| Title | Size | Downloads |
| 01-Text.pdf | 1.17 MB |
| 01-Text | 1.17 MB |
Table of Contents
Examining the Installation Site
Temperature and Humidity Requirements
Determining the Installation Position
Mounting the AP Through the Wall
Connecting the AP to the Network
Introduction
The H3C WA2600 Series Indoor WLAN Access Points (hereinafter referred to as the WA2600 indoor series) are one of the 802.11n access point (AP) product series developed by Hangzhou H3C Technologies Co., Ltd. (hereinafter referred to as H3C). The WA2600 indoor series can serve as fat APs for networking independently, and serve as fit APs to cooperate with wireless local area network (WLAN) switches or access controllers to provide wireless access for WLAN users.
Figure 1-1 shows a typical scenario of hotspot deployments using the WA2600 indoor series.
Figure 1-1 Typical networking using the WA2600 indoor series
Figure 1-2 shows the appearance of the WA2600 indoor series.
Figure 1-2 Appearance of the WA2600 indoor series
Table 1-1 Physical dimensions and weight of the WA2600 indoor series
Model |
Physical dimensions |
Weight |
WA2610-AGN (H × W × D) |
42 × 181 × 127 mm (1.65 × 7.13 × 5.00 in.) |
1 kg (2.20 lb.) |
WA2612-AGN (diameter × thickness) |
Φ190 × 60 mm (Φ7.48 × 2.36 in.) |
0.5 kg (1.10 lb.) |
Hardware Configuration
The WA2600 indoor series provide two models. Table 1-2 lists the basic configurations.
Table 1-2 Device basic configurations
Model |
Protocols and chassis material |
Antenna |
Power consumption |
WA2610-AGN |
l IEEE 802.11a/b/g/n, l single-RF, sheet metal + plastic mold design |
External antenna: l 2.4 GHz, gain: 2 dBi l 5 GHz, gain: 3 dBi |
5.2 W to 6.5 W |
WA2612-AGN |
l IEEE 802.11a/b/g/n, l single-RF, plastic mold design |
Internal antenna: l 2.4 GHz, gain: 6 dBi l 5 GHz, gain: 7 dBi |
5.9 W to 6.5 W |
The following describes the hardware configurations and functions of the WA2600 indoor series in detail.
LEDs
WA2610-AGN
Figure 1-3 LEDs on the WA2610-AGN
Table 1-3 Description of the LEDs on the WA2610-AGN
LED |
Color |
QTY |
Meaning |
POWER |
Green |
1 |
Displays the power supply status: l Steady on: The power supply is normal. l Off/blinking: The power supply is not well connected or the device works abnormally. |
2.4G (Wireless link LED) |
Green |
1 |
Displays the 2.4 GHz wireless link status: l Off: The wireless link is not initialized or the link is faulty. l Blinking slowly: The wireless link works normally. l Blinking rapidly: Data is being transmitted or received. |
5G (Wireless link LED) |
Green |
1 |
Displays the 5 GHz wireless link status: l Off: The wireless link is not initialized or the link is faulty. l Blinking slowly: The wireless link works normally. l Blinking rapidly: Data is being transmitted or received. |
ETHERNET (Ethernet interface LED) |
Yellow/green |
1 |
Displays the status of the Ethernet interface: l Steady on (green): The 1000 M Ethernet interface is in the link-up state. l Blinking (green): Data is being transmitted or received at 1000 Mbps. l Steady on (yellow): The 10/100 Mbps Ethernet interface is in the link-up state. l Blinking (yellow): Data is being transmitted or received at 10/100 Mbps. l Off: The Ethernet interface is in the link-down state. |
WPS |
Yellow/green |
1 |
Reserved for expansion use |
WA2612-AGN
Figure 1-4 LEDs on the WA2612-AGN
Table 1-4 Description of the LEDs on the WA2612-AGN
LED |
Color |
QTY |
Meaning |
POWER |
Green |
1 |
Displays the power supply status: l Steady on: The power supply is normal. l Off/blinking: The power supply is not well connected or works abnormally. |
10/100M (Ethernet interface LED) |
Yellow |
1 |
Displays the status of the Ethernet interface: l Steady on: The Ethernet interface is in the link-up state. l Off: The Ethernet interface is in the link-down state. l Blinking: Data is being transmitted or received at 10/100 Mbps. |
1000M (Ethernet interface LED) |
Green |
1 |
Displays the status of the 1000 M Ethernet interface: l Steady on: The Ethernet interface is in the link-up state. l Off: The Ethernet interface is in the link-down state. l Blinking: Data is being transmitted or received at 1000 Mbps. |
Green |
1 |
Green |
1 |
Interfaces
Interfaces provided by the WA2610-AGN
The WA2610-AGN provides the following interfaces:
l A console interface
l An Ethernet interface
l A power supply interface
In addition, the WA2610-AGN provides a reset button, a WPS button (reserved for expansion use) and a security slot.
Figure 1-5 Interfaces on the WA2610-AGN
Interfaces provided by the WA2612-AGN
The WA2612-AGN provides the following interfaces:
In addition, the WA2612-AGN provides a reset button and a security slot.
Figure 1-6 Interfaces on the WA2612-AGN
Table 1-5 describes the interfaces provided by each model.
Table 1-5 Descriptions of interfaces on the WA2610-AGN/WA2612-AGN
Interface silkscreen |
Standards and protocols |
CONSOLE |
RS/EIA-232 |
The console interface is used for device configuration and management. |
ETHERNET |
l IEEE802.3 l IEEE802.3u l IEEE802.3af |
The Ethernet interface can serve as an uplink interface to access the Internet or MAN, and as a PoE interface at the same time. |
When connecting a cable to an interface, pay attention to the interface silkscreen to avoid connection mistakes.
Safety Precautions
Installation and removal of the unit and its accessories must be carried out by qualified personnel. You must read all of the Safety Instructions supplied with your device before installation and operation.
Installation und Ausbau der Anlage und ihrer Zubehörteile müssen von qualifiziertem Personal realisiert werden. Sie müssen vor der Installation oder Bedienung allen beiliegenden Sicherheitshinweise lesen.
负责安装和日常维护本设备的人员必须具备安全操作基本技能。在操作本设备前,请务必认真阅读和执行产品手册规定的安全规范。
This chapter describes the preparations for WA2600 indoor series installation, including the preparation of installation tools, environment examination, unpacking and inspection.
Unpacking and Inspection
Before unpacking the package, make sure that the package is intact, without any serious damage or signs of water soaking. When unpacking the package, avoid excessive force or collision. Otherwise, the articles inside the package may get damaged.
l The accessories may vary with the models. For the exact contents of the package, refer to the packing list.
l If the contents do not check with the packing list, timely contact your local dealer.
l If the package is found to be rusted or water soaked, stop unpacking and contact your local dealer immediately.
Preparing Installation Tools
When installing the AP, you may need the tools listed in Table 2-1. Choose the appropriate tools according to the installation environment.
Table 2-1 List of installation tools
Type of tool |
Indoor installation |
General tools |
1-meter-long rulers, marking pens, knives, and a percussion drill with appropriate bits |
Special tools |
Cable strippers, crimping pliers, and RJ-45 crimping pliers |
Auxiliary tools |
Ladders and rubber hammers |
Table 2-1 is for reference only. Select appropriate tools as needed for installation.
Before installation, examine the installation site to make sure that the AP will work in a good environment. You can examine the installation site from the following two aspects.
Installation Site Selection
Keep the AP away from high temperature, dust, harmful gases, inflammables, explosive substances, electromagnetic interference sources (heavy-duty radars, radio stations, or electrical substations), unstable voltage, heavy vibration, or loud noise. The installation site should be dry, without any leakage, dripping or dew. The AP should be at least 500 m (0.31 miles) away from the seaside and should not face the direction of sea wind.
In engineering design, the site should be selected according to the network planning and technical requirements of the communications equipment, and the considerations such as climate, hydrology, geology, earthquake, electric power, and transportation.
Table 2-2 lists the operating temperature and humidity requirements.
Table 2-2 Environment specifications
Specification |
Range |
Operating temperature |
-10°C to 55°C (14°F to 131°F) |
Storage temperature |
–40°C to +70°C (–40°F to +158°F) |
Relative humidity (noncondensing) |
5% to 95% |
Power Supply
The AP supports local power supply (using a power adapter) and PoE power supply, both supporting a 48 VDC power input. Refer to Table 2-3 for details.
Table 2-3 Supported power supply modes
Power supply |
WA2610-AGN |
WA2612-AGN |
Local power supply |
l Rated voltage range: 100 VAC to 240 VAC; 50 Hz or 60 Hz l Max voltage range: 90 VAC to 264 VAC; 47 Hz to 63 Hz |
Not supported |
PoE power supply |
Supported |
Supported |
Installation Flowchart
Figure 3-1 shows the installation flowchart of the WA2600 indoor series.
Figure 3-1 Installation flowchart
l Before installing the WA2612-AGN to the wall-mounting bracket, you need to connect the network cable. Only the common network cable, rather than the shielded cable and cable with molded ends, is applicable.
l Before connecting the console cable to the WA2612-AGN for debugging or pressing the reset button, you need to remove the device from the wall-mounting bracket.
l When installing or removing the WA2612-AGN, try not press its top cover. Doing so may deform the inner antenna and affect its use.
Determine the installation position by observing the following principles:
l Leave as few obstacles (such as wall and ceiling) as possible between the AP and the wireless stations.
l Keep the AP far away from electronic devices (such as microwave ovens) that may generate RF noise.
l Install the AP in a place where it will not hinder people’s daily work and life.
l Make sure the ceiling is strong enough and the structure is suitable in case of ceiling mounting. Reinforce the ceiling if needed.
l A padlock is recommended for securing the device to the wall-mounting bracket or other solid objects, thus to prevent any falloff in case of shocks. A Blossom 071 padlock or similar padlock is recommended for the WA2610-AGN and a standard Kensington lock is recommended for the WA2612-AGN.
Installing the AP
The WA2600 indoor series support three installation methods. See Figure 3-1 for details.
Table 3-1 Supported installation methods
Installation method |
WA2610-AGN |
WA2612-AGN |
Mounting the AP on a wall |
Supported |
Supported |
Mounting the AP through the wall |
Not supported |
Supported |
Mounting the AP to a T-rail |
Not supported |
Supported |
Mounting the AP on a Wall
The following describes how to mount a WA2600 indoor series AP on a wall:
l Installing the wall-mounting bracket on the wall
l Installing the AP on the wall-mounting bracket
l Locking the AP onto the wall-mounting bracket (optional)
Step1 Place the wall-mounting bracket tightly against the wall where the AP is to be mounted and mark the locations to drill holes for installing the screws. Then use a percussion drill with a bit of 6 mm (0.24 in) in diameter to drill holes on the wall. The drilled holes must correspond to those in the wall-mounting bracket.
l There are eight installation holes (with a diameter of 6 mm, or 0.24 in) in total in the wall-mounting bracket of the WA2610-AGN. Select at least four of them for the installation.
l There are five installation holes in total in the wall-mounting bracket of the WA2612-AGN. Select the three round holes (with a diameter of 5 mm, or 0.20 in) for the installation.
l Before installation, clean dust inside and outside the holes with a dust collector and then measure the spacing of holes. If errors are not acceptable, you need to measure and drill again.
Pay attention to the following when drilling holes:
l Hold the drill handle firmly with both hands, keeping the bit perpendicular to the wall to prevent tilted holes or damage to the wall.
l The depth of the hole equals the length of the wall anchor plus the length of the drill bit. All the holes should have the same depth. Clean the holes before measuring their net depth. When drilling, you can use the dust collector to avoid dust spreading.
l The bit is difficult to position on hard, smooth surfaces. In this case, punch a small hole on every mounting-hole mark before drilling.
Figure 3-2 Screw hole locations and screw hole size of the WA2610-AGN wall-mounting bracket (in mm)
Figure 3-3 Screw hole locations and screw hole size of the WA2612-AGN wall-mounting bracket (in mm)
Step2 Insert the pointed end of wall anchors into the drilled holes and tap the flat end of wall anchors with a rubber hammer until they are all flush with the wall surface.
Step3 Align the holes in the wall-mounting bracket with the wall anchors and insert screws through the installation holes into the wall anchors, as shown in Figure 3-4 and Figure 3-5.
Step4 Adjust the position of the wall-mounting bracket and tighten the screws.
Figure 3-4 Install the wall-mounting bracket of the WA2610-AGN
Figure 3-5 Install the wall-mounting bracket of the WA2612-AGN
Install the wall-mounting bracket with the arrow on the bracket pointing upwards.
Step1 Align the AP with the key-hole clips on the wall-mounting bracket and hang the AP on the bracket. See callout 1 in Figure 3-6 and Figure 3-7.
Step2 Press or rotate the AP to fix it. See callout 2 in Figure 3-6
and Figure 3-7. Fix the
-shaped holes on the AP’s rear panel to
the key-hole clips on the wall-mounting bracket.
Figure 3-6 Fix the WA2610-AGN onto the wall-mounting bracket
Figure 3-7 Fix the WA2612-AGN onto the wall-mounting bracket
l When installing the WA2610-AGN, you are recommended to arrange the three antennae in a rectangular order, as shown in Figure 3-6.
l Rotating the WA2612-AGN clockwise installs the device, while rotating it counterclockwise uninstalls it.
1) The WA2610-AGN has a security slot on the top, which can be used to lock the AP onto the wall-mounting bracket to prevent theft. Follow these steps to lock the AP onto the wall-mounting bracket:
Step1 Insert the locking plate into the security slot on the top of the AP. See callout 1 in Figure 3-8.
Step2 Turn the locking plate counterclockwise until the hole on the locking plate is aligned with the hole in the wall-mounting bracket. See callout 2 in Figure 3-8.
Step3 Put the latch through the two holes that are aligned in step 2. See callout 3 in Figure 3-8.
Step4 Lock the latch with a lock.
Figure 3-8 Lock the WA2610-AGN onto the wall-mounting bracket
2) The WA2612-AGN has a security slot on the upper left side, which can be used to lock the AP to a fixed object to prevent theft. Follow these steps to lock the AP to a fixed object:
Step1 Fix the security cable to a nearby fixed object.
Step2 Insert the locking plate in the security slot to lock the AP.
Figure 3-9 Lock the WA2612-AGN to a fixed object
The lock is user supplied.
l This installation method requires that the thickness of the wall or the ceiling be less than 18 mm (0.71 in), and the wall or the ceiling bear a weight of at least 5 kg (11.02 lb.).
l You are not recommended to use this method to mount the AP to a location made of low-intensity materials such as a plaster ceiling. If this installation method is required in such an environment, put a high-intensity plate beneath the nut to secure the installation.
Select the two installation holes of the wall-mounting bracket as shown in Figure 3-10 to mount the AP through the wall. Follow these steps to mount the AP through the wall:
Step1 Drill two holes on the wall or ceiling corresponding to the two installation holes on the wall-mounting bracket.
Figure 3-10 Installation holes on the wall-mounting bracket (in mm)
Step2 Insert the bolts through the installation holes of the wall-mounting bracket and the drilled holes on the wall (or ceiling), and then tighten the nuts of the bolts on the other side of the wall (or ceiling) to secure the wall-mounting bracket, as shown in Figure 3-11.
Figure 3-11 Mount the wall-mounting bracket through the wall
Step3 Mount the WA2612-AGN to the wall-mounting bracket. For details, refer to Installing the AP on the wall-mounting bracket.
Mounting the AP to a T-Rail
l It is required that the width of the T-rail be in the range of 14 mm (0.55 in) to 24 mm (0.94).
l This installation method applies only to T-rails.
Follow these steps to mount the AP to a T-rail:
Step1 Loosen the two M3 × 6 screws on each clip holder until the screw heads are lower than the upper edge of the nuts (do not remove the screws or they may get lost).
Step2 Adjust the T-rail clips to make the T-rail holder wider than the T-rail, and then lock the T-rail with the T-rail holder according to the arrow indicated in Figure 3-12.
Step3 Tighten the M3 × 6 screws on the two clip holders until the screw heads touch the T-rail, and then fix the screws.
Step4 Check whether the T-rail holder is fixed to the T-rail.
Step5 Hook the mounting clip of the wall-mounting bracket to the mounting hook of the T-rail holder, as shown Figure 3-13.
Step6 Insert the two M4 × 8 screws through the two holes (with a diameter of 5 mm, or 0.20 in) on the wall-mounting bracket according to the dashed line shown in Figure 3-13 and fix the screws to the T-rail holder.
Step7 Check whether the wall-mounting bracket is fixed to the T-rail.
Step8 Install the WA2612-AGN to the wall-mounting bracket. For details, refer to Installing the AP on the wall-mounting bracket.
Figure 3-13 Mount the AP to the T-rail
Connecting the Power Cords
You can provide power supply to the AP through a PoE module (or PoE-capable switch), or you can connect the AP to the power source through the power adapter.
Table 3-2 Supported power supply methods
Product model |
External PoE power supply |
WA2610-AGN |
Supported |
Supported |
WA2612-AGN |
Supported |
Not supported |
Power over Ethernet
If the uplink device of the WA2600 indoor series is a PoE-capable switch or the like, use an Ethernet cable to connect the Ethernet interface of the AP to the PoE-capable device.
l You only need to connect one end of an Ethernet cable to the Ethernet interface of the AP and the other end to an Ethernet interface of the PoE-capable device (for example, an Ethernet switch).
l Identify the silkscreen on the device to avoid taking the console interface for the Ethernet interface, or vice versa.
Local Power Supply
You can connect a power adapter to the local power interface on the WA2610-AGN to implement local power supply.
The Ethernet interface of the WA2600 indoor series can be connected to the Ethernet interface of an Ethernet switch to access the Internet, as shown in Figure 3-15.
Figure 3-15 Connect the AP to the network
