H3C S3600 Series Ethernet Switches Installation Manual(V1.04)
HomeSupportSwitchesH3C S3600 Switch SeriesInstall & UpgradeInstallation GuidesH3C S3600 Series Ethernet Switches Installation Manual(V1.04)
00-1Cover
00-1Cover 304 KB
Installation Manual
Hangzhou H3C Technologies Co., Ltd.
http://www.h3c.com
Manual Version: T2-08045V-20070517-C-1.04
Copyright ? 2006-2007, Hangzhou H3C Technologies Co., Ltd. and its licensors
All Rights Reserved
No part of this manual may be reproduced or transmitted in any form or by any means without prior written consent of Hangzhou H3C Technologies Co., Ltd.
Trademarks
H3C, , Aolynk, , H3Care, , TOP G, , IRF, NetPilot, Neocean, NeoVTL, SecPro, SecPoint, SecEngine, SecPath, Comware, Secware, Storware, NQA, VVG, V2G, VnG, PSPT, XGbus, N-Bus, TiGem, InnoVision and HUASAN are trademarks of Hangzhou H3C Technologies Co., Ltd.
All other trademarks that may be mentioned in this manual are the property of their respective owners.
Notice
The information in this document is subject to change without notice. Every effort has been made in the preparation of this document to ensure accuracy of the contents, but all statements, information, and recommendations in this document do not constitute the warranty of any kind, express or implied.
To obtain the latest information, please access:
http://www. h3c.com
Technical Support
[email protected]
http://www. h3c.com
About This Manual
Related Documentation
In addition to this manual, each H3C S3600 Series Ethernet Switches documentation set includes the following:
Manual
H3C S3600 Series Ethernet Switches Operation Manual-Release 1510
It guides users to use H3C S3900 Series Ethernet Switches, in respect of CLI, login, configuration file management, VLAN, management VLAN, voice VLAN, GVRP, port basic configuration, link aggregation, MSTP, routing protocol, DHCP, and HWPing. It also explains the acronyms and abbreviations present in the manual.
H3C S3600 Series Ethernet Switches Command Manual-Release 1510
It provides detailed descriptions of the commands available on H3C S3900 Series Ethernet Switches about CLI, login, configuration file management, VLAN, management VLAN, voice VLAN, GVRP, port basic configuration, link aggregation, MSTP, routing protocol, DHCP, and HWPing. It also indexes the commands presents in the manual.
Organization
H3C S3600 Series Ethernet Switches Installation Manual is organized as follows:
Chapter
1 Product Overview
Introduces the characteristics and technical specifications of S3600 Series Ethernet Switches.
2 Preparation
Introduces the installation preparation and precaution of S3600 Series Ethernet Switches.
3 Installation
Introduces the procedures to install an S3600 Series Ethernet Switch, including the setup of the mainframe, cards and cables.
4 Starting up the Switch at the Initial Boot
Introduces the booting process of an S3600 Series Ethernet Switch, including the power-on booting of the switch and the system initialization.
5 Loading Boot ROM and Host Software
Introduces how to load BootROM and host software for an S3600 Series Ethernet Switch.
6 Maintenance and Troubleshooting
Introduces the problems that might occur during the installation and the booting of an S3600 Series Ethernet Switch and the related solution.
7 Appendix Lightning Protection of the Switch
Introduces lightning protection of S3600 Series Ethernet Switches.
Conventions
The manual uses the following conventions:
I. GUI conventions
Convention
Button names are inside angle brackets. For example, click <OK>.
Window names, menu items, data table and field names are inside square brackets. For example, pop up the [New User] window.
Multi-level menus are separated by forward slashes. For example, [File/Create/Folder].
II. Symbols
Convention
  Warning
Means reader be extremely careful. Improper operation may cause bodily injury.
  Caution
Means reader be careful. Improper operation may cause data loss or damage to equipment.
&  Note
Means a complementary description.
Environmental Protection
This product has been designed to comply with the requirements on environmental protection. For the proper storage, use and disposal of this product, national laws and regulations must be observed.
