H3C S5500-SI Complete Series Ethernet Switches Installation Guide(V1.03)
HomeSupportSwitchesH3C S5500 Switch SeriesInstall & UpgradeInstallation GuidesH3C S5500-SI Complete Series Ethernet Switches Installation Guide(V1.03)
Preface
H3C S5500-SI Switch Series Installation Guide describes the appearance, installation, power-on, maintenance, and troubleshooting of the S5500-SI switches.
This preface includes:
·           Audience
·           Conventions
·           About the H3C S5500-SI documentation set
·           Obtaining documentation
·           Technical support
·           Documentation feedback
Audience
·           Network planners
·           Field technical support and servicing engineers
·           Network administrators working with the S5500-SI series
Conventions
This section describes the conventions used in this documentation set.
Command conventions
Convention
Boldface
Italic
{ x | y | ... }
[ x | y | ... ]
{ x | y | ... } *
Asterisk marked braces enclose a set of required syntax choices separated by vertical bars, from which you select at least one.
[ x | y | ... ] *
&<1-n>
GUI conventions
Convention
Boldface
Window names, button names, field names, and menu items are in Boldface. For example, the New User window appears; click OK.
Symbols
Convention
WARNING WARNING
CAUTION CAUTION
IMPORTANT IMPORTANT
NOTE
TIP TIP
Network topology icons
Port numbering in examples
The port numbers in this document are for illustration only and might be unavailable on your device.
The H3C S5500-SI documentation set includes:
Category
Documents
Purposes
Product description and specifications
Marketing brochures
Describe product specifications and benefits.
Technology white papers
Provide an in-depth description of software features and technologies.
Hardware specifications and installation
Compliance and safety manual
CE DOCs
Provide regulatory information and the safety instructions that must be followed during installation.
Quick start
Guides you through initial installation and setup procedures to help you quickly set up your device.
Installation guide
Provides a complete guide to switch installation and specifications.
RPS Ordering Information for H3C Low-End Ethernet Switches
Helps you order RPSs for switches that can work with an RPS.
User manuals for RPSs
Describe the specifications, installation, and replacement of RPSs.
User manuals for interface cards
Describe the specifications, installation, and replacement of expansion interface cards.
H3C Low End Series Ethernet Switches Pluggable Modules Manual
Describes the specifications of pluggable transceiver modules.
Pluggable SFP[SFP+][XFP] Transceiver Modules Installation Guide
Describe the installation, and replacement of SFP/SFP+/XFP transceiver modules.
Software configuration
Configuration guides
Describe software features and configuration procedures.
Command references
Provide a quick reference to all available commands.
Operations and maintenance
H3C Series Ethernet Switches Login Password Recovery Manual
Helps you deal with switch login password loss.
Release notes
Provide information about the product release, including the version history, hardware and software compatibility matrix, version upgrade information, technical support information, and software upgrading.
You can access the most up-to-date H3C product documentation on the World Wide Web at http://www.h3c.com.
Click the links on the top navigation bar to obtain different categories of product documentation:
[Technical Support & Documents > Technical Documents] – Provides hardware installation, software upgrading, and software feature configuration and maintenance documentation.
[Products & Solutions] Provides information about products and technologies, as well as solutions. [Technical Support & Documents > Software Download] – Provides the documentation released with the software version.
Technical support
[email protected]
http://www.h3c.com
We appreciate your comments.
