H3C S9500 Command Manual-Release1648[v1.24]-02 IP Services Volume
HomeSupportSwitchesS9500 SwitchesReference GuidesCommand ReferencesH3C S9500 Command Manual-Release1648[v1.24]-02 IP Services Volume
08-IP Performance Commands
08-IP Performance Commands 71.96 KB
Chapter 1  IP Performance Configuration Commands
1.1  IP Performance Configuration Commands
1.1.1  display fib
display fib [ all ]
View
all: Displays all the entries, including inactive ones, in the forwarding information base (FIB).
Use the display fib command to display all the active entries in the forwarding information base.
Use the display fib all command to display all the entries, including inactive ones, in the forwarding information base.
Each FIB entry includes destination address/mask length, next hop, current flag, timestamp, outbound interface, and activation flag.
# Display active entries of the FIB.
Destination/Mask   Nexthop       Flag TimeStamp     Interface         Act
2.2.2.2/32         8.8.8.2         S    t[0]       Vlan-interface10   YES
8.8.8.2/32         8.8.8.2         H    t[0]       Vlan-interface10   YES
8.8.8.1/32         127.0.0.1       GHU  t[0]       InLoopBack0        YES
8.8.8.0/24         8.8.8.1         U    t[0]       Vlan-interface10   YES
127.0.0.0/8        127.0.0.1       U    t[0]       InLoopBack0        YES
# Display all the entries of the FIB.
<H3C> display fib all
2.2.2.2/32         8.8.8.3       GHSU  t[0]        Vlan-interface10  NO
Table 1-1 Description on the fields of the display fib command
Destination/Mask
Destination address/Mask length
Nexthop
Next hop address
Flag
The flag options include:
B – Blackhole route
D – Dynamic route
G – Gateway route
H – Host route
S – Static route
U – Route in UP state
R – Unreachable route
L – Route generated by ARP or ESIS
Timestamp
Timestamp
Forwarding interface
Act
Activation flag:
YES: Active entries
NO: Inactive entries
1.1.2  display fib [ all ] ip-address [ longer ]
display fib [ all ] [ ip-address [ mask | mask-length ] [ longer ] ]
display fib [ all ] ip-address1 { mask1 | mask-length1 } ip-address2 { mask2 | mask-length2 }
View
all: Displays all the entries, including inactive ones, in the forwarding information base.
ip-address: Destination IP address, in dotted decimal notation.
mask: IP address mask, in dotted decimal notation.
mask-length: Mask length expressed an integer.
longer: Specifies to display the FIB entries that exactly match the specified IP address/subnet mask pairs.
ip-address1, ip-address2: Destination IP address, in dotted decimal notation. ip-address1 and ip-address2 jointly define an address range. The FIB entries in this address range are displayed.
mask1, mask2: IP address mask, in dotted decimal notation.
mask-length1, mask-length2: Mask length for an IP address.
Use the display fib [ all ] [ ip-address [ mask | mask-length ] [ longer ] ] command to view the FIB entries matching the specified destination IP address.
Use the display fib [ all ] ip-address1 { mask1 | mask-length1 } ip-address2 { mask2 | mask-length2 } command to display the FIB entries matching a specified destination IP address range. Each line outputs an FIB entry and the display contents for each entry include destination address/mask length, next hop, current flag, timestamp, outbound interface, and activation flag.
# Display the active FIB entries whose destination addresses match 169.253.0.0 in the natural mask range or which match most of 169.253.0.0.
<H3C> display fib 169.253.0.0
169.253.0.0/16   2.1.1.1    U        t[0]            Vlan-interface1   YES
# Display the FIB entries whose destination addresses are in the range of 169.254.0.0/16 to 169.254.0.6/16.
<H3C> display fib 169.254.0.0 255.255.0.0 169.254.0.6 255.255.0.0
169.254.0.1/16   2.1.1.1     U       t[0]            Vlan-interface1  YES
For the descriptions of the displayed fields, refer to Table 1-1.
1.1.3  display fib acl
display fib [ all ] acl { number | name }
View
all: Displays all the entries, including inactive ones, in the FIB.
number: ACL in number form, in the range 2000 to 2999
name: ACL in name form, a string of 1 to 32 characters.
Use the display fib [ all ] acl command to display the FIB entries permitted by a specific ACL.
# Display the active FIB entries permitted by ACL 2000.
<H3C> display fib acl 2000
Route entry matched by access-list 2000:
1.1.4  display fib |
display fib [ all ] | { { begin | include | exclude } text }
View
all: Specifies to display all the entries, including inactive ones, in the FIB.
|: Regular expression.
begin: Displays the FIB entries from the first one containing the character string text.
include: Displays only those FIB entries containing the character string text.
exclude: Displays only those FIB entries excluding the character string text.
text: Character string.
Use the display fib [ all ] | command to display the FIB entries in the buffer which begin with, include or exclude the specified character string
# Display the lines starting from the first one containing the string 169.254.0.0
<H3C> display fib | begin 169.254.0.0
169.254.0.0/16   2.1.1.1     U       t[0]            Vlan-interface1      YES
2.0.0.0/16       2.1.1.1     U       t[0]            Vlan-interface1      YES
1.1.5  display fib ip-prefix
display fib [ all ] ip-prefix listname
View
listname: Prefix list name, a string of 1 to 19 characters in length.
Use the display fib [ all ] ip-prefix command to display  the FIB entries permitted by the specific prefix list.
# Display the FIB entries permitted by the prefix list abc0.
<H3C> display fib ip-prefix abc0
Route Entry matched by prefix-list abc0:
127.0.0.1/32     127.0.0.1   U       t[0]            InLoopBack0         YES
169.0.0.0/8      2.1.1.1     SU      t[0]            Vlan-interface1     YES
1.1.6  display fib statistics
display fib [ all ] statistics
View
Use the display fib [ all ] statistics command to display the total number of FIB entries.
# Display the total number of active FIB entries.
<H3C> display fib statistics
Route Entry Count : 30
# Display the total number of FIB entries.
<H3C> display fib all statistics
Route Entry Count : 32
1.1.7  display icmp statistics
View
None
Use the display icmp statistics command to view the statistics information about ICMP packets.
Related commands: display ip interface, reset ip statistics.
# View statistics about ICMP packets.
<H3C> display icmp statistics
  Input: bad formats   0                   bad checksum            0
         echo          5                   destination unreachable 0
         source quench 0                   redirects               0
         echo reply    10                  parameter problem       0
         timestamp     0                   information request     0
         mask requests 0                   mask replies            0
         time exceeded 0
  Output:echo          10                  destination unreachable 0
         echo reply    5                   parameter problem       0
         timestamp     0                     information reply     0
         time exceeded 0
Table 1-2 Description on the fields of the display icmp statistics command
bad formats
Number of input packets in bad format
bad checksum
Number of input packets with wrong checksum
echo
Number of input/output echo request packets
Number of input/output packets with unreachable destination
source quench
Number of input/output source quench packets
redirects
Number of input/output redirected packets
echo reply
Number of input/output echo reply packets
parameter problem
Number of input/output packets with parameter problems
timestamp
Number of input/output timestamp packets
information request
Number of input information request packets
mask requests
Number of input/output mask request packets
mask replies
Number of input/output mask reply packets
information reply
Number of output information reply packets
time exceeded
Number of input/output packets that exceeds the time
1.1.8  display ip socket
display ip socket [ socktype sock-type ] [ task-id socket-id ]
View
sock-type: The type of a socket (tcp:1, udp: 2, raw ip: 3).
task-id: The ID of a task, with the value ranging from 1 to 100.
socket-id: The ID of a socket, with the value ranging from 0 to 3072.
Use the display ip socket command to display the information about the sockets in the current system.
# Display the information about the socket of TCP type.
<H3C> display ip socket socktype 1
SOCK_STREAM:
Task = VTYD(18), socketid = 1, Proto = 6,
LA = 0.0.0.0:23, FA = 0.0.0.0:0,
sndbuf = 8192, rcvbuf = 8192, sb_cc = 0, rb_cc = 0,
socket option = SO_ACCEPTCONN SO_KEEPALIVE SO_SENDVPNID SO_SETKEEPALIVE,
socket state = SS_PRIV SS_ASYNC
Task = VTYD(18), socketid = 2, Proto = 6,
LA = 10.153.17.99:23, FA = 10.153.17.56:1161,
socket option = SO_KEEPALIVE SO_OOBINLINE SO_SENDVPNID SO_SETKEEPALIVE,
socket state = SS_ISCONNECTED SS_PRIV SS_ASYNC
Task = VTYD(18), socketid = 3, Proto = 6,
LA = 10.153.17.99:23, FA = 10.153.17.82:1121,
Table 1-3 Description on the fields of the display ip socket command
SOCK_STREAM
The socket type
The ID of a task
socketid
The ID of a socket
Proto
The protocol number used by the socket
sndbuf
The sending buffer size of the socket
rcvbuf
The receiving buffer size of the socket
sb_cc
The current data size in the sending buffer. The value makes sense only for the socket of TCP type, because only TCP is able to cache data
rb_cc
The current data size in the receiving buffer
socket option
The option of the socket
socket state
The state of the socket
1.1.9  display ip statistics
View
None
Use the display ip statistics command to view the statistics information about IP packets.
# View statistics about IP packets.
<H3C> display ip statistics
  Input:   sum            7120             local             112
           bad protocol   0                bad format        0
           bad checksum   0                bad options       0
  Output:  forwarding     0                local             27
           dropped        0                no route          2
           compress fails 0
  Fragment:input          0                output            0
           dropped        0
           fragmented     0                couldn't fragment 0
  Reassembling:sum        0                timeouts          0
Table 1-4 Description on the fields of the display ip statistics command
Input:
sum
Sum of input packets
local
Number of received packets whose destination is the local device
bad protocol
Number of packets with wrong protocol number
bad format
Number of packets in bad format
bad checksum
Number of packets with wrong checksum
bad options
Number of packets that have wrong options
Output:
forwarding
Number of forwarded packets
local
Number of packets that are sent by the local device
dropped
Number of dropped packets during transmission
no route
Number of packets that cannot be routed
compress fails
Number of packets that cannot be compressed
Fragment:
input
Number of input fragments
output
Number of output fragments
dropped
Number of dropped fragments
fragmented
Number of packets that are fragmented
couldn't fragment
Number of packets that cannot be fragmented
Reassembling:
sum
Number of packets that are reassembled
timeouts
Number of packets that time out
1.1.10  display tcp statistics
View
None
Use the display tcp statistics command to view the statistics information about TCP packets.
Related commands: display tcp status, reset tcp statistics.
# View statistics about TCP packets.
<H3C> display tcp statistics
Received packets:
 Total: 753
 packets in sequence: 412 (11032 bytes)
 window probe packets: 0, window update packets: 0
 checksum error: 0, offset error: 0, short error: 0
 duplicate packets: 4 (88 bytes), partially duplicate packets: 5 (7 bytes)
 out-of-order packets: 0 (0 bytes)
 packets of data after window: 0 (0 bytes)
 packets received after close: 0
 ACK packets: 481 (8776 bytes)
 duplicate ACK packets: 7, too much ACK packets: 0
Sent packets:
 Total: 665
 urgent packets: 0
 control packets: 5 (including 1 RST)
 window probe packets: 0, window update packets: 2
 data packets: 618 (8770 bytes) data packets retransmitted: 0 (0 bytes)
 ACK-only packets: 40 (28 delayed)
Retransmitted timeout: 0, connections dropped in retransmitted timeout: 0
Keepalive timeout: 0, keepalive probe: 0, Keepalive timeout, so connections disconnected : 0
Initiated connections: 0, accepted connections: 0, established connections: 0
Closed connections: 0 (dropped: 0, initiated dropped: 0)
Packets dropped with MD5 authentication: 0
Packets permitted with MD5 authentication: 0
Table 1-5 Description on the fields of the display tcp statistics command
Received packets
Information followed is about received packets
Total:753
Total number of received packets: 753
packets in sequence: 412 (11,032 bytes)
Up to 412 packets (total of 11,032 bytes) arrive in sequence
Number of window probe packets: 0
Number of window update packets: 0
Number of checksum errors: 0
Number of offset errors: 0
Number of short errors: 0
Number of duplicate packets: 4 (total of 88 bytes)
Number of partially duplicate packets: 5 (total of 7 bytes)
Number of out-of-order packets: 0 (0 byte)
Number of packets out of receiving window: 0 (0 byte)
Number of packets received after the connection closed: 0
ACK packets: 481 (8,776 bytes)
Number of ACK packets: 481 (total of 8,776 bytes of data acknowledged)
Number of duplicate ACK packets: 7
Number of too-much ACK packets: 0 (ACK packets that acknowledge data not sent)
Sent packets
Information followed is about sent packets
Total: 665
Total number of sent packets: 665
urgent packets: 0
Number of urgent packets: 0
Number of control packets: 5 (including 1 RST packet)
Number of window update packets: 2
data packets: 618 (8,770 bytes) data packets retransmitted: 0 (0 bytes)
Number of data packets: 618 (total of 8,770 bytes)
Number of data packets retransmitted: 0 (0 byte)
Number of ACK packets: 40 (28 of which delayed)
Number of retransmitted timeout events: 0
Number of connections dropped due to the number of retransmitted timeout events exceeding the specified value: 0
Number of keepalive timeout events: 0
Number of keepalive probe packets sent: 0
disconnected : 0
Number of connections disconnected when keepalive probes fail: 0
Number of initiated connections: 0
Number of accepted connections: 0
Number of established connection: 0
Number of closed connection: 0
Number of dropped connections (after SYN messages received): 0
Number of connections initiated drooped: 0
Number of packets dropped with MD5 authentication: 0
Number of packets permitted with MD5 authentication: 0
1.1.11  display tcp status
display tcp status
View
None
Use the display tcp status command to view all TCP connection states. This helps user monitor TCP connection at any time.
# Display the state of all TCP connections.
<H3C> display tcp status
TCPCB        Local Add:port      Foreign Add:port        State
03e37dc4 0.0.0.0:4001            0.0.0.0:0           Listening
04217174 100.0.0.204:23      100.0.0.253:65508   Established
The displayed information indicates that a TCP connection is established. The local IP address of this TCP connection is 100.0.0.204, and the local port number is 23. The remote IP address is 100.0.0.253, and the remote port number is 65508. In addition, there is a local server process which listens to the port 4001.
1.1.12  display udp statistics
View
None
Use the display udp statistics command to view UDP traffic statistic information.
It displays the statistic information of all current UDP connections. The statistics information about UDP packets are divided into two major kinds which are received packets and sent packets. The packets are further divided into different types such as check packets and error packets. There are also some statistics related closely to the connections, such as the number of broadcast packets. All these displayed information are measured in packets.
Related commands: reset udp statistics.
# Display the UDP traffic statistic information.
<H3C> display udp statistics
Received packet:
Total:0
checksum error:0
shorter than header:0, data length larger than packet:0
no socket on port:0
broadcast:0
not delivered, input socket full:0
input packets missing pcb cache:0
Sent packet:
Total:0
Table 1-6 Description on the fields of the display udp statistics command
Received packet:
Total: 0
Total received UDP packets: 0
checksum error: 0
shorter than header: 0, data length larger than packet: 0
Cases that the length of the packets is shorter than the header: 0
Cases that the data length exceeds the packet length: 0
no socket on port: 0
Cases that there is no socket on port: 0
broadcast: 0
Number of broadcast packets: 0
not delivered, input socket full: 0
Cases that the packets are not forwarded because the socket buffer is full: 0
input packets missing pcb cache: 0
Cases that the packets cannot find pcb: 0
Sent packet:
Total: 0
Total sent UDP packets: 0
1.1.13  ip icmp-time-exceed enable
undo ip icmp-time-exceed enable
View
None
Use the ip icmp-time-exceed enable command to make the switch send a “time exceeded” ICMP error packet to the IP packet sender when the switch receives an IP packet whose TTL is “1”, preventing the switch from repeatedly returning a destination unreachable packet to the sender.
Use the undo icmp-time-exceed enable command to cancel the configuration. In this case, the switch returns a destination unreachable packet to the sender.
By default, the switch sends a "time exceeded” ICMP error packet to the network management system.
# Configure the switch to send a “time exceeded” ICMP error packet to the IP packet sender when the switch receives a packet whose TTL is “1”.
<H3C> system-view
[H3C] ip icmp-time-exceed enable
1.1.14  reset ip statistics
reset ip statistics
View
None
Use the reset ip statistics command to clear the IP statistics information.
Related commands: display ip interface, display ip statistics.
# Clear the IP statistics information.
<H3C> reset ip statistics
1.1.15  reset tcp statistics
View
None
Use the reset tcp statistics command to clear the TCP statistics information.
Related commands: display tcp statistics.
# Clear the TCP statistics information.
<H3C> reset tcp statistics
1.1.16  reset udp statistics
View
None
Use the reset udp statistics command to can clear the UDP statistics information.
# Clear the UDP traffic statistics information.
<H3C> reset udp statistics
1.1.17  tcp timer fin-timeout
undo tcp timer fin-timeout
View
time-value: TCP finwait timer value in second, with the value ranging from 76 to 3,600; By default, it is 675 seconds.
Use the tcp timer fin-timeout command to configure the TCP finwait timer.
Use the undo tcp timer fin-timeout command to restore the default value of the TCP finwait timer.
When the TCP connection state changes from FIN_WAIT_1 to FIN_WAIT_2, the finwait timer is enabled. If the switch does not receive FIN packets before the finwait timer times out, the TCP connection is terminated.
Related commands: tcp timer syn-timeout, tcp window.
# Configure the TCP finwait timer value as 800 seconds.
<H3C> system-view
[H3C] tcp timer fin-timeout 800
1.1.18  tcp timer syn-timeout
undo tcp timer syn-timeout
View
time-value: TCP synwait timer value measured in seconds, whose value ranges from 2 to 600. The default time-value is 75 seconds.
Use the tcp timer syn-timeout command to configure the TCP synwait timer.
Use the undo tcp timer syn-timeout command to restore the default value of the timer.
TCP enables the synwait timer if a SYN packet is sent. The TCP connection is terminated if the response packet is not received.
Related commands: tcp timer fin-timeout, tcp window.
# Configure the TCP synwait timer value as 80 seconds.
<H3C> system-view
[H3C] tcp timer syn-timeout 80
1.1.19  tcp window
tcp window window-size
undo tcp window
View
window-size: The size of the sending and receiving buffers measured in kilobytes (KB), whose value ranges from 1 to 32. By default, the window-size is 8KB.
Use the tcp window command to configure the size of the sending and receiving buffers of the connection-oriented Socket.
Use the undo tcp window command to restore the default size of the buffer.
Related commands: tcp timer fin-timeout, tcp timer syn-timeout.
# Configure the size of the sending and receiving buffers as 3KB.
<H3C> system-view
[H3C] tcp window 3
