H3C S9500 Operation Manual-Release2132[V2.03]-05 MPLS VPN Volume
HomeSupportSwitchesS9500 SwitchesConfigure & DeployConfiguration GuidesH3C S9500 Operation Manual-Release2132[V2.03]-05 MPLS VPN Volume
06-MPLS Hybrid Insertion Configuration
06-MPLS Hybrid Insertion Configuration 245.59 KB
Chapter 1  MPLS Hybrid Insertion Configuration
When configuring MPLS hybrid insertion, go to these sections for information you are interested in:
l           Overview of MPLS Hybrid Insertion
l           Configuring Hybrid Insertion Based on LPUs with a Suffix of C, CA, or CB
l           Configuring Hybrid Insertion Based on L3+ SPUs
l           Hybrid Insertion Configuration Example
&  Note:
l      For information about basic configuration of MPLS, refer to MPLS Basics Configuration.
l      MPLS hybrid insertion configuration does not involve the actual networking. It simply demonstrates the MPLS processing capability, that is, a system that does not support MPLS can provide MPLS/MPLS VPN services after configuration of MPLS hybrid insertion.
l      For detailed configuration information about service loopback group, ACL, and QoS, refer to related manuals.
l      A routing switch running MPLS has the functions of a router. The term "router” in this document refers to a router in a generic sense or a Layer 3 Ethernet switch running MPLS.
l      For an S9500 Series routing switch, only line processor units (LPUs) with a suffix of C, CA or CB and VPLS service processor cards (SPCs) support MPLS. For S9500 Series routing switches to support MPLS VPN functions, you need to equip them with MPLS capable LPUs or VPLS SPCs. You can identify the suffix of an LPU by the silkscreen in the upper right corner of the LPU’s front panel. As an example, the silkscreen of an LSB1P4G8CA0 LPU is P4G8CA, and therefore the suffix of the LPU is CA.
1.1  Overview of MPLS Hybrid Insertion
1.1.1  Introduction to Hybrid Insertion
Currently, the device supports both the SPUs with or without the MPLS function. In the following description, these two types of SPUs are respectively referred to as MPLS board and non-MPLS board. In order to provide the MPLS/MPLS VPN service in an environment that does not support the MPLS, a lot of users require adding MPLS SPUs without changing the original networking. To meet this requirement, LPUs supporting MPLS must be configured to redirect the MPLS service to the MPLS SPUs for service processing. With the hybrid insertion feature, the MPLS VPN service can be deployed on boards that do not support MPLS. The device supports the MPLS VPN in several modes. It provides diversified MPLS VPN services to address different MPLS VPN requirements, such as service performance, reliability, and port utilization ratio.
1.1.2  Classification of Hybrid Insertion
Although LPUs with a suffix of C, CA, or CB and L3+ SPUs support the MPLS function, their functions and configurations are different. Accordingly, hybrid insertion is classified into two types: hybrid insertion based on LPUs with a suffix of C, CA, or CB, and hybrid insertion based on L3+ SPUs.
Here, MPLS hybrid insertion includes both L2VPN and L3VPN hybrid insertions.
I. Hybrid insertion based on LPUs with a suffix of C, CA, or CB
l           Support hybrid insertion of LPUs with a suffix of C, CA, or CB and non-MPLS SPUs.
l           The service at the L3VPN private network side must be redirected to the MPLS service loopback group on the MPLS board for processing.
II. Hybrid insertion based on L3+ SPUs
l           Support hybrid insertion of L3+ SPUs and non-L3+ SPUs.
l           VPLS service and MPLS packets with the outer label assigned by the public network must be redirected to different virtual service interfaces on the L3+ SPUs for processing.
1.2  Configuring Hybrid Insertion Based on LPUs with a Suffix of C, CA, or CB
Before configuring hybrid insertion based on LPUs with a suffix C, CA, or CB, you need to:
l           Configure the MPLS service loopback group.
l           Configure the QoS policy to redirect the private network packets to the MPLS service loopback group in the case of L3VPN hybrid insertion.
1.2.1  Configuring Redirection of MPLS Service at Private Network Side
I. Configuration prerequisites
Before redirecting MPLS service at private network side, complete the following tasks:
l           Configure the basic MPLS capability.
l           Configure the service loopback group with the MPLS processing capability.
II. Configuring MPLS service redirection at private network side
Redirect the MPLS service at the private network side to the service loopback group with the MPLS processing capability.
1.2.2  Configuring MPLS Service Loopback Group
Follow these steps to configure an MPLS service loopback group:
To do...
Use the command...
Remarks
Enter system view
Create a manual aggregation group
link-aggregation group agg-id mode { manual | static }
Required
The type of the aggregation group must be manual.
Set the type of service loopback group to MPLS
link-aggregation group agg-id service-type { ipv6 | ipv6mc | mpls | tunnel }
Required
Add the port of MPLS board to the loopback group
port link-aggregation group agg-id
Required
1.2.3  Configuring Port-based QoS Policy
Follow these steps to configure a port-based QoS policy:
To do...
Use the command...
Remarks
Enter system view
Enter ACL view
acl number acl-number [ match-order { config | auto } ]
Required
Configure the IP ACL
rule [ rule-id ] { permit | deny } [ rule-string ]
Required
Enter QACL class view
traffic classifier tcl-name [ operator { and | or } ]
Required
Configure the rule
if-match match-criteria
Required
Enter QACL behavior view
Required
Configure the behavior
remark service-vlan-id vlan-id-value
Required
Configure the traffic redirection action for the traffic behavior
redirect { cpu | interface interface-type interface-number | next-hop { ipv4-add [ ipv4-add ] | ipv6-add [ interface-type interface-number ] [ ipv6-add [ interface-type interface-number | link-aggregation group group-number ] ] } }
Required
Enter QoS policy view
qos policy policy-name
Required
classifier tcl-name behavior behavior-name
Required
Apply QoS policy to the port
Required
&  Note:
l      Configure the port-based QoS policy only in the case of L3VPN hybrid insertion.
l      You can add multiple ports to an MPLS loopback group for load sharing purpose.
l      LSB1GV48DA0, LSB1GV48DB0, and LSB1XP4DB0 do not support L2VPN hybrid insertion.
1.3  Configuring Hybrid Insertion Based on L3+ SPUs
Before configuring the hybrid insertion based on L3+ SPUs, you need to:
l           Redirect the MPLS and VPLS services at the public network side to the virtual service interface on the L3+ board for processing.
l           Bind the VPLS instance with different MPLS-VPLS virtual service interfaces to share the load of VPLS service.
In the configuration of hybrid insertion based on L3+ SPUs, two types of virtual service interface on the L3+ board are used:
l           MPLS virtual service interface
l           MPLS-VPLS virtual service interface
1.3.1  Configuring MPLS Service Redirection at Public Network Side
MPLS service redirection is to redirect the MPLS service to the MPLS virtual service interface on the L3+ board capable of MPLS processing.
&  Note:
The MPLS service here refers to the service processed by the device that functions as a P device. It does not include the L3VPN or VLL services on the PE.
Follow these steps to configure MPLS service redirection at the public network side:
To do...
Use the command...
Remarks
Enter system view
Enter MPLS virtual service interface view
interface MPLS interface-number
Redirect the MPLS service to the MPLS virtual service interface on the L3+ board capable of MPLS processing
mpls service binding
Required
1.3.2  Configuring VPLS Service Redirection at Public Network Side
VPLS service redirection is to redirect the VPLS service to the MPLS-VPLS virtual service interface on the L3+ board capable of MPLS processing.
Follow these steps to configure VPLS service redirection at the public network side:
To do...
Use the command...
Remarks
Enter system view
Enter MPLS-VPLS virtual service interface view
interface MPLS-VPLS interface-number
Redirect the VPLS service to the MPLS-VPLS virtual service interface on the L3+ board capable of MPLS processing
l2vpn-vpls service binding service-id service-id
Required
1.3.3  Binding VPLS Virtual Service Interface with VPLS Instance
Before binding the VPLS virtual service interface with the VPLS instance, complete the following tasks:
l           Configure the VPLS virtual service interface, to which the VPLS service at the public network side is redirected.
l           Create a VPLS instance, VSI.
&  Note:
For configuration of VPLS instance, refer to VPLS Configuration.
II. Binding VPLS virtual service interface with VPLS instance
By binding the MPLS-VPLS virtual service interface with the VPLS instance, the load can be shared among virtual service interfaces on the L3+ board.
Follow these steps to bind a VPLS virtual service interface with an MPLS-VPLS instance:
To do...
Use the command...
Remarks
Enter system view
Specify the VPLS instance to be bound on the MPLS-VPLS virtual service interface
l2vpn-vpls service binding vsi vsi-name
Required
1.3.4  Configuring Backup Interface for Virtual Service Interface
With the backup interface of virtual service interface, the service can be switched to the backup interface once the virtual service interface is in down state, thus ensuring uninterrupted traffic forwarding.
Follow these steps to configure the backup interface for the virtual service interface:
To do...
Use the command...
Remarks
Enter system view
Enter virtual service interface view
Specify the backup interface for the virtual service interface
backup interface interface-type interface-number
Required
&  Note:
l      At present, you can configure two virtual service interfaces only for an L3+ board: MPLS virtual service interface and MPLS-VPLS virtual service interface.
l      The backup virtual service interface must be in available state and have the same interface type as the active virtual service interface.
1.3.5  Displaying and Maintaining Hybrid Insertion Configuration
To do...
Use the command...
Remarks
Display the current configuration
display current-configuration
Available in any view
Display information about service loopback groups
display link-aggregation service-type [ agg-id ]
Display information about configured IPv4 ACLs
display acl { acl-number | all }
Display configuration information about a specified class or all classes and the associated actions in a specified or all policies
display qos policy user-defined [ policy-name [ classifier tcl-name ] ]
Display configuration and operation information about policies of a specified interface or all interfaces
display qos policy interface [ interface-type interface-number ] [ inbound | outbound ]
Display information about configured traffic behaviors
display traffic behavior user-defined [ behavior-name ]
Display information about configured classes
display traffic classifier user-defined [ tcl-name ]
1.4  Hybrid Insertion Configuration Example
1.4.1  Example for Configuring L3VPN Hybrid Insertion
I. Network requirements
l           Configure the service loopback group with MPLS processing capability.
l           Redirect the service at the L3VPN private network side to the above service loopback group.
II. Network diagram
Figure 1-1 Network diagram for configuring MPLS hybrid insertion
In the figure above:
l           CE 1 and CE 3 constitute VPN A. CE 2 and CE 4 constitute VPN B.
l           PE 1 and PE 2 are H3C S9500 series routing switches that support the MPLS function. CE 1 and CE 2 are common low-end or mid-range routing devices. CE 3 and CE 4 are Layer-2 switches that directly connect with users.
l           LPU configurations are the same on two PEs. A non-MPLS board with FE ports resides in Slot 3, and an MPLS board with GE ports in Slot 2.
III. Configuration procedure
1)         Configure CE 1
# Establish the EBGP neighbor relationship between CE 1 and PE 1. Inject a directly connected route and a static route to redistribute the VPN private network user routes of CE 1 to BGP routes and then advertise injected routes to PE 1.
<CE1> system-view
[CE1] vlan 10
[CE1] interface vlan-interface 10
[CE1-vlan-interface10] ip address 10.10.10.10 255.255.255.0
[CE1-vlan-interface10] quit
[CE1] bgp 65410
[CE1-bgp] group vpna external
[CE1-bgp] peer 10.10.10.1 group vpna as-number 100
[CE1-bgp] import-route direct
[CE1-bgp] import-route static
&  Note:
The configuration on CE 2 is similar with that on CE 1, and is therefore omitted
2)         Configure PE 1
# Configure the global MPLS.
[PE1] mpls lsr-id 1.1.1.1
[PE1] mpls
[PE1] mpls ldp
# Configure a public network interface and enable MPLS on it.
[PE1] interface loopback 0
[PE1-LoopBack0] quit
[PE1] vlan 100
[PE1-vlan100] port GigabitEthernet 2/2/1
[PE1-vlan100] interface vlan-interface 100
[PE1-vlan-interface100] ip address 196.168.1.1 255.255.255.0
[PE1-vlan-interface100] mpls
[PE1-vlan-interface100] mpls ldp
[PE1-vlan-interface100] quit
# Start the OSPF on the interface connecting PE 1 and the P routing device and on the loopback interface.
[PE1] ospf 1 router-id 1.1.1.1
[PE1-ospf-1] area 0
[PE1-ospf-1-area-0.0.0.0] network 196.168.1.0 0.0.0.255
# Configure the VPN-instance. The configuration on VPN B is similar with that on VPN A. The following provides the configuration on VPN A only.
<PE1> system-view
[PE1] ip vpn-instance vpna
[PE1-vpn-vpna] route-distinguisher 100:1
[PE1-vpn-vpna] vpn-target 100:1 both
[PE1-vpn-vpna] quit
# Configure the MPLS service loopback group:
[PE1] link-aggregation group 1 mode manual
[PE1] link-aggregation group 1 service-type mpls
# Add multiple ports to the MPLS service loopback group.
[PE1] interface GigabitEthernet 2/2/3
[PE1-GigabitEthernet2/2/3] stp disable
[PE1-GigabitEthernet2/2/3] port link-aggregation group 1
[PE1-GigabitEthernet2/2/3] interface GigabitEthernet 2/2/4
[PE1-GigabitEthernet2/2/4] stp disable
[PE1-GigabitEthernet2/2/4] port link-aggregation group 1
# Configure the port-based QoS policy.
[PE1] acl number 2000
[PE1-acl-basic-2000] rule 0 permit source any
[PE1] traffic classifier one
[PE1-classifier-one] if-match acl 2000
[PE1-classifier-one] traffic behavior one
[PE1-behavior-one] remark service-vlan-id 10
[PE1-behavior-one] redirect link-aggregation group 1
[PE1] qos policy one
[PE1-qospolicy-one] classifier one behavior one
[PE1-qospolicy-one] interface Ethernet 3/1/1
[PE1-Ethernet3/1/1] qos apply policy one inbound
[PE1-Ethernet3/1/1] quit
# Configure the VLAN interface.
[PE1] vlan 10
[PE1-vlan10] port Ethernet 3/1/1
[PE1-vlan10] interface vlan-interface 10
[PE1-vlan-interface10] quit
# Bind the VPN A to the VLAN interface that connects PE 1 and CE 1.
[PE1-Vlan-interface10] ip binding  vpn-instance  vpna
[PE1-Vlan-interface10] ip address  10.10.10.1 24
[PE1-Vlan-interface10] quit
# Establish the EBGP neighbor relationship between PE 1 and CE 1 and inject the interface routes of VPN-instance.
[PE1] bgp 100
[PE1-bgp] ipv4-family vpn-instance vpna
[PE1-bgp-af-vpn-instance] group vpna external
[PE1-bgp-af-vpn-instance] peer 10.10.10.10 group vpna as-number 65410
[PE1-bgp-af-vpn-instance] import-route direct
[PE1-bgp-af-vpn-instance] quit
[PE1-bgp] quit
# Establish the MBGP neighbor relationship between PEs to exchange VPN routing information among PEs. Activate the IBGP peer in VPNv4 address family view.
[PE1] bgp 100
[PE1-bgp] group 100
[PE1-bgp] peer 2.2.2.2 group 100
[PE1-bgp] peer 2.2.2.2 connect-interface loopback0
[PE1-bgp] ipv4-family vpnv4
[PE1-bgp-af-vpn] peer 100 enable
[PE1-bgp-af-vpn] peer 2.2.2.2 group 100
3)         Configure the P device
[P] mpls lsr-id 3.3.3.3
[P] mpls
[P] mpls ldp
# Configure an interface and enable MPLS on the interface.
[P] interface loopback0
[P-LoopBack0] ip address 3.3.3.3 32
[P-LoopBack0] quit
[P] vlan 100
[P-vlan100] port GigabitEthernet 2/1/1
[P-vlan100] interface vlan-interface 100
[P-vlan-interface100] ip address 196.168.1.2 255.255.255.0
[P-vlan-interface100] mpls
[P-vlan-interface100] mpls ldp
[P-vlan-interface100] quit
[P] vlan 200
[P-vlan200] port GigabitEthernet 2/1/2
[P-vlan200] interface vlan-interface 200
[P-vlan-interface200] ip address 196.168.2.2 255.255.255.0
[P-vlan-interface200] mpls
[P-vlan-interface200] mpls ldp
[P-vlan-interface200] quit
# Configure the OSPF.
[P] ospf 1 router-id 3.3.3.3
[P-ospf-1] area 0
[P-ospf-1-area-0.0.0.0] network 196.168.1.0 0.0.0.255
[P-ospf-1-area-0.0.0.0] network 196.168.2.0 0.0.0.255
[P-ospf-1-area-0.0.0.0] network 3.3.3.3 0.0.0.0
4)         Configure PE 2
[PE2] mpls lsr-id 2.2.2.2
[PE2] mpls
[PE2] mpls ldp
# Configure a public network interface and enable MPLS on the interface.
[PE2] interface loopback0
[PE2-LoopBack0] ip address 2.2.2.2 32
[PE2-LoopBack0] quit
[PE2] vlan 200
[PE2-vlan200] port GigabitEthernet 2/2/1
[PE2-vlan200] interface vlan-interface 200
[PE2-vlan-interface200] ip address 196.168.2.1 255.255.255.0
[PE2-vlan-interface200] mpls
[PE2-vlan-interface200] mpls ldp
[PE2-vlan-interface200] quit
# Start the OSPF on the interface connecting PE 2 and the P routing device and on the loopback interface.
[PE2] ospf 1 router-id 2.2.2.2
[PE2-ospf-1] area 0
[PE2-ospf-1-area-0.0.0.0] network 196.168.1.0 0.0.0.255
[PE2-ospf-1-area-0.0.0.0] network 2.2.2.2 0.0.0.0
[PE2] ip vpn-instance vpna
[PE2-vpn-vpna] route-distinguisher 100:1
[PE2-vpn-vpna] vpn-target 100:1 both
[PE2-vpn-vpna] quit
[PE2] link-aggregation  group  1 mode manual
[PE2] link-aggregation  group 1 service-type mpls
[PE2] inter GigabitEthernet 2/2/3
[PE2-GigabitEthernet2/2/3] stp disable
[PE2-GigabitEthernet2/2/3] port link-aggregation group 1
[PE2-GigabitEthernet2/2/3] interface GigabitEthernet 2/2/4
[PE2-GigabitEthernet2/2/4] stp disable
[PE2-GigabitEthernet2/2/4] port link-aggregation group 1
# Configure the port-based QoS policy:
[PE2] acl number 2000
[PE2-acl-basic-2000] rule 0 permit source any
[PE2] traffic classifier one
[PE2-classifier-one] if-match acl 2000
[PE2-classifier-one] traffi behavior one
[PE2-behavior-one] remark service-vlan-id 10
[PE2-behavior-one] redirect link-aggregation group 1
[PE2] qos policy one
[PE2-qospolicy-one] classifier one behavior one
[PE2-qospolicy-one] interface e3/1/1
[PE2-Ethernet3/1/1] qos apply policy one inbound
[PE2-Ethernet3/1/1] quit
# Bind the VPN A to the VLAN interface that connects PE 2 and CE 3.
[PE2] interface vlan-interface 10
[PE2-vlan-interface10] ip binding vpn-instance vpna
[PE2-vlan-interface10] ip address 20.2.1.2 255.255.255.0
[PE2-vlan-interface10] quit
# Inject the PE 2-CE 3 private network interface route for VPN A.
[PE2] bgp 100
[PE2-bgp] ipv4-family vpn-instance vpna
[PE2-bgp-af-vpn-instance] import-route direct
[PE2-bgp-af-vpn-instance] quit
[PE2-bgp] quit
[PE2] bgp 100
[PE2-bgp] group 100
[PE2-bgp] peer 1.1.1.1 group 100
[PE2-bgp] peer 1.1.1.1 connect-interface loopback0
[PE2-bgp] ipv4-family vpnv4
[PE2-bgp-af-vpn] peer 100 enable
[PE2-bgp-af-vpn] peer 1.1.1.1 group 100
1.4.2  Example for Configuring L2VPN Hybrid Insertion
l           Redirect the service at the L2VPN private network side to the above service loopback group.
II. Network diagram
Figure 1-2 Network diagram for configuring L2VPN hybrid insertion
l           CE 1 and CE 3 constitute VPNA. CE 2 and CE 3 constitute VPNB.
l           LPU configurations are the same on two PEs. A non-MPLS board with FE ports resides in Slot 3, and an MPLS board with a suffix of CA or CB that provides GE ports in Slot 2.
1)         Configure CE 1
# Configure the IP address of the interface.
<CE1> system-view
[CE1] vlan 10
[CE1-vlan-interface10] ip address 10.10.10.1 255.255.255.0
2)         Configure PE 1
[PE1] mpls
[PE1] mpls ldp
[PE1] interface loopback0
[PE1] vlan 100
[PE1-ospf-1] area 0
# Configure the LDP remote session.
[PE1] mpls ldp remote-peer 1
[PE1-mpls-ldp-remote-1] remote-ip 2.2.2.2
[PE1] vlan 10
# Bind the VPNA to the VLAN interface that connects PE 1 and CE 1.
[PE1-Vlan-interface10] mpls l2vc 2.2.2.2 100
[P] mpls
[P] mpls ldp
[P-LoopBack0] quit
[P] vlan 100
[P] vlan 200
[P-ospf-1] area 0
4)         Configure PE 2
[PE2] mpls
[PE2] mpls ldp
[PE2] vlan 200
[PE2-ospf-1] area 0
[PE2] mpls ldp remote-peer 1
[PE2-mpls-ldp-remote-1] remote-ip 1.1.1.1
[PE2] interface GigabitEthernet 2/2/3
# Bind the VPNA to the VLAN interface that connects PE 2 and CE 3.
[PE2-vlan-interface10] mpls l2vc 1.1.1.1 100
&  Note:
l      Currently, only MPLS boards with a suffix of CA or CB support VLL (L2VPN). Thus, VLL hybrid insertion includes:
     - Hybrid insertion of non-MPLS boards and MPLS boards with a suffix of CA
     - Hybrid insertion of MPLS boards with a suffix of C and MPLS boards with a suffix of CA
l      All MPLS boards support MPLS L3VPN. Thus, L3VPN hybrid insertion refers to hybrid insertion of non-MPLS boards and MPLS boards only.
l      You need to configure the port-based QoS policy for L3VPN hybrid insertion only, but not for VLL hybrid insertion.
1.4.3  Example for Configuring L3+ Hybrid Insertion
l           Bind the VPLS virtual service interface with the VPLS instance.
l           Configure the backup virtual service interface.
II. Network diagram
Figure 1-3 Network diagram for configuring L3+ hybrid insertion
1)         Configure PE 1
# Configure the IGP protocol, which is OSPF in this example.
# Configure the basic MPLS capability.
[Sysname] sysname PE1
[PE1] interface LoopBack 0
[PE1-LoopBack0] ip address 1.1.1.9 32
[PE1] mpls lsr-id 1.1.1.9
[PE1] mpls
[PE1-mpls] quit
[PE1] mpls ldp
[PE1-mpls-ldp] quit
# Redirect the service to the virtual service interface on the L3+ board and configure the backup interface for the virtual service interface.
[PE1] interface MPLS-VPLS 0/0/2
[PE1-MPLS-VPLS0/0/2] l2vpn-vpls service binding service-id 1
[PE1-MPLS-VPLS0/0/2] backup interface MPLS-VPLS 1/0/2
[PE1-MPLS-VPLS0/0/2] quit
# Configure VLAN 10 and create VLAN-interface 10.
[PE1] vlan 10
[PE1-vlan10] port Ethernet 4/1/1
[PE1-vlan10] quit
[PE1] interface Vlan-interface 10
[PE1-Vlan-interface10] ip address 10.10.10.10 24
# Configure the basic MPLS capability on the VLAN interface.
[PE1-Vlan-interface10] mpls ldp
# Configure MPLS L2VPN.
[PE1] mpls l2vpn
# Configure LDP VPLS instance aaa.
[PE1] vsi aaa static
[PE1-vsi-aaa] pwsignal ldp
[PE1-vsi-aaa-ldp] vsi-id 500
[PE1-vsi-aaa-ldp] peer 2.2.2.9
[PE1-vsi-aaa-ldp] quit
[PE1-vsi-aaa] quit
# Bind the MPLS-VPLS virtual service interface with the VPLS instance aaa.
[PE1-MPLS-VPLS0/0/2] l2vpn-vpls service binding vsi aaa
# Configure VLAN 100 and create VLAN-interface 100.
[PE1] vlan 100
[PE1-Vlan-100] port Ethernet 4/1/2
[PE1-Vlan-100] interface Vlan-interface 100
# Bind VPLS instance aaa with VLAN-interface 100.
[PE1-Vlan-interface100] l2 binding vsi aaa
2)         Configure PE 2
[Sysname] sysname PE2
[PE2] interface Lookback 0
[PE2-LoopBack0] ip address 2.2.2.9 32
[PE2] mpls lsr-id 2.2.2.9
[PE2] mpls
[PE2-mpls] quit
[PE2] mpls ldp
[PE2-mpls-ldp] quit
[PE2] interface MPLS-VPLS 0/0/2
[PE2-MPLS-VPLS0/0/2] l2vpn-vpls service binding service-id 1
[PE2-MPLS-VPLS0/0/2] quit
[PE2] vlan 10
[PE2-vlan10] port Ethernet 4/1/1
[PE2-vlan10] quit
[PE2] interface Vlan-interface 10
[PE2-Vlan-interface10] ip address 10.10.10.11 24
[PE2-Vlan-interface10] mpls
[PE2-Vlan-interface10] mpls ldp
[PE2-Vlan-interface10] quit
[PE2] mpls l2vpn
[PE2] vsi aaa static
[PE2-vsi-aaa] pwsignal ldp
[PE2-vsi-aaa-ldp] vsi-id 500
[PE2-vsi-aaa-ldp] peer 1.1.1.9
[PE2-vsi-aaa-ldp] quit
[PE2-vsi-aaa] quit
[PE2-MPLS-VPLS0/0/2] l2vpn-vpls service binding vsi aaa
[PE2] vlan 100
[PE2-vlan-100] port Ethernet 4/1/2
[PE2-vlan-100] quit
[PE2] interface Vlan-interface 100
[PE2-Vlan-interface100] l2 binding vsi aaa
3)         Verify the configuration
After completing the above configurations, you may perform the display vpls connection on a PE. There should be a PW connection established and in the state of up.
