About the S3100V2 Configuration Guides
HomeSupportSwitchesH3C S3100V2 Switch SeriesConfigure & DeployConfiguration GuidesH3C S3100V2 Switch Series Configuration Guides-Release 5103-6W100About the S3100V2 Configuration Guides
Download Book
The S3100V2 configuration guides are part of the S3100V2 documentation set. They describe the software features for the S3100V2 switch series, Release5103, and guide you through the software configuration procedures. These configuration guides also provide configuration examples to help you apply the software features to different network scenarios. The S3100V2 documentation set includes 9 configuration guides:
Configuration guide
Content
Fundamentals Configuration Guide
Describes how to use the command line interface of the switch, log in to and set up the switch, and use the automatic configuration function. This guide includes:
·       CLI configuration
·       Login methods
·       CLI login
·       Web login
·       NMS login
·       User login control
·       FTP configuration
·       TFTP configuration
·       File management configuration
·       Configuration file management
·       Software upgrade configuration
·       Device management configuration
·       Automatic configuration
Layer 2 – LAN Switching Configuration Guide
Covers Layer 2 technologies and features used on a LAN switched network, such as VLAN technology, port isolation, MSTP. You can use these features to divide broadcast domains, remove Layer 2 loops, isolate users within a VLAN, re-mark VLAN tags, and so on. This guide includes:
·       Ethernet interface configuration
·       Loopback and null interface configuration
·       MAC address table configuration
·       MAC information configuration
·       Ethernet Link aggregation configuration
·       Port Isolation configuration
·       MSTP configuration
·       BPDU tunneling configuration
·       VLAN configuration
·       Voice VLAN configuration
·       GVRP configuration
·       QinQ configuration
·       VLAN Mapping Configuration
·       LLDP configuration
Layer 3 – IP Services Configuration Guide
Describes how to configure IP addressing, DHCP, IP performance optimization, ARP, DNS, IPv6 basics and DHCPv6,. This guide includes:
·       ARP configuration
·       Gratuitous ARP configuration
·       IP addressing configuration
·       DHCP overview
·       DHCP client configuration
·       DHCP snooping configuration
·       BOOTP client configuration
·       IPv4 DNS configuration
·       IPv6 DNS configuration
·       IP performance optimization configuration
·       IPv6 basics configuration
·       DHCPv6 overview
·       DHCPv6 client configuration
·       DHCPv6 snooping configuration
Layer 3 – IP Routing Configuration Guide
Covers the routing technologies for IPv4 and IPv6 networks. This guide includes:
·       IP Routing Overview
·       Static Routing Configuration
·       IPv6 Static Routing Configuration
IP Multicast Configuration Guide
Describes Layer 2 multicast fundamentals and configuration. This guide includes:
·       Mulitcast overview
·       IGMP snooping configuration
·       Multicast VLAN configuration
·       MLD snooping configuration
·       IPv6 multicast VLAN configuration
ACL and QoS Configuration Guide
Describes how to classify traffic with ACLs, and allocate network resources and manage congestions with QoS technologies to improve network performance and network use efficiency. This guide includes:
·       ACL configuration
·       QoS overview
·       QoS configuration approaches
·       Priority mapping configuration
·       Traffic policing, traffic shaping, and line rate configuration
·       Congestion management configuration
·       Traffic filtering configuration
·       Priority marking configuration
·       Traffic redirecting configuration
·       Class-based accounting configuration
·       Data buffer configuration
·       Appendix A Default priority mapping tables
·       Appendix B Introduction to packet precedences
Security Configuration Guide
Covers security features. The major security features available on the switch include identity authentication (AAA and PKI), access security (802.1X, MAC authentication, and so on), secure management (SSH), SSL, and attack protection (IP source guard, ARP attack protection, and so on). This guide includes:
·       AAA configuration
·       802.1X fundamentals
·       802.1X configuration
·       EAD fast deployment configuration
·       MAC authentication configuration
·       Portal configuration
·       Triple authentication configuration
·       Port security configuration
·       User profile configuration
·       Password control configuration
·       HABP configuration
·       Public key configuration
·       PKI configuration
·       SSH2.0 configuration
·       SFTP configuration
·       SSL configuration
·       TCP attack protection configuration
·       IP source guard configuration
·       ARP attack protection configuration
·       ND attack defense configuration
·       SAVI Configuration
High Availability Configuration Guide
Describes high availability technologies and features available on the switch for failure detection and failover. Failure detection technologies focus on fault detection and isolation. Failover technologies focus on network recovery. This guide includes:
·       High availability overview
·       Ethernet OAM configuration
·       DLDP configuration
·       Smart Link configuration
·       Monitor Link configuration
Network Management and Monitoring Configuration Guide
Describes features that help you manage and monitor your network, for example, manage system events, assess network performance, synchronize the clock for all devices with the clock in the network, supply power for attached devices by using PoE, perform cluster management for switches, and test network connectivity. This guide includes:
·       System maintenance and debugging
·       NQA configuration
·       NTP configuration
·       PoE configuration
·       SNMP configuration
·       MIB style configuration
·       RMON configuration
·       Cluster management configuration
·       Port mirroring configuration
·       Traffic mirroring configuration
·       Stack Management configuration
·       Information center configuration
