| 03-QoS Configuration | 306.76 KB |
Table of Contents
Introduction to QoS Service Models
Applying QoS Techniques in a Network
QoS Configuration Approach Overview
Defining a QoS Policy and Applying the QoS Policy to an Interface
Displaying and Maintaining QoS Policies
3 Priority Mapping Configuration
Introduction to Packet Precedences
Introduction to Priority Mapping
Introduction to Priority Mapping Tables
Priority Mapping Configuration Task List
Configuring a Priority Mapping Table
Configuring a Port to Trust Packet Priority for Priority Mapping
Changing the Port Priority of an Interface
Displaying and Maintaining Priority Mapping
Priority Mapping Configuration Example
l The models listed in this document are not applicable to all regions. Please consult your local sales office for the models applicable to your region.
l Support of the H3C WA series WLAN access points (APs) for features may vary by AP model. For more information, see Feature Matrix.
l The interface types and the number of interfaces vary by AP model.
l The term AP in this document refers to common APs, wireless bridges, and mesh APs.
1 QoS Overview
This chapter includes these sections:
l Introduction to QoS Service Models
Introduction to QoS
In data communications, Quality of Service (QoS) is the ability of a network to provide differentiated service guarantees for diversified traffic in terms of bandwidth, delay, jitter, and drop rate.
Network resources are always scarce. The contention for resources demands that QoS prioritize important traffic flows over trivial traffic flows. When making a QoS scheme, a network administrator must consider the characteristics of various applications to balance the interests of diversified users and fully utilize network resources.
The subsequent section describes some typical QoS service models and widely-used mature QoS techniques. By appropriately using these techniques, you can improve QoS effectively.
This section covers three typical QoS service models:
Best-Effort Service Model
Best effort is a single service model and also the simplest service model. In the best effort service model, the network does its best to deliver packets but does not guarantee delay or reliability.
The best-effort service model is the default model in the Internet and applies to most network applications. It uses the first in first out (FIFO) queuing mechanism.
IntServ Service Model
The integrated service (IntServ) model is a multiple-service model that can accommodate diverse QoS requirements. It provides the most granularly differentiated QoS by identifying and guaranteeing definite QoS for each data flow.
In the IntServ model, an application must request service from the network before it sends data. IntServ signals the service request with the Resource Reservation Protocol (RSVP). All nodes that receive the request reserve resources as requested and maintain state information for the application flow.
The IntServ model demands high storage and processing capabilities, because it requires that all nodes along the transmission path maintain resource state information for each flow. The model is suitable for small-sized or edge networks, but not large-sized networks, for example, the core layer of the Internet, where billions of flows are present.
For more information about RSVP, see MPLS TE in the MPLS Configuration Guide.
DiffServ Service Model
The differentiated service (DiffServ) model is a multiple-service model that can satisfy diverse QoS requirements. Unlike IntServ, DiffServ does not require an application to signal the network to reserve resources before sending data. DiffServ is easy to implement and extend.
All QoS techniques in this document are based on the Diff-Serv model.
QoS Techniques Overview
The QoS techniques fall into traffic classification, traffic policing, traffic shaping, line rate, congestion management, and congestion avoidance. The following part briefly introduces these QoS techniques.
Figure 1-1 Positions of the QoS techniques in a network
As shown in Figure 1-1, traffic classification, traffic shaping, traffic policing, congestion management, and congestion avoidance mainly implement the following functions:
l Traffic classification uses certain match criteria to assign packets with the same characteristics to a class. Based on classes, you can provide differentiated services.
l Traffic policing polices flows entering or leaving an AP, and imposes penalties on traffic flows that exceed the pre-set threshold to prevent aggressive use of network resources. You can apply traffic policing to both incoming and outgoing traffic of a port.
l Traffic shaping proactively adapts the output rate of traffic to the network resources available on the downstream AP to eliminate packet drops. Traffic shaping usually applies to the outgoing traffic of a port.
l Congestion management provides a resource scheduling policy to determine the packet forwarding sequence when congestion occurs. Congestion management usually applies to the outgoing traffic of a port.
l Congestion avoidance monitors the network resource usage and is usually applied to the outgoing traffic of a port. When congestion worsens, congestion avoidance actively reduces the queue length by dropping packets.
QoS Processing Flow in an AP
Figure 1-2 QoS processing flow
Figure 1-2 briefly describes how the QoS module processes traffic:
1) Traffic classifier identifies and classifies traffic for subsequent QoS actions.
2) The QoS module takes various QoS actions on classified traffic as configured, depending on the traffic processing phase and network status. For example, you may configure the QoS module to perform traffic policing for incoming traffic, traffic shaping for outgoing traffic, congestion avoidance before congestion occurs, and congestion management when congestion occurs.
l QoS Configuration Approach Overview
l Displaying and Maintaining QoS Policies
Two approaches are available for configuring QoS: Non-Policy Approach and Policy Approach.
Some features support both approaches, but some support only one.
Non-Policy Approach
In non-policy approach, you configure QoS service parameters directly without using a QoS policy. For example, you can use the line rate feature to set a rate limit on an interface without using a QoS policy.
Policy Approach
In policy approach, you configure QoS service parameters by using QoS policies. A QoS policy defines the shaping, policing, or other QoS actions to take on different classes of traffic. It is a set of class-behavior associations.
A class is a set of match criteria for identifying traffic. It uses the AND or OR operator:
l If the operator is AND, a packet must match all the criteria to match the class.
l If the operator is OR, a packet matches the class if it matches any of the criteria in the class.
A traffic behavior defines a set of QoS actions to take on packets, such as priority marking and redirect.
By associating a traffic behavior with a class in a QoS policy, you apply the specific set of QoS actions to the class of traffic.
Configuring a QoS Policy
Figure 2-1 shows how to configure a QoS policy.
Figure 2-1 QoS policy configuration procedure
Defining a Class
To define a class, specify its name and then configure the match criteria in class view.
Follow these steps to define a class:
To do... |
Use the command... |
Remarks |
Enter system view |
system-view |
Create a class and enter class view |
traffic classifier tcl-name [ operator { and | or } ] |
Required By default, the operator of a class is AND. The operator of a class can be AND or OR. l AND: A packet is considered belonging to a class only when the packet matches all the criteria in the class. l OR: A packet is considered belonging to a class if it matches any of the criteria in the class. |
Configure match criteria |
if-match match-criteria |
Required For more information, see the if-match command in QoS in the ACL and QoS Command Reference. |
Defining a Traffic Behavior
A traffic behavior is a set of QoS actions (such as traffic filtering, traffic policing, and priority mapping) to take on a class of traffic. To define a traffic behavior, first create it and then configure QoS actions (such as priority mapping and traffic policing) in traffic behavior view.
Follow these steps to define a traffic behavior:
To do... |
Remarks |
Enter system view |
system-view |
Create a traffic behavior and enter traffic behavior view |
traffic behavior behavior-name |
Required |
Configure a CAR action |
car cir committed-information-rate [ cbs committed-burst-size [ ebs excess-burst-size ] ] [ pir peak-information-rate ] [ red action ] |
Optional |
Drop or send packets |
filter { deny | permit } |
Optional To drop matching packets, select the deny keyword. To permit matching packets to pass through, select the permit keyword. |
Set the local precedence for packets |
remark local-precedence local-precedence |
Optional |
Set the 802.1p priority for packets |
remark dot1p 8021p |
Optional |
Display traffic behavior configuration information |
display traffic behavior user-defined [ behavior-name ] |
Optional Available in any view |
A policy applied to an interface takes effect on the traffic sent or received by the interface.
A policy can be applied to multiple interfaces, but only one policy can be applied in one direction (inbound or outbound) of an interface.
Follow these steps to apply the QoS policy to an interface:
To do... |
Remarks |
Enter system view |
system-view |
Define a QoS policy and enter QoS policy view |
qos policy policy-name |
Required |
Associate a class with a behavior in the QoS policy |
classifier tcl-name behavior behavior-name |
Required Repeat this step to create more class-behavior associations. |
Enter interface view |
Apply the policy to the interface |
qos apply policy policy-name { inbound | outbound } |
Required |
The QoS policy applied to the outgoing traffic of an interface does not regulate local packets. Local packets refer to the critical protocol packets sent by the local system for maintaining the normal operation of the AP. To avoid drop of local packets, QoS does not process them. Commonly used local packets are link maintenance packets and so on.
To do... |
Remarks |
Display traffic class information |
display traffic classifier user-defined [ tcl-name ] |
Display the configuration of one or all classes in one or all QoS policies and the associated behaviors of the classes |
display qos policy user-defined [ policy-name [ classifier tcl-name ] ] |
Display QoS policy configuration on the specified or all interfaces |
display qos policy interface [ interface-type interface-number ] [ inbound | outbound ] |
l Introduction to Packet Precedences
l Priority Mapping Configuration Task List
l Configuring Priority Mapping
l Displaying and Maintaining Priority Mapping
l Priority Mapping Configuration Example
IP Precedence and DSCP Values
As shown in Figure 3-1, the ToS field of the IP header contains eight bits, and the first three bits (0 to 2) represent IP precedence from 0 to 7. According to RFC 2474, the ToS field of the IP header is redefined as the differentiated services (DS) field, where a DSCP value is represented by the first six bits (0 to 5) and is in the range 0 to 63. The remaining two bits (6 and 7) are reserved.
Table 3-1 Description on IP precedence
IP precedence (decimal) |
IP precedence (binary) |
0 |
000 |
Routine |
1 |
001 |
priority |
2 |
010 |
immediate |
3 |
011 |
flash |
4 |
100 |
flash-override |
5 |
101 |
critical |
6 |
110 |
internet |
7 |
111 |
network |
Table 3-2 Description on DSCP values
DSCP value (decimal) |
DSCP value (binary) |
46 |
101110 |
ef |
10 |
001010 |
af11 |
12 |
001100 |
af12 |
14 |
001110 |
af13 |
18 |
010010 |
af21 |
20 |
010100 |
af22 |
22 |
010110 |
af23 |
26 |
011010 |
af31 |
28 |
011100 |
af32 |
30 |
011110 |
af33 |
34 |
100010 |
af41 |
36 |
100100 |
af42 |
38 |
100110 |
af43 |
8 |
001000 |
cs1 |
16 |
010000 |
cs2 |
24 |
011000 |
cs3 |
32 |
100000 |
cs4 |
40 |
101000 |
cs5 |
48 |
110000 |
cs6 |
56 |
111000 |
cs7 |
0 |
000000 |
be (default) |
802.1p Priority
802.1p priority lies in the Layer 2 header and is applicable to occasions where Layer 3 header analysis is not needed and QoS must be assured at Layer 2.
Figure 3-2 An Ethernet frame with an 802.1Q tag header
As shown in Figure 3-2, the 4-byte 802.1Q tag header consists of the tag protocol identifier (TPID, two bytes in length), whose value is 0x8100, and the tag control information (TCI, two bytes in length). Figure 3-3 presents the format of the 802.1Q tag header. The Priority field in the 802.1Q tag header is called the 802.1p priority, because its use is defined in IEEE 802.1p. Table 3-3 presents the values for 802.1p priority.
Table 3-3 Description on 802.1p priority
802.1p priority (decimal) |
802.1p priority (binary) |
0 |
000 |
best-effort |
1 |
001 |
background |
2 |
010 |
spare |
3 |
011 |
excellent-effort |
4 |
100 |
controlled-load |
5 |
101 |
video |
6 |
110 |
voice |
7 |
111 |
network-management |
802.11e Priority
To provide QoS services on WLAN, the 802.11e standard was developed. IEEE 802.11e is a MAC-layer enhancement to IEEE 802.11. IEEE 802.11e adds a 2-byte QoS Control field to the 802.11e MAC frame header. Three bits of the QoS control field represents the 802.11e priority, which ranges from 0 to 7.
Figure 3-4 802.11e frame structure
Priority Mapping Overview
When a packet enters an AP, the AP assigns a set of QoS priority parameters to the packet based on a certain priority field carried in the packet and sometimes may modify its priority, according to certain rules depending on AP status. This process is called priority mapping. The set of QoS priority parameters decides the scheduling priority and forwarding priority of the packet.
Priority mapping is implemented with priority mapping tables and involves priorities such as 802.11e priority and 802.1p priority.
The AP provides various types of priority mapping table, as listed below.
l dot11e-lp: 802.11e-to-local priority mapping table.
l dot1p-lp: 802.1p-to-local priority mapping table.
l dscp-lp: DSCP-to-local priority mapping table, which applies to only IP packets.
l lp-dot11e: Local-to-802.11e priority mapping table.
l lp-dot1p: Local-to-802.1p priority mapping table.
l lp-dscp: Local-to-DSCP priority mapping table.
Table 3-4 through Table 3-7 list the default priority mapping tables.
Table 3-4 The default dot1p-lp mapping
802.1p priority |
Local precedence |
0 |
2 |
1 |
0 |
2 |
1 |
3 |
3 |
4 |
4 |
5 |
5 |
6 |
6 |
7 |
7 |
Table 3-5 The default dscp-lp mapping
DSCP |
Local precedence |
0 to 7 |
0 |
8 to 15 |
1 |
16 to 23 |
2 |
24 to 31 |
3 |
32 to 39 |
4 |
40 to 47 |
5 |
48 to 55 |
6 |
56 to 63 |
7 |
Table 3-6 The default lp-dot1p and lp-dscp mappings
Local precedence |
802.1p priority |
DSCP |
0 |
1 |
0 |
1 |
2 |
8 |
2 |
0 |
16 |
3 |
3 |
24 |
4 |
4 |
32 |
5 |
5 |
40 |
6 |
6 |
48 |
7 |
7 |
56 |
Table 3-7 The default port priority-local precedence mapping
Port priority |
Local precedence |
0 |
0 |
1 |
1 |
2 |
2 |
3 |
3 |
4 |
4 |
5 |
5 |
6 |
6 |
7 |
7 |
For the default dot11e-lp and lp-dot11e mappings, an input value yields a target value that is equal to it.
You can configure priority mapping in two approaches:
l Configuring priority trust mode. In this approach, you can configure a port to look up the priority mapping tables based on a certain priority such as 802.1p carried in incoming packets. If no packet priority is trusted, the port priority of the incoming port is used.
l Changing port priority. By default, all ports are assigned the port priority of zero. By changing the port priority of a port, you can change the priority of the incoming packets on the port.
It is recommended that you plan QoS throughout the network before making QoS configuration.
Complete the following task to configure priority mapping:
Task |
Remarks |
Optional |
Configuring a Port to Trust Packet Priority for Priority Mapping |
Optional |
Optional |
Follow these steps to configure a priority mapping table:
Remarks |
Enter system view |
system-view |
Enter priority mapping table view |
qos map-table { dot11e-lp | dot1p-lp | dscp-lp | lp-dot11e | lp-dot1p | lp-dscp } |
Required You can enter the corresponding priority mapping table view as required. |
Configure the priority mapping table |
import import-value-list export export-value |
Required Newly configured mappings overwrite the previous ones. |
Display the configuration of the priority mapping table |
display qos map-table [ dot11e-lp | dot1p-lp | dscp-lp | lp-dot11e | lp-dot1p | lp-dscp ] |
You can configure the AP to trust a particular priority field carried in packets for priority mapping on ports or globally.
When configuring the priority trust mode for a port, you can select the following keywords:
l dot11e: Uses the 802.11e priority of the received packets for mapping.
l dot1p: Uses the 802.1p priority of the received packets for mapping.
l dscp: Uses the DSCP value of the received packets for mapping.
Follow these steps to configure the priority trust mode for a port:
To do... |
Remarks |
Enter system view |
system-view |
Configure the priority trust mode |
qos trust { dot11e | dot1p | dscp } |
Required |
Display the priority trust mode and port priority information of the specified interface or all interfaces |
display qos trust interface [ interface-type interface-number ] |
If an interface does not trust any packet priority, the AP uses its port priority to look for the set of priority parameters for the incoming packets. By changing port priority, you can prioritize traffic received on different interfaces.
Follow these steps to change the port priority of an interface:
To do... |
Remarks |
Enter system view |
system-view |
Set the port priority of the port |
qos priority priority-value |
Required By default, the port priority is 0. |
To do... |
Remarks |
Display priority mapping table configuration information |
display qos map-table [ dot11e-lp | dot1p-lp | lp-dot11e | lp-dot1p ] |
Display the priority trust mode and port priority of the specified interface or all interfaces |
Network requirements
As shown in Figure 3-5:
l All departments access the Intranet through the same AP. Each department is configured with an independent WLAN name. These departments are assigned to different VLANs based on WLAN-BSS interface.
l It is required that the AP assigns local precedence to incoming packets by mapping the priority of the receiving port.
l The default priority mapping table of the AP is used.
Figure 3-5 Network diagram for priority mapping configuration
Configuration procedure
1) Configure the switch
# Create VLAN 2 and VLAN 3.
<Switch> system-view
[Switch] vlan 2
[Switch-vlan2] port ethernet 1/0/2
[Switch-vlan2] vlan 3
[Switch-vlan3] port ethernet 1/0/3
[Switch-vlan3] quit
[Switch] interface ethernet1/0/1
[Switch-Ethernet1/0/1] port link-type trunk
[Switch-Ethernet1/0/1] port trunk permit vlan all
[Switch-Ethernet1/0/1] quit
[Switch]
2) Configure the AP
# Enter system view.
<AP> system-view
# Configure a WLAN network for each of the two departments, with the SSID being PART1 and PART2 respectively. Bind the two WLAN networks to WLAN-BSS 1 and WLAN-BSS 2 respectively.
[AP] wlan service-template 1 clear
[AP-wlan-st-1] ssid PART1
[AP-wlan-st-1] service-template enable
[AP-wlan-st-1]quit
# Create interface WLAN-BSS1, and configure its port priority as 5.
[AP] interface wlan-bss 1
[AP-WLAN-BSS1] qos priority 5
[AP-WLAN-BSS1] quit
[AP] interface wlan-radio 1/0/2
[AP-WLAN-Radio1/0/2] service-template 1 interface WLAN-BSS 1
[AP-wlan-st-1] quit
[AP] wlan service-template 2 clear
[AP-wlan-st-2] ssid PART2
[AP-wlan-st-2] service-template enable
[AP-wlan-st-2]quit
# Create interface WLAN-BSS2, and configure its port priority as 7.
[AP] interface wlan-bss 2
[AP-WLAN-BSS2] qos priority 7
[AP-WLAN-BSS2] quit
[AP-WLAN-Radio1/0/2] service-template 2 interface WLAN-BSS 2
[AP-wlan-st-2] quit
# Assign interfaces WLAN-BSS 1 and WLAN-BSS 2 to different VLANs, such as VLAN 2 and VLAN 3 respectively.
[AP] vlan 2
[AP-vlan2]quit
[AP] interface WLAN-BSS 1
[AP-WLAN-BSS1] port access vlan 2
[AP-WLAN-BSS1] quit
[AP] vlan 3
[AP-vlan3]quit
[AP] interface WLAN-BSS 2
[AP-WLAN-BSS2]port access vlan 3
[AP-WLAN-BSS2] quit
# Configure port Ethernet 1/0/1 to use the 802.1p priority of received packets for priority mapping, and configure port Ethernet 1/0/1 as a trunk port.
[AP] interface ethernet 1/0/1
[AP-Ethernet1/0/1] qos trust dot1p
[AP-Ethernet1/0/1]port link-type trunk
# Assign port Ethernet 1/0/1 to VLAN 1 through VLAN 3.
[AP-Ethernet1/0/1] port trunk permit vlan 1 to 3
[AP-Ethernet1/0/1] quit
With these configurations completed, when you copy files to Host A and Host B or load files to Host A and Host B through the two wireless users connecting to BSS1 and BSS2 respectively, you will find that the loading rate of the wireless user connecting to BSS2 is faster than the loading rate of the wireless user connecting to BSS1.
These configurations just apply to the traffic from the wireless network to the wired network. To regulate the traffic from the wired network to the wireless network, you should make port priority configurations on the involved ports on the switch.
