H3C S9500 Operation Manual-Release2132[V2.03]-04 IP Multicast Volume
HomeSupportSwitchesH3C S9500 Series SwitchesConfigure & DeployConfiguration GuidesH3C S9500 Operation Manual-Release2132[V2.03]-04 IP Multicast Volume
06-MSDP Configuration
06-MSDP Configuration 433.78 KB
Chapter 1  MSDP Configuration
When configuring MSDP, go to these sections for information you are interested in:
l           MSTP Overview
l           Configuring Basic Functions of MSDP
l           Configuring an MSDP Peer Connection
l           Configuring SA Messages Related Parameters
l           Displaying and Maintaining MSDP
l           MSDP Configuration Examples
l           Troubleshooting MSDP
&  Note:
l      The term “router” in this document refers to a router in a generic sense or an S9500 series routing switch running the MSDP protocol.
l      For details about the concepts of designated router (DR), bootstrap router (BSR), candidate-BSR (C-BSR), rendezvous point (RP), candidate RP (C-RP), shortest path tree (SPT) and rendezvous point tree (RPT) mentioned in this manual, refer to PIM Configuration in the IP Multicast Volume.
1.1  MSTP Overview
1.1.1  Introduction to MSDP
Multicast source discovery protocol (MSDP) is an inter-domain multicast solution developed to address the interconnection of protocol independent multicast sparse mode (PIM-SM) domains. It is used to discover multicast source information in other PIM-SM domains.
In the basic PIM-SM mode, a multicast source registers only with the RP in the local PIM-SM domain, and the multicast source information of a domain is isolated from that of another domain. As a result, the RP is aware of the source information only within the local domain and a multicast distribution tree is built only within the local domain to deliver multicast data from a local multicast source to local receivers. If there is a mechanism that allows RPs of different PIM-SM domains to share their multicast source information, the local RP will be able to join multicast sources in other domains and multicast data can be transmitted among different domains.
MSDP achieves this objective. By establishing MSDP peer relationships among RPs of different PIM-SM domains, source active (SA) messages can be forwarded among domains and the multicast source information can be shared.
&  Note:
l      MSDP is applicable only if the intra-domain multicast protocol is PIM-SM.
l      MSDP is meaningful only for the any-source multicast (ASM) model.
1.1.2  How MSDP Works
I. MSDP peers
As shown in Figure 1-1, an active multicast source (Source) exists in the domain PIM-SM 1, and RP 1 has learned the existence of Source through multicast source registration. If receiver hosts in PIM-SM 2 and PIM-SM 3 also wish to receive multicast data from Source, the RPs in these domains can learn the location of Source by establishing MSDP peering relationships. MSDP peering relationships can be established among RPs of different or the same PIM-SM domain, between RPs and multicast routers, or even between multicast routers.
With one or more pairs of MSDP peers configured in the network, an MSDP interconnection map is formed, where the RPs of different PIM-SM domains are interconnected in series. Relayed by these MSDP peers, an SA message sent by an RP can be delivered to RPs in other domains.
Figure 1-1 Where MSDP peers are in the network
The blue lines in Figure 1-1 interconnect MSDP peers. MSDP peers created on PIM-SM routers that assume different roles function differently.
1)         MSDP peers on RPs
l           Source-side MSDP peer: the MSDP peer nearest to the multicast source (Source), typically the source-side RP, like RP 1 in Figure 1-1. The source-side RP creates SA messages and sends the messages to its remote MSDP peer to notify the MSDP peer of the locally registered multicast source information. A source-side MSDP must be created on the source-side RP; otherwise it will not be able to advertise the multicast source information out of the PIM-SM domain.
l           Receiver-side MSDP peer: the MSDP peer nearest to the receivers, typically the source-side RP, like RP 3 in Figure 1-1. Upon receiving an SA message, the receiver-side MSDP peer resolves the multicast source information carried in the message and joins the SPT rooted at the source across the PIM-SM domain. When multicast data from the multicast source arrives, the receiver-side MSDP peer forwards the data to the receivers along the RPT.
l           Intermediate MSDP peer: an MSDP peer with multicast remote MSDP peers, like RP 2 in Figure 1-1. An intermediate MSDP peer forwards SA messages received from one remote MSDP peer to other remote MSDP peers, functioning as a relay of multicast source information.
2)         MSDP peers created on common multicast routers (other than RPs)
Router A and Router B are MSDP peers on common multicast routers. Such MSDP peers just forward received SA messages.
&  Note:
In a PIM-SM network running the BSR mechanism, the RP is dynamically elected from C-RPs. To enhance network robustness, a PIM-SM network typically has more than one C-RP. As the RP election result is unpredictable, MSDP peering relationships should be built among all C-RPs so that the winner C-RP is always on the "MSDP interconnection map”, while looser C-RPs will assume the role of command PIM-SM routers on the “MSDP interconnection map”.
II. Implementing inter-domain multicast delivery by leveraging MSDP peers
As shown in Figure 1-2, an active source (Source) exists in the domain PIM-SM 1, and RP 1 has learned the existence of Source through multicast source registration. If RPs in PIM-SM 2 and PIM-SM 3 also wish to know the specific location of Source so that receiver hosts can receive multicast traffic originated from it, MSDP peering relationships should be established between RP 1 and RP 3 and between RP 3 and RP 2 respectively.
Figure 1-2 MSDP peering relationships
The process if implementing inter-domain multicast delivery by leveraging MSDP peers is as follows:
1)         When the multicast source in PIM-SM 1 sends the first multicast packet to multicast group G, DR 1 encapsulates the multicast data within a register message and sends the register message to RP 1. Then, RP 1 gets aware of the information related to the multicast source.
2)         As the source-side RP, RP 1 creates SA messages and periodically sends the SA messages to its MSDP peer. An SA message contains the source address (S), the multicast group address (G), and the address of the RP which has created this SA message (namely RP 1).
3)         On MSDP peers, each SA message is subject to a reverse path forwarding (RPF) check and multicast policy–based filtering, so that only SA messages that have arrived along the correct path and passed the filtering are received and forwarded. This avoids delivery loops of SA messages. In addition, you can configure MSDP peers into an MSDP mesh group so as to avoid flooding of SA messages between MSDP peers.
4)         SA messages are forwarded from one MSDP peer to another, and finally the information of the multicast source traverses all PIM-SM domains with MSDP peers (PIM-SM 2 and PIM-SM 3 in this example).
5)         Upon receiving the SA message create by RP 1, RP 2 in PIM-SM 2 checks whether there are any receivers for the multicast group in the domain.
l           If so, the RPT for the multicast group G is maintained between RP 2 and the receivers. RP 2 creates an (S, G) entry, and sends an (S, G) join message hop by hop towards DR 1 at the multicast source side, so that it can directly join the SPT rooted at the source over other PIM-SM domains. Then, the multicast data can flow along the SPT to RP 2 and is forwarded by RP 2 to the receivers along the RPT. Upon receiving the multicast traffic, the DR at the receiver side (DR 2) decides whether to initiate an RPT-to-SPT switchover process.
l           If no receivers for the group exist in the domain, RP 2 does dot create an (S, G) entry and does join the SPT rooted at the source.
&  Note:
l      An MSDP mesh group refers to a group of MSDP peers that have an MSDP peering relationship among one another and share the same group name.
l      When using MSDP for inter-domain multicasting, once an RP receives information form a multicast source, it no longer relies on RPs in other PIM-SM domains. The receivers can override the RPs in other domains and directly join the multicast source based SPT.
III. RPF check rules for SA messages
As shown in Figure 1-3, there are five autonomous systems in the network, AS 1 through AS 5, with IGP enabled on routers within each AS and BGP as the interoperation protocol among different ASs. Each AS contains at least one PIM-SM domain and each PIM-SM domain contains one ore more RPs. MSDP peering relationships have been established among different RPs. RP 3, RP 4 and RP 5 are in an MSDP mesh group. On RP 7, RP 6 is configured as its static RPF peer.
&  Note:
If only one MSDP peer exists in a PIM-SM domain, this PIM-SM domain is also called a stub domain. For example, AS 4 in Figure 1-3 is a stub domain. The MSDP peer in a stub domain can have multiple remote MSDP peers at the same time. You can configure one or more remote MSDP peers as static RPF peers. When an RP receives an SA message from a static RPF peer, the RP accepts the SA message and forwards it to other peers without performing an RPF check.
Figure 1-3 Diagram for RPF check for SA messages
As illustrated in Figure 1-3, these MSDP peers dispose of SA messages according to the following RPF check rules:
1)         When RP 2 receives an SA message from RP 1
Because the source-side RP address carried in the SA message is the same as the MSDP peer address, which means that the MSDP peer where the SA is from is the RP that has created the SA message, RP 2 accepts the SA message and forwards it to its other MSDP peer (RP 3).
2)         When RP 3 receives the SA message from RP 2
Because the SA message is from an MSDP peer (RP 2) in the same AS, and the MSDP peer is the next hop on the optimal path to the source-side RP, RP 3 accepts the message and forwards it to other peers (RP 4 and RP 5).
3)         When RP 4 and RP 5 receive the SA message from RP 3
Because the SA message is from an MSDP peer (RP 3) in the same mesh group, RP 4 and RP 5 both accept the SA message, but they do not forward the message to other members in the mesh group; instead, they forward it to other MSDP peers (RP 6 in this example) out of the mesh group.
4)         When RP 6 receives the SA messages from RP 4 and RP 5 (suppose RP 5 has a higher IP address)
Although RP 4 and RP 5 are in the same SA (AS 3) and both are MSDP peers of RP 6, because RP 5 has a higher IP address, RP 6 accepts only the SA message from RP 5.
5)         When RP 7 receives the SA message from RP 6
Because the SA message is from a static RPF peer (RP 6), RP 7 accepts the SA message and forwards it to other peer (RP 8).
6)         When RP 8 receives the SA message from RP 7
A BGP route exists between two MSDP peers in different ASs. Because the SA message is from an MSDP peer (RP 7) in a different AS, and the MSDP peer is the next hop on the BGP route to the source-side RP, RP 8 accepts the message and forwards it to its other peer (RP 9).
7)         When RP 9 receives the SA message from RP 8
Because RP 9 has only one MSDP peer, RP 9 accepts the SA message.
SA messages from other paths than described above will not be accepted nor forwarded by MSDP peers.
IV. Implementing intra-domain Anycast RP by leveraging MSDP peers
Anycast RP refers to such an application that enables load balancing and redundancy backup between two or more RPs within a PIM-SM domain by configuring the same IP address for, and establishing MSDP peering relationships between, these RPs.
As shown in Figure 1-4, within the same PIM-SM domain, a multicast source sends multicast data to multicast group G, and Receiver is a member of the multicast group. To implement Anycast RP, configure the same IP address (known as anycast RP address, typically a private address) on Router A and Router B, configure these interfaces as C-RPs, and establish an MSDP peering relationship between Router A and Router B.
&  Note:
Usually an Anycast RP address is configured on a logic interface, like a loopback interface.
Figure 1-4 Typical network diagram of Anycast RP
The work process of Anycast RP is as follows:
1)         The multicast source registers with the nearest RP. In this example, Source registers with RP 1, with its multicast data encapsulated in the register message. When the register message arrives at RP 1, RP 1 decapsulates the message.
2)         Receivers send join messages to the nearest RP to join in the RPT rooted as this RP. In this example, Receiver joins the RPT rooted at RP 2.
3)         RPs share the registered multicast information by means of SA messages. In this example, RP 1 creates an SA message and sends it to RP 2, with the multicast data from Source encapsulated in the SA message. When the SA message reaches RP 2, RP 2 decapsulates the message.
4)         Receivers receive the multicast data along the RPT and directly join the SPT rooted at the multicast source. In this example, RP 2 forwards the multicast data down the RPT. When Receiver receives the multicast data from Source, it directly joins the SPT rooted at Source.
The significance of Anycast RP is as follows:
l           Optimal RP path: A multicast source registers with the nearest RP so that an SPT with the optimal path is built; a receiver joins the nearest RP so that an RPT with the optimal path is built.
l           Load balancing between RPs: Each RP just needs to maintain part of the source/group information within the PIM-SM domain and forward part of the multicast data, thus achieving load balancing between different RPs.
l           Redundancy backup between RPs: When an RP fails, the multicast source previously registered on it or the receivers previous joined it will register with or join another nearest RP, thus achieving redundancy backup between RPs.
l      Be sure to configure a 32-bit subnet mask (255.255.255.255) for the Anycast RP address, namely configure the Anycast RP address into a host address.
l      An MSDP peer address must be different from the Anycast RP address.
1.1.3  MSDP Related Protocols and Standards
MSDP is documented in the following specifications:
l           RFC 3618: Multicast Source Discovery Protocol (MSDP)
l           RFC 3446: Anycast Rendezvous Point (RP) mechanism using Protocol Independent Multicast (PIM) and Multicast Source Discovery Protocol (MSDP)
1.2  MSDP Configuration Task List
Complete these tasks to configure MSDP:
Remarks
Enabling MSDP
Required
Creating an MSDP Peer Connection
Required
Configuring a Static RPF Peer
Optional
Configuring MSDP Peer Description
Optional
Configuring an MSDP Mesh Group
Optional
Configuring MSDP Peer Connection Control
Optional
Configuring SA Message Content
Optional
Configuring SA Request Messages
Optional
Configuring an SA Message Filtering Rule
Optional
Configuring SA Message Cache
Optional
1.3  Configuring Basic Functions of MSDP
&  Note:
All the configuration tasks should be carried out on RPs in PIM-SM domains, and each of these RPs acts as an MSDP peer.
1.3.1  Configuration Prerequisites
Before configuring the basic functions of MSDP, complete the following tasks:
l           Configure any unicast routing protocol so that all devices in the domain are interoperable at the network layer.
l           Configuring the basic functions of PIM-SM to enable intra-domain multicast forwarding.
Before configuring the basic functions of MSDP, prepare the following data:
l           IP addresses of MSDP peers
l           Address prefix list for an RP address filtering policy
1.3.2  Enabling MSDP
Follow these steps to enable MSDP:
To do...
Use the command...
Remarks
Enter system view
Enable IP multicast routing
multicast routing-enable
Required
Disabled by default
Enable MSDP and enter MSDP view
msdp
Required
Disabled by default
1.3.3  Creating an MSDP Peer Connection
An MSDP peering relationship is identified by an address pair, namely the address of the local MSDP peer and that of the remote MSDP peer. An MSDP peer connection must be created on both devices that are a pairs of MSDP peers.
Follow these steps to create an MSDP peer connection:
To do...
Use the command...
Remarks
Enter system view
Enter MSDP view
msdp
Create an MSDP peer connection
peer peer-address connect-interface interface-type interface-number
Required
No MSDP peer connection created by default
&  Note:
If an interface of the device is shared by an MSDP peer and a BGP peer at the same time, you are recommended to configuration the same IP address for the MSDP peer and BGP peer.
1.3.4  Configuring a Static RPF Peer
Configuring static RPF peers avoids RPF check of SA messages.
Follow these steps to configure a static RPF peer:
To do...
Use the command...
Remarks
Enter system view
Enter MSDP view
msdp
Configure a static RPF peer
static-rpf-peer peer-address [ rp-policy ip-prefix-name ]
Required
No static RPF peer configured by default
When configuring multiple static RPF peers on the same device, observe the following rules:
l           If you use the rp-policy keyword for all the static RPF peers, all the static RPF peers will be activated concurrently. SA messages will be filtered as per the configured prefix list and only those SA messages whose RP addresses pass the filtering will be accepted. If multiple static RPF peers use the same filtering policy at the same time, when a peer receives an SA message, it will forward the SA message to the other peers.
l           If you use the rp-policy keyword for none of the static RPF peers, according to the configuration sequence, only the first static RPF peer whose connection is in the UP state will be activated, and all SA messages from this peer will be accepted while the SA messages from other static RPF peers will be discarded. When this active static RPF peer fails (for example, when the configuration is removed or when the connection is torn down), based on the configuration sequence, the next RPF peer with its connection in the UP state will be selected as the activated RPF peer.
  Caution:
l      An MSDP peering connection must be created before static RPF peers can be configured.
l      If only one MSDP peer is configured on a device, this MSDP peer will act as a static RPF peer.
1.4  Configuring an MSDP Peer Connection
1.4.1  Configuration Prerequisites
Before configuring MSDP peer connection, complete the following tasks:
l           Configuring basic functions of MSDP
Before configuring an MSDP peer connection, prepare the following data:
l           Description information of MSDP peers
l           Name of an MSDP mesh group
l           MSDP peer connection retry interval
1.4.2  Configuring MSDP Peer Description
With the MSDP peer description information, the administrator can easily distinguish different MSDP peers and thus better manage MSDP peers.
Follow these steps to configure description for an MSDP peer:
To do...
Use the command...
Remarks
Enter system view
Enter MSDP view
msdp
Configure description for an MSDP peer
peer peer-address description text
Required
No description for MSDP peers by default
1.4.3  Configuring an MSDP Mesh Group
An AS may contain multiple MSDP peers. You can use the MSDP mesh group mechanism to avoid SA message flooding among these MSDP peers and optimize the multicast traffic.
On one hand, an MSDP peer in an MSDP mesh group forwards SA messages from outside the mesh group that have passed the RPF check to the other members in the mesh group; on the other hand, a mesh group member accepts SA messages from inside the group without performing an RPF check, and does not forward the message within the mesh group either. This mechanism not only avoids SA flooding but also simplifies the RPF check mechanism, because BGP is not needed to run between these MSDP peers.
By configuring the same mesh group name for multiple MSDP peers, you can create a mesh group with these MSDP peers.
Follow these steps to create an MSDP mesh group:
To do...
Use the command...
Remarks
Enter system view
Enter MSDP view
msdp
Create an MSDP peer as a mesh group member
peer peer-address mesh-group name
Required
An MSDP peer does not belong to any mesh group by default
  Caution:
l      Before grouping multiple devices into an MSDP mesh group, make sure that these devices are interconnected with one another.
l      Make sure to configure the same mesh group name on each peer.
l      If you configure more than one mesh group name on an MSDP peer, only the last configuration is effective.
1.4.4  Configuring MSDP Peer Connection Control
MSDP peers are interconnected over TCP. You can flexibly control sessions between MSDP peers by manually deactivating and reactivating the MSDP peering connections. When the connection between two MSDP peers is deactivated, SA messages will no longer be delivered between them, and the TCP connection is closed without any connection setup retry, but the configuration information will remain unchanged.
When a new MSDP peer is created, or when a previously deactivated MSDP peer connection is reactivated, or when a previously failed MSDP peer attempts to resume operation, a TCP connection is required. You can flexibly adjust the interval between MSDP peering connection retries.
Follow these steps to configure MSDP peer connection control:
To do...
Use the command...
Remarks
Enter system view
Enter MSDP view
msdp
Deactivate an MSDP peer
shutdown peer-address
Optional
Active by default
Configure the interval between MSDP peer connection retries
timer retry interval
Optional
30 seconds by default
1.5  Configuring SA Messages Related Parameters
1.5.1  Configuration Prerequisites
Before configuring SA message related parameters, complete the following tasks:
Before configuring SA message related parameters, prepare the following data:
l           ACL as a filtering rule for SA request messages
l           ACL as an SA message creation rule
l           ACL as a filtering rule for receiving or forwarding SA messages
l           Time-to-live (TTL) threshold for multicast packet encapsulation in SA messages
l           Maximum number of (S, G) entries learned from the specified MSDP peer that the router can cache
1.5.2  Configuring SA Message Content
Some multicast sources send multicast data at an interval longer than the aging time of (S, G) entries. In this case, the source-side DR has to encapsulate multicast data packet by packet in register messages and send them to the source-side RP. The source-side RP transmits the (S, G) information to the remote RP through SA messages. Then the remote RP joins the source-side DR and builds an SPT. Since the (S, G) entries have timed out, remote receivers can never receive the multicast data from the multicast source.
If the source-side RP is enabled to encapsulate register messages in SA messages, when there is a multicast packet to deliver, the source-side RP encapsulates a register message containing the multicast packet in an SA message and sends it out. After receiving the SA message, the remote RP decapsulates the SA message and delivers the multicast data contained in the register message to the receivers along the RPT.
The MSDP peers deliver SA messages to one another. Upon receiving an SA message, a device performs RPF check on the message. If the device finds that the remote RP address is the same as the local RP address, it will discard the SA message. In the Anycast RP application, however, you need to configure RPs with the same IP address on two or more devices in the same PIM-SM domain, and configure these devices as MSDP peers to one another. Therefore, a logic RP address (namely the RP address on the logic interface) that is different from the actual RP address must be designated for SA messages so that the messages can pass the RPF check.
Follow these steps to configure the SA message content:
To do...
Use the command...
Remarks
Enter system view
Enter MSDP view
msdp
Enable encapsulation of a registration message
encap-data-enable
Optional
Disabled by default
Configure the interface address as the RP address in SA messages
originating-rp interface-type interface-number
Optional
PIM RP address by default
1.5.3  Configuring SA Request Messages
By default, upon receiving a new Join message, a device does not send an SA request message to its designated MSDP peer; instead, it waits for the next SA message from its MSDP peer. This will cause the receiver to delay obtaining multicast source information. To enable a new receiver to get the currently active multicast source information as early as possible, you can configure devices to send SA request messages to the designated MSDP peers upon receiving a Join message of a new receiver.
Follow these steps to configure SA message transmission and filtering:
To do...
Use the command...
Remarks
Enter system view
Enter MSDP view
msdp
Enable sending SA request messages
peer peer-address request-sa-enable
Optional
Disabled by default
Configure a filtering rule for SA request messages
peer peer-address sa-request-policy [ acl acl-number ]
Optional
SA request messages are not filtered by default
&  Note:
l      With the function of sending SA request messages enabled, when receiving a Join message from a new multicast receiver, the device sends an SA request message to the remote MSDP peer specified by this command, and the remote peer responds with cached SA information. Upon sending an SA request message, the device receives the information about all the active multicast sources.
l      If you do not specify an ACL when configuring an SA message filtering rule, all the SA requests sent by the device’s MSDP peers will be ignored. If you specify an ACL, SA request messages complying with the filtering rule will be accepted, while all other SA request messages will be ignored.
  Caution:
Before you can enable the device to send SA requests, be sure to disable the SA message cache mechanism.
1.5.4  Configuring an SA Message Filtering Rule
By configuring an SA message creation rule, you can enable the router to filter the (S, G) entries to be advertised when creating an SA message, so that the propagation of messages of multicast sources is controlled.
By configuring a filtering rule for receiving or forwarding SA messages, you can enable the router to filter the (S, G) forwarding entries to be advertised when receiving or forwarding an SA message, so that the propagation of multicast source information is controlled at SA message reception or forwarding.
By configuring a TTL threshold for multicast data packet encapsulation in SA messages, you can control the multicast data packet encapsulation in SA messages and limit the propagation range of SA messages:
l           Before creating an SA message with an encapsulated multicast data packet, the router checks the TTL value of the multicast data packet. If the TTL value is less than the threshold, the router does not create an SA message; if the TTL value is greater than or equal to the threshold, the router encapsulates the multicast data in an SA message and sends the SA message out.
l           Upon receiving an SA message with an encapsulated multicast data packet, the router decrements the TTL value of the multicast packet by 1 and then checks the TTL value. If the TTL value is less than the threshold, the router does not forward the SA message to the designated MSDP peer; if the TTL value is greater than or equal to the threshold, the router re-encapsulates the multicast data in an SA message and sends the SA message out.
Follow these steps to configure a filtering rule for receiving or forwarding SA messages:
To do...
Use the command...
Remarks
Enter system view
Enter MSDP view
msdp
Configuring an SA message creation rule
import-source [ acl acl-number ]
Required
No restrictions on (S, G) entries by default
Configure a filtering rule for receiving or forwarding SA messages
peer peer-address sa-policy { import | export } [ acl acl-number ]
Required
No filtering rule by default
Configure the TTL threshold for multicast data packet encapsulation in SA messages
peer peer-address minimum-ttl ttl-value
Optional
0 by default
1.5.5  Configuring SA Message Cache
To reduce the time spent in obtaining the multicast information, you can enable the SA cache mechanism to cache (S, G) entries contained in SA messages locally on the router. However, the more (S, G) entries are cached, the larger memory space of the router is used.
With the SA cache mechanism enabled, when receiving a new (*, G) join message, the router searches its SA cache first:
l           If the corresponding (S, G) entry does not exist in the cache, the router waits for the SA message its MSDP peer will send in the next cycle;
l           If the corresponding (S, G) entry exists in the cache, the router joins the corresponding SPT rooted at S.
To protect the router effectively against denial of service (DoS) attacks, you can set a limit on the number of (S, G) entries the router can cache.
Follow these steps to configure the SA message cache:
To do...
Use the command...
Remarks
Enter system view
Enter MSDP view
msdp
Enable the SA message cache mechanism
cache-sa-enable
Required
Enabled by default
Configure the maximum number of (S, G) entries learned from the specified MSDP peer that the router can cache
peer peer-address sa-cache-maximum sa-limit
Required
8192 by default
1.6  Displaying and Maintaining MSDP
To do...
Use the command...
Remarks
View the brief information of MSDP peers status
display msdp brief
Available in any view
View the detailed information about the status of MSDP peers
display msdp peer-status [ peer-address ]
View the (S, G) entry information in the SA cache
display msdp sa-cache [ group-address | source-address | as-number ] *
View the number of (S, G) entries in the SA cache
display msdp sa-count [ as-number ]
Reset the TCP connection with an MSDP peer
reset msdp peer [ peer-address ]
Available in user view
Clear (S, G) entries in the SA cache
reset msdp sa-cache [ group-address ]
Clear all statistics information of an MSDP peer
reset msdp statistics [ peer-address ]
1.7  MSDP Configuration Examples
1.7.1  Example of Configuration Leveraging BGP Routes
I. Network requirements
l           Two ISPs maintains their ASs, AS 100 and AS 200 respectively. OSPF is running within each AS, and BGP is running between the two ASs.
l           PIM-SM 1 belongs to AS 100, while PIM-SM 2 and PIM-SM 3 belong to AS 200.
l           Each PIM-SM domain has zero or one multicast source and one or more receivers. OSPF runs within each domain to provide unicast routes.
l           MSDP peering relationships need to be established among RPs of different PIM-SM domains leveraging BGP routes.
l           The respective Loopback 0 interfaces of Switch C, Switch D and Switch F are configured as the C-BSR and C-RP of the respective PIM-SM domains.
l           An MSDP peering relationship needs to be established between Switch C and Switch D through BGP, and an MSDP peering relationship needs to be established between Switch D and Switch F through IBGP.
II. Network diagram
Device
IP address
Device
IP address
Switch C
Vlan-int100
10.110.1.1/24
Switch D
Vlan-int300
10.110.4.1/24
Vlan-int200
10.110.2.1/24
Vlan-int102
192.168.3.1/24
Vlan-int101
192.168.1.1/24
Vlan-int101
192.168.1.2/24
Loop0
1.1.1.1/32
Loop0
2.2.2.2/32
Switch F
Vlan-int400
10.110.3.1/24
Vlan-int102
192.168.3.2/24
Loop0
3.3.3.3/32
Figure 1-5 Network diagram for configuration leveraging a BGP route
III. Configuration procedure
&  Note:
Only the commands related to the MSDP configuration leveraging a BGP route are listed in this example.
1)         Configure IP addresses and unicast routing
Configure the IP address and subnet mask for each interface as per Figure 1-5. Detailed configuration steps are omitted.
Configure OSPF for interconnection between devices in each PIM-SM domain. Ensure the network-layer interoperation among Switch A, Switch B and Switch C in PIM-SM 1, the network-layer interoperation between Switch D and Switch E in PIM-SM 2, and the network-layer interoperation between Switch F and Switch G in PIM-SM 3, and ensure the dynamic update of routing information between the devices in each PIM-SM domain through a unicast routing protocol. Detailed configuration steps are omitted.
2)         Enable IP multicast routing, and enable PIM-SM on each interface
# Enable IP multicast routing on Switch C, and enable PIM-SM on each interface.
[SwitchC] multicast routing-enable
[SwitchC-Vlan-interface100] pim sm
[SwitchC-Vlan-interface200] pim sm
[SwitchC] interface vlan-interface 101
[SwitchC-Vlan-interface101] pim sm
The configuration on Switch A, Switch B, Switch D, Switch E, Switch F and Switch G is similar to the configuration on Switch C.
# Configure BSR boundary on Switch C.
[SwitchC-Vlan-interface101] pim bsr-boundary
[SwitchC-Vlan-interface101] quit
The configuration on Switch D and Switch F is similar to the configuration on Switch C.
3)         Configure C-BSRs and C-RPs
# Configure Loopback 0 as a C-BSR and a C-RP on Switch C.
[SwitchC-LoopBack0] ip address 1.1.1.1 255.255.255.255
[SwitchC-LoopBack0] pim sm
[SwitchC-LoopBack0] quit
[SwitchC] pim
[SwitchC-pim] c-bsr loopback 0
[SwitchC-pim] c-rp loopback 0
[SwitchC-pim] quit
4)         Configure inter-AS BGP and configure mutual route redistribution between BGP and OSPF
# Configure BGP on Switch C, and configure OSPF route redistribution.
[SwitchC] bgp 100
[SwitchC-bgp] router-id 1.1.1.1
[SwitchC-bgp] peer 192.168.1.2 as-number 200
[SwitchC-bgp] import-route ospf 1
[SwitchC-bgp] quit
# Configure IBGP and BGP on Switch D, and configure OSPF route redistribution.
<SwitchD> system-view
[SwitchD] bgp 200
[SwitchD-bgp] router-id 2.2.2.2
[SwitchD-bgp] peer 192.168.1.1 as-number 100
[SwitchD-bgp] peer 192.168.3.2 as-number 200
[SwitchD-bgp] import-route ospf 1
[SwitchD-bgp] quit
# Configure IBGP on Switch F, and configure OSPF route redistribution.
<SwitchF> system-view
[SwitchF] bgp 200
[SwitchF-bgp] router-id 3.3.3.3
[SwitchF-bgp] peer 192.168.3.1 as-number 200
[SwitchF-bgp] import-route ospf 1
[SwitchF-bgp] quit
# Configure BGP route redistribution in OSPF on Switch C.
[SwitchC] ospf 1
[SwitchC-ospf-1] import-route bgp
[SwitchC-ospf-1] quit
Use the display bgp peer command to view the BGP peering relationships between the switches. For example:
# View the information about BGP peering relationship on Switch C.
[SwitchC] display bgp peer
 BGP local router ID : 1.1.1.1
 Local AS number : 100
 Total number of peers : 1                 Peers in established state : 1
  Peer         V  AS  MsgRcvd  MsgSent  OutQ PrefRcv Up/Down  State
  192.168.1.2  4  200      24       21     0       6 00:13:09 Established
# View the information about BGP peering relationship on Switch D.
[SwitchD] display bgp peer
 BGP local router ID : 2.2.2.2
 Local AS number : 200
 Total number of peers : 2                 Peers in established state : 2
  192.168.1.1  4  100      18       16     0       1 00:12:04 Established
  192.168.3.2  4  200      21       20     0       6 00:12:05 Established
# View the information about BGP peering relationships on Switch F.
[SwitchF] display bgp peer
BGP local router ID : 3.3.3.3
  192.168.3.1  4  200      16       14     0       1 00:10:58 Established
5)         Configure MSDP peers
# Configure an MSDP peer on Switch C.
[SwitchC] msdp
[SwitchC-msdp] peer 192.168.1.2 connect-interface vlan-interface 101
[SwitchC-msdp] quit
# Configure an MSDP peer on Switch D.
[SwitchD] msdp
[SwitchD-msdp] peer 192.168.1.1 connect-interface vlan-interface 101
[SwitchD-msdp] peer 192.168.3.2 connect-interface vlan-interface 102
[SwitchD-msdp] quit
# Configure MSDP peers on Switch F.
[SwitchF] msdp
[SwitchF-msdp] peer 192.168.3.1 connect-interface vlan-interface 102
[SwitchF-msdp] quit
When the multicast source (Source 1) sends multicast information, receivers in PIM-SM 2 and PIM-SM 3 can receive the multicast data. You can use the display msdp brief command to view the brief information of MSDP peering relationships between the switches. For example:
# View the brief information about MSDP peering relationship on Switch C.
[SwitchC] display msdp brief
MSDP Peer Brief Information
  Configured   Up           Listen       Connect      Shutdown     Down
  1            1            0            0            0            0
  Peer's Address     State     Up/Down time    AS     SA Count   Reset Count
  192.168.1.2        Up        00:12:27       200    13         0
# View the brief information about MSDP peering relationship on Switch D.
[SwitchD] display msdp brief
  2            2            0            0            0            0
  192.168.3.2        Up        00:15:32       200    8          0
  192.168.1.1        Up        00:06:39       100    13         0
# View the brief information about MSDP peering relationships on Switch F.
[SwitchF] display msdp brief
  1            1            0            0            0            0
  192.168.3.1        Up        01:07:08       200    8          0
# View the detailed MSDP peer information on Switch C.
[SwitchC] display msdp peer-status
  MSDP Peer 192.168.1.2, AS 200
  Description:
  Information about connection status:
    State: Up
    Up/down time: 00:15:47
    Resets: 0
    Connection interface: Vlan-interface101 (192.168.1.1)
    Number of sent/received messages: 16/16
    Number of discarded output messages: 0
    Elapsed time since last connection or counters clear: 00:17:51
  Information about (Source, Group)-based SA filtering policy:
    Import policy: none
    Export policy: none
  Information about SA-Requests:
    Policy to accept SA-Request messages: none
    Sending SA-Requests status: disable
  Minimum TTL to forward SA with encapsulated data: 0
  SAs learned from this peer: 0, SA-cache maximum for the peer: none
  Input queue size: 0, Output queue size: 0
  Counters for MSDP message:
    Count of RPF check failure: 0
    Incoming/outgoing SA messages: 0/0
    Incoming/outgoing SA requests: 0/0
    Incoming/outgoing SA responses: 0/0
    Incoming/outgoing data packets: 0/0
1.7.2  Example of Anycast RP Application Configuration
l           The PIM-SM domain in this example has multiple multicast sources and receivers. OSPF runs within the domain to provide unicast routes.
l           The anycast RP application is configured in the PIM-SM domain. When a new member joins the multicast group, the switch directly connected to receivers can initiate a Join message to the topologically nearest RP.
l           An MSDP peering relationship is set up between Switch C and Switch F.
l           On Switch C and Switch F, the interface Loopback 1 is configured as a C-BSR, and Loopback 10 is configured as a C-RP.
l           The router ID of Switch C is 1.1.1.1, while the router ID of Switch F is 2.2.2.2.
II. Network diagram
Device
IP address
Device
IP address
Switch A
Vlan-int103
10.110.1.2/24
Switch D
Vlan-int300
10.110.4.1/24
Switch B
Vlan-int100
10.110.2.2/24
Vlan-int102
192.168.3.1/24
Switch C
Vlan-int103
10.110.1.1/24
Vlan-int101
192.168.1.2/24
Vlan-int100
10.110.2.1/24
Switch F
Vlan-int200
10.110.3.1/24
Vlan-int101
192.168.1.1/24
Vlan-int102
192.168.3.2/24
Loop0
1.1.1.1/32
Loop0
2.2.2.2/32
Loop1
3.3.3.3/32
Loop1
4.4.4.4/32
Loop10
10.1.1.1/32
Loop10
10.1.1.1/32
Figure 1-6 Network diagram for anycast RP configuration
&  Note:
Only the commands related to the configuration of Anycast RP application are listed in this example.
Configure the IP address and subnet mask for each interface as per Figure 1-6. Detailed configuration steps are omitted.
Configure OSPF for interconnection between the switches. Detailed configuration steps are omitted.
[SwitchC] interface vlan-interface 103
[SwitchC-Vlan-interface103] pim sm
[SwitchC-Vlan-interface103] quit
[SwitchC] interface loopback 1
[SwitchC-LoopBack1] pim sm
[SwitchC-LoopBack1] quit
[SwitchC] interface loopback 10
[SwitchC-LoopBack10] pim sm
[SwitchC-LoopBack10] quit
# On Switch C and Switch F, configure Loopback 1 as a C-BSR and configure Loopback 10 as a C-RP.
[SwitchC-LoopBack1] ip address 3.3.3.3 255.255.255.255
[SwitchC-LoopBack10] ip address 10.1.1.1 255.255.255.255
[SwitchC] pim
[SwitchC-pim] c-bsr loopback 1
[SwitchC-pim] c-rp loopback 10
[SwitchC-pim] quit
The configuration on Switch F is similar to the configuration on Switch C.
To view the PIM routing information on the switches, use the display pim routing-table command. When the multicast source (Source 1, with the address of 10.110.5.100/24) in the PIM-SM domain sends multicast data to the multicast group G (225.1.1.1), the receivers attached to Switch F can receive the multicast data.
# View the PIM routing information on Switch C.
[SwitchC] display pim routing-table
 (10.110.5.100, 225.1.1.1),
 RP: 10.1.1.1 (local)
     Protocol: pim-sm, Flag: SPT LOC ACT
     UpTime: 00:10:20
     Upstream interface: Vlan-interface100
         Upstream neighbor: 10.110.2.2
         RPF prime neighbor: 10.110.1.2
         1: Vlan-interface101
             Protocol: pim-sm, UpTime: 00:10:20, Expires: 00:03:10
# View the PIM routing information on Switch F.
[SwitchF] display pim routing-table
     Protocol: pim-sm, Flag: SPT ACT
     UpTime: 00:03:32
     Upstream interface: Vlan-interface102
         Upstream neighbor: 192.168.3.1
         RPF prime neighbor: 192.168.3.1
         1: Vlan-interface200
             Protocol: pim-sm, UpTime: 00:03:32, Expires: -
4)         Configure MSDP peers
# Configure an MSDP peer on Loopback0 of Switch C.
[SwitchC] msdp
[SwitchC-msdp] originating-rp loopback 0
[SwitchC-msdp] peer 2.2.2.2 connect-interface loopback 0
[SwitchC-msdp] quit
# Configure an MSDP peer on Loopback0 of Switch F.
[SwitchF] interface loopback 0
[SwitchF-LoopBack0] ip address 2.2.2.2 255.255.255.255
[SwitchF-LoopBack0] pim sm
[SwitchF-LoopBack0] quit
[SwitchF] msdp
[SwitchF-msdp] originating-rp loopback 0
[SwitchF-msdp] peer 1.1.1.1 connect-interface loopback 0
[SwitchF-msdp] quit
# View the brief MSDP peer information on Switch C.
  1            1            0            0            0            0
  2.2.2.2            Up        00:10:17        ?      0          0
# View the brief MSDP peer information on Switch F.
  1            1            0            0            0            0
  1.1.1.1            Up        00:10:18        ?      0          0
1.7.3  Static RPF Peer Configuration Example
l           PIM-SM 2 and PIM-SM 3 are both PIM stub domains, and BGP is not required between these two domains and PIM-SM 1. Instead, static RPF peers are configured to avoid RPF check on SA messages.
l           The respective loopback interfaces of Switch C, Switch D and Switch F are configured as the C-BSR and C-RP of the respective PIM-SM domains.
l           The static RPF peers of Switch C are Switch D and Switch F, while Switch C is the only RPF peer of Switch D and Switch F. Any switch can receive SA messages sent by its static RPF peer(s) and permitted by the corresponding filtering policy.
II. Network diagram
Device
IP address
Device
IP address
Switch D
Vlan-int101
192.168.1.2/24
Switch C
Vlan-int101
192.168.1.1/24
Loop0
2.2.2.2/32
Vlan-int102
192.168.3.1/24
Switch F
Vlan-int102
192.168.3.2/24
Loop0
1.1.1.1/32
Loop0
3.3.3.3/32
Figure 1-7 Network diagram for static RPF peer configuration
&  Note:
Only the commands related to the MSDP configuration for static RPF peering connections in PIM stub domains are listed in this example.
Configure the IP address and subnet mask for each interface of each switch as per Figure 1-7.
Configure OSPF for interconnection between the switches. Ensure network-layer interoperation within the AS, and ensure the dynamic update of routing information between the switches in each PIM-SM domain through a unicast routing protocol. Detailed configuration steps are omitted.
Configure BGP among Switch C, Switch D, Switch C and Switch F, and configure mutual route redistribution between BGP and OSPF. Detailed configuration steps are omitted.
[SwitchC-Vlan-interface102] pim bsr-boundary
3)         Configure C-BSRs and C-RPs.
[SwitchC] router-id 1.1.1.1
[SwitchC] pim
[SwitchC-pim] quit
4)         Configure static RPF peers
# Configure Switch D and Switch F as MSDP peers and static RPF peers of Switch C.
[SwitchC] ip ip-prefix list-df permit 192.168.0.0 16 greater-equal 16 less-equal 32
[SwitchC] msdp
[SwitchC-msdp] peer 192.168.3.2 connect-interface vlan-interface 102
[SwitchC-msdp] static-rpf-peer 192.168.3.2 rp-policy list-df
[SwitchC-msdp] static-rpf-peer 192.168.1.2 rp-policy list-df
[SwitchC-msdp] quit
# Configure Switch C as MSDP peer and static RPF peer of Switch D.
[SwitchD] ip ip-prefix list-c permit 192.168.0.0 16 greater-equal 16 less-equal 32
[SwitchD] msdp
[SwitchD-msdp] static-rpf-peer 192.168.1.1 rp-policy list-c
[SwitchD-msdp] quit
# Configure Switch C as MSDP peer and static RPF peer of Switch F.
[SwitchF] ip ip-prefix list-c permit 192.168.0.0 16 greater-equal 16 less-equal 32
[SwitchF] msdp
[SwitchF-msdp] static-rpf-peer 192.168.3.1 rp-policy list-c
[SwitchF-msdp] quit
5)         Verify the configuration
Carry out the display bgp peer command to view the BGP peering relationships between the switches. If the command gives no output information, a BGP peering relationship has not been established between the switches.
When the multicast source (Source 1) in PIM-SM 1 sends multicast information, receivers in PIM-SM 2 and PIM-SM 3 can receive the multicast data. You can use the display msdp brief command to view the brief information of MSDP peering relationships between the switches. For example:
  2            2            0            0            0            0
  192.168.3.2        Up        01:07:08       ?        8           0
  192.168.1.2        Up        00:16:39       ?        13          0
# View the brief MSDP peer information on Switch D.
  1            1            0            0            0            0
  192.168.1.1        Up        01:07:09       ?        8           0
  1            1            0            0            0            0
  192.168.3.1        Up        00:16:40       ?        13          0
1.8  Troubleshooting MSDP
1.8.1  MSDP Peers Stay in Down State
I. Symptom
The configured MSDP peers stay in the down state.
II. Analysis
l           A TCP connection–based MSDP peering relationship is established between the local interface address and the MSDP peer after the configuration.
l           The TCP connection setup will fail if there is a consistency between the local interface address and the MSDP peer address configured on the switch.
l           If no route is available between the MSDP peers, the TCP connection setup will also fail.
III. Solution
1)         Check that a route is available between the devices. Carry out the display ip routing-table command to check whether the unicast route between the switches is correct.
2)         Check that a unicast route is available between the two devices that will become MSDP peers to each other.
3)         Verify the interface address consistency between the MSDP peers. Use the display current-configuration command to verify that the local interface address and the MSDP peer address of the remote switch are the same.
1.8.2  No SA Entries in the Device’s SA Cache
I. Symptom
MSDP fails to send (S, G) entries through SA messages.
II. Analysis
l           The import-source command is used control sending (S, G) entries through SA messages to MSDP peers. If this command is executed without the acl-number argument, all the (S, G) entries will be filtered off, namely no (S, G) entries of the local domain will be advertised.
l           If the import-source command is not executed, the system will advertise all the (S, G) entries of the local domain. If MSDP fails to send (S, G) entries through SA messages, check whether the import-source command has been correct configured.
III. Solution
1)         Check that a route is available between the devices. Carry out the display ip routing-table command to check whether the unicast route between the devices is correct.
3)         Check configuration of the import-source command and its acl-number argument and make sure that ACL rule can filter appropriate (S, G) entries.
1.8.3  Inter-RP Communication Faults in Anycast RP Application
I. Symptom
RPs fail to exchange their locally registered (S, G) entries with one another in the Anycast RP application.
II. Analysis
l           In the Anycast RP application, RPs in the same PIM-SM domain are configured to be MSDP peers to achieve load balancing among the RPs.
l           An MSDP peer address must be different from the anycast RP address, and the C-BSR and C-RP must be configured on different devices or interfaces.
l           If the originating-rp command is executed, MSDP will replace the RP address in the SA messages with the address of the interface specified in the command.
l           When an MSDP peer receives an SA message, it performs RPF check on the message. If the MSDP peer finds that the remote RP address is the same as the local RP address, it will discard the SA message.
III. Solution
2)         Check that a unicast route is available between the two devices that will become MSDP peer to each other.
3)         Check the configuration of the originating-rp command. In the Anycast RP application environment, be sure to use the originating-rp command to configure the RP address in the SA messages, which must be the local interface address.
4)         Verify that the C-BSR address is different from the anycast RP address.
