H3C S9500 Command Manual-Release1648[v1.24]-06 QoS ACL Volume
HomeSupportSwitchesH3C S9500 Series SwitchesReference GuidesCommand ReferencesH3C S9500 Command Manual-Release1648[v1.24]-06 QoS ACL Volume
00-1Cover
00-1Cover 68.71 KB
H3C S9500 Series Routing Switches
Command Manual
Hangzhou H3C Technologies Co., Ltd.
http://www.h3c.com
Manual Version: T2-08194S-20081225-C-1.24
Product Version: S9500-CMW310-R1648
Copyright © 2007-2008, Hangzhou H3C Technologies Co., Ltd. and its licensors
All Rights Reserved
No part of this manual may be reproduced or transmitted in any form or by any means without prior written consent of Hangzhou H3C Technologies Co., Ltd.
Trademarks
H3C, Adobe Systems, Aolynk, , H3Care, , TOP G, , IRF, NetPilot, Neocean, NeoVTL, SecPro, SecPoint, SecEngine, SecPath, Comware, Secware, Storware, NQA, VVG, V2G, VnG, PSPT, XGbus, N-Bus, TiGem, InnoVision and HUASAN are trademarks of Hangzhou H3C Technologies Co., Ltd.
All other trademarks that may be mentioned in this manual are the property of their respective owners.
Notice
The information in this document is subject to change without notice. Every effort has been made in the preparation of this document to ensure accuracy of the contents, but all statements, information, and recommendations in this document do not constitute the warranty of any kind, express or implied.
Technical Support
[email protected]
http://www.h3c.com
About This Manual
Organization
H3C S9500 Series Routing Switches Command Manual is organized as follows:
Part
00 Feature List and Command Index
includes Feature List and Command Index.
01 Access Volume
includes Ethernet Port Commands, POS Port Configuration Commands, Link Aggregation Configuration Commands, Port Isolation Configuration Commands, VLAN Commands, MAC Address Table Management Commands, GVRP Commands, QinQ Commands, Port Loopback Detection Commands, DLDP Commands, Ethernet OAM Commands, Smart Link and Monitor Link Commands, MSTP Commands, BPDU Tunnel Commands, HVRP Commands, RRPP Commands and RPR Commands.
02 IP Services Volume
includes ARP Commands, IP Address Commands, VRRP Commands, DHCP Commands, DNS Commands, UDP Helper Commands, NAT Commands, IP Performance Commands and URPF Commands.
03 IP Routing Volume
includes Static Route Commands, RIP Commands, OSPF Commands, ISIS Commands, BGP Commands, Routing Policy Commands, Route Capacity Configuration Commands and Recursive Routing Commands.
04 IP Multicast Volume
includes Common Multicast Configuration Commands, IGMP Snooping Configuration Commands, IGMP Configuration Commands, PIM Commands, Multicast VLAN Commands, MSDP Commands and MBGP Commands.
05 MPLS VPN Volume
includes MPLS Commands, MPLS VLL Commands, MPLS VPLS Commands, MPLS L3VPN Commands and MPLS OAM Commands.
06 QoS ACL Volume
includes QoS Commands and ACL Commands.
07 Security Volume
includes Protocol Port Security Commands, 802.1x Commands, AAA RADIUS HWTACACS Commands, Password Control Commands, SSH Commands, IDS Linkage Commands, Portal Commands, VBAS Commands and Traffic Accounting Commands.
08 System Volume
includes Command Line Interface Commands, Login and User Interface Commands, FTP and TFTP Commands, HA Commands, NQA Commands, NetStream Commands, NTP Commands, RMON Commands, SNMP Commands, Packet Statistics Accounting Commands, Device Management Commands, Configuration File Management Commands, File System Management Commands, Cluster Management Commands, System Maintenance and Debugging Commands, Information Center Commands, PoE Commands, Clock Module Commands, ACSEI Server Commands, and OAP Module Commands.
Conventions
The manual uses the following conventions:
I. Command conventions
Convention
Boldface
The keywords of a command line are in Boldface.
italic
Command arguments are in italic.
Items (keywords or arguments) in square brackets [ ] are optional.
{ x | y | ... }
Alternative items are grouped in braces and separated by vertical bars. One is selected.
[ x | y | ... ]
Optional alternative items are grouped in square brackets and separated by vertical bars. One or none is selected.
{ x | y | ... } *
Alternative items are grouped in braces and separated by vertical bars. A minimum of one or a maximum of all can be selected.
[ x | y | ... ] *
Optional alternative items are grouped in square brackets and separated by vertical bars. Many or none can be selected.
&<1-n>
The argument(s) before the ampersand (&) sign can be entered 1 to n times.
A line starting with the # sign is comments.
II. GUI conventions
Convention
Button names are inside angle brackets. For example, click <OK>.
Window names, menu items, data table and field names are inside square brackets. For example, pop up the [New User] window.
Multi-level menus are separated by forward slashes. For example, [File/Create/Folder].
III. Symbols
Convention
  Warning
Means reader be extremely careful. Improper operation may cause bodily injury.
  Caution
Means reader be careful. Improper operation may cause data loss or damage to equipment.
&  Note
Means a complementary description.
Related Documentation
In addition to this manual, each H3C S9500 Series Routing Switches documentation set includes the following:
Manual
H3C S9500 Series Routing Switches  Installation Manual
It introduces the installation procedure, commissioning, maintenance and monitoring of the S9500 series routing switches.
H3C S9500 Series Routing Switches  Operation Manual
It includes Product Overview, Access Volume, IP Service Volume, IP Routing Volume, IP Multicast Volume, MPLS VPN Volume, QoS ACL Volume, Security Volume, System Volume and Acronyms.
Obtaining Documentation
You can access the most up-to-date H3C product documentation on the World Wide Web at this URL: http://www.h3c.com.
The following are the columns from which you can obtain different categories of product documentation:
[Products & Solutions]: Provides information about products and technologies.
[Technical Support & Document > Technical Documents]: Provides several categories of product documentation, such as installation and operation.
[Technical Support & Document > Product Support > Software]: Provides the documentation released with the software version.
Documentation Feedback
We appreciate your comments.
