01-AD-DC 6.3 Unified Platform and Components Deployment Guide
HomeSupportAD-NET(SDN)H3C AD-DCConfigure & DeployConfiguration GuidesAD-DC 6.3 Configuration Guide-5W10001-AD-DC 6.3 Unified Platform and Components Deployment Guide
Download Book
AD-DC 6.3
Document version: 5W100-20230513
Copyright © 2023 New H3C Technologies Co., Ltd. All rights reserved.
This document provides generic technical information, some of which might not be applicable to your products.
Overview
Components
This document describes the deployment procedures for the following AD-DC components:
·     Unified Platform—Platform component on which you deploy controllers and analyzers.
·     SeerEngine-DC—Controller component that runs SDN applications. It controls resources on the network and is the network management center.
·     SeerAnalyzer—Analyzer component that provides intelligent analysis for AD-DC solutions.
·     vBGP—Virtual BGP component that provides conversion between host overlay flow tables and network overlay EVPN routes. It is typically used in hybrid overlay scenarios.
·     Digital-Twin-Network (DTN)—Simulation component that provides the simulation functionality.
·     CollectorCollects and sends traffic to SeerAnalyzer.
·     Super Controller—Manages the SDN controller cluster in the multi-data center scenario and provides unified service orchestration and O&M across data centers.
·     Super Analyzer-DCManages multiple analyzers in the cross-data center scenario. It provides NetStream, sFlow, and full-flow data collection and analysis and can implement cross-data center network traffic analysis.
Deployment workflow
Figure 1 Deployment workflow
Hardware resource requirements
For the server hardware resources required to install the components, see AD-NET Solution Hardware Configuration Guide.
Plan network configuration
The following information uses examples to describe how to plan network configuration for Unified Platform and all its components. You can select components for your deployment scenario as required.
Super Controller uses the northbound service VIP of Unified Platform to communicate with sites. You do not need to plan a separate management IP address for it.
The vBGP component supports both the management network and service network converged scheme and management network and service network separated scheme. This document uses the  management network and service network converged scheme for the controller for example and the southbound and northbound integrated network (no southbound network) scheme for the analyzer for example.
This section plans only for the management network configuration. For service network configuration, see the network configuration plan for the specific deployment scenario.
The IP address plan in this section is for illustration only.
Standalone deployment
About standalone deployment
The vBGP component is not supported in the standalone deployment scenario.
In a standalone deployment, you deploy SeerEngine-DC, Super Controller, SeerAnalyzer, and Super Analyzer-DC on separate Unified Platform nodes, and deploy the collector on a server other than the Unified Platform nodes.
Connect all the Unified Platform nodes to the management switch and configure the management switch to provide gateway services.
IP address plan
Component
IP address type
IP addresses
Remarks
Unified Platform 1
(on which SeerEngine-DC is deployed)
Master node IP
192.168.10.102/24
These IP addresses must be on the same network segment.
Specify gateway 192.168.10.1, which is placed on the management switch.
Cluster internal VIP
192.168.10.101/32
Northbound service VIP
192.168.10.100/32
Unified Platform 2
(on which SeerAnalyzer is deployed)
Master node IP
192.168.10.202/24
192.168.10.201/32
192.168.10.200/32
Unified Platform 3
(on which Super Controller is deployed)
Master node IP
192.168.10.212/24
192.168.10.211/32
192.168.10.210/32
Unified Platform 4
(on which Super Analyzer-DC is deployed)
Master node IP
192.168.10.222/24
Super Analyzer-DC uses the northbound service VIP of Unified Platform as its management IP address. You do not need to plan a separate management IP address for it.
192.168.10.221/32
192.168.10.220/32
Collector
Management IP
192.168.10.50/24
Southbound collection IP
11.1.1.0/24
You need to configure two IP addresses. Use one to receive mirrored network device packets. Use the other as the SeerCollector float IP for it to be discovered by devices.
SeerEngine-DC
Management network
Subnet: 192.168.12.0/24
Network address pool: 192.168.12.101 to 192.168.12.132
Configure a MACVLAN-type management network. Specify gateway 192.168.12.1, which is placed on the management switch.
SeerAnalyzer
Management network
Network address pool: 192.168.12.141 to 192.168.12.172
Cluster separated deployment
About cluster separated deployment
In a cluster separated deployment, you deploy SeerEngine-DC, SeerAnalyzer (analyzer), Super Controller, and Super Analyzer-DC in separate Uniform Platform clusters, and deploy the collector on a separate physical server.
This document uses the following cluster separated deployment for example:
·     Unified Platform cluster 1—Contains three master nodes and one worker node for SeerEngine-DC deployment. vBGP is deployed on two master nodes, and DTN is deployed on the worker node.
·     Unified Platform cluster 2Contains three master nodes for SeerAnalyzer deployment.
·     Unified Platform cluster 3Contains three master nodes for Super Controller deployment.
·     Unified Platform cluster 4Contains three master nodes for Super Analyzer-DC deployment.
·     Separate server—Used for collector deployment.
Connect all these servers to the management switch and configure the management switch to provide gateway services. You must use a network interface on each of the two servers on which vBGP is deployed for configuring a management network for vBGP.
The Unified Platform cluster for SeerEngine-DC can span one subnet or multiple subnets. For high availability, you can deploy the master nodes in 2+1+1 mode. For information about address planning and available deployment modes, see H3C SeerEngine-DC Installation Guide. In this deployment example, the nodes are deployed on the same subnet.
IP address plan
Component
IP address type
IP addresses
Remarks
Master node 1 IP
192.168.10.102/24
In this example, all the IP addresses are on the same subnet.
Master node 2 IP
192.168.10.103/24
Master node 3 IP
192.168.10.104/24
Worker node 1 IP (DTN)
192.168.10.105/24
192.168.10.101/32
192.168.10.100/32
Master node 4 IP (SeerAnalyzer)
192.168.10.202/24
Master node 5 IP (SeerAnalyzer)
192.168.10.203/24
Master node 6 IP (SeerAnalyzer)
192.168.10.204/24
192.168.10.201/32
192.168.10.200/32
Master node 7 IP (Super Controller)
192.168.10.212/24
Master node 8 IP (Super Controller)
192.168.10.213/24
Master node 9 IP (Super Controller)
192.168.10.214/24
192.168.10.211/32
Northbound service virtual IP
192.168.10.210/32
Master node 10 IP (Super Analyzer-DC)
192.168.10.222/24
Master node 11 IP (Super Analyzer-DC)
192.168.10.223/24
Master node 12 IP (Super Analyzer-DC)
192.168.10.224/24
192.168.10.221/32
192.168.10.220/32
Collector
Management IP
192.168.10.50/24
11.1.1.0/24
SeerEngine-DC
Management network
vBGP
Management network and service network converged
Subnet: 192.168.13.0/24
Network address pool: 192.168.13.101 to 192.168.13.132
Configure OVSDPDK networks. Specify gateway 192.168.13.1, which is placed on the management switch.
DTN
Management network
Subnet: 192.168.15.0/24
Network address pool: 192.168.15.101 to 192.168.15.101
DTN host node
Simulation management network
Network address pool: 192.168.12.134/24 to 192.168.12.144/24
N/A
Simulation device service network
Network address pool: 192.168.11.134/24 to 192.168.11.144/24
N/A
Node management network
Network address pool: 192.168.10.110 to 192.168.10.120
N/A
SeerAnalyzer
Management network
Configure a MACVLAN-type management network. Specify gateway 192.168.10.1, which is placed on the management switch.
Cluster converged deployment
About cluster converged deployment
In a cluster converged deployment, you deploy SeerEngine-DC, SeerAnalyzer, Super Controller, and Super Analyzer-DC on one Unified Platform cluster.
This document uses the following cluster converged deployment for example:
·     Deploy a Unified Platform cluster that has three master nodes and four worker nodes.
·     Deploy SeerEngine-DC and Super Controller on the three master nodes.
·     Deploy SeerAnalyzer and Super Analyzer-DC on three of the worker nodes.
·     Deploy vBGP on two of the master nodes.
·     Deploy DTN on one of the worker nodes.
·     Deploy collectors on servers outside of the cluster. In this example, one collector is deployed.
IP address plan
Component
IP address type
IP addresses
Remarks
Unified Platform
Master node 1 IP
192.168.10.102/24
Specify gateway 192.168.10.1 for the component, which is placed on the management switch.
Master node 2 IP
192.168.10.103/24
Master node 3 IP
192.168.10.104/24
Worker node 7 IP (DTN)
192.168.10.105/24
Worker node 4 IP (SeerAnalyzer)
192.168.10.202/24
Worker node 5 IP (SeerAnalyzer)
192.168.10.203/24
Worker node 6 IP (SeerAnalyzer)
192.168.10.204/24
192.168.10.101/32
192.168.10.100/32
Collector
Management IP
192.168.10.50/24
11.1.1.0/24
SeerEngine-DC
Management network
Configure a MACVLAN-type management network. Specify gateway 192.168.12.1 for the component, which is placed on the management switch.
vBGP
Management network
Configure an OVSDPDK-type management network. Specify gateway 192.168.13.1, which is placed on the management switch.
DTN
Management network
Configure a MACVLAN-type management network. Specify gateway 192.168.15.1, which is placed on the management switch.
DTN host node
N/A
N/A
N/A
SeerAnalyzer
Management network
Deploy the components
Deploy Unified Platform
For the Unified Platform deployment procedure, see H3C Unified Platform Deployment Guide. For information about how to obtain this document, see "Appendix A  Obtain documentation."
To run the controller on Unified Platform, partition the system drive and deploy all required application installation packages required by the controller.
Partition the drive
Partition the drive on the node where a controller resides
Use the following table to partition the drive. Do not use automatic partitioning for the drive.
Table 1 Drive partition settings (2400 GB)
RAID configuration
Partition name
Mounting point
Minimum capacity
Remarks
RAID 10, with a total drive size 2400 GB
/dev/sda1
/boot/efi
200 MiB
EFI system partition, required only in UEFI mode.
/dev/sda2
/boot
1024 MiB
N/A
/dev/sda3
900 GiB
Supports capacity expansion when the drive size is sufficient.
/dev/sda4
/var/lib/docker
460 GiB
/dev/sda6
swap
1024 MiB
Swap partition.
/dev/sda7
/var/lib/ssdata
520 GiB
/dev/sda8
N/A
300 GiB
Reserved for GlusterFS. You do not need to configure this partition during operating system installation.
RAID 1, with a total drive size 50 GB
/dev/sdb
/var/lib/etcd
50 GiB
·     For a controller in a version earlier than E6203 deployed on Unified Platform in a version earlier than E0706 (including E06xx), make sure the etcd partition has exclusive use of a physical drive.
·     For a controller in E6203 or later deployed on Unified Platform in E0706 or later, the etcd partition can share a physical drive with other partitions. As a best practice for optimal performance, use a separate drive for the etcd partition.
Table 2 Drive partition settings (1920 GB)
RAID configuration
Partition name
Mounting point
Minimum capacity
Remarks
RAID 10, with a total drive size 1920 GB
/dev/sda1
/boot/efi
200 MiB
EFI system partition.
This partition is required only in UEFI mode.
/dev/sda2
/boot
1024MiB
N/A
/dev/sda3
650 GiB
/dev/sda4
/var/lib/docker
410 GiB
/dev/sda6
swap
1024 MiB
Swap partition
/dev/sda7
/var/lib/ssdata
450 GiB
/dev/sda8
N/A
220 GiB
/dev/sdb
/var/lib/etcd
50 GiB
Partition the drives on the node where an analyzer resides
·     System drive
Table 3 System drive partition settings
RAID configuration
Partition name
Mounting point
Minimum capacity
Remarks
2*1.92 TB, RAID 1
/dev/sda1
/boot/efi
200 MB
/dev/sda2
/boot
1024 MB
N/A
/dev/sda3
400 GB
As a best practice, do not save service data in the root directory.
/dev/sda4
/var/lib/docker
400 GB
/dev/sda6
swap
4 GB
Swap partition.
/dev/sda7
/var/lib/ssdata
450 GB
/dev/sda8
N/A
500 GB
2*50 GB, RAID 1
/dev/sdb
/var/lib/etcd
50 GB
Make sure etcd has exclusive use of a physical disk.
·     Data drives
Data drives are mainly used to store SeerAnalyzer's service data and Kafka data. The required quantity and capacity of data drives depend on the network scale and amount of service data.
Table 4 Data drive partition configuration (option 1)
RAID configuration
Partition name
Mounting point
Minimum capacity
File system type
3*4 TB, RAID 5
/dev/sdc1
/sa_data
400 GB
ext4
/dev/sdc2
/sa_data/mpp_data
4800 GB
ext4
/dev/sdc3
/sa_data/kafka_data
2400 GB
ext4
Table 5 Data drive partition configuration (option 2)
RAID configuration
Partition name
Mounting point
Minimum capacity
File system type
5*4 TB, RAID 5
/dev/sdc1
/sa_data
400 GB
ext4
/dev/sdc2
/sa_data/mpp_data
9600 GB
ext4
/dev/sdc3
/sa_data/kafka_data
4800 GB
ext4
Table 6 Data drive partition configuration (option 3)
RAID configuration
Partition name
Mounting point
Minimum capacity
File system type
7*4 TB, RAID 5
/dev/sdc1
/sa_data
400 GB
ext4
/dev/sdc2
/sa_data/mpp_data
14400 GB
ext4
/dev/sdc3
/sa_data/kafka_data
7200 GB
ext4
Deploy the Unified Platform application packages
Unified Platform can be installed on x86 or ARM servers. Select the installation packages specific to the server type as described in Table 8 and upload the selected packages. For the installation procedures of the packages, see H3C Unified Platform Deployment Guide.
The common_PLAT_GlusterFS_2.0, general_PLAT_portal_2.0, general_PLAT_kernel_2.0, and general_PLAT_oneclickcheck_2.0 installation packages are required and must be deployed during the Unified Platform deployment process. For the deployment procedure, see "Deploying the applications" in H3C Unified Platform Deployment Guide.
The general_PLAT_kernel-base_2.0, general_PLAT_Dashboard_2.0, and general_PLAT_widget_2.0 installation packages are required. They will be installed automatically during the controller deployment process. You only need to upload the packages.
To use optional applications such as general_PLAT_network_2.0, webdm, Syslog, and general_PLAT_netconf_2.0, deploy them on Matrix manually. You can deploy them before or after SeerEngine-DC components are deployed. To avoid deployment failure, make sure the required and optional packages use the same version. For the deployment procedure, see "Deploying the applications" in H3C Unified Platform Deployment Guide.
Table 7 Installation packages required by the controller
·     x86: common_PLAT_GlusterFS_2.0_version_x86.zip
·     ARM: common_PLAT_GlusterFS_2.0_version_arm.zip
Provides local shared storage functionalities.
·     x86: general_PLAT_portal_2.0_version_x86.zip
·     ARM: general_PLAT_portal_2.0_version_arm.zip
Provides portal, unified authentication, user management, service gateway, and help center functionalities.
·     x86: general_PLAT_kernel_2.0_version_x86.zip
·     ARM: general_PLAT_kernel_2.0_version_arm.zip
Provides access control, resource identification, license, configuration center, resource group, and log functionalities.
·     x86: general_PLAT_kernel-base_2.0_version_x86.zip
·     ARM: general_PLAT_kernel-base_2.0_version_arm.zip
Provides alarm, access parameter template, monitoring template, report, email, and SMS forwarding functionalities.
·     x86: general_PLAT_network_2.0_version_x86.zip
·     ARM: general_PLAT_network_2.0_version_arm.zip
(Optional.) Provides basic management of network resources, network performance, network topology, and iCC.
Install this application if you are to check match of the software versions with the solution or implement network element monitoring and maintenance.
·     x86: general_PLAT_Dashboard_2.0_version_x86.zip
·     ARM: general_PLAT_Dashboard_2.0_version_arm.zip
Provides the dashboard framework.
·     x86: general_PLAT_widget_2.0_version_x86.zip
·     ARM: general_PLAT_widget_2.0_version_arm.zip
Provides dashboard widget management.
·     x86: general_PLAT_oneclickcheck_2.0_version_x86.zip
·     ARM: general_PLAT_oneclickcheck_2.0_version_arm.zip
Provides one-click check.
·     x86: general_PLAT_kernel-region_2.0_version_x86.zip
·     ARM: general_PLAT_kernel-region_2.0_version_arm.zip
(Optional.) Provides hierarchical management. To use hierarchical management, you need to install the general_ PLAT_ network_ 2.0 application package and use it in tandem with Super Controller for Super Controller to manage DC networks.
Install this application if you need to use the software and solution compatibility check.
·     x86: webdm_version_x86.zip
·     ARM: webdm_version_arm.zip
(Optional.) Provides the device faceplate feature. To use this feature, you need to install the general_PLAT_network_2.0 application package.
·     x86: Syslog-version.zip
·     ARM: Syslog-version_arm.zip
(Optional.) Provides Syslog management (log viewing, log-to-alarm escalation rules, and log parsing).
Install this application package if you are to use syslog management.
·     x86: general_PLAT_netconf_2.0_version_x86.zip
·     ARM: general_PLAT_netconf_2.0_version_arm.zip
(Optional.) Provides NETCONF and NETCONF configuration validity check features.
Install this application package if you are to use NETCONF service.
Application packages required for the analyzer nodes
Multiple component packages are available for SeerAnalyzer. Select the component packages as needed.
Table 8 Installation packages required by analyzer nodes
Component
Unified Platform
common_Linux-<version>.iso
Installation package of the H3C proprietary Linux operating system.
common_PLAT_GlusterFS_2.0_<version>.zip
general_PLAT_portal_2.0_<version>.zip
general_PLAT_kernel_2.0_<version>.zip
general_PLAT_kernel-base_2.0_<version>.zip
general_PLAT_websocket_2.0_<version>.zip
(Optional.) Provide WebSocket service.
This component is required only when the analyzer is deployed on the cloud.
general_PLAT_network_2.0_<version>.zip
Install this application if third-party devices are incorporated on the analyzer.
ITOA-Syslog-<version>.zip
(Optional.) Syslog application.
If the northbound service VIP is used for log collection, the analyzer uses the syslog application on Unified Platform. You must install the syslog application on Unified Platform prior to SeerAnalyzer.
If the southbound service VIP is used for log collection, the analyzer does not require this application.
In the scenario where Analyzer-LGA is deployed on a separate server, you must install the syslog application.
general_PLAT_Dashboard_<version>.zip
Dashboard framework.
general_PLAT_widget_2.0_<version>.zip
Platform dashboard widget.
Analyzer-Collector_<version>.zip
Install this package when deploying the analyzer.
general_PLAT_kernel-region_2.0_<version>.zip
(Optional.) To use IOM proxy in the Analyzer-LGA scenario, install this application.
IOM
COLLECTPLAT_<version>.zip
(Optional.) Contains the cmc/etcd service and provides features including collection platform configuration management center, alarm computing service, data distribution service, ETCD, task distribution service. To use IOM proxy in the Analyzer-LGA deployment scenario, install this application.
AGENT_<version>.zip
(Optional.) Provides agent management. To use IOM proxy in the Analyzer-LGA deployment scenario, install this application.
AGENT_RECEIVER_<version>.zip
(Optional.) Provides agent data receipt. To use IOM proxy in the Analyzer-LGA deployment scenario, install this application.
AGENT_UPDATER_<version>.zip
(Optional.) Provides automatic agent update. To use IOM proxy in the Analyzer-LGP deployment scenario, install this application.
SeerAnalyzer
Analyzer-Platform-<version>.zip
Platform component package.
Analyzer-Telemetry-<version>.zip
Telemetry component package.
Analyzer-NPA-<version>.zip
Network performance analysis component package.
Analyzer-AI-<version>.zip
AI-driven forecast component package.
Analyzer-Diagnosis-<version>.zip
Diagnosis and analysis component package.
Analyzer-SLA-<version>.zip
Service quality analysis component package.
Analyzer-TCP-<version>.zip
TCP stream analysis component package.
Analyzer-WAN-<version>.zip
WAN application analysis component package.
Analyzer-User-<version>.zip
User analysis component package.
Analyzer-AV-<version>.zip
Audio and video analysis component package.
Analyzer-LGA-<version>.zip
Log analysis component package.
Analyzer-TRA-<version>.zip
Trace analytics component package.
H3Linux
common_H3Linux-<version>.iso
SeerCollector operating system image file.
NPA traffic collector
H3CData-<version>.zip
Collects and sends traffic data to NPA (required in the NPA sceanario).
Deploy SeerEngine-DC, vBGP, DTN, and Super Controller
Before deploying SeerEngine-DC, make sure the general_PLAT_kernel-base_2.0, general_PLAT_Dashboard_2.0, and general_PLAT_widget_2.0 installation packages have been uploaded. These application packages will be automatically deployed during the SeerEngine-DC deployment process.
For information about the SeerEngine-DC, vBGP, and DTN deployment procedures and required application installation packages, see H3C SeerEngine-DC Controller Installation Guide (Unified Platform). For information about how to obtain the document, see "Appendix A  Obtain documentation".
For information about the Super Controller deployment procedure and required application installation packages, see H3C Super Controller Installation Guide (Unified Platform). For information about how to obtain the document, see "Appendix A  Obtain documentation".
As a best practice, use the non-RDRS scheme for this solution.
Deploy SeerAnalyzer, collectors, and Super Analyzer-DC
For information about the SeerAnalyzer deployment procedure and required application installation packages, see H3C SeerAnalyzer Deployment Guide. For information about how to obtain the document, see "Appendix A  Obtain documentation."
Follow these restrictions and guidelines when you deploy SeerAnalyzer and collectors:
1.     To plan the network configuration, see network planning for single-stack southbound network in H3C SeerAnalyzer Deployment Guide.
2.     After switching devices are deployed, use an interface on each collector to connect to a leaf device and change the NIC type to DPDK for traffic collection.
For information about the Super Analyzer-DC deployment procedure and required application packages, see H3C Super Analyzer-DC Deployment Guide. For information about how to obtain the document, see "Appendix A  Obtain documentation".
Operations monitoring
For information about operations monitoring for this solution, see AD-DC 6.3 Operations Monitoring Configuration Guide.
To obtain documentation for installing Unified Platform and its components:
1.     Access the website at https://www.h3c.com/en/Support/Resource_Center/Technical_Documents/.
2.     Select the product category and model and then obtain the document.
Use the following table to obtain the desired documents:
Product name
Manual name
Directory
Unified Platform
H3C Unified Platform Deployment Guide-E0708
SDN/SeerEngine-DC/Install & Upgrade
SeerEngine-DC
H3C SeerEngine-DC Installation Guide (Unified Platform )-E63xx
SeerAnalyzer
H3C SeerAnalyzer Deployment Guide-E63xx
Super Controller
H3C Super Controller Installation Guide (Unified Platform)-E31xx-5W100
Super Analyzer-DC
H3C Super Analyzer-DC Deployment Guide-E63xx
SDN/Super Analyzer-DC/Install & Upgrade
