H3C WX5002 Access Controller Installation Manual-(V1.02)
HomeSupportWirelessH3C WX5000 Series Access ControllersInstall & UpgradeInstallation GuidesH3C WX5002 Access Controller Installation Manual-(V1.02)
00-1Cover
00-1Cover 60.93 KB
Installation Manual
Hangzhou H3C Technologies Co., Ltd.
Manual Version: T2-080410-20090605-C-1.02
Copyright © 2007-2009, Hangzhou H3C Technologies Co., Ltd. and its licensors
H3C Technologies Co., Ltd., a subsidiary of 3Com Corporation.
All Rights Reserved
No part of this manual may be reproduced or transmitted in any form or by any means without prior written consent of Hangzhou H3C Technologies Co., Ltd.
Trademarks
H3C, Adobe Systems, Aolynk, , H3Care, , TOP G, , IRF, NetPilot, Neocean, NeoVTL, SecPro, SecPoint, SecEngine, SecPath, Comware, Secware, Storware, NQA, VVG, V2G, VnG, PSPT, XGbus, N-Bus, TiGem, InnoVision and HUASAN are trademarks of Hangzhou H3C Technologies Co., Ltd.
All other trademarks that may be mentioned in this manual are the property of their respective owners.
Notice
The information in this document is subject to change without notice. Every effort has been made in the preparation of this document to ensure accuracy of the contents, but all statements, information, and recommendations in this document do not constitute the warranty of any kind, express or implied.
About This Manual
Organization
H3C WX5002 Access Controller Installation Manual is organized as follows:
Chapter
1 Product Overview
Introduces the features and appearance of the H3C WX5002 access controller.
2 Installation Preparation
Introduces the installation environments of the H3C WX5002 access controller, the precautions before and during router installation, and the tools required for the installation.
3 Installation
Introduces the installation method for the WX5002 access controller, power cable connection, console cable connection, Ethernet cable connection, and a post-installation checklist.
4 Initial Startup
Introduces the startup and configuration of the WX5002 access controller, including the establishment of a configuration environment, connection of the console cable, setting of the terminal parameters, and Access Controller startup.
5 AC Software Maintenance
Introduces the software maintenance for the WX5002 access controller, covering the BootWare menu, software upgrade, and password loss handling.
6 Maintenance and Troubleshooting
Introduces problems that may occur during the startup of the WX5002 access controller and the solutions to the problems.
Appendix A Obtaining Support for your Product
Introduces how to obtain support for the product.
Conventions
The manual uses the following conventions:
GUI conventions
Convention
Boldface
Window names, button names, field names, and menu items are in Boldface. For example, the New User window appears; click OK.
Convention
Button names are inside angle brackets. For example, click <OK>.
Window names, menu items, data table and field names are inside square brackets. For example, pop up the [New User] window.
Multi-level menus are separated by forward slashes. For example, [File/Create/Folder].
Symbols
Convention
Means reader be extremely careful. Improper operation may cause bodily injury.
Means reader be careful. Improper operation may cause data loss or damage to equipment.
Means an action or information that needs special attention to ensure successful configuration or good performance.
Means a complementary description.
Related Documentation
In addition to this manual, each H3C WX5000 Series Access Controller documentation set includes the following:
Manual
H3C WX Series Access Controller Products User Manual
Provides a guide to the configuration of the WX series access controllers. The manual covers command line interface, VLAN, system maintenance and debugging, wireless LAN, IPv4, IPv6, basic port configurations, multicast protocols, 802.1x, AAA, SSH, ACL, QoS, and description of the acronyms used throughout the manual.
H3C WX Series Access Controller Products Web-Based Configuration Manual
Introduces the Web-based management function of the WX series access controllers.
Obtaining Documentation and Technical Support
To obtain up-to-date documentation and technical support, go to http://www.h3c.com and select your country or region. Depending on your selection, you will be redirected to either of the following websites:
At http://www.h3c.com
Documentation
Go to the following columns for different categories of product documentation:
[Products & Solutions]: Provides information about products and technologies.
[Technical Support & Document > Technical Documents]: Provides several categories of product documentation, such as installation and configuration.
[Technical Support & Document > Software Download]: Provides the documentation released with the software version.
Technical Support
[email protected]
http://www.h3c.com
At http://www.h3cnetworks.com
Documentation
Select Drivers & Downloads in the Support area.
Select Documentation for Type of File and select Product Category.
Technical Support
Please see the appendix Obtaining Support for Your Product.
Documentation Feedback
We appreciate your comments.
Environmental Protection
This product has been designed to comply with the requirements on environmental protection. For the proper storage, use and disposal of this product, national laws and regulations must be observed.
