H3C S3100 Series Ethernet Switches Operation Manual-Release 21XX Series(V1.06)
HomeSupportSwitchesH3C S3100 Switch SeriesConfigure & DeployConfiguration GuidesH3C S3100 Series Ethernet Switches Operation Manual-Release 21XX Series(V1.06)
Title Size Downloads
00-1Cover.pdf 75.59 KB
00-1Cover
00-1Cover 75.59 KB
Operation Manual
Hangzhou H3C Technologies Co., Ltd.
http://www.h3c.com
Manual Version: 20090710-C-1.06
Copyright © 2007-2009, Hangzhou H3C Technologies Co., Ltd. and its licensors
All Rights Reserved
No part of this manual may be reproduced or transmitted in any form or by any means without prior written consent of Hangzhou H3C Technologies Co., Ltd.
Trademarks
H3C, Adobe Systems, Aolynk, , H3Care, , TOP G, , IRF, NetPilot, Neocean, NeoVTL, SecPro, SecPoint, SecEngine, SecPath, Comware, Secware, Storware, NQA, VVG, V2G, VnG, PSPT, XGbus, N-Bus, TiGem, InnoVision and HUASAN are trademarks of Hangzhou H3C Technologies Co., Ltd.
All other trademarks that may be mentioned in this manual are the property of their respective owners.
Notice
The information in this document is subject to change without notice. Every effort has been made in the preparation of this document to ensure accuracy of the contents, but all statements, information, and recommendations in this document do not constitute the warranty of any kind, express or implied.
Technical Support
[email protected]
http://www.h3c.com
About This Manual
Organization
H3C S3100 Series Ethernet Switches Operation Manual is organized as follows:
Part
0 Product Overview
Introduces the characteristics and implementations of the Ethernet switch.
1 CLI
Introduces the command hierarchy, command view and CLI features of the Ethernet switch.
2 Login
Introduces the ways to log into an Ethernet switch.
3 Configuration File Management
Introduces the ways to manage configuration files.
4 VLAN
Introduces VLAN fundamental and the related configuration.
5 Management VLAN
Introduces the management VLAN configuration.
6 IP Address-IP Performance
Introduces IP address and IP performance fundamental and the related configuration.
7 Voice VLAN
Introduces voice VLAN fundamental and the related configuration.
8 GVRP
Introduces GVRP and the related configuration.
9 Port Basic Configuration
Introduces basic port configuration.
10 Link Aggregation
Introduces link aggregation and the related configuration.
11 Port Isolation
Introduces port isolation and the related configuration.
12 Port Security-Port Binding
Introduces port security, port binding, and the related configuration.
13 DLDP
Introduces DLDP and the related configuration.
14 MAC Address Table Management
Introduces MAC address forwarding table and the related configuration.
15 MSTP
Introduces STP and the related configuration.
16 Multicast
Introduces the configuration of IGMP Snooping.
17 802.1x-System Guard
Introduces 802.1x, System-Guard and the related configuration.
18 AAA
Introduces AAA, RADIUS, HWTACACS, EAD, and the related configurations.
19 MAC Address Authentication
Introduces MAC address authentication and the related configuration.
20 ARP
Introduces ARP and the related configuration.
21 DHCP
Introduces DHCP, DHCP-Snooping, and the related configurations.
22 ACL
Introduces ACL and the related configuration.
23 QoS-QoS Profile
Introduces QoS, QoS profile and the related configuration.
24 Mirroring
Introduces port mirroring and the related configuration.
25 Stack-Cluster
Introduces the configuration to form clusters using HGMP V2.
26 PoE-PoE Profile
Introduces PoE, PoE profile and the related configuration.
27 SNMP-RMON
Introduces the configuration to manage network devices through SNMP and RMON.
28 NTP
Introduces NTP and the related configuration.
29 SSH
Introduces SSH and the related configuration.
30 File System Management
Introduces basic configuration for file system management.
31 FTP-SFTP-TFTP
Introduces basic configuration for FTP, SFTP, TFTP, and the applications.
32 Information Center
Introduces the configuration to analyze and diagnose networks using the information center.
33 System Maintenance and Debugging
Introduces daily system maintenance and debugging.
34 VLAN-VPN
Introduces VLAN VPN and the related configuration.
35 HWPing
Introduces HWPing and the related configuration.
36 IPv6 Management
Introduces IPv6 Management and the related configuration.
37 DNS
Introduces DNS and the related configuration.
38 Smart Link-Monitor Link
Introduces Smart Link, Monitor Link and the related configuration.
39 Appendix
Lists the acronyms used in this manual.
Conventions
The manual uses the following conventions:
Command conventions
Convention
Boldface
The keywords of a command line are in Boldface.
italic
Command arguments are in italic.
Items (keywords or arguments) in square brackets [ ] are optional.
{ x | y | ... }
Alternative items are grouped in braces and separated by vertical bars. One is selected.
[ x | y | ... ]
Optional alternative items are grouped in square brackets and separated by vertical bars. One or none is selected.
{ x | y | ... } *
Alternative items are grouped in braces and separated by vertical bars. A minimum of one or a maximum of all can be selected.
[ x | y | ... ] *
Optional alternative items are grouped in square brackets and separated by vertical bars. Many or none can be selected.
&<1-n>
The argument(s) before the ampersand (&) sign can be entered 1 to n times.
A line starting with the # sign is comments.
GUI conventions
Convention
Boldface
Window names, button names, field names, and menu items are in Boldface. For example, the New User window appears; click OK.
Symbols
Convention
Means reader be extremely careful. Improper operation may cause bodily injury.
Means reader be careful. Improper operation may cause data loss or damage to equipment.
Means an action or information that needs special attention to ensure successful configuration or good performance.
Means a complementary description.
Means techniques helpful for you to make configuration with ease.
Related Documentation
In addition to this manual, each H3C S3100 Series Ethernet Switches documentation set includes the following:
Manual
H3C S3100 Series Ethernet Switches  Installation Manual
It provides information for the system installation.
H3C S3100 Series Ethernet Switches  Command Manual
It is used for assisting the users in using various commands.
H3C S3100 Series Ethernet Switches  Compliance and Safety Manual
It lists the regulatory compliance statements and provides the safety information of H3C S3100 series Ethernet switches.
Obtaining Documentation
You can access the most up-to-date H3C product documentation on the World Wide Web at this URL: http://www.h3c.com.
The following are the columns from which you can obtain different categories of product documentation:
[Products & Solutions]: Provides information about products and technologies, as well as solutions.
[Technical Support & Document > Technical Documents]: Provides several categories of product documentation, such as installation, configuration, and maintenance.
[Technical Support & Document > Software Download]: Provides the documentation released with the software version.
Documentation Feedback
We appreciate your comments.
