-id
View
Default level
2: System level
period period-value: Specifies the AIS frame transmission period in the range of 1 to 60 seconds.
Use cfd ais period to configure the AIS frame transmission period in the specified service instance.
Use undo cfd ais period to restore the default.
By default, the AIS frame transmission period is 1 second in all service instances.
Regardless of the value of the period-value argument, the undo cfd ais period command restores the AIS frame transmission period to 1 second.
# Configure the AIS frame transmission period as 60 seconds in service instance 1.
[Sysname] cfd ais period 60 service-instance 1
cfd cc enable
cfd cc service-instance instance-id mep mep-id enable
undo cfd cc service-instance instance-id mep mep-id enable
View
Default level
2: System level
service-instance instance-id: Specifies the service instance ID in the range of 1 to 32767.
mep mep-id: Specifies the ID of a MEP, in the range of 1 to 8191.
Use cfd cc enable to enable CCM sending on a specified MEP.
Use undo cfd cc enable to disable CCM sending on a specified MEP.
By default, the CCM sending function is disabled.
Related commands: cfd cc interval.
# On port GigabitEthernet 3/0/1, enable CCM sending on MEP 3 in service instance 5.
[Sysname] interface GigabitEthernet3/0/1
[Sysname-GigabitEthernet3/0/1] cfd cc service-instance 5 mep 3 enable
cfd cc interval
cfd cc interval interval-value service-instance instance-id
undo cfd cc interval service-instance instance-id
View
Default level
2: System level
interval interval-value: Specifies the value of the interval field in CCM messages. The interval-value argument is in the range of 2 to 7.
Use cfd cc interval to set the value of the interval field in the CCM messages.
Use undo cfd cc interval to restore default.
By default, the value of this field is 4 for all CCMs sent.
Only the MPUs with silkscreen LSR1SRP2C1, LSR1SRP2C2, or LSR1SRP2D1 have assistant CPUs.
If the switch has two MPUs with assistant CPUs, the CCM frames will be sent by the active MPU. If the active MPU is removed, the standby MPU will take over to send CCM frames and CC will be re-performed.
If the switch has one MPU with an assistant CPU, the CCM frames will be sent by this MPU.
If the switch has no MPUs with assistant CPUs, the CCM frames will be sent by the card where the MEP is located. The card sends and receives only low-speed CCM messages, and discards high-speed CCM messages.
Table 1 Relationship between the interval field value in the CCM messages, interval for sending CCM messages, and timeout time of remote MEP
Interval field value in the CCM messages
Interval for sending CCM messages
Timeout time of remote MEP
2
10 milliseconds
35 milliseconds
3
100 milliseconds
350 milliseconds
4
1 second
3.5 seconds
5
10 seconds
35 seconds
6
60 seconds
210 seconds
7
600 seconds
2100 seconds
Related commands: cfd cc enable.
# Set the value of the interval field in CCMs sent by MEPs in service instance 2 to 7.
[Sysname] cfd cc interval 7 service-instance 2
cfd enable
cfd enable
undo cfd enable
View
Default level
2: System level
None
Use cfd enable to enable CFD.
Use undo cfd enable to disable CFD.
By default, CFD is disabled.
# Enable CFD.
[Sysname] cfd enable
cfd linktrace
cfd linktrace service-instance instance-id mep mep-id { target-mep target-mep-id | target-mac mac-address } [ ttl ttl-value ] [ hw-only ]
View
Default level
0: Visit level
mep mep-id: Specifies the ID of the source MEP, in the range of 1 to 8191.
target-map target-mep-id: Specifies the ID of the destination MEP, in the range of 1 to 8191.
target-mac mac-address: Specifies the destination MAC address, in the format of H-H-H.
ttl ttl-value: Specifies the time to live value in the range of 1 to 255. The default is 64.
hw-only: Sets the hw-only bits of the LTMs sent. When this keyword is specified and the MIP that receives LTMs cannot find the destination MAC address in its forwarding table, the MIP does not broadcast these LTM messages. Otherwise, the MIP broadcasts these LTM messages.
Use cfd linktrace to find the path between the source and target MEPs, which is achieved through the transmission of LTMs between the two and detection of the responding LTRs.
Related commands: cfd linktrace auto-detection.
# Identify the path between source MEP 1101 and target MEP 2001 in service instance 1 when the standard version (IEEE 802.1ag) of CFD is used.
[Sysname] cfd version standard
[Sysname] cfd linktrace service-instance 1 mep 1101 target-mep 2001
Linktrace to MEP 2001 with the sequence number 1101-43361
MAC Address               TTL     Last MAC         Relay Action
0010-FC00-6512            63      0010-FC00-6500   Hit
# Identify the path between source MEP 1101 and target MEP 2001 in service instance 1 when the IEEE 802.1ag draft 5.2 version of CFD is used.
[Sysname] cfd version draft5
Linktrace to MEP 2001 with the sequence number 1101-43361 :
MAC Address               TTL     Forwarded         Relay Action
0010-FC00-6512            63      No                None
# Identify the path between source MEP 1101 and target MEP 2001 in service instance 1 when the IEEE 802.1ag draft 5.2 interim version of CFD is used.
[Sysname] cfd version draft5-plus
The output varies by CFD protocol version.
Linktrace to target MEP 2001 with the sequence number 1101-43361.
MAC Address
Source MAC address in the LTR messages.
TTL
Hop count when the LTM passes the device.
Last MAC
MAC address of the last-hop device the LTM passes.
Forwarded
Indicates whether the device forwards LTMs:
·     Yes means that the current device forwards LTMs.
·     No means that the current device does not forward LTMs.
Relay Action
Indicates whether the forwarding device found the destination MAC address in its MAC address table.
When the standard version (IEEE 802.1ag) of CFD is used:
·     HitThe current device is the destination device.
·     FDBThe forwarding device found the destination MAC address.
·     MPDBThe destination MAC address is not found, or the destination MAC address is found in the MEP or MIP database.
When the IEEE 802.1ag draft5.2 version or the IEEE 802.1ag draft 5.2 interim version of CFD is used:
·     FoundThe forwarding device found the destination MAC address.
·     UnknownThe forwarding device failed to find the destination MAC address.
·     NoneIt is a MEP that responded to the LTM message. A MEP does not need to find the destination MAC address.
cfd linktrace auto-detection [ size size-value ]
undo cfd linktrace auto-detection
View
Default level
2: System level
size size-value: Specifies the size of the buffer used to store the auto-detection result, in the range of 1 to 100 (in terms of sending times).
This value defaults to 5, which means the buffer stores the results of the recent five auto-detections.
Use cfd linktrace auto-detection to enable the auto sending of linktrace messages.
Use undo cfd linktrace auto-detection to disable this function.
By default, this function is disabled.
After LT messages automatic sending is enabled, if the source MEP fails to receive the CCMs from the target MEP within 3.5 times the sending interval, the link between the two is regarded as faulty and LTMs will be sent out. (The destination of the LTMs is the target MEP, and the TTL field value is 255.) Based on the LTRs that echo back, the fault source can be located.
Once you disable LT messages automatic sending, the content stored in the buffer will be removed.
Related commands: cfd linktrace.
# Enable automatic LT messages sending, and specify the size of the buffer used to store the auto-detection result to 100 (in terms of sending times).
[Sysname] cfd linktrace auto-detection size 100
cfd loopback
cfd loopback service-instance instance-id mep mep-id { target-mep target-mep-id | target-mac mac-address } [ number number ]
View
Default level
0: Visit level
target-mep target-mep-id: Specifies the ID of the target MEP, in the range of 1 to 8191.
target-mac mac-address: Specifies the destination MAC address of the MP, in the format of H-H-H.
number number: Specifies the number of the LBMs packets sent, in the range of 1 to 10. The default is 5.
Use cfd loopback to enable LB function so that LBMs can be sent from the source MEP to the target MP, and LBR messages can be received.
By default, LB is not enabled.
# Enable LB to check the status of the link between MEP 1101 and MEP 2001 in service instance 1 (assume that the link status is normal).
<Sysname> cfd loopback service-instance 1 mep 1101 target-mep 2001
Loopback to 0010-FC00-6512 with the sequence number start from 1101-43404:
Reply from 0010-FC00-6512: sequence number=1101-43404 time=5ms
Reply from 0010-FC00-6512: sequence number=1101-43405 time=5ms
Reply from 0010-FC00-6512: sequence number=1101-43406 time=5ms
Reply from 0010-FC00-6512: sequence number=1101-43407 time=5ms
Reply from 0010-FC00-6512: sequence number=1101-43408 time=5ms
Send:5        Received:5        Lost:0
# Enable LB to check the status of the link between MEP 1101 and MEP 2001 in service instance 1 (assume that the link status is abnormal).
Sequence number=1101-43404: Request timed out
Send:5        Received:0        Lost:5
Sends LBMs to 0010-FC00-6512 with the sequence number starting with 1101-43404.
sequence number
Sequence number in the LBR messages.
time=5ms
The interval between the sending of LBMs and receiving of LBRs is 5 milliseconds.
Request timed out
The request is timed out because no LBR is received within 5 milliseconds.
Send
Number of LBMs sent.
Received
Number of LBR messages received.
Lost
Number of lost LBRs.
cfd ma
cfd ma ma-name md md-name vlan vlan-id
undo cfd ma ma-name md md-name
View
Default level
2: System level
ma ma-name: Specifies the name of the MA, which is a string of 1 to 43 characters. IEEE 802.1ag standard version allows an MA name to contain letters, numbers, and special characters (including ~ ! @ # $ % ^ & * ( ) - _ + = { } [ ] | \ : ; " ' < > , . /). IEEE 802.1ag draft5.2 version and IEEE 802.1ag draft5.2 interim version allow an MA name to contain letters, numbers, and special characters (including – and _), but do not allow an MA name to start or end with a special character.
md md-name: Specifies the name of an MD, a string of 1 to 43 characters. IEEE 802.1ag standard version allows an MD name to contain letters, numbers, and special characters (including ~ ! @ # $ % ^ & * ( ) - _ + = { } [ ] | \ : ; " ' < > , . /). IEEE 802.1ag draft5.2 version and IEEE 802.1ag draft5.2 interim version allow an MD name to contain letters, numbers, and special characters (including – and _), but do not allow an MD name to start or end with a special character.
vlan vlan-id: Specifies the ID of the VLAN where MA is in service, in the range of 1 to 4094.
Use cfd ma to create MAs in an MD.
Use undo cfd ma to delete MAs in an MD.
By default, no MA is created.
Before creating an MA, you must create an MD first.
The total length of the MA and MD names should not exceed 44 characters.
When deleting an MA, you will also delete the configurations related to that MA.
Related commands: cfd md.
# Create an MA named test_ma in an MD named test_md, and configure the MA to serve VLAN 100.
[Sysname] cfd md test_md level 3
[Sysname] cfd ma test_ma md test_md vlan 100
cfd md
cfd md md-name level level-value
undo cfd md md-name
View
Default level
2: System level
md md-name: Specifies the name of an MD, which is a string of 1 to 43 characters. IEEE 802.1ag standard version allows an MD name to contain letters, numbers, and special characters (including ~ ! @ # $ % ^ & * ( ) - _ + = { } [ ] | \ : ; " ' < > , . /). IEEE 802.1ag draft5.2 version and IEEE 802.1ag draft5.2 interim version allow an MD name to contain letters, numbers, and special characters (including – and _), but do not allow an MD name to start or end with a special character.
level level-value: Specifies an MD level in the range of 0 to 7.
Use cfd md to create an MD.
Use undo cfd md to delete an MD.
By default, no MD is created.
You can create only one MD with a specific level. MD cannot be created if you enter an invalid MD name or an existing MD name.
When deleting an MD, you will also delete the configurations related to that MD.
# Create an MD named test_md, with its level being 3.
cfd mep
cfd mep mep-id service-instance instance-id { inbound | outbound }
undo cfd mep mep-id service-instance instance-id
View
Default level
2: System level
inbound: Creates an inward-facing MEP.
outbound: Creates an outward-facing MEP.
Use cfd mep to create a MEP on a port.
Use undo cfd mep to delete the specified MEP.
By default, no MEP exists on a port.
In creating a MEP, the service instance you specified defines the MD and MA that the MEP belongs to.
You cannot create a MEP if the MEP ID is not included in the MEP list of the relevant service instance.
Related commands: cfd meplist.
# Configure a MEP list in service instance 5, and create and enable inward-facing MEP 3 in service instance 5 on GigabitEthernet 3/0/1.
[Sysname] cfd service-instance 5 md test_md ma test_ma
[Sysname] cfd meplist 3 service-instance 5
[Sysname-GigabitEthernet3/0/1] cfd mep 3 service-instance 5 inbound
cfd mep enable
cfd mep service-instance instance-id mep mep-id enable
undo cfd mep service-instance instance-id mep mep-id enable
View
Default level
2: System level
Use cfd mep enable to enable the MEP configured on a port.
Use undo cfd mep enable to disable the MEP.
By default, MEP is disabled on a port and cannot respond to various CFD frames (such as LTM frames, LBM frames, 1DM frames, DMM frames, and TST frames) unless you enable it.
Related commands: cfd mep.
# Enable MEP 3 in service instance 5 on GigabitEthernet 3/0/1.
[Sysname-GigabitEthernet3/0/1] cfd mep service-instance 5 mep 3 enable
cfd meplist
cfd meplist mep-list service-instance instance-id
undo cfd meplist mep-list service-instance instance-id
View
Default level
2: System level
meplist mep-list: Specifies a list of MEP IDs, indicating multiple MEPs, in the format of mep-list = { mep-id [ to mep-id ] }&<1-10>, in which mep-id represents the MEP ID in the range of 1 to 8191. &<1-10> indicates you can specify up to 10 MEP ID ranges.
Use cfd meplist to create a MEP list, which is a collection of local MEPs allowed to be configured and the remote MEPs to be monitored in the same MA.
Use undo cfd meplist to delete existing MEP lists.
By default, no MEP list is created.
Before creating a MEP list, create the relevant MD, MA, and service instance.
After you delete a MEP list, all local MEP configurations based on this list are deleted.
Related commands: cfd ma, cfd md, and cfd service-instance.
# Create a MEP list that includes MEP 9 through MEP 15 in service instance 5.
[Sysname] cfd meplist 9 to 15 service-instance 5
cfd mip-rule
cfd mip-rule { explicit | default } service-instance instance-id
undo cfd mip-rule service-instance instance-id
View
Default level
2: System level
explicit: This rule means that if the lower level MA is not configured with MIPs, whether the current MA will create MIPs depends on whether the lower level MA is configured with MEPs.
default: This rule means that if the lower level MA is not configured with MIPs, the current MA will create MIPs.
Use cfd mip-rule to configure the rules for generating MIPs. MIPs are generated on each port automatically according to the rules configured.
Use undo cfd mip-rule to delete the rule for generating MIPs.
By default, no rules for generating MIPs are configured and no MIPs exist.
# Configure the MIP generation rule as default in service instance 5.
[Sysname] cfd mip-rule default service-instance 5
cfd service-instance instance-id md md-name ma ma-name
undo cfd service-instance instance-id
View
Default level
2: System level
md md-name: Specifies the name of an MD. The md-name argument is a string of 1 to 43 characters. IEEE 802.1ag standard version allows an MD name to contain letters, numbers, and special characters (including ~ ! @ # $ % ^ & * ( ) - _ + = { } [ ] | \ : ; " ' < > , . /). IEEE 802.1ag draft5.2 version and IEEE 802.1ag draft5.2 interim version allow an MD name to contain letters, numbers, and special characters (including – and _), but do not allow an MD name to start or end with a special character.
ma ma-name: Specifies the name of an MA. The ma-name argument is a string of 1 to 43 characters. IEEE 802.1ag standard version allows an MA name to contain letters, numbers, and special characters (including ~ ! @ # $ % ^ & * ( ) - _ + = { } [ ] | \ : ; " ' < > , . /). IEEE 802.1ag draft5.2 version and IEEE 802.1ag draft5.2 interim version allow an MA name to contain letters, numbers, and special characters (including – and _), but do not allow an MA name to start or end with a special character.
Use cfd service-instance to create a service instance with the MD name.
Use undo cfd service-instance to delete a service instance.
By default, no service instance is created.
You must create the relevant MD and MA prior to creating a service instance with the MD name.
The service instance ID uniquely identifies an MA in an MD.
When deleting a service instance, you are deleting the configurations related to that service instance as well.
Deleting a service instance simply breaks up the connection between the service instance and the relevant MA, the MA itself is not deleted.
A service instance with the MD name takes effect in all versions of CFD.
Related commands: cfd md, cfd ma, and cfd version.
# Create a level-3 MD named test_md, create an MA named test_ma, which serves VLAN 100, in test_md, and then create service instance 5 with the MD name for test_md and test_ma.
cfd service-instance maid format
cfd service-instance instance-id maid format { icc-based ma-name | string ma-name } level level-value vlan vlan-id
View
Default level
2: System level
icc-based ma-name: MA name in the Y.1731 format. The ma-name argument is a string of 1 to 13 characters. IEEE 802.1ag standard version allows an MA name to contain letters, numbers, and special characters (including ~ ! @ # $ % ^ & * ( ) - _ + = { } [ ] | \ : ; " ' < > , . /). IEEE 802.1ag draft5.2 version and IEEE 802.1ag draft5.2 interim version allow an MA name to contain letters, numbers, and special characters (including – and _), but do not allow an MA name to start or end with a special character.
string ma-name: MA name in the IEEE 802.1ag format. The ma-name argument is a string of 1 to 45 characters. IEEE 802.1ag standard version allows an MA name to contain letters, numbers, and special characters (including ~ ! @ # $ % ^ & * ( ) - _ + = { } [ ] | \ : ; " ' < > , . /). IEEE 802.1ag draft5.2 version and IEEE 802.1ag draft5.2 interim version allow an MA name to contain letters, numbers, and special characters (including – and _), but do not allow an MA name to start or end with a special character.
level level-value: Specifies the MD level for the service instance, in the range of 0 to 7.
vlan vlan-id: Specifies the VLAN for the service instance. The vlan-id argument is in the range of 1 to 4094.
Use cfd service-instance maid format to create a service instance without the MD name.
Use undo cfd service-instance to remove the specified service instance.
When you create a service instance without the MD name, the system automatically creates the MA and MD for the service instance.
The service instance ID, MA name, and MD level uniquely identify a MA.
Deleting a service instance also deletes all configurations based on the service instance.
Deleting a service instance removes not only the service instance ID-MA association, but also the MA.
A MD with no MAs will be deleted.
A service instance without the MD name takes effect only in the IEEE 802.1ag standard version of CFD.
Related commands: cfd version.
# Create service instance 5 without the MD name in CFD IEEE 802.1ag, and configure the MA named test_ma1 in the Y.1731 format, MD level 3, and VLAN 100 for the service instance.
[Sysname] cfd service-instance 5 maid format icc-based test_ma1 level 3 vlan 100
# Create service instance 6 without the MD name in CFD IEEE 802.1ag, and configure the MA named test_ma2 in the IEEE 802.1ag format, MD level 4, and VLAN 200 for the service instance.
[Sysname] cfd service-instance 6 maid format string test_ma2 level 4 vlan 200
cfd tst
cfd tst service-instance instance-id mep mep-id { target-mac mac-address | target-mep target-mep-id } [ number number ] [ length-of-test length ] [ pattern-of-test { all-zero | prbs } [ with-crc ] ]
View
Default level
2: System level
mep mep-id: Specifies the source MEP by its ID, in the range of 1 to 8191.
target-mac mac-address: Specifies the target MEP by its MAC address, which is in the format of H-H-H.
target-mep target-mep-id: Specifies the target MEP by its ID in the range of 1 to 8191.
number number: Specifies the number of TST frames sent. The number argument is in the range of 1 to 10, and defaults to 5.
length-of-test length: Specifies the length of the Test TLV (Type/Length/Value) in the TST frame. The value range for the length argument is 4 to 1400, and the default is 64.
pattern-of-test { all-zero | prbs } [ with-crc ]: Specifies the pattern of the Test TLV in the TST frame, which can be all-zero (all-zero value without CRC-32), prbs (pseudo random bit sequence without CRC-32), all-zero with-crc (all-zero value with CRC-32), and prbs with-crc (pseudo random bit sequence with CRC-32). The default mode is all-zero.
Use cfd tst to enable the TST function. The TST function detects the bit errors between two MEPs by sending TST frames from the source MEP to the target MEP.
By default, the TST function is disabled.
The TST function takes effect only in CFD IEEE 802.1ag.
To view the TST test result, use the display cfd tst command on the target MEP.
Related commands: cfd version and display cfd tst.
# Enable the TST function in CFD IEEE 802.1ag to test the bit errors between source MEP 1101 and destination MEP 1003 in service instance 1.
[Sysname] cfd tst service-instance 1 mep 1101 target-mep 1003
Info: TST process is done. Please check the result on the remote device.
TST process is done
The TST test has been performed.
cfd version
cfd version { draft5 | draft5-plus | standard }
undo cfd version
View
Default level
2: System level
draft5: Specifies that IEEE 802.1ag draft5.2 be used.
draft5-plus: Specifies that the IEEE 802.1ag draft5.2 interim version be used.
standard: Specifies that the standard version of IEEE 802.1ag be used.
Use cfd version to configure the CFD protocol version.
Use undo cfd version to restore the default.
By default, CFD uses the standard version of IEEE 802.1ag.
If an MD is created by using the cfd md command or automatically generated by using the cfd service-instance maid format command on a device, you cannot switch between the standard version and draft5.2 version (or draft5.2 interim version); however, you can switch between the draft5.2 version and draft5.2 interim version. This restriction does not apply to the device without an MD configured.
Related commands: cfd md and cfd service-instance maid format.
# Configure the CFD protocol version as IEEE 802.1ag draft5.2.
display cfd ais
display cfd ais [ service-instance instance-id [ mep mep-id ] ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
mep mep-id: Specifies the MEP by its ID in the range of 1 to 8191.
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
Use display cfd ais to display the AIS configuration and information on the specified MEP.
If no MEP is specified, the display cfd ais command displays the AIS configuration and information of all MEPs in the specified service instance.
If no service instance is specified, the display cfd ais command displays the AIS configuration and information of all MEPs in all service instances.
Related commands: cfd ais enable, cfd ais level, and cfd ais period.
# Display the AIS configuration and information of all the MEPs in all service instances.
<Sysname> display cfd ais
Service instance: 5
AIS level: 4    AIS period: 1s
MEP ID: 1
AIS condition: yes   Time to enter the condition: 2009/05/22 10:43:57
AIS state machine: Prestate: NO_RECEIVE
                   Curstate: RECEIVE
MEP ID: 2
                   Curstate: RECEIVE
Service instance: 20
AIS level: 3    AIS period: 60s
MEP ID: 10
                   Curstate: RECEIVE
Service instance: 100
AIS level: 6    AIS period: 1s
MEP ID: 20
AIS condition: no    Time to enter the condition: 2009/05/22 11:40:01
AIS state machine: Prestate: IDLE
                   Curstate: NO_RECEIVE
Table 5 Command output
Service instance
Service instance of the MEP.
AIS level
AIS frame transmission level.
AIS period
AIS frame transmission period.
AIS condition
AIS status:
·     yesAIS is running.
·     noAIS is not running.
The time when the AIS status began.
AIS state machine
AIS packet receiving state machine.
Prestate
Previous state:
·     IDLENot activated.
·     NO_RECEIVEActivated.
·     RECEIVEAIS frames are received.
Curstate
Current state:
display cfd linktrace-reply
display cfd linktrace-reply [ service-instance instance-id [ mep mep-id ] ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use display cfd linktrace-reply to display the LTR information received by a MEP.
If this command is used without specifying MEP, the information of LTRs of all MEPs in the current service instance is displayed.
If this command is used without specifying any service instance, the information of LTRs of all MEPs is displayed.
# Display the LTR information saved on all the MEPs in every service instance when the standard version (IEEE 802.1ag) of CFD is used.
[Sysname] display cfd linktrace-reply
Service instance: 1       MEP ID: 1003
0000-FC00-6505            63      0000-FC00-6504    MPDB
000F-E269-A852            62      0000-FC00-6505    FDB
0000-FC00-6508            61      000F-E269-A852    Hit
Service instance: 2       MEP ID: 1023
# Display the LTR information saved on all the MEPs in every service instance when the IEEE 802.1ag draft5.2 version of CFD is used.
00E0-FC27-6502            63      Yes               Found
00E0-FC00-6510            62      Yes               Found
00E0-FC52-BAA0            61      No                None
00E0-FC27-6502            63      No                None
# Display the LTR information saved on all the MEPs in every service instance when the IEEE 802.1ag draft5.2 interim version of CFD is used.
Table 6 Command output
Service instance
Service instance to which the MEPs that send LTMs belong.
MEP ID
ID of the MEP that sends LTMs.
MAC Address
Source MAC address in the LTR message.
TTL
Hop count when LTM passes the device.
Last MAC
Forwarded
·     Yes means that the device has forwarded the LTMs.
·     No means that the device did not forward the LTMs.
Relay Action
When the IEEE 802.1ag draft5.2 version or the IEEE 802.1ag draft5.2 interim version of CFD is used:
·     FoundThe forwarding device found the destination MAC address in its MAC address table.
·     UnknownThe forwarding device failed to find the destination MAC address in its MAC address table.
display cfd linktrace-reply auto-detection
display cfd linktrace-reply auto-detection [ size size-value ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
size size-value: Specifies the times of recent auto-detections, in the range of 1 to 100.
Use display cfd linktrace-reply auto-detection to display the content of the LTR messages received as responses to the automatically sent LTMs.
These LTR messages received as responses to automatically sent LTMs are stored in the buffer after you executed the cfd linktrace auto-detection command.
With the size keyword not specified, this command displays the information of all LTRs stored in the buffer.
# Display the contents of the LTRs received as responses to the LTMs automatically sent when the standard version (IEEE 802.1ag) of CFD is used.
[Sysname] display cfd linktrace-reply auto-detection
Service instance: 1       MEP ID: 1003    Time: 2006/05/22 10:43:57
Target MEP ID: 2005       TTL: 64
Service instance: 2       MEP ID: 1023    Time: 2006/05/22 10:44:06
Target MEP ID: 2025       TTL: 64
# Display the contents of the LTRs received as responses to the LTMs automatically sent when the IEEE 802.1ag draft5.2 version of CFD is used.
# Display the contents of the LTRs received as responses to the LTMs automatically sent when the IEEE 802.1ag draft5.2 interim version of CFD is used.
Table 7 Command output
Service instance
Service instance to which the MEPs that sent LTM messages belong.
MEP ID
Time
Time of the LTMs automatically sent.
Target MEP ID
ID of the target MEP.
TTL
Initial hop count of the automatically sent LTMs.
MAC Address
TTL
Last MAC
Forwarded
Relay Action
display cfd ma
display cfd ma [ [ ma-name ] md { md-name | level level-value } ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
ma-name: Name of MA, a character string of 1 to 43 characters. IEEE 802.1ag standard version allows an MA name to contain letters, numbers, and special characters (including ~ ! @ # $ % ^ & * ( ) - _ + = { } [ ] | \ : ; " ' < > , . /). IEEE 802.1ag draft5.2 version and IEEE 802.1ag draft5.2 interim version allow an MA name to contain letters, numbers, and special characters (including – and _), but do not allow an MA name to start or end with a special character.
md-name: Name of an MD, a character string of 1 to 43 characters. IEEE 802.1ag standard version allows an MD name to contain letters, numbers, and special characters (including ~ ! @ # $ % ^ & * ( ) - _ + = { } [ ] | \ : ; " ' < > , . /). IEEE 802.1ag draft5.2 version and IEEE 802.1ag draft5.2 interim version allow an MD name to contain letters, numbers, and special characters (including – and _), but do not allow an MD name to start or end with a special character.
level level-value: Specifies the MD level in the range of 0 to 7.
Use display cfd ma to display the configuration of a specified MA.
If MD is not specified, this command will display the MA configurations of all MDs on the device.
If both MD and MA are specified, this command will display the specified MA configuration.
If only MD is specified, this command will display the configurations of all MAs in that MD.
If a MD does not have a name, you can specify it only by the MD level.
# Display the MA configuration information in all MDs.
<Sysname> display cfd ma
3 maintenance domain(s) configured.
Maintenance domain: mdtest_5
1 maintenance association(s) belong(s) to this maintenance domain:
Maintenance association: matest_5
Service instance: 5          VLAN: 5          Level: 5
Maintenance domain: mdtest_6
Maintenance association: matest_6
Service instance: 6          VLAN: 6          Level: 6
Maintenance domain: (Without Name)
Maintenance association: matest_7
Service instance: 7          VLAN: 7          Level: 7
Table 8 Command output
Number of MDs configured.
Maintenance domain
Name of the MD. (If the MD does not have a name, this field is displayed as Without Name.)
Level
MD level.
Number of MAs configured in the MD.
Name of the MA.
Service instance
Service instance of the MA.
VLAN
VLAN to which the service instance belongs.
Level
Level of the MD to which the MA belongs.
display cfd md
display cfd md [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use display cfd md to display the MD configuration information.
# Display the MD configuration information.
<Sysname> display cfd md
CFD is enabled.
8 maintenance domain(s) configured:
Level: 0     Maintenance domain: mdtest_0
Level: 1     Maintenance domain: mdtest_1
Level: 2     Maintenance domain: mdtest_2
Level: 3     Maintenance domain: mdtest_3
Level: 4     Maintenance domain: mdtest_4
Level: 5     Maintenance domain: mdtest_5
Level: 6     Maintenance domain: mdtest_6
Level: 7     Maintenance domain: (Without Name)
Table 9 Command output
Level
Level of MD, each level allows only one MD.
Maintenance domain
Name of MD. (If the MD does not have a name, this field is displayed as Without Name.)
display cfd mep
display cfd mep mep-id service-instance instance-id [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
mep mep-id: Specifies a MEP by its ID in the range of 1 to 8191.
Use display cfd mep to display the attribute and operating information of a MEP.
# Display the attribute and operating information of MEP 50 in service instance 1.
<Sysname> display cfd mep 50 service-instance 1
Interface: GigabitEthernet3/0/2
Maintenance association: matest_1
Level: 1        VLAN: 1         Direction: Outbound
Administrative state: Active          CCM send: Enable
FNG state: FNG_DEFECT_REPORTED
CCM:
Current state: CCI_WAITING
Interval: 1s       SendCCM: 12018
Loopback:
NextSeqNumber: 8877
SendLBR: 0          ReceiveInOrderLBR: 0          ReceiveOutOrderLBR: 0
Linktrace:
NextSeqNumber: 8877
SendLTR: 0          ReceiveLTM: 0
No CCM from some remote MEPs is received.
One or more streams of error CCMs is received. The last-received CCM:
Maintenance association:matest1
MEP:5      Sequence Number:0x50A
Received Time: 02/3/6 13:01:34
One or more streams of cross-connect CCMs is received. The last-received CCM:
Maintenance domain:mdtest1
MEP:6      Sequence Number:0x63A
Some other MEPs are transmitting the RDI bit.
Table 10 Command output
Interface that an MD belongs to.
Maintenance domain
MD that a MEP belongs to. (If the MD does not have a name, this field is displayed as Without Name.)
MA that a MEP belongs to.
Level
Level of the MD.
VLAN
VLAN that the MA belongs to.
Direction
Direction of the MEPs.
State of MEP, either Active or Inactive.
CCM send
Whether the MEP sends CCM.
FNG state
State of FNG (Fault Notification Generator):
·     FNG_RESET.
·     FNG_DEFECT.
·     FNG_REPORT_DEFECT.
·     FNG_DEFECT_REPORTED.
·     FNG_DEFECT_CLEARING.
If this field is not supported, a hyphen (-) is displayed.
CCM
Information related to CCM.
Current state
State of CCMs sent:
·     CCI_IDLE.
·     CCI_WAITING.
Interval
Interval to send CCM.
SendCCM
Number of CCMs that have been sent by the MEPs.
Loopback
Information related to Loopback.
NextSeqNumber
Sequence number of the next LBM to be sent.
SendLBR
Number of LBRs that have been sent. If the MEP is inward-facing, the number of LBRs will not be counted.
ReceiveInOrderLBR
Number of LBR messages received in correct sequence.
ReceiveOutOrderLBR
Number of LBR messages received out of order.
Linktrace
Information related to linktrace.
NextSeqNumber
Sequence number of the next LTM to be sent.
SendLTR
Number of LTRs sent. If the MEP is inward-facing, the number of LTRs will not be counted.
ReceiveLTM
Number of LTMs received.
Failure to receive CCMs from some remote MEPs (This information is displayed only when some CCMs are lost.)
Display the content of the last error CCM when one or more error CCMs are received. (This information is displayed only when error CCMs are received.)
Maintenance domain
MD of the last error CCM message.
MA of the last error CCM message.
MEP
ID of the MEP that sent the last error CCM message.
Sequence Number
Sequence number of the last error CCM.
Received Time
Time when the last error CCM is received.
Cross-connect CCMs are received, and the content of the last cross-connect CCM is displayed. (This information is displayed only when cross-connect CCMs are received.)
CCMs with the RDI flag bits set are received from other MEPs. (This information is displayed only when this type of CCMs are received.)
display cfd meplist
display cfd meplist [ service-instance instance-id ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use display cfd meplist to display the MEP list in a service instance.
If the service instance ID is not specified, this command displays MEP lists in all service instances.
# Display the MEP list in service instance 5.
<Sysname> display cfd meplist service-instance 5
Service instance: 5
MEP list: 1 to 20, 30, 50.
display cfd mp
display cfd mp [ interface interface-type interface-number ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
interface interface-type interface-number: Displays the MP information on a port specified by its port type and port number.
Use display cfd mp to display the MP information.
If no port is specified, this command displays the MP information on all ports.
The output is arranged by port name, then in the ascending VLAN ID order on the same port, and in the order of outward-facing MEPs (from low to high level), MIPs, and inward-facing MEPs (from high to low level) within the same VLAN.
# Display the MP information on all ports.
<Sysname> display cfd mp
Interface GigabitEthernet3/0/1   VLAN 100
MEP ID: 100      Level: 0    Service instance: 100    Direction: Outbound
Maintenance domain: mdtest0
Maintenance association: mainmd0
MEP ID: 105      Level: 5    Service instance: 105    Direction: Outbound
Maintenance domain: mdtest5
Maintenance association: mainmd5
MIP              Level: 6    Service instance: 106
Maintenance domain: mdtest6
Maintenance association: mainmd6
MEP ID: 104      Level: 4    Service instance: 104    Direction: Inbound
Maintenance domain: mdtest4
Maintenance association: mainmd4
MEP ID: 102      Level: 2    Service instance: 102    Direction: Inbound
Maintenance domain: mdtest2
Maintenance association: mainmd2
Interface GigabitEthernet3/0/4   VLAN 1
MEP ID: 9        Level: 6    Service instance: 6      Direction: Outbound
Maintenance association: matest6
Table 11 Command output
MP configuration of the specified VLAN on the specified port.
MEP ID
ID of the MEP.
MIP
A MIP in the MP.
Level
MD level that an MP belongs to.
Service instance
Service instance to which the MP belongs.
Direction
Direction of the MEP.
Maintenance domain
MD to which an MP belongs.
MA to which an MP belongs.
display cfd remote-mep
display cfd remote-mep service-instance instance-id mep mep-id [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
mep mep-id: Specifies the ID of a remote MEP, in the range of 1 to 8191.
Use display cfd remote-mep to display the information of a remote MEP.
# Display the information of remote MEP 10 in service instance 4.
<Sysname> display cfd remote-mep service-instance 4 mep 10
MEP ID   MAC Address      State        Time                  MAC Status
20       00E0-FC00-6565   OK           2006/03/06 02:36:38   UP
30       00E0-FC27-6502   OK           2006/03/06 02:36:38   DOWN
40       00E0-FC00-6510   FAILED       2006/03/06 02:36:39   DOWN
50       00E0-FC52-BAA0   OK           2006/03/06 02:36:44   DOWN
60       0010-FC00-6502   OK           2006/03/06 02:36:42   DOWN
Table 12 Command output
MEP ID
ID of the remote MED.
MAC Address
MAC address of the remote MEP device.
Running state of the remote MEP: OK or FAILED.
Time
Time when the remote MEP entered the FAILED or OK state for the last time.
MAC Status
State of the port indicated by the last CCM received from the remote MEP: UP or DOWN.
display cfd service-instance
display cfd service-instance [ instance-id ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use display cfd service-instance to display the configuration information of service instance.
Without specifying the service instance ID, the command will display the configuration information of all service instances.
# Display the configuration information of all service instances.
<Sysname> display cfd service-instance
2 service instance(s) configured:
Service instance 5:
Level: 5        VLAN: 5        MIP rule: None         CCM interval: 1s
Service instance 6:
Level: 6        VLAN: 6        MIP rule: None         CCM interval: 1s
MEP ID: 730     Interface: GigabitEthernet3/0/1                Direction: Inbound
Service instance 6:
MEP ID: 731     Interface: GigabitEthernet3/0/2                Direction: Outbound
Table 13 Command output
2 service instance(s) are configured.
Number of service instance configured.
Service instance 5
Service instance ID.
Maintenance domain
MD of the service instance. (If the MD does not have a name, this field is displayed as Without Name.)
MA of the service instances.
Level
MD level.
VLAN
MIP rule
MIP generation rules configured on service instance.
CCM interval
Interval to send CCMs.
MEP ID
ID of MEPs configured on the service instance.
Interface of the MEP configured on the service instance.
Direction
Direction of the MEPs configured on the service instance.
display cfd status
display cfd status [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use display cfd status to display the status of CFD and AIS (enabled or disabled).
# Display the status of CFD and AIS.
<Sysname> display cfd status
CFD is enabled.
AIS is disabled.
display cfd tst
display cfd tst [ service-instance instance-id [ mep mep-id ] ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use display cfd tst to display the TST result on the specified MEP.
If no MEP is specified, the display cfd tst command displays the TST results of all MEPs in the specified service instance.
If no service instance is specified, the display cfd tst command displays the TST results of all MEPs in all service instances.
Related commands: cfd tst.
# Display the TST results of all the MEPs in all service instances.
<Sysname> display cfd tst
Service instance: 1
MEP ID: 1003
Send TST total number: 0
Received TST total number: 5
Received from 0010-FC00-6510, sequence number 1: Bit True
Received from 0010-FC00-6510, sequence number 2: Bit True
Received from 0010-FC00-6510, sequence number 3: Bit True
Received from 0010-FC00-6510, sequence number 4: Bit True
Received from 0010-FC00-6510, sequence number 5: Bit True
MEP ID: 1004
Send TST total number: 5
Received TST total number: 0
Service instance: 2
No mep exists in the service instance.
Service instance: 3
MEP ID: 1023
Table 14 Command output
Service instance
Number of TST frames sent.
Number of TST frames received.
Received from 0010-FC00-6510, sequence number 01
TST frame with sequence number 01 received from the MEP with MAC address 0010-FC00-6510:
·     Bit TrueNo bit error occurred.
·     Bit FalseBit errors occurred.
display cfd version
display cfd version [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use display cfd version to display the CFD protocol version.
# Display the CFD protocol version.
<Sysname> display cfd version
The current CFD version is standard.
Table 15 Command output
The current CFD version is draft5
Indicates that the current CFD protocol is IEEE 802.1ag draft5.2.
The current CFD version is draft5-plus
Indicates that the current CFD protocol is the IEEE 802.1ag draft5.2 interim version.
Indicates that the current CFD protocol is the standard version of IEEE 802.1ag.
reset cfd tst
reset cfd tst [ service-instance instance-id [ mep mep-id ] ]
View
Default level
1: Monitor level
Use reset cfd tst to clear the TST result on the specified MEP.
If no MEP is specified, the reset cfd tst command clear the TST results of all MEPs in the specified service instance.
If no service instance is specified, the reset cfd tst command clears the TST results of all MEPs in all service instances.
Related commands: display cfd tst.
# Clear the TST results of all the MEPs in all service instances.
<Sysname> reset cfd tst
