00-1Cover | 63.89 KB |
H3C S3100 Series Ethernet Switches |
Quick Start (For Japan) |
Hangzhou H3C Technologies Co., Ltd. http://www.h3c.com
Manual Version: T2-08018X-20080110-C-1.04 |
Copyright © 2007-2008, Hangzhou H3C Technologies Co., Ltd. and its licensors
All Rights Reserved
No part of this manual may be reproduced or transmitted in any form or by any means without prior written consent of Hangzhou H3C Technologies Co., Ltd.
Trademarks
H3C, , Aolynk,
, H3Care,
, TOP G,
, IRF, NetPilot, Neocean, NeoVTL, SecPro,
SecPoint, SecEngine, SecPath, Comware, Secware, Storware, NQA, VVG, V2G,
VnG, PSPT, XGbus, N-Bus, TiGem, InnoVision and HUASAN are trademarks
All other trademarks that may be mentioned in this manual are the property of their respective owners.
Notice
The information in this document is subject to change without notice. Every effort has been made in the preparation of this document to ensure accuracy of the contents, but all statements, information, and recommendations in this document do not constitute the warranty of any kind, express or implied.
To obtain the latest information, please access:
http://www.h3c.com
Technical Support
http://www.h3c.com
About This Manual
Related Documentation
In addition to this manual, each H3C S3100 Series Ethernet Switches documentation set includes the following:
Manual |
Content |
H3C S3100 Series Ethernet Switches Operation Manual |
It is used for assisting the users in data configurations and typical applications. |
H3C S3100 Series Ethernet Switches Command Manual |
It is used for assisting the users in using various commands. |
H3C S3100 Series Ethernet Switches Installation Manual (For Japan) |
It is used for assisting the users in switch installation, booting up, hardware and software maintenance. |
Organization
H3C S3100 Series Ethernet Switches Quick Start (For Japan) is organized as follows:
Chapter |
Contents |
1 Product Overview |
Introduces the characteristics and technical specifications of S3100 Series Ethernet Switches. |
2 Installation Preparation |
Introduces the installation preparation and precaution of S3100 Series Ethernet Switches. |
3 Installation |
Introduces the procedures to install an S3100 Series Ethernet Switch, including the setup of the mainframe, cards and cables. |
4 Lightning Protection of the Switch |
Introduces lightning protection of S3100 Series Ethernet Switches. |
Conventions
The manual uses the following conventions:
I. GUI conventions
Convention |
Button names are inside angle brackets. For example, click <OK>. |
Window names, menu items, data table and field names are inside square brackets. For example, pop up the [New User] window. |
Multi-level menus are separated by forward slashes. For example, [File/Create/Folder]. |
II. Symbols
Convention |
Means reader be extremely careful. Improper operation may cause bodily injury. |
Means reader be careful. Improper operation may cause data loss or damage to equipment. |
& Note |
Means a complementary description. |
Environmental Protection
This product has been designed to comply with the requirements on environmental protection. For the proper storage, use and disposal of this product, national laws and regulations must be observed.
