Title | Size | Downloads |
H3C LSWM12H2Q Interface Card User Manual-6PW102-book.pdf | 268.80 KB |
▌Introduction
Overview
The LSWM12H2Q interface card provides two QSFP28 ports and two QSFP+ ports.
Figure 1 Front panel
(1) QSFP+ port LED |
(2) QSFP28 port LED |
(3) QSFP28 port |
(4) QSFP+ port |
QSFP+ ports
You can install the following transceiver modules and cables in the QSFP+ ports on the card:
· QSFP+ transceiver modules in Table 1 and Table 2.
· QSFP+ DAC cables in Table 3.
· QSFP+ to SFP+ DAC cables in Table 4.
· QSFP+ AOC cables in Table 5.
Table 1 QSFP+ transceiver modules available for the QSFP+ ports (1)
QSFP+ transceiver module |
Central wavelength (nm) |
Connector |
QSFP-40G-SR4-MM850 |
850 |
MPO |
QSFP-40G-CSR4-MM850 |
850 |
MPO |
QSFP-40G-LR4-WDM1300 |
Four lanes: · 1271 · 1291 · 1311 · 1331 |
LC |
QSFP-40G-LR4L-WDM1300 |
LC |
Table 2 QSFP+ transceiver modules available for the QSFP+ ports (2)
Cable/fiber diameter (µm) |
Modal bandwidth (MHz × km) |
Max transmission distance |
Multi-mode, 50/125 |
2000 |
100 m (328.08 ft) |
4700 |
150 m (492.12 ft) |
2000 |
300 m (984.25 ft) |
4700 |
400 m (1312.33 ft) |
Single-mode, 9/125 |
N/A |
10 km (6.21 miles) |
N/A |
2 km (1.24 miles) |
Table 3 QSFP+ DAC cables available for the QSFP+ ports
QSFP+ DAC cable |
Cable length |
Data rate |
LSWM1QSTK0 |
1 m (3.28 ft) |
40 Gbps |
LSWM1QSTK1 |
3 m (9.84 ft) |
LSWM1QSTK2 |
5 m (16.40 ft) |
Table 4 QSFP+ to SFP+ DAC cables available for the QSFP+ ports
QSFP+ to SFP+ DAC cable |
Cable length |
Data rate |
LSWM1QSTK3 |
1 m (3.28 ft) |
40 Gbps |
LSWM1QSTK4 |
3 m (9.84 ft) |
LSWM1QSTK5 |
5 m (16.40 ft) |
Table 5 QSFP+ AOC cables available for the QSFP+ ports
QSFP+ AOC cable |
Cable length |
Data rate |
QSFP-40G-D-AOC-7M |
7 m (22.97 ft) |
40 Gbps |
QSFP-40G-D-AOC-10M |
10 m (32.81 ft) |
QSFP-40G-D-AOC-20M |
20 m (65.62 ft) |
NOTE: As a best practice, use H3C QSFP+ transceiver modules, QSFP+ DAC cables, QSFP+ to SFP+ DAC cables, and QSFP+ AOC cables for the QSFP+ ports on the LSWM12H2Q interface card. The H3C QSFP+ transceiver modules and QSFP+ cables available for the card are subject to change over time. For the most recent list of H3C QSFP+ transceiver modules and QSFP+ cables available for the card, contact H3C Support or marketing staff. |
For more information about H3C QSFP+ transceiver modules and QSFP+ cables, see H3C Transceiver Modules User Guide at www.h3c.com.
QSFP28 ports
You can install the following transceiver modules and cables in the QSFP28 ports on the card:
· QSFP28 transceiver modules in Table 6 and Table 7.
· QSFP28 DAC cables in Table 8.
Table 6 QSFP28 transceiver modules available for the QSFP28 ports (1)
QSFP28 transceiver module |
Connector |
QSFP-100G-SR4-MM850 |
850 |
MPO (PC polished, 12-core) |
QSFP-100G-LR4-WDM1300 |
Four lanes: · 1295 · 1300 · 1304 · 1309 |
LC |
Table 7 QSFP28 transceiver modules available for the QSFP28 ports (2)
4700 |
100 m (328.08 ft) |
N/A |
Table 8 QSFP28 DAC cables available for the QSFP28 ports
QSFP28 DAC cable |
Cable length |
Data rate |
QSFP-100G-D-CAB-1M |
1 m (3.28 ft) |
100 Gbps |
QSFP-100G-D-CAB-3M |
3 m (9.84 ft) |
NOTE: As a best practice, use H3C QSFP+/QSFP28 transceiver modules and QSFP+/QSFP28 DAC cables for the QSFP28 ports on the LSWM12H2Q interface card. The H3C QSFP+/QSFP28 transceiver modules and QSFP+/QSFP28 DAC cables available for the card are subject to change over time. For the most recent list of H3C QSFP+/QSFP28 transceiver modules and QSFP+/QSFP28 DAC cables available for the card, contact H3C Support or marketing staff. |
For more information about H3C QSFP+/QSFP28 transceiver modules and QSFP+/QSFP28 DAC cables, see H3C Transceiver Modules User Guide at www.h3c.com.
LEDs
Table 9 describes QSFP28 port LEDs and QSFP+ port LEDs on the front panel.
Table 9 QSFP28 port LED description
LED status |
Steady green |
A transceiver module is installed in the port. The port is operating at 100 Gbps, and a link is present on the port. |
Flashing green |
The port is sending or receiving data at 100 Gbps. |
Steady yellow |
A transceiver module is installed in the port. The port is operating at 10/40 Gbps, and a link is present on the port. |
Flashing yellow (3 Hz) |
The port is sending or receiving data at 10/40 Gbps. |
Off |
No transceiver module is installed in the port, or no link is present on the port. |
Table 10 QSFP+ port LED description
LED status |
Steady green |
A transceiver module is installed in the port. The port is operating at 40 Gbps, and a link is present on the port. |
Flashing green |
The port is sending or receiving data at 40 Gbps. |
Steady yellow |
A transceiver module is installed in the port. The port is operating at 10 Gbps, and a link is present on the port. |
Flashing yellow |
The port is sending or receiving data at 10 Gbps. |
Off |
NOTE: The QSFP28 port LEDs and QSFP+ port LEDs are not affected by the port LED mode switching button on your switch. For more information about the port LED mode switching button, see the installation guide for the switch. |
▌Installing and removing the card
CAUTION: · Before you install or remove the card, wear an ESD wrist strap and make sure the strap makes good skin contact and is reliably grounded. · To avoid device damage, do not use excessive force when you install or remove the card. |
Installing the card
1. Remove the filler panel (if any) from the target slot.
Keep the removed filler panel secure for future use.
2. Unpack the interface card.
Figure 2 LSWM12H2Q interface card
(1) Ejector lever |
(2) Latch |
3. Press the latch on the card to release the ejector lever.
4. As shown by callout 1 in Figure 3, insert the card slowly into the slot along the guide rails.
5. Rotate inward the ejector lever as shown by callout 2 in Figure 3 until the latch locks the ejector lever in place.
Figure 3 Installing the LSWM12H2Q interface card
Removing the card
CAUTION: To avoid cable damage, remove the cables from the card before removing the card. |
To remove the card:
1. Prepare an anti-static bag.
2. Press the latch to release the ejector lever
3. Rotate outward the ejector lever as shown by callout 1 in Figure 4.
4. Pull out the interface card slowly out of the interface card slot, as shown by callout 2 in Figure 4.
5. Place the removed interface card in the anti-static bag.
6. If you are not to install a new card, install a filler panel in the slot to prevent dust and ensure good ventilation in the device.
Figure 4 Removing the LSWM12H2Q interface card
Installing and removing QSFP28/QSFP+ transceiver modules and cables
For information about installing and removing QSFP28/QSFP+ transceiver modules and cables, see H3C Transceiver Modules and Network Cables Installation Guide at www.h3c.com.
Verifying the installation
After the installation is complete, determine whether the card is operating correctly.
If the card fails to operate correctly, perform the following steps:
1. Reinstall the card following the installation procedures described in this document.
2. If the problem persists, contact H3C Support.
▌Technical support
New H3C Technologies Co., Ltd. provides customers with comprehensive technical support and service. If you purchase the products from the sales agent of New H3C Technologies Co., Ltd., please contact our sales agent or technical personnel.
Website: http://www.h3c.com
BOM: 3101A0L1
