| 00-Preface | 66.83 KB |
Preface
The H3C WA2610i-GN AP Installation Guide describes the hardware specifications, preparations before installation, installation procedure, cabling and grounding, and login procedure of the WA2610i-GN AP.
This preface includes:
· Audience
Audience
· Network planners
· Field technical support and servicing engineers
· Network administrators working with the WA2610i-GN APs
Conventions
This section describes the conventions used in this documentation set.
GUI conventions
Convention |
Boldface |
Window names, button names, field names, and menu items are in Boldface. For example, the New User window appears; click OK. |
Symbols
Convention |
NOTE |
Obtaining documentation
You can access the most up-to-date H3C product documentation on the World Wide Web at http://www.h3c.com.
Click the links on the top navigation bar to obtain different categories of product documentation:
[Technical Support & Documents > Technical Documents] – Provides hardware installation, software upgrading, and software feature configuration and maintenance documentation.
[Products & Solutions] – Provides information about products and technologies, as well as solutions.
[Technical Support & Documents > Software Download] – Provides the documentation released with the software version.
Technical support
http://www.h3c.com
Documentation feedback
We appreciate your comments.
