Title | Size | Downloads |
14-MAC Address Table Management Operation.pdf | 125.57 KB |
14-MAC Address Table Management Operation | 125.57 KB |
Table of Contents
1 MAC Address Table Management
Introduction to MAC Address Table
Introduction to MAC Address Learning
MAC Address Table Management Configuration Task List
Configuring a MAC Address Entry
Setting the MAC Address Aging Timer
Setting the Maximum Number of MAC Addresses a Port Can Learn
Disabling MAC Address learning for a VLAN
Assigning MAC Addresses for Ethernet Ports
Displaying MAC Address Table Information
Adding a Static MAC Address Entry Manually
When configuring MAC address table management, go to these sections for information you are interested in:
l Overview
l MAC Address Table Management
l Displaying MAC Address Table Information
This chapter describes the management of static, dynamic, and blackhole MAC address entries. For information about the management of multicast MAC address entries, refer to Multicast Operation.
Overview
An Ethernet switch is mainly used to forward packets at the data link layer, that is, transmit the packets to the corresponding ports according to the destination MAC address of the packets. To forward packets quickly, a switch maintains a MAC address table, which is a Layer 2 address table recording the MAC address-to-forwarding port association. Each entry in a MAC address table contains the following fields:
l Destination MAC address
l ID of the VLAN which a port belongs to
l Forwarding egress port number on the local switch
When forwarding a packet, an Ethernet switch adopts one of the two forwarding methods based upon the MAC address table entries.
l Unicast forwarding: If the destination MAC address carried in the packet is included in a MAC address table entry, the switch forwards the packet through the forwarding egress port in the entry.
l Broadcast forwarding: If the destination MAC address carried in the packet is not included in the MAC address table, tthe switch broadcasts the packet to all ports except the one that originally received the packet.
MAC address table entries can be updated and maintained through the following two ways:
l Manual configuration
l MAC address learning
Generally, the majority of MAC address entries are created and maintained through MAC address learning. The following describes the MAC address learning process of a switch:
1) As shown in Figure 1-1, User A and User B are both in VLAN 1. When User A communicates with User B, the packet from User A comes into the switch on Ethernet 1/0/1. At this time, the switch records the source MAC address of the packet, that is, the address MAC-A of User A to the MAC address table of the switch, forming an entry shown in Figure 1-2.
Figure 1-1 MAC address learning diagram (1)
Figure 1-2 MAC address table entry of the switch (1)
2) After learning the MAC address of User A, the switch starts to forward the packet. Because there is no MAC address and port information of User B in the existing MAC address table, the switch forwards the packet to all ports except Ethernet 1/0/1 to ensure that User B can receive the packet.
Figure 1-3 MAC address learning diagram (2)
3) Because the switch broadcasts the packet, both User B and User C can receive the packet. However, User C is not the destination device of the packet, and therefore does not process the packet. Normally, User B will respond to User A, as shown in Figure 1-4. When the response packet from User B comes into the switch on Ethernet 1/0/4, the switch records the association between the MAC address of User B and the corresponding port to the MAC address table of the switch.
Figure 1-4 MAC address learning diagram (3)
4) At this time, the MAC address table of the switch includes two forwarding entries shown in Figure 1-5. When forwarding the response packet from User B to User A, the switch sends the response to User A through Ethernet 1/0/1 (technically called unicast), because MAC-A is already in the MAC address table.
Figure 1-5 MAC address table entries of the switch (2)
5) After this interaction, the switch sends packets destined for User A and User B in unicast mode based on the corresponding MAC address table entries.
l Under some special circumstances, for example, User B is unreachable or User B receives the packet but does not respond to it, the switch cannot learn the MAC address of User B. Hence, the switch still broadcasts the packets destined for User B.
l The switch learns only unicast addresses by using the MAC address learning mechanism but directly drops any packet with a broadcast source MAC address.
Managing MAC Address Table
Aging of MAC address table
To fully utilize a MAC address table, which has a limited capacity, the switch uses an aging mechanism for updating the table. That is, the switch starts an aging timer for an entry when dynamically creating the entry. The switch removes the MAC address entry if no more packets with the MAC address recorded in the entry are received within the aging time.
The MAC address aging timer only takes effect on dynamic MAC address entries.
Entries in a MAC address table
Entries in a MAC address table fall into the following categories according to their characteristics and configuration methods:
l Static MAC address entry: Also known as permanent MAC address entry. This type of MAC address entries are added/removed manually by the network operator and cannot age out by themselves. Using static MAC address entries can greatly reduce broadcast packets and are suitable for networks where network devices seldom change.
l Dynamic MAC address entry: This type of MAC address entries age out after the configured aging time. They are generated by the MAC address learning mechanism or configured manually.
l Blackhole MAC address entry: This type of MAC address entries are configured manually. A switch discards the packets destined for or originated from the MAC addresses contained in blackhole MAC address entries. Blackhole entries are configured for filtering out frames with specific source or destination MAC addresses.
Table 1-1 lists the different types of MAC address entries and their characteristics.
Table 1-1 Characteristics of different types of MAC address entries
MAC address entry |
Configuration method |
Aging time |
Reserved or not at reboot (if the configuration is saved) |
Static MAC address entry |
Manually configured |
Unavailable |
Yes |
Dynamic MAC address entry |
Manually configured or generated by MAC address learning mechanism |
Available |
No |
Blackhole MAC address entry |
Unavailable |
Yes |
Complete the following tasks to configure MAC address table management:
Task |
Remarks |
Required |
Optional |
Setting the Maximum Number of MAC Addresses a Port Can Learn |
Optional |
Optional |
Optional |
You can add, modify, or remove a MAC address entry, remove all MAC address entries concerning a specific port, or remove specific type of MAC address entries (dynamic or static MAC address entries).
You can add a MAC address entry in either system view or Ethernet port view.
Adding a MAC address entry in system view
Follow these steps to add a MAC address entry in system view:
To do… |
Use the command… |
Remarks |
Enter system view |
system-view |
Add a MAC address entry |
mac-address { static | dynamic | blackhole } mac-address interface interface-type interface-number vlan vlan-id |
Required |
l When you add a MAC address entry, the port specified by the interface argument must belong to the VLAN specified by the vlan argument in the command. Otherwise, you will fail to add this MAC address entry. By default, all ports belong to VLAN 1..
l If the VLAN specified by the vlan argument is a dynamic VLAN, after a static MAC address is added, it will become a static VLAN.
Adding a MAC address entry in Ethernet port view
Follow these steps to add a MAC address entry in Ethernet port view:
To do… |
Use the command… |
Remarks |
Enter system view |
system-view |
Enter Ethernet port view |
mac-address { static | dynamic | blackhole } mac-address vlan vlan-id |
Required |
l When you add a MAC address entry, the current port must belong to the VLAN specified by the vlan argument in the command. Otherwise, the entry will not be added.
Setting an appropriate MAC address aging timer is important for the switch to run efficiently.
l If the aging timer is set too long, excessive invalid MAC address entries maintained by the switch may fill up the MAC address table. This prevents the MAC address table from being updated with network changes in time.
l If the aging timer is set too short, the switch may remove valid MAC address entries. This decreases the forwarding performance of the switch.
Follow these steps to set aging time of MAC address entries:
To do… |
Use the command… |
Remarks |
Enter system view |
system-view |
Set the MAC address aging timer |
mac-address timer { aging age | no-aging } |
Required The default is 300 seconds. |
The capacity of the MAC address table on a switch is limited. After the limit is reached, the switch will forward the frames received with unknown source MAC addresses without learning MAC addresses. In case the MAC address table gets full, you can tune the aging timer to a smaller value to speed up MAC address entry aging so that new MAC addresses can be learned.
Normally, you are recommended to use the default aging timer, namely, 300 seconds. The no-aging keyword specifies that MAC address entries never age out.
MAC address aging configuration applies to all ports, but only takes effect on dynamic MAC addresses, which are either learnt or configured.
The MAC address learning mechanism enables an Ethernet switch to acquire the MAC addresses of the network devices on the segment connected to the ports of the switch. By searching the MAC address table, the switch directly forwards the packets destined for these MAC addresses through the hardware, improving the forwarding efficiency. A MAC address table too big in size may prolong the time for searching MAC address entries, thus decreasing the forwarding performance of the switch.
By setting the maximum number of MAC addresses that can be learned from individual ports, the administrator can control the number of the MAC address entries the MAC address table can dynamically maintain. When the number of the MAC address entries learnt from a port reaches the set value, the port stops learning MAC addresses.
Follow these steps to set the maximum number of MAC addresses a port can learn:
To do… |
Use the command… |
Remarks |
Enter system view |
system-view |
Set the maximum number of MAC addresses the port can learn |
mac-address max-mac-count count |
Required By default, the number of the MAC addresses a port can learn is not limited. |
If you have configured the maximum number of MAC addresses that a port can learn, you cannot enable the MAC address authentication or port security functions on the port, and vice versa.
The contents of this section are only applicable to the S3100-EI series among S3100 series switches.
You can disable a switch from learning MAC addresses in specific VLANs to improve stability and security for the users belong to these VLANs and prevent unauthorized accesses.
Table 1-2 Disable MAC address learning for a VLAN
Operation |
Command |
Enter system view |
system-view |
Enter VLAN view |
vlan vlan-id |
Disable the switch from learning MAC addresses in the VLAN |
mac-address max-mac-count 0 |
Required By default, a switch learns MAC addresses in any VLAN. |
l If the VLAN is configured as a remote probe VLAN used by port mirroring, you can not disable MAC address learning of this VLAN. Similarly, after you disable MAC address learning, this VLAN can not be configured as a remote probe VLAN.
l Disabling the MAC address learning function of a VLAN takes no effect on enabling the MAC address authentication on the ports that belong to the VLAN.
By default, no Ethernet port of an S3100 switch is configured with a MAC address. Therefore, when the switch sends Layer 2 protocol packets, for example, BPDUs of STP, it uses the MAC address predefined in the protocol as the source address to send the BPDUs. As switches in your network may use the same source MAC address for Layer 2 protocol data units (PDUs), different ports on a switch may learn the same MAC address, thus affecting the maintenance of the MAC address table.
To avoid the problem, you are allowed to assign MAC addresses to the Ethernet ports on an S3100 series switch. The idea is to assign a MAC address (called the start port MAC address) for the start Ethernet port, that is, Ethernet 1/0/1, and each of the following ports uses the MAC address of the preceding port plus 1 as its MAC address.
For example, if you configure 000f-e200-0001 as the start port MAC address, then port Ethernet 1/0/2 will take MAC address 000f-e200-0002, and so on.
Follow these steps to configure the start port MAC address:
To do… |
Use the command… |
Remarks |
Enter system view |
system-view |
Configure the start port MAC address |
port-mac start-mac-address |
Required No start port MAC address is configured by default. |
The start port MAC address must be a valid unicast address.
With the port MAC address configuration, the switch uses the MAC address of a port as the source MAC address when sending the following Layer 2 PDUs out of the port:
l LACP
l STP
l NDP/NTDP
l GVRP
l DLDP
Port MAC address configuration does not affect service packet forwarding.
To do… |
Use the command… |
Remarks |
Display information about the MAC address table |
display mac-address [ display-option ] |
Available in any view |
Display the aging time of the dynamic MAC address entries in the MAC address table |
display mac-address aging-time |
Display the configured start port MAC address |
display port-mac |
Configuration Example
Network requirements
The server connects to the switch through Ethernet 1/0/2. To prevent the switch from broadcasting packets destined for the server, it is required to add the MAC address of the server to the MAC address table of the switch, which then forwards packets destined for the server through Ethernet 1/0/2.
l The MAC address of the server is 000f-e20f-dc71.
l Port Ethernet 1/0/2 belongs to VLAN 1.
l Suppose the MAC address of a host is 000f-e235-abcd and belongs to VLAN 1. Because the host once behaved suspiciously on the network, you can add a blackhole MAC address entry for the MAC address to drop all packets destined for the host for security sake.
Configuration procedure
# Enter system view.
[Sysname]
# Add a MAC address, with the VLAN, ports, and states specified.
[Sysname] mac-address static 000f-e20f-dc71 interface Ethernet 1/0/2 vlan 1
# Add a black hole MAC address 000f-e235-abcd, with the VLAN and ports specified.
[Sysname] mac-address blackhole 000f-e235-abcd interface Ethernet 1/0/2 vlan 1
# Display information about the current MAC address table.
[Sysname] display mac-address interface Ethernet 1/0/2
MAC ADDR VLAN ID STATE PORT INDEX AGING TIME(s)
000f-e20f-dc71 1 Config static Ethernet1/0/2 NOAGED
000f-e235-abcd 1 Blackhole Ethernet1/0/2 NOAGED
000f-e20f-a7d6 1 Learned Ethernet1/0/2 AGING
000f-e20f-b1fb 1 Learned Ethernet1/0/2 AGING
000f-e20f-f116 1 Learned Ethernet1/0/2 AGING
--- 4 mac address(es) found on port Ethernet1/0/2 ---
