Title | Size | Downloads |
H3C WA2620X-AGNP Access Point Installation Guide-APW100-Text.pdf | 864.41 KB |
01-Text | 864.41 KB |
Examining the installation site
Grounding and lightning protection
Installing the outdoor antennas
Installing a directional antenna on a pole
Installing the omnidirectional antennas on poles
Connecting the AP to the power source
Connecting the grounding cable
Appendix A Crimping an RJ-45 connector
Overview
H3C WA2620X-AGNP access point (AP) is a new-generation AP that supports 802.11n and can work in fit or fat mode. A fit AP can work with an access controller (AC) or wireless switch to provide WLAN access. A fat AP can provide WLAN access alone. Figure 1 shows a typical networking scenario for WA2620X-AGNP APs.
Figure 1 Deployment of WA2620X-AGNP APs (in fat mode)
Hardware specifications
The WA2620X-AGNP AP offers IP66 rated protection and allows for outdoor deployment. The following sections describe its hardware specifications, LEDs, and ports.
Table 1 Hardware specifications
Item |
Dimensions (H×W×D) |
76 x 245 x 245 mm (2.99 x 9.65 x 9.65 in.) |
Weight |
2.35 kg (5.18 lb) |
Power consumption |
12 W (standby) to 24 W (maximum) |
Protocols and materials |
· IEEE802.11a/b/g/n · Waterproof cast aluminum + plastic housing |
802.at |
Support for PoE+ |
LEDs
LED |
Color |
Quantity |
POWER (Power LED) |
Green |
1 |
Indicates power status: · On: The AP is powered on. · Off: The AP is powered off or operates abnormally. |
ETH1 (10/100M) (10/100M Ethernet port LED) |
Green |
1 |
Indicates Ethernet port status: · Steady on: A link is present on the port. · Off: No link is present on the port. · Blinking: The port is transmitting or receiving data. |
ETH1 (1000M) (GE port LED) |
Green |
1 |
ETH2 (SFP) (GE fiber port LED) |
Green |
1 |
Indicates fiber port status: · Steady on: A link is present on the port. · Off: No link is present on the port. · Blinking: The port is transmitting or receiving data. |
2.4G (802.11g/n LED) |
Green |
1 |
Indicates wireless link status: · Off: The wireless link is down or fails. · Slow blinking: The wireless link is normal. · Fast blinking: Data is being transmitted or received. |
5G (802.11a/n LED) |
Green |
1 |
Ports
The WA2620X-AGNP AP provides three 2.4 GHz antenna ports and three 5.0 GHz antenna ports, a console port, Ethernet ports (fiber and copper), a power port, and a grounding terminal.
Figure 3 WA2620X-AGNP port layout
1: 2.4G-1 antenna port |
2: 2.4G-2 antenna port |
3: 2.4G-3 antenna port |
4: 5G-1 antenna port |
5: 5G-2 antenna port |
6: 5G-3 antenna port |
7: ETH2 (1000BASE-FX fiber port) |
8: ETH 1 (10/100/1000BASE-TX copper port) |
9: Grounding terminal |
10: Console port |
Port |
Standards and protocols |
Function |
ETH 2 1000BASE-FX fiber port |
IEEE802.3 SFP MSA SFF-8472 |
Connects to the Internet or Metropolitan Area Network (MAN). NOTE: The SFP transceiver module (9/125µm single mode fiber) uses an LC connector and delivers a transmission speed of 1250 Mbps (central wavelength: 1310 nm; output power: –9.5 dBm to –3 dBm; receive sensitivity ≤ –20 dBm; light saturation: –3 dBm). |
ETH 1 10/100/1000BASE-TX copper port |
IEEE802.3 IEEE802.3u IEEE802.3at |
Connects to the Internet or MAN and serves as a PoE port. |
2.4G-1/2/3 |
IEEE802.11b/g/n |
Antenna port for 2.4 GHz band |
5G-1/2/3 |
IEEE802.11a/n |
Antenna port for 5 GHz band |
CONSOLE |
RS/EIA-232 |
Console port for configuration and management |
This chapter describes how to prepare for the installation of the AP, including the preparation of tools and installation site survey.
Preparing installation tools
When installing the AP, you may need the tools listed in Table 4. Choose the appropriate tools according to the installation environment.
Table 4 List of installation tools
Type of tools |
Tools |
General tools |
Digging tools, adjustable wrench, pliers, Phillips screwdriver |
Special tools |
Cable stripper, crimping pliers, RJ-45 crimping pliers, waterproof sealing tape, fiber fusion splicer |
Auxiliary tools |
Ladder |
Before installation, examine the installation site to make sure that the AP will work in a good environment. You can examine the installation site from the following two aspects.
Installation site selection
Keep the AP away from high temperature, dust, harmful gases, inflammables, explosive substances, electromagnetic interference sources (heavy-duty radars, radio stations, or electrical substations), unstable voltage, heavy vibration, or loud noise. The installation site should be dry, without any leakage, dripping, or dew. The AP should be at least 500 m (0.31 miles) away from the seaside and should not face the direction of sea wind.
In engineering design, the site should be selected according to the network planning and technical requirements of the communications equipment, and the considerations such as climate, hydrology, geology, earthquake, electric power, and transportation.
Temperature and humidity
Table 5 Temperature and humidity requirements
Item |
Range |
Operating temperature |
–40°C to +65°C (–40°F to 149°F) |
Storage temperature |
–40°C to +85°C (–40°F to 185°F) |
Operating relative humidity (noncondensing) |
0% to 100% |
Storage relative humidity (noncondensing) |
0% to 100% |
Power supply
The AP can be powered by a power injector or through PoE+.
1. Power injector
You can use an H3C POE-5 power injector to power the AP. For more information about how to power the AP through the power injector, see “Connecting the AP to a power injector.”
NOTE: The input voltage of the POE-5 power injector must be 85 to 264 VAC (50/60 Hz). The power injector is not shipped with the AP and must be ordered separately. |
2. PoE+
If the switch connected to the AP is PoE+ capable, the AP can be powered by the switch through the cable between the 10/100/1000BASE-TX port of the AP and the Ethernet port of the switch.
Table 6 Grounding and lightning protection requirements
Item |
Requirements |
Grounding resistance |
· The grounding resistance is usually required to be less than 5 ohms, and less than 10 ohms in an area with less than 20 thunderstorm days a year. If a piece of angle steel is buried as the grounding conductor, the grounding resistance is required to be less than 10 ohms. In an area with a higher grounding resistance, reduce the grounding resistance by using brine or resistance reducing agent around the grounding conductor. · The top of the grounding conductor should be at least 0.7 m (2.30 ft) away from the ground surface. In cold areas, the grounding conductor should be buried below the frozen soil layer. |
Grounding connection |
· If a grounding strip is available, connect the yellow and green grounding cable of the AP to the grounding strip. To make a grounding cable, make sure the cable is with a cross-section area of at least 6 mm2 (0.01 in.2) and a length of no longer than 3 m (9.84 ft). · If no grounding strip is available, bury a piece of angle steel/steel tube at least 0.5 m (1.64 ft) long in the earth to serve as the grounding conductor. In the case of a piece of angle steel, the size should be at least 50 × 50 × 5 mm (1.97. × 1.97 × 0.20 in.); in the case of a piece of steel tube, it must be zinc-plated and have a wall thickness of at least 3.5 mm (0.14 in.). Weld the yellow and green grounding cable of the AP onto the grounding conductor and use anti-erosion treatment on the welding joint. The grounding cable should be as short as possible and must not be coiled. · Make sure that the grounding terminals of all the lightning arresters of the AP and the peer device of the AP are well grounded. |
Grounding lead-in |
A grounding lead-in is a metal conductor connecting a grounding net and a grounding strip. The grounding cable of the AP should be connected to the grounding strip. The grounding lead-in must be 30 m (98.43 ft) or shorter. A piece of zinc-coated flat steel with a cross-section area of 40 × 4 mm (1.57 × 0.16 in.) or 50 × 5 mm (1.97 × 0.20 in.) is recommended. Connect the grounding strip and the grounding lead-in of the AP through the yellow and green grounding cable with an area of 35 mm2 (0.05 in.2), or weld them directly. Use anti-erosion treatment on the welding joint. |
Power grounding (AC) |
· Use a power cord with a protective earth (PE). Do not use a power cord with only an L line and an N line. · The neutral line of the power cord should not be connected with the PGND of other communications equipment. The L and N lines cannot be connected. |
Lightning rod |
In plain areas, the shielding angle of the lightning rod should be less than 45 degrees. In mountainous areas or lightning areas, the shielding angle should be less than 30 degrees. The lightning protection grounding (for example, the grounding of the lightning rod) should be connected to the grounding conductor of the equipment room. |
Antenna |
· The antenna support is already prepared according to the design requirements. · The AP is well grounded according to design requirements. |
Network cable |
Use a shielded twisted pair cable for outdoor installation. Make sure that the devices at the two ends of the cable are well grounded. |
Examining the AP
Before installing the AP, connect the AP to the power source (if a power injector is used) and the Ethernet and check the status of the LEDs to ensure that the AP is functional. Save the MAC address of the AP for future use.
The WA2620X-AGNP AP can be mounted on a pole. To ensure the radio coverage, have the AP installed by professionals. The installation involves the following procedures:
Installing the AP
The AP can be fixed to a vertical or horizontal pole whose outer diameter is between 60 mm and 110 mm (2.36 in. and 4.33 in.). The mounting kit includes a pair of V-shaped brackets, a mounting plate, bolts, and nuts, as shown in Figure 4.
Figure 4 Mounting plate and V-shaped bracket
1: Mounting plate |
2: Mounting slot (allows bracket rotation) |
3: Bolt |
4: V-shaped bracket |
You can adjust the tilt of the AP by rotating the mounting plate around the bolt to help installation, as shown in Figure 5.
Figure 5 Adjust the tilt of the AP
1: Mounting plate |
2: Bolt |
3: Mounting slot (allows bracket rotation) |
Pole mounting is suitable for rooftop installation.
Follow these steps to install the AP on a pole:
Step1 Vertically fix the pedestal of the pole to the rooftop or a cement pier on the rooftop with expansion screws, as shown in Figure 6.
Step2 Fix the V-shaped bracket onto the mounting plate with the bolt.
Step3 Attach another V-shaped bracket to the pole, making sure that the two V-shaped bracket are level. Insert two long bolts through the screw holes on the two brackets and attach the bolts, nuts, and flat and spring washers, as shown in Figure 7 and Figure 8.
Figure 7 Mount the AP on the pole (vertical)
1: AP |
2: Screw (M6 x 12) |
3: Mounting plate |
5: Long bolt |
6: #10 flat washer |
7: #10 spring washer |
8: M10 nut |
Figure 8 Mount the AP on the pole (horizontal)
1: AP |
2: Mounting plate |
3: V-shaped bracket |
4: Long bolt |
5: M10 nut |
6: #10 spring washer |
7: #10 flat washer |
8: Screw (M6 x 12) |
Step4 Fix the AP onto the mounting plate with screws and fasten the screws, as shown in Figure 7 and Figure 8.
NOTE: You can fix the mounting plate on the pole with brackets before or after fixing the AP onto the mounting plate, whichever is more convenient. |
Outdoor antennas fall into directional and omnidirectional antennas. Omnidirectional antennas can be installed on the AP directly. The following section describes how to install directional and omnidirectional antennas.
NOTE: Ensure that the location of the pole does not hamper the adjustment of antenna direction and tilt. |
Before you install a directional antenna on the pole, make sure that the pole is vertical to the rooftop surface.
Follow these steps to install a directional antenna:
Step1 Weld the lightning rod to the tip of the pole.
Step2 Install the pole on a parapet or cement pier.
· If there are parapets on the rooftop and the height of the parapets is no less than 1.2 m (3.94 ft), you can fix the pole on a parapet with expansion screws and fix the directional antenna on the pole with the pole mounting bracket, as shown in Figure 9.
Figure 9 Install a directional antenna on a parapet (I)
· If there are parapets on the rooftop and the height of the parapets is less than 1.2 m (3.94 ft), you can fix the pole on a parapet at one point with expansion screws and fix the bottom end of the pole to the rooftop surface, and then fix the directional antenna on the pole with the pole mounting bracket, as shown in Figure 10.
Figure 10 Install a directional antenna on a parapet (II)
· If there is no parapet on the rooftop, fix the pole to the rooftop surface or a cement pier on the rooftop with expansion screws and stabilize the pole with steel wires. Then, install the directional antenna on the pole, as shown in Figure 11.
Figure 11 Install a directional antenna on a cement pier
Step3 Connect the pole to a grounding grid with a flat steel bar (40 x 4 mm or 1.57 x 0.16 in.).
Step4 Fix the antenna on the pole with the pole mounting bracket.
NOTE: · The diameter of the poles for omnidirectional antennas must be 35 to 50 mm (1.38 to 1.97 in.). Usually, poles are made of round steel bars 50 mm (1.97 in.) in diameter. · The pole clamp at the top of the pole and the one at the bottom of the antenna must be level, as shown in Figure 12. · The antennas and the lightning rod must be of such heights that the antennas can provide desired coverage and remain within the shielding angle (45°) of the lightning rod. |
Omnidirectional antennas must be kept at least one meter (3.28 ft) away horizontally from metal objects. Therefore, do not weld the lightning rod on a pole attached with an antenna. Install the lightning rod on a separate pole between the two omnidirectional antennas and ensure that the antennas are within the shielding angle of the lightning rod.
Figure 12 Install omnidirectional antennas
If separately installing the lightning rod is not practical, use the alternative method shown in Figure 13, but allow at least one meter (3.28 ft) of clearance between the lightning rod and the antenna.
Figure 13 Alternative method for installing an omnidirectional antenna
NOTE: In Figure 13, the antenna pole is not fixed on the cement pier. Instead, the antenna pole is fixed by welding two angle steel bars between the antenna pole and the lightning rod pole. |
Connecting cables
WARNING! Before connecting any cable, make sure that all power lines are disconnected and locked out and that no hazardous voltage is present on the neutral (N) line. |
CAUTION: Make sure that the outer sheath of cables is intact and does not absorb moisture to protect the AP from water leak. |
External cables may include antenna cable, Ethernet cable, fiber cable, grounding cable, and power cord.
Connecting the antenna cables
The antenna cables connect the antenna ports (2.4 GHz and 5 GHz) to the outdoor antennas.
Follow these steps to connect the antenna cables:
Step1 Connect the antenna cables to the antenna ports of the AP at one end and to the outdoor antennas at the other end.
· For 2 x 2 MIMO antennas, connect the cables to the 2.4 G-1/3 and 5G-1/3 antenna ports on the AP.
· For 3 x 3 MIMO antennas, connect the cables to the 2.4 G-1/2/3 and 5G-1/2/3 antenna ports on the AP, respectively.
Step2 Wrap the connections with insulating tape and apply several layers of waterproof sealing tape over the insulating tape.
NOTE: · No antenna arrestor is needed. The WA2620X-AGNP AP provides lightning arresting function. · Make sure that the grounding cables are well grounded during outdoor deployment. · You have the option to order the standard ready-made antenna cables, or order cables of desired lengths and N-type antenna connectors and make antenna cables on-site as needed. · Stretch the waterproof sealing tape till the width of the tape is reduced to 3/4 of the original width and wrap the waterproof sealing tape around the cable to achieve desired waterproof performance. |
Connecting the Ethernet cable
CAUTION: Observe the following procedure when connecting the copper cable. Otherwise, the AP might be damaged. |
Step1 Route the Ethernet cable with waterproof sheath from the equipment room to the AP.
Figure 14 Connect a copper cable
Figure 15 Connect a fiber cable
NOTE: · If the AP is powered by a PoE+ switch, no power injector is needed. Make sure that the PoE+ switch can support the maximum power consumption of the AP. · If a fiber cable is used to transmit data, the copper cable only provides power and does not transmit data. · The Ethernet port marked with “Signal & power output” on the power injector must be connected to the AP. · Make sure that the installation of the AP is complete before powering on the AP, regardless of whether the AP is powered through PoE+ or by a power injector. |
Step2 Insert the copper cable through the liquid tight adapter and crimp an RJ-45 connector on the end of the cable. For more information about how to crimp an RJ-45 connector on a cable ,see “Appendix A Crimping an RJ-45 connector”.
Step3 Connect the cable to the copper port of the AP.
Figure 17 Connect the copper cable to the copper port of the AP
1: RJ-45 connector |
2: Liquid tight adapter |
3: Sealing nut |
Step4 Make sure the sealing nut is loose. Tighten the liquid tight adapter, and then tighten the sealing nut.
Step5 Seal the connection with waterproof sealing tape.
Connecting the fiber cable
CAUTION: · Observe the following procedure when connecting the fiber cable. Otherwise, the AP might be damaged. · When a fiber cable is used to transmit data, both ends of the cable must use appropriate SFP transceiver modules. The SFP transceiver modules provided by H3C meet the outdoor deployment requirements, use single mode fiber, and have a transmission distance of 15 km (9.32 mi). |
If the AP is connected to the switch through a fiber cable, an SFP transceiver module and a liquid tight adapter are required at the AP side, as shown in Figure 18.
Figure 18 Connect the fiber cable to the fiber port of the AP
1: SFP transceiver module |
2: Fiber connector |
3: Liquid tight adapter |
4: Sealing nut |
Follow these steps to connect a fiber cable:
Step1 Insert an SFP transceiver module into the fiber port of the AP.
Step2 Insert an LC fiber connector with liquid tight adapter to the SFP transceiver module.
Step3 Make sure the sealing nut is loose. Tighten the liquid tight adapter, and then tighten the sealing nut.
Step4 Seal the connection with waterproof sealing tape.
NOTE: · The optional fiber cable is a 10-meter pigtail with waterproof sheath. One end of the pigtail uses an LC connector and a liquid tight adapter and is inserted into the fiber port of the AP and the other end uses an SC connector and is connected to an end user terminal or switch. · If the fiber is connected to a fiber termination box, connect the SC connector to a pair of SC sockets. The one marked as A is the receiving port (RX) of the AP and must be connected to the transmitting port (TX) of the peer device; the one marked as B is the TX port of the AP and must be connected to the RX port of the peer device. Usually, fiber termination boxes are not waterproof. Put the fiber termination box indoor or in a waterproof cabinet. · If the fiber is connected to a fiber connector box, cut off the SC connector and splice the fiber end with the connector on the connector box. The pigtail marked as A is connected to the RX port of the AP and the TX port of the peer device; the pigtail marked as B is connected to the TX port of the AP and the RX port of the peer device. Fiber connector boxes are usually waterproof and can be buried underground or mounted on a pole. |
The WA2620X-AGNP AP can be powered by a power injector or a PoE+ switch.
As shown in Figure 16, follow these steps to connect the power injector to the AP:
Step1 Connect the power input line to an AC power source.
Step2 Connect the signal & power output line to the copper port of the AP.
Step3 Connect the signal input line to a switch or an access controller.
Step4 Ground the PE output line of the power injector.
Connecting the AP to a PoE+ capable switch
To power the AP by using a PoE+ capable switch, connect the 10/100/1000BASE-TX port of the AP to an Ethernet port of the switch through an Ethernet cable.
NOTE: · If the AP is powered by a PoE+ switch, the power injector is not needed. Make sure that the PoE+ port can support the maximum power consumption of the AP. · If the AP is powered by a power injector, put the power injector at the switch side, and the switch connected to the power injector does not need to be PoE+ capable. · Make sure that the installation of the AP is complete before powering on the AP, regardless of whether the AP is powered through PoE+ or by a power injector. |
Connect the grounding terminal of the AP to the grounding point with the yellow and green grounding cable shipped with the AP, as shown in Figure 3. For more information about the procedure, see “Grounding and lightning protection”.
NOTE: If the AP is powered by a power injector, the PE output line of the power injector must also be grounded. |
Verifying the installation
After the installation and cabling, check the following items before powering on the AP:
· The power source meets the power specification of the AP;
· The AP is well grounded;
· The power input cable and the Ethernet cables are correctly connected;
· The outdoor antennas are installed;
· If the AP is powered by a PoE+ switch, an Ethernet lightning arrestor (which is not shipped with the AP) is installed on the AP.
Powering on the AP
Make sure that all the cables are correctly connected. Then, switch on the external power source and check the power LED of the AP against Table 2.
CAUTION: If the AP is installed outdoor, the Ethernet cable must be waterproof and the connection at the AP port must be sealed with waterproof sealing tape. |
NOTE: A fit AP is zero-configuration and is managed by an access controller or wireless switch. This chapter describes how to log in to a fat AP on a web interface. |
Use the following factory default settings to log in to a fat AP on a web interface:
· Username: admin
· Password: h3capadmin
· IP address: 192.168.0.50 (mask: 255.255.255.0)
Follow these steps to log in to the AP:
Step1 Connect the AP to a computer with an Ethernet cable.
Step2 Set the IP address of the computer to an address (such as 192.168.0.100 with a mask of 255.255.255.0) that is in the same subnet as the AP.
Step3 Launch the web browser and input the address (http://192.168.0.50) of the AP in the address bar and press Enter. The login interface appears, as shown in Figure 19. On the web interface, enter the default username and password and the verification code, and click Login.
You must insert the Ethernet cable through the liquid tight adapter before crimping an RJ-45 connector on the end of the cable (usually category 5 or category 5E cable).
Figure 20 RJ-45 connector
The following describes two common types of cables and how to make them.
· Straight-through cable: The colored wires are of the same sequence at the two ends of the cable. A straight-through cable is usually used to connect these devices: PC to hub or switch, router to hub or switch.
· Crossover cable: The colored wires are of different sequences at the two ends of the cable. A crossover cable is usually used to connect these devices: PC to PC, router to router, or PC to router.
Table 7 Straight-through cable pin-outs
RJ45 pin |
Signal |
Wire |
Signal direction |
RJ45 pin |
1 |
TX+ |
White-orange |
à |
1 |
2 |
TX- |
Orange |
à |
2 |
3 |
RX+ |
White-green |
ß |
3 |
4 |
Blue |
4 |
5 |
White-blue |
5 |
6 |
RX- |
Green |
ß |
6 |
7 |
White-brown |
7 |
8 |
Brown |
8 |
Table 8 Crossover cable pin-outs
RJ45 pin |
Signal |
Wire |
Signal direction |
RJ45 pin |
1 |
TX+ |
White-orange |
à |
3 |
2 |
TX- |
Orange |
à |
6 |
3 |
RX+ |
White-green |
ß |
1 |
4 |
Blue |
4 |
5 |
White-blue |
5 |
6 |
RX- |
Green |
ß |
2 |
7 |
White-brown |
7 |
8 |
Brown |
8 |
NOTE: · The Ethernet ports of the AP are autosensing and can recognize both types of cables. · When making a cable, follow the exact sequence listed in Table 7 or Table 8. · When the AP is installed outdoors, the cable must be waterproof. If possible, use waterproof tubing to protect the cable. |
