H3C S3100 Series Ethernet Switches Installation Manual-(V1.06)
HomeSupportSwitchesS3100 SeriesInstall & UpgradeInstallation GuidesH3C S3100 Series Ethernet Switches Installation Manual-(V1.06)
00-1Cover
00-1Cover 67.03 KB
Installation Manual
Hangzhou H3C Technologies Co., Ltd.
http://www.h3c.com
Manual Version: 20090601-C-1.06
Copyright © 2007-2009, Hangzhou H3C Technologies Co., Ltd. and its licensors
All Rights Reserved
No part of this manual may be reproduced or transmitted in any form or by any means without prior written consent of Hangzhou H3C Technologies Co., Ltd.
Trademarks
H3C, Adobe Systems, Aolynk, , H3Care, , TOP G, , IRF, NetPilot, Neocean, NeoVTL, SecPro, SecPoint, SecEngine, SecPath, Comware, Secware, Storware, NQA, VVG, V2G, VnG, PSPT, XGbus, N-Bus, TiGem, InnoVision and HUASAN are trademarks of Hangzhou H3C Technologies Co., Ltd.
All other trademarks that may be mentioned in this manual are the property of their respective owners.
Notice
The information in this document is subject to change without notice. Every effort has been made in the preparation of this document to ensure accuracy of the contents, but all statements, information, and recommendations in this document do not constitute the warranty of any kind, express or implied.
Technical Support
[email protected]
http://www.h3c.com
About This Manual
Organization
H3C S3100 Series Ethernet Switches Installation Manual is organized as follows:
Chapter
1 Product Introduction
Introduces the characteristics and technical specifications of S3100 Series Ethernet Switches.
2 Installation Preparation
Introduces the installation preparation and precaution of S3100 Series Ethernet Switches.
3 Installation
Introduces the procedures to install an S3100 Series Ethernet Switch, including the setup of the mainframe, cards and cables.
4 First Power-on
Introduces the booting process of an S3100 Series Ethernet Switch, including the power-on booting of the switch and the system initialization.
5 Boot ROM and Host Software Loading
Introduces how to load Boot ROM and host software for an S3100 Series Ethernet Switch.
6 Maintenance and Troubleshooting
Introduces the problems that might occur during the installation and the booting of an S3100 Series Ethernet Switch and the related solution.
7 Appendix Lightning Protection of the Switch
Introduces lightning protection of S3100 Series Ethernet Switches.
Conventions
The manual uses the following conventions:
Command conventions
Convention
Boldface
The keywords of a command line are in Boldface.
italic
Command arguments are in italic.
Items (keywords or arguments) in square brackets [ ] are optional.
{ x | y | ... }
Alternative items are grouped in braces and separated by vertical bars. One is selected.
[ x | y | ... ]
Optional alternative items are grouped in square brackets and separated by vertical bars. One or none is selected.
{ x | y | ... } *
Alternative items are grouped in braces and separated by vertical bars. A minimum of one or a maximum of all can be selected.
[ x | y | ... ] *
Optional alternative items are grouped in square brackets and separated by vertical bars. Many or none can be selected.
&<1-n>
The argument(s) before the ampersand (&) sign can be entered 1 to n times.
A line starting with the # sign is comments.
GUI conventions
Convention
Button names are inside angle brackets. For example, click <OK>.
Window names, menu items, data table and field names are inside square brackets. For example, pop up the [New User] window.
Multi-level menus are separated by forward slashes. For example, [File/Create/Folder].
Symbols
Convention
Means reader be extremely careful. Improper operation may cause bodily injury.
Means reader be careful. Improper operation may cause data loss or damage to equipment.
Means an action or information that needs special attention to ensure successful configuration or good performance.
Means a complementary description.
Means techniques helpful for you to make configuration with ease.
Related Documentation
In addition to this manual, each H3C S3100 Series Ethernet Switches documentation set includes the following:
Manual
H3C S3100 Series Ethernet Switches  Operation Manual
It is used for assisting the users in data configurations and typical applications.
H3C S3100 Series Ethernet Switches  Command Manual
It is used for assisting the users in using various commands.
Obtaining Documentation
You can access the most up-to-date H3C product documentation on the World Wide Web at this URL: http://www.h3c.com.
The following are the columns from which you can obtain different categories of product documentation:
[Products & Solutions]: Provides information about products and technologies.
[Technical Support & Document > Technical Documents]: Provides several categories of product documentation, such as installation, configuration, and maintenance.
[Technical Support & Document > Software Download]: Provides the documentation released with the software version.
Documentation Feedback
We appreciate your comments.
Environmental Protection
This product has been designed to comply with the requirements on environmental protection. For the proper storage, use and disposal of this product, national laws and regulations must be observed.
