H3C S9500 Command Manual-Release1648[v1.24]-03 IP Routing Volume
HomeSupportSwitchesS9500 SwitchesReference GuidesCommand ReferencesH3C S9500 Command Manual-Release1648[v1.24]-03 IP Routing Volume
02-RIP Commands
02-RIP Commands 78.39 KB
Chapter 1  RIP Configuration Commands
&  Note:
When a switch runs a routing protocol, it can perform the router functions. The term “router” or the router icon in this document refers to a router in a generic sense or an S9500 switch running routing protocols.
1.1  RIP Configuration Commands
1.1.1  checkzero
checkzero
undo checkzero
View
RIP view
None
Use the checkzero command to check the zero field of RIPv1 packet.
Use the undo checkzero command to disable the checking of the zero fields.
By default, RIPv1 performs zero field check.
According to the protocol specifications (RFC1058), some fields in RIPv1 packets must be zero, called zero fields. You can use the checkzero command to enable the zero field check operation on RIPv1 packet. During the zero field check operation, if a RIPv1 packet whose zero fields are not zeros is received, it will be rejected.
This command does not take effect on RIPv2 since RIPv2 packets have no zero fields.
# Disable zero field checking for RIPv1 packets.
[H3C-rip] undo checkzero
1.1.2  default cost
default cost value
undo default cost
View
RIP view
value: Default routing cost to be set, ranging from 1 to 16. The default value is 1.
Use default cost command to set the default routing cost of an imported route.
Use the undo default cost command to restore the default value.
If no specific routing cost is specified when importing the route of another routing protocol with the import-route command, the redistribution will be performed with the default routing cost specified with the default cost command.
Related commands: import-route.
# Set the default routing cost of the imported route of another routing protocol to 3.
[H3C-rip] default cost 3
1.1.3  display rip
display rip [ routing | vpn-instance ]
View
routing: Displays RIP routing information.
vpn-instance: Displays VPN instance information.
Use the display rip command to display the current RIP running state and its configuration information.
# Display the current running state and configuration information of RIP.
<H3C> display rip
RIP is running
  public net VPN-Instance
    Checkzero is on         Default cost : 1
    Summary is on          Preference : 100
    Traffic-share is off
    Period update timer : 30
    Timeout timer : 180
    Garbage-collection timer : 120
    No peer router
    Network :
    202.38.168.0
Table 1-1 Description on the fields of the display rip command
RIP is running
RIP is active.
Public network in the VPN
Checkzero is on
Zero field checking is enabled.
Default cost : 1
The default route cost is 1.
Summary is on
Routes are summarized automatically.
Preference : 100
The preference of RIP is 100.
Load balancing state for the interface
Timeout timer : 180
Three timers of RIP
No peer router
No destination address of a transmission is specified.
Network :202.38.168.0
RIP is enabled on network segment 202.38.168.0.
1.1.4  filter-policy export
filter-policy { acl-number | ip-prefix ip-prefix-name } export [ routing-protocol ]
undo filter-policy { acl-number | ip-prefix ip-prefix-name } export [ routing-protocol ]
View
RIP view
acl-number: Access control list (ACL) number used for filtering the destination addresses of the routing information.
ip-prefix-name: Name of address prefix list used for filtering the destination addresses of the routing information.
routing-protocol: Routing protocol whose routing information is to be filtered. It can be direct, isis, bgp, ospf, ospf-ase, ospf-nssa, nat, and static at present.
Use the filter-policy export command to configure to filter the advertised routing information by RIP.
Use the undo filter-policy export command to configure not to filter the advertised routing information.
By default, RIP does not filter the advertised routing information.
Related commands: acl, filter-policy import, ip ip-prefix.
&  Note:
If no rule is specified in the filter-policy command, all routes are denied by default.
# Filter the advertised route information with ACL 2000.
[H3C-rip] filter-policy 2000 export
1.1.5  filter-policy import
filter-policy gateway ip-prefix-name import
undo filter-policy gateway ip-prefix-name import
filter-policy { acl-number | ip-prefix ip-prefix-name [ gateway ip-prefix-name ] } import
undo filter-policy { acl-number | ip-prefix ip-prefix-name [ gateway ip-prefix-name ] } import
View
RIP view
acl-number: Specifies an ACL for filtering the destination addresses of the routing information.
gateway ip-prefix-name: Specifies the name of an address prefix list for filtering the addresses of the neighboring routers advertising the routing information.
Use the filter-policy gateway import command to configure to filter the received routing information distributed from the specified address.
Use the undo filter-policy gateway import command to configure not to filter the received routing information distributed from the specified address.
Use the filter-policy import command to configure the filtering to the received global routing information.
Use the undo filter-policy import command to disable filtering to the received global routing information
By default, RIP does not filter the received routing information.
Related commands: acl, filter-policy export, ip ip-prefix.
&  Note:
# Filter the received global routing information with ACL 2000.
[H3C-rip] filter-policy 2000 import
# Filter incoming routes from the addresses specified by IP prefix list 4.
[H3C-rip] filter-policy gateway 4 import
1.1.6  host-route
host-route
undo host-route
View
RIP view
None
Use the host-route command to enable RIP to accept the host route.
Use the undo host-route command to reject the host route.
By default, RIP accepts the host route.
In some special cases, RIP receives a great number of host routes in the same network segment. These routes do not help routing much but occupy a lot of resources. In this case, the undo host-route command can be used to reject a host route.
# Configure RIP to reject the host route.
[H3C-rip] undo host-route
1.1.7  import-route
import-route protocol [ cost value | route-policy route-policy-name ]*
undo import-route protocol
View
RIP view
protocol: Specifies the source routing protocol to be redistributed by RIP. At present, RIP can redistribute the following routes: direct, bgp, ospf, ospf-ase, ospf-nssa, isis, nat, and static. When routes are redistributed from BGP, the allow-ibgp keyword can be specified to redistribute IBGP routes.
value: Cost value of the route to be redistributed.
route-policy route-policy-name: Redistributes the route matching the condition of the specified Route-policy only.
Use the import-route command to redistribute the routes of other protocols into RIP.
Use the undo import-route command to cancel the routes redistributed from other protocols.
By default, RIP does not redistribute any other route.
The import-route command is used to redistribute the route of another protocol by using a certain cost value. RIP regards the redistributed route as its own route and transmits it with the specified cost value. This command can greatly enhance the RIP capability of obtaining routes, thus increasing the RIP performance.
If the cost value is not specified, routes will be redistributed according to the default cost ranging from 1 to 16. If the cost value of the redistributed route is 16, then RIP continues to advertise this cost to other routers running RIP, and marks this route “Hold Down”. However, this router can still forward packets until the Garbage Collection timer times out (defaults to 120 seconds).
Related commands: default cost.
# Redistribute a static route with the cost value of 4.
[H3C-rip] import-route static cost 4
# Set the default cost and redistribute an OSPF route with the default cost.
[H3C-rip] import-route ospf
# Redistribute BGP routes, including IBGP routes.
[H3C-rip] import-route bgp allow-ibgp
1.1.8  network
network network-address
undo network network-address
View
RIP view
network-address: IP address of the RIP interface. It can be the IP network address of any interface.
Use the network command to enable RIP for the specified network connected to the router.
Use the undo network command to disable RIP on the interface.
By default, all RIP interfaces are disabled.
RIP route processes are disabled on all interfaces by default. To enable a RIP route process on an interface, use the network command.
The undo network command is similar to the undo rip work command in terms of function. But they are not identical. Their similarity is that the interface using either command will not receive/transmit RIP routes. The difference between them is that, in the case of undo rip work, other interfaces will still forward the routes of the interface using the undo rip work command. In the case of undo network, other interfaces will not forward the routes of the interface using this command and it seems that the interface disappeared.
When the network command is used on an address, the effect is that the interface on the network segment at this address is enabled. For example, the results of viewing the network 129.102.1.1 with both the display current-configuration command and the display rip command are shown as the network 129.102.0.0.
Related commands: rip work.
# Enable RIP on the interface with the network address as 129.102.0.0.
[H3C-rip] network 129.102.0.0
1.1.9  peer
peer ip-address
undo peer ip-address
View
RIP view
ip-address: The interface IP address of the peer router, in dotted decimal format.
Use the peer command to configure the sending destination address of the peer device. Use the undo peer command to cancel the set destination address.
By default, no peer IP address is specified.
RIP exchanges routing information with non-broadcast networks in unicast view. This command specifies the sending destination address to fit some non-broadcast networks. Usually, it is not recommended to use this command.
# Specify to send unicast updates to peer 202.38.165.1.
[H3C-rip] peer 202.38.165.1
1.1.10  preference
preference value
undo preference
View
RIP view
value: Preference value, ranging from 1 to 255. By default, the value is 100.
Use the preference command to configure the route preference of RIP.
Use the undo preference command to restore the default preference.
Every routing protocol has its own preference. Its default value is determined by the specific routing policy. The preference will finally determine the routing algorithm to obtain the optimal route in the IP routing table. This command can be used to modify the RIP preference manually.
# Specify the RIP preference as 20.
[H3C-rip] preference 20
1.1.11  reset
reset
View
RIP view
None
Use the reset command to reset the system configuration parameters of RIP.
When you need to reconfigure parameters of RIP, this command can be used to restore to the default setting.
# Reset the RIP system.
[H3C-rip] reset
1.1.12  rip
rip
undo rip
View
system view
None
Use the rip command to enable RIP and enter RIP view.
Use the undo rip command to disable RIP.
By default, the system does not run RIP.
To enter RIP view to configure RIP global parameters, enable RIP first. But the configuration of parameters related to the interfaces is not restricted by the enabling/disabling of RIP.
&  Note:
The interface parameters configured previously would be invalid when RIP is disabled or reset.
# Enable RIP and enter RIP view.
[H3C] rip
[H3C-rip]
1.1.13  rip authentication-mode
rip authentication-mode { simple password-string | md5 { usual key-string | nonstandard key-string key-id } }
undo rip authentication-mode
View
Interface view
simple: Simple text authentication mode.
password-string: Simple text authentication key. It is a string of 1 to 16 characters.
md5: MD5 cipher text authentication mode.
usual: Specifies the MD5 cipher text authentication packet to use the general packet format (RFC1723 standard format).
key-string: MD5 cipher text authentication key. If it is input in a plain text form, the MD5 key is a string of no more than 16 characters. And it will be displayed in a cipher text form in a length of 24 characters when the display current-configuration command is executed. Inputting the MD5 key in a cipher text form with 24 characters long is also supported.
nonstandard: Specifies the MD5 cipher text authentication packet to use a nonstandard packet format described in RFC2082.
key-id: MD5 cipher text authentication identifier, ranging from 1 to 255.
Use the rip authentication-mode command to configure RIPv2 authentication mode and its parameters.
Use the undo rip authentication-mode command to cancel the RIPv2 authentication.
RIPv1 does not support authentication. There are two RIP authentication modes: simple authentication and MD5 cipher text authentication for RIPv2. When MD5 cipher text authentication mode is used, there are two types of packet formats. One of them is that described in RFC 1723, which was brought forward earlier. The other format is the one described specially in RFC 2082. The router supports both of the packet formats and the user can select either of them as required.
Related commands: rip version.
# Specify VLAN-interface 10 to use the simple authentication with the key as aaa.
[H3C] interface Vlan-interface 10
[H3C-Vlan-interface10] rip version 2
[H3C-Vlan-interface10] rip authentication-mode simple aaa
# Set MD5 authentication on VLAN-interface 10 with the key string as aaa and the packet type as usual.
[H3C-Vlan-interface10] rip authentication-mode md5 usual aaa
1.1.14  rip input
rip input
undo rip input
View
Interface view
None
Use the rip input command to allow an interface to receive RIP packets.
Use the undo rip input command to disable an interface from receiving RIP packets.
By default, all interfaces except loopback interfaces are enabled to receive RIP packets.
This command is used in cooperation with two other commands: rip output and rip work. Functionally, the rip work command is equivalent to the rip input command and the rip output command. The latter two control the receipt and the transmission of RIP packets respectively on an interface. The former command equals the functional combination of the latter two commands.
Related commands: rip output, rip work.
# Disable VLAN-interface 10 from receiving RIP packets.
[H3C-Vlan-interface10] undo rip input
1.1.15  rip metricin
rip metricin value
undo rip metricin
View
Interface view
value: Additional route metric added when an interface receives a packet, ranging from 0 to 16. By default, the value is 0.
Use the rip metricin command to configure the additional route metric added to the route when an interface receives RIP packets.
Use the undo rip metricin command to restore the default value of this additional route metric.
Related commands: rip metricout.
# Specify the additional route metric to 2 when the interface VLAN-interface 10 receives RIP packets.
[H3C-Vlan-interface10] rip metricin 2
1.1.16  rip metricout
rip metricout value
undo rip metricout
View
Interface view
value: Additional route metric added when an interface transmits a packet, ranging from 1 to 16. By default, the value is 1.
Use the rip metricout command to configure the additional route metric to the route when an interface transmits RIP packets.
Use the undo rip metricout command to restore the default value of this additional route metric.
Related commands: rip metricin.
# Set the additional route metric to 2 when the interface VLAN-interface 10 transmits RIP packets.
[H3C-Vlan-interface10] rip metricout 2
1.1.17  rip output
rip output
undo rip output
View
Interface view
None
Use the rip output command to enable an interface to send RIP packets.
Use the undo rip output command to disable the interface from sending RIP packets.
By default, all interfaces except loopback interfaces are enabled to send RIP packets.
This command is used in cooperation with two other commands: rip input and rip work. Functionally, the rip work command is equivalent to the rip input command and the rip output command. The latter two control the receipt and the transmission of RIP packets respectively on an interface. The former command equals the functional combination of the latter two commands.
Related commands: rip input, rip work.
# Disable the interface VLAN-interface 10 from sending RIP packets.
[H3C-Vlan-interface10] undo rip output
1.1.18  rip split-horizon
rip split-horizon
undo rip split-horizon
View
Interface view
None
Use the rip split-horizon command to configure an interface to use split horizon when transmitting RIP packets.
Use undo rip split-horizon command to configure an interface not to use split horizon when transmitting RIP packets.
By default, an interface is enabled to use split horizon when transmitting RIP packets.
Normally, split horizon is necessary for reducing route loops. In some special cases, you need to disable split horizon to ensure the correct execution of protocols. Do so only when necessary.
# Disable VLAN-interface 10 from using split horizon when processing RIP packets.
[H3C-Vlan-interface10] undo rip split-horizon
1.1.19  rip version
rip version 1
rip version 2 [ broadcast | multicast ]
undo rip version
View
Interface view
1: Specifies the version of RIP packets on an interface as RIPv1.
2: Specifies the version of RIP packets on an interface as RIPv2.
broadcast: Sends RIPv2 packets in broadcast mode.
multicast: Sends RIPv2 packets in multicast mode.
Use the rip version command to configure the version of RIP packets on an interface. Use the undo rip version command to restore the default value of RIP packet version on the interface.
By default, the interface RIP version is RIPv1. RIPv1 transmits packets in broadcast mode, while RIPv2 transmits packets in multicast mode by default.
When running RIPv1, the interface only receives and transmits RIPv1 broadcast packets, and receives RIPv2 broadcast packets, but does not receive RIPv2 multicast packets. When running RIPv2 in broadcast mode, the interface only receives and transmits RIPv2 broadcast packets, receives RIPv1 packets and RIPv2 multicast packets. When running RIPv2 in multicast mode, the interface only receives and transmits RIPv2 multicast packets, receives RIPv2 broadcast packets, but does not receive RIPv1 packets.
# Configure VLAN-interface 10 to broadcast RIPv2 packets.
[H3C-Vlan-interface10] rip version 2 broadcast
1.1.20  rip work
rip work
undo rip work
View
Interface view
None
Use the rip work command to enable the running of RIP on an interface.
Use the undo rip work command to disable the running of RIP on an interface.
By default, RIP is enabled on an interface.
This command is used in cooperation with the rip input, rip output, and network commands.
Related commands: network, rip input, rip output.
# Disable RIP on VLAN-interface 10.
[H3C-Vlan-interface10] undo rip work
1.1.21  summary
summary
undo summary
View
RIP view
None
Use the summary command to configure to activate RIPv2 automatic route summarization.
Use the undo summary command to disable RIPv2 automatic route summarization.
By default, RIPv2 route summarization is used.
Automatic route summarization can be performed to reduce the routing traffic on the network as well as to reduce the size of the routing table. If RIPv2 is used, route summarization function can be disabled with the undo summary command, when it is necessary to broadcast the subnet route.
RIPv1 does not support subnet masks. Forwarding subnet route may cause ambiguity. Therefore, RIPv1 uses route summarization all the time. Thus, the undo summary command does not take effect on RIPv1.
# Set the RIP version on VLAN-interface 10 to RIPv2 and disable the route summarization function.
[H3C-Vlan-interface10] quit
[H3C] rip
[H3C-rip] undo summary
1.1.22  timers
timers { update update-timer-length | timeout timeout-timer-length } *
undo timers { update | timeout } *
View
RIP view
update-timer-length: Value of the Period Update timer, ranging from 1 to 3600 seconds. By default, it is 30 seconds.
timeout-timer-length: Value of the Timeout timer, ranging from 1 to 3600 seconds. By default, it is 180 seconds.
Use the timers command to modify the values of the three RIP timers: Period Update, Timeout, and Garbage-collection.
Use the undo timers command to restore the default settings.
By default, the values of Period Update, Timeout, and Garbage-collection timers are 30 seconds, 180 seconds, and 120 seconds respectively.
Generally, the value of Garbage-collection timer is fixed to four times of that of Period Update timer. Adjusting Period Update timer will affect Garbage-collection timer.
The modification of RIP timers is validated immediately.
Related commands: display rip.
# Set the Period Update timer and Timeout timer of RIP to 10 seconds and 30 seconds respectively.
[H3C] rip
[H3C-rip] timers update 10 timeout 30
1.1.23  traffic-share-across-interface
undo traffic-share-across-interface
View
RIP view
None
Use the traffic-share-across-interface command to enable traffic sharing across RIP interfaces; namely, distribute traffic over equivalent routes across the interfaces on a router.
Use the undo traffic-share-across-interface command to disable this function.
By default, traffic sharing across interfaces is disabled.
In the case the number of equal-cost routes reaches the upper limit:
l           With this function enabled, the newly learned equal-cost routes replace the old ones in the routing table.
l           With this function disabled, if there are equal cost routes reaching the set age time, the router will replace them with the newly learned equal cost routes. Otherwise, the router drops the equal-cost route newly learned.
# Enable traffic sharing on RIP interfaces.
<H3C> system-view
[H3C] rip
[H3C-rip] traffic-share-across-interface
