H3C S9500 Command Manual-Release1648[v1.24]-02 IP Services Volume
HomeSupportSwitchesS9500 SwitchesReference GuidesCommand ReferencesH3C S9500 Command Manual-Release1648[v1.24]-02 IP Services Volume
06-UDP Helper Commands
06-UDP Helper Commands 22.34 KB
Chapter 1  UDP Helper Configuration Commands
1.1  UDP Helper Configuration Commands
1.1.1  debugging udp-helper
debugging udp-helper { event | packet [ receive | send ] }
undo debugging udp-helper { event | packet [ receive | send ] }
View
event: Enables event debugging for UDP Helper.
packet: Enables packet debugging for UDP Helper.
receive: Enables incoming packet debugging for UDP Helper.
send: Enables outgoing packet debugging for UDP Helper.
Use the debugging udp-helper command to enable UDP Helper debugging.
Use the undo debugging udp-helper command to disable UDP Helper debugging.
By default, UDP Helper debugging is disabled.
# Enable packet debugging for UDP Helper.
<H3C> debugging udp-helper packet
1.1.2  display udp-helper
display udp-helper { server [ interface vlan-interface vlan-id ] | port }
View
vlan-id: ID of a VLAN.
Use the display udp-helper server command to display the information of the destination server corresponding to the VLAN interface.
Use the display udp-helper port command to display the configuration of the global UDP ports.
# Display the information of the destination server corresponding to VLAN-interface 1.
<H3C> display udp-helper server interface vlan-interface 1
interface name       server address      packets sent
Vlan-interface1      192.1.1.2           0
The information above shows that the IP address of the destination server corresponding to VLAN-interface 1 is 192.1.1.2, and no packets have been forwarded.
# Display the configuration of the global UDP ports.
<H3C> display udp-helper port
Now, the following config udp-helper port exist(s):
 37(time), 49(tacacs), 53(dns), 34, 89, 456, 10000-10005
The information above shows the configuration of the global UDP ports (including the default port 37, 49, 53 and the configured ports) when UDP helper is enabled.
1.1.3  udp-helper enable
udp-helper enable
udp-helper enable
View
None
Use the udp-helper enable command to enable the function of forwarding UDP broadcast packets.
Use the undo udp-helper enable command to disable the function.
By default, the function of forwarding UDP broadcast packets is disabled.
# Enable the function of forwarding UDP broadcast packets.
<H3C>system-view
[H3C] udp-helper enable
1.1.4  udp-helper port
udp-helper port { port | dns | netbios-ds | netbios-ns | tacacs | tftp | time }
undo udp-helper port { port | dns | netbios-ds | netbios-ns | tacacs | tftp | time }
View
port: UDP port number, in the range of 1 to 65535. Packets with this UDP port number can be forwarded. Up to 250 ports are supported besides the default ports. The UDP Helper enabled device cannot forward DHCP broadcast packets, and therefore, the UDP port number cannot be set to 67 or 68..
dns: Refers to domain name system (DNS), whose UDP port number is 53.
netbios-ds: Refers to NetBIOS datagram service (netbios-ds), whose UDP port number is 138.
netbios-ns: Refers to NetBIOS name service (netbios-ns), whose UDP port number is 137.
tacacs: Refers to terminal access controller access control system (TACACS), whose UDP port number is 49.
tftp: Refers to trivial transfer protocol (TFTP), whose UDP port number is 69.
time: Refers to time service, whose UDP port number is 37.
Use the udp-helper port command to specify the port number that UDP packets to be forwarded contain.
Use the undo udp-helper port command to remove the configuration.
# Specify the port corresponding to the DNS protocol as an UDP port.
<H3C>system-view
[H3C] udp-helper port dns
1.1.5  udp-helper server
udp-helper server ip-address
undo udp-helper server [ ip-address ]
View
VLAN interface view
ip-address: IP address of the destination server, in dotted decimal notation. This argument can be the address of a host or the broadcast address of a subnet. Up to 20 destination servers can be configured on a VLAN virtual interface.
Use the udp-helper server command to specify the destination server to which the UDP packets are to be forwarded.
Use the undo udp-helper server command to remove the configured destination server.
No destination server is configured by default.
Related commands: display udp-helper.
# Specify to forward UDP packets to the destination server at IP address 192.1.1.2.
<H3C>system-view
[H3C]interface Vlan-interface 1
[H3C-Vlan-interface1] udp-helper server 192.1.1.2
